RTEMS  5.1
Data Structures | Macros
struct  Matrix
 Matrix hardware registers. More...
#define MATRIX_MCFG0_ULBT_Pos   0
#define MATRIX_MCFG0_ULBT_Msk   (0x7u << MATRIX_MCFG0_ULBT_Pos)
 (MATRIX_MCFG0) Undefined Length Burst Type
#define MATRIX_MCFG0_ULBT(value)   ((MATRIX_MCFG0_ULBT_Msk & ((value) << MATRIX_MCFG0_ULBT_Pos)))
#define MATRIX_MCFG0_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG0) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG0_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG0) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG0_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG0) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG0_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG0) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG0_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG0) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG0_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG0) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG0_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG0) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG0_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG0) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_MCFG1_ULBT_Pos   0
#define MATRIX_MCFG1_ULBT_Msk   (0x7u << MATRIX_MCFG1_ULBT_Pos)
 (MATRIX_MCFG1) Undefined Length Burst Type
#define MATRIX_MCFG1_ULBT(value)   ((MATRIX_MCFG1_ULBT_Msk & ((value) << MATRIX_MCFG1_ULBT_Pos)))
#define MATRIX_MCFG1_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG1) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG1_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG1) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG1_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG1) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG1_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG1) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG1_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG1) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG1_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG1) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG1_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG1) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG1_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG1) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_MCFG2_ULBT_Pos   0
#define MATRIX_MCFG2_ULBT_Msk   (0x7u << MATRIX_MCFG2_ULBT_Pos)
 (MATRIX_MCFG2) Undefined Length Burst Type
#define MATRIX_MCFG2_ULBT(value)   ((MATRIX_MCFG2_ULBT_Msk & ((value) << MATRIX_MCFG2_ULBT_Pos)))
#define MATRIX_MCFG2_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG2) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG2_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG2) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG2_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG2) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG2_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG2) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG2_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG2) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG2_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG2) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG2_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG2) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG2_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG2) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_MCFG3_ULBT_Pos   0
#define MATRIX_MCFG3_ULBT_Msk   (0x7u << MATRIX_MCFG3_ULBT_Pos)
 (MATRIX_MCFG3) Undefined Length Burst Type
#define MATRIX_MCFG3_ULBT(value)   ((MATRIX_MCFG3_ULBT_Msk & ((value) << MATRIX_MCFG3_ULBT_Pos)))
#define MATRIX_MCFG3_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG3) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG3_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG3) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG3_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG3) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG3_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG3) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG3_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG3) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG3_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG3) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG3_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG3) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG3_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG3) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_MCFG4_ULBT_Pos   0
#define MATRIX_MCFG4_ULBT_Msk   (0x7u << MATRIX_MCFG4_ULBT_Pos)
 (MATRIX_MCFG4) Undefined Length Burst Type
#define MATRIX_MCFG4_ULBT(value)   ((MATRIX_MCFG4_ULBT_Msk & ((value) << MATRIX_MCFG4_ULBT_Pos)))
#define MATRIX_MCFG4_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG4) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG4_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG4) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG4_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG4) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG4_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG4) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG4_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG4) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG4_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG4) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG4_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG4) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG4_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG4) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_MCFG5_ULBT_Pos   0
#define MATRIX_MCFG5_ULBT_Msk   (0x7u << MATRIX_MCFG5_ULBT_Pos)
 (MATRIX_MCFG5) Undefined Length Burst Type
#define MATRIX_MCFG5_ULBT(value)   ((MATRIX_MCFG5_ULBT_Msk & ((value) << MATRIX_MCFG5_ULBT_Pos)))
#define MATRIX_MCFG5_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG5) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG5_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG5) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG5_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG5) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG5_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG5) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG5_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG5) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG5_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG5) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG5_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG5) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG5_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG5) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_MCFG6_ULBT_Pos   0
#define MATRIX_MCFG6_ULBT_Msk   (0x7u << MATRIX_MCFG6_ULBT_Pos)
 (MATRIX_MCFG6) Undefined Length Burst Type
#define MATRIX_MCFG6_ULBT(value)   ((MATRIX_MCFG6_ULBT_Msk & ((value) << MATRIX_MCFG6_ULBT_Pos)))
#define MATRIX_MCFG6_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG6) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG6_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG6) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG6_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG6) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG6_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG6) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG6_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG6) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG6_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG6) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG6_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG6) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG6_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG6) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_MCFG8_ULBT_Pos   0
#define MATRIX_MCFG8_ULBT_Msk   (0x7u << MATRIX_MCFG8_ULBT_Pos)
 (MATRIX_MCFG8) Undefined Length Burst Type
#define MATRIX_MCFG8_ULBT(value)   ((MATRIX_MCFG8_ULBT_Msk & ((value) << MATRIX_MCFG8_ULBT_Pos)))
#define MATRIX_MCFG8_ULBT_UNLTD_LENGTH   (0x0u << 0)
 (MATRIX_MCFG8) Unlimited Length Burst-No predicted end of burst is generated, therefore INCR bursts coming from this master can only be broken if the Slave Slot Cycle Limit is reached. If the Slot Cycle Limit is not reached, the burst is normally completed by the master, at the latest, on the next AHB 1-Kbyte address boundary, allowing up to 256-beat word bursts or 128-beat double-word bursts.This value should not be used in the very particular case of a master capable of performing back-to-back undefined length bursts on a single slave, since this could indefinitely freeze the slave arbitration and thus prevent another master from accessing this slave.
#define MATRIX_MCFG8_ULBT_SINGLE_ACCESS   (0x1u << 0)
 (MATRIX_MCFG8) Single Access-The undefined length burst is treated as a succession of single accesses, allowing re-arbitration at each beat of the INCR burst or bursts sequence.
#define MATRIX_MCFG8_ULBT_4BEAT_BURST   (0x2u << 0)
 (MATRIX_MCFG8) 4-beat Burst-The undefined length burst or bursts sequence is split into 4-beat bursts or less, allowing re-arbitration every 4 beats.
#define MATRIX_MCFG8_ULBT_8BEAT_BURST   (0x3u << 0)
 (MATRIX_MCFG8) 8-beat Burst-The undefined length burst or bursts sequence is split into 8-beat bursts or less, allowing re-arbitration every 8 beats.
#define MATRIX_MCFG8_ULBT_16BEAT_BURST   (0x4u << 0)
 (MATRIX_MCFG8) 16-beat Burst-The undefined length burst or bursts sequence is split into 16-beat bursts or less, allowing re-arbitration every 16 beats.
#define MATRIX_MCFG8_ULBT_32BEAT_BURST   (0x5u << 0)
 (MATRIX_MCFG8) 32-beat Burst -The undefined length burst or bursts sequence is split into 32-beat bursts or less, allowing re-arbitration every 32 beats.
#define MATRIX_MCFG8_ULBT_64BEAT_BURST   (0x6u << 0)
 (MATRIX_MCFG8) 64-beat Burst-The undefined length burst or bursts sequence is split into 64-beat bursts or less, allowing re-arbitration every 64 beats.
#define MATRIX_MCFG8_ULBT_128BEAT_BURST   (0x7u << 0)
 (MATRIX_MCFG8) 128-beat Burst-The undefined length burst or bursts sequence is split into 128-beat bursts or less, allowing re-arbitration every 128 beats.
#define MATRIX_SCFG_SLOT_CYCLE_Pos   0
#define MATRIX_SCFG_SLOT_CYCLE_Msk   (0x1ffu << MATRIX_SCFG_SLOT_CYCLE_Pos)
 (MATRIX_SCFG[9]) Maximum Bus Grant Duration for Masters
#define MATRIX_SCFG_SLOT_CYCLE(value)   ((MATRIX_SCFG_SLOT_CYCLE_Msk & ((value) << MATRIX_SCFG_SLOT_CYCLE_Pos)))
#define MATRIX_SCFG_DEFMSTR_TYPE_Pos   16
#define MATRIX_SCFG_DEFMSTR_TYPE_Msk   (0x3u << MATRIX_SCFG_DEFMSTR_TYPE_Pos)
 (MATRIX_SCFG[9]) Default Master Type
#define MATRIX_SCFG_DEFMSTR_TYPE(value)   ((MATRIX_SCFG_DEFMSTR_TYPE_Msk & ((value) << MATRIX_SCFG_DEFMSTR_TYPE_Pos)))
#define MATRIX_SCFG_DEFMSTR_TYPE_NONE   (0x0u << 16)
 (MATRIX_SCFG[9]) No Default Master-At the end of the current slave access, if no other master request is pending, the slave is disconnected from all masters.This results in a one clock cycle latency for the first access of a burst transfer or for a single access.
#define MATRIX_SCFG_DEFMSTR_TYPE_LAST   (0x1u << 16)
 (MATRIX_SCFG[9]) Last Default Master-At the end of the current slave access, if no other master request is pending, the slave stays connected to the last master having accessed it.This results in not having one clock cycle latency when the last master tries to access the slave again.
#define MATRIX_SCFG_DEFMSTR_TYPE_FIXED   (0x2u << 16)
 (MATRIX_SCFG[9]) Fixed Default Master-At the end of the current slave access, if no other master request is pending, the slave connects to the fixed master the number that has been written in the FIXED_DEFMSTR field.This results in not having one clock cycle latency when the fixed master tries to access the slave again.
#define MATRIX_SCFG_FIXED_DEFMSTR_Pos   18
#define MATRIX_SCFG_FIXED_DEFMSTR_Msk   (0xfu << MATRIX_SCFG_FIXED_DEFMSTR_Pos)
#define MATRIX_SCFG_FIXED_DEFMSTR(value)   ((MATRIX_SCFG_FIXED_DEFMSTR_Msk & ((value) << MATRIX_SCFG_FIXED_DEFMSTR_Pos)))
#define MATRIX_PRAS0_M0PR_Pos   0
#define MATRIX_PRAS0_M0PR_Msk   (0x3u << MATRIX_PRAS0_M0PR_Pos)
 (MATRIX_PRAS0) Master 0 Priority
#define MATRIX_PRAS0_M0PR(value)   ((MATRIX_PRAS0_M0PR_Msk & ((value) << MATRIX_PRAS0_M0PR_Pos)))
#define MATRIX_PRAS0_M1PR_Pos   4
#define MATRIX_PRAS0_M1PR_Msk   (0x3u << MATRIX_PRAS0_M1PR_Pos)
 (MATRIX_PRAS0) Master 1 Priority
#define MATRIX_PRAS0_M1PR(value)   ((MATRIX_PRAS0_M1PR_Msk & ((value) << MATRIX_PRAS0_M1PR_Pos)))
#define MATRIX_PRAS0_M2PR_Pos   8
#define MATRIX_PRAS0_M2PR_Msk   (0x3u << MATRIX_PRAS0_M2PR_Pos)
 (MATRIX_PRAS0) Master 2 Priority
#define MATRIX_PRAS0_M2PR(value)   ((MATRIX_PRAS0_M2PR_Msk & ((value) << MATRIX_PRAS0_M2PR_Pos)))
#define MATRIX_PRAS0_M3PR_Pos   12
#define MATRIX_PRAS0_M3PR_Msk   (0x3u << MATRIX_PRAS0_M3PR_Pos)
 (MATRIX_PRAS0) Master 3 Priority
#define MATRIX_PRAS0_M3PR(value)   ((MATRIX_PRAS0_M3PR_Msk & ((value) << MATRIX_PRAS0_M3PR_Pos)))
#define MATRIX_PRAS0_M4PR_Pos   16
#define MATRIX_PRAS0_M4PR_Msk   (0x3u << MATRIX_PRAS0_M4PR_Pos)
 (MATRIX_PRAS0) Master 4 Priority
#define MATRIX_PRAS0_M4PR(value)   ((MATRIX_PRAS0_M4PR_Msk & ((value) << MATRIX_PRAS0_M4PR_Pos)))
#define MATRIX_PRAS0_M5PR_Pos   20
#define MATRIX_PRAS0_M5PR_Msk   (0x3u << MATRIX_PRAS0_M5PR_Pos)
 (MATRIX_PRAS0) Master 5 Priority
#define MATRIX_PRAS0_M5PR(value)   ((MATRIX_PRAS0_M5PR_Msk & ((value) << MATRIX_PRAS0_M5PR_Pos)))
#define MATRIX_PRAS0_M6PR_Pos   24
#define MATRIX_PRAS0_M6PR_Msk   (0x3u << MATRIX_PRAS0_M6PR_Pos)
 (MATRIX_PRAS0) Master 6 Priority
#define MATRIX_PRAS0_M6PR(value)   ((MATRIX_PRAS0_M6PR_Msk & ((value) << MATRIX_PRAS0_M6PR_Pos)))
#define MATRIX_PRBS0_M8PR_Pos   0
#define MATRIX_PRBS0_M8PR_Msk   (0x3u << MATRIX_PRBS0_M8PR_Pos)
 (MATRIX_PRBS0) Master 8 Priority
#define MATRIX_PRBS0_M8PR(value)   ((MATRIX_PRBS0_M8PR_Msk & ((value) << MATRIX_PRBS0_M8PR_Pos)))
#define MATRIX_PRAS1_M0PR_Pos   0
#define MATRIX_PRAS1_M0PR_Msk   (0x3u << MATRIX_PRAS1_M0PR_Pos)
 (MATRIX_PRAS1) Master 0 Priority
#define MATRIX_PRAS1_M0PR(value)   ((MATRIX_PRAS1_M0PR_Msk & ((value) << MATRIX_PRAS1_M0PR_Pos)))
#define MATRIX_PRAS1_M1PR_Pos   4
#define MATRIX_PRAS1_M1PR_Msk   (0x3u << MATRIX_PRAS1_M1PR_Pos)
 (MATRIX_PRAS1) Master 1 Priority
#define MATRIX_PRAS1_M1PR(value)   ((MATRIX_PRAS1_M1PR_Msk & ((value) << MATRIX_PRAS1_M1PR_Pos)))
#define MATRIX_PRAS1_M2PR_Pos   8
#define MATRIX_PRAS1_M2PR_Msk   (0x3u << MATRIX_PRAS1_M2PR_Pos)
 (MATRIX_PRAS1) Master 2 Priority
#define MATRIX_PRAS1_M2PR(value)   ((MATRIX_PRAS1_M2PR_Msk & ((value) << MATRIX_PRAS1_M2PR_Pos)))
#define MATRIX_PRAS1_M3PR_Pos   12
#define MATRIX_PRAS1_M3PR_Msk   (0x3u << MATRIX_PRAS1_M3PR_Pos)
 (MATRIX_PRAS1) Master 3 Priority
#define MATRIX_PRAS1_M3PR(value)   ((MATRIX_PRAS1_M3PR_Msk & ((value) << MATRIX_PRAS1_M3PR_Pos)))
#define MATRIX_PRAS1_M4PR_Pos   16
#define MATRIX_PRAS1_M4PR_Msk   (0x3u << MATRIX_PRAS1_M4PR_Pos)
 (MATRIX_PRAS1) Master 4 Priority
#define MATRIX_PRAS1_M4PR(value)   ((MATRIX_PRAS1_M4PR_Msk & ((value) << MATRIX_PRAS1_M4PR_Pos)))
#define MATRIX_PRAS1_M5PR_Pos   20
#define MATRIX_PRAS1_M5PR_Msk   (0x3u << MATRIX_PRAS1_M5PR_Pos)
 (MATRIX_PRAS1) Master 5 Priority
#define MATRIX_PRAS1_M5PR(value)   ((MATRIX_PRAS1_M5PR_Msk & ((value) << MATRIX_PRAS1_M5PR_Pos)))
#define MATRIX_PRAS1_M6PR_Pos   24
#define MATRIX_PRAS1_M6PR_Msk   (0x3u << MATRIX_PRAS1_M6PR_Pos)
 (MATRIX_PRAS1) Master 6 Priority
#define MATRIX_PRAS1_M6PR(value)   ((MATRIX_PRAS1_M6PR_Msk & ((value) << MATRIX_PRAS1_M6PR_Pos)))
#define MATRIX_PRBS1_M8PR_Pos   0
#define MATRIX_PRBS1_M8PR_Msk   (0x3u << MATRIX_PRBS1_M8PR_Pos)
 (MATRIX_PRBS1) Master 8 Priority
#define MATRIX_PRBS1_M8PR(value)   ((MATRIX_PRBS1_M8PR_Msk & ((value) << MATRIX_PRBS1_M8PR_Pos)))
#define MATRIX_PRAS2_M0PR_Pos   0
#define MATRIX_PRAS2_M0PR_Msk   (0x3u << MATRIX_PRAS2_M0PR_Pos)
 (MATRIX_PRAS2) Master 0 Priority
#define MATRIX_PRAS2_M0PR(value)   ((MATRIX_PRAS2_M0PR_Msk & ((value) << MATRIX_PRAS2_M0PR_Pos)))
#define MATRIX_PRAS2_M1PR_Pos   4
#define MATRIX_PRAS2_M1PR_Msk   (0x3u << MATRIX_PRAS2_M1PR_Pos)
 (MATRIX_PRAS2) Master 1 Priority
#define MATRIX_PRAS2_M1PR(value)   ((MATRIX_PRAS2_M1PR_Msk & ((value) << MATRIX_PRAS2_M1PR_Pos)))
#define MATRIX_PRAS2_M2PR_Pos   8
#define MATRIX_PRAS2_M2PR_Msk   (0x3u << MATRIX_PRAS2_M2PR_Pos)
 (MATRIX_PRAS2) Master 2 Priority
#define MATRIX_PRAS2_M2PR(value)   ((MATRIX_PRAS2_M2PR_Msk & ((value) << MATRIX_PRAS2_M2PR_Pos)))
#define MATRIX_PRAS2_M3PR_Pos   12
#define MATRIX_PRAS2_M3PR_Msk   (0x3u << MATRIX_PRAS2_M3PR_Pos)
 (MATRIX_PRAS2) Master 3 Priority
#define MATRIX_PRAS2_M3PR(value)   ((MATRIX_PRAS2_M3PR_Msk & ((value) << MATRIX_PRAS2_M3PR_Pos)))
#define MATRIX_PRAS2_M4PR_Pos   16
#define MATRIX_PRAS2_M4PR_Msk   (0x3u << MATRIX_PRAS2_M4PR_Pos)
 (MATRIX_PRAS2) Master 4 Priority
#define MATRIX_PRAS2_M4PR(value)   ((MATRIX_PRAS2_M4PR_Msk & ((value) << MATRIX_PRAS2_M4PR_Pos)))
#define MATRIX_PRAS2_M5PR_Pos   20
#define MATRIX_PRAS2_M5PR_Msk   (0x3u << MATRIX_PRAS2_M5PR_Pos)
 (MATRIX_PRAS2) Master 5 Priority
#define MATRIX_PRAS2_M5PR(value)   ((MATRIX_PRAS2_M5PR_Msk & ((value) << MATRIX_PRAS2_M5PR_Pos)))
#define MATRIX_PRAS2_M6PR_Pos   24
#define MATRIX_PRAS2_M6PR_Msk   (0x3u << MATRIX_PRAS2_M6PR_Pos)
 (MATRIX_PRAS2) Master 6 Priority
#define MATRIX_PRAS2_M6PR(value)   ((MATRIX_PRAS2_M6PR_Msk & ((value) << MATRIX_PRAS2_M6PR_Pos)))
#define MATRIX_PRBS2_M8PR_Pos   0
#define MATRIX_PRBS2_M8PR_Msk   (0x3u << MATRIX_PRBS2_M8PR_Pos)
 (MATRIX_PRBS2) Master 8 Priority
#define MATRIX_PRBS2_M8PR(value)   ((MATRIX_PRBS2_M8PR_Msk & ((value) << MATRIX_PRBS2_M8PR_Pos)))
#define MATRIX_PRAS3_M0PR_Pos   0
#define MATRIX_PRAS3_M0PR_Msk   (0x3u << MATRIX_PRAS3_M0PR_Pos)
 (MATRIX_PRAS3) Master 0 Priority
#define MATRIX_PRAS3_M0PR(value)   ((MATRIX_PRAS3_M0PR_Msk & ((value) << MATRIX_PRAS3_M0PR_Pos)))
#define MATRIX_PRAS3_M1PR_Pos   4
#define MATRIX_PRAS3_M1PR_Msk   (0x3u << MATRIX_PRAS3_M1PR_Pos)
 (MATRIX_PRAS3) Master 1 Priority
#define MATRIX_PRAS3_M1PR(value)   ((MATRIX_PRAS3_M1PR_Msk & ((value) << MATRIX_PRAS3_M1PR_Pos)))
#define MATRIX_PRAS3_M2PR_Pos   8
#define MATRIX_PRAS3_M2PR_Msk   (0x3u << MATRIX_PRAS3_M2PR_Pos)
 (MATRIX_PRAS3) Master 2 Priority
#define MATRIX_PRAS3_M2PR(value)   ((MATRIX_PRAS3_M2PR_Msk & ((value) << MATRIX_PRAS3_M2PR_Pos)))
#define MATRIX_PRAS3_M3PR_Pos   12
#define MATRIX_PRAS3_M3PR_Msk   (0x3u << MATRIX_PRAS3_M3PR_Pos)
 (MATRIX_PRAS3) Master 3 Priority
#define MATRIX_PRAS3_M3PR(value)   ((MATRIX_PRAS3_M3PR_Msk & ((value) << MATRIX_PRAS3_M3PR_Pos)))
#define MATRIX_PRAS3_M4PR_Pos   16
#define MATRIX_PRAS3_M4PR_Msk   (0x3u << MATRIX_PRAS3_M4PR_Pos)
 (MATRIX_PRAS3) Master 4 Priority
#define MATRIX_PRAS3_M4PR(value)   ((MATRIX_PRAS3_M4PR_Msk & ((value) << MATRIX_PRAS3_M4PR_Pos)))
#define MATRIX_PRAS3_M5PR_Pos   20
#define MATRIX_PRAS3_M5PR_Msk   (0x3u << MATRIX_PRAS3_M5PR_Pos)
 (MATRIX_PRAS3) Master 5 Priority
#define MATRIX_PRAS3_M5PR(value)   ((MATRIX_PRAS3_M5PR_Msk & ((value) << MATRIX_PRAS3_M5PR_Pos)))
#define MATRIX_PRAS3_M6PR_Pos   24
#define MATRIX_PRAS3_M6PR_Msk   (0x3u << MATRIX_PRAS3_M6PR_Pos)
 (MATRIX_PRAS3) Master 6 Priority
#define MATRIX_PRAS3_M6PR(value)   ((MATRIX_PRAS3_M6PR_Msk & ((value) << MATRIX_PRAS3_M6PR_Pos)))
#define MATRIX_PRBS3_M8PR_Pos   0
#define MATRIX_PRBS3_M8PR_Msk   (0x3u << MATRIX_PRBS3_M8PR_Pos)
 (MATRIX_PRBS3) Master 8 Priority
#define MATRIX_PRBS3_M8PR(value)   ((MATRIX_PRBS3_M8PR_Msk & ((value) << MATRIX_PRBS3_M8PR_Pos)))
#define MATRIX_PRAS4_M0PR_Pos   0
#define MATRIX_PRAS4_M0PR_Msk   (0x3u << MATRIX_PRAS4_M0PR_Pos)
 (MATRIX_PRAS4) Master 0 Priority
#define MATRIX_PRAS4_M0PR(value)   ((MATRIX_PRAS4_M0PR_Msk & ((value) << MATRIX_PRAS4_M0PR_Pos)))
#define MATRIX_PRAS4_M1PR_Pos   4
#define MATRIX_PRAS4_M1PR_Msk   (0x3u << MATRIX_PRAS4_M1PR_Pos)
 (MATRIX_PRAS4) Master 1 Priority
#define MATRIX_PRAS4_M1PR(value)   ((MATRIX_PRAS4_M1PR_Msk & ((value) << MATRIX_PRAS4_M1PR_Pos)))
#define MATRIX_PRAS4_M2PR_Pos   8
#define MATRIX_PRAS4_M2PR_Msk   (0x3u << MATRIX_PRAS4_M2PR_Pos)
 (MATRIX_PRAS4) Master 2 Priority
#define MATRIX_PRAS4_M2PR(value)   ((MATRIX_PRAS4_M2PR_Msk & ((value) << MATRIX_PRAS4_M2PR_Pos)))
#define MATRIX_PRAS4_M3PR_Pos   12
#define MATRIX_PRAS4_M3PR_Msk   (0x3u << MATRIX_PRAS4_M3PR_Pos)
 (MATRIX_PRAS4) Master 3 Priority
#define MATRIX_PRAS4_M3PR(value)   ((MATRIX_PRAS4_M3PR_Msk & ((value) << MATRIX_PRAS4_M3PR_Pos)))
#define MATRIX_PRAS4_M4PR_Pos   16
#define MATRIX_PRAS4_M4PR_Msk   (0x3u << MATRIX_PRAS4_M4PR_Pos)
 (MATRIX_PRAS4) Master 4 Priority
#define MATRIX_PRAS4_M4PR(value)   ((MATRIX_PRAS4_M4PR_Msk & ((value) << MATRIX_PRAS4_M4PR_Pos)))
#define MATRIX_PRAS4_M5PR_Pos   20
#define MATRIX_PRAS4_M5PR_Msk   (0x3u << MATRIX_PRAS4_M5PR_Pos)
 (MATRIX_PRAS4) Master 5 Priority
#define MATRIX_PRAS4_M5PR(value)   ((MATRIX_PRAS4_M5PR_Msk & ((value) << MATRIX_PRAS4_M5PR_Pos)))
#define MATRIX_PRAS4_M6PR_Pos   24
#define MATRIX_PRAS4_M6PR_Msk   (0x3u << MATRIX_PRAS4_M6PR_Pos)
 (MATRIX_PRAS4) Master 6 Priority
#define MATRIX_PRAS4_M6PR(value)   ((MATRIX_PRAS4_M6PR_Msk & ((value) << MATRIX_PRAS4_M6PR_Pos)))
#define MATRIX_PRBS4_M8PR_Pos   0
#define MATRIX_PRBS4_M8PR_Msk   (0x3u << MATRIX_PRBS4_M8PR_Pos)
 (MATRIX_PRBS4) Master 8 Priority
#define MATRIX_PRBS4_M8PR(value)   ((MATRIX_PRBS4_M8PR_Msk & ((value) << MATRIX_PRBS4_M8PR_Pos)))
#define MATRIX_PRAS5_M0PR_Pos   0
#define MATRIX_PRAS5_M0PR_Msk   (0x3u << MATRIX_PRAS5_M0PR_Pos)
 (MATRIX_PRAS5) Master 0 Priority
#define MATRIX_PRAS5_M0PR(value)   ((MATRIX_PRAS5_M0PR_Msk & ((value) << MATRIX_PRAS5_M0PR_Pos)))
#define MATRIX_PRAS5_M1PR_Pos   4
#define MATRIX_PRAS5_M1PR_Msk   (0x3u << MATRIX_PRAS5_M1PR_Pos)
 (MATRIX_PRAS5) Master 1 Priority
#define MATRIX_PRAS5_M1PR(value)   ((MATRIX_PRAS5_M1PR_Msk & ((value) << MATRIX_PRAS5_M1PR_Pos)))
#define MATRIX_PRAS5_M2PR_Pos   8
#define MATRIX_PRAS5_M2PR_Msk   (0x3u << MATRIX_PRAS5_M2PR_Pos)
 (MATRIX_PRAS5) Master 2 Priority
#define MATRIX_PRAS5_M2PR(value)   ((MATRIX_PRAS5_M2PR_Msk & ((value) << MATRIX_PRAS5_M2PR_Pos)))
#define MATRIX_PRAS5_M3PR_Pos   12
#define MATRIX_PRAS5_M3PR_Msk   (0x3u << MATRIX_PRAS5_M3PR_Pos)
 (MATRIX_PRAS5) Master 3 Priority
#define MATRIX_PRAS5_M3PR(value)   ((MATRIX_PRAS5_M3PR_Msk & ((value) << MATRIX_PRAS5_M3PR_Pos)))
#define MATRIX_PRAS5_M4PR_Pos   16
#define MATRIX_PRAS5_M4PR_Msk   (0x3u << MATRIX_PRAS5_M4PR_Pos)
 (MATRIX_PRAS5) Master 4 Priority
#define MATRIX_PRAS5_M4PR(value)   ((MATRIX_PRAS5_M4PR_Msk & ((value) << MATRIX_PRAS5_M4PR_Pos)))
#define MATRIX_PRAS5_M5PR_Pos   20
#define MATRIX_PRAS5_M5PR_Msk   (0x3u << MATRIX_PRAS5_M5PR_Pos)
 (MATRIX_PRAS5) Master 5 Priority
#define MATRIX_PRAS5_M5PR(value)   ((MATRIX_PRAS5_M5PR_Msk & ((value) << MATRIX_PRAS5_M5PR_Pos)))
#define MATRIX_PRAS5_M6PR_Pos   24
#define MATRIX_PRAS5_M6PR_Msk   (0x3u << MATRIX_PRAS5_M6PR_Pos)
 (MATRIX_PRAS5) Master 6 Priority
#define MATRIX_PRAS5_M6PR(value)   ((MATRIX_PRAS5_M6PR_Msk & ((value) << MATRIX_PRAS5_M6PR_Pos)))
#define MATRIX_PRBS5_M8PR_Pos   0
#define MATRIX_PRBS5_M8PR_Msk   (0x3u << MATRIX_PRBS5_M8PR_Pos)
 (MATRIX_PRBS5) Master 8 Priority
#define MATRIX_PRBS5_M8PR(value)   ((MATRIX_PRBS5_M8PR_Msk & ((value) << MATRIX_PRBS5_M8PR_Pos)))
#define MATRIX_PRAS6_M0PR_Pos   0
#define MATRIX_PRAS6_M0PR_Msk   (0x3u << MATRIX_PRAS6_M0PR_Pos)
 (MATRIX_PRAS6) Master 0 Priority
#define MATRIX_PRAS6_M0PR(value)   ((MATRIX_PRAS6_M0PR_Msk & ((value) << MATRIX_PRAS6_M0PR_Pos)))
#define MATRIX_PRAS6_M1PR_Pos   4
#define MATRIX_PRAS6_M1PR_Msk   (0x3u << MATRIX_PRAS6_M1PR_Pos)
 (MATRIX_PRAS6) Master 1 Priority
#define MATRIX_PRAS6_M1PR(value)   ((MATRIX_PRAS6_M1PR_Msk & ((value) << MATRIX_PRAS6_M1PR_Pos)))
#define MATRIX_PRAS6_M2PR_Pos   8
#define MATRIX_PRAS6_M2PR_Msk   (0x3u << MATRIX_PRAS6_M2PR_Pos)
 (MATRIX_PRAS6) Master 2 Priority
#define MATRIX_PRAS6_M2PR(value)   ((MATRIX_PRAS6_M2PR_Msk & ((value) << MATRIX_PRAS6_M2PR_Pos)))
#define MATRIX_PRAS6_M3PR_Pos   12
#define MATRIX_PRAS6_M3PR_Msk   (0x3u << MATRIX_PRAS6_M3PR_Pos)
 (MATRIX_PRAS6) Master 3 Priority
#define MATRIX_PRAS6_M3PR(value)   ((MATRIX_PRAS6_M3PR_Msk & ((value) << MATRIX_PRAS6_M3PR_Pos)))
#define MATRIX_PRAS6_M4PR_Pos   16
#define MATRIX_PRAS6_M4PR_Msk   (0x3u << MATRIX_PRAS6_M4PR_Pos)
 (MATRIX_PRAS6) Master 4 Priority
#define MATRIX_PRAS6_M4PR(value)   ((MATRIX_PRAS6_M4PR_Msk & ((value) << MATRIX_PRAS6_M4PR_Pos)))
#define MATRIX_PRAS6_M5PR_Pos   20
#define MATRIX_PRAS6_M5PR_Msk   (0x3u << MATRIX_PRAS6_M5PR_Pos)
 (MATRIX_PRAS6) Master 5 Priority
#define MATRIX_PRAS6_M5PR(value)   ((MATRIX_PRAS6_M5PR_Msk & ((value) << MATRIX_PRAS6_M5PR_Pos)))
#define MATRIX_PRAS6_M6PR_Pos   24
#define MATRIX_PRAS6_M6PR_Msk   (0x3u << MATRIX_PRAS6_M6PR_Pos)
 (MATRIX_PRAS6) Master 6 Priority
#define MATRIX_PRAS6_M6PR(value)   ((MATRIX_PRAS6_M6PR_Msk & ((value) << MATRIX_PRAS6_M6PR_Pos)))
#define MATRIX_PRBS6_M8PR_Pos   0
#define MATRIX_PRBS6_M8PR_Msk   (0x3u << MATRIX_PRBS6_M8PR_Pos)
 (MATRIX_PRBS6) Master 8 Priority
#define MATRIX_PRBS6_M8PR(value)   ((MATRIX_PRBS6_M8PR_Msk & ((value) << MATRIX_PRBS6_M8PR_Pos)))
#define MATRIX_PRAS7_M0PR_Pos   0
#define MATRIX_PRAS7_M0PR_Msk   (0x3u << MATRIX_PRAS7_M0PR_Pos)
 (MATRIX_PRAS7) Master 0 Priority
#define MATRIX_PRAS7_M0PR(value)   ((MATRIX_PRAS7_M0PR_Msk & ((value) << MATRIX_PRAS7_M0PR_Pos)))
#define MATRIX_PRAS7_M1PR_Pos   4
#define MATRIX_PRAS7_M1PR_Msk   (0x3u << MATRIX_PRAS7_M1PR_Pos)
 (MATRIX_PRAS7) Master 1 Priority
#define MATRIX_PRAS7_M1PR(value)   ((MATRIX_PRAS7_M1PR_Msk & ((value) << MATRIX_PRAS7_M1PR_Pos)))
#define MATRIX_PRAS7_M2PR_Pos   8
#define MATRIX_PRAS7_M2PR_Msk   (0x3u << MATRIX_PRAS7_M2PR_Pos)
 (MATRIX_PRAS7) Master 2 Priority
#define MATRIX_PRAS7_M2PR(value)   ((MATRIX_PRAS7_M2PR_Msk & ((value) << MATRIX_PRAS7_M2PR_Pos)))
#define MATRIX_PRAS7_M3PR_Pos   12
#define MATRIX_PRAS7_M3PR_Msk   (0x3u << MATRIX_PRAS7_M3PR_Pos)
 (MATRIX_PRAS7) Master 3 Priority
#define MATRIX_PRAS7_M3PR(value)   ((MATRIX_PRAS7_M3PR_Msk & ((value) << MATRIX_PRAS7_M3PR_Pos)))
#define MATRIX_PRAS7_M4PR_Pos   16
#define MATRIX_PRAS7_M4PR_Msk   (0x3u << MATRIX_PRAS7_M4PR_Pos)
 (MATRIX_PRAS7) Master 4 Priority
#define MATRIX_PRAS7_M4PR(value)   ((MATRIX_PRAS7_M4PR_Msk & ((value) << MATRIX_PRAS7_M4PR_Pos)))
#define MATRIX_PRAS7_M5PR_Pos   20
#define MATRIX_PRAS7_M5PR_Msk   (0x3u << MATRIX_PRAS7_M5PR_Pos)
 (MATRIX_PRAS7) Master 5 Priority
#define MATRIX_PRAS7_M5PR(value)   ((MATRIX_PRAS7_M5PR_Msk & ((value) << MATRIX_PRAS7_M5PR_Pos)))
#define MATRIX_PRAS7_M6PR_Pos   24
#define MATRIX_PRAS7_M6PR_Msk   (0x3u << MATRIX_PRAS7_M6PR_Pos)
 (MATRIX_PRAS7) Master 6 Priority
#define MATRIX_PRAS7_M6PR(value)   ((MATRIX_PRAS7_M6PR_Msk & ((value) << MATRIX_PRAS7_M6PR_Pos)))
#define MATRIX_PRBS7_M8PR_Pos   0
#define MATRIX_PRBS7_M8PR_Msk   (0x3u << MATRIX_PRBS7_M8PR_Pos)
 (MATRIX_PRBS7) Master 8 Priority
#define MATRIX_PRBS7_M8PR(value)   ((MATRIX_PRBS7_M8PR_Msk & ((value) << MATRIX_PRBS7_M8PR_Pos)))
#define MATRIX_PRAS8_M0PR_Pos   0
#define MATRIX_PRAS8_M0PR_Msk   (0x3u << MATRIX_PRAS8_M0PR_Pos)
 (MATRIX_PRAS8) Master 0 Priority
#define MATRIX_PRAS8_M0PR(value)   ((MATRIX_PRAS8_M0PR_Msk & ((value) << MATRIX_PRAS8_M0PR_Pos)))
#define MATRIX_PRAS8_M1PR_Pos   4
#define MATRIX_PRAS8_M1PR_Msk   (0x3u << MATRIX_PRAS8_M1PR_Pos)
 (MATRIX_PRAS8) Master 1 Priority
#define MATRIX_PRAS8_M1PR(value)   ((MATRIX_PRAS8_M1PR_Msk & ((value) << MATRIX_PRAS8_M1PR_Pos)))
#define MATRIX_PRAS8_M2PR_Pos   8
#define MATRIX_PRAS8_M2PR_Msk   (0x3u << MATRIX_PRAS8_M2PR_Pos)
 (MATRIX_PRAS8) Master 2 Priority
#define MATRIX_PRAS8_M2PR(value)   ((MATRIX_PRAS8_M2PR_Msk & ((value) << MATRIX_PRAS8_M2PR_Pos)))
#define MATRIX_PRAS8_M3PR_Pos   12
#define MATRIX_PRAS8_M3PR_Msk   (0x3u << MATRIX_PRAS8_M3PR_Pos)
 (MATRIX_PRAS8) Master 3 Priority
#define MATRIX_PRAS8_M3PR(value)   ((MATRIX_PRAS8_M3PR_Msk & ((value) << MATRIX_PRAS8_M3PR_Pos)))
#define MATRIX_PRAS8_M4PR_Pos   16
#define MATRIX_PRAS8_M4PR_Msk   (0x3u << MATRIX_PRAS8_M4PR_Pos)
 (MATRIX_PRAS8) Master 4 Priority
#define MATRIX_PRAS8_M4PR(value)   ((MATRIX_PRAS8_M4PR_Msk & ((value) << MATRIX_PRAS8_M4PR_Pos)))
#define MATRIX_PRAS8_M5PR_Pos   20
#define MATRIX_PRAS8_M5PR_Msk   (0x3u << MATRIX_PRAS8_M5PR_Pos)
 (MATRIX_PRAS8) Master 5 Priority
#define MATRIX_PRAS8_M5PR(value)   ((MATRIX_PRAS8_M5PR_Msk & ((value) << MATRIX_PRAS8_M5PR_Pos)))
#define MATRIX_PRAS8_M6PR_Pos   24
#define MATRIX_PRAS8_M6PR_Msk   (0x3u << MATRIX_PRAS8_M6PR_Pos)
 (MATRIX_PRAS8) Master 6 Priority
#define MATRIX_PRAS8_M6PR(value)   ((MATRIX_PRAS8_M6PR_Msk & ((value) << MATRIX_PRAS8_M6PR_Pos)))
#define MATRIX_PRBS8_M8PR_Pos   0
#define MATRIX_PRBS8_M8PR_Msk   (0x3u << MATRIX_PRBS8_M8PR_Pos)
 (MATRIX_PRBS8) Master 8 Priority
#define MATRIX_PRBS8_M8PR(value)   ((MATRIX_PRBS8_M8PR_Msk & ((value) << MATRIX_PRBS8_M8PR_Pos)))
#define MATRIX_MRCR_RCB0   (0x1u << 0)
 (MATRIX_MRCR) Remap Command Bit for Master 0
#define MATRIX_MRCR_RCB1   (0x1u << 1)
 (MATRIX_MRCR) Remap Command Bit for Master 1
#define MATRIX_MRCR_RCB2   (0x1u << 2)
 (MATRIX_MRCR) Remap Command Bit for Master 2
#define MATRIX_MRCR_RCB3   (0x1u << 3)
 (MATRIX_MRCR) Remap Command Bit for Master 3
#define MATRIX_MRCR_RCB4   (0x1u << 4)
 (MATRIX_MRCR) Remap Command Bit for Master 4
#define MATRIX_MRCR_RCB5   (0x1u << 5)
 (MATRIX_MRCR) Remap Command Bit for Master 5
#define MATRIX_MRCR_RCB6   (0x1u << 6)
 (MATRIX_MRCR) Remap Command Bit for Master 6
#define MATRIX_MRCR_RCB8   (0x1u << 8)
 (MATRIX_MRCR) Remap Command Bit for Master 8
#define CCFG_SYSIO_SYSIO4   (0x1u << 4)
 (CCFG_SYSIO) PB4 or TDI Assignment
#define CCFG_SYSIO_SYSIO5   (0x1u << 5)
 (CCFG_SYSIO) PB5 or TDO/TRACESWO Assignment
#define CCFG_SYSIO_SYSIO6   (0x1u << 6)
 (CCFG_SYSIO) PB6 or TMS/SWDIO Assignment
#define CCFG_SYSIO_SYSIO7   (0x1u << 7)
 (CCFG_SYSIO) PB7 or TCK/SWCLK Assignment
#define CCFG_SYSIO_SYSIO12   (0x1u << 12)
 (CCFG_SYSIO) PB12 or ERASE Assignment
#define CCFG_SMCNFCS_SMC_NFCS0   (0x1u << 0)
 (CCFG_SMCNFCS) SMC NAND Flash Chip Select 0 Assignment
#define CCFG_SMCNFCS_SMC_NFCS1   (0x1u << 1)
 (CCFG_SMCNFCS) SMC NAND Flash Chip Select 1 Assignment
#define CCFG_SMCNFCS_SMC_NFCS2   (0x1u << 2)
 (CCFG_SMCNFCS) SMC NAND Flash Chip Select 2 Assignment
#define CCFG_SMCNFCS_SMC_NFCS3   (0x1u << 3)
 (CCFG_SMCNFCS) SMC NAND Flash Chip Select 3 Assignment
#define CCFG_SMCNFCS_SDRAMEN   (0x1u << 4)
 (CCFG_SMCNFCS) SDRAM Enable
#define MATRIX_WPMR_WPEN   (0x1u << 0)
 (MATRIX_WPMR) Write Protection Enable
#define MATRIX_WPMR_WPKEY_Pos   8
#define MATRIX_WPMR_WPKEY_Msk   (0xffffffu << MATRIX_WPMR_WPKEY_Pos)
 (MATRIX_WPMR) Write Protection Key
#define MATRIX_WPMR_WPKEY(value)   ((MATRIX_WPMR_WPKEY_Msk & ((value) << MATRIX_WPMR_WPKEY_Pos)))
#define MATRIX_WPMR_WPKEY_PASSWD   (0x4D4154u << 8)
 (MATRIX_WPMR) Writing any other value in this field aborts the write operation of the WPEN bit.Always reads as 0.
#define MATRIX_WPSR_WPVS   (0x1u << 0)
 (MATRIX_WPSR) Write Protection Violation Status
#define MATRIX_WPSR_WPVSRC_Pos   8
#define MATRIX_WPSR_WPVSRC_Msk   (0xffffu << MATRIX_WPSR_WPVSRC_Pos)
 (MATRIX_WPSR) Write Protection Violation Source
SOFTWARE API DEFINITION FOR AHB Bus Matrix
