RTEMS  5.1
epiphany-utility.h
1
10 /*
11  * Copyright (c) 2015 University of York.
12  * Hesham ALMatary <hmka501@york.ac.uk>
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  *
23  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
24  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
27  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
28  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
29  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
30  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
31  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
32  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
33  * SUCH DAMAGE.
34  */
35
36 #ifndef _EPIPHANY_UTILITY_H
37 #define _EPIPHANY_UTILITY_H
38
39 /* eCore IRQs */
40 typedef enum
41 {
42  START,
43  SW_EXCEPTION,
44  MEM_FAULT,
45  TIMER0,
46  TIMER1,
47  SMP_MESSAGE,
48  DMA0,
49  DMA1,
50  SER,
51 } EPIPHANY_IRQ_PER_CORE_T;
52
53 /* Per-core IO mapped register addresses
54  * @see Epiphany architecture reference.
55  */
56 #define EPIPHANY_PER_CORE_REG_CONFIG 0xF0400
57 #define EPIPHANY_PER_CORE_REG_STATUS 0xF0404
58 #define EPIPHANY_PER_CORE_REG_PC 0xF0408
59 #define EPIPHANY_PER_CORE_REG_DEBUGSTATUS 0xF040C
60 #define EPIPHANY_PER_CORE_REG_LC 0xF0414
61 #define EPIPHANY_PER_CORE_REG_LS 0xF0418
62 #define EPIPHANY_PER_CORE_REG_LE 0xF041C
63 #define EPIPHANY_PER_CORE_REG_IRET 0xF0420
64 #define EPIPHANY_PER_CORE_REG_IMASK 0xF0424
65 #define EPIPHANY_PER_CORE_REG_ILAT 0xF0428
66 #define EPIPHANY_PER_CORE_REG_ILATST 0xF042C
67 #define EPIPHANY_PER_CORE_REG_ILATCL 0xF0430
68 #define EPIPHANY_PER_CORE_REG_IPEND 0xF0434
69 #define EPIPHANY_PER_CORE_REG_FSTATUS 0xF0440
70 #define EPIPHANY_PER_CORE_REG_DEBUGCMD 0xF0448
71 #define EPIPHANY_PER_CORE_REG_RESETCORE 0xF070C
72
73 /* Event timer registers */
74 #define EPIPHANY_PER_CORE_REG_CTIMER0 0xF0438
75 #define EPIPHANY_PER_CORE_REG_CTIMER1 0xF043C
76
77 /* Processor control registers */
78 #define EPIPHANY_PER_CORE_REG_MEMSTATUS 0xF0604
79 #define EPIPHANY_PER_CORE_REG_MEMPROTECT 0xF0608
80
81 /* DMA Registers */
82 #define EPIPHANY_PER_CORE_REG_DMA0CONFIG 0xF0500
83 #define EPIPHANY_PER_CORE_REG_DMA0STRIDE 0xF0504
84 #define EPIPHANY_PER_CORE_REG_DMA0COUNT 0xF0508
85 #define EPIPHANY_PER_CORE_REG_DMA0SRCADDR 0xF050C
86 #define EPIPHANY_PER_CORE_REG_DMA0DSTADDR 0xF0510
87 #define EPIPHANY_PER_CORE_REG_DMA0AUTO0 0xF0514
88 #define EPIPHANY_PER_CORE_REG_DMA0AUTO1 0xF0518
89 #define EPIPHANY_PER_CORE_REG_DMA0STATUS 0xF051C
90 #define EPIPHANY_PER_CORE_REG_DMA1CONFIG 0xF0520
91 #define EPIPHANY_PER_CORE_REG_DMA1STRIDE 0xF0524
92 #define EPIPHANY_PER_CORE_REG_DMA1COUNT 0xF0528
93 #define EPIPHANY_PER_CORE_REG_DMA1SRCADDR 0xF052C
94 #define EPIPHANY_PER_CORE_REG_DMA1DSTADDR 0xF0530
95 #define EPIPHANY_PER_CORE_REG_DMA1AUTO0 0xF0534
96 #define EPIPHANY_PER_CORE_REG_DMA1AUTO1 0xF0538
97 #define EPIPHANY_PER_CORE_REG_DMA1STATUS 0xF053C
98
99 /* Mesh Node Control Registers */
100 #define EPIPHANY_PER_CORE_REG_MESHCONFIG 0xF0700
101 #define EPIPHANY_PER_CORE_REG_COREID 0xF0704
102 #define EPIPHANY_PER_CORE_REG_MULTICAST 0xF0708
103 #define EPIPHANY_PER_CORE_REG_CMESHROUTE 0xF0710
104 #define EPIPHANY_PER_CORE_REG_XMESHROUTE 0xF0714
105 #define EPIPHANY_PER_CORE_REG_RMESHROUTE 0xF0718
106
107 /* This macros constructs an address space of epiphany cores
108  * from their IDs.
109  */
110 #define EPIPHANY_COREID_TO_MSB_ADDR(id) (id) << 20
111
112 /* Construct a complete/absolute IO mapped address register from
113  * core ID and register name
114  */
115 #define EPIPHANY_GET_REG_ABSOLUTE_ADDR(coreid, reg) \
116  (EPIPHANY_COREID_TO_MSB_ADDR(coreid) | (reg))
117
118 #define EPIPHANY_REG(reg) (uint32_t *) (reg)
119
120 /* Read register with its absolute address */
121 static inline uint32_t read_epiphany_reg(volatile uint32_t reg_addr)
122 {
123  return *(EPIPHANY_REG(reg_addr));
124 }
125
126 /* Write register with its abolute address */
127 static inline void write_epiphany_reg(volatile uint32_t reg_addr, uint32_t val)
128 {
129  *(EPIPHANY_REG(reg_addr)) = val;
130 }
131
132 /* Epiphany uses 12 bits for defining core IDs, while RTEMS uses
133  * linear IDs. The following function converts RTEMS linear IDs to
134  * Epiphany corresponding ones
135  */
136 static const uint32_t map[16] =
137 {
138  0x808, 0x809, 0x80A, 0x80B,
139  0x848, 0x849, 0x84A, 0x84B,
140  0x888, 0x889, 0x88A, 0x88B,
141  0x8C8, 0x8C9, 0x8CA, 0x8CB
142 };
143
144 static inline uint32_t rtems_coreid_to_epiphany_map(uint32_t rtems_id)
145 {
146  return map[rtems_id];
147 }
148
149 /* Epiphany uses 12 bits for defining core IDs, while RTEMS uses
150  * linear IDs. The following function is used to map Epiphany IDs to
151  * RTEMS linear IDs.
152  */
153 static inline uint32_t epiphany_coreid_to_rtems_map(uint32_t epiphany_id)
154 {
155  register uint32_t coreid asm ("r17") = epiphany_id;
156
157  /* Mapping from Epiphany IDs to 0-16 IDs macro */
158  __asm__ __volatile__(" \
159  movfs r17, coreid \
160  mov r19, #0x003 \
161  mov r20, #0x0F0 \
162  and r19, r17, r19 \
163  and r20, r17, r20 \
164  lsr r20, r20, #4 \
165  add r17, r19, r20 \
166  ");
167
168  /* coreid or r17 now holds the rtems core id */
169  return coreid;
170 }
171
172 static inline uint32_t _Epiphany_Get_current_processor(void)
173 {
174  uint32_t coreid;
175
176  asm volatile ("movfs %0, coreid" : "=r" (coreid): );
177
178  return epiphany_coreid_to_rtems_map(coreid);
179 }
180 #endif /* _EPIPHANY_UTILITY_H */
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: mm.c:60
