RTEMS
5.1
Block Device Management. More...
#include <rtems/diskdevs.h>
#include <rtems/print.h>
#include <sys/ioccom.h>
struct | rtems_blkdev_sg_buffer |
Block device scatter or gather buffer structure. More... | |
struct | rtems_blkdev_request |
The block device transfer request is used to read or write a number of blocks from or to the device. More... | |
#define | RTEMS_BLKDEV_START_BLOCK(req) (req->bufs[0].block) |
The start block in a request. More... | |
#define | RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES |
IO Control Request Codes | |
#define | RTEMS_BLKIO_REQUEST _IOWR('B', 1, rtems_blkdev_request) |
#define | RTEMS_BLKIO_GETMEDIABLKSIZE _IOR('B', 2, uint32_t) |
#define | RTEMS_BLKIO_GETBLKSIZE _IOR('B', 3, uint32_t) |
#define | RTEMS_BLKIO_SETBLKSIZE _IOW('B', 4, uint32_t) |
#define | RTEMS_BLKIO_GETSIZE _IOR('B', 5, rtems_blkdev_bnum) |
#define | RTEMS_BLKIO_SYNCDEV _IO('B', 6) |
#define | RTEMS_BLKIO_DELETED _IO('B', 7) |
#define | RTEMS_BLKIO_CAPABILITIES _IO('B', 8) |
#define | RTEMS_BLKIO_GETDISKDEV _IOR('B', 9, rtems_disk_device *) |
#define | RTEMS_BLKIO_PURGEDEV _IO('B', 10) |
#define | RTEMS_BLKIO_GETDEVSTATS _IOR('B', 11, rtems_blkdev_stats *) |
#define | RTEMS_BLKIO_RESETDEVSTATS _IO('B', 12) |
Block Device Driver Capabilities | |
#define | RTEMS_BLKDEV_CAP_MULTISECTOR_CONT (1 << 0) |
Only consecutive multi-sector buffer requests are supported. More... | |
#define | RTEMS_BLKDEV_CAP_SYNC (1 << 1) |
The driver will accept a sync call. More... | |
Typedefs | |
typedef enum rtems_blkdev_request_op | rtems_blkdev_request_op |
Block device request type. More... | |
typedef void(* | rtems_blkdev_request_cb) (struct rtems_blkdev_request *req, rtems_status_code status) |
Block device request done callback function type. | |
typedef struct rtems_blkdev_sg_buffer | rtems_blkdev_sg_buffer |
Block device scatter or gather buffer structure. | |
typedef struct rtems_blkdev_request | rtems_blkdev_request |
Enumerations | |
enum | rtems_blkdev_request_op { RTEMS_BLKDEV_REQ_READ, RTEMS_BLKDEV_REQ_WRITE, RTEMS_BLKDEV_REQ_SYNC } |
int | rtems_blkdev_ioctl (rtems_disk_device *dd, uint32_t req, void *argp) |
Common IO control primitive. More... | |
rtems_status_code | rtems_blkdev_create (const char *device, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, rtems_block_device_ioctl handler, void *driver_data) |
Creates a block device. More... | |
rtems_status_code | rtems_blkdev_create_partition (const char *partition, const char *parent_block_device, rtems_blkdev_bnum media_block_begin, rtems_blkdev_bnum media_block_count) |
Creates a partition within a parent block device. More... | |
void | rtems_blkdev_print_stats (const rtems_blkdev_stats *stats, uint32_t media_block_size, uint32_t media_block_count, uint32_t block_size, const rtems_printer *printer) |
Prints the block device statistics. | |
void | rtems_blkstats (const rtems_printer *printer, const char *device, bool reset) |
Block device statistics command. | |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_ioctl (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED const rtems_driver_address_table | rtems_blkdev_generic_ops |
