RTEMS  5.1
Files | Data Structures | Macros | Enumerations | Functions
Input Devices for MicroWindows
file  mw_uid.h
 Input Devices for MicroWindows.
file  mw_print.c
 MicroWindows Print.
file  mw_uid.c
 MicroWindows UID.
struct  MW_UID_MESSAGE
#define MW_UID_REGISTER_DEVICE   0x4100
#define MW_UID_UNREGISTER_DEVICE   0x4101
#define MV_BUTTON_RIGHT   0x01
#define MV_BUTTON_CENTER   0x02
#define MV_BUTTON_LEFT   0x04
#define MV_KEY_MODIFIER_SHIFT_DOWN   0x10
#define MV_KEY_MODIFIER_ALT_DOWN   0x20
#define MV_KEY_MODIFIER_CAPS_ON   0x04
#define MV_KEY_MODIFIER_NUN_LOCK_ON   0x02
#define MV_KEY_SCROLL_LOCK_ON   0x01
#define MV_KEY_MODE_ASCII   0x01
#define MV_KEY_MODE_SCANCODE   0x00
#define MV_KDGKBMODE   0x4B44 /* gets current keyboard mode */
#define MV_KDSKBMODE   0x4B45 /* sets current keyboard mode */
enum  MW_INPUT_DEVICE_TYPE {
  MV_UID_INVALID = 0, MV_UID_REL_POS = 1, MV_UID_ABS_POS = 2, MV_UID_KBD = 3,
  MV_UID_TIMER = 4
int uid_open_queue (const char *q_name, int flags, size_t max_msgs)
int uid_close_queue (void)
int uid_read_message (struct MW_UID_MESSAGE *m, unsigned long timeout)
int uid_send_message (struct MW_UID_MESSAGE *m)
int uid_register_device (int fd, const char *q_name)
int uid_unregister_device (int fd)
int uid_set_kbd_mode (int fd, int mode, int *old_mode)
void uid_print_message (struct MW_UID_MESSAGE *uid)
void uid_print_message_with_plugin (const rtems_printer *printer, struct MW_UID_MESSAGE *uid)
◆ uid_close_queue()
int uid_close_queue ( void  )
This method closes the message queue and deletes it.
Return values
Thismethod returns 0 on success and -1 on error.
◆ uid_open_queue()
int uid_open_queue ( const char *  q_name,
int  flags,
size_t  max_msgs
This method creates the message queue that holds events from the input devices.
Parameters
[in]q_nameis the name of the message queue
[in]flagscontrols the behaviour of the queue
[in]max_msgsspecifies the maximum number of pending messages
Note
The message queue is from the Classic API.
Return values
◆ uid_print_message()
void uid_print_message ( struct MW_UID_MESSAGE uid)
This methods prints the specified UID message using printk
Parameters
[in]uidpoints to the message to print
◆ uid_print_message_with_plugin()
void uid_print_message_with_plugin ( const rtems_printer printer,
This methods prints the specified UID message using your fprintf style method of choice.
Parameters
[in]RTEMSprinter
◆ uid_read_message()
int uid_read_message ( struct MW_UID_MESSAGE m,
This method reads a message from the queue. It waits up to the specified timeout in miliseconds. A timeout of 0 is a poll.
Parameters
[in]mwill be filled in with the received message
[in]timeoutis the maximum number of mulliseconds to wait
Return values
◆ uid_register_device()
int uid_register_device ( int  fd,
const char *  q_name
This method registers the device associated with fd to to insert data to the queue
◆ uid_send_message()
int uid_send_message ( struct MW_UID_MESSAGE m)
This methods writes a message to the queue.
Parameters
[in]mis the message to send
Return values
