RTEMS
5.1
ALT_STATUS_CODE | alt_l2_addr_filter_cfg_get (uint32_t *addr_filt_start, uint32_t *addr_filt_end) |
ALT_STATUS_CODE | alt_l2_addr_filter_cfg_set (uint32_t addr_filt_start, uint32_t addr_filt_end) |
The L2 cache address filter controls where physical addresses within certain ranges of the MPU address space are directed.
The L2 cache has master port connections to the L3 interconnect and the SDRAM controller. A programmable address filter controls which portions of the 32-bit physical address space use each master.
When l2 address filtering is configured and enabled, a physical address will be redirected to one master or the other based upon the address filter configuration.
If address_filter_start <= physical_address < address_filter_end:
See: ARM DDI 0246F, CoreLink Level 2 Cache Controller L2C-310 Technical Reference Manual, Section 3.3.12 Address Filtering for more information.
ALT_STATUS_CODE alt_l2_addr_filter_cfg_get | ( | uint32_t * | addr_filt_start, |
uint32_t * | addr_filt_end | ||
Get the L2 cache address filtering configuration settings.
addr_filt_start | [out] An output parameter variable for the address filtering start address for the range of physical addresses redirected to the SDRAM AXI master port. The value returned is always a 1 MiB aligned address. |
addr_filt_end | [out] An output parameter variable for the address filtering end address for the range of physical addresses redirected to the SDRAM AXI master port. The value returned is always a 1 MiB aligned address. |
ALT_E_SUCCESS | The operation was successful. |
ALT_E_ERROR | The operation failed. |
ALT_E_BAD_ARG | An bad argument was passed. Either addr_filt_start or addr_filt_end or both are invalid addresses. |
ALT_STATUS_CODE alt_l2_addr_filter_cfg_set | ( | uint32_t | addr_filt_start, |
uint32_t | addr_filt_end | ||
Set the L2 cache address filtering configuration settings.
Address filtering start and end values must be 1 MiB aligned.
addr_filt_start | The address filtering start address for the range of physical addresses redirected to the SDRAM AXI master port. Only bits [31:20] of the address are valid. Any bits outside the range [31:20] are invalid and will cause an error status to be returned. |
addr_filt_end | The address filtering end address for the range of physical addresses redirected to the SDRAM AXI master port. Only bits [31:20] of the address are valid. Any bits outside the range [31:20] are invalid and will cause an error status to be returned. |
ALT_E_SUCCESS | The operation was succesful. |
ALT_E_ARG_RANGE | An argument violates a range constraint. One or more address arguments do not satisfy the argument constraints. |
