RTEMS  5.1
Data Structures | Macros
struct  Sdramc
 Sdramc hardware registers. More...
#define SDRAMC_MR_MODE_Pos   0
#define SDRAMC_MR_MODE_Msk   (0x7u << SDRAMC_MR_MODE_Pos)
 (SDRAMC_MR) SDRAMC Command Mode
#define SDRAMC_MR_MODE(value)   ((SDRAMC_MR_MODE_Msk & ((value) << SDRAMC_MR_MODE_Pos)))
#define SDRAMC_MR_MODE_NORMAL   (0x0u << 0)
 (SDRAMC_MR) Normal mode. Any access to the SDRAM is decoded normally. To activate this mode, command must be followed by a write to the SDRAM.
#define SDRAMC_MR_MODE_NOP   (0x1u << 0)
 (SDRAMC_MR) The SDRAMC issues a NOP command when the SDRAM device is accessed regardless of the cycle. To activate this mode, command must be followed by a write to the SDRAM.
#define SDRAMC_MR_MODE_ALLBANKS_PRECHARGE   (0x2u << 0)
 (SDRAMC_MR) The SDRAMC issues an "All Banks Precharge" command when the SDRAM device is accessed regardless of the cycle. To activate this mode, command must be followed by a write to the SDRAM.
#define SDRAMC_MR_MODE_LOAD_MODEREG   (0x3u << 0)
 (SDRAMC_MR) The SDRAMC issues a "Load Mode Register" command when the SDRAM device is accessed regardless of the cycle. To activate this mode, command must be followed by a write to the SDRAM.
#define SDRAMC_MR_MODE_AUTO_REFRESH   (0x4u << 0)
 (SDRAMC_MR) The SDRAMC issues an "Auto-Refresh" Command when the SDRAM device is accessed regardless of the cycle. Previously, an "All Banks Precharge" command must be issued. To activate this mode, command must be followed by a write to the SDRAM.
#define SDRAMC_MR_MODE_EXT_LOAD_MODEREG   (0x5u << 0)
 (SDRAMC_MR) The SDRAMC issues an "Extended Load Mode Register" command when the SDRAM device is accessed regardless of the cycle. To activate this mode, the "Extended Load Mode Register" command must be followed by a write to the SDRAM. The write in the SDRAM must be done in the appropriate bank; most low-power SDRAM devices use the bank 1.
#define SDRAMC_MR_MODE_DEEP_POWERDOWN   (0x6u << 0)
 (SDRAMC_MR) Deep power-down mode. Enters deep power-down mode.
#define SDRAMC_TR_COUNT_Pos   0
#define SDRAMC_TR_COUNT_Msk   (0xfffu << SDRAMC_TR_COUNT_Pos)
 (SDRAMC_TR) SDRAMC Refresh Timer Count
#define SDRAMC_TR_COUNT(value)   ((SDRAMC_TR_COUNT_Msk & ((value) << SDRAMC_TR_COUNT_Pos)))
#define SDRAMC_CR_NC_Pos   0
#define SDRAMC_CR_NC_Msk   (0x3u << SDRAMC_CR_NC_Pos)
 (SDRAMC_CR) Number of Column Bits
#define SDRAMC_CR_NC(value)   ((SDRAMC_CR_NC_Msk & ((value) << SDRAMC_CR_NC_Pos)))
#define SDRAMC_CR_NC_COL8   (0x0u << 0)
 (SDRAMC_CR) 8 column bits
#define SDRAMC_CR_NC_COL9   (0x1u << 0)
 (SDRAMC_CR) 9 column bits
#define SDRAMC_CR_NC_COL10   (0x2u << 0)
 (SDRAMC_CR) 10 column bits
#define SDRAMC_CR_NC_COL11   (0x3u << 0)
 (SDRAMC_CR) 11 column bits
#define SDRAMC_CR_NR_Pos   2
#define SDRAMC_CR_NR_Msk   (0x3u << SDRAMC_CR_NR_Pos)
 (SDRAMC_CR) Number of Row Bits
#define SDRAMC_CR_NR(value)   ((SDRAMC_CR_NR_Msk & ((value) << SDRAMC_CR_NR_Pos)))
#define SDRAMC_CR_NR_ROW11   (0x0u << 2)
 (SDRAMC_CR) 11 row bits
#define SDRAMC_CR_NR_ROW12   (0x1u << 2)
 (SDRAMC_CR) 12 row bits
#define SDRAMC_CR_NR_ROW13   (0x2u << 2)
 (SDRAMC_CR) 13 row bits
#define SDRAMC_CR_NB   (0x1u << 4)
 (SDRAMC_CR) Number of Banks
#define SDRAMC_CR_NB_BANK2   (0x0u << 4)
 (SDRAMC_CR) 2 banks
#define SDRAMC_CR_NB_BANK4   (0x1u << 4)
 (SDRAMC_CR) 4 banks
#define SDRAMC_CR_CAS_Pos   5
#define SDRAMC_CR_CAS_Msk   (0x3u << SDRAMC_CR_CAS_Pos)
 (SDRAMC_CR) CAS Latency
#define SDRAMC_CR_CAS(value)   ((SDRAMC_CR_CAS_Msk & ((value) << SDRAMC_CR_CAS_Pos)))
#define SDRAMC_CR_CAS_LATENCY1   (0x0u << 5)
 (SDRAMC_CR) 1 cycle CAS latency
#define SDRAMC_CR_CAS_LATENCY2   (0x1u << 5)
 (SDRAMC_CR) 2 cycle CAS latency
#define SDRAMC_CR_CAS_LATENCY3   (0x2u << 5)
 (SDRAMC_CR) 3 cycle CAS latency
#define SDRAMC_CR_DBW   (0x1u << 7)
 (SDRAMC_CR) Data Bus Width
#define SDRAMC_CR_TWR_Pos   8
#define SDRAMC_CR_TWR_Msk   (0xfu << SDRAMC_CR_TWR_Pos)
 (SDRAMC_CR) Write Recovery Delay
#define SDRAMC_CR_TWR(value)   ((SDRAMC_CR_TWR_Msk & ((value) << SDRAMC_CR_TWR_Pos)))
#define SDRAMC_CR_TRC_TRFC_Pos   12
#define SDRAMC_CR_TRC_TRFC_Msk   (0xfu << SDRAMC_CR_TRC_TRFC_Pos)
 (SDRAMC_CR) Row Cycle Delay and Row Refresh Cycle
#define SDRAMC_CR_TRC_TRFC(value)   ((SDRAMC_CR_TRC_TRFC_Msk & ((value) << SDRAMC_CR_TRC_TRFC_Pos)))
#define SDRAMC_CR_TRP_Pos   16
#define SDRAMC_CR_TRP_Msk   (0xfu << SDRAMC_CR_TRP_Pos)
 (SDRAMC_CR) Row Precharge Delay
#define SDRAMC_CR_TRP(value)   ((SDRAMC_CR_TRP_Msk & ((value) << SDRAMC_CR_TRP_Pos)))
#define SDRAMC_CR_TRCD_Pos   20
#define SDRAMC_CR_TRCD_Msk   (0xfu << SDRAMC_CR_TRCD_Pos)
 (SDRAMC_CR) Row to Column Delay
#define SDRAMC_CR_TRCD(value)   ((SDRAMC_CR_TRCD_Msk & ((value) << SDRAMC_CR_TRCD_Pos)))
#define SDRAMC_CR_TRAS_Pos   24
#define SDRAMC_CR_TRAS_Msk   (0xfu << SDRAMC_CR_TRAS_Pos)
 (SDRAMC_CR) Active to Precharge Delay
#define SDRAMC_CR_TRAS(value)   ((SDRAMC_CR_TRAS_Msk & ((value) << SDRAMC_CR_TRAS_Pos)))
#define SDRAMC_CR_TXSR_Pos   28
#define SDRAMC_CR_TXSR_Msk   (0xfu << SDRAMC_CR_TXSR_Pos)
 (SDRAMC_CR) Exit Self Refresh to Active Delay
#define SDRAMC_CR_TXSR(value)   ((SDRAMC_CR_TXSR_Msk & ((value) << SDRAMC_CR_TXSR_Pos)))
#define SDRAMC_LPR_LPCB_Pos   0
#define SDRAMC_LPR_LPCB_Msk   (0x3u << SDRAMC_LPR_LPCB_Pos)
 (SDRAMC_LPR) Low-power Configuration Bits
#define SDRAMC_LPR_LPCB(value)   ((SDRAMC_LPR_LPCB_Msk & ((value) << SDRAMC_LPR_LPCB_Pos)))
#define SDRAMC_LPR_LPCB_DISABLED   (0x0u << 0)
 (SDRAMC_LPR) Low Power Feature is inhibited: no Power-down, Self-refresh or Deep Power-down command is issued to the SDRAM device.
#define SDRAMC_LPR_LPCB_SELF_REFRESH   (0x1u << 0)
 (SDRAMC_LPR) The SDRAMC issues a Self-refresh command to the SDRAM device, the SDCK clock is deactivated and the SDCKE signal is set low. The SDRAM device leaves the Self Refresh Mode when accessed and enters it after the access.
#define SDRAMC_LPR_LPCB_POWER_DOWN   (0x2u << 0)
 (SDRAMC_LPR) The SDRAMC issues a Power-down Command to the SDRAM device after each access, the SDCKE signal is set to low. The SDRAM device leaves the Power-down Mode when accessed and enters it after the access.
#define SDRAMC_LPR_LPCB_DEEP_POWER_DOWN   (0x3u << 0)
 (SDRAMC_LPR) The SDRAMC issues a Deep Power-down command to the SDRAM device. This mode is unique to low-power SDRAM.
#define SDRAMC_LPR_PASR_Pos   4
#define SDRAMC_LPR_PASR_Msk   (0x7u << SDRAMC_LPR_PASR_Pos)
 (SDRAMC_LPR) Partial Array Self-refresh (only for low-power SDRAM)
#define SDRAMC_LPR_PASR(value)   ((SDRAMC_LPR_PASR_Msk & ((value) << SDRAMC_LPR_PASR_Pos)))
#define SDRAMC_LPR_TCSR_Pos   8
#define SDRAMC_LPR_TCSR_Msk   (0x3u << SDRAMC_LPR_TCSR_Pos)
 (SDRAMC_LPR) Temperature Compensated Self-Refresh (only for low-power SDRAM)
#define SDRAMC_LPR_TCSR(value)   ((SDRAMC_LPR_TCSR_Msk & ((value) << SDRAMC_LPR_TCSR_Pos)))
#define SDRAMC_LPR_DS_Pos   10
#define SDRAMC_LPR_DS_Msk   (0x3u << SDRAMC_LPR_DS_Pos)
 (SDRAMC_LPR) Drive Strength (only for low-power SDRAM)
#define SDRAMC_LPR_DS(value)   ((SDRAMC_LPR_DS_Msk & ((value) << SDRAMC_LPR_DS_Pos)))
#define SDRAMC_LPR_TIMEOUT_Pos   12
#define SDRAMC_LPR_TIMEOUT_Msk   (0x3u << SDRAMC_LPR_TIMEOUT_Pos)
 (SDRAMC_LPR) Time to Define When Low-power Mode Is Enabled
#define SDRAMC_LPR_TIMEOUT(value)   ((SDRAMC_LPR_TIMEOUT_Msk & ((value) << SDRAMC_LPR_TIMEOUT_Pos)))
#define SDRAMC_LPR_TIMEOUT_LP_LAST_XFER   (0x0u << 12)
 (SDRAMC_LPR) The SDRAMC activates the SDRAM low-power mode immediately after the end of the last transfer.
#define SDRAMC_LPR_TIMEOUT_LP_LAST_XFER_64   (0x1u << 12)
 (SDRAMC_LPR) The SDRAMC activates the SDRAM low-power mode 64 clock cycles after the end of the last transfer.
#define SDRAMC_LPR_TIMEOUT_LP_LAST_XFER_128   (0x2u << 12)
 (SDRAMC_LPR) The SDRAMC activates the SDRAM low-power mode 128 clock cycles after the end of the last transfer.
#define SDRAMC_IER_RES   (0x1u << 0)
 (SDRAMC_IER) Refresh Error Status
#define SDRAMC_IDR_RES   (0x1u << 0)
 (SDRAMC_IDR) Refresh Error Status
#define SDRAMC_IMR_RES   (0x1u << 0)
 (SDRAMC_IMR) Refresh Error Status
#define SDRAMC_ISR_RES   (0x1u << 0)
 (SDRAMC_ISR) Refresh Error Status (cleared on read)
#define SDRAMC_MDR_MD_Pos   0
#define SDRAMC_MDR_MD_Msk   (0x3u << SDRAMC_MDR_MD_Pos)
 (SDRAMC_MDR) Memory Device Type
#define SDRAMC_MDR_MD(value)   ((SDRAMC_MDR_MD_Msk & ((value) << SDRAMC_MDR_MD_Pos)))
#define SDRAMC_MDR_MD_SDRAM   (0x0u << 0)
 (SDRAMC_MDR) SDRAM
#define SDRAMC_MDR_MD_LPSDRAM   (0x1u << 0)
 (SDRAMC_MDR) Low-power SDRAM
#define SDRAMC_CFR1_TMRD_Pos   0
#define SDRAMC_CFR1_TMRD_Msk   (0xfu << SDRAMC_CFR1_TMRD_Pos)
 (SDRAMC_CFR1) Load Mode Register Command to Active or Refresh Command
#define SDRAMC_CFR1_TMRD(value)   ((SDRAMC_CFR1_TMRD_Msk & ((value) << SDRAMC_CFR1_TMRD_Pos)))
#define SDRAMC_CFR1_UNAL   (0x1u << 8)
 (SDRAMC_CFR1) Support Unaligned Access
#define SDRAMC_CFR1_UNAL_UNSUPPORTED   (0x0u << 8)
 (SDRAMC_CFR1) Unaligned access is not supported.
#define SDRAMC_CFR1_UNAL_SUPPORTED   (0x1u << 8)
 (SDRAMC_CFR1) Unaligned access is supported.
#define SDRAMC_OCMS_SDR_SE   (0x1u << 0)
 (SDRAMC_OCMS) SDRAM Memory Controller Scrambling Enable
#define SDRAMC_OCMS_KEY1_KEY1_Pos   0
#define SDRAMC_OCMS_KEY1_KEY1_Msk   (0xffffffffu << SDRAMC_OCMS_KEY1_KEY1_Pos)
 (SDRAMC_OCMS_KEY1) Off-chip Memory Scrambling (OCMS) Key Part 1
#define SDRAMC_OCMS_KEY1_KEY1(value)   ((SDRAMC_OCMS_KEY1_KEY1_Msk & ((value) << SDRAMC_OCMS_KEY1_KEY1_Pos)))
#define SDRAMC_OCMS_KEY2_KEY2_Pos   0
#define SDRAMC_OCMS_KEY2_KEY2_Msk   (0xffffffffu << SDRAMC_OCMS_KEY2_KEY2_Pos)
 (SDRAMC_OCMS_KEY2) Off-chip Memory Scrambling (OCMS) Key Part 2
#define SDRAMC_OCMS_KEY2_KEY2(value)   ((SDRAMC_OCMS_KEY2_KEY2_Msk & ((value) << SDRAMC_OCMS_KEY2_KEY2_Pos)))
#define SDRAMC_VERSION_VERSION_Pos   0
#define SDRAMC_VERSION_VERSION_Msk   (0xfffu << SDRAMC_VERSION_VERSION_Pos)
 (SDRAMC_VERSION) Version of the Hardware Module
#define SDRAMC_VERSION_MFN_Pos   16
#define SDRAMC_VERSION_MFN_Msk   (0x7u << SDRAMC_VERSION_MFN_Pos)
 (SDRAMC_VERSION) Metal Fix Number
SOFTWARE API DEFINITION FOR SDRAM Controller
