RTEMS  5.1
irq.h
1 /* PCI IRQ Library
2  *
3  * COPYRIGHT (c) 2010 Cobham Gaisler AB.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 /* IRQ handling does not have so much with PCI to do, this library depends
11  * on the BSP to implement shared interrupts.
12  */
13
14 #ifndef __PCI_IRQ_H__
15 #define __PCI_IRQ_H__
16
17 #include <rtems/irq-extension.h>
18 #include <rtems/score/basedefs.h>
19
20 /*
21  * FIXME: This should be available via the IRQ extensions API.
22  *
23  * https://devel.rtems.org/ticket/3269
24  */
25 void BSP_shared_interrupt_clear(int irq);
26 void BSP_shared_interrupt_unmask(int irq);
27 void BSP_shared_interrupt_mask(int irq);
28
29 /* PCI Handler (ISR) called when IRQ is generated by any of the PCI devices
30  * connected to the same PCI IRQ Pin. This has been defined the same way as
31  * rtems_interrupt_handler in order for BSPs to "direct-map" the register
32  * and unregister functions rtems_interrupt_handler_install/remove
33  */
34 typedef void (*pci_isr)(void *arg);
35
36 /* Get assigned system IRQ to a PCI Device. If no IRQ 0 is returned */
37 extern int pci_dev_irq(pci_dev_t dev);
38
39 /* Register shared PCI IRQ handler, but does not enable it. The system interrupt
40  * number is read from the PCI board's PCI configuration space header iline
41  * field. The iline field is initialized by the PCI subsystem during start up,
42  * the ipin field is translated into a system IRQ and written to iline. The
43  * board's driver should use the iline field as the irq argument to this
44  * function.
45  *
46  * Arguments
47  * irq System IRQ number, normally taken from the PCI configuration area
48  * isr Function pointer to the ISR
49  * arg Second argument to function isr
50  */
51 RTEMS_INLINE_ROUTINE int pci_interrupt_register(int irq, const char *info,
52  pci_isr isr, void *arg)
53 {
54  return rtems_interrupt_handler_install(irq, info,
56  arg);
57 }
58
59 /* Unregister previously registered shared PCI IRQ handler
60  *
61  * Arguments
62  * irq System IRQ number, normally taken from the PCI configuration area
63  * isr Function pointer to the ISR
64  * arg Second argument to function isr
65  */
66 RTEMS_INLINE_ROUTINE int pci_interrupt_unregister(int irq, pci_isr isr,
67  void *arg)
68 {
69  return rtems_interrupt_handler_remove(irq, isr, arg);
70 }
71
72 /* Enable shared PCI IRQ handler. This function will unmask the interrupt
73  * controller and mark this interrupt handler ready to handle interrupts. Note
74  * that since it is a shared interrupt handler service the interrupt may
75  * already be enabled, however no calls to this specific handler is made
76  * until it is enabled.
77  *
78  * Arguments
79  * irq System IRQ number, normally taken from the PCI configuration area
80  * isr Function pointer to the ISR
81  * arg Second argument to function isr
82  */
83 RTEMS_INLINE_ROUTINE void pci_interrupt_unmask(int irq)
84 {
85  BSP_shared_interrupt_unmask(irq);
86 }
87
88 /* Disable shared PCI IRQ handler. This function will mask the interrupt
89  * controller and mark this interrupt handler not ready to receive interrupts.
90  * Note that since it is a shared interrupt handler service the interrupt may
91  * still be enabled, however no calls to this specific handler is made
92  * while it is disabled.
93  *
94  * Arguments
95  * irq System IRQ number, normally taken from the PCI configuration area
96  * isr Function pointer to the ISR
97  * arg Second argument to function isr
98  */
99 RTEMS_INLINE_ROUTINE void pci_interrupt_mask(int irq)
100 {
101  BSP_shared_interrupt_mask(irq);
102 }
103
104 /* Acknowledge the interrupt controller by writing to the interrupt controller.
105  * Note that since it is a shared interrupt handler service, clearing the
106  * interrupt source may affect other ISRs registered to this IRQ.
107  *
108  * Arguments
109  * irq System IRQ number, normally taken from the PCI configuration area
110  * isr Function pointer to the ISR
111  * arg Second argument to function isr
112  */
113 RTEMS_INLINE_ROUTINE void pci_interrupt_clear(int irq)
114 {
115  BSP_shared_interrupt_clear(irq);
116 }
117
118 #endif /* !__PCI_IRQ_H__ */
#define RTEMS_INTERRUPT_SHARED
Allows that this interrupt handler may share a common interrupt vector with other handler.
Definition: irq-extension.h:50
rtems_status_code rtems_interrupt_handler_remove(rtems_vector_number vector, rtems_interrupt_handler handler, void *arg)
Removes the interrupt handler routine handler with argument arg for the interrupt vector with number ...
Definition: irq.c:175
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector.
Definition: irq.c:127
Header file for the Interrupt Manager Extension.
Basic Definitions.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
