RTEMS  5.1
m360_spi.h
1
9 /*===============================================================*\
10 | Project: RTEMS support for MC68360 |
11 +-----------------------------------------------------------------+
12 | Copyright (c) 2008 |
13 | Embedded Brains GmbH |
14 | Obere Lagerstr. 30 |
15 | D-82178 Puchheim |
16 | Germany |
17 | rtems@embedded-brains.de |
18 +-----------------------------------------------------------------+
19 | The license and distribution terms for this file may be |
20 | found in the file LICENSE in this distribution or at |
21 | |
22 | http://www.rtems.org/license/LICENSE. |
23 | |
24 \*===============================================================*/
25
34 #ifndef _M360_SPIDRV_H
35 #define _M360_SPIDRV_H
36
37 #include <rtems/m68k/m68360.h>
38 #include <rtems/libi2c.h>
39 #include <rtems/irq.h>
40
41 #ifdef __cplusplus
42 extern "C" {
43 #endif
44
45 typedef struct m360_spi_softc {
46  int initialized;
47  rtems_id irq_sema_id;
48  rtems_isr_entry old_handler;
52
53 typedef struct {
54  rtems_libi2c_bus_t bus_desc;
55  m360_spi_softc_t softc;
57
58 /*=========================================================================*\
59 | Function: |
60 \*-------------------------------------------------------------------------*/
61 rtems_status_code m360_spi_init
62 (
63 /*-------------------------------------------------------------------------*\
64 | Purpose: |
65 | initialize the driver |
66 +---------------------------------------------------------------------------+
67 | Input Parameters: |
68 \*-------------------------------------------------------------------------*/
69  rtems_libi2c_bus_t *bh /* bus specifier structure */
70  );
71 /*-------------------------------------------------------------------------*\
72 | Return Value: |
73 | o = ok or error code |
74 \*=========================================================================*/
75
76 /*=========================================================================*\
77 | Function: |
78 \*-------------------------------------------------------------------------*/
79 int m360_spi_read_bytes
80 (
81 /*-------------------------------------------------------------------------*\
82 | Purpose: |
83 | receive some bytes from SPI device |
84 +---------------------------------------------------------------------------+
85 | Input Parameters: |
86 \*-------------------------------------------------------------------------*/
87  rtems_libi2c_bus_t *bh, /* bus specifier structure */
88  unsigned char *buf, /* buffer to store bytes */
89  int len /* number of bytes to receive */
90  );
91 /*-------------------------------------------------------------------------*\
92 | Return Value: |
93 | number of bytes received or (negative) error code |
94 \*=========================================================================*/
95
96 /*=========================================================================*\
97 | Function: |
98 \*-------------------------------------------------------------------------*/
99 int m360_spi_write_bytes
100 (
101 /*-------------------------------------------------------------------------*\
102 | Purpose: |
103 | send some bytes to SPI device |
104 +---------------------------------------------------------------------------+
105 | Input Parameters: |
106 \*-------------------------------------------------------------------------*/
107  rtems_libi2c_bus_t *bh, /* bus specifier structure */
108  unsigned char *buf, /* buffer to send */
109  int len /* number of bytes to send */
110
111  );
112 /*-------------------------------------------------------------------------*\
113 | Return Value: |
114 | number of bytes sent or (negative) error code |
115 \*=========================================================================*/
116
117 /*=========================================================================*\
118 | Function: |
119 \*-------------------------------------------------------------------------*/
120 rtems_status_code m360_spi_set_tfr_mode
121 (
122 /*-------------------------------------------------------------------------*\
123 | Purpose: |
124 | set SPI to desired baudrate/clock mode/character mode |
125 +---------------------------------------------------------------------------+
126 | Input Parameters: |
127 \*-------------------------------------------------------------------------*/
128  rtems_libi2c_bus_t *bh, /* bus specifier structure */
129  const rtems_libi2c_tfr_mode_t *tfr_mode /* transfer mode info */
130  );
131 /*-------------------------------------------------------------------------*\
132 | Return Value: |
133 | rtems_status_code |
134 \*=========================================================================*/
135
136 /*=========================================================================*\
137 | Function: |
138 \*-------------------------------------------------------------------------*/
139 int m360_spi_ioctl
140 (
141 /*-------------------------------------------------------------------------*\
142 | Purpose: |
143 | perform selected ioctl function for SPI |
144 +---------------------------------------------------------------------------+
145 | Input Parameters: |
146 \*-------------------------------------------------------------------------*/
147  rtems_libi2c_bus_t *bh, /* bus specifier structure */
148  int cmd, /* ioctl command code */
149  void *arg /* additional argument array */
150  );
151 /*-------------------------------------------------------------------------*\
152 | Return Value: |
153 | rtems_status_code |
154 \*=========================================================================*/
155
156 #ifdef __cplusplus
157 }
158 #endif
159
160
161 #endif /* _M360_SPIDRV_H */
Definition: libi2c.h:162
Definition: m360_spi.h:53
rtems_status_code
Classic API Status.
Definition: status.h:43
Definitions for Motorola MC68360 Processor.
Definition: libi2c.h:462
Definition: m68360.h:403
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Legacy I2C Library.
Definition: m360_spi.h:45
