RTEMS  5.1
dbg_console.h File Reference
#include <stdint.h>
void DBG_Configure (uint32_t dwBaudrate, uint32_t dwMasterClock)
 Configures an USART peripheral with the specified parameters. More...
void DBG_PutChar (uint8_t uc)
 Outputs a character on the UART line. More...
uint32_t DBG_GetChar (void)
 Input a character from the UART line. More...
uint32_t DBG_IsRxReady (void)
 Check if there is Input from UART line. More...
void DBG_DumpFrame (uint8_t *pucFrame, uint32_t dwSize)
void DBG_DumpMemory (uint8_t *pucBuffer, uint32_t dwSize, uint32_t dwAddress)
uint32_t DBG_GetInteger (int32_t *pdwValue)
uint32_t DBG_GetIntegerMinMax (int32_t *pdwValue, int32_t dwMin, int32_t dwMax)
uint32_t DBG_GetHexa32 (uint32_t *pdwValue)
Include function prototype for the UART console.
◆ DBG_Configure()
void DBG_Configure ( uint32_t  baudrate,
uint32_t  masterClock
Parameters
baudrateBaudrate at which the USART should operate (in Hz).
masterClockFrequency of the system master clock (in Hz).
◆ DBG_DumpFrame()
void DBG_DumpFrame ( uint8_t *  pucFrame,
uint32_t  dwSize
Displays the content of the given frame on the UART0.
Parameters
pucFramePointer to the frame to dump.
dwSizeBuffer size in bytes.
◆ DBG_DumpMemory()
void DBG_DumpMemory ( uint8_t *  pucBuffer,
uint32_t  dwSize,
uint32_t  dwAddress
Displays the content of the given buffer on the UART0.
Parameters
pucBufferPointer to the buffer to dump.
dwAddressStart address to display
◆ DBG_GetChar()
uint32_t DBG_GetChar ( void  )
Note
This function is synchronous
Returns
character received.
◆ DBG_GetHexa32()
uint32_t DBG_GetHexa32 ( uint32_t *  pdwValue)
Reads an hexadecimal number
Parameters
pdwValuePointer to the uint32_t variable to contain the input value.
◆ DBG_GetInteger()
uint32_t DBG_GetInteger ( int32_t *  pdwValue)
Reads an integer
Parameters
pdwValuePointer to a integer variable to contain the input value.
Returns
success(1) or failure(0)
◆ DBG_GetIntegerMinMax()
uint32_t DBG_GetIntegerMinMax ( int32_t *  pdwValue,
int32_t  dwMin,
int32_t  dwMax
Reads an integer and check the value
Parameters
dwMinMinimum value
dwMaxMaximum value
Returns
◆ DBG_IsRxReady()
uint32_t DBG_IsRxReady ( void  )
Returns
true if there is Input.
◆ DBG_PutChar()
void DBG_PutChar ( uint8_t  c)
Note
This function is synchronous (i.e. uses polling).
Parameters
cCharacter to send.
