RTEMS
5.1
void | MCAN_Init (const MCan_ConfigType *mcanConfig) |
Initializes the MCAN hardware for giving peripheral. Default: Mixed mode TX Buffer + FIFO. More... | |
void | MCAN_InitFdEnable (const MCan_ConfigType *mcanConfig) |
Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More... | |
void | MCAN_InitFdBitRateSwitchEnable (const MCan_ConfigType *mcanConfig) |
Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More... | |
void | MCAN_InitLoopback (const MCan_ConfigType *mcanConfig) |
Initializes the MCAN in loop back mode. INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More... | |
void | MCAN_InitTxQueue (const MCan_ConfigType *mcanConfig) |
Initializes MCAN queue for TX INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More... | |
void | MCAN_Enable (const MCan_ConfigType *mcanConfig) |
Enable MCAN peripheral. INIT must be set - so this should be called between MCAN_Init() More... | |
void | MCAN_RequestIso11898_1 (const MCan_ConfigType *mcanConfig) |
Requests switch to Iso11898-1 (standard / classic) mode (tx & rx payloads up to 8 bytes). More... | |
void | MCAN_RequestFd (const MCan_ConfigType *mcanConfig) |
Requests switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching. requested mode should have been enabled at initialization. More... | |
void | MCAN_RequestFdBitRateSwitch (const MCan_ConfigType *mcanConfig) |
Request switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching. requested mode should have been enabled at initialization. More... | |
void | MCAN_LoopbackOn (const MCan_ConfigType *mcanConfig) |
Switch on loop back mode. TEST must be set in MCAN_CCCR - e.g. by a prior call to MCAN_InitLoopback() More... | |
void | MCAN_LoopbackOff (const MCan_ConfigType *mcanConfig) |
Switch off loop back mode. More... | |
void | MCAN_IEnableMessageStoredToRxDedBuffer (const MCan_ConfigType *mcanConfig, MCan_IntrLineType line) |
Enable message line and message stored to Dedicated Receive Buffer Interrupt Line. More... | |
uint8_t * | MCAN_ConfigTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, uint32_t id, MCan_IdType idType, MCan_DlcType dlc) |
Configures a Dedicated TX Buffer. More... | |
void | MCAN_SendTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer) |
Send Tx buffer. More... | |
uint32_t | MCAN_AddToTxFifoQ (const MCan_ConfigType *mcanConfig, uint32_t id, MCan_IdType idType, MCan_DlcType dlc, uint8_t *data) |
Adds Message to TX Fifo / Queue. More... | |
uint8_t | MCAN_IsBufferTxd (const MCan_ConfigType *mcanConfig, uint8_t buffer) |
Check if data transmitted from buffer/fifo/queue. More... | |
void | MCAN_ConfigRxBufferFilter (const MCan_ConfigType *mcanConfig, uint32_t buffer, uint32_t filter, uint32_t id, MCan_IdType idType) |
Configure RX Buffer Filter ID must match exactly for a RX Buffer Filter. More... | |
void | MCAN_ConfigRxClassicFilter (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, uint8_t filter, uint32_t id, MCan_IdType idType, uint32_t mask) |
Configure Classic Filter Classic Filters direct accepted messages to a FIFO & include both a ID and a ID mask. More... | |
uint8_t | MCAN_IsNewDataInRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer) |
check if data received into buffer More... | |
void | MCAN_GetRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, Mailbox64Type *pRxMailbox) |
Get Rx buffer. More... | |
uint32_t | MCAN_GetRxFifoBuffer (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, Mailbox64Type *pRxMailbox) |
Get from the receive FIFO and place in a application mailbox. More... | |
const MCan_ConfigType | mcan0Config |
const MCan_ConfigType | mcan1Config |
#define MCAN0_BRP |
#define MCAN0_FBRP |
#define MCAN0_RX_DED_BUFS_WRDS |
#define MCAN0_RX_FIFO0_WRDS |
#define MCAN0_RX_FIFO1_WRDS |
#define MCAN0_TX_DED_BUF_WRDS |
#define MCAN0_TX_FIFO_Q_WRDS |
#define MCAN1_BRP |
#define MCAN1_FBRP |
#define MCAN1_RX_DED_BUFS_WRDS |
#define MCAN1_RX_FIFO0_WRDS |
#define MCAN1_RX_FIFO1_WRDS |
#define MCAN1_TX_DED_BUF_WRDS |
#define MCAN1_TX_FIFO_Q_WRDS |
uint32_t MCAN_AddToTxFifoQ | ( | const MCan_ConfigType * | mcanConfig, |
uint32_t | id, | ||
MCan_IdType | idType, | ||
MCan_DlcType | dlc, | ||
uint8_t * | data | ||
mcanConfig | Pointer to a MCAN instance. |
id | Message ID. |
idType | Type of ID |
dlc | Type of dlc. |
data | Pointer to data. |
void MCAN_ConfigRxBufferFilter | ( | const MCan_ConfigType * | mcanConfig, |
uint32_t | buffer, | ||
uint32_t | filter, | ||
uint32_t | id, | ||
MCan_IdType | idType | ||
buffer | Pointer to data buffer. |
filter | data of filter. |
void MCAN_ConfigRxClassicFilter | ( | const MCan_ConfigType * | mcanConfig, |
MCan_FifoType | fifo, | ||
uint8_t | filter, | ||
uint32_t | id, | ||
uint32_t | mask | ||
fifo | fifo Number. |
mask | Mask to be match |
uint8_t* MCAN_ConfigTxDedBuffer | ( | const MCan_ConfigType * | mcanConfig, |
uint8_t | buffer, | ||
uint32_t | id, | ||
MCan_DlcType | dlc | ||
buffer | Pointer to buffer. |
id | Message ID. |
void MCAN_Enable | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_GetRxDedBuffer | ( | const MCan_ConfigType * | mcanConfig, |
Mailbox64Type * | pRxMailbox | ||
Get Rx buffer.
pRxMailbox | Pointer to rx Mailbox. |
uint32_t MCAN_GetRxFifoBuffer | ( | const MCan_ConfigType * | mcanConfig, |
fifo | Fifo Number |
void MCAN_IEnableMessageStoredToRxDedBuffer | ( | const MCan_ConfigType * | mcanConfig, |
MCan_IntrLineType | line | ||
line | Message line. |
void MCAN_Init | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_InitFdBitRateSwitchEnable | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_InitFdEnable | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_InitLoopback | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_InitTxQueue | ( | const MCan_ConfigType * | mcanConfig | ) |
uint8_t MCAN_IsBufferTxd | ( | const MCan_ConfigType * | mcanConfig, |
uint8_t | buffer | ||
uint8_t MCAN_IsNewDataInRxDedBuffer | ( | const MCan_ConfigType * | mcanConfig, |
void MCAN_LoopbackOff | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_LoopbackOn | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_RequestFd | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_RequestFdBitRateSwitch | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_RequestIso11898_1 | ( | const MCan_ConfigType * | mcanConfig | ) |
void MCAN_SendTxDedBuffer | ( | const MCan_ConfigType * | mcanConfig, |
Send Tx buffer.
