RTEMS  5.1
isr.h
1
14 /*
15  * COPYRIGHT (c) 1989-2012.
16  * On-Line Applications Research Corporation (OAR).
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef _RTEMS_SCORE_ISR_H
24 #define _RTEMS_SCORE_ISR_H
25
26 #include <rtems/score/isrlevel.h>
27
44 #ifdef __cplusplus
45 extern "C" {
46 #endif
47
51 typedef uint32_t ISR_Vector_number;
52
56 typedef void ISR_Handler;
57
58 #if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
59
60 typedef void * ISR_Handler_entry;
61
62 #else
63
66 #if (CPU_ISR_PASSES_FRAME_POINTER == TRUE)
67 typedef ISR_Handler ( *ISR_Handler_entry )(
70  );
71 #else
72 typedef ISR_Handler ( *ISR_Handler_entry )(
74  );
75 #endif
76
81 extern ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
82 #endif
83
90 RTEMS_DECLARE_GLOBAL_SYMBOL( _ISR_Stack_size );
91
99 extern char _ISR_Stack_area_begin[];
100
108 extern const char _ISR_Stack_area_end[];
109
115 void _ISR_Handler_initialization ( void );
116
134 #define _ISR_Install_vector( _vector, _new_handler, _old_handler ) \
135  _CPU_ISR_install_vector( _vector, _new_handler, _old_handler )
136
151 void _ISR_Handler( void );
152
163 bool _ISR_Is_in_progress( void );
164
165 #ifdef __cplusplus
166 }
167 #endif
168
171 #endif
172 /* end of include file */
The interrupt stack area begin.
bool _ISR_Is_in_progress(void)
Checks if an ISR in progress.
Definition: nios2-isr-is-in-progress.c:23
Interrupt stack frame (ISF).
Definition: cpu.h:191
ISR Level Type.
RTEMS_DECLARE_GLOBAL_SYMBOL(_ISR_Stack_size)
Global symbol with a value equal to the configure interrupt stack size.
#define CPU_INTERRUPT_NUMBER_OF_VECTORS
Definition: cpu.h:686
void _ISR_Handler(void)
ISR interrupt dispatcher.
Definition: cpu_asm.c:126
void _ISR_Handler_initialization(void)
Initializes the ISR handler.
Definition: isr.c:36
The interrupt stack area end.
Definition: isr.h:51
void ISR_Handler
Definition: isr.h:56
