#define | UINT12_MAX (4096) |
#define | ALT_ORIGINAL_GUARDBAND_VAL 20 |
#define | ALT_GUARDBAND_LIMIT 20 |
#define | ALT_CLK_PLL_MULT_MAX 4095 |
#define | ALT_CLK_PLL_DIV_MAX 63 |
#define | ALT_CLK_PLL_CNTR_MAX 511 |
#define | ALT_CLK_PLL_RST_BIT_C0 0x00000001 |
#define | ALT_CLK_PLL_RST_BIT_C1 0x00000002 |
#define | ALT_CLK_PLL_RST_BIT_C2 0x00000004 |
#define | ALT_CLK_PLL_RST_BIT_C3 0x00000008 |
#define | ALT_CLK_PLL_RST_BIT_C4 0x00000010 |
#define | ALT_CLK_PLL_RST_BIT_C5 0x00000020 |
#define | ALT_CLK_MGR_PLL_LOCK_BITS |
#define | ALT_CLKMGR_ALTERA_OFST 0xe0 |
#define | ALT_CLKMGR_ALTERA_MPUCLK_OFST 0x0 |
#define | ALT_CLKMGR_ALTERA_MAINCLK_OFST 0x4 |
#define | ALT_CLKMGR_ALTERA_DBGATCLK_OFST 0x8 |
#define | ALT_CLKMGR_ALTERA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_ALTERA_OFST)) |
#define | ALT_CLKMGR_ALTERA_MPUCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ALTERA_ADDR) + ALT_CLKMGR_ALTERA_MPUCLK_OFST)) |
#define | ALT_CLKMGR_ALTERA_MAINCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ALTERA_ADDR) + ALT_CLKMGR_ALTERA_MAINCLK_OFST)) |
#define | ALT_CLKMGR_ALTERA_DBGATCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ALTERA_ADDR) + ALT_CLKMGR_ALTERA_DBGATCLK_OFST)) |
#define | ALT_CLKMGR_ALTERA_MPUCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0) |
#define | ALT_CLKMGR_ALTERA_MAINCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0) |
#define | ALT_CLKMGR_ALTERA_DBGATCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0) |
#define | ALT_SW_MANAGED_CLK_WAIT_CTRDIV 30 /* 30 or more MPU clock cycles */ |
#define | ALT_SW_MANAGED_CLK_WAIT_HWCTRDIV 40 |
#define | ALT_SW_MANAGED_CLK_WAIT_BYPASS 30 |
#define | ALT_SW_MANAGED_CLK_WAIT_SAFEREQ 30 |
#define | ALT_SW_MANAGED_CLK_WAIT_SAFEEXIT 30 |
#define | ALT_SW_MANAGED_CLK_WAIT_NANDCLK 8 /* 8 or more MPU clock cycles */ |
#define | ALT_BYPASS_TIMEOUT_CNT 50 |
#define | ALT_TIMEOUT_PHASE_SYNC 300 |
#define | alt_within_delta(ref, neu, prcnt) |
#define | ALT_PREVENT_GLITCH_BYP true |
#define | ALT_PREVENT_GLITCH_EXSAFE true |
#define | ALT_PREVENT_GLITCH_CNTRRST true |
#define | ALT_PREVENT_GLITCH_CHGC1 true |
#define | ALT_CLK_PLL_VCO_CHG_METHOD_TEST_MODE false |
#define | ALT_CLK_WITHIN_FREQ_LIMITS_TEST_MODE false |
