RTEMS  5.1
cpustdatomic.h
1
7 /*
8  * COPYRIGHT (c) 2013 Deng Hengyi.
9  * Copyright (c) 2015 embedded brains GmbH.
10  *
11  * The license and distribution terms for this file may be
12  * found in the file LICENSE in this distribution or at
13  * http://www.rtems.org/license/LICENSE.
14  */
15
16 #ifndef _RTEMS_SCORE_CPUSTDATOMIC_H
17 #define _RTEMS_SCORE_CPUSTDATOMIC_H
18
19 #include <rtems/score/basedefs.h>
20
31 #ifdef RTEMS_SMP
32  #if defined(__cplusplus) \
33  && (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 9))
34  /*
35  * The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible. The
36  * suggested solution was to include <atomic> in case C++ is used. This works
37  * at least with GCC 4.9. See also:
38  *
39  * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
40  * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
41  */
42  #include <atomic>
43  #define _RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC
44  #else
45  #include <stdatomic.h>
46  #define _RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC
47  #endif
48 #else
49  #include <rtems/score/isrlevel.h>
50 #endif
51
52 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
53
54 typedef std::atomic_uint CPU_atomic_Uint;
55
56 typedef std::atomic_ulong CPU_atomic_Ulong;
57
58 typedef std::atomic_uintptr_t CPU_atomic_Uintptr;
59
60 typedef std::atomic_flag CPU_atomic_Flag;
61
62 typedef std::memory_order CPU_atomic_Order;
63
64 #define CPU_ATOMIC_ORDER_RELAXED std::memory_order_relaxed
65
66 #define CPU_ATOMIC_ORDER_ACQUIRE std::memory_order_acquire
67
68 #define CPU_ATOMIC_ORDER_RELEASE std::memory_order_release
69
70 #define CPU_ATOMIC_ORDER_ACQ_REL std::memory_order_acq_rel
71
72 #define CPU_ATOMIC_ORDER_SEQ_CST std::memory_order_seq_cst
73
74 #define CPU_ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
75
76 #define CPU_ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
77
78 #define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
79
80 #define CPU_ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
81
82 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
83
84 typedef atomic_uint CPU_atomic_Uint;
85
86 typedef atomic_ulong CPU_atomic_Ulong;
87
88 typedef atomic_uintptr_t CPU_atomic_Uintptr;
89
90 typedef atomic_flag CPU_atomic_Flag;
91
92 typedef memory_order CPU_atomic_Order;
93
94 #define CPU_ATOMIC_ORDER_RELAXED memory_order_relaxed
95
96 #define CPU_ATOMIC_ORDER_ACQUIRE memory_order_acquire
97
98 #define CPU_ATOMIC_ORDER_RELEASE memory_order_release
99
100 #define CPU_ATOMIC_ORDER_ACQ_REL memory_order_acq_rel
101
102 #define CPU_ATOMIC_ORDER_SEQ_CST memory_order_seq_cst
103
104 #define CPU_ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
105
106 #define CPU_ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
107
108 #define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
109
110 #define CPU_ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
111
112 #else
113
114 typedef unsigned int CPU_atomic_Uint;
115
116 typedef unsigned long CPU_atomic_Ulong;
117
118 typedef uintptr_t CPU_atomic_Uintptr;
119
120 typedef bool CPU_atomic_Flag;
121
122 typedef int CPU_atomic_Order;
123
124 #define CPU_ATOMIC_ORDER_RELAXED 0
125
126 #define CPU_ATOMIC_ORDER_ACQUIRE 2
127
128 #define CPU_ATOMIC_ORDER_RELEASE 3
129
130 #define CPU_ATOMIC_ORDER_ACQ_REL 4
131
132 #define CPU_ATOMIC_ORDER_SEQ_CST 5
133
134 #define CPU_ATOMIC_INITIALIZER_UINT( value ) ( value )
135
136 #define CPU_ATOMIC_INITIALIZER_ULONG( value ) ( value )
137
138 #define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ( value )
139
140 #define CPU_ATOMIC_INITIALIZER_FLAG false
141
142 #endif
143
149 static inline void _CPU_atomic_Fence( CPU_atomic_Order order )
150 {
151 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
152  std::atomic_thread_fence( order );
153 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
154  atomic_thread_fence( order );
155 #else
156  (void) order;
158 #endif
159 }
160
167 static inline void _CPU_atomic_Init_uint( CPU_atomic_Uint *obj, unsigned int desired )
168 {
169 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
170  obj->store( desired );
171 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
172  atomic_init( obj, desired );
173 #else
174  *obj = desired;
175 #endif
176 }
177
184 static inline void _CPU_atomic_Init_ulong( CPU_atomic_Ulong *obj, unsigned long desired )
185 {
186 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
187  obj->store( desired );
188 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
189  atomic_init( obj, desired );
190 #else
191  *obj = desired;
192 #endif
193 }
194
201 static inline void _CPU_atomic_Init_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired )
202 {
203 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
204  obj->store( desired );
205 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
206  atomic_init( obj, desired );
207 #else
208  *obj = desired;
209 #endif
210 }
211
220 static inline unsigned int _CPU_atomic_Load_uint( const CPU_atomic_Uint *obj, CPU_atomic_Order order )
221 {
222 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
223  return obj->load( order );
224 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
225  return atomic_load_explicit( obj, order );
226 #else
227  unsigned int val;
228
229  (void) order;
230  val = *obj;
232
233  return val;
234 #endif
235 }
236
245 static inline unsigned long _CPU_atomic_Load_ulong( const CPU_atomic_Ulong *obj, CPU_atomic_Order order )
246 {
247 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
248  return obj->load( order );
249 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
250  return atomic_load_explicit( obj, order );
251 #else
252  unsigned long val;
253
254  (void) order;
255  val = *obj;
257
258  return val;
259 #endif
260 }
261
270 static inline uintptr_t _CPU_atomic_Load_uintptr( const CPU_atomic_Uintptr *obj, CPU_atomic_Order order )
271 {
272 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
273  return obj->load( order );
274 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
275  return atomic_load_explicit( obj, order );
276 #else
277  uintptr_t val;
278
279  (void) order;
280  val = *obj;
282
283  return val;
284 #endif
285 }
286
294 static inline void _CPU_atomic_Store_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
295 {
296 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
297  obj->store( desired );
298 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
299  atomic_store_explicit( obj, desired, order );
300 #else
301  (void) order;
303  *obj = desired;
304 #endif
305 }
306
314 static inline void _CPU_atomic_Store_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
315 {
316 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
317  obj->store( desired );
318 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
319  atomic_store_explicit( obj, desired, order );
320 #else
321  (void) order;
323  *obj = desired;
324 #endif
325 }
326
334 static inline void _CPU_atomic_Store_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired, CPU_atomic_Order order )
335 {
336 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
337  obj->store( desired );
338 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
339  atomic_store_explicit( obj, desired, order );
340 #else
341  (void) order;
343  *obj = desired;
344 #endif
345 }
346
356 static inline unsigned int _CPU_atomic_Fetch_add_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
357 {
358 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
359  return obj->fetch_add( arg, order );
360 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
361  return atomic_fetch_add_explicit( obj, arg, order );
362 #else
363  unsigned int val;
364  ISR_Level level;
365
366  (void) order;
367  _ISR_Local_disable( level );
368  val = *obj;
369  *obj = val + arg;
370  _ISR_Local_enable( level );
371
372  return val;
373 #endif
374 }
375
385 static inline unsigned long _CPU_atomic_Fetch_add_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
386 {
387 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
388  return obj->fetch_add( arg, order );
389 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
390  return atomic_fetch_add_explicit( obj, arg, order );
391 #else
392  unsigned long val;
393  ISR_Level level;
394
395  (void) order;
396  _ISR_Local_disable( level );
397  val = *obj;
398  *obj = val + arg;
399  _ISR_Local_enable( level );
400
401  return val;
402 #endif
403 }
404
414 static inline uintptr_t _CPU_atomic_Fetch_add_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
415 {
416 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
417  return obj->fetch_add( arg, order );
418 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
419  return atomic_fetch_add_explicit( obj, arg, order );
420 #else
421  uintptr_t val;
422  ISR_Level level;
423
424  (void) order;
425  _ISR_Local_disable( level );
426  val = *obj;
427  *obj = val + arg;
428  _ISR_Local_enable( level );
429
430  return val;
431 #endif
432 }
433
443 static inline unsigned int _CPU_atomic_Fetch_sub_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
444 {
445 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
446  return obj->fetch_sub( arg, order );
447 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
448  return atomic_fetch_sub_explicit( obj, arg, order );
449 #else
450  unsigned int val;
451  ISR_Level level;
452
453  (void) order;
454  _ISR_Local_disable( level );
455  val = *obj;
456  *obj = val - arg;
457  _ISR_Local_enable( level );
458
459  return val;
460 #endif
461 }
462
472 static inline unsigned long _CPU_atomic_Fetch_sub_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
473 {
474 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
475  return obj->fetch_sub( arg, order );
476 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
477  return atomic_fetch_sub_explicit( obj, arg, order );
478 #else
479  unsigned long val;
480  ISR_Level level;
481
482  (void) order;
483  _ISR_Local_disable( level );
484  val = *obj;
485  *obj = val - arg;
486  _ISR_Local_enable( level );
487
488  return val;
489 #endif
490 }
491
501 static inline uintptr_t _CPU_atomic_Fetch_sub_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
502 {
503 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
504  return obj->fetch_sub( arg, order );
505 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
506  return atomic_fetch_sub_explicit( obj, arg, order );
507 #else
508  uintptr_t val;
509  ISR_Level level;
510
511  (void) order;
512  _ISR_Local_disable( level );
513  val = *obj;
514  *obj = val - arg;
515  _ISR_Local_enable( level );
516
517  return val;
518 #endif
519 }
520
530 static inline unsigned int _CPU_atomic_Fetch_or_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
531 {
532 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
533  return obj->fetch_or( arg, order );
534 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
535  return atomic_fetch_or_explicit( obj, arg, order );
536 #else
537  unsigned int val;
538  ISR_Level level;
539
540  (void) order;
541  _ISR_Local_disable( level );
542  val = *obj;
543  *obj = val | arg;
544  _ISR_Local_enable( level );
545
546  return val;
547 #endif
548 }
549
559 static inline unsigned long _CPU_atomic_Fetch_or_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
560 {
561 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
562  return obj->fetch_or( arg, order );
563 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
564  return atomic_fetch_or_explicit( obj, arg, order );
565 #else
566  unsigned long val;
567  ISR_Level level;
568
569  (void) order;
570  _ISR_Local_disable( level );
571  val = *obj;
572  *obj = val | arg;
573  _ISR_Local_enable( level );
574
575  return val;
576 #endif
577 }
578
588 static inline uintptr_t _CPU_atomic_Fetch_or_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
589 {
590 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
591  return obj->fetch_or( arg, order );
592 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
593  return atomic_fetch_or_explicit( obj, arg, order );
594 #else
595  uintptr_t val;
596  ISR_Level level;
597
598  (void) order;
599  _ISR_Local_disable( level );
600  val = *obj;
601  *obj = val | arg;
602  _ISR_Local_enable( level );
603
604  return val;
605 #endif
606 }
607
617 static inline unsigned int _CPU_atomic_Fetch_and_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
618 {
619 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
620  return obj->fetch_and( arg, order );
621 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
622  return atomic_fetch_and_explicit( obj, arg, order );
623 #else
624  unsigned int val;
625  ISR_Level level;
626
627  (void) order;
628  _ISR_Local_disable( level );
629  val = *obj;
630  *obj = val & arg;
631  _ISR_Local_enable( level );
632
633  return val;
634 #endif
635 }
636
646 static inline unsigned long _CPU_atomic_Fetch_and_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
647 {
648 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
649  return obj->fetch_and( arg, order );
650 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
651  return atomic_fetch_and_explicit( obj, arg, order );
652 #else
653  unsigned long val;
654  ISR_Level level;
655
656  (void) order;
657  _ISR_Local_disable( level );
658  val = *obj;
659  *obj = val & arg;
660  _ISR_Local_enable( level );
661
662  return val;
663 #endif
664 }
665
675 static inline uintptr_t _CPU_atomic_Fetch_and_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
676 {
677 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
678  return obj->fetch_and( arg, order );
679 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
680  return atomic_fetch_and_explicit( obj, arg, order );
681 #else
682  uintptr_t val;
683  ISR_Level level;
684
685  (void) order;
686  _ISR_Local_disable( level );
687  val = *obj;
688  *obj = val & arg;
689  _ISR_Local_enable( level );
690
691  return val;
692 #endif
693 }
694
704 static inline unsigned int _CPU_atomic_Exchange_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
705 {
706 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
707  return obj->exchange( desired, order );
708 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
709  return atomic_exchange_explicit( obj, desired, order );
710 #else
711  unsigned int val;
712  ISR_Level level;
713
714  (void) order;
715  _ISR_Local_disable( level );
716  val = *obj;
717  *obj = desired;
718  _ISR_Local_enable( level );
719
720  return val;
721 #endif
722 }
723
733 static inline unsigned long _CPU_atomic_Exchange_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
734 {
735 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
736  return obj->exchange( desired, order );
737 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
738  return atomic_exchange_explicit( obj, desired, order );
739 #else
740  unsigned long val;
741  ISR_Level level;
742
743  (void) order;
744  _ISR_Local_disable( level );
745  val = *obj;
746  *obj = desired;
747  _ISR_Local_enable( level );
748
749  return val;
750 #endif
751 }
752
762 static inline uintptr_t _CPU_atomic_Exchange_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired, CPU_atomic_Order order )
763 {
764 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
765  return obj->exchange( desired, order );
766 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
767  return atomic_exchange_explicit( obj, desired, order );
768 #else
769  uintptr_t val;
770  ISR_Level level;
771
772  (void) order;
773  _ISR_Local_disable( level );
774  val = *obj;
775  *obj = desired;
776  _ISR_Local_enable( level );
777
778  return val;
779 #endif
780 }
781
799 static inline bool _CPU_atomic_Compare_exchange_uint( CPU_atomic_Uint *obj, unsigned int *expected, unsigned int desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
800 {
801 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
802  return obj->compare_exchange_strong( *expected, desired, succ, fail );
803 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
804  return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
805 #else
806  bool success;
807  ISR_Level level;
808  unsigned int actual;
809
810  (void) succ;
811  (void) fail;
812  _ISR_Local_disable( level );
813  actual = *obj;
814  success = ( actual == *expected );
815  if ( success ) {
816  *obj = desired;
817  } else {
818  *expected = actual;
819  }
820  _ISR_Local_enable( level );
821
822  return success;
823 #endif
824 }
825
843 static inline bool _CPU_atomic_Compare_exchange_ulong( CPU_atomic_Ulong *obj, unsigned long *expected, unsigned long desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
844 {
845 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
846  return obj->compare_exchange_strong( *expected, desired, succ, fail );
847 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
848  return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
849 #else
850  bool success;
851  ISR_Level level;
852  unsigned long actual;
853
854  (void) succ;
855  (void) fail;
856  _ISR_Local_disable( level );
857  actual = *obj;
858  success = ( actual == *expected );
859  if ( success ) {
860  *obj = desired;
861  } else {
862  *expected = actual;
863  }
864  _ISR_Local_enable( level );
865
866  return success;
867 #endif
868 }
869
887 static inline bool _CPU_atomic_Compare_exchange_uintptr( CPU_atomic_Uintptr *obj, uintptr_t *expected, uintptr_t desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
888 {
889 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
890  return obj->compare_exchange_strong( *expected, desired, succ, fail );
891 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
892  return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
893 #else
894  bool success;
895  ISR_Level level;
896  uintptr_t actual;
897
898  (void) succ;
899  (void) fail;
900  _ISR_Local_disable( level );
901  actual = *obj;
902  success = ( actual == *expected );
903  if ( success ) {
904  *obj = desired;
905  } else {
906  *expected = actual;
907  }
908  _ISR_Local_enable( level );
909
910  return success;
911 #endif
912 }
913
920 static inline void _CPU_atomic_Flag_clear( CPU_atomic_Flag *obj, CPU_atomic_Order order )
921 {
922 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
923  obj->clear( order );
924 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
925  atomic_flag_clear_explicit( obj, order );
926 #else
927  (void) order;
928  *obj = false;
929 #endif
930 }
931
941 static inline bool _CPU_atomic_Flag_test_and_set( CPU_atomic_Flag *obj, CPU_atomic_Order order )
942 {
943 #if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
944  return obj->test_and_set( order );
945 #elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
946  return atomic_flag_test_and_set_explicit( obj, order );
947 #else
948  bool flag;
949  ISR_Level level;
950
951  (void) order;
952  _ISR_Local_disable( level );
953  flag = *obj;
954  *obj = true;
955  _ISR_Local_enable( level );
956
957  return flag;
958 #endif
959 }
960
963 #endif /* _RTEMS_SCORE_CPUSTDATOMIC_H */
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:57
ISR Level Type.
#define RTEMS_COMPILER_MEMORY_BARRIER()
Definition: basedefs.h:77
uint32_t ISR_Level
Definition: isrlevel.h:41
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:74
Basic Definitions.
