RTEMS
5.1
Global BSP definitions. More...
#include <libcpu/bf533.h>
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <rtems/score/bfin.h>
#include <rtems/bfin/bf533.h>
#define | L1_DATA_SRAM_A 0xff800000L |
Blackfin environment memory map. | |
#define | FIFOLENGTH 0x100 |
PLL and clock setup values: | |
PLL configuration for ezkit533 XTL = 27 MHz CLKIN = 13 MHz VCO = 391 MHz CCLK = 391 MHz SCLK = 130 MHz | |
#define | PLL_CSEL 0x0000 |
CCLK = VCO */. | |
#define | PLL_SSEL 0x0003 |
SCLK = CCLK/3 */. | |
#define | PLL_MSEL 0x3A00 |
VCO = 29xCLKIN */. | |
#define | PLL_DF 0x0001 |
CLKIN = XTL/2 */. | |
#define | CCLK 391000000 |
CORE CLOCK */. | |
#define | SCLK 130000000 |
SYSTEM CLOCK */. | |
UART setup values | |
#define | BAUDRATE 57600 |
Console Baudrate */. | |
#define | WORD_5BITS 0x00 |
5 bits word */ | |
#define | WORD_6BITS 0x01 |
6 bits word */ | |
#define | WORD_7BITS 0x02 |
7 bits word */ | |
#define | WORD_8BITS 0x03 |
8 bits word */ | |
#define | EVEN_PARITY 0x18 |
Enable EVEN parity */. | |
#define | ODD_PARITY 0x08 |
Enable ODD parity */. | |
#define | TWO_STP_BIT 0x04 |
2 stop bits */ | |
Ezkit flash ports | |
#define | FlashA_PortB_Dir 0x20270007L |
#define | FlashA_PortB_Data 0x20270005L |
Constants | |
#define | RAM_START 0 |
#define | RAM_END 0x100000 |
functions | |
void | setLED (uint8_t value) |
Helper Function to use the EzKits LEDS. Can be used by the Application. | |
uint8_t | getLED (void) |
Helper Function to use the EzKits LEDS. | |
rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
Install an interrupt handler. More... | |
void | Init_RTC (void) |
void | bfin_null_isr (void) |
This include file contains all board IO definitions for TLL6527M.
