RTEMS
5.1
ISR Level Type. More...
#define | _ISR_Local_disable(_level) |
Disables interrupts on this processor. More... | |
#define | _ISR_Local_enable(_level) |
Enables interrupts on this processor. More... | |
#define | _ISR_Local_flash(_level) |
Temporarily enables interrupts on this processor. More... | |
#define | _ISR_Is_enabled(_level) _CPU_ISR_Is_enabled( _level ) |
Returns true if interrupts are enabled in the specified interrupt level, otherwise returns false. More... | |
#define | _ISR_Get_level() _CPU_ISR_Get_level() |
Return current interrupt level. More... | |
#define | _ISR_Set_level(_new_level) |
Set current interrupt level. More... | |
Typedefs | |
typedef uint32_t | ISR_Level |
ISR Level Type.
This include file defines the ISR Level type. It exists to simplify include dependencies. It is part of the ISR Handler.
