RTEMS  5.1
bsp.h
1
11 /* bsp.h
12  *
13  * This include file contains all board IO definitions for eZKit533.
14  *
15  * Copyright (c) 2006 by Atos Automacao Industrial Ltda.
16  * written by Alain Schaefer <alain.schaefer@easc.ch>
17  * and Antonio Giovanini <antonio@atos.com.br>
18  *
19  * The license and distribution terms for this file may be
20  * found in the file LICENSE in this distribution or at
21  * http://www.rtems.org/license/LICENSE.
22  */
23
24
25 #ifndef LIBBSP_BFIN_EZKIT533_BSP_H
26 #define LIBBSP_BFIN_EZKIT533_BSP_H
27
28 #ifndef ASM
29
30 #include <libcpu/bf533.h>
31
32 #include <bspopts.h>
34
35 #include <rtems.h>
36 #include <rtems/score/bfin.h>
37 #include <rtems/bfin/bf533.h>
38
39 #ifdef __cplusplus
40 extern "C" {
41 #endif
42
67 #define PLL_CSEL 0x0000
68 #define PLL_SSEL 0x0003
69 #define PLL_MSEL 0x3A00
70 #define PLL_DF 0x0001
71
72 #define CCLK 391000000
73 #define SCLK 130000000
74
75
82 #define BAUDRATE 57600
83 #define WORD_5BITS 0x00
84 #define WORD_6BITS 0x01
85 #define WORD_7BITS 0x02
86 #define WORD_8BITS 0x03
87 #define EVEN_PARITY 0x18
88 #define ODD_PARITY 0x08
89 #define TWO_STP_BIT 0x04
90
91
98 #define FlashA_PortB_Dir 0x20270007L
99 #define FlashA_PortB_Data 0x20270005L
100
106 #define L1_DATA_SRAM_A 0xff800000L
107
108 #define FIFOLENGTH 0x100
109
115 #define RAM_START 0
116 #define RAM_END 0x100000
117
129 void setLED (uint8_t value);
130
134 uint8_t getLED (void);
135
147 rtems_isr_entry set_vector(
148  rtems_isr_entry handler,
149  rtems_vector_number vector,
150  int type
151 );
152
153 /*
154  * Internal BSP methods that are used across file boundaries
155  */
156 void Init_RTC(void);
157
158 /*
159  * Prototype for methods in .S files that are referenced from C.
160  */
161 void bfin_null_isr(void);
162
167 #ifdef __cplusplus
168 }
169 #endif
170
171 #endif /* !ASM */
172
175 #endif
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
Blackfin Set up Basic CPU Dependency Settings Based on Compiler Settings.
Basic MMR for the Blackfin 531/532/533 CPU.
void setLED(uint8_t value)
Helper Function to use the EzKits LEDS. Can be used by the Application.
Definition: bspstart.c:145
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
uint8_t getLED(void)
Definition: bspstart.c:153
