RTEMS  5.1
clock-armv7m.h
1 /*
2  * Copyright (c) 2011, 2018 Sebastian Huber. All rights reserved.
3  *
4  * embedded brains GmbH
5  * Dornierstr. 4
6  * 82178 Puchheim
7  * Germany
8  * <rtems@embedded-brains.de>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef BSP_CLOCK_ARMV7M_H
16 #define BSP_CLOCK_ARMV7M_H
17
18 #include <rtems/score/armv7m.h>
19 #include <rtems/timecounter.h>
20
21 #include <bsp.h>
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif /* __cplusplus */
26
27 #ifdef ARM_MULTILIB_ARCH_V7M
28
29 typedef struct {
30  struct timecounter base;
31  uint32_t ticks;
32 } ARMV7M_Timecounter;
33
34 extern ARMV7M_Timecounter _ARMV7M_TC;
35
36 static inline uint32_t _ARMV7M_Clock_frequency(void)
37 {
38 #ifdef BSP_ARMV7M_SYSTICK_FREQUENCY
39  return BSP_ARMV7M_SYSTICK_FREQUENCY;
40 #else
41  volatile ARMV7M_Systick *systick = _ARMV7M_Systick;
42  return ARMV7M_SYSTICK_CALIB_TENMS_GET(systick->calib) * 100;
43 #endif
44 }
45
46 static uint32_t _ARMV7M_Clock_counter(ARMV7M_Timecounter *tc)
47 {
48  volatile ARMV7M_Systick *systick;
50  uint32_t interval;
51  uint32_t counter;
52  uint32_t ticks;
53  uint32_t csr;
54
56  systick = _ARMV7M_Systick;
57  counter = systick->cvr;
58  csr = systick->csr;
59  interval = systick->rvr;
60  ticks = tc->ticks;
61
62  if (RTEMS_PREDICT_FALSE((csr & ARMV7M_SYSTICK_CSR_COUNTFLAG) != 0)) {
63  counter = systick->cvr;
64  ticks += interval;
65  tc->ticks = ticks;
66  }
67
68  counter = interval - counter + ticks;
70
71  return counter;
72 }
73
74 #endif /* ARM_MULTILIB_ARCH_V7M */
75
76 #ifdef __cplusplus
77 }
78 #endif /* __cplusplus */
79
80 #endif /* BSP_CLOCK_ARMV7M_H */
ARMV7M Architecture Support.
Timecounter API.
Definition: timetc.h:46
#define rtems_interrupt_disable(_isr_cookie)
Disable RTEMS Interrupt.
Definition: intr.h:99
#define rtems_interrupt_enable(_isr_cookie)
Enable RTEMS Interrupt.
Definition: intr.h:110
ISR_Level rtems_interrupt_level
Interrupt level type.
Definition: intr.h:42
#define RTEMS_PREDICT_FALSE(_exp)
Returns the value of the specified integral expression and tells the compiler that the predicted valu...
Definition: basedefs.h:388
