RTEMS  5.1
Macros | Typedefs
asr.h File Reference
#include <rtems/rtems/modes.h>
#define RTEMS_SIGNAL_0   0x00000001
#define RTEMS_SIGNAL_1   0x00000002
#define RTEMS_SIGNAL_2   0x00000004
#define RTEMS_SIGNAL_3   0x00000008
#define RTEMS_SIGNAL_4   0x00000010
#define RTEMS_SIGNAL_5   0x00000020
#define RTEMS_SIGNAL_6   0x00000040
#define RTEMS_SIGNAL_7   0x00000080
#define RTEMS_SIGNAL_8   0x00000100
#define RTEMS_SIGNAL_9   0x00000200
#define RTEMS_SIGNAL_10   0x00000400
#define RTEMS_SIGNAL_11   0x00000800
#define RTEMS_SIGNAL_12   0x00001000
#define RTEMS_SIGNAL_13   0x00002000
#define RTEMS_SIGNAL_14   0x00004000
#define RTEMS_SIGNAL_15   0x00008000
#define RTEMS_SIGNAL_16   0x00010000
#define RTEMS_SIGNAL_17   0x00020000
#define RTEMS_SIGNAL_18   0x00040000
#define RTEMS_SIGNAL_19   0x00080000
#define RTEMS_SIGNAL_20   0x00100000
#define RTEMS_SIGNAL_21   0x00200000
#define RTEMS_SIGNAL_22   0x00400000
#define RTEMS_SIGNAL_23   0x00800000
#define RTEMS_SIGNAL_24   0x01000000
#define RTEMS_SIGNAL_25   0x02000000
#define RTEMS_SIGNAL_26   0x04000000
#define RTEMS_SIGNAL_27   0x08000000
#define RTEMS_SIGNAL_28   0x10000000
#define RTEMS_SIGNAL_29   0x20000000
#define RTEMS_SIGNAL_30   0x40000000
#define RTEMS_SIGNAL_31   0x80000000
typedef uint32_t rtems_signal_set
typedef void rtems_asr
typedef rtems_asr(* rtems_asr_entry) (rtems_signal_set)
This include file contains all the constants and structures associated with the Asynchronous Signal Handler. This Handler provides the low-level support required by the Signal Manager.
