RTEMS  5.1
barrierdata.h
1
10 /* COPYRIGHT (c) 1989-2008.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _RTEMS_RTEMS_BARRIERDATA_H
19 #define _RTEMS_RTEMS_BARRIERDATA_H
20
21 #include <rtems/rtems/barrier.h>
22 #include <rtems/score/objectdata.h>
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
38 typedef struct {
46
51
61 #define BARRIER_INFORMATION_DEFINE( max ) \
62  OBJECTS_INFORMATION_DEFINE( \
63  _Barrier, \
64  OBJECTS_CLASSIC_API, \
65  OBJECTS_RTEMS_BARRIERS, \
66  Barrier_Control, \
67  max, \
68  OBJECTS_NO_STRING_NAME, \
69  NULL \
70  )
71
74 #ifdef __cplusplus
75 }
76 #endif
77
78 #endif
79 /* end of include file */
uint32_t rtems_attribute
Definition: attr.h:41
Objects_Control Object
Definition: barrierdata.h:40
Definition: objectdata.h:39
Objects_Information _Barrier_Information
The Classic Barrier objects information.
rtems_attribute attribute_set
Definition: barrierdata.h:44
Object Handler Data Structures.
Constants and Structures Associated with the Barrier Handler.
Definition: barrierdata.h:38
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
CORE_barrier_Control Barrier
Definition: barrierdata.h:42
Definition: corebarrier.h:75
Classic Barrier Manager API.
