RTEMS  5.1
Typedefs | Enumerations | Functions
typedef enum ALT_CACHE_L2_INTERRUPT_e ALT_CACHE_L2_INTERRUPT_t
enum  ALT_CACHE_L2_INTERRUPT_e {
  ALT_CACHE_L2_INTERRUPT_DECERR = 1 << 8, ALT_CACHE_L2_INTERRUPT_SLVERR = 1 << 7, ALT_CACHE_L2_INTERRUPT_ERRRD = 1 << 6, ALT_CACHE_L2_INTERRUPT_ERRRT = 1 << 5,
  ALT_CACHE_L2_INTERRUPT_ERRWD = 1 << 4, ALT_CACHE_L2_INTERRUPT_ERRWT = 1 << 3, ALT_CACHE_L2_INTERRUPT_PARRD = 1 << 2, ALT_CACHE_L2_INTERRUPT_PARRT = 1 << 1,
  ALT_CACHE_L2_INTERRUPT_ECNTR = 1 << 0
ALT_STATUS_CODE alt_cache_l2_init (void)
ALT_STATUS_CODE alt_cache_l2_uninit (void)
ALT_STATUS_CODE alt_cache_l2_prefetch_enable (void)
ALT_STATUS_CODE alt_cache_l2_prefetch_disable (void)
bool alt_cache_l2_prefetch_is_enabled (void)
ALT_STATUS_CODE alt_cache_l2_parity_enable (void)
ALT_STATUS_CODE alt_cache_l2_parity_disable (void)
bool alt_cache_l2_parity_is_enabled (void)
ALT_STATUS_CODE alt_cache_l2_enable (void)
ALT_STATUS_CODE alt_cache_l2_disable (void)
bool alt_cache_l2_is_enabled (void)
ALT_STATUS_CODE alt_cache_l2_sync (void)
ALT_STATUS_CODE alt_cache_l2_invalidate (void *paddress, size_t length)
ALT_STATUS_CODE alt_cache_l2_invalidate_all (void)
ALT_STATUS_CODE alt_cache_l2_clean (void *paddress, size_t length)
ALT_STATUS_CODE alt_cache_l2_clean_all (void)
ALT_STATUS_CODE alt_cache_l2_purge (void *paddress, size_t length)
ALT_STATUS_CODE alt_cache_l2_purge_all (void)
ALT_STATUS_CODE alt_cache_l2_int_enable (uint32_t interrupt)
ALT_STATUS_CODE alt_cache_l2_int_disable (uint32_t interrupt)
uint32_t alt_cache_l2_int_status_get (void)
ALT_STATUS_CODE alt_cache_l2_int_status_clear (uint32_t interrupt)
This API group provides functions to interact with various features of the L2 cache on the SoCFPGA. This includes the following features:
The API within this group affects the L2 cache which is visible to all CPUs on the system.
With respect to bring-up, the L1 and L2 cache controller setups are fully independent. The L2 can be setup at any time, before or after the L1 is setup.
◆ ALT_CACHE_L2_INTERRUPT_e
This type definition enumerates all the interrupt conditions that can be generated by the L2 cache controller as register mask values.
Decode error received on the master ports from L3.
Slave error received on the master ports from L3.
Error on the L2 data RAM read.
Error on the L2 tag RAM read.
Error on the L2 data RAM write.
Error on the L2 tag RAM write.
Parity error on the L2 data RAM read.
Parity error on the L2 tag RAM read.
Event counter overflow or increment.
◆ alt_cache_l2_clean()
ALT_STATUS_CODE alt_cache_l2_clean ( void *  paddress,
size_t  length
Cleans the specified contents of the L2 cache for the given memory segment.
The memory segment address and length specified must align to the characteristics of the cache line. This means the address and length must be multiples of the cache line size. To determine the cache line size, use the ALT_CACHE_LINE_SIZE macro.
Parameters
paddressThe physical address of the memory segment to be cleaned.
lengthThe length of the memory segment to be cleaned.
Return values
ALT_E_SUCCESSThe operation was successful.
ALT_E_ERRORThe operation failed.
ALT_E_BAD_ARGThe memory segment is invalid.
ALT_E_TMOThe memory operation timed out.
◆ alt_cache_l2_clean_all()
ALT_STATUS_CODE alt_cache_l2_clean_all ( void  )
Cleans the entire L2 cache. All L2 cache controller interrupts will be temporarily disabled while the clean operation is in progress and restored once the it is finished.
Return values
◆ alt_cache_l2_disable()
ALT_STATUS_CODE alt_cache_l2_disable ( void  )
Disables the L2 cache.
If the L2 cache is already disabled, nothing is done. Otherwise the entire contents of the cache is first cleaned before being disabled.
Return values
◆ alt_cache_l2_enable()
ALT_STATUS_CODE alt_cache_l2_enable ( void  )
Enables the L2 cache.
If the L2 cache is already enabled, nothing is done. Otherwise the entire contents of the cache is first invalidated before being enabled.
Return values
◆ alt_cache_l2_init()
ALT_STATUS_CODE alt_cache_l2_init ( void  )
Initializes the L2 cache controller.
Return values
ALT_E_SUCCESSSuccessful status.
ALT_E_ERRORDetails about error status code
◆ alt_cache_l2_int_disable()
ALT_STATUS_CODE alt_cache_l2_int_disable ( uint32_t  interrupt)
Disables the L2 cache controller interrupts for the specified set of condition(s).
Parameters
interruptA register mask of the selected L2 cache controller interrupting conditions.
Return values
◆ alt_cache_l2_int_enable()
ALT_STATUS_CODE alt_cache_l2_int_enable ( uint32_t  interrupt)
Enables the L2 cache controller interrupts for the specified set of condition(s).
Parameters
Return values
◆ alt_cache_l2_int_status_clear()
ALT_STATUS_CODE alt_cache_l2_int_status_clear ( uint32_t  interrupt)
Clears the specified conditon(s) causing the L2 cache controller to interrupt as a mask. Condition(s) specified which are not causing an interrupt or condition(s) specified which are not enabled are ignored.
Parameters
Return values
◆ alt_cache_l2_int_status_get()
uint32_t alt_cache_l2_int_status_get ( void  )
Gets the condition(s) causing the L2 cache controller to interrupt as a register mask.
Returns
A register mask of the currently asserted and enabled conditions resulting in an interrupt being generated.
◆ alt_cache_l2_invalidate()
ALT_STATUS_CODE alt_cache_l2_invalidate ( void *  paddress,
size_t  length
Invalidates the specified contents of the L2 cache for the given memory segment.
Parameters
paddressThe physical address of the memory segment to be invalidated.
lengthThe length of the memory segment to be invalidated.
Return values
◆ alt_cache_l2_invalidate_all()
ALT_STATUS_CODE alt_cache_l2_invalidate_all ( void  )
Invalidates th entire contents of the L2 cache.
Normally this is done automatically as part of alt_cache_l2_enable(), but in certain circumstances it may be necessary to invalidate it manually. An example of this situation is when the address space is remapped and the processor accesses memory from the new memory area.
Return values
◆ alt_cache_l2_is_enabled()
bool alt_cache_l2_is_enabled ( void  )
Returns true when the L2 cache is enabled and false when it is disabled.
Return values
trueThe L2 cache is enabled.
falseThe L2 cache is disabled.
◆ alt_cache_l2_parity_disable()
ALT_STATUS_CODE alt_cache_l2_parity_disable ( void  )
Disables parity error detection in the L2 cache.
Return values
◆ alt_cache_l2_parity_enable()
ALT_STATUS_CODE alt_cache_l2_parity_enable ( void  )
Enables parity error detection in the L2 cache.
Ideally parity should be enabled before the L2 cache is enabled. If the cache is already enabled, it will first be cleaned and disabled before parity is enabled in hardware. Afterwards, the cache will be invalidated and enabled.
For a parity error to be reported, the ALT_CACHE_L2_INTERRUPT_PARRD and / or ALT_CACHE_L2_INTERRUPT_PARRT interrupt condition(s) must be enabled. This is done by calling alt_cache_l2_int_enable(). As well, the L2 cache interrupt must be enabled using the interrupt controller API. Refer to the interrupt controller API for more details about programming the interrupt controller.
In the event of a parity error is detected, the appropriate L2 cache parity interrupt will be raised. To clear the parity interrupt(s), the appropriate L2 cache parity interrupt must be cleared by calling alt_cache_l2_int_status_clear().
For ECC support, refer to the ECC related API documentation for more information.
Return values
◆ alt_cache_l2_parity_is_enabled()
bool alt_cache_l2_parity_is_enabled ( void  )
Returns true when parity error detection is enabled and false when it is disabled.
Return values
trueThe L2 cache parity error detection feature is enabled.
falseThe L2 cache parity error detection feature is disabled.
◆ alt_cache_l2_prefetch_disable()
ALT_STATUS_CODE alt_cache_l2_prefetch_disable ( void  )
Disables the L2 cache features for data and instruction prefetching.
Prefetching can be enabled or disabled while the L2 cache is enabled.
Return values
◆ alt_cache_l2_prefetch_enable()
ALT_STATUS_CODE alt_cache_l2_prefetch_enable ( void  )
Enables the L2 cache features for data and instruction prefetching.
Return values
◆ alt_cache_l2_prefetch_is_enabled()
bool alt_cache_l2_prefetch_is_enabled ( void  )
Returns true if either L2 cache data or instruction prefetch features are enabled and false if no prefetching features are enabled.
Return values
trueThe L2 data and instruction prefetch features are enabled.
falseSome L2 data and instruction prefetch features are disabled.
◆ alt_cache_l2_purge()
ALT_STATUS_CODE alt_cache_l2_purge ( void *  paddress,
size_t  length
Cleans and invalidates the specified contents of the L2 cache for the given memory segment.
Parameters
paddressThe physical address of the memory segment to be purged.
lengthThe length of the memory segment to be purged.
Return values
◆ alt_cache_l2_purge_all()
ALT_STATUS_CODE alt_cache_l2_purge_all ( void  )
Cleans and invalidates the entire L2 cache. All L2 cache controller interrupts will be temporarily disabled while the clean and invalidate operation is in progress and restored once the it is finished.
Return values
◆ alt_cache_l2_sync()
ALT_STATUS_CODE alt_cache_l2_sync ( void  )
Flushes the L2 cache controller hardware buffers.
Return values
◆ alt_cache_l2_uninit()
ALT_STATUS_CODE alt_cache_l2_uninit ( void  )
Uninitializes the L2 cache controller.
Return values
