RTEMS
5.1
Implementation details. More...
struct | T_case_context |
struct | T_check_context |
struct | T_check_context_msg |
#define | T_CHECK_STOP 1U |
#define | T_CHECK_QUIET 2U |
#define | T_CHECK_STEP_FLAG 4U |
#define | T_CHECK_STEP_TO_FLAGS(step) ((unsigned int)(step) << 8) |
#define | T_CHECK_STEP_FROM_FLAGS(flags) ((flags) >> 8) |
#define | T_CHECK_STEP(step) (T_CHECK_STEP_TO_FLAGS(step) | T_CHECK_STEP_FLAG) |
#define | T_flags_true(a, flags, ...) |
#define | T_flags_eq(a, e, flags, ...) T_flags_true((a) == (e), flags, __VA_ARGS__) |
#define | T_flags_ne(a, e, flags, ...) T_flags_true((a) != (e), flags, __VA_ARGS__) |
#define | T_flags_eq_ptr(a, e, flags, sa, se) |
#define | T_flags_ne_ptr(a, e, flags, sa, se) |
#define | T_flags_null(a, flags, sa) |
#define | T_flags_not_null(a, flags, sa) |
#define | T_flags_eq_mem(a, e, n, flags, sa, se, sn) |
#define | T_flags_ne_mem(a, e, n, flags, sa, se, sn) |
#define | T_flags_eq_str(a, e, flags) |
#define | T_flags_ne_str(a, e, flags) |
#define | T_flags_eq_nstr(a, e, n, flags) |
#define | T_flags_ne_nstr(a, e, n, flags) |
#define | T_flags_eq_char(a, e, flags) |
#define | T_flags_ne_char(a, e, flags) |
#define | T_flags_eq_int(a, e, flags) |
#define | T_flags_ne_int(a, e, flags) |
#define | T_flags_ge_int(a, e, flags) |
#define | T_flags_gt_int(a, e, flags) |
#define | T_flags_le_int(a, e, flags) |
#define | T_flags_lt_int(a, e, flags) |
#define | T_flags_eq_uint(a, e, flags) |
#define | T_flags_ne_uint(a, e, flags) |
#define | T_flags_ge_uint(a, e, flags) |
#define | T_flags_gt_uint(a, e, flags) |
#define | T_flags_le_uint(a, e, flags) |
#define | T_flags_lt_uint(a, e, flags) |
#define | T_flags_eq_long(a, e, flags) |
#define | T_flags_ne_long(a, e, flags) |
#define | T_flags_ge_long(a, e, flags) |
#define | T_flags_gt_long(a, e, flags) |
#define | T_flags_le_long(a, e, flags) |
#define | T_flags_lt_long(a, e, flags) |
#define | T_flags_eq_ulong(a, e, flags) |
#define | T_flags_ne_ulong(a, e, flags) |
#define | T_flags_ge_ulong(a, e, flags) |
#define | T_flags_gt_ulong(a, e, flags) |
#define | T_flags_le_ulong(a, e, flags) |
#define | T_flags_lt_ulong(a, e, flags) |
#define | T_flags_eq_ll(a, e, flags) |
#define | T_flags_ne_ll(a, e, flags) |
#define | T_flags_ge_ll(a, e, flags) |
#define | T_flags_gt_ll(a, e, flags) |
#define | T_flags_le_ll(a, e, flags) |
#define | T_flags_lt_ll(a, e, flags) |
#define | T_flags_eq_ull(a, e, flags) |
#define | T_flags_ne_ull(a, e, flags) |
#define | T_flags_ge_ull(a, e, flags) |
#define | T_flags_gt_ull(a, e, flags) |
#define | T_flags_le_ull(a, e, flags) |
#define | T_flags_lt_ull(a, e, flags) |
#define | T_flags_eno(a, e, flags) |
#define | T_flags_eno_success(a, flags) |
#define | T_flags_psx_error(a, eno, flags) |
#define | T_flags_psx_success(a, flags) |
Typedefs | |
typedef struct T_case_context | T_case_context |
void | T_case_register (T_case_context *) |
void | T_check_true (bool, const T_check_context *, const char *,...) |
void | T_check_eq_ptr (const void *, const T_check_context_msg *, const void *) |
void | T_check_ne_ptr (const void *, const T_check_context_msg *, const void *) |
void | T_check_null (const void *, const T_check_context_msg *) |
void | T_check_not_null (const void *, const T_check_context_msg *) |
void | T_check_eq_mem (const void *, const T_check_context_msg *, const void *, size_t) |
void | T_check_ne_mem (const void *, const T_check_context_msg *, const void *, size_t) |
void | T_check_eq_str (const char *, const T_check_context *, const char *) |
void | T_check_ne_str (const char *, const T_check_context *, const char *) |
void | T_check_eq_nstr (const char *, const T_check_context *, const char *, size_t) |
void | T_check_ne_nstr (const char *, const T_check_context *, const char *, size_t) |
void | T_check_eq_char (char, const T_check_context *, char) |
void | T_check_ne_char (char, const T_check_context *, char) |
void | T_check_eq_int (int, const T_check_context *, int) |
void | T_check_ne_int (int, const T_check_context *, int) |
void | T_check_ge_int (int, const T_check_context *, int) |
void | T_check_gt_int (int, const T_check_context *, int) |
void | T_check_le_int (int, const T_check_context *, int) |
void | T_check_lt_int (int, const T_check_context *, int) |
void | T_check_eq_uint (unsigned int, const T_check_context *, unsigned int) |
void | T_check_ne_uint (unsigned int, const T_check_context *, unsigned int) |
void | T_check_ge_uint (unsigned int, const T_check_context *, unsigned int) |
void | T_check_gt_uint (unsigned int, const T_check_context *, unsigned int) |
void | T_check_le_uint (unsigned int, const T_check_context *, unsigned int) |
void | T_check_lt_uint (unsigned int, const T_check_context *, unsigned int) |
void | T_check_eq_long (long, const T_check_context *, long) |
void | T_check_ne_long (long, const T_check_context *, long) |
void | T_check_ge_long (long, const T_check_context *, long) |
void | T_check_gt_long (long, const T_check_context *, long) |
void | T_check_le_long (long, const T_check_context *, long) |
void | T_check_lt_long (long, const T_check_context *, long) |
void | T_check_eq_ulong (unsigned long, const T_check_context *, unsigned long) |
void | T_check_ne_ulong (unsigned long, const T_check_context *, unsigned long) |
void | T_check_ge_ulong (unsigned long, const T_check_context *, unsigned long) |
void | T_check_gt_ulong (unsigned long, const T_check_context *, unsigned long) |
void | T_check_le_ulong (unsigned long, const T_check_context *, unsigned long) |
void | T_check_lt_ulong (unsigned long, const T_check_context *, unsigned long) |
void | T_check_eq_ll (long long, const T_check_context *, long long) |
void | T_check_ne_ll (long long, const T_check_context *, long long) |
void | T_check_ge_ll (long long, const T_check_context *, long long) |
void | T_check_gt_ll (long long, const T_check_context *, long long) |
void | T_check_le_ll (long long, const T_check_context *, long long) |
void | T_check_lt_ll (long long, const T_check_context *, long long) |
void | T_check_eq_ull (unsigned long long, const T_check_context *, unsigned long long) |
void | T_check_ne_ull (unsigned long long, const T_check_context *, unsigned long long) |
void | T_check_ge_ull (unsigned long long, const T_check_context *, unsigned long long) |
void | T_check_gt_ull (unsigned long long, const T_check_context *, unsigned long long) |
void | T_check_le_ull (unsigned long long, const T_check_context *, unsigned long long) |
void | T_check_lt_ull (unsigned long long, const T_check_context *, unsigned long long) |
void | T_check_eno (int, const T_check_context *, int) |
void | T_check_eno_success (int, const T_check_context *) |
void | T_check_psx_error (int, const T_check_context *, int) |
void | T_check_psx_success (int, const T_check_context *) |
#define T_flags_eno | ( | a, | |
e, | |||
flags | |||
#define T_flags_eno_success | ( | a, | |
flags | |||
#define T_flags_eq_char | ( | a, | |
e, | |||
flags | |||
#define T_flags_eq_int | ( | a, | |
e, | |||
flags | |||
#define T_flags_eq_ll | ( | a, | |
e, | |||
flags | |||
#define T_flags_eq_long | ( | a, | |
e, | |||
flags | |||
#define T_flags_eq_mem | ( | a, | |
e, | |||
n, | |||
flags, | |||
sa, | |||
se, | |||
sn | |||
#define T_flags_eq_nstr | ( | a, | |
e, | |||
n, | |||
flags | |||
#define T_flags_eq_ptr | ( | a, | |
e, | |||
flags, | |||
sa, | |||
se | |||
#define T_flags_eq_str | ( | a, | |
e, | |||
flags | |||
#define T_flags_eq_uint | ( | a, | |
e, | |||
flags | |||
#define T_flags_eq_ull | ( | a, | |
e, | |||
flags | |||
#define T_flags_eq_ulong | ( | a, | |
e, | |||
flags | |||
#define T_flags_ge_int | ( | a, | |
e, | |||
flags | |||
#define T_flags_ge_ll | ( | a, | |
e, | |||
flags | |||
#define T_flags_ge_long | ( | a, | |
e, | |||
flags | |||
#define T_flags_ge_uint | ( | a, | |
e, | |||
flags | |||
#define T_flags_ge_ull | ( | a, | |
e, | |||
flags | |||
#define T_flags_ge_ulong | ( | a, | |
e, | |||
flags | |||
#define T_flags_gt_int | ( | a, | |
e, | |||
flags | |||
#define T_flags_gt_ll | ( | a, | |
e, | |||
flags | |||
#define T_flags_gt_long | ( | a, | |
e, | |||
flags | |||
#define T_flags_gt_uint | ( | a, | |
e, | |||
flags | |||
#define T_flags_gt_ull | ( | a, | |
e, | |||
flags | |||
#define T_flags_gt_ulong | ( | a, | |
e, | |||
flags | |||
#define T_flags_le_int | ( | a, | |
e, | |||
flags | |||
#define T_flags_le_ll | ( | a, | |
e, | |||
flags | |||
#define T_flags_le_long | ( | a, | |
e, | |||
flags | |||
#define T_flags_le_uint | ( | a, | |
e, | |||
flags | |||
#define T_flags_le_ull | ( | a, | |
e, | |||
flags | |||
#define T_flags_le_ulong | ( | a, | |
e, | |||
flags | |||
#define T_flags_lt_int | ( | a, | |
e, | |||
flags | |||
#define T_flags_lt_ll | ( | a, | |
e, | |||
flags | |||
#define T_flags_lt_long | ( | a, | |
e, | |||
flags | |||
#define T_flags_lt_uint | ( | a, | |
e, | |||
flags | |||
#define T_flags_lt_ull | ( | a, | |
e, | |||
flags | |||
#define T_flags_lt_ulong | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_char | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_int | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_ll | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_long | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_mem | ( | a, | |
e, | |||
n, | |||
flags, | |||
sa, | |||
se, | |||
sn | |||
#define T_flags_ne_nstr | ( | a, | |
e, | |||
n, | |||
flags | |||
#define T_flags_ne_ptr | ( | a, | |
e, | |||
flags, | |||
sa, | |||
se | |||
#define T_flags_ne_str | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_uint | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_ull | ( | a, | |
e, | |||
flags | |||
#define T_flags_ne_ulong | ( | a, | |
e, | |||
flags | |||
#define T_flags_not_null | ( | a, | |
flags, | |||
sa | |||
#define T_flags_null | ( | a, | |
flags, | |||
sa | |||
#define T_flags_psx_error | ( | a, | |
eno, | |||
flags | |||
#define T_flags_psx_success | ( | a, | |
flags | |||
#define T_flags_true | ( | a, | |
flags, | |||
