RTEMS  5.1
Files | Functions
BSP Command Line Helpers
file  bspcmdline.h
 BSP Command Line Handler.
file  bspcmdline_get.c
 Obtain Pointer to BSP Boot Command String.
file  bspcmdline_getparam.c
 Obtain COPY of the Entire Matching Argument.
file  bspcmdline_getparamraw.c
 Obtain Pointer to the Entire Matching Argument.
file  bspcmdline_getparamrhs.c
 Obtain COPY of the Right Hand Side of the Matching Argument.
const char * rtems_bsp_cmdline_get (void)
 Obtain Pointer to BSP Boot Command String. More...
const char * rtems_bsp_cmdline_get_param (const char *name, char *value, size_t length)
 Obtain COPY of the Entire Matching Argument. More...
const char * rtems_bsp_cmdline_get_param_rhs (const char *name, char *value, size_t length)
 Obtain COPY of the Right Hand Side of the Matching Argument. More...
const char * rtems_bsp_cmdline_get_param_raw (const char *name)
 Obtain Pointer to the Entire Matching Argument. More...
The BSP Command Line Handler provides a set of routines which assist in examining and decoding the Command Line String passed to the BSP at boot time.
◆ rtems_bsp_cmdline_get()
const char* rtems_bsp_cmdline_get ( void  )
This method returns a pointer to the BSP Boot Command String. It is as likely to be NULL as point to a string as most BSPs do not have a start environment that provides a boot string.
Return values
Thismethod returns the pointer to the BSP Boot Command String.
◆ rtems_bsp_cmdline_get_param()
const char* rtems_bsp_cmdline_get_param ( const char *  name,
char *  value,
size_t  length
This method searches for the argument name in the BSP Boot Command String and returns a copy of the entire string associated with it in value up to a string of length. This will include the argument and any right hand side portion of the string. For example, one might be returned –mode=FAST if searching for –mode.
Parameters
[in]nameis the arugment to search for
[in]valuepoints to where the contents will be placed if located.
[in]lengthis the maximum length to copy
Returns
This method returns NULL if not found and value if found.
◆ rtems_bsp_cmdline_get_param_raw()
const char* rtems_bsp_cmdline_get_param_raw ( const char *  name)
This method searches for the argument name in the BSP Boot Command String and returns a pointer to the entire string associated with it. This will include the argument and any right hand side portion of the string. For example, one might be returned –mode=FAST if searching for –mode.
Parameters
Return values
Thismethod returns NULL if not found and a pointer into the BSP Boot Command String if found.
Note
The pointer will be to the original BSP Command Line string. Exercise caution when using this.
◆ rtems_bsp_cmdline_get_param_rhs()
const char* rtems_bsp_cmdline_get_param_rhs ( const char *  name,
char *  value,
size_t  length
This method searches for the argument name in the BSP Boot Command String and returns the right hand side associated with it in value up to a maximum string length. This will NOT include the argument but only any right hand side portion of the string. * For example, one might be returned FAST if searching for –mode.
Parameters
Return values
Thismethod returns NULL if not found and value if found.
