RTEMS  5.1
tm27.h
1 /*
2  * @file
3  * @ingroup powerpc_mvme5500
4  * @brief Implementations for interrupt mechanisms for Time Test 27
5  */
6
7 /*
8  * The license and distribution terms for this file may be
9  * found in the file LICENSE in this distribution or at
10  * http://www.rtems.org/license/LICENSE.
11  */
12
13 #ifndef _RTEMS_TMTEST27
14 #error "This is an RTEMS internal file you must not include directly."
15 #endif
16
17 #ifndef __tm27_h
18 #define __tm27_h
19
20 #include <bsp/irq.h>
21
22 /*
23  * Stuff for Time Test 27
24  */
25
26 #define MUST_WAIT_FOR_INTERRUPT 1
27
28 static void nullFunc(void) {}
29 static rtems_irq_connect_data clockIrqData = {BSP_DECREMENTER,
30  0,
31  (rtems_irq_enable)nullFunc,
32  (rtems_irq_disable)nullFunc,
33  (rtems_irq_is_enabled) nullFunc};
34
35 RTEMS_INLINE_ROUTINE void Install_tm27_vector(void (*_handler)())
36 {
37  clockIrqData.hdl = _handler;
38  if (!BSP_install_rtems_irq_handler (&clockIrqData)) {
39  printk("Error installing clock interrupt handler!\n");
41  }
42 }
43
44 #define Cause_tm27_intr() \
45  do { \
46  uint32_t _clicks = 1; \
47  __asm__ volatile( "mtdec %0" : "=r" ((_clicks)) : "r" ((_clicks)) ); \
48  } while (0)
49
50
51 #define Clear_tm27_intr() \
52  do { \
53  uint32_t _clicks = 0xffffffff; \
54  __asm__ volatile( "mtdec %0" : "=r" ((_clicks)) : "r" ((_clicks)) ); \
55  } while (0)
56
57 #define Lower_tm27_intr() \
58  do { \
59  uint32_t _msr = 0; \
60  _ISR_Set_level( 0 ); \
61  __asm__ volatile( "mfmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
62  _msr |= 0x8002; \
63  __asm__ volatile( "mtmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
64  } while (0)
65
66 #endif
void rtems_fatal_error_occurred(uint32_t the_error) RTEMS_NO_RETURN
Invokes the internal error handler with a source of INTERNAL_ERROR_RTEMS_API and is internal set to f...
Definition: fatal.c:28
Definition: irq.h:45
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
int BSP_install_rtems_irq_handler(const rtems_irq_connect_data *cd)
Definition: irq-legacy.c:44
int printk(const char *fmt,...) RTEMS_PRINTFLIKE(1
Kernel Print.
