RTEMS
5.1
RTD316 driver interface defintions. More...
#define | RTD316_DRIVER_TABLE_ENTRY { rtd316_initialize, NULL, NULL, NULL, NULL, NULL } |
rtems_device_driver | rtd316_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTD316 Initialization Entry Point. More... | |
uint8_t | rtd316_com_get_register (uint32_t addr, uint8_t reg) |
RTD316 Obtain Register Helper. More... | |
void | rtd316_com_set_register (uint32_t addr, uint8_t reg, uint8_t val) |
RTD316 Set Register Helper. More... | |
This macro defines the standard device driver table entry for a console device driver.
uint8_t rtd316_com_get_register | ( | uint32_t | addr, |
uint8_t | reg | ||
This method is used to read registers on the RTD316.
[in] | addr | is the base address |
[in] | reg | is the register number |
void rtd316_com_set_register | ( | uint32_t | addr, |
uint8_t | reg, | ||
uint8_t | val | ||
This method is used to set registers on the RTD316.
rtems_device_driver rtd316_initialize | ( | rtems_device_major_number | major, |
rtems_device_minor_number | minor, | ||
void * | arg | ||
This method initializes the RTD316 device driver.
[in] | major | is the device driver major number |
[in] | minor | is the device driver minor number |
[in] | arg | is the parameters to this call |
