RTEMS  5.1
Data Structures | Macros
struct  Hsmci
 Hsmci hardware registers. More...
#define HSMCI_CR_MCIEN   (0x1u << 0)
 (HSMCI_CR) Multi-Media Interface Enable
#define HSMCI_CR_MCIDIS   (0x1u << 1)
 (HSMCI_CR) Multi-Media Interface Disable
#define HSMCI_CR_PWSEN   (0x1u << 2)
 (HSMCI_CR) Power Save Mode Enable
#define HSMCI_CR_PWSDIS   (0x1u << 3)
 (HSMCI_CR) Power Save Mode Disable
#define HSMCI_CR_SWRST   (0x1u << 7)
 (HSMCI_CR) Software Reset
#define HSMCI_MR_CLKDIV_Pos   0
#define HSMCI_MR_CLKDIV_Msk   (0xffu << HSMCI_MR_CLKDIV_Pos)
 (HSMCI_MR) Clock Divider
#define HSMCI_MR_CLKDIV(value)   ((HSMCI_MR_CLKDIV_Msk & ((value) << HSMCI_MR_CLKDIV_Pos)))
#define HSMCI_MR_PWSDIV_Pos   8
#define HSMCI_MR_PWSDIV_Msk   (0x7u << HSMCI_MR_PWSDIV_Pos)
 (HSMCI_MR) Power Saving Divider
#define HSMCI_MR_PWSDIV(value)   ((HSMCI_MR_PWSDIV_Msk & ((value) << HSMCI_MR_PWSDIV_Pos)))
#define HSMCI_MR_RDPROOF   (0x1u << 11)
 (HSMCI_MR) Read Proof Enable
#define HSMCI_MR_WRPROOF   (0x1u << 12)
 (HSMCI_MR) Write Proof Enable
#define HSMCI_MR_FBYTE   (0x1u << 13)
 (HSMCI_MR) Force Byte Transfer
#define HSMCI_MR_PADV   (0x1u << 14)
 (HSMCI_MR) Padding Value
#define HSMCI_MR_CLKODD   (0x1u << 16)
 (HSMCI_MR) Clock divider is odd
#define HSMCI_DTOR_DTOCYC_Pos   0
#define HSMCI_DTOR_DTOCYC_Msk   (0xfu << HSMCI_DTOR_DTOCYC_Pos)
 (HSMCI_DTOR) Data Timeout Cycle Number
#define HSMCI_DTOR_DTOCYC(value)   ((HSMCI_DTOR_DTOCYC_Msk & ((value) << HSMCI_DTOR_DTOCYC_Pos)))
#define HSMCI_DTOR_DTOMUL_Pos   4
#define HSMCI_DTOR_DTOMUL_Msk   (0x7u << HSMCI_DTOR_DTOMUL_Pos)
 (HSMCI_DTOR) Data Timeout Multiplier
#define HSMCI_DTOR_DTOMUL(value)   ((HSMCI_DTOR_DTOMUL_Msk & ((value) << HSMCI_DTOR_DTOMUL_Pos)))
#define HSMCI_DTOR_DTOMUL_1   (0x0u << 4)
 (HSMCI_DTOR) DTOCYC
#define HSMCI_DTOR_DTOMUL_16   (0x1u << 4)
 (HSMCI_DTOR) DTOCYC x 16
#define HSMCI_DTOR_DTOMUL_128   (0x2u << 4)
 (HSMCI_DTOR) DTOCYC x 128
#define HSMCI_DTOR_DTOMUL_256   (0x3u << 4)
 (HSMCI_DTOR) DTOCYC x 256
#define HSMCI_DTOR_DTOMUL_1024   (0x4u << 4)
 (HSMCI_DTOR) DTOCYC x 1024
#define HSMCI_DTOR_DTOMUL_4096   (0x5u << 4)
 (HSMCI_DTOR) DTOCYC x 4096
#define HSMCI_DTOR_DTOMUL_65536   (0x6u << 4)
 (HSMCI_DTOR) DTOCYC x 65536
#define HSMCI_DTOR_DTOMUL_1048576   (0x7u << 4)
 (HSMCI_DTOR) DTOCYC x 1048576
#define HSMCI_SDCR_SDCSEL_Pos   0
#define HSMCI_SDCR_SDCSEL_Msk   (0x3u << HSMCI_SDCR_SDCSEL_Pos)
 (HSMCI_SDCR) SDCard/SDIO Slot
#define HSMCI_SDCR_SDCSEL(value)   ((HSMCI_SDCR_SDCSEL_Msk & ((value) << HSMCI_SDCR_SDCSEL_Pos)))
#define HSMCI_SDCR_SDCSEL_SLOTA   (0x0u << 0)
 (HSMCI_SDCR) Slot A is selected.
#define HSMCI_SDCR_SDCBUS_Pos   6
#define HSMCI_SDCR_SDCBUS_Msk   (0x3u << HSMCI_SDCR_SDCBUS_Pos)
 (HSMCI_SDCR) SDCard/SDIO Bus Width
#define HSMCI_SDCR_SDCBUS(value)   ((HSMCI_SDCR_SDCBUS_Msk & ((value) << HSMCI_SDCR_SDCBUS_Pos)))
#define HSMCI_SDCR_SDCBUS_1   (0x0u << 6)
 (HSMCI_SDCR) 1 bit
#define HSMCI_SDCR_SDCBUS_4   (0x2u << 6)
 (HSMCI_SDCR) 4 bits
#define HSMCI_SDCR_SDCBUS_8   (0x3u << 6)
 (HSMCI_SDCR) 8 bits
#define HSMCI_ARGR_ARG_Pos   0
#define HSMCI_ARGR_ARG_Msk   (0xffffffffu << HSMCI_ARGR_ARG_Pos)
 (HSMCI_ARGR) Command Argument
#define HSMCI_ARGR_ARG(value)   ((HSMCI_ARGR_ARG_Msk & ((value) << HSMCI_ARGR_ARG_Pos)))
#define HSMCI_CMDR_CMDNB_Pos   0
#define HSMCI_CMDR_CMDNB_Msk   (0x3fu << HSMCI_CMDR_CMDNB_Pos)
 (HSMCI_CMDR) Command Number
#define HSMCI_CMDR_CMDNB(value)   ((HSMCI_CMDR_CMDNB_Msk & ((value) << HSMCI_CMDR_CMDNB_Pos)))
#define HSMCI_CMDR_RSPTYP_Pos   6
#define HSMCI_CMDR_RSPTYP_Msk   (0x3u << HSMCI_CMDR_RSPTYP_Pos)
 (HSMCI_CMDR) Response Type
#define HSMCI_CMDR_RSPTYP(value)   ((HSMCI_CMDR_RSPTYP_Msk & ((value) << HSMCI_CMDR_RSPTYP_Pos)))
#define HSMCI_CMDR_RSPTYP_NORESP   (0x0u << 6)
 (HSMCI_CMDR) No response
#define HSMCI_CMDR_RSPTYP_48_BIT   (0x1u << 6)
 (HSMCI_CMDR) 48-bit response
#define HSMCI_CMDR_RSPTYP_136_BIT   (0x2u << 6)
 (HSMCI_CMDR) 136-bit response
#define HSMCI_CMDR_RSPTYP_R1B   (0x3u << 6)
 (HSMCI_CMDR) R1b response type
#define HSMCI_CMDR_SPCMD_Pos   8
#define HSMCI_CMDR_SPCMD_Msk   (0x7u << HSMCI_CMDR_SPCMD_Pos)
 (HSMCI_CMDR) Special Command
#define HSMCI_CMDR_SPCMD(value)   ((HSMCI_CMDR_SPCMD_Msk & ((value) << HSMCI_CMDR_SPCMD_Pos)))
#define HSMCI_CMDR_SPCMD_STD   (0x0u << 8)
 (HSMCI_CMDR) Not a special CMD.
#define HSMCI_CMDR_SPCMD_INIT   (0x1u << 8)
 (HSMCI_CMDR) Initialization CMD: 74 clock cycles for initialization sequence.
#define HSMCI_CMDR_SPCMD_SYNC   (0x2u << 8)
 (HSMCI_CMDR) Synchronized CMD: Wait for the end of the current data block transfer before sending the pending command.
#define HSMCI_CMDR_SPCMD_CE_ATA   (0x3u << 8)
 (HSMCI_CMDR) CE-ATA Completion Signal disable Command. The host cancels the ability for the device to return a command completion signal on the command line.
#define HSMCI_CMDR_SPCMD_IT_CMD   (0x4u << 8)
 (HSMCI_CMDR) Interrupt command: Corresponds to the Interrupt Mode (CMD40).
#define HSMCI_CMDR_SPCMD_IT_RESP   (0x5u << 8)
 (HSMCI_CMDR) Interrupt response: Corresponds to the Interrupt Mode (CMD40).
#define HSMCI_CMDR_SPCMD_BOR   (0x6u << 8)
 (HSMCI_CMDR) Boot Operation Request. Start a boot operation mode, the host processor can read boot data from the MMC device directly.
#define HSMCI_CMDR_SPCMD_EBO   (0x7u << 8)
 (HSMCI_CMDR) End Boot Operation. This command allows the host processor to terminate the boot operation mode.
#define HSMCI_CMDR_OPDCMD   (0x1u << 11)
 (HSMCI_CMDR) Open Drain Command
#define HSMCI_CMDR_OPDCMD_PUSHPULL   (0x0u << 11)
 (HSMCI_CMDR) Push pull command.
#define HSMCI_CMDR_OPDCMD_OPENDRAIN   (0x1u << 11)
 (HSMCI_CMDR) Open drain command.
#define HSMCI_CMDR_MAXLAT   (0x1u << 12)
 (HSMCI_CMDR) Max Latency for Command to Response
#define HSMCI_CMDR_MAXLAT_5   (0x0u << 12)
 (HSMCI_CMDR) 5-cycle max latency.
#define HSMCI_CMDR_MAXLAT_64   (0x1u << 12)
 (HSMCI_CMDR) 64-cycle max latency.
#define HSMCI_CMDR_TRCMD_Pos   16
#define HSMCI_CMDR_TRCMD_Msk   (0x3u << HSMCI_CMDR_TRCMD_Pos)
 (HSMCI_CMDR) Transfer Command
#define HSMCI_CMDR_TRCMD(value)   ((HSMCI_CMDR_TRCMD_Msk & ((value) << HSMCI_CMDR_TRCMD_Pos)))
#define HSMCI_CMDR_TRCMD_NO_DATA   (0x0u << 16)
 (HSMCI_CMDR) No data transfer
#define HSMCI_CMDR_TRCMD_START_DATA   (0x1u << 16)
 (HSMCI_CMDR) Start data transfer
#define HSMCI_CMDR_TRCMD_STOP_DATA   (0x2u << 16)
 (HSMCI_CMDR) Stop data transfer
#define HSMCI_CMDR_TRDIR   (0x1u << 18)
 (HSMCI_CMDR) Transfer Direction
#define HSMCI_CMDR_TRDIR_WRITE   (0x0u << 18)
 (HSMCI_CMDR) Write.
#define HSMCI_CMDR_TRDIR_READ   (0x1u << 18)
 (HSMCI_CMDR) Read.
#define HSMCI_CMDR_TRTYP_Pos   19
#define HSMCI_CMDR_TRTYP_Msk   (0x7u << HSMCI_CMDR_TRTYP_Pos)
 (HSMCI_CMDR) Transfer Type
#define HSMCI_CMDR_TRTYP(value)   ((HSMCI_CMDR_TRTYP_Msk & ((value) << HSMCI_CMDR_TRTYP_Pos)))
#define HSMCI_CMDR_TRTYP_SINGLE   (0x0u << 19)
 (HSMCI_CMDR) MMC/SD Card Single Block
#define HSMCI_CMDR_TRTYP_MULTIPLE   (0x1u << 19)
 (HSMCI_CMDR) MMC/SD Card Multiple Block
#define HSMCI_CMDR_TRTYP_STREAM   (0x2u << 19)
 (HSMCI_CMDR) MMC Stream
#define HSMCI_CMDR_TRTYP_BYTE   (0x4u << 19)
 (HSMCI_CMDR) SDIO Byte
#define HSMCI_CMDR_TRTYP_BLOCK   (0x5u << 19)
 (HSMCI_CMDR) SDIO Block
#define HSMCI_CMDR_IOSPCMD_Pos   24
#define HSMCI_CMDR_IOSPCMD_Msk   (0x3u << HSMCI_CMDR_IOSPCMD_Pos)
 (HSMCI_CMDR) SDIO Special Command
#define HSMCI_CMDR_IOSPCMD(value)   ((HSMCI_CMDR_IOSPCMD_Msk & ((value) << HSMCI_CMDR_IOSPCMD_Pos)))
#define HSMCI_CMDR_IOSPCMD_STD   (0x0u << 24)
 (HSMCI_CMDR) Not an SDIO Special Command
#define HSMCI_CMDR_IOSPCMD_SUSPEND   (0x1u << 24)
 (HSMCI_CMDR) SDIO Suspend Command
#define HSMCI_CMDR_IOSPCMD_RESUME   (0x2u << 24)
 (HSMCI_CMDR) SDIO Resume Command
#define HSMCI_CMDR_ATACS   (0x1u << 26)
 (HSMCI_CMDR) ATA with Command Completion Signal
#define HSMCI_CMDR_ATACS_NORMAL   (0x0u << 26)
 (HSMCI_CMDR) Normal operation mode.
#define HSMCI_CMDR_ATACS_COMPLETION   (0x1u << 26)
 (HSMCI_CMDR) This bit indicates that a completion signal is expected within a programmed amount of time (HSMCI_CSTOR).
#define HSMCI_CMDR_BOOT_ACK   (0x1u << 27)
 (HSMCI_CMDR) Boot Operation Acknowledge
#define HSMCI_BLKR_BCNT_Pos   0
#define HSMCI_BLKR_BCNT_Msk   (0xffffu << HSMCI_BLKR_BCNT_Pos)
 (HSMCI_BLKR) MMC/SDIO Block Count - SDIO Byte Count
#define HSMCI_BLKR_BCNT(value)   ((HSMCI_BLKR_BCNT_Msk & ((value) << HSMCI_BLKR_BCNT_Pos)))
#define HSMCI_BLKR_BLKLEN_Pos   16
#define HSMCI_BLKR_BLKLEN_Msk   (0xffffu << HSMCI_BLKR_BLKLEN_Pos)
 (HSMCI_BLKR) Data Block Length
#define HSMCI_BLKR_BLKLEN(value)   ((HSMCI_BLKR_BLKLEN_Msk & ((value) << HSMCI_BLKR_BLKLEN_Pos)))
#define HSMCI_CSTOR_CSTOCYC_Pos   0
#define HSMCI_CSTOR_CSTOCYC_Msk   (0xfu << HSMCI_CSTOR_CSTOCYC_Pos)
 (HSMCI_CSTOR) Completion Signal Timeout Cycle Number
#define HSMCI_CSTOR_CSTOCYC(value)   ((HSMCI_CSTOR_CSTOCYC_Msk & ((value) << HSMCI_CSTOR_CSTOCYC_Pos)))
#define HSMCI_CSTOR_CSTOMUL_Pos   4
#define HSMCI_CSTOR_CSTOMUL_Msk   (0x7u << HSMCI_CSTOR_CSTOMUL_Pos)
 (HSMCI_CSTOR) Completion Signal Timeout Multiplier
#define HSMCI_CSTOR_CSTOMUL(value)   ((HSMCI_CSTOR_CSTOMUL_Msk & ((value) << HSMCI_CSTOR_CSTOMUL_Pos)))
#define HSMCI_CSTOR_CSTOMUL_1   (0x0u << 4)
 (HSMCI_CSTOR) CSTOCYC x 1
#define HSMCI_CSTOR_CSTOMUL_16   (0x1u << 4)
 (HSMCI_CSTOR) CSTOCYC x 16
#define HSMCI_CSTOR_CSTOMUL_128   (0x2u << 4)
 (HSMCI_CSTOR) CSTOCYC x 128
#define HSMCI_CSTOR_CSTOMUL_256   (0x3u << 4)
 (HSMCI_CSTOR) CSTOCYC x 256
#define HSMCI_CSTOR_CSTOMUL_1024   (0x4u << 4)
 (HSMCI_CSTOR) CSTOCYC x 1024
#define HSMCI_CSTOR_CSTOMUL_4096   (0x5u << 4)
 (HSMCI_CSTOR) CSTOCYC x 4096
#define HSMCI_CSTOR_CSTOMUL_65536   (0x6u << 4)
 (HSMCI_CSTOR) CSTOCYC x 65536
#define HSMCI_CSTOR_CSTOMUL_1048576   (0x7u << 4)
 (HSMCI_CSTOR) CSTOCYC x 1048576
#define HSMCI_RSPR_RSP_Pos   0
#define HSMCI_RSPR_RSP_Msk   (0xffffffffu << HSMCI_RSPR_RSP_Pos)
 (HSMCI_RSPR[4]) Response
#define HSMCI_RDR_DATA_Pos   0
#define HSMCI_RDR_DATA_Msk   (0xffffffffu << HSMCI_RDR_DATA_Pos)
 (HSMCI_RDR) Data to Read
#define HSMCI_TDR_DATA_Pos   0
#define HSMCI_TDR_DATA_Msk   (0xffffffffu << HSMCI_TDR_DATA_Pos)
 (HSMCI_TDR) Data to Write
#define HSMCI_TDR_DATA(value)   ((HSMCI_TDR_DATA_Msk & ((value) << HSMCI_TDR_DATA_Pos)))
#define HSMCI_SR_CMDRDY   (0x1u << 0)
 (HSMCI_SR) Command Ready (cleared by writing in HSMCI_CMDR)
#define HSMCI_SR_RXRDY   (0x1u << 1)
 (HSMCI_SR) Receiver Ready (cleared by reading HSMCI_RDR)
#define HSMCI_SR_TXRDY   (0x1u << 2)
 (HSMCI_SR) Transmit Ready (cleared by writing in HSMCI_TDR)
#define HSMCI_SR_BLKE   (0x1u << 3)
 (HSMCI_SR) Data Block Ended (cleared on read)
#define HSMCI_SR_DTIP   (0x1u << 4)
 (HSMCI_SR) Data Transfer in Progress (cleared at the end of CRC16 calculation)
#define HSMCI_SR_NOTBUSY   (0x1u << 5)
 (HSMCI_SR) HSMCI Not Busy
#define HSMCI_SR_SDIOIRQA   (0x1u << 8)
 (HSMCI_SR) SDIO Interrupt for Slot A (cleared on read)
#define HSMCI_SR_SDIOWAIT   (0x1u << 12)
 (HSMCI_SR) SDIO Read Wait Operation Status
#define HSMCI_SR_CSRCV   (0x1u << 13)
 (HSMCI_SR) CE-ATA Completion Signal Received (cleared on read)
#define HSMCI_SR_RINDE   (0x1u << 16)
 (HSMCI_SR) Response Index Error (cleared by writing in HSMCI_CMDR)
#define HSMCI_SR_RDIRE   (0x1u << 17)
 (HSMCI_SR) Response Direction Error (cleared by writing in HSMCI_CMDR)
#define HSMCI_SR_RCRCE   (0x1u << 18)
 (HSMCI_SR) Response CRC Error (cleared by writing in HSMCI_CMDR)
#define HSMCI_SR_RENDE   (0x1u << 19)
 (HSMCI_SR) Response End Bit Error (cleared by writing in HSMCI_CMDR)
#define HSMCI_SR_RTOE   (0x1u << 20)
 (HSMCI_SR) Response Time-out Error (cleared by writing in HSMCI_CMDR)
#define HSMCI_SR_DCRCE   (0x1u << 21)
 (HSMCI_SR) Data CRC Error (cleared on read)
#define HSMCI_SR_DTOE   (0x1u << 22)
 (HSMCI_SR) Data Time-out Error (cleared on read)
#define HSMCI_SR_CSTOE   (0x1u << 23)
 (HSMCI_SR) Completion Signal Time-out Error (cleared on read)
#define HSMCI_SR_BLKOVRE   (0x1u << 24)
 (HSMCI_SR) DMA Block Overrun Error (cleared on read)
#define HSMCI_SR_FIFOEMPTY   (0x1u << 26)
 (HSMCI_SR) FIFO empty flag
#define HSMCI_SR_XFRDONE   (0x1u << 27)
 (HSMCI_SR) Transfer Done flag
#define HSMCI_SR_ACKRCV   (0x1u << 28)
 (HSMCI_SR) Boot Operation Acknowledge Received (cleared on read)
#define HSMCI_SR_ACKRCVE   (0x1u << 29)
 (HSMCI_SR) Boot Operation Acknowledge Error (cleared on read)
#define HSMCI_SR_OVRE   (0x1u << 30)
 (HSMCI_SR) Overrun (if FERRCTRL = 1, cleared by writing in HSMCI_CMDR or cleared on read if FERRCTRL = 0)
#define HSMCI_SR_UNRE   (0x1u << 31)
 (HSMCI_SR) Underrun (if FERRCTRL = 1, cleared by writing in HSMCI_CMDR or cleared on read if FERRCTRL = 0)
#define HSMCI_IER_CMDRDY   (0x1u << 0)
 (HSMCI_IER) Command Ready Interrupt Enable
#define HSMCI_IER_RXRDY   (0x1u << 1)
 (HSMCI_IER) Receiver Ready Interrupt Enable
#define HSMCI_IER_TXRDY   (0x1u << 2)
 (HSMCI_IER) Transmit Ready Interrupt Enable
#define HSMCI_IER_BLKE   (0x1u << 3)
 (HSMCI_IER) Data Block Ended Interrupt Enable
#define HSMCI_IER_DTIP   (0x1u << 4)
 (HSMCI_IER) Data Transfer in Progress Interrupt Enable
#define HSMCI_IER_NOTBUSY   (0x1u << 5)
 (HSMCI_IER) Data Not Busy Interrupt Enable
#define HSMCI_IER_SDIOIRQA   (0x1u << 8)
 (HSMCI_IER) SDIO Interrupt for Slot A Interrupt Enable
#define HSMCI_IER_SDIOWAIT   (0x1u << 12)
 (HSMCI_IER) SDIO Read Wait Operation Status Interrupt Enable
#define HSMCI_IER_CSRCV   (0x1u << 13)
 (HSMCI_IER) Completion Signal Received Interrupt Enable
#define HSMCI_IER_RINDE   (0x1u << 16)
 (HSMCI_IER) Response Index Error Interrupt Enable
#define HSMCI_IER_RDIRE   (0x1u << 17)
 (HSMCI_IER) Response Direction Error Interrupt Enable
#define HSMCI_IER_RCRCE   (0x1u << 18)
 (HSMCI_IER) Response CRC Error Interrupt Enable
#define HSMCI_IER_RENDE   (0x1u << 19)
 (HSMCI_IER) Response End Bit Error Interrupt Enable
#define HSMCI_IER_RTOE   (0x1u << 20)
 (HSMCI_IER) Response Time-out Error Interrupt Enable
#define HSMCI_IER_DCRCE   (0x1u << 21)
 (HSMCI_IER) Data CRC Error Interrupt Enable
#define HSMCI_IER_DTOE   (0x1u << 22)
 (HSMCI_IER) Data Time-out Error Interrupt Enable
#define HSMCI_IER_CSTOE   (0x1u << 23)
 (HSMCI_IER) Completion Signal Timeout Error Interrupt Enable
#define HSMCI_IER_BLKOVRE   (0x1u << 24)
 (HSMCI_IER) DMA Block Overrun Error Interrupt Enable
#define HSMCI_IER_FIFOEMPTY   (0x1u << 26)
 (HSMCI_IER) FIFO empty Interrupt enable
#define HSMCI_IER_XFRDONE   (0x1u << 27)
 (HSMCI_IER) Transfer Done Interrupt enable
#define HSMCI_IER_ACKRCV   (0x1u << 28)
 (HSMCI_IER) Boot Acknowledge Interrupt Enable
#define HSMCI_IER_ACKRCVE   (0x1u << 29)
 (HSMCI_IER) Boot Acknowledge Error Interrupt Enable
#define HSMCI_IER_OVRE   (0x1u << 30)
 (HSMCI_IER) Overrun Interrupt Enable
#define HSMCI_IER_UNRE   (0x1u << 31)
 (HSMCI_IER) Underrun Interrupt Enable
#define HSMCI_IDR_CMDRDY   (0x1u << 0)
 (HSMCI_IDR) Command Ready Interrupt Disable
#define HSMCI_IDR_RXRDY   (0x1u << 1)
 (HSMCI_IDR) Receiver Ready Interrupt Disable
#define HSMCI_IDR_TXRDY   (0x1u << 2)
 (HSMCI_IDR) Transmit Ready Interrupt Disable
#define HSMCI_IDR_BLKE   (0x1u << 3)
 (HSMCI_IDR) Data Block Ended Interrupt Disable
#define HSMCI_IDR_DTIP   (0x1u << 4)
 (HSMCI_IDR) Data Transfer in Progress Interrupt Disable
#define HSMCI_IDR_NOTBUSY   (0x1u << 5)
 (HSMCI_IDR) Data Not Busy Interrupt Disable
#define HSMCI_IDR_SDIOIRQA   (0x1u << 8)
 (HSMCI_IDR) SDIO Interrupt for Slot A Interrupt Disable
#define HSMCI_IDR_SDIOWAIT   (0x1u << 12)
 (HSMCI_IDR) SDIO Read Wait Operation Status Interrupt Disable
#define HSMCI_IDR_CSRCV   (0x1u << 13)
 (HSMCI_IDR) Completion Signal received interrupt Disable
#define HSMCI_IDR_RINDE   (0x1u << 16)
 (HSMCI_IDR) Response Index Error Interrupt Disable
#define HSMCI_IDR_RDIRE   (0x1u << 17)
 (HSMCI_IDR) Response Direction Error Interrupt Disable
#define HSMCI_IDR_RCRCE   (0x1u << 18)
 (HSMCI_IDR) Response CRC Error Interrupt Disable
#define HSMCI_IDR_RENDE   (0x1u << 19)
 (HSMCI_IDR) Response End Bit Error Interrupt Disable
#define HSMCI_IDR_RTOE   (0x1u << 20)
 (HSMCI_IDR) Response Time-out Error Interrupt Disable
#define HSMCI_IDR_DCRCE   (0x1u << 21)
 (HSMCI_IDR) Data CRC Error Interrupt Disable
#define HSMCI_IDR_DTOE   (0x1u << 22)
 (HSMCI_IDR) Data Time-out Error Interrupt Disable
#define HSMCI_IDR_CSTOE   (0x1u << 23)
 (HSMCI_IDR) Completion Signal Time out Error Interrupt Disable
#define HSMCI_IDR_BLKOVRE   (0x1u << 24)
 (HSMCI_IDR) DMA Block Overrun Error Interrupt Disable
#define HSMCI_IDR_FIFOEMPTY   (0x1u << 26)
 (HSMCI_IDR) FIFO empty Interrupt Disable
#define HSMCI_IDR_XFRDONE   (0x1u << 27)
 (HSMCI_IDR) Transfer Done Interrupt Disable
#define HSMCI_IDR_ACKRCV   (0x1u << 28)
 (HSMCI_IDR) Boot Acknowledge Interrupt Disable
#define HSMCI_IDR_ACKRCVE   (0x1u << 29)
 (HSMCI_IDR) Boot Acknowledge Error Interrupt Disable
#define HSMCI_IDR_OVRE   (0x1u << 30)
 (HSMCI_IDR) Overrun Interrupt Disable
#define HSMCI_IDR_UNRE   (0x1u << 31)
 (HSMCI_IDR) Underrun Interrupt Disable
#define HSMCI_IMR_CMDRDY   (0x1u << 0)
 (HSMCI_IMR) Command Ready Interrupt Mask
#define HSMCI_IMR_RXRDY   (0x1u << 1)
 (HSMCI_IMR) Receiver Ready Interrupt Mask
#define HSMCI_IMR_TXRDY   (0x1u << 2)
 (HSMCI_IMR) Transmit Ready Interrupt Mask
#define HSMCI_IMR_BLKE   (0x1u << 3)
 (HSMCI_IMR) Data Block Ended Interrupt Mask
#define HSMCI_IMR_DTIP   (0x1u << 4)
 (HSMCI_IMR) Data Transfer in Progress Interrupt Mask
#define HSMCI_IMR_NOTBUSY   (0x1u << 5)
 (HSMCI_IMR) Data Not Busy Interrupt Mask
#define HSMCI_IMR_SDIOIRQA   (0x1u << 8)
 (HSMCI_IMR) SDIO Interrupt for Slot A Interrupt Mask
#define HSMCI_IMR_SDIOWAIT   (0x1u << 12)
 (HSMCI_IMR) SDIO Read Wait Operation Status Interrupt Mask
#define HSMCI_IMR_CSRCV   (0x1u << 13)
 (HSMCI_IMR) Completion Signal Received Interrupt Mask
#define HSMCI_IMR_RINDE   (0x1u << 16)
 (HSMCI_IMR) Response Index Error Interrupt Mask
#define HSMCI_IMR_RDIRE   (0x1u << 17)
 (HSMCI_IMR) Response Direction Error Interrupt Mask
#define HSMCI_IMR_RCRCE   (0x1u << 18)
 (HSMCI_IMR) Response CRC Error Interrupt Mask
#define HSMCI_IMR_RENDE   (0x1u << 19)
 (HSMCI_IMR) Response End Bit Error Interrupt Mask
#define HSMCI_IMR_RTOE   (0x1u << 20)
 (HSMCI_IMR) Response Time-out Error Interrupt Mask
#define HSMCI_IMR_DCRCE   (0x1u << 21)
 (HSMCI_IMR) Data CRC Error Interrupt Mask
#define HSMCI_IMR_DTOE   (0x1u << 22)
 (HSMCI_IMR) Data Time-out Error Interrupt Mask
#define HSMCI_IMR_CSTOE   (0x1u << 23)
 (HSMCI_IMR) Completion Signal Time-out Error Interrupt Mask
#define HSMCI_IMR_BLKOVRE   (0x1u << 24)
 (HSMCI_IMR) DMA Block Overrun Error Interrupt Mask
#define HSMCI_IMR_FIFOEMPTY   (0x1u << 26)
 (HSMCI_IMR) FIFO Empty Interrupt Mask
#define HSMCI_IMR_XFRDONE   (0x1u << 27)
 (HSMCI_IMR) Transfer Done Interrupt Mask
#define HSMCI_IMR_ACKRCV   (0x1u << 28)
 (HSMCI_IMR) Boot Operation Acknowledge Received Interrupt Mask
#define HSMCI_IMR_ACKRCVE   (0x1u << 29)
 (HSMCI_IMR) Boot Operation Acknowledge Error Interrupt Mask
#define HSMCI_IMR_OVRE   (0x1u << 30)
 (HSMCI_IMR) Overrun Interrupt Mask
#define HSMCI_IMR_UNRE   (0x1u << 31)
 (HSMCI_IMR) Underrun Interrupt Mask
#define HSMCI_DMA_CHKSIZE_Pos   4
#define HSMCI_DMA_CHKSIZE_Msk   (0x7u << HSMCI_DMA_CHKSIZE_Pos)
 (HSMCI_DMA) DMA Channel Read and Write Chunk Size
#define HSMCI_DMA_CHKSIZE(value)   ((HSMCI_DMA_CHKSIZE_Msk & ((value) << HSMCI_DMA_CHKSIZE_Pos)))
#define HSMCI_DMA_CHKSIZE_1   (0x0u << 4)
 (HSMCI_DMA) 1 data available
#define HSMCI_DMA_CHKSIZE_2   (0x1u << 4)
 (HSMCI_DMA) 2 data available
#define HSMCI_DMA_CHKSIZE_4   (0x2u << 4)
 (HSMCI_DMA) 4 data available
#define HSMCI_DMA_CHKSIZE_8   (0x3u << 4)
 (HSMCI_DMA) 8 data available
#define HSMCI_DMA_CHKSIZE_16   (0x4u << 4)
 (HSMCI_DMA) 16 data available
#define HSMCI_DMA_DMAEN   (0x1u << 8)
 (HSMCI_DMA) DMA Hardware Handshaking Enable
#define HSMCI_CFG_FIFOMODE   (0x1u << 0)
 (HSMCI_CFG) HSMCI Internal FIFO control mode
#define HSMCI_CFG_FERRCTRL   (0x1u << 4)
 (HSMCI_CFG) Flow Error flag reset control mode
#define HSMCI_CFG_HSMODE   (0x1u << 8)
 (HSMCI_CFG) High Speed Mode
#define HSMCI_CFG_LSYNC   (0x1u << 12)
 (HSMCI_CFG) Synchronize on the last block
#define HSMCI_WPMR_WPEN   (0x1u << 0)
 (HSMCI_WPMR) Write Protect Enable
#define HSMCI_WPMR_WPKEY_Pos   8
#define HSMCI_WPMR_WPKEY_Msk   (0xffffffu << HSMCI_WPMR_WPKEY_Pos)
 (HSMCI_WPMR) Write Protect Key
#define HSMCI_WPMR_WPKEY(value)   ((HSMCI_WPMR_WPKEY_Msk & ((value) << HSMCI_WPMR_WPKEY_Pos)))
#define HSMCI_WPMR_WPKEY_PASSWD   (0x4D4349u << 8)
 (HSMCI_WPMR) Writing any other value in this field aborts the write operation of the WPEN bit.Always reads as 0.
#define HSMCI_WPSR_WPVS   (0x1u << 0)
 (HSMCI_WPSR) Write Protection Violation Status
#define HSMCI_WPSR_WPVSRC_Pos   8
#define HSMCI_WPSR_WPVSRC_Msk   (0xffffu << HSMCI_WPSR_WPVSRC_Pos)
 (HSMCI_WPSR) Write Protection Violation Source
#define HSMCI_VERSION_VERSION_Pos   0
#define HSMCI_VERSION_VERSION_Msk   (0xfffu << HSMCI_VERSION_VERSION_Pos)
 (HSMCI_VERSION) Hardware Module Version
#define HSMCI_VERSION_MFN_Pos   16
#define HSMCI_VERSION_MFN_Msk   (0x7u << HSMCI_VERSION_MFN_Pos)
 (HSMCI_VERSION) Metal Fix Number
#define HSMCI_FIFO_DATA_Pos   0
#define HSMCI_FIFO_DATA_Msk   (0xffffffffu << HSMCI_FIFO_DATA_Pos)
 (HSMCI_FIFO[256]) Data to Read or Data to Write
#define HSMCI_FIFO_DATA(value)   ((HSMCI_FIFO_DATA_Msk & ((value) << HSMCI_FIFO_DATA_Pos)))
SOFTWARE API DEFINITION FOR High Speed MultiMedia Card Interface
