RTEMS  5.1
interr.h
1
12 /*
13  * COPYRIGHT (c) 1989-2009.
14  * On-Line Applications Research Corporation (OAR).
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_SCORE_INTERR_H
22 #define _RTEMS_SCORE_INTERR_H
23
24 #include <rtems/score/cpu.h>
25
39 #ifdef __cplusplus
40 extern "C" {
41 #endif
42
47 typedef enum {
54
59
64
71
78
85
95
104
111
120
127
134
141
148
157
165 typedef enum {
166  /* INTERNAL_ERROR_NO_CONFIGURATION_TABLE = 0, */
167  /* INTERNAL_ERROR_NO_CPU_TABLE = 1, */
168  INTERNAL_ERROR_TOO_LITTLE_WORKSPACE = 2,
169  /* INTERNAL_ERROR_WORKSPACE_ALLOCATION = 3, */
170  /* INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL = 4, */
171  INTERNAL_ERROR_THREAD_EXITTED = 5,
172  INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION = 6,
173  INTERNAL_ERROR_INVALID_NODE = 7,
174  INTERNAL_ERROR_NO_MPCI = 8,
175  INTERNAL_ERROR_BAD_PACKET = 9,
176  INTERNAL_ERROR_OUT_OF_PACKETS = 10,
177  INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS = 11,
178  INTERNAL_ERROR_OUT_OF_PROXIES = 12,
179  INTERNAL_ERROR_INVALID_GLOBAL_ID = 13,
180  INTERNAL_ERROR_BAD_STACK_HOOK = 14,
181  /* INTERNAL_ERROR_BAD_ATTRIBUTES = 15, */
182  /* INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY = 16, */
183  /* INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL = 17, */
184  /* INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_FROM_BAD_STATE = 18, */
185  /* INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0 = 19, */
186  /* INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP = 20, */
187  INTERNAL_ERROR_GXX_KEY_ADD_FAILED = 21,
188  INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED = 22,
189  INTERNAL_ERROR_NO_MEMORY_FOR_HEAP = 23,
190  INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR = 24,
191  INTERNAL_ERROR_RESOURCE_IN_USE = 25,
192  INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL = 26,
193  /* INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL = 27, */
194  INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK = 28,
195  INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE = 29,
196  INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL = 30,
197  INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT = 31,
198  INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED = 32,
199  INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED = 33,
200  /* INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED = 34, */
201  /* INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED = 35, */
202  INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED = 36,
203  INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED = 37,
204  INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT = 38,
205  INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL = 39,
206  INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA = 40
208
209 typedef CPU_Uint32ptr Internal_errors_t;
210
214 typedef struct {
218  Internal_errors_t the_error;
220
225
263 void _Terminate(
264  Internal_errors_Source the_source,
265  Internal_errors_t the_error
267
277
278 #ifdef __cplusplus
279 }
280 #endif
281
284 #endif
285 /* end of include file */
Internal_errors_Core_list
A list of errors which are generated internally by the executive core.
Definition: interr.h:165
Fatal source for the block device cache.
Definition: interr.h:70
Fatal source of SMP domain.
Definition: interr.h:126
Fatal source of assert().
Definition: interr.h:103
Errors of the RTEMS API.
Definition: interr.h:58
void _Terminate(Internal_errors_Source the_source, Internal_errors_t the_error) RTEMS_NO_RETURN
Initiates system termination.
Definition: interr.c:31
Fatal source of the exceptions.
Definition: interr.h:119
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
Fatal source for invalid C program heap frees via free().
Definition: interr.h:140
Errors of the POSIX API.
Definition: interr.h:63
Fatal source for heap errors.
Definition: interr.h:147
This type lists the possible sources from which an error can be reported.
Definition: interr.h:47
Internal_errors_Information _Internal_errors_What_happened
Definition: interr.c:29
Fatal source of rtems_panic().
Definition: interr.h:133
Errors of the core system.
Definition: interr.h:53
Definition: interr.h:214
Fatal source of exit().
Definition: interr.h:84
Fatal source for BSP errors.
Definition: interr.h:94
The last available fatal source.
Definition: interr.h:155
Fatal source for application specific errors.
Definition: interr.h:77
void _Internal_error(Internal_errors_Core_list core_error) RTEMS_NO_RETURN
Terminates the system with an INTERNAL_ERROR_CORE fatal source and the specified core error code.
Definition: interr.c:51
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
Definition: interr.h:216
Definition: interr.h:218
Fatal source of the stack checker.
Definition: interr.h:110
