| Boolean Checks |
| Checks for boolean expressions.
| Character Checks |
| Checks for characters (char).
| Destructors |
| Support to run destructors at the end of a test case.
| Generic Checks |
| Checks for data types with an equality or inequality operator.
| Memory Area Checks |
| Checks for memory areas.
| POSIX Status and Error Number Checks |
| Checks for POSIX status and error numbers.
| Pointer Checks |
| Checks for pointers.
| RTEMS Test Framework Implementation |
| Implementation details.
| Runtime Measurements |
| Support to measure the runtime of code fragments.
| Signed 16-Bit Integer Checks |
| Checks for signed 16-bit integers (int16_t).
| Signed 32-Bit Integer Checks |
| Checks for signed 32-bit integers (int32_t).
| Signed 64-Bit Integer Checks |
| Checks for signed 64-bit integers (int64_t).
| Signed 8-Bit Integer Checks |
| Checks for signed 8-bit integers (int8_t).
| Signed Character Checks |
| Checks for signed characters (signed char).
| Signed Integer Checks |
| Checks for signed integers (int).
| Signed Long Integer Checks |
| Checks for signed long integers (long).
| Signed Pointer Value Checks |
| Checks for signed pointer values (intptr_t).
| Signed Short Integer Checks |
| Checks for signed short integers (short).
| Signed Size Checks |
| Checks for signed sizes (ssize_t).
| Size Checks |
| Checks for sizes (size_t).
| String Checks |
| Checks for strings.
| Time Services |
| Time service functions.
| Unsigned 16-Bit Integer Checks |
| Checks for unsigned 16-bit integers (uint16_t).
| Unsigned 32-Bit Integer Checks |
| Checks for unsigned 32-bit integers (uint32_t).
| Unsigned 64-Bit Integer Checks |
| Checks for unsigned 64-bit integers (uint64_t).
| Unsigned 8-Bit Integer Checks |
| Checks for unsigned 8-bit integers (uint8_t).
| Unsigned Character Checks |
| Checks for unsigned characters (unsigned char).
| Unsigned Integer Checks |
| Checks for unsigned integers (unsigned int).
| Unsigned Long Integer Checks |
| Checks for unsigned long integers (unsigned long).
| Unsigned Long Long Integer Checks |
| Checks for unsigned long long integers (unsigned long long).
| Unsigned Pointer Value Checks |
| Checks for unsigned pointer values (uintptr_t).
| Unsigned Short Integer Checks |
| Checks for unsigned short integers (unsigned short).
