RTEMS  5.1
asr.h
1
11 /* COPYRIGHT (c) 1989-2013.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_RTEMS_ASR_H
20 #define _RTEMS_RTEMS_ASR_H
21
22 #include <rtems/rtems/modes.h>
23
24 #ifdef __cplusplus
25 extern "C" {
26 #endif
27
42 typedef uint32_t rtems_signal_set;
43
47 typedef void rtems_asr;
48
55  );
56
57 /*
58  * The following constants define the individual signals which may
59  * be used to compose a signal set.
60  */
61
63 #define RTEMS_SIGNAL_0 0x00000001
64
65 #define RTEMS_SIGNAL_1 0x00000002
66
67 #define RTEMS_SIGNAL_2 0x00000004
68
69 #define RTEMS_SIGNAL_3 0x00000008
70
71 #define RTEMS_SIGNAL_4 0x00000010
72
73 #define RTEMS_SIGNAL_5 0x00000020
74
75 #define RTEMS_SIGNAL_6 0x00000040
76
77 #define RTEMS_SIGNAL_7 0x00000080
78
79 #define RTEMS_SIGNAL_8 0x00000100
80
81 #define RTEMS_SIGNAL_9 0x00000200
82
83 #define RTEMS_SIGNAL_10 0x00000400
84
85 #define RTEMS_SIGNAL_11 0x00000800
86
87 #define RTEMS_SIGNAL_12 0x00001000
88
89 #define RTEMS_SIGNAL_13 0x00002000
90
91 #define RTEMS_SIGNAL_14 0x00004000
92
93 #define RTEMS_SIGNAL_15 0x00008000
94
95 #define RTEMS_SIGNAL_16 0x00010000
96
97 #define RTEMS_SIGNAL_17 0x00020000
98
99 #define RTEMS_SIGNAL_18 0x00040000
100
101 #define RTEMS_SIGNAL_19 0x00080000
102
103 #define RTEMS_SIGNAL_20 0x00100000
104
105 #define RTEMS_SIGNAL_21 0x00200000
106
107 #define RTEMS_SIGNAL_22 0x00400000
108
109 #define RTEMS_SIGNAL_23 0x00800000
110
111 #define RTEMS_SIGNAL_24 0x01000000
112
113 #define RTEMS_SIGNAL_25 0x02000000
114
115 #define RTEMS_SIGNAL_26 0x04000000
116
117 #define RTEMS_SIGNAL_27 0x08000000
118
119 #define RTEMS_SIGNAL_28 0x10000000
120
121 #define RTEMS_SIGNAL_29 0x20000000
122
123 #define RTEMS_SIGNAL_30 0x40000000
124
125 #define RTEMS_SIGNAL_31 0x80000000
126
129 #ifdef __cplusplus
130 }
131 #endif
132
133 #endif
134 /* end of include file */
void rtems_asr
Definition: asr.h:47
Definition: asr.h:42
rtems_asr(* rtems_asr_entry)(rtems_signal_set)
Definition: asr.h:53
