RTEMS  5.1
alt_sysmgr.h
1
7 /*******************************************************************************
8 * *
9 * Copyright 2013 Altera Corporation. All Rights Reserved. *
10 * *
11 * Redistribution and use in source and binary forms, with or without *
12 * modification, are permitted provided that the following conditions are met: *
13 * *
14 * 1. Redistributions of source code must retain the above copyright notice, *
15 * this list of conditions and the following disclaimer. *
16 * *
17 * 2. Redistributions in binary form must reproduce the above copyright notice, *
18 * this list of conditions and the following disclaimer in the documentation *
19 * and/or other materials provided with the distribution. *
20 * *
21 * 3. The name of the author may not be used to endorse or promote products *
22 * derived from this software without specific prior written permission. *
23 * *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27 * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33 * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34 * *
35 *******************************************************************************/
36
37 /* Altera - ALT_SYSMGR */
38
39 #ifndef __ALTERA_ALT_SYSMGR_H__
40 #define __ALTERA_ALT_SYSMGR_H__
41
42 #ifdef __cplusplus
43 extern "C"
44 {
45 #endif /* __cplusplus */
46
47 /*
48  * Component : System Manager Module - ALT_SYSMGR
49  * System Manager Module
50  *
51  * Registers in the System Manager module
52  *
53  */
54 /*
55  * Register : Silicon ID1 Register - siliconid1
56  *
57  * Specifies Silicon ID and revision number.
58  *
59  * Register Layout
60  *
61  * Bits | Access | Reset | Description
62  * :--------|:-------|:------|:-----------------
63  * [15:0] | R | 0x1 | Silicon Revision
64  * [31:16] | R | 0x0 | Silicon ID
65  *
66  */
67 /*
68  * Field : Silicon Revision - rev
69  *
70  * Silicon revision number.
71  *
72  * Field Enumeration Values:
73  *
74  * Enum | Value | Description
75  * :---------------------------------|:------|:------------
76  * ALT_SYSMGR_SILICONID1_REV_E_REV1 | 0x1 | Revision 1
77  *
78  * Field Access Macros:
79  *
80  */
81 /*
82  * Enumerated value for register field ALT_SYSMGR_SILICONID1_REV
83  *
84  * Revision 1
85  */
86 #define ALT_SYSMGR_SILICONID1_REV_E_REV1 0x1
87
88 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SILICONID1_REV register field. */
89 #define ALT_SYSMGR_SILICONID1_REV_LSB 0
90 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SILICONID1_REV register field. */
91 #define ALT_SYSMGR_SILICONID1_REV_MSB 15
92 /* The width in bits of the ALT_SYSMGR_SILICONID1_REV register field. */
93 #define ALT_SYSMGR_SILICONID1_REV_WIDTH 16
94 /* The mask used to set the ALT_SYSMGR_SILICONID1_REV register field value. */
95 #define ALT_SYSMGR_SILICONID1_REV_SET_MSK 0x0000ffff
96 /* The mask used to clear the ALT_SYSMGR_SILICONID1_REV register field value. */
97 #define ALT_SYSMGR_SILICONID1_REV_CLR_MSK 0xffff0000
98 /* The reset value of the ALT_SYSMGR_SILICONID1_REV register field. */
99 #define ALT_SYSMGR_SILICONID1_REV_RESET 0x1
100 /* Extracts the ALT_SYSMGR_SILICONID1_REV field value from a register. */
101 #define ALT_SYSMGR_SILICONID1_REV_GET(value) (((value) & 0x0000ffff) >> 0)
102 /* Produces a ALT_SYSMGR_SILICONID1_REV register field value suitable for setting the register. */
103 #define ALT_SYSMGR_SILICONID1_REV_SET(value) (((value) << 0) & 0x0000ffff)
104
105 /*
106  * Field : Silicon ID - id
107  *
108  * Silicon ID
109  *
110  * Field Enumeration Values:
111  *
112  * Enum | Value | Description
113  * :-------------------------------------------|:------|:----------------------------------------------
114  * ALT_SYSMGR_SILICONID1_ID_E_CYCLONEV_ARRIAV | 0x0 | HPS in Cyclone V and Arria V SoC FPGA devices
115  *
116  * Field Access Macros:
117  *
118  */
119 /*
120  * Enumerated value for register field ALT_SYSMGR_SILICONID1_ID
121  *
122  * HPS in Cyclone V and Arria V SoC FPGA devices
123  */
124 #define ALT_SYSMGR_SILICONID1_ID_E_CYCLONEV_ARRIAV 0x0
125
126 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SILICONID1_ID register field. */
127 #define ALT_SYSMGR_SILICONID1_ID_LSB 16
128 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SILICONID1_ID register field. */
129 #define ALT_SYSMGR_SILICONID1_ID_MSB 31
130 /* The width in bits of the ALT_SYSMGR_SILICONID1_ID register field. */
131 #define ALT_SYSMGR_SILICONID1_ID_WIDTH 16
132 /* The mask used to set the ALT_SYSMGR_SILICONID1_ID register field value. */
133 #define ALT_SYSMGR_SILICONID1_ID_SET_MSK 0xffff0000
134 /* The mask used to clear the ALT_SYSMGR_SILICONID1_ID register field value. */
135 #define ALT_SYSMGR_SILICONID1_ID_CLR_MSK 0x0000ffff
136 /* The reset value of the ALT_SYSMGR_SILICONID1_ID register field. */
137 #define ALT_SYSMGR_SILICONID1_ID_RESET 0x0
138 /* Extracts the ALT_SYSMGR_SILICONID1_ID field value from a register. */
139 #define ALT_SYSMGR_SILICONID1_ID_GET(value) (((value) & 0xffff0000) >> 16)
140 /* Produces a ALT_SYSMGR_SILICONID1_ID register field value suitable for setting the register. */
141 #define ALT_SYSMGR_SILICONID1_ID_SET(value) (((value) << 16) & 0xffff0000)
142
143 #ifndef __ASSEMBLY__
144 /*
145  * WARNING: The C register and register group struct declarations are provided for
146  * convenience and illustrative purposes. They should, however, be used with
147  * caution as the C language standard provides no guarantees about the alignment or
148  * atomicity of device memory accesses. The recommended practice for writing
149  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
150  * alt_write_word() functions.
151  *
152  * The struct declaration for register ALT_SYSMGR_SILICONID1.
153  */
155 {
156  const uint32_t rev : 16; /* Silicon Revision */
157  const uint32_t id : 16; /* Silicon ID */
158 };
159
160 /* The typedef declaration for register ALT_SYSMGR_SILICONID1. */
161 typedef volatile struct ALT_SYSMGR_SILICONID1_s ALT_SYSMGR_SILICONID1_t;
162 #endif /* __ASSEMBLY__ */
163
164 /* The byte offset of the ALT_SYSMGR_SILICONID1 register from the beginning of the component. */
165 #define ALT_SYSMGR_SILICONID1_OFST 0x0
166
167 /*
168  * Register : Silicon ID2 Register - siliconid2
169  *
170  * Reserved for future use.
171  *
172  * Register Layout
173  *
174  * Bits | Access | Reset | Description
175  * :-------|:-------|:------|:------------
176  * [31:0] | R | 0x0 | Reserved
177  *
178  */
179 /*
180  * Field : Reserved - rsv
181  *
182  * Reserved for future use.
183  *
184  * Field Access Macros:
185  *
186  */
187 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SILICONID2_RSV register field. */
188 #define ALT_SYSMGR_SILICONID2_RSV_LSB 0
189 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SILICONID2_RSV register field. */
190 #define ALT_SYSMGR_SILICONID2_RSV_MSB 31
191 /* The width in bits of the ALT_SYSMGR_SILICONID2_RSV register field. */
192 #define ALT_SYSMGR_SILICONID2_RSV_WIDTH 32
193 /* The mask used to set the ALT_SYSMGR_SILICONID2_RSV register field value. */
194 #define ALT_SYSMGR_SILICONID2_RSV_SET_MSK 0xffffffff
195 /* The mask used to clear the ALT_SYSMGR_SILICONID2_RSV register field value. */
196 #define ALT_SYSMGR_SILICONID2_RSV_CLR_MSK 0x00000000
197 /* The reset value of the ALT_SYSMGR_SILICONID2_RSV register field. */
198 #define ALT_SYSMGR_SILICONID2_RSV_RESET 0x0
199 /* Extracts the ALT_SYSMGR_SILICONID2_RSV field value from a register. */
200 #define ALT_SYSMGR_SILICONID2_RSV_GET(value) (((value) & 0xffffffff) >> 0)
201 /* Produces a ALT_SYSMGR_SILICONID2_RSV register field value suitable for setting the register. */
202 #define ALT_SYSMGR_SILICONID2_RSV_SET(value) (((value) << 0) & 0xffffffff)
203
204 #ifndef __ASSEMBLY__
205 /*
206  * WARNING: The C register and register group struct declarations are provided for
207  * convenience and illustrative purposes. They should, however, be used with
208  * caution as the C language standard provides no guarantees about the alignment or
209  * atomicity of device memory accesses. The recommended practice for writing
210  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
211  * alt_write_word() functions.
212  *
213  * The struct declaration for register ALT_SYSMGR_SILICONID2.
214  */
216 {
217  const uint32_t rsv : 32; /* Reserved */
218 };
219
220 /* The typedef declaration for register ALT_SYSMGR_SILICONID2. */
221 typedef volatile struct ALT_SYSMGR_SILICONID2_s ALT_SYSMGR_SILICONID2_t;
222 #endif /* __ASSEMBLY__ */
223
224 /* The byte offset of the ALT_SYSMGR_SILICONID2 register from the beginning of the component. */
225 #define ALT_SYSMGR_SILICONID2_OFST 0x4
226
227 /*
228  * Register : L4 Watchdog Debug Register - wddbg
229  *
230  * Controls the behavior of the L4 watchdogs when the CPUs are in debug mode. These
231  * control registers are used to drive the pause input signal of the L4 watchdogs.
232  * Note that the watchdogs built into the MPU automatically are paused when their
233  * associated CPU enters debug mode. Only reset by a cold reset.
234  *
235  * Register Layout
236  *
237  * Bits | Access | Reset | Description
238  * :-------|:-------|:------|:------------
239  * [1:0] | RW | 0x3 | Debug Mode
240  * [3:2] | RW | 0x3 | Debug Mode
241  * [31:4] | ??? | 0x0 | *UNDEFINED*
242  *
243  */
244 /*
245  * Field : Debug Mode - mode_0
246  *
247  * Controls behavior of L4 watchdog when CPUs in debug mode. Field array index
248  * matches L4 watchdog index.
249  *
250  * Field Enumeration Values:
251  *
252  * Enum | Value | Description
253  * :-------------------------------------|:------|:-------------------------------------------------
254  * ALT_SYSMGR_WDDBG_MOD_0_E_CONTINUE | 0x0 | Continue normal operation ignoring debug mode of
255  * : | | CPUs
256  * ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU0 | 0x1 | Pause normal operation only if CPU0 is in debug
257  * : | | mode
258  * ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU1 | 0x2 | Pause normal operation only if CPU1 is in debug
259  * : | | mode
260  * ALT_SYSMGR_WDDBG_MOD_0_E_PAUSEEITHER | 0x3 | Pause normal operation if CPU0 or CPU1 is in
261  * : | | debug mode
262  *
263  * Field Access Macros:
264  *
265  */
266 /*
267  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_0
268  *
269  * Continue normal operation ignoring debug mode of CPUs
270  */
271 #define ALT_SYSMGR_WDDBG_MOD_0_E_CONTINUE 0x0
272 /*
273  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_0
274  *
275  * Pause normal operation only if CPU0 is in debug mode
276  */
277 #define ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU0 0x1
278 /*
279  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_0
280  *
281  * Pause normal operation only if CPU1 is in debug mode
282  */
283 #define ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU1 0x2
284 /*
285  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_0
286  *
287  * Pause normal operation if CPU0 or CPU1 is in debug mode
288  */
289 #define ALT_SYSMGR_WDDBG_MOD_0_E_PAUSEEITHER 0x3
290
291 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
292 #define ALT_SYSMGR_WDDBG_MOD_0_LSB 0
293 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
294 #define ALT_SYSMGR_WDDBG_MOD_0_MSB 1
295 /* The width in bits of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
296 #define ALT_SYSMGR_WDDBG_MOD_0_WIDTH 2
297 /* The mask used to set the ALT_SYSMGR_WDDBG_MOD_0 register field value. */
298 #define ALT_SYSMGR_WDDBG_MOD_0_SET_MSK 0x00000003
299 /* The mask used to clear the ALT_SYSMGR_WDDBG_MOD_0 register field value. */
300 #define ALT_SYSMGR_WDDBG_MOD_0_CLR_MSK 0xfffffffc
301 /* The reset value of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
302 #define ALT_SYSMGR_WDDBG_MOD_0_RESET 0x3
303 /* Extracts the ALT_SYSMGR_WDDBG_MOD_0 field value from a register. */
304 #define ALT_SYSMGR_WDDBG_MOD_0_GET(value) (((value) & 0x00000003) >> 0)
305 /* Produces a ALT_SYSMGR_WDDBG_MOD_0 register field value suitable for setting the register. */
306 #define ALT_SYSMGR_WDDBG_MOD_0_SET(value) (((value) << 0) & 0x00000003)
307
308 /*
309  * Field : Debug Mode - mode_1
310  *
311  * Controls behavior of L4 watchdog when CPUs in debug mode. Field array index
312  * matches L4 watchdog index.
313  *
314  * Field Enumeration Values:
315  *
316  * Enum | Value | Description
317  * :-------------------------------------|:------|:-------------------------------------------------
318  * ALT_SYSMGR_WDDBG_MOD_1_E_CONTINUE | 0x0 | Continue normal operation ignoring debug mode of
319  * : | | CPUs
320  * ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU0 | 0x1 | Pause normal operation only if CPU0 is in debug
321  * : | | mode
322  * ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU1 | 0x2 | Pause normal operation only if CPU1 is in debug
323  * : | | mode
324  * ALT_SYSMGR_WDDBG_MOD_1_E_PAUSEEITHER | 0x3 | Pause normal operation if CPU0 or CPU1 is in
325  * : | | debug mode
326  *
327  * Field Access Macros:
328  *
329  */
330 /*
331  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_1
332  *
333  * Continue normal operation ignoring debug mode of CPUs
334  */
335 #define ALT_SYSMGR_WDDBG_MOD_1_E_CONTINUE 0x0
336 /*
337  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_1
338  *
339  * Pause normal operation only if CPU0 is in debug mode
340  */
341 #define ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU0 0x1
342 /*
343  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_1
344  *
345  * Pause normal operation only if CPU1 is in debug mode
346  */
347 #define ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU1 0x2
348 /*
349  * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_1
350  *
351  * Pause normal operation if CPU0 or CPU1 is in debug mode
352  */
353 #define ALT_SYSMGR_WDDBG_MOD_1_E_PAUSEEITHER 0x3
354
355 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
356 #define ALT_SYSMGR_WDDBG_MOD_1_LSB 2
357 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
358 #define ALT_SYSMGR_WDDBG_MOD_1_MSB 3
359 /* The width in bits of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
360 #define ALT_SYSMGR_WDDBG_MOD_1_WIDTH 2
361 /* The mask used to set the ALT_SYSMGR_WDDBG_MOD_1 register field value. */
362 #define ALT_SYSMGR_WDDBG_MOD_1_SET_MSK 0x0000000c
363 /* The mask used to clear the ALT_SYSMGR_WDDBG_MOD_1 register field value. */
364 #define ALT_SYSMGR_WDDBG_MOD_1_CLR_MSK 0xfffffff3
365 /* The reset value of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
366 #define ALT_SYSMGR_WDDBG_MOD_1_RESET 0x3
367 /* Extracts the ALT_SYSMGR_WDDBG_MOD_1 field value from a register. */
368 #define ALT_SYSMGR_WDDBG_MOD_1_GET(value) (((value) & 0x0000000c) >> 2)
369 /* Produces a ALT_SYSMGR_WDDBG_MOD_1 register field value suitable for setting the register. */
370 #define ALT_SYSMGR_WDDBG_MOD_1_SET(value) (((value) << 2) & 0x0000000c)
371
372 #ifndef __ASSEMBLY__
373 /*
374  * WARNING: The C register and register group struct declarations are provided for
375  * convenience and illustrative purposes. They should, however, be used with
376  * caution as the C language standard provides no guarantees about the alignment or
377  * atomicity of device memory accesses. The recommended practice for writing
378  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
379  * alt_write_word() functions.
380  *
381  * The struct declaration for register ALT_SYSMGR_WDDBG.
382  */
384 {
385  uint32_t mode_0 : 2; /* Debug Mode */
386  uint32_t mode_1 : 2; /* Debug Mode */
387  uint32_t : 28; /* *UNDEFINED* */
388 };
389
390 /* The typedef declaration for register ALT_SYSMGR_WDDBG. */
391 typedef volatile struct ALT_SYSMGR_WDDBG_s ALT_SYSMGR_WDDBG_t;
392 #endif /* __ASSEMBLY__ */
393
394 /* The byte offset of the ALT_SYSMGR_WDDBG register from the beginning of the component. */
395 #define ALT_SYSMGR_WDDBG_OFST 0x10
396
397 /*
398  * Register : Boot Info Register - bootinfo
399  *
400  * Provides access to boot configuration information.
401  *
402  * Register Layout
403  *
404  * Bits | Access | Reset | Description
405  * :--------|:-------|:--------|:---------------------
406  * [2:0] | R | Unknown | Boot Select
407  * [4:3] | R | Unknown | Clock Select
408  * [7:5] | R | Unknown | HPS Pin Boot Select
409  * [9:8] | R | Unknown | HPS Pin Clock Select
410  * [31:10] | ??? | Unknown | *UNDEFINED*
411  *
412  */
413 /*
414  * Field : Boot Select - bsel
415  *
416  * The boot select field specifies the boot source. It is read by the Boot ROM code
417  * on a cold or warm reset to determine the boot source.
418  *
419  * The HPS BSEL pins value are sampled upon deassertion of cold reset.
420  *
421  * Field Enumeration Values:
422  *
423  * Enum | Value | Description
424  * :--------------------------------------------------------|:------|:-----------------------------------
425  * ALT_SYSMGR_BOOT_BSEL_E_RSVD | 0x0 | Reserved
426  * ALT_SYSMGR_BOOT_BSEL_E_FPGA | 0x1 | FPGA (HPS2FPGA Bridge)
427  * ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_1_8V | 0x2 | NAND Flash (1.8v)
428  * ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_3_0V | 0x3 | NAND Flash (3.0v)
429  * ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_EXTERNAL_TRANSCEIVER_1_8V | 0x4 | SD/MMC External Transceiver (1.8v)
430  * ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_INTERNAL_TRANSCEIVER_3_0V | 0x5 | SD/MMC Internal Transceiver (3.0v)
431  * ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_1_8V | 0x6 | QSPI Flash (1.8v)
432  * ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_3_0V | 0x7 | QSPI Flash (3.0v)
433  *
434  * Field Access Macros:
435  *
436  */
437 /*
438  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
439  *
440  * Reserved
441  */
442 #define ALT_SYSMGR_BOOT_BSEL_E_RSVD 0x0
443 /*
444  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
445  *
446  * FPGA (HPS2FPGA Bridge)
447  */
448 #define ALT_SYSMGR_BOOT_BSEL_E_FPGA 0x1
449 /*
450  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
451  *
452  * NAND Flash (1.8v)
453  */
454 #define ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_1_8V 0x2
455 /*
456  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
457  *
458  * NAND Flash (3.0v)
459  */
460 #define ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_3_0V 0x3
461 /*
462  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
463  *
464  * SD/MMC External Transceiver (1.8v)
465  */
466 #define ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_EXTERNAL_TRANSCEIVER_1_8V 0x4
467 /*
468  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
469  *
470  * SD/MMC Internal Transceiver (3.0v)
471  */
472 #define ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_INTERNAL_TRANSCEIVER_3_0V 0x5
473 /*
474  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
475  *
476  * QSPI Flash (1.8v)
477  */
478 #define ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_1_8V 0x6
479 /*
480  * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
481  *
482  * QSPI Flash (3.0v)
483  */
484 #define ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_3_0V 0x7
485
486 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_BSEL register field. */
487 #define ALT_SYSMGR_BOOT_BSEL_LSB 0
488 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_BSEL register field. */
489 #define ALT_SYSMGR_BOOT_BSEL_MSB 2
490 /* The width in bits of the ALT_SYSMGR_BOOT_BSEL register field. */
491 #define ALT_SYSMGR_BOOT_BSEL_WIDTH 3
492 /* The mask used to set the ALT_SYSMGR_BOOT_BSEL register field value. */
493 #define ALT_SYSMGR_BOOT_BSEL_SET_MSK 0x00000007
494 /* The mask used to clear the ALT_SYSMGR_BOOT_BSEL register field value. */
495 #define ALT_SYSMGR_BOOT_BSEL_CLR_MSK 0xfffffff8
496 /* The reset value of the ALT_SYSMGR_BOOT_BSEL register field is UNKNOWN. */
497 #define ALT_SYSMGR_BOOT_BSEL_RESET 0x0
498 /* Extracts the ALT_SYSMGR_BOOT_BSEL field value from a register. */
499 #define ALT_SYSMGR_BOOT_BSEL_GET(value) (((value) & 0x00000007) >> 0)
500 /* Produces a ALT_SYSMGR_BOOT_BSEL register field value suitable for setting the register. */
501 #define ALT_SYSMGR_BOOT_BSEL_SET(value) (((value) << 0) & 0x00000007)
502
503 /*
504  * Field : Clock Select - csel
505  *
506  * The clock select field specifies clock information for booting. The clock select
507  * encoding is a function of the CSEL value. The clock select field is read by the
508  * Boot ROM code on a cold or warm reset when booting from a flash device to get
509  * information about how to setup the HPS clocking to boot from the specified clock
510  * device.
511  *
512  * The encoding of the clock select field is specified by the enum associated with
513  * this field.
514  *
515  * The HPS CSEL pins value are sampled upon deassertion of cold reset.
516  *
517  * Field Enumeration Values:
518  *
519  * Enum | Value | Description
520  * :------------------------------|:------|:------------------------------------------------
521  * ALT_SYSMGR_BOOT_CSEL_E_CSEL_0 | 0x0 | QSPI device clock is osc1_clk divided by 4,
522  * : | | SD/MMC device clock is osc1_clk divided by 4,
523  * : | | NAND device operation is osc1_clk divided by 25
524  * ALT_SYSMGR_BOOT_CSEL_E_CSEL_1 | 0x1 | QSPI device clock is osc1_clk divided by 2,
525  * : | | SD/MMC device clock is osc1_clk divided by 1,
526  * : | | NAND device operation is osc1_clk multiplied by
527  * : | | 20/25
528  * ALT_SYSMGR_BOOT_CSEL_E_CSEL_2 | 0x2 | QSPI device clock is osc1_clk divided by 1,
529  * : | | SD/MMC device clock is osc1_clk divided by 2,
530  * : | | NAND device operation is osc1_clk multiplied by
531  * : | | 10/25
532  * ALT_SYSMGR_BOOT_CSEL_E_CSEL_3 | 0x3 | QSPI device clock is osc1_clk multiplied by 2,
533  * : | | SD/MMC device clock is osc1_clk divided by 4,
534  * : | | NAND device operation is osc1_clk multiplied by
535  * : | | 5/25
536  *
537  * Field Access Macros:
538  *
539  */
540 /*
541  * Enumerated value for register field ALT_SYSMGR_BOOT_CSEL
542  *
543  * QSPI device clock is osc1_clk divided by 4, SD/MMC device clock is osc1_clk
544  * divided by 4, NAND device operation is osc1_clk divided by 25
545  */
546 #define ALT_SYSMGR_BOOT_CSEL_E_CSEL_0 0x0
547 /*
548  * Enumerated value for register field ALT_SYSMGR_BOOT_CSEL
549  *
550  * QSPI device clock is osc1_clk divided by 2, SD/MMC device clock is osc1_clk
551  * divided by 1, NAND device operation is osc1_clk multiplied by 20/25
552  */
553 #define ALT_SYSMGR_BOOT_CSEL_E_CSEL_1 0x1
554 /*
555  * Enumerated value for register field ALT_SYSMGR_BOOT_CSEL
556  *
557  * QSPI device clock is osc1_clk divided by 1, SD/MMC device clock is osc1_clk
558  * divided by 2, NAND device operation is osc1_clk multiplied by 10/25
559  */
560 #define ALT_SYSMGR_BOOT_CSEL_E_CSEL_2 0x2
561 /*
562  * Enumerated value for register field ALT_SYSMGR_BOOT_CSEL
563  *
564  * QSPI device clock is osc1_clk multiplied by 2, SD/MMC device clock is osc1_clk
565  * divided by 4, NAND device operation is osc1_clk multiplied by 5/25
566  */
567 #define ALT_SYSMGR_BOOT_CSEL_E_CSEL_3 0x3
568
569 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_CSEL register field. */
570 #define ALT_SYSMGR_BOOT_CSEL_LSB 3
571 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_CSEL register field. */
572 #define ALT_SYSMGR_BOOT_CSEL_MSB 4
573 /* The width in bits of the ALT_SYSMGR_BOOT_CSEL register field. */
574 #define ALT_SYSMGR_BOOT_CSEL_WIDTH 2
575 /* The mask used to set the ALT_SYSMGR_BOOT_CSEL register field value. */
576 #define ALT_SYSMGR_BOOT_CSEL_SET_MSK 0x00000018
577 /* The mask used to clear the ALT_SYSMGR_BOOT_CSEL register field value. */
578 #define ALT_SYSMGR_BOOT_CSEL_CLR_MSK 0xffffffe7
579 /* The reset value of the ALT_SYSMGR_BOOT_CSEL register field is UNKNOWN. */
580 #define ALT_SYSMGR_BOOT_CSEL_RESET 0x0
581 /* Extracts the ALT_SYSMGR_BOOT_CSEL field value from a register. */
582 #define ALT_SYSMGR_BOOT_CSEL_GET(value) (((value) & 0x00000018) >> 3)
583 /* Produces a ALT_SYSMGR_BOOT_CSEL register field value suitable for setting the register. */
584 #define ALT_SYSMGR_BOOT_CSEL_SET(value) (((value) << 3) & 0x00000018)
585
586 /*
587  * Field : HPS Pin Boot Select - pinbsel
588  *
589  * Specifies the sampled value of the HPS BSEL pins. The value of HPS BSEL pins are
590  * sampled upon deassertion of cold reset.
591  *
592  * Field Access Macros:
593  *
594  */
595 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_PINBSEL register field. */
596 #define ALT_SYSMGR_BOOT_PINBSEL_LSB 5
597 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_PINBSEL register field. */
598 #define ALT_SYSMGR_BOOT_PINBSEL_MSB 7
599 /* The width in bits of the ALT_SYSMGR_BOOT_PINBSEL register field. */
600 #define ALT_SYSMGR_BOOT_PINBSEL_WIDTH 3
601 /* The mask used to set the ALT_SYSMGR_BOOT_PINBSEL register field value. */
602 #define ALT_SYSMGR_BOOT_PINBSEL_SET_MSK 0x000000e0
603 /* The mask used to clear the ALT_SYSMGR_BOOT_PINBSEL register field value. */
604 #define ALT_SYSMGR_BOOT_PINBSEL_CLR_MSK 0xffffff1f
605 /* The reset value of the ALT_SYSMGR_BOOT_PINBSEL register field is UNKNOWN. */
606 #define ALT_SYSMGR_BOOT_PINBSEL_RESET 0x0
607 /* Extracts the ALT_SYSMGR_BOOT_PINBSEL field value from a register. */
608 #define ALT_SYSMGR_BOOT_PINBSEL_GET(value) (((value) & 0x000000e0) >> 5)
609 /* Produces a ALT_SYSMGR_BOOT_PINBSEL register field value suitable for setting the register. */
610 #define ALT_SYSMGR_BOOT_PINBSEL_SET(value) (((value) << 5) & 0x000000e0)
611
612 /*
613  * Field : HPS Pin Clock Select - pincsel
614  *
615  * Specifies the sampled value of the HPS CSEL pins. The value of HPS CSEL pins are
616  * sampled upon deassertion of cold reset.
617  *
618  * Field Access Macros:
619  *
620  */
621 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_PINCSEL register field. */
622 #define ALT_SYSMGR_BOOT_PINCSEL_LSB 8
623 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_PINCSEL register field. */
624 #define ALT_SYSMGR_BOOT_PINCSEL_MSB 9
625 /* The width in bits of the ALT_SYSMGR_BOOT_PINCSEL register field. */
626 #define ALT_SYSMGR_BOOT_PINCSEL_WIDTH 2
627 /* The mask used to set the ALT_SYSMGR_BOOT_PINCSEL register field value. */
628 #define ALT_SYSMGR_BOOT_PINCSEL_SET_MSK 0x00000300
629 /* The mask used to clear the ALT_SYSMGR_BOOT_PINCSEL register field value. */
630 #define ALT_SYSMGR_BOOT_PINCSEL_CLR_MSK 0xfffffcff
631 /* The reset value of the ALT_SYSMGR_BOOT_PINCSEL register field is UNKNOWN. */
632 #define ALT_SYSMGR_BOOT_PINCSEL_RESET 0x0
633 /* Extracts the ALT_SYSMGR_BOOT_PINCSEL field value from a register. */
634 #define ALT_SYSMGR_BOOT_PINCSEL_GET(value) (((value) & 0x00000300) >> 8)
635 /* Produces a ALT_SYSMGR_BOOT_PINCSEL register field value suitable for setting the register. */
636 #define ALT_SYSMGR_BOOT_PINCSEL_SET(value) (((value) << 8) & 0x00000300)
637
638 #ifndef __ASSEMBLY__
639 /*
640  * WARNING: The C register and register group struct declarations are provided for
641  * convenience and illustrative purposes. They should, however, be used with
642  * caution as the C language standard provides no guarantees about the alignment or
643  * atomicity of device memory accesses. The recommended practice for writing
644  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
645  * alt_write_word() functions.
646  *
647  * The struct declaration for register ALT_SYSMGR_BOOT.
648  */
650 {
651  const uint32_t bsel : 3; /* Boot Select */
652  const uint32_t csel : 2; /* Clock Select */
653  const uint32_t pinbsel : 3; /* HPS Pin Boot Select */
654  const uint32_t pincsel : 2; /* HPS Pin Clock Select */
655  uint32_t : 22; /* *UNDEFINED* */
656 };
657
658 /* The typedef declaration for register ALT_SYSMGR_BOOT. */
659 typedef volatile struct ALT_SYSMGR_BOOT_s ALT_SYSMGR_BOOT_t;
660 #endif /* __ASSEMBLY__ */
661
662 /* The byte offset of the ALT_SYSMGR_BOOT register from the beginning of the component. */
663 #define ALT_SYSMGR_BOOT_OFST 0x14
664
665 /*
666  * Register : HPS Info Register - hpsinfo
667  *
668  * Provides information about the HPS capabilities.
669  *
670  * Register Layout
671  *
672  * Bits | Access | Reset | Description
673  * :-------|:-------|:--------|:------------
674  * [0] | R | Unknown | Dual Core
675  * [1] | R | Unknown | CAN
676  * [31:2] | ??? | 0x0 | *UNDEFINED*
677  *
678  */
679 /*
680  * Field : Dual Core - dualcore
681  *
682  * Indicates if CPU1 is available in MPU or not.
683  *
684  * Field Enumeration Values:
685  *
686  * Enum | Value | Description
687  * :-----------------------------------------|:------|:---------------------------------------------
688  * ALT_SYSMGR_HPSINFO_DUALCORE_E_SINGLECORE | 0x0 | Not dual-core (only CPU0 available).
689  * ALT_SYSMGR_HPSINFO_DUALCORE_E_DUALCORE | 0x1 | Is dual-core (CPU0 and CPU1 both available).
690  *
691  * Field Access Macros:
692  *
693  */
694 /*
695  * Enumerated value for register field ALT_SYSMGR_HPSINFO_DUALCORE
696  *
697  * Not dual-core (only CPU0 available).
698  */
699 #define ALT_SYSMGR_HPSINFO_DUALCORE_E_SINGLECORE 0x0
700 /*
701  * Enumerated value for register field ALT_SYSMGR_HPSINFO_DUALCORE
702  *
703  * Is dual-core (CPU0 and CPU1 both available).
704  */
705 #define ALT_SYSMGR_HPSINFO_DUALCORE_E_DUALCORE 0x1
706
707 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_HPSINFO_DUALCORE register field. */
708 #define ALT_SYSMGR_HPSINFO_DUALCORE_LSB 0
709 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_HPSINFO_DUALCORE register field. */
710 #define ALT_SYSMGR_HPSINFO_DUALCORE_MSB 0
711 /* The width in bits of the ALT_SYSMGR_HPSINFO_DUALCORE register field. */
712 #define ALT_SYSMGR_HPSINFO_DUALCORE_WIDTH 1
713 /* The mask used to set the ALT_SYSMGR_HPSINFO_DUALCORE register field value. */
714 #define ALT_SYSMGR_HPSINFO_DUALCORE_SET_MSK 0x00000001
715 /* The mask used to clear the ALT_SYSMGR_HPSINFO_DUALCORE register field value. */
716 #define ALT_SYSMGR_HPSINFO_DUALCORE_CLR_MSK 0xfffffffe
717 /* The reset value of the ALT_SYSMGR_HPSINFO_DUALCORE register field is UNKNOWN. */
718 #define ALT_SYSMGR_HPSINFO_DUALCORE_RESET 0x0
719 /* Extracts the ALT_SYSMGR_HPSINFO_DUALCORE field value from a register. */
720 #define ALT_SYSMGR_HPSINFO_DUALCORE_GET(value) (((value) & 0x00000001) >> 0)
721 /* Produces a ALT_SYSMGR_HPSINFO_DUALCORE register field value suitable for setting the register. */
722 #define ALT_SYSMGR_HPSINFO_DUALCORE_SET(value) (((value) << 0) & 0x00000001)
723
724 /*
725  * Field : CAN - can
726  *
727  * Indicates if CAN0 and CAN1 controllers are available or not.
728  *
729  * Field Enumeration Values:
730  *
731  * Enum | Value | Description
732  * :-----------------------------------------|:------|:---------------------------------
733  * ALT_SYSMGR_HPSINFO_CAN_E_CAN_UNAVAILABLE | 0x0 | CAN0 and CAN1 are not available.
734  * ALT_SYSMGR_HPSINFO_CAN_E_CAN_AVAILABLE | 0x1 | CAN0 and CAN1 are available.
735  *
736  * Field Access Macros:
737  *
738  */
739 /*
740  * Enumerated value for register field ALT_SYSMGR_HPSINFO_CAN
741  *
742  * CAN0 and CAN1 are not available.
743  */
744 #define ALT_SYSMGR_HPSINFO_CAN_E_CAN_UNAVAILABLE 0x0
745 /*
746  * Enumerated value for register field ALT_SYSMGR_HPSINFO_CAN
747  *
748  * CAN0 and CAN1 are available.
749  */
750 #define ALT_SYSMGR_HPSINFO_CAN_E_CAN_AVAILABLE 0x1
751
752 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_HPSINFO_CAN register field. */
753 #define ALT_SYSMGR_HPSINFO_CAN_LSB 1
754 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_HPSINFO_CAN register field. */
755 #define ALT_SYSMGR_HPSINFO_CAN_MSB 1
756 /* The width in bits of the ALT_SYSMGR_HPSINFO_CAN register field. */
757 #define ALT_SYSMGR_HPSINFO_CAN_WIDTH 1
758 /* The mask used to set the ALT_SYSMGR_HPSINFO_CAN register field value. */
759 #define ALT_SYSMGR_HPSINFO_CAN_SET_MSK 0x00000002
760 /* The mask used to clear the ALT_SYSMGR_HPSINFO_CAN register field value. */
761 #define ALT_SYSMGR_HPSINFO_CAN_CLR_MSK 0xfffffffd
762 /* The reset value of the ALT_SYSMGR_HPSINFO_CAN register field is UNKNOWN. */
763 #define ALT_SYSMGR_HPSINFO_CAN_RESET 0x0
764 /* Extracts the ALT_SYSMGR_HPSINFO_CAN field value from a register. */
765 #define ALT_SYSMGR_HPSINFO_CAN_GET(value) (((value) & 0x00000002) >> 1)
766 /* Produces a ALT_SYSMGR_HPSINFO_CAN register field value suitable for setting the register. */
767 #define ALT_SYSMGR_HPSINFO_CAN_SET(value) (((value) << 1) & 0x00000002)
768
769 #ifndef __ASSEMBLY__
770 /*
771  * WARNING: The C register and register group struct declarations are provided for
772  * convenience and illustrative purposes. They should, however, be used with
773  * caution as the C language standard provides no guarantees about the alignment or
774  * atomicity of device memory accesses. The recommended practice for writing
775  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
776  * alt_write_word() functions.
777  *
778  * The struct declaration for register ALT_SYSMGR_HPSINFO.
779  */
781 {
782  const uint32_t dualcore : 1; /* Dual Core */
783  const uint32_t can : 1; /* CAN */
784  uint32_t : 30; /* *UNDEFINED* */
785 };
786
787 /* The typedef declaration for register ALT_SYSMGR_HPSINFO. */
788 typedef volatile struct ALT_SYSMGR_HPSINFO_s ALT_SYSMGR_HPSINFO_t;
789 #endif /* __ASSEMBLY__ */
790
791 /* The byte offset of the ALT_SYSMGR_HPSINFO register from the beginning of the component. */
792 #define ALT_SYSMGR_HPSINFO_OFST 0x18
793
794 /*
795  * Register : Parity Fail Injection Register - parityinj
796  *
797  * Inject parity failures into the parity-protected RAMs in the MPU. Allows
798  * software to test the parity failure interrupt handler. The field array index
799  * corresponds to the CPU index.
800  *
801  * All fields are reset by a cold or warm reset.
802  *
803  * Register Layout
804  *
805  * Bits | Access | Reset | Description
806  * :--------|:-------|:------|:-----------------------------------------------------
807  * [0] | RW | 0x0 | Parity Fail Injection for Data Cache Data RAM
808  * [1] | RW | 0x0 | Parity Fail Injection for Data Cache Data RAM
809  * [2] | RW | 0x0 | Parity Fail Injection for Data Cache Tag RAM
810  * [3] | RW | 0x0 | Parity Fail Injection for Data Cache Tag RAM
811  * [4] | RW | 0x0 | Parity Fail Injection for Data Cache Outer RAM
812  * [5] | RW | 0x0 | Parity Fail Injection for Data Cache Outer RAM
813  * [6] | RW | 0x0 | Parity Fail Injection for Main TLB RAM
814  * [7] | RW | 0x0 | Parity Fail Injection for Main TLB RAM
815  * [8] | RW | 0x0 | Parity Fail Injection for Instruction Cache Data RAM
816  * [9] | RW | 0x0 | Parity Fail Injection for Instruction Cache Data RAM
817  * [10] | RW | 0x0 | Parity Fail Injection for Instruction Cache Tag RAM
818  * [11] | RW | 0x0 | Parity Fail Injection for Instruction Cache Tag RAM
819  * [12] | RW | 0x0 | Parity Fail Injection for GHB RAM
820  * [13] | RW | 0x0 | Parity Fail Injection for GHB RAM
821  * [14] | RW | 0x0 | Parity Fail Injection for BTAC RAM
822  * [15] | RW | 0x0 | Parity Fail Injection for BTAC RAM
823  * [31:16] | ??? | 0x0 | *UNDEFINED*
824  *
825  */
826 /*
827  * Field : Parity Fail Injection for Data Cache Data RAM - dcdata_0
828  *
829  * If 1, injecting parity error to Data Cache Data RAM.The field array index
830  * corresponds to the CPU index.
831  *
832  * Field Access Macros:
833  *
834  */
835 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
836 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_LSB 0
837 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
838 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_MSB 0
839 /* The width in bits of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
840 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_WIDTH 1
841 /* The mask used to set the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field value. */
842 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_SET_MSK 0x00000001
843 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field value. */
844 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_CLR_MSK 0xfffffffe
845 /* The reset value of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
846 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_RESET 0x0
847 /* Extracts the ALT_SYSMGR_PARITYINJ_DCDATA_0 field value from a register. */
848 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_GET(value) (((value) & 0x00000001) >> 0)
849 /* Produces a ALT_SYSMGR_PARITYINJ_DCDATA_0 register field value suitable for setting the register. */
850 #define ALT_SYSMGR_PARITYINJ_DCDATA_0_SET(value) (((value) << 0) & 0x00000001)
851
852 /*
853  * Field : Parity Fail Injection for Data Cache Data RAM - dcdata_1
854  *
855  * If 1, injecting parity error to Data Cache Data RAM.The field array index
856  * corresponds to the CPU index.
857  *
858  * Field Access Macros:
859  *
860  */
861 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
862 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_LSB 1
863 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
864 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_MSB 1
865 /* The width in bits of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
866 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_WIDTH 1
867 /* The mask used to set the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field value. */
868 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_SET_MSK 0x00000002
869 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field value. */
870 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_CLR_MSK 0xfffffffd
871 /* The reset value of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
872 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_RESET 0x0
873 /* Extracts the ALT_SYSMGR_PARITYINJ_DCDATA_1 field value from a register. */
874 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_GET(value) (((value) & 0x00000002) >> 1)
875 /* Produces a ALT_SYSMGR_PARITYINJ_DCDATA_1 register field value suitable for setting the register. */
876 #define ALT_SYSMGR_PARITYINJ_DCDATA_1_SET(value) (((value) << 1) & 0x00000002)
877
878 /*
879  * Field : Parity Fail Injection for Data Cache Tag RAM - dctag_0
880  *
881  * If 1, injecting parity error to Data Cache Tag RAM.The field array index
882  * corresponds to the CPU index.
883  *
884  * Field Access Macros:
885  *
886  */
887 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
888 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_LSB 2
889 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
890 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_MSB 2
891 /* The width in bits of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
892 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_WIDTH 1
893 /* The mask used to set the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field value. */
894 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_SET_MSK 0x00000004
895 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field value. */
896 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_CLR_MSK 0xfffffffb
897 /* The reset value of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
898 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_RESET 0x0
899 /* Extracts the ALT_SYSMGR_PARITYINJ_DCTAG_0 field value from a register. */
900 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_GET(value) (((value) & 0x00000004) >> 2)
901 /* Produces a ALT_SYSMGR_PARITYINJ_DCTAG_0 register field value suitable for setting the register. */
902 #define ALT_SYSMGR_PARITYINJ_DCTAG_0_SET(value) (((value) << 2) & 0x00000004)
903
904 /*
905  * Field : Parity Fail Injection for Data Cache Tag RAM - dctag_1
906  *
907  * If 1, injecting parity error to Data Cache Tag RAM.The field array index
908  * corresponds to the CPU index.
909  *
910  * Field Access Macros:
911  *
912  */
913 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
914 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_LSB 3
915 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
916 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_MSB 3
917 /* The width in bits of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
918 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_WIDTH 1
919 /* The mask used to set the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field value. */
920 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_SET_MSK 0x00000008
921 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field value. */
922 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_CLR_MSK 0xfffffff7
923 /* The reset value of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
924 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_RESET 0x0
925 /* Extracts the ALT_SYSMGR_PARITYINJ_DCTAG_1 field value from a register. */
926 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_GET(value) (((value) & 0x00000008) >> 3)
927 /* Produces a ALT_SYSMGR_PARITYINJ_DCTAG_1 register field value suitable for setting the register. */
928 #define ALT_SYSMGR_PARITYINJ_DCTAG_1_SET(value) (((value) << 3) & 0x00000008)
929
930 /*
931  * Field : Parity Fail Injection for Data Cache Outer RAM - dcouter_0
932  *
933  * If 1, injecting parity error to Data Cache Outer RAM.The field array index
934  * corresponds to the CPU index.
935  *
936  * Field Access Macros:
937  *
938  */
939 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
940 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_LSB 4
941 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
942 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_MSB 4
943 /* The width in bits of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
944 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_WIDTH 1
945 /* The mask used to set the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field value. */
946 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_SET_MSK 0x00000010
947 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field value. */
948 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_CLR_MSK 0xffffffef
949 /* The reset value of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
950 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_RESET 0x0
951 /* Extracts the ALT_SYSMGR_PARITYINJ_DCOUTER_0 field value from a register. */
952 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_GET(value) (((value) & 0x00000010) >> 4)
953 /* Produces a ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field value suitable for setting the register. */
954 #define ALT_SYSMGR_PARITYINJ_DCOUTER_0_SET(value) (((value) << 4) & 0x00000010)
955
956 /*
957  * Field : Parity Fail Injection for Data Cache Outer RAM - dcouter_1
958  *
959  * If 1, injecting parity error to Data Cache Outer RAM.The field array index
960  * corresponds to the CPU index.
961  *
962  * Field Access Macros:
963  *
964  */
965 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
966 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_LSB 5
967 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
968 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_MSB 5
969 /* The width in bits of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
970 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_WIDTH 1
971 /* The mask used to set the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field value. */
972 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_SET_MSK 0x00000020
973 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field value. */
974 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_CLR_MSK 0xffffffdf
975 /* The reset value of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
976 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_RESET 0x0
977 /* Extracts the ALT_SYSMGR_PARITYINJ_DCOUTER_1 field value from a register. */
978 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_GET(value) (((value) & 0x00000020) >> 5)
979 /* Produces a ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field value suitable for setting the register. */
980 #define ALT_SYSMGR_PARITYINJ_DCOUTER_1_SET(value) (((value) << 5) & 0x00000020)
981
982 /*
983  * Field : Parity Fail Injection for Main TLB RAM - maintlb_0
984  *
985  * If 1, injecting parity error to Main TLB RAM.The field array index corresponds
986  * to the CPU index.
987  *
988  * Field Access Macros:
989  *
990  */
991 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
992 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_LSB 6
993 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
994 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_MSB 6
995 /* The width in bits of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
996 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_WIDTH 1
997 /* The mask used to set the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field value. */
998 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_SET_MSK 0x00000040
999 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field value. */
1000 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_CLR_MSK 0xffffffbf
1001 /* The reset value of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
1002 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_RESET 0x0
1003 /* Extracts the ALT_SYSMGR_PARITYINJ_MAINTLB_0 field value from a register. */
1004 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_GET(value) (((value) & 0x00000040) >> 6)
1005 /* Produces a ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field value suitable for setting the register. */
1006 #define ALT_SYSMGR_PARITYINJ_MAINTLB_0_SET(value) (((value) << 6) & 0x00000040)
1007
1008 /*
1009  * Field : Parity Fail Injection for Main TLB RAM - maintlb_1
1010  *
1011  * If 1, injecting parity error to Main TLB RAM.The field array index corresponds
1012  * to the CPU index.
1013  *
1014  * Field Access Macros:
1015  *
1016  */
1017 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
1018 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_LSB 7
1019 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
1020 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_MSB 7
1021 /* The width in bits of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
1022 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_WIDTH 1
1023 /* The mask used to set the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field value. */
1024 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_SET_MSK 0x00000080
1025 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field value. */
1026 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_CLR_MSK 0xffffff7f
1027 /* The reset value of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
1028 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_RESET 0x0
1029 /* Extracts the ALT_SYSMGR_PARITYINJ_MAINTLB_1 field value from a register. */
1030 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_GET(value) (((value) & 0x00000080) >> 7)
1031 /* Produces a ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field value suitable for setting the register. */
1032 #define ALT_SYSMGR_PARITYINJ_MAINTLB_1_SET(value) (((value) << 7) & 0x00000080)
1033
1034 /*
1035  * Field : Parity Fail Injection for Instruction Cache Data RAM - icdata_0
1036  *
1037  * If 1, injecting parity error to Instruction Cache Data RAM.The field array index
1038  * corresponds to the CPU index.
1039  *
1040  * Field Access Macros:
1041  *
1042  */
1043 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
1044 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_LSB 8
1045 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
1046 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_MSB 8
1047 /* The width in bits of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
1048 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_WIDTH 1
1049 /* The mask used to set the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field value. */
1050 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_SET_MSK 0x00000100
1051 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field value. */
1052 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_CLR_MSK 0xfffffeff
1053 /* The reset value of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
1054 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_RESET 0x0
1055 /* Extracts the ALT_SYSMGR_PARITYINJ_ICDATA_0 field value from a register. */
1056 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_GET(value) (((value) & 0x00000100) >> 8)
1057 /* Produces a ALT_SYSMGR_PARITYINJ_ICDATA_0 register field value suitable for setting the register. */
1058 #define ALT_SYSMGR_PARITYINJ_ICDATA_0_SET(value) (((value) << 8) & 0x00000100)
1059
1060 /*
1061  * Field : Parity Fail Injection for Instruction Cache Data RAM - icdata_1
1062  *
1063  * If 1, injecting parity error to Instruction Cache Data RAM.The field array index
1064  * corresponds to the CPU index.
1065  *
1066  * Field Access Macros:
1067  *
1068  */
1069 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
1070 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_LSB 9
1071 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
1072 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_MSB 9
1073 /* The width in bits of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
1074 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_WIDTH 1
1075 /* The mask used to set the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field value. */
1076 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_SET_MSK 0x00000200
1077 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field value. */
1078 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_CLR_MSK 0xfffffdff
1079 /* The reset value of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
1080 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_RESET 0x0
1081 /* Extracts the ALT_SYSMGR_PARITYINJ_ICDATA_1 field value from a register. */
1082 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_GET(value) (((value) & 0x00000200) >> 9)
1083 /* Produces a ALT_SYSMGR_PARITYINJ_ICDATA_1 register field value suitable for setting the register. */
1084 #define ALT_SYSMGR_PARITYINJ_ICDATA_1_SET(value) (((value) << 9) & 0x00000200)
1085
1086 /*
1087  * Field : Parity Fail Injection for Instruction Cache Tag RAM - ictag_0
1088  *
1089  * If 1, injecting parity error to Instruction Cache Tag RAM.The field array index
1090  * corresponds to the CPU index.
1091  *
1092  * Field Access Macros:
1093  *
1094  */
1095 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
1096 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_LSB 10
1097 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
1098 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_MSB 10
1099 /* The width in bits of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
1100 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_WIDTH 1
1101 /* The mask used to set the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field value. */
1102 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_SET_MSK 0x00000400
1103 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field value. */
1104 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_CLR_MSK 0xfffffbff
1105 /* The reset value of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
1106 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_RESET 0x0
1107 /* Extracts the ALT_SYSMGR_PARITYINJ_ICTAG_0 field value from a register. */
1108 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_GET(value) (((value) & 0x00000400) >> 10)
1109 /* Produces a ALT_SYSMGR_PARITYINJ_ICTAG_0 register field value suitable for setting the register. */
1110 #define ALT_SYSMGR_PARITYINJ_ICTAG_0_SET(value) (((value) << 10) & 0x00000400)
1111
1112 /*
1113  * Field : Parity Fail Injection for Instruction Cache Tag RAM - ictag_1
1114  *
1115  * If 1, injecting parity error to Instruction Cache Tag RAM.The field array index
1116  * corresponds to the CPU index.
1117  *
1118  * Field Access Macros:
1119  *
1120  */
1121 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
1122 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_LSB 11
1123 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
1124 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_MSB 11
1125 /* The width in bits of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
1126 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_WIDTH 1
1127 /* The mask used to set the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field value. */
1128 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_SET_MSK 0x00000800
1129 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field value. */
1130 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_CLR_MSK 0xfffff7ff
1131 /* The reset value of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
1132 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_RESET 0x0
1133 /* Extracts the ALT_SYSMGR_PARITYINJ_ICTAG_1 field value from a register. */
1134 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_GET(value) (((value) & 0x00000800) >> 11)
1135 /* Produces a ALT_SYSMGR_PARITYINJ_ICTAG_1 register field value suitable for setting the register. */
1136 #define ALT_SYSMGR_PARITYINJ_ICTAG_1_SET(value) (((value) << 11) & 0x00000800)
1137
1138 /*
1139  * Field : Parity Fail Injection for GHB RAM - ghb_0
1140  *
1141  * If 1, injecting parity error to GHB RAM.The field array index corresponds to the
1142  * CPU index.
1143  *
1144  * Field Access Macros:
1145  *
1146  */
1147 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
1148 #define ALT_SYSMGR_PARITYINJ_GHB_0_LSB 12
1149 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
1150 #define ALT_SYSMGR_PARITYINJ_GHB_0_MSB 12
1151 /* The width in bits of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
1152 #define ALT_SYSMGR_PARITYINJ_GHB_0_WIDTH 1
1153 /* The mask used to set the ALT_SYSMGR_PARITYINJ_GHB_0 register field value. */
1154 #define ALT_SYSMGR_PARITYINJ_GHB_0_SET_MSK 0x00001000
1155 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_GHB_0 register field value. */
1156 #define ALT_SYSMGR_PARITYINJ_GHB_0_CLR_MSK 0xffffefff
1157 /* The reset value of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
1158 #define ALT_SYSMGR_PARITYINJ_GHB_0_RESET 0x0
1159 /* Extracts the ALT_SYSMGR_PARITYINJ_GHB_0 field value from a register. */
1160 #define ALT_SYSMGR_PARITYINJ_GHB_0_GET(value) (((value) & 0x00001000) >> 12)
1161 /* Produces a ALT_SYSMGR_PARITYINJ_GHB_0 register field value suitable for setting the register. */
1162 #define ALT_SYSMGR_PARITYINJ_GHB_0_SET(value) (((value) << 12) & 0x00001000)
1163
1164 /*
1165  * Field : Parity Fail Injection for GHB RAM - ghb_1
1166  *
1167  * If 1, injecting parity error to GHB RAM.The field array index corresponds to the
1168  * CPU index.
1169  *
1170  * Field Access Macros:
1171  *
1172  */
1173 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
1174 #define ALT_SYSMGR_PARITYINJ_GHB_1_LSB 13
1175 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
1176 #define ALT_SYSMGR_PARITYINJ_GHB_1_MSB 13
1177 /* The width in bits of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
1178 #define ALT_SYSMGR_PARITYINJ_GHB_1_WIDTH 1
1179 /* The mask used to set the ALT_SYSMGR_PARITYINJ_GHB_1 register field value. */
1180 #define ALT_SYSMGR_PARITYINJ_GHB_1_SET_MSK 0x00002000
1181 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_GHB_1 register field value. */
1182 #define ALT_SYSMGR_PARITYINJ_GHB_1_CLR_MSK 0xffffdfff
1183 /* The reset value of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
1184 #define ALT_SYSMGR_PARITYINJ_GHB_1_RESET 0x0
1185 /* Extracts the ALT_SYSMGR_PARITYINJ_GHB_1 field value from a register. */
1186 #define ALT_SYSMGR_PARITYINJ_GHB_1_GET(value) (((value) & 0x00002000) >> 13)
1187 /* Produces a ALT_SYSMGR_PARITYINJ_GHB_1 register field value suitable for setting the register. */
1188 #define ALT_SYSMGR_PARITYINJ_GHB_1_SET(value) (((value) << 13) & 0x00002000)
1189
1190 /*
1191  * Field : Parity Fail Injection for BTAC RAM - btac_0
1192  *
1193  * If 1, injecting parity error to BTAC RAM.The field array index corresponds to
1194  * the CPU index.
1195  *
1196  * Field Access Macros:
1197  *
1198  */
1199 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
1200 #define ALT_SYSMGR_PARITYINJ_BTAC_0_LSB 14
1201 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
1202 #define ALT_SYSMGR_PARITYINJ_BTAC_0_MSB 14
1203 /* The width in bits of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
1204 #define ALT_SYSMGR_PARITYINJ_BTAC_0_WIDTH 1
1205 /* The mask used to set the ALT_SYSMGR_PARITYINJ_BTAC_0 register field value. */
1206 #define ALT_SYSMGR_PARITYINJ_BTAC_0_SET_MSK 0x00004000
1207 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_BTAC_0 register field value. */
1208 #define ALT_SYSMGR_PARITYINJ_BTAC_0_CLR_MSK 0xffffbfff
1209 /* The reset value of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
1210 #define ALT_SYSMGR_PARITYINJ_BTAC_0_RESET 0x0
1211 /* Extracts the ALT_SYSMGR_PARITYINJ_BTAC_0 field value from a register. */
1212 #define ALT_SYSMGR_PARITYINJ_BTAC_0_GET(value) (((value) & 0x00004000) >> 14)
1213 /* Produces a ALT_SYSMGR_PARITYINJ_BTAC_0 register field value suitable for setting the register. */
1214 #define ALT_SYSMGR_PARITYINJ_BTAC_0_SET(value) (((value) << 14) & 0x00004000)
1215
1216 /*
1217  * Field : Parity Fail Injection for BTAC RAM - btac_1
1218  *
1219  * If 1, injecting parity error to BTAC RAM.The field array index corresponds to
1220  * the CPU index.
1221  *
1222  * Field Access Macros:
1223  *
1224  */
1225 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
1226 #define ALT_SYSMGR_PARITYINJ_BTAC_1_LSB 15
1227 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
1228 #define ALT_SYSMGR_PARITYINJ_BTAC_1_MSB 15
1229 /* The width in bits of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
1230 #define ALT_SYSMGR_PARITYINJ_BTAC_1_WIDTH 1
1231 /* The mask used to set the ALT_SYSMGR_PARITYINJ_BTAC_1 register field value. */
1232 #define ALT_SYSMGR_PARITYINJ_BTAC_1_SET_MSK 0x00008000
1233 /* The mask used to clear the ALT_SYSMGR_PARITYINJ_BTAC_1 register field value. */
1234 #define ALT_SYSMGR_PARITYINJ_BTAC_1_CLR_MSK 0xffff7fff
1235 /* The reset value of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
1236 #define ALT_SYSMGR_PARITYINJ_BTAC_1_RESET 0x0
1237 /* Extracts the ALT_SYSMGR_PARITYINJ_BTAC_1 field value from a register. */
1238 #define ALT_SYSMGR_PARITYINJ_BTAC_1_GET(value) (((value) & 0x00008000) >> 15)
1239 /* Produces a ALT_SYSMGR_PARITYINJ_BTAC_1 register field value suitable for setting the register. */
1240 #define ALT_SYSMGR_PARITYINJ_BTAC_1_SET(value) (((value) << 15) & 0x00008000)
1241
1242 #ifndef __ASSEMBLY__
1243 /*
1244  * WARNING: The C register and register group struct declarations are provided for
1245  * convenience and illustrative purposes. They should, however, be used with
1246  * caution as the C language standard provides no guarantees about the alignment or
1247  * atomicity of device memory accesses. The recommended practice for writing
1248  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1249  * alt_write_word() functions.
1250  *
1251  * The struct declaration for register ALT_SYSMGR_PARITYINJ.
1252  */
1254 {
1255  uint32_t dcdata_0 : 1; /* Parity Fail Injection for Data Cache Data RAM */
1256  uint32_t dcdata_1 : 1; /* Parity Fail Injection for Data Cache Data RAM */
1257  uint32_t dctag_0 : 1; /* Parity Fail Injection for Data Cache Tag RAM */
1258  uint32_t dctag_1 : 1; /* Parity Fail Injection for Data Cache Tag RAM */
1259  uint32_t dcouter_0 : 1; /* Parity Fail Injection for Data Cache Outer RAM */
1260  uint32_t dcouter_1 : 1; /* Parity Fail Injection for Data Cache Outer RAM */
1261  uint32_t maintlb_0 : 1; /* Parity Fail Injection for Main TLB RAM */
1262  uint32_t maintlb_1 : 1; /* Parity Fail Injection for Main TLB RAM */
1263  uint32_t icdata_0 : 1; /* Parity Fail Injection for Instruction Cache Data RAM */
1264  uint32_t icdata_1 : 1; /* Parity Fail Injection for Instruction Cache Data RAM */
1265  uint32_t ictag_0 : 1; /* Parity Fail Injection for Instruction Cache Tag RAM */
1266  uint32_t ictag_1 : 1; /* Parity Fail Injection for Instruction Cache Tag RAM */
1267  uint32_t ghb_0 : 1; /* Parity Fail Injection for GHB RAM */
1268  uint32_t ghb_1 : 1; /* Parity Fail Injection for GHB RAM */
1269  uint32_t btac_0 : 1; /* Parity Fail Injection for BTAC RAM */
1270  uint32_t btac_1 : 1; /* Parity Fail Injection for BTAC RAM */
1271  uint32_t : 16; /* *UNDEFINED* */
1272 };
1273
1274 /* The typedef declaration for register ALT_SYSMGR_PARITYINJ. */
1275 typedef volatile struct ALT_SYSMGR_PARITYINJ_s ALT_SYSMGR_PARITYINJ_t;
1276 #endif /* __ASSEMBLY__ */
1277
1278 /* The byte offset of the ALT_SYSMGR_PARITYINJ register from the beginning of the component. */
1279 #define ALT_SYSMGR_PARITYINJ_OFST 0x1c
1280
1281 /*
1282  * Register Group : FPGA Interface Group - ALT_SYSMGR_FPGAINTF
1283  * FPGA Interface Group
1284  *
1285  * Registers used to enable/disable interfaces between the FPGA and HPS. Required
1286  * for either of the following situations:[list][*]Interfaces that cannot be
1287  * disabled by putting an HPS module associated with the interface into
1288  * reset.[*]HPS modules that accept signals from the FPGA fabric and those signals
1289  * might interfere with the normal operation of the module.[/list].
1290  *
1291  * All registers are only reset by a cold reset (ignore warm reset).
1292  *
1293  */
1294 /*
1295  * Register : Global Disable Register - gbl
1296  *
1297  * Used to disable all interfaces between the FPGA and HPS.
1298  *
1299  * Register Layout
1300  *
1301  * Bits | Access | Reset | Description
1302  * :-------|:-------|:------|:-----------------
1303  * [0] | RW | 0x1 | Global Interface
1304  * [31:1] | ??? | 0x0 | *UNDEFINED*
1305  *
1306  */
1307 /*
1308  * Field : Global Interface - intf
1309  *
1310  * Used to disable all interfaces between the FPGA and HPS. Software must ensure
1311  * that all interfaces between the FPGA and HPS are inactive before disabling them.
1312  *
1313  * Field Enumeration Values:
1314  *
1315  * Enum | Value | Description
1316  * :-----------------------------------|:------|:-------------------------------------------------
1317  * ALT_SYSMGR_FPGAINTF_GBL_INTF_E_DIS | 0x0 | All interfaces between FPGA and HPS are
1318  * : | | disabled.
1319  * ALT_SYSMGR_FPGAINTF_GBL_INTF_E_EN | 0x1 | Interfaces between FPGA and HPS are not all
1320  * : | | disabled. Interfaces can be indivdually disabled
1321  * : | | by putting the HPS module associated with the
1322  * : | | interface in reset using registers in the Reset
1323  * : | | Manager or by using registers in this register
1324  * : | | group of the System Manager for interfaces
1325  * : | | without an associated module.
1326  *
1327  * Field Access Macros:
1328  *
1329  */
1330 /*
1331  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_GBL_INTF
1332  *
1333  * All interfaces between FPGA and HPS are disabled.
1334  */
1335 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_E_DIS 0x0
1336 /*
1337  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_GBL_INTF
1338  *
1339  * Interfaces between FPGA and HPS are not all disabled. Interfaces can be
1340  * indivdually disabled by putting the HPS module associated with the interface in
1341  * reset using registers in the Reset Manager or by using registers in this
1342  * register group of the System Manager for interfaces without an associated
1343  * module.
1344  */
1345 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_E_EN 0x1
1346
1347 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
1348 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_LSB 0
1349 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
1350 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_MSB 0
1351 /* The width in bits of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
1352 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_WIDTH 1
1353 /* The mask used to set the ALT_SYSMGR_FPGAINTF_GBL_INTF register field value. */
1354 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_SET_MSK 0x00000001
1355 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_GBL_INTF register field value. */
1356 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_CLR_MSK 0xfffffffe
1357 /* The reset value of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
1358 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_RESET 0x1
1359 /* Extracts the ALT_SYSMGR_FPGAINTF_GBL_INTF field value from a register. */
1360 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_GET(value) (((value) & 0x00000001) >> 0)
1361 /* Produces a ALT_SYSMGR_FPGAINTF_GBL_INTF register field value suitable for setting the register. */
1362 #define ALT_SYSMGR_FPGAINTF_GBL_INTF_SET(value) (((value) << 0) & 0x00000001)
1363
1364 #ifndef __ASSEMBLY__
1365 /*
1366  * WARNING: The C register and register group struct declarations are provided for
1367  * convenience and illustrative purposes. They should, however, be used with
1368  * caution as the C language standard provides no guarantees about the alignment or
1369  * atomicity of device memory accesses. The recommended practice for writing
1370  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1371  * alt_write_word() functions.
1372  *
1373  * The struct declaration for register ALT_SYSMGR_FPGAINTF_GBL.
1374  */
1376 {
1377  uint32_t intf : 1; /* Global Interface */
1378  uint32_t : 31; /* *UNDEFINED* */
1379 };
1380
1381 /* The typedef declaration for register ALT_SYSMGR_FPGAINTF_GBL. */
1382 typedef volatile struct ALT_SYSMGR_FPGAINTF_GBL_s ALT_SYSMGR_FPGAINTF_GBL_t;
1383 #endif /* __ASSEMBLY__ */
1384
1385 /* The byte offset of the ALT_SYSMGR_FPGAINTF_GBL register from the beginning of the component. */
1386 #define ALT_SYSMGR_FPGAINTF_GBL_OFST 0x0
1387
1388 /*
1389  * Register : Individual Disable Register - indiv
1390  *
1391  * Used to disable individual interfaces between the FPGA and HPS.
1392  *
1393  * Register Layout
1394  *
1395  * Bits | Access | Reset | Description
1396  * :-------|:-------|:------|:------------------------------
1397  * [0] | RW | 0x1 | Reset Request Interface
1398  * [1] | RW | 0x1 | JTAG Enable Interface
1399  * [2] | RW | 0x1 | CONFIG_IO Interface
1400  * [3] | RW | 0x1 | Boundary-Scan Interface
1401  * [4] | RW | 0x1 | Trace Interface
1402  * [5] | ??? | 0x1 | *UNDEFINED*
1403  * [6] | RW | 0x1 | STM Event Interface
1404  * [7] | RW | 0x1 | Cross Trigger Interface (CTI)
1405  * [31:8] | ??? | 0x0 | *UNDEFINED*
1406  *
1407  */
1408 /*
1409  * Field : Reset Request Interface - rstreqintf
1410  *
1411  * Used to disable the reset request interface. This interface allows logic in the
1412  * FPGA fabric to request HPS resets. This field disables the following reset
1413  * request signals from the FPGA fabric to HPS:[list][*]f2h_cold_rst_req_n -
1414  * Triggers a cold reset of the HPS[*]f2h_warm_rst_req_n - Triggers a warm reset of
1415  * the HPS[*]f2h_dbg_rst_req_n - Triggers a debug reset of the HPS[/list]
1416  *
1417  * Field Enumeration Values:
1418  *
1419  * Enum | Value | Description
1420  * :-------------------------------------------|:------|:-------------------------------------------------
1421  * ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_DIS | 0x0 | Reset request interface is disabled. Logic in
1422  * : | | the FPGA fabric cannot reset the HPS.
1423  * ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_EN | 0x1 | Reset request interface is enabled. Logic in the
1424  * : | | FPGA fabric can reset the HPS.
1425  *
1426  * Field Access Macros:
1427  *
1428  */
1429 /*
1430  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF
1431  *
1432  * Reset request interface is disabled. Logic in the FPGA fabric cannot reset the
1433  * HPS.
1434  */
1435 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_DIS 0x0
1436 /*
1437  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF
1438  *
1439  * Reset request interface is enabled. Logic in the FPGA fabric can reset the HPS.
1440  */
1441 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_EN 0x1
1442
1443 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
1444 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_LSB 0
1445 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
1446 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_MSB 0
1447 /* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
1448 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_WIDTH 1
1449 /* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field value. */
1450 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_SET_MSK 0x00000001
1451 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field value. */
1452 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_CLR_MSK 0xfffffffe
1453 /* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
1454 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_RESET 0x1
1455 /* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF field value from a register. */
1456 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_GET(value) (((value) & 0x00000001) >> 0)
1457 /* Produces a ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field value suitable for setting the register. */
1458 #define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_SET(value) (((value) << 0) & 0x00000001)
1459
1460 /*
1461  * Field : JTAG Enable Interface - jtagenintf
1462  *
1463  * Used to disable the JTAG enable interface. This interface allows logic in the
1464  * FPGA fabric to disable the HPS JTAG operation.
1465  *
1466  * Field Enumeration Values:
1467  *
1468  * Enum | Value | Description
1469  * :-------------------------------------------|:------|:------------------------------------------------
1470  * ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_DIS | 0x0 | JTAG enable interface is disabled. Logic in the
1471  * : | | FPGA fabric cannot disable the HPS JTAG.
1472  * ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_EN | 0x1 | JTAG enable interface is enabled. Logic in the
1473  * : | | FPGA fabric can disable the HPS JTAG.
1474  *
1475  * Field Access Macros:
1476  *
1477  */
1478 /*
1479  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF
1480  *
1481  * JTAG enable interface is disabled. Logic in the FPGA fabric cannot disable the
1482  * HPS JTAG.
1483  */
1484 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_DIS 0x0
1485 /*
1486  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF
1487  *
1488  * JTAG enable interface is enabled. Logic in the FPGA fabric can disable the HPS
1489  * JTAG.
1490  */
1491 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_EN 0x1
1492
1493 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
1494 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_LSB 1
1495 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
1496 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_MSB 1
1497 /* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
1498 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_WIDTH 1
1499 /* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field value. */
1500 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_SET_MSK 0x00000002
1501 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field value. */
1502 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_CLR_MSK 0xfffffffd
1503 /* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
1504 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_RESET 0x1
1505 /* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF field value from a register. */
1506 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_GET(value) (((value) & 0x00000002) >> 1)
1507 /* Produces a ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field value suitable for setting the register. */
1508 #define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_SET(value) (((value) << 1) & 0x00000002)
1509
1510 /*
1511  * Field : CONFIG_IO Interface - configiointf
1512  *
1513  * Used to disable the CONFIG_IO interface. This interface allows the FPGA JTAG TAP
1514  * controller to execute the CONFIG_IO instruction and configure all device I/Os
1515  * (FPGA and HPS). This is typically done before executing boundary-scan
1516  * instructions. The CONFIG_IO interface must be enabled before attempting to send
1517  * the CONFIG_IO instruction to the FPGA JTAG TAP controller.
1518  *
1519  * Field Enumeration Values:
1520  *
1521  * Enum | Value | Description
1522  * :------------------------------------------|:------|:-------------------------------------------------
1523  * ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_DIS | 0x0 | CONFIG_IO interface is disabled. Execution of
1524  * : | | the CONFIG_IO instruction in the FPGA JTAG TAP
1525  * : | | controller is unsupported and produces undefined
1526  * : | | results.
1527  * ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_EN | 0x1 | CONFIG_IO interface is enabled. Execution of the
1528  * : | | CONFIG_IO instruction in the FPGA JTAG TAP
1529  * : | | controller is supported.
1530  *
1531  * Field Access Macros:
1532  *
1533  */
1534 /*
1535  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF
1536  *
1537  * CONFIG_IO interface is disabled. Execution of the CONFIG_IO instruction in the
1538  * FPGA JTAG TAP controller is unsupported and produces undefined results.
1539  */
1540 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_DIS 0x0
1541 /*
1542  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF
1543  *
1544  * CONFIG_IO interface is enabled. Execution of the CONFIG_IO instruction in the
1545  * FPGA JTAG TAP controller is supported.
1546  */
1547 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_EN 0x1
1548
1549 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
1550 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_LSB 2
1551 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
1552 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_MSB 2
1553 /* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
1554 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_WIDTH 1
1555 /* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field value. */
1556 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_SET_MSK 0x00000004
1557 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field value. */
1558 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_CLR_MSK 0xfffffffb
1559 /* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
1560 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_RESET 0x1
1561 /* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF field value from a register. */
1562 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_GET(value) (((value) & 0x00000004) >> 2)
1563 /* Produces a ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field value suitable for setting the register. */
1564 #define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_SET(value) (((value) << 2) & 0x00000004)
1565
1566 /*
1567  * Field : Boundary-Scan Interface - bscanintf
1568  *
1569  * Used to disable the boundary-scan interface. This interface allows the FPGA JTAG
1570  * TAP controller to execute boundary-scan instructions such as SAMPLE/PRELOAD,
1571  * EXTEST, and HIGHZ. The boundary-scan interface must be enabled before attempting
1572  * to send the boundary-scan instructions to the FPGA JTAG TAP controller.
1573  *
1574  * Field Enumeration Values:
1575  *
1576  * Enum | Value | Description
1577  * :------------------------------------------|:------|:-------------------------------------------------
1578  * ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_DIS | 0x0 | Boundary-scan interface is disabled. Execution
1579  * : | | of boundary-scan instructions in the FPGA JTAG
1580  * : | | TAP controller is unsupported and produces
1581  * : | | undefined results.
1582  * ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_EN | 0x1 | Boundary-scan interface is enabled. Execution of
1583  * : | | the boundary-scan instructions in the FPGA JTAG
1584  * : | | TAP controller is supported.
1585  *
1586  * Field Access Macros:
1587  *
1588  */
1589 /*
1590  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF
1591  *
1592  * Boundary-scan interface is disabled. Execution of boundary-scan instructions in
1593  * the FPGA JTAG TAP controller is unsupported and produces undefined results.
1594  */
1595 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_DIS 0x0
1596 /*
1597  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF
1598  *
1599  * Boundary-scan interface is enabled. Execution of the boundary-scan instructions
1600  * in the FPGA JTAG TAP controller is supported.
1601  */
1602 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_EN 0x1
1603
1604 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
1605 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_LSB 3
1606 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
1607 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_MSB 3
1608 /* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
1609 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_WIDTH 1
1610 /* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field value. */
1611 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_SET_MSK 0x00000008
1612 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field value. */
1613 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_CLR_MSK 0xfffffff7
1614 /* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
1615 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_RESET 0x1
1616 /* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF field value from a register. */
1617 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_GET(value) (((value) & 0x00000008) >> 3)
1618 /* Produces a ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field value suitable for setting the register. */
1619 #define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_SET(value) (((value) << 3) & 0x00000008)
1620
1621 /*
1622  * Field : Trace Interface - traceintf
1623  *
1624  * Used to disable the trace interface. This interface allows the HPS debug logic
1625  * to send trace data to logic in the FPGA fabric.
1626  *
1627  * Field Enumeration Values:
1628  *
1629  * Enum | Value | Description
1630  * :------------------------------------------|:------|:-----------------------------------------------
1631  * ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_DIS | 0x0 | Trace interface is disabled. HPS debug logic
1632  * : | | cannot send trace data to the FPGA fabric.
1633  * ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_EN | 0x1 | Trace interface is enabled. Other registers in
1634  * : | | the HPS debug logic must be programmmed to
1635  * : | | actually send trace data to the FPGA fabric.
1636  *
1637  * Field Access Macros:
1638  *
1639  */
1640 /*
1641  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF
1642  *
1643  * Trace interface is disabled. HPS debug logic cannot send trace data to the FPGA
1644  * fabric.
1645  */
1646 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_DIS 0x0
1647 /*
1648  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF
1649  *
1650  * Trace interface is enabled. Other registers in the HPS debug logic must be
1651  * programmmed to actually send trace data to the FPGA fabric.
1652  */
1653 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_EN 0x1
1654
1655 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
1656 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_LSB 4
1657 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
1658 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_MSB 4
1659 /* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
1660 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_WIDTH 1
1661 /* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field value. */
1662 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_SET_MSK 0x00000010
1663 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field value. */
1664 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_CLR_MSK 0xffffffef
1665 /* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
1666 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_RESET 0x1
1667 /* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF field value from a register. */
1668 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_GET(value) (((value) & 0x00000010) >> 4)
1669 /* Produces a ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field value suitable for setting the register. */
1670 #define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_SET(value) (((value) << 4) & 0x00000010)
1671
1672 /*
1673  * Field : STM Event Interface - stmeventintf
1674  *
1675  * Used to disable the STM event interface. This interface allows logic in the FPGA
1676  * fabric to trigger events to the STM debug module in the HPS.
1677  *
1678  * Field Enumeration Values:
1679  *
1680  * Enum | Value | Description
1681  * :---------------------------------------------|:------|:-----------------------------------------------
1682  * ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_DIS | 0x0 | STM event interface is disabled. Logic in the
1683  * : | | FPGA fabric cannot trigger STM events.
1684  * ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_EN | 0x1 | STM event interface is enabled. Logic in the
1685  * : | | FPGA fabric can trigger STM events.
1686  *
1687  * Field Access Macros:
1688  *
1689  */
1690 /*
1691  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF
1692  *
1693  * STM event interface is disabled. Logic in the FPGA fabric cannot trigger STM
1694  * events.
1695  */
1696 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_DIS 0x0
1697 /*
1698  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF
1699  *
1700  * STM event interface is enabled. Logic in the FPGA fabric can trigger STM
1701  * events.
1702  */
1703 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_EN 0x1
1704
1705 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
1706 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_LSB 6
1707 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
1708 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_MSB 6
1709 /* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
1710 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_WIDTH 1
1711 /* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field value. */
1712 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_SET_MSK 0x00000040
1713 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field value. */
1714 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_CLR_MSK 0xffffffbf
1715 /* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
1716 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_RESET 0x1
1717 /* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF field value from a register. */
1718 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_GET(value) (((value) & 0x00000040) >> 6)
1719 /* Produces a ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field value suitable for setting the register. */
1720 #define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_SET(value) (((value) << 6) & 0x00000040)
1721
1722 /*
1723  * Field : Cross Trigger Interface (CTI) - crosstrigintf
1724  *
1725  * Used to disable the FPGA Fabric from sending triggers to HPS debug logic. Note
1726  * that this doesn't prevent the HPS debug logic from sending triggers to the FPGA
1727  * Fabric.
1728  *
1729  * Field Enumeration Values:
1730  *
1731  * Enum | Value | Description
1732  * :----------------------------------------------|:------|:----------------------------------
1733  * ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_DIS | 0x0 | FPGA Fabric cannot send triggers.
1734  * ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_EN | 0x1 | FPGA Fabric can send triggers.
1735  *
1736  * Field Access Macros:
1737  *
1738  */
1739 /*
1740  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF
1741  *
1742  * FPGA Fabric cannot send triggers.
1743  */
1744 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_DIS 0x0
1745 /*
1746  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF
1747  *
1748  * FPGA Fabric can send triggers.
1749  */
1750 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_EN 0x1
1751
1752 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
1753 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_LSB 7
1754 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
1755 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_MSB 7
1756 /* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
1757 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_WIDTH 1
1758 /* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field value. */
1759 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_SET_MSK 0x00000080
1760 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field value. */
1761 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_CLR_MSK 0xffffff7f
1762 /* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
1763 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_RESET 0x1
1764 /* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF field value from a register. */
1765 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_GET(value) (((value) & 0x00000080) >> 7)
1766 /* Produces a ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field value suitable for setting the register. */
1767 #define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_SET(value) (((value) << 7) & 0x00000080)
1768
1769 #ifndef __ASSEMBLY__
1770 /*
1771  * WARNING: The C register and register group struct declarations are provided for
1772  * convenience and illustrative purposes. They should, however, be used with
1773  * caution as the C language standard provides no guarantees about the alignment or
1774  * atomicity of device memory accesses. The recommended practice for writing
1775  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1776  * alt_write_word() functions.
1777  *
1778  * The struct declaration for register ALT_SYSMGR_FPGAINTF_INDIV.
1779  */
1781 {
1782  uint32_t rstreqintf : 1; /* Reset Request Interface */
1783  uint32_t jtagenintf : 1; /* JTAG Enable Interface */
1784  uint32_t configiointf : 1; /* CONFIG_IO Interface */
1785  uint32_t bscanintf : 1; /* Boundary-Scan Interface */
1786  uint32_t traceintf : 1; /* Trace Interface */
1787  uint32_t : 1; /* *UNDEFINED* */
1788  uint32_t stmeventintf : 1; /* STM Event Interface */
1789  uint32_t crosstrigintf : 1; /* Cross Trigger Interface (CTI) */
1790  uint32_t : 24; /* *UNDEFINED* */
1791 };
1792
1793 /* The typedef declaration for register ALT_SYSMGR_FPGAINTF_INDIV. */
1794 typedef volatile struct ALT_SYSMGR_FPGAINTF_INDIV_s ALT_SYSMGR_FPGAINTF_INDIV_t;
1795 #endif /* __ASSEMBLY__ */
1796
1797 /* The byte offset of the ALT_SYSMGR_FPGAINTF_INDIV register from the beginning of the component. */
1798 #define ALT_SYSMGR_FPGAINTF_INDIV_OFST 0x4
1799
1800 /*
1801  * Register : Module Disable Register - module
1802  *
1803  * Used to disable signals from the FPGA fabric to individual HPS modules.
1804  *
1805  * Register Layout
1806  *
1807  * Bits | Access | Reset | Description
1808  * :-------|:-------|:------|:------------
1809  * [1:0] | ??? | 0x0 | *UNDEFINED*
1810  * [2] | RW | 0x0 | EMAC Module
1811  * [3] | RW | 0x0 | EMAC Module
1812  * [31:4] | ??? | 0x0 | *UNDEFINED*
1813  *
1814  */
1815 /*
1816  * Field : EMAC Module - emac_0
1817  *
1818  * Used to disable signals from the FPGA fabric to the EMAC modules that could
1819  * potentially interfere with their normal operation.
1820  *
1821  * The array index corresponds to the EMAC module instance.
1822  *
1823  * Field Enumeration Values:
1824  *
1825  * Enum | Value | Description
1826  * :----------------------------------------|:------|:-------------------------------------------------
1827  * ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_DIS | 0x0 | Signals from FPGA fabric cannot affect operation
1828  * : | | of the EMAC module.
1829  * ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_EN | 0x1 | Signals from FPGA fabric can potentially affect
1830  * : | | operation of the EMAC module.
1831  *
1832  * Field Access Macros:
1833  *
1834  */
1835 /*
1836  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0
1837  *
1838  * Signals from FPGA fabric cannot affect operation of the EMAC module.
1839  */
1840 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_DIS 0x0
1841 /*
1842  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0
1843  *
1844  * Signals from FPGA fabric can potentially affect operation of the EMAC module.
1845  */
1846 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_EN 0x1
1847
1848 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
1849 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_LSB 2
1850 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
1851 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_MSB 2
1852 /* The width in bits of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
1853 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_WIDTH 1
1854 /* The mask used to set the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field value. */
1855 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_SET_MSK 0x00000004
1856 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field value. */
1857 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_CLR_MSK 0xfffffffb
1858 /* The reset value of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
1859 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_RESET 0x0
1860 /* Extracts the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 field value from a register. */
1861 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_GET(value) (((value) & 0x00000004) >> 2)
1862 /* Produces a ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field value suitable for setting the register. */
1863 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_SET(value) (((value) << 2) & 0x00000004)
1864
1865 /*
1866  * Field : EMAC Module - emac_1
1867  *
1868  * Used to disable signals from the FPGA fabric to the EMAC modules that could
1869  * potentially interfere with their normal operation.
1870  *
1871  * The array index corresponds to the EMAC module instance.
1872  *
1873  * Field Enumeration Values:
1874  *
1875  * Enum | Value | Description
1876  * :----------------------------------------|:------|:-------------------------------------------------
1877  * ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_DIS | 0x0 | Signals from FPGA fabric cannot affect operation
1878  * : | | of the EMAC module.
1879  * ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_EN | 0x1 | Signals from FPGA fabric can potentially affect
1880  * : | | operation of the EMAC module.
1881  *
1882  * Field Access Macros:
1883  *
1884  */
1885 /*
1886  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1
1887  *
1888  * Signals from FPGA fabric cannot affect operation of the EMAC module.
1889  */
1890 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_DIS 0x0
1891 /*
1892  * Enumerated value for register field ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1
1893  *
1894  * Signals from FPGA fabric can potentially affect operation of the EMAC module.
1895  */
1896 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_EN 0x1
1897
1898 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
1899 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_LSB 3
1900 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
1901 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_MSB 3
1902 /* The width in bits of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
1903 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_WIDTH 1
1904 /* The mask used to set the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field value. */
1905 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_SET_MSK 0x00000008
1906 /* The mask used to clear the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field value. */
1907 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_CLR_MSK 0xfffffff7
1908 /* The reset value of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
1909 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_RESET 0x0
1910 /* Extracts the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 field value from a register. */
1911 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_GET(value) (((value) & 0x00000008) >> 3)
1912 /* Produces a ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field value suitable for setting the register. */
1913 #define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_SET(value) (((value) << 3) & 0x00000008)
1914
1915 #ifndef __ASSEMBLY__
1916 /*
1917  * WARNING: The C register and register group struct declarations are provided for
1918  * convenience and illustrative purposes. They should, however, be used with
1919  * caution as the C language standard provides no guarantees about the alignment or
1920  * atomicity of device memory accesses. The recommended practice for writing
1921  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1922  * alt_write_word() functions.
1923  *
1924  * The struct declaration for register ALT_SYSMGR_FPGAINTF_MODULE.
1925  */
1927 {
1928  uint32_t : 2; /* *UNDEFINED* */
1929  uint32_t emac_0 : 1; /* EMAC Module */
1930  uint32_t emac_1 : 1; /* EMAC Module */
1931  uint32_t : 28; /* *UNDEFINED* */
1932 };
1933
1934 /* The typedef declaration for register ALT_SYSMGR_FPGAINTF_MODULE. */
1935 typedef volatile struct ALT_SYSMGR_FPGAINTF_MODULE_s ALT_SYSMGR_FPGAINTF_MODULE_t;
1936 #endif /* __ASSEMBLY__ */
1937
1938 /* The byte offset of the ALT_SYSMGR_FPGAINTF_MODULE register from the beginning of the component. */
1939 #define ALT_SYSMGR_FPGAINTF_MODULE_OFST 0x8
1940
1941 #ifndef __ASSEMBLY__
1942 /*
1943  * WARNING: The C register and register group struct declarations are provided for
1944  * convenience and illustrative purposes. They should, however, be used with
1945  * caution as the C language standard provides no guarantees about the alignment or
1946  * atomicity of device memory accesses. The recommended practice for writing
1947  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1948  * alt_write_word() functions.
1949  *
1950  * The struct declaration for register group ALT_SYSMGR_FPGAINTF.
1951  */
1953 {
1954  volatile ALT_SYSMGR_FPGAINTF_GBL_t gbl; /* ALT_SYSMGR_FPGAINTF_GBL */
1955  volatile ALT_SYSMGR_FPGAINTF_INDIV_t indiv; /* ALT_SYSMGR_FPGAINTF_INDIV */
1956  volatile ALT_SYSMGR_FPGAINTF_MODULE_t module; /* ALT_SYSMGR_FPGAINTF_MODULE */
1957  volatile uint32_t _pad_0xc_0x10; /* *UNDEFINED* */
1958 };
1959
1960 /* The typedef declaration for register group ALT_SYSMGR_FPGAINTF. */
1961 typedef volatile struct ALT_SYSMGR_FPGAINTF_s ALT_SYSMGR_FPGAINTF_t;
1962 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_FPGAINTF. */
1964 {
1965  volatile uint32_t gbl; /* ALT_SYSMGR_FPGAINTF_GBL */
1966  volatile uint32_t indiv; /* ALT_SYSMGR_FPGAINTF_INDIV */
1967  volatile uint32_t module; /* ALT_SYSMGR_FPGAINTF_MODULE */
1968  volatile uint32_t _pad_0xc_0x10; /* *UNDEFINED* */
1969 };
1970
1971 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_FPGAINTF. */
1972 typedef volatile struct ALT_SYSMGR_FPGAINTF_raw_s ALT_SYSMGR_FPGAINTF_raw_t;
1973 #endif /* __ASSEMBLY__ */
1974
1975
1976 /*
1977  * Register Group : Scan Manager Group - ALT_SYSMGR_SCANMGR
1978  * Scan Manager Group
1979  *
1980  * Registers related to the Scan Manager that aren't located inside the Scan
1981  * Manager itself.
1982  *
1983  */
1984 /*
1985  * Register : Scan Manager Control Register - ctrl
1986  *
1987  * Controls behaviors of Scan Manager not controlled by registers in the Scan
1988  * Manager itself.
1989  *
1990  * Register Layout
1991  *
1992  * Bits | Access | Reset | Description
1993  * :-------|:-------|:------|:-----------------
1994  * [0] | RW | 0x0 | FPGA JTAG Enable
1995  * [31:1] | ??? | 0x0 | *UNDEFINED*
1996  *
1997  */
1998 /*
1999  * Field : FPGA JTAG Enable - fpgajtagen
2000  *
2001  * Controls whether FPGA JTAG pins or Scan Manager drives JTAG signals to the FPGA.
2002  *
2003  * Only reset by a cold reset (ignores warm reset).
2004  *
2005  * Field Enumeration Values:
2006  *
2007  * Enum | Value | Description
2008  * :---------------------------------------------|:------|:------------------------------------------
2009  * ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_FPGAPINS | 0x0 | FPGA JTAG pins drive JTAG signals to FPGA
2010  * ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_SCANMGR | 0x1 | Scan Manager drives JTAG signals to FPGA
2011  *
2012  * Field Access Macros:
2013  *
2014  */
2015 /*
2016  * Enumerated value for register field ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN
2017  *
2018  * FPGA JTAG pins drive JTAG signals to FPGA
2019  */
2020 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_FPGAPINS 0x0
2021 /*
2022  * Enumerated value for register field ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN
2023  *
2024  * Scan Manager drives JTAG signals to FPGA
2025  */
2026 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_SCANMGR 0x1
2027
2028 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
2029 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_LSB 0
2030 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
2031 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_MSB 0
2032 /* The width in bits of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
2033 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_WIDTH 1
2034 /* The mask used to set the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field value. */
2035 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_SET_MSK 0x00000001
2036 /* The mask used to clear the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field value. */
2037 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_CLR_MSK 0xfffffffe
2038 /* The reset value of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
2039 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_RESET 0x0
2040 /* Extracts the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN field value from a register. */
2041 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_GET(value) (((value) & 0x00000001) >> 0)
2042 /* Produces a ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field value suitable for setting the register. */
2043 #define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_SET(value) (((value) << 0) & 0x00000001)
2044
2045 #ifndef __ASSEMBLY__
2046 /*
2047  * WARNING: The C register and register group struct declarations are provided for
2048  * convenience and illustrative purposes. They should, however, be used with
2049  * caution as the C language standard provides no guarantees about the alignment or
2050  * atomicity of device memory accesses. The recommended practice for writing
2051  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2052  * alt_write_word() functions.
2053  *
2054  * The struct declaration for register ALT_SYSMGR_SCANMGR_CTL.
2055  */
2057 {
2058  uint32_t fpgajtagen : 1; /* FPGA JTAG Enable */
2059  uint32_t : 31; /* *UNDEFINED* */
2060 };
2061
2062 /* The typedef declaration for register ALT_SYSMGR_SCANMGR_CTL. */
2063 typedef volatile struct ALT_SYSMGR_SCANMGR_CTL_s ALT_SYSMGR_SCANMGR_CTL_t;
2064 #endif /* __ASSEMBLY__ */
2065
2066 /* The byte offset of the ALT_SYSMGR_SCANMGR_CTL register from the beginning of the component. */
2067 #define ALT_SYSMGR_SCANMGR_CTL_OFST 0x0
2068
2069 #ifndef __ASSEMBLY__
2070 /*
2071  * WARNING: The C register and register group struct declarations are provided for
2072  * convenience and illustrative purposes. They should, however, be used with
2073  * caution as the C language standard provides no guarantees about the alignment or
2074  * atomicity of device memory accesses. The recommended practice for writing
2075  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2076  * alt_write_word() functions.
2077  *
2078  * The struct declaration for register group ALT_SYSMGR_SCANMGR.
2079  */
2081 {
2082  volatile ALT_SYSMGR_SCANMGR_CTL_t ctrl; /* ALT_SYSMGR_SCANMGR_CTL */
2083 };
2084
2085 /* The typedef declaration for register group ALT_SYSMGR_SCANMGR. */
2086 typedef volatile struct ALT_SYSMGR_SCANMGR_s ALT_SYSMGR_SCANMGR_t;
2087 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_SCANMGR. */
2089 {
2090  volatile uint32_t ctrl; /* ALT_SYSMGR_SCANMGR_CTL */
2091 };
2092
2093 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_SCANMGR. */
2094 typedef volatile struct ALT_SYSMGR_SCANMGR_raw_s ALT_SYSMGR_SCANMGR_raw_t;
2095 #endif /* __ASSEMBLY__ */
2096
2097
2098 /*
2099  * Register Group : Freeze Control Group - ALT_SYSMGR_FRZCTL
2100  * Freeze Control Group
2101  *
2102  * Registers used to generate HPS IO freeze signals.
2103  *
2104  * All registers are only reset by a cold reset (ignore warm reset).
2105  *
2106  */
2107 /*
2108  * Register : VIO Control Register - vioctrl
2109  *
2110  * Used to drive freeze signals to HPS VIO banks.
2111  *
2112  * The register array index corresponds to the freeze channel.
2113  *
2114  * Freeze channel 0 provides freeze signals to VIO bank 0 and 1.
2115  *
2116  * Freeze channel 1 provides freeze signals to VIO bank 2 and 3. Only drives freeze
2117  * signals when SRC.VIO1 is set to SW.
2118  *
2119  * Freeze channel 2 provides freeze signals to VIO bank 4.
2120  *
2121  * All fields are only reset by a cold reset (ignore warm reset).
2122  *
2123  * The following equation determines when the weak pullup resistor is enabled:
2124  *
2125  * enabled = ~wkpullup | (CFF & cfg & tristate)
2126  *
2127  * where CFF is the value of weak pullup as set by IO configuration
2128  *
2129  * Register Layout
2130  *
2131  * Bits | Access | Reset | Description
2132  * :-------|:-------|:------|:-----------------
2133  * [0] | RW | 0x0 | IO Configuration
2134  * [1] | RW | 0x0 | IO Bus Hold
2135  * [2] | RW | 0x0 | IO Tri-State
2136  * [3] | RW | 0x0 | IO Weak Pullup
2137  * [4] | RW | 0x0 | IO Slew-rate
2138  * [31:5] | ??? | 0x0 | *UNDEFINED*
2139  *
2140  */
2141 /*
2142  * Field : IO Configuration - cfg
2143  *
2144  * Controls IO configuration
2145  *
2146  * Field Enumeration Values:
2147  *
2148  * Enum | Value | Description
2149  * :-----------------------------------|:------|:-----------------------------------------------
2150  * ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_DIS | 0x0 | Disable IO configuration (forced to a safe
2151  * : | | value).
2152  * ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_CFG | 0x1 | Enables IO configuration as previously
2153  * : | | configured by software using the Scan Manager.
2154  *
2155  * Field Access Macros:
2156  *
2157  */
2158 /*
2159  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_CFG
2160  *
2161  * Disable IO configuration (forced to a safe value).
2162  */
2163 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_DIS 0x0
2164 /*
2165  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_CFG
2166  *
2167  * Enables IO configuration as previously configured by software using the Scan
2168  * Manager.
2169  */
2170 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_CFG 0x1
2171
2172 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
2173 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_LSB 0
2174 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
2175 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_MSB 0
2176 /* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
2177 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_WIDTH 1
2178 /* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field value. */
2179 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_SET_MSK 0x00000001
2180 /* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field value. */
2181 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_CLR_MSK 0xfffffffe
2182 /* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
2183 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_RESET 0x0
2184 /* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_CFG field value from a register. */
2185 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_GET(value) (((value) & 0x00000001) >> 0)
2186 /* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field value suitable for setting the register. */
2187 #define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_SET(value) (((value) << 0) & 0x00000001)
2188
2189 /*
2190  * Field : IO Bus Hold - bushold
2191  *
2192  * Controls bus hold circuit
2193  *
2194  * Field Enumeration Values:
2195  *
2196  * Enum | Value | Description
2197  * :---------------------------------------|:------|:-------------------------------------------------
2198  * ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_DIS | 0x0 | Disable bus hold circuit.
2199  * ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_CFG | 0x1 | Bus hold circuit controlled by IO configuration.
2200  *
2201  * Field Access Macros:
2202  *
2203  */
2204 /*
2205  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD
2206  *
2207  * Disable bus hold circuit.
2208  */
2209 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_DIS 0x0
2210 /*
2211  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD
2212  *
2213  * Bus hold circuit controlled by IO configuration.
2214  */
2215 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_CFG 0x1
2216
2217 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
2218 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_LSB 1
2219 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
2220 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_MSB 1
2221 /* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
2222 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_WIDTH 1
2223 /* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field value. */
2224 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_SET_MSK 0x00000002
2225 /* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field value. */
2226 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_CLR_MSK 0xfffffffd
2227 /* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
2228 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_RESET 0x0
2229 /* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD field value from a register. */
2230 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_GET(value) (((value) & 0x00000002) >> 1)
2231 /* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field value suitable for setting the register. */
2232 #define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_SET(value) (((value) << 1) & 0x00000002)
2233
2234 /*
2235  * Field : IO Tri-State - tristate
2236  *
2237  * Controls IO tri-state
2238  *
2239  * Field Enumeration Values:
2240  *
2241  * Enum | Value | Description
2242  * :----------------------------------------|:------|:---------------------------------------------
2243  * ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_EN | 0x0 | IO tri-state enabled.
2244  * ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_CFG | 0x1 | IO tri-state controlled by IO configuration.
2245  *
2246  * Field Access Macros:
2247  *
2248  */
2249 /*
2250  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE
2251  *
2252  * IO tri-state enabled.
2253  */
2254 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_EN 0x0
2255 /*
2256  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE
2257  *
2258  * IO tri-state controlled by IO configuration.
2259  */
2260 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_CFG 0x1
2261
2262 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
2263 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_LSB 2
2264 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
2265 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_MSB 2
2266 /* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
2267 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_WIDTH 1
2268 /* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field value. */
2269 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_SET_MSK 0x00000004
2270 /* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field value. */
2271 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_CLR_MSK 0xfffffffb
2272 /* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
2273 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_RESET 0x0
2274 /* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE field value from a register. */
2275 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_GET(value) (((value) & 0x00000004) >> 2)
2276 /* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field value suitable for setting the register. */
2277 #define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_SET(value) (((value) << 2) & 0x00000004)
2278
2279 /*
2280  * Field : IO Weak Pullup - wkpullup
2281  *
2282  * Controls weak pullup resistor
2283  *
2284  * Field Enumeration Values:
2285  *
2286  * Enum | Value | Description
2287  * :----------------------------------------|:------|:---------------------------------------------
2288  * ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_EN | 0x0 | Weak pullup resistor enabled.
2289  * ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_CFG | 0x1 | Weak pullup resistor enable controlled by IO
2290  * : | | configuration.
2291  *
2292  * Field Access Macros:
2293  *
2294  */
2295 /*
2296  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP
2297  *
2298  * Weak pullup resistor enabled.
2299  */
2300 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_EN 0x0
2301 /*
2302  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP
2303  *
2304  * Weak pullup resistor enable controlled by IO configuration.
2305  */
2306 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_CFG 0x1
2307
2308 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
2309 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_LSB 3
2310 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
2311 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_MSB 3
2312 /* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
2313 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_WIDTH 1
2314 /* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field value. */
2315 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_SET_MSK 0x00000008
2316 /* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field value. */
2317 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_CLR_MSK 0xfffffff7
2318 /* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
2319 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_RESET 0x0
2320 /* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP field value from a register. */
2321 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_GET(value) (((value) & 0x00000008) >> 3)
2322 /* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field value suitable for setting the register. */
2323 #define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_SET(value) (((value) << 3) & 0x00000008)
2324
2325 /*
2326  * Field : IO Slew-rate - slew
2327  *
2328  * Controls IO slew-rate
2329  *
2330  * Field Enumeration Values:
2331  *
2332  * Enum | Value | Description
2333  * :-------------------------------------|:------|:------------------------------------------
2334  * ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_SLOW | 0x0 | Slew-rate forced to slow.
2335  * ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_CFG | 0x1 | Slew-rate controlled by IO configuration.
2336  *
2337  * Field Access Macros:
2338  *
2339  */
2340 /*
2341  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_SLEW
2342  *
2343  * Slew-rate forced to slow.
2344  */
2345 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_SLOW 0x0
2346 /*
2347  * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_SLEW
2348  *
2349  * Slew-rate controlled by IO configuration.
2350  */
2351 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_CFG 0x1
2352
2353 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
2354 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_LSB 4
2355 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
2356 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_MSB 4
2357 /* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
2358 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_WIDTH 1
2359 /* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field value. */
2360 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_SET_MSK 0x00000010
2361 /* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field value. */
2362 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_CLR_MSK 0xffffffef
2363 /* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
2364 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_RESET 0x0
2365 /* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW field value from a register. */
2366 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_GET(value) (((value) & 0x00000010) >> 4)
2367 /* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field value suitable for setting the register. */
2368 #define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_SET(value) (((value) << 4) & 0x00000010)
2369
2370 #ifndef __ASSEMBLY__
2371 /*
2372  * WARNING: The C register and register group struct declarations are provided for
2373  * convenience and illustrative purposes. They should, however, be used with
2374  * caution as the C language standard provides no guarantees about the alignment or
2375  * atomicity of device memory accesses. The recommended practice for writing
2376  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2377  * alt_write_word() functions.
2378  *
2379  * The struct declaration for register ALT_SYSMGR_FRZCTL_VIOCTL.
2380  */
2382 {
2383  uint32_t cfg : 1; /* IO Configuration */
2384  uint32_t bushold : 1; /* IO Bus Hold */
2385  uint32_t tristate : 1; /* IO Tri-State */
2386  uint32_t wkpullup : 1; /* IO Weak Pullup */
2387  uint32_t slew : 1; /* IO Slew-rate */
2388  uint32_t : 27; /* *UNDEFINED* */
2389 };
2390
2391 /* The typedef declaration for register ALT_SYSMGR_FRZCTL_VIOCTL. */
2392 typedef volatile struct ALT_SYSMGR_FRZCTL_VIOCTL_s ALT_SYSMGR_FRZCTL_VIOCTL_t;
2393 #endif /* __ASSEMBLY__ */
2394
2395 /* The byte offset of the ALT_SYSMGR_FRZCTL_VIOCTL register from the beginning of the component. */
2396 #define ALT_SYSMGR_FRZCTL_VIOCTL_OFST 0x0
2397
2398 /*
2399  * Register : HIO Control Register - hioctrl
2400  *
2401  * Used to drive freeze signals to HPS HIO bank (DDR SDRAM).
2402  *
2403  * All fields are only reset by a cold reset (ignore warm reset).
2404  *
2405  * The following equation determines when the weak pullup resistor is enabled:
2406  *
2407  * enabled = ~wkpullup | (CFF & cfg & tristate)
2408  *
2409  * where CFF is the value of weak pullup as set by IO configuration
2410  *
2411  * Register Layout
2412  *
2413  * Bits | Access | Reset | Description
2414  * :-------|:-------|:------|:-----------------------------------------
2415  * [0] | RW | 0x0 | IO Configuration
2416  * [1] | RW | 0x0 | IO Bus Hold
2417  * [2] | RW | 0x0 | IO Tri-State
2418  * [3] | RW | 0x0 | IO Weak Pullup
2419  * [4] | RW | 0x0 | IO Slew-rate
2420  * [5] | RW | 0x1 | DLL Reset
2421  * [6] | RW | 0x1 | OCT Reset
2422  * [7] | RW | 0x1 | IO and DQS Reset
2423  * [8] | RW | 0x0 | OCT Calibration and Configuration Enable
2424  * [31:9] | ??? | 0x0 | *UNDEFINED*
2425  *
2426  */
2427 /*
2428  * Field : IO Configuration - cfg
2429  *
2430  * Controls IO configuration
2431  *
2432  * Field Enumeration Values:
2433  *
2434  * Enum | Value | Description
2435  * :-----------------------------------|:------|:-----------------------------------------------
2436  * ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_DIS | 0x0 | Disable IO configuration (forced to a safe
2437  * : | | value).
2438  * ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_CFG | 0x1 | Enables IO configuration as previously
2439  * : | | configured by software using the Scan Manager.
2440  *
2441  * Field Access Macros:
2442  *
2443  */
2444 /*
2445  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_CFG
2446  *
2447  * Disable IO configuration (forced to a safe value).
2448  */
2449 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_DIS 0x0
2450 /*
2451  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_CFG
2452  *
2453  * Enables IO configuration as previously configured by software using the Scan
2454  * Manager.
2455  */
2456 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_CFG 0x1
2457
2458 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
2459 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_LSB 0
2460 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
2461 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_MSB 0
2462 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
2463 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_WIDTH 1
2464 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field value. */
2465 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_SET_MSK 0x00000001
2466 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field value. */
2467 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_CLR_MSK 0xfffffffe
2468 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
2469 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_RESET 0x0
2470 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_CFG field value from a register. */
2471 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_GET(value) (((value) & 0x00000001) >> 0)
2472 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field value suitable for setting the register. */
2473 #define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_SET(value) (((value) << 0) & 0x00000001)
2474
2475 /*
2476  * Field : IO Bus Hold - bushold
2477  *
2478  * Controls bus hold circuit
2479  *
2480  * Field Enumeration Values:
2481  *
2482  * Enum | Value | Description
2483  * :---------------------------------------|:------|:-------------------------------------------------
2484  * ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_DIS | 0x0 | Disable bus hold circuit.
2485  * ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_CFG | 0x1 | Bus hold circuit controlled by IO configuration.
2486  *
2487  * Field Access Macros:
2488  *
2489  */
2490 /*
2491  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD
2492  *
2493  * Disable bus hold circuit.
2494  */
2495 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_DIS 0x0
2496 /*
2497  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD
2498  *
2499  * Bus hold circuit controlled by IO configuration.
2500  */
2501 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_CFG 0x1
2502
2503 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
2504 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_LSB 1
2505 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
2506 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_MSB 1
2507 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
2508 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_WIDTH 1
2509 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field value. */
2510 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_SET_MSK 0x00000002
2511 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field value. */
2512 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_CLR_MSK 0xfffffffd
2513 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
2514 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_RESET 0x0
2515 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD field value from a register. */
2516 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_GET(value) (((value) & 0x00000002) >> 1)
2517 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field value suitable for setting the register. */
2518 #define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_SET(value) (((value) << 1) & 0x00000002)
2519
2520 /*
2521  * Field : IO Tri-State - tristate
2522  *
2523  * Controls IO tri-state
2524  *
2525  * Field Enumeration Values:
2526  *
2527  * Enum | Value | Description
2528  * :----------------------------------------|:------|:---------------------------------------------
2529  * ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_EN | 0x0 | IO tri-state enabled.
2530  * ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_CFG | 0x1 | IO tri-state controlled by IO configuration.
2531  *
2532  * Field Access Macros:
2533  *
2534  */
2535 /*
2536  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE
2537  *
2538  * IO tri-state enabled.
2539  */
2540 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_EN 0x0
2541 /*
2542  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE
2543  *
2544  * IO tri-state controlled by IO configuration.
2545  */
2546 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_CFG 0x1
2547
2548 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
2549 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_LSB 2
2550 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
2551 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_MSB 2
2552 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
2553 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_WIDTH 1
2554 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field value. */
2555 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_SET_MSK 0x00000004
2556 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field value. */
2557 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_CLR_MSK 0xfffffffb
2558 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
2559 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_RESET 0x0
2560 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE field value from a register. */
2561 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_GET(value) (((value) & 0x00000004) >> 2)
2562 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field value suitable for setting the register. */
2563 #define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_SET(value) (((value) << 2) & 0x00000004)
2564
2565 /*
2566  * Field : IO Weak Pullup - wkpullup
2567  *
2568  * Controls weak pullup resistor
2569  *
2570  * Field Enumeration Values:
2571  *
2572  * Enum | Value | Description
2573  * :----------------------------------------|:------|:---------------------------------------------
2574  * ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_EN | 0x0 | Weak pullup resistor enabled.
2575  * ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_CFG | 0x1 | Weak pullup resistor enable controlled by IO
2576  * : | | configuration.
2577  *
2578  * Field Access Macros:
2579  *
2580  */
2581 /*
2582  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP
2583  *
2584  * Weak pullup resistor enabled.
2585  */
2586 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_EN 0x0
2587 /*
2588  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP
2589  *
2590  * Weak pullup resistor enable controlled by IO configuration.
2591  */
2592 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_CFG 0x1
2593
2594 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
2595 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_LSB 3
2596 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
2597 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_MSB 3
2598 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
2599 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_WIDTH 1
2600 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field value. */
2601 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_SET_MSK 0x00000008
2602 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field value. */
2603 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_CLR_MSK 0xfffffff7
2604 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
2605 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_RESET 0x0
2606 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP field value from a register. */
2607 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_GET(value) (((value) & 0x00000008) >> 3)
2608 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field value suitable for setting the register. */
2609 #define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_SET(value) (((value) << 3) & 0x00000008)
2610
2611 /*
2612  * Field : IO Slew-rate - slew
2613  *
2614  * Controls IO slew-rate
2615  *
2616  * Field Enumeration Values:
2617  *
2618  * Enum | Value | Description
2619  * :-------------------------------------|:------|:------------------------------------------
2620  * ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_SLOW | 0x0 | Slew-rate forced to slow.
2621  * ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_CFG | 0x1 | Slew-rate controlled by IO configuration.
2622  *
2623  * Field Access Macros:
2624  *
2625  */
2626 /*
2627  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_SLEW
2628  *
2629  * Slew-rate forced to slow.
2630  */
2631 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_SLOW 0x0
2632 /*
2633  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_SLEW
2634  *
2635  * Slew-rate controlled by IO configuration.
2636  */
2637 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_CFG 0x1
2638
2639 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
2640 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_LSB 4
2641 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
2642 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_MSB 4
2643 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
2644 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_WIDTH 1
2645 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field value. */
2646 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_SET_MSK 0x00000010
2647 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field value. */
2648 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_CLR_MSK 0xffffffef
2649 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
2650 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_RESET 0x0
2651 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW field value from a register. */
2652 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_GET(value) (((value) & 0x00000010) >> 4)
2653 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field value suitable for setting the register. */
2654 #define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_SET(value) (((value) << 4) & 0x00000010)
2655
2656 /*
2657  * Field : DLL Reset - dllrst
2658  *
2659  * Controls DLL (Delay-Locked Loop) reset.
2660  *
2661  * Field Enumeration Values:
2662  *
2663  * Enum | Value | Description
2664  * :--------------------------------------|:------|:----------------------------------------------
2665  * ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_DIS | 0x0 | No reset or clock gating.
2666  * ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_EN | 0x1 | Resets registers in the DLL and gates off DLL
2667  * : | | clock.
2668  *
2669  * Field Access Macros:
2670  *
2671  */
2672 /*
2673  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST
2674  *
2675  * No reset or clock gating.
2676  */
2677 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_DIS 0x0
2678 /*
2679  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST
2680  *
2681  * Resets registers in the DLL and gates off DLL clock.
2682  */
2683 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_EN 0x1
2684
2685 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
2686 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_LSB 5
2687 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
2688 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_MSB 5
2689 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
2690 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_WIDTH 1
2691 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field value. */
2692 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_SET_MSK 0x00000020
2693 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field value. */
2694 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_CLR_MSK 0xffffffdf
2695 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
2696 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_RESET 0x1
2697 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST field value from a register. */
2698 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_GET(value) (((value) & 0x00000020) >> 5)
2699 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field value suitable for setting the register. */
2700 #define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_SET(value) (((value) << 5) & 0x00000020)
2701
2702 /*
2703  * Field : OCT Reset - octrst
2704  *
2705  * Controls OCT reset.
2706  *
2707  * Field Enumeration Values:
2708  *
2709  * Enum | Value | Description
2710  * :--------------------------------------|:------|:-----------------------------
2711  * ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_DIS | 0x0 | No reset.
2712  * ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_EN | 0x1 | Resets registers in the OCT.
2713  *
2714  * Field Access Macros:
2715  *
2716  */
2717 /*
2718  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST
2719  *
2720  * No reset.
2721  */
2722 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_DIS 0x0
2723 /*
2724  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST
2725  *
2726  * Resets registers in the OCT.
2727  */
2728 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_EN 0x1
2729
2730 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
2731 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_LSB 6
2732 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
2733 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_MSB 6
2734 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
2735 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_WIDTH 1
2736 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field value. */
2737 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_SET_MSK 0x00000040
2738 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field value. */
2739 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_CLR_MSK 0xffffffbf
2740 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
2741 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_RESET 0x1
2742 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST field value from a register. */
2743 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_GET(value) (((value) & 0x00000040) >> 6)
2744 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field value suitable for setting the register. */
2745 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_SET(value) (((value) << 6) & 0x00000040)
2746
2747 /*
2748  * Field : IO and DQS Reset - regrst
2749  *
2750  * Controls IO and DQS reset.
2751  *
2752  * Field Enumeration Values:
2753  *
2754  * Enum | Value | Description
2755  * :--------------------------------------|:------|:-------------------------------------------
2756  * ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_DIS | 0x0 | No reset.
2757  * ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_EN | 0x1 | Resets all IO registers and DQS registers.
2758  *
2759  * Field Access Macros:
2760  *
2761  */
2762 /*
2763  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_REGRST
2764  *
2765  * No reset.
2766  */
2767 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_DIS 0x0
2768 /*
2769  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_REGRST
2770  *
2771  * Resets all IO registers and DQS registers.
2772  */
2773 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_EN 0x1
2774
2775 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
2776 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_LSB 7
2777 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
2778 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_MSB 7
2779 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
2780 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_WIDTH 1
2781 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field value. */
2782 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_SET_MSK 0x00000080
2783 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field value. */
2784 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_CLR_MSK 0xffffff7f
2785 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
2786 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_RESET 0x1
2787 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST field value from a register. */
2788 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_GET(value) (((value) & 0x00000080) >> 7)
2789 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field value suitable for setting the register. */
2790 #define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_SET(value) (((value) << 7) & 0x00000080)
2791
2792 /*
2793  * Field : OCT Calibration and Configuration Enable - oct_cfgen_calstart
2794  *
2795  * Controls OCT calibration and OCT IO configuration enable.
2796  *
2797  * Field Enumeration Values:
2798  *
2799  * Enum | Value | Description
2800  * :--------------------------------------------------|:------|:-------------------------------------------------
2801  * ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_DIS | 0x0 | Disables IO configuration (forced to a safe
2802  * : | | value) in OCT calibration block.
2803  * ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_EN | 0x1 | Starts OCT calibration state machine and enables
2804  * : | | IO configuration in OCT calibration block.
2805  *
2806  * Field Access Macros:
2807  *
2808  */
2809 /*
2810  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART
2811  *
2812  * Disables IO configuration (forced to a safe value) in OCT calibration block.
2813  */
2814 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_DIS 0x0
2815 /*
2816  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART
2817  *
2818  * Starts OCT calibration state machine and enables IO configuration in OCT
2819  * calibration block.
2820  */
2821 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_EN 0x1
2822
2823 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
2824 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_LSB 8
2825 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
2826 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_MSB 8
2827 /* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
2828 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_WIDTH 1
2829 /* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field value. */
2830 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_SET_MSK 0x00000100
2831 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field value. */
2832 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_CLR_MSK 0xfffffeff
2833 /* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
2834 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_RESET 0x0
2835 /* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART field value from a register. */
2836 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_GET(value) (((value) & 0x00000100) >> 8)
2837 /* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field value suitable for setting the register. */
2838 #define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_SET(value) (((value) << 8) & 0x00000100)
2839
2840 #ifndef __ASSEMBLY__
2841 /*
2842  * WARNING: The C register and register group struct declarations are provided for
2843  * convenience and illustrative purposes. They should, however, be used with
2844  * caution as the C language standard provides no guarantees about the alignment or
2845  * atomicity of device memory accesses. The recommended practice for writing
2846  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2847  * alt_write_word() functions.
2848  *
2849  * The struct declaration for register ALT_SYSMGR_FRZCTL_HIOCTL.
2850  */
2852 {
2853  uint32_t cfg : 1; /* IO Configuration */
2854  uint32_t bushold : 1; /* IO Bus Hold */
2855  uint32_t tristate : 1; /* IO Tri-State */
2856  uint32_t wkpullup : 1; /* IO Weak Pullup */
2857  uint32_t slew : 1; /* IO Slew-rate */
2858  uint32_t dllrst : 1; /* DLL Reset */
2859  uint32_t octrst : 1; /* OCT Reset */
2860  uint32_t regrst : 1; /* IO and DQS Reset */
2861  uint32_t oct_cfgen_calstart : 1; /* OCT Calibration and Configuration Enable */
2862  uint32_t : 23; /* *UNDEFINED* */
2863 };
2864
2865 /* The typedef declaration for register ALT_SYSMGR_FRZCTL_HIOCTL. */
2866 typedef volatile struct ALT_SYSMGR_FRZCTL_HIOCTL_s ALT_SYSMGR_FRZCTL_HIOCTL_t;
2867 #endif /* __ASSEMBLY__ */
2868
2869 /* The byte offset of the ALT_SYSMGR_FRZCTL_HIOCTL register from the beginning of the component. */
2870 #define ALT_SYSMGR_FRZCTL_HIOCTL_OFST 0x10
2871
2872 /*
2873  * Register : Source Register - src
2874  *
2875  * Contains register field to choose between software state machine (vioctrl array
2876  * index [1] register) or hardware state machine in the Freeze Controller as the
2877  * freeze signal source for VIO channel 1.
2878  *
2879  * All fields are only reset by a cold reset (ignore warm reset).
2880  *
2881  * Register Layout
2882  *
2883  * Bits | Access | Reset | Description
2884  * :-------|:-------|:------|:--------------------------
2885  * [0] | RW | 0x0 | VIO1 Freeze Signal Source
2886  * [31:1] | ??? | 0x0 | *UNDEFINED*
2887  *
2888  */
2889 /*
2890  * Field : VIO1 Freeze Signal Source - vio1
2891  *
2892  * The freeze signal source for VIO channel 1 (VIO bank 2 and bank 3).
2893  *
2894  * Field Enumeration Values:
2895  *
2896  * Enum | Value | Description
2897  * :--------------------------------|:------|:-------------------------------------------------
2898  * ALT_SYSMGR_FRZCTL_SRC_VIO1_E_SW | 0x0 | VIO1 freeze signals are driven by software
2899  * : | | writing to the VIOCTRL[1] register. The
2900  * : | | VIO1-related fields in the hwctrl register are
2901  * : | | active but don't effect the VIO1 freeze signals.
2902  * ALT_SYSMGR_FRZCTL_SRC_VIO1_E_HW | 0x1 | VIO1 freeze signals are driven by the hardware
2903  * : | | state machine in the Freeze Controller. The
2904  * : | | VIO1-related fields in the hwctrl register are
2905  * : | | active and effect the VIO1 freeze signals.
2906  *
2907  * Field Access Macros:
2908  *
2909  */
2910 /*
2911  * Enumerated value for register field ALT_SYSMGR_FRZCTL_SRC_VIO1
2912  *
2913  * VIO1 freeze signals are driven by software writing to the VIOCTRL[1] register.
2914  * The VIO1-related fields in the hwctrl register are active but don't effect the
2915  * VIO1 freeze signals.
2916  */
2917 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_E_SW 0x0
2918 /*
2919  * Enumerated value for register field ALT_SYSMGR_FRZCTL_SRC_VIO1
2920  *
2921  * VIO1 freeze signals are driven by the hardware state machine in the Freeze
2922  * Controller. The VIO1-related fields in the hwctrl register are active and effect
2923  * the VIO1 freeze signals.
2924  */
2925 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_E_HW 0x1
2926
2927 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
2928 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_LSB 0
2929 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
2930 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_MSB 0
2931 /* The width in bits of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
2932 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_WIDTH 1
2933 /* The mask used to set the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field value. */
2934 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_SET_MSK 0x00000001
2935 /* The mask used to clear the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field value. */
2936 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_CLR_MSK 0xfffffffe
2937 /* The reset value of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
2938 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_RESET 0x0
2939 /* Extracts the ALT_SYSMGR_FRZCTL_SRC_VIO1 field value from a register. */
2940 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_GET(value) (((value) & 0x00000001) >> 0)
2941 /* Produces a ALT_SYSMGR_FRZCTL_SRC_VIO1 register field value suitable for setting the register. */
2942 #define ALT_SYSMGR_FRZCTL_SRC_VIO1_SET(value) (((value) << 0) & 0x00000001)
2943
2944 #ifndef __ASSEMBLY__
2945 /*
2946  * WARNING: The C register and register group struct declarations are provided for
2947  * convenience and illustrative purposes. They should, however, be used with
2948  * caution as the C language standard provides no guarantees about the alignment or
2949  * atomicity of device memory accesses. The recommended practice for writing
2950  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2951  * alt_write_word() functions.
2952  *
2953  * The struct declaration for register ALT_SYSMGR_FRZCTL_SRC.
2954  */
2956 {
2957  uint32_t vio1 : 1; /* VIO1 Freeze Signal Source */
2958  uint32_t : 31; /* *UNDEFINED* */
2959 };
2960
2961 /* The typedef declaration for register ALT_SYSMGR_FRZCTL_SRC. */
2962 typedef volatile struct ALT_SYSMGR_FRZCTL_SRC_s ALT_SYSMGR_FRZCTL_SRC_t;
2963 #endif /* __ASSEMBLY__ */
2964
2965 /* The byte offset of the ALT_SYSMGR_FRZCTL_SRC register from the beginning of the component. */
2966 #define ALT_SYSMGR_FRZCTL_SRC_OFST 0x14
2967
2968 /*
2969  * Register : Hardware Control Register - hwctrl
2970  *
2971  * Activate freeze or thaw operations on VIO channel 1 (HPS IO bank 2 and bank 3)
2972  * and monitor for completeness and the current state.
2973  *
2974  * These fields interact with the hardware state machine in the Freeze Controller.
2975  * These fields can be accessed independent of the value of SRC1.VIO1 although they
2976  * only have an effect on the VIO channel 1 freeze signals when SRC1.VIO1 is setup
2977  * to have the hardware state machine be the freeze signal source.
2978  *
2979  * All fields are only reset by a cold reset (ignore warm reset).
2980  *
2981  * Register Layout
2982  *
2983  * Bits | Access | Reset | Description
2984  * :-------|:-------|:------|:----------------------------------
2985  * [0] | RW | 0x1 | VIO channel 1 Freeze/Thaw request
2986  * [2:1] | R | 0x2 | VIO channel 1 State
2987  * [31:3] | ??? | 0x0 | *UNDEFINED*
2988  *
2989  */
2990 /*
2991  * Field : VIO channel 1 Freeze/Thaw request - vio1req
2992  *
2993  * Requests hardware state machine to generate freeze signal sequence to transition
2994  * between frozen and thawed states.
2995  *
2996  * If this field is read by software, it contains the value previously written by
2997  * software (i.e. this field is not written by hardware).
2998  *
2999  * Field Enumeration Values:
3000  *
3001  * Enum | Value | Description
3002  * :------------------------------------------|:------|:--------------------------------------
3003  * ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQTHAW | 0x0 | Requests a thaw (unfreeze) operation.
3004  * ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQFRZ | 0x1 | Requests a freeze operation.
3005  *
3006  * Field Access Macros:
3007  *
3008  */
3009 /*
3010  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ
3011  *
3012  * Requests a thaw (unfreeze) operation.
3013  */
3014 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQTHAW 0x0
3015 /*
3016  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ
3017  *
3018  * Requests a freeze operation.
3019  */
3020 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQFRZ 0x1
3021
3022 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
3023 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_LSB 0
3024 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
3025 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_MSB 0
3026 /* The width in bits of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
3027 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_WIDTH 1
3028 /* The mask used to set the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field value. */
3029 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_SET_MSK 0x00000001
3030 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field value. */
3031 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_CLR_MSK 0xfffffffe
3032 /* The reset value of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
3033 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_RESET 0x1
3034 /* Extracts the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ field value from a register. */
3035 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_GET(value) (((value) & 0x00000001) >> 0)
3036 /* Produces a ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field value suitable for setting the register. */
3037 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_SET(value) (((value) << 0) & 0x00000001)
3038
3039 /*
3040  * Field : VIO channel 1 State - vio1state
3041  *
3042  * Software reads this field to determine the current frozen/thawed state of the
3043  * VIO channel 1 or to determine when a freeze/thaw request is made by writing the
3044  * corresponding *REQ field in this register has completed.
3045  *
3046  * Reset by a cold reset (ignores warm reset).
3047  *
3048  * Field Enumeration Values:
3049  *
3050  * Enum | Value | Description
3051  * :--------------------------------------------------|:------|:-------------------------------------------------
3052  * ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED2FROZEN | 0x0 | Transitioning from thawed state to frozen state.
3053  * ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED | 0x1 | Thawed state. I/Os behave as configured. I/Os
3054  * : | | must be configured by the Scan Manager before
3055  * : | | entering this state.
3056  * ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN | 0x2 | Frozen state. I/O configuration is ignored.
3057  * : | | Instead, I/Os are in tri-state mode with a weak
3058  * : | | pull-up. Scan Manager can be used to configure
3059  * : | | the I/Os while they are frozen.
3060  * ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN2THAWED | 0x3 | Transitioning from frozen state to thawed state.
3061  *
3062  * Field Access Macros:
3063  *
3064  */
3065 /*
3066  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE
3067  *
3068  * Transitioning from thawed state to frozen state.
3069  */
3070 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED2FROZEN 0x0
3071 /*
3072  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE
3073  *
3074  * Thawed state. I/Os behave as configured. I/Os must be configured by the Scan
3075  * Manager before entering this state.
3076  */
3077 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED 0x1
3078 /*
3079  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE
3080  *
3081  * Frozen state. I/O configuration is ignored. Instead, I/Os are in tri-state mode
3082  * with a weak pull-up. Scan Manager can be used to configure the I/Os while they
3083  * are frozen.
3084  */
3085 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN 0x2
3086 /*
3087  * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE
3088  *
3089  * Transitioning from frozen state to thawed state.
3090  */
3091 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN2THAWED 0x3
3092
3093 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
3094 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_LSB 1
3095 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
3096 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_MSB 2
3097 /* The width in bits of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
3098 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_WIDTH 2
3099 /* The mask used to set the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field value. */
3100 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_SET_MSK 0x00000006
3101 /* The mask used to clear the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field value. */
3102 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_CLR_MSK 0xfffffff9
3103 /* The reset value of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
3104 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_RESET 0x2
3105 /* Extracts the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE field value from a register. */
3106 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_GET(value) (((value) & 0x00000006) >> 1)
3107 /* Produces a ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field value suitable for setting the register. */
3108 #define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_SET(value) (((value) << 1) & 0x00000006)
3109
3110 #ifndef __ASSEMBLY__
3111 /*
3112  * WARNING: The C register and register group struct declarations are provided for
3113  * convenience and illustrative purposes. They should, however, be used with
3114  * caution as the C language standard provides no guarantees about the alignment or
3115  * atomicity of device memory accesses. The recommended practice for writing
3116  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3117  * alt_write_word() functions.
3118  *
3119  * The struct declaration for register ALT_SYSMGR_FRZCTL_HWCTL.
3120  */
3122 {
3123  uint32_t vio1req : 1; /* VIO channel 1 Freeze/Thaw request */
3124  const uint32_t vio1state : 2; /* VIO channel 1 State */
3125  uint32_t : 29; /* *UNDEFINED* */
3126 };
3127
3128 /* The typedef declaration for register ALT_SYSMGR_FRZCTL_HWCTL. */
3129 typedef volatile struct ALT_SYSMGR_FRZCTL_HWCTL_s ALT_SYSMGR_FRZCTL_HWCTL_t;
3130 #endif /* __ASSEMBLY__ */
3131
3132 /* The byte offset of the ALT_SYSMGR_FRZCTL_HWCTL register from the beginning of the component. */
3133 #define ALT_SYSMGR_FRZCTL_HWCTL_OFST 0x18
3134
3135 #ifndef __ASSEMBLY__
3136 /*
3137  * WARNING: The C register and register group struct declarations are provided for
3138  * convenience and illustrative purposes. They should, however, be used with
3139  * caution as the C language standard provides no guarantees about the alignment or
3140  * atomicity of device memory accesses. The recommended practice for writing
3141  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3142  * alt_write_word() functions.
3143  *
3144  * The struct declaration for register group ALT_SYSMGR_FRZCTL.
3145  */
3147 {
3148  volatile ALT_SYSMGR_FRZCTL_VIOCTL_t vioctrl[3]; /* ALT_SYSMGR_FRZCTL_VIOCTL */
3149  volatile uint32_t _pad_0xc_0xf; /* *UNDEFINED* */
3150  volatile ALT_SYSMGR_FRZCTL_HIOCTL_t hioctrl; /* ALT_SYSMGR_FRZCTL_HIOCTL */
3151  volatile ALT_SYSMGR_FRZCTL_SRC_t src; /* ALT_SYSMGR_FRZCTL_SRC */
3152  volatile ALT_SYSMGR_FRZCTL_HWCTL_t hwctrl; /* ALT_SYSMGR_FRZCTL_HWCTL */
3153  volatile uint32_t _pad_0x1c_0x20; /* *UNDEFINED* */
3154 };
3155
3156 /* The typedef declaration for register group ALT_SYSMGR_FRZCTL. */
3157 typedef volatile struct ALT_SYSMGR_FRZCTL_s ALT_SYSMGR_FRZCTL_t;
3158 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_FRZCTL. */
3160 {
3161  volatile uint32_t vioctrl[3]; /* ALT_SYSMGR_FRZCTL_VIOCTL */
3162  volatile uint32_t _pad_0xc_0xf; /* *UNDEFINED* */
3163  volatile uint32_t hioctrl; /* ALT_SYSMGR_FRZCTL_HIOCTL */
3164  volatile uint32_t src; /* ALT_SYSMGR_FRZCTL_SRC */
3165  volatile uint32_t hwctrl; /* ALT_SYSMGR_FRZCTL_HWCTL */
3166  volatile uint32_t _pad_0x1c_0x20; /* *UNDEFINED* */
3167 };
3168
3169 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_FRZCTL. */
3170 typedef volatile struct ALT_SYSMGR_FRZCTL_raw_s ALT_SYSMGR_FRZCTL_raw_t;
3171 #endif /* __ASSEMBLY__ */
3172
3173
3174 /*
3175  * Register Group : EMAC Group - ALT_SYSMGR_EMAC
3176  * EMAC Group
3177  *
3178  * External control registers for the EMACs
3179  *
3180  */
3181 /*
3182  * Register : Control Register - ctrl
3183  *
3184  * Registers used by the EMACs. All fields are reset by a cold or warm reset.
3185  *
3186  * Register Layout
3187  *
3188  * Bits | Access | Reset | Description
3189  * :-------|:-------|:------|:---------------------
3190  * [1:0] | RW | 0x2 | PHY Interface Select
3191  * [3:2] | RW | 0x2 | PHY Interface Select
3192  * [4] | RW | 0x0 | PTP Clock Select
3193  * [5] | RW | 0x0 | PTP Clock Select
3194  * [31:6] | ??? | 0x0 | *UNDEFINED*
3195  *
3196  */
3197 /*
3198  * Field : PHY Interface Select - physel_0
3199  *
3200  * Controls the PHY interface selection of the EMACs. This is sampled by an EMAC
3201  * module when it exits from reset. The associated enum defines the allowed values.
3202  * The field array index corresponds to the EMAC index.
3203  *
3204  * Field Enumeration Values:
3205  *
3206  * Enum | Value | Description
3207  * :----------------------------------------|:------|:------------------------------
3208  * ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_GMII_MII | 0x0 | Select GMII/MII PHY interface
3209  * ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RGMII | 0x1 | Select RGMII PHY interface
3210  * ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RMII | 0x2 | Select RMII PHY interface
3211  *
3212  * Field Access Macros:
3213  *
3214  */
3215 /*
3216  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_0
3217  *
3218  * Select GMII/MII PHY interface
3219  */
3220 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_GMII_MII 0x0
3221 /*
3222  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_0
3223  *
3224  * Select RGMII PHY interface
3225  */
3226 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RGMII 0x1
3227 /*
3228  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_0
3229  *
3230  * Select RMII PHY interface
3231  */
3232 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RMII 0x2
3233
3234 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
3235 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_LSB 0
3236 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
3237 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_MSB 1
3238 /* The width in bits of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
3239 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_WIDTH 2
3240 /* The mask used to set the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field value. */
3241 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_SET_MSK 0x00000003
3242 /* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field value. */
3243 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_CLR_MSK 0xfffffffc
3244 /* The reset value of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
3245 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_RESET 0x2
3246 /* Extracts the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 field value from a register. */
3247 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_GET(value) (((value) & 0x00000003) >> 0)
3248 /* Produces a ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field value suitable for setting the register. */
3249 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_SET(value) (((value) << 0) & 0x00000003)
3250
3251 /*
3252  * Field : PHY Interface Select - physel_1
3253  *
3254  * Controls the PHY interface selection of the EMACs. This is sampled by an EMAC
3255  * module when it exits from reset. The associated enum defines the allowed values.
3256  * The field array index corresponds to the EMAC index.
3257  *
3258  * Field Enumeration Values:
3259  *
3260  * Enum | Value | Description
3261  * :----------------------------------------|:------|:------------------------------
3262  * ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_GMII_MII | 0x0 | Select GMII/MII PHY interface
3263  * ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RGMII | 0x1 | Select RGMII PHY interface
3264  * ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RMII | 0x2 | Select RMII PHY interface
3265  *
3266  * Field Access Macros:
3267  *
3268  */
3269 /*
3270  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_1
3271  *
3272  * Select GMII/MII PHY interface
3273  */
3274 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_GMII_MII 0x0
3275 /*
3276  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_1
3277  *
3278  * Select RGMII PHY interface
3279  */
3280 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RGMII 0x1
3281 /*
3282  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_1
3283  *
3284  * Select RMII PHY interface
3285  */
3286 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RMII 0x2
3287
3288 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
3289 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_LSB 2
3290 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
3291 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_MSB 3
3292 /* The width in bits of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
3293 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_WIDTH 2
3294 /* The mask used to set the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field value. */
3295 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_SET_MSK 0x0000000c
3296 /* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field value. */
3297 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_CLR_MSK 0xfffffff3
3298 /* The reset value of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
3299 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_RESET 0x2
3300 /* Extracts the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 field value from a register. */
3301 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_GET(value) (((value) & 0x0000000c) >> 2)
3302 /* Produces a ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field value suitable for setting the register. */
3303 #define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_SET(value) (((value) << 2) & 0x0000000c)
3304
3305 /*
3306  * Field : PTP Clock Select - ptpclksel_0
3307  *
3308  * Selects the source of the 1588 PTP reference clock. This is sampled by an EMAC
3309  * module when it exits from reset. The field array index corresponds to the EMAC
3310  * index.
3311  *
3312  * Field Enumeration Values:
3313  *
3314  * Enum | Value | Description
3315  * :---------------------------------------------------|:------|:-------------------------
3316  * ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_OSC1_CLK | 0x0 | Selects osc1_clk
3317  * ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_FPGA_PTP_REF_CLK | 0x1 | Selects fpga_ptp_ref_clk
3318  *
3319  * Field Access Macros:
3320  *
3321  */
3322 /*
3323  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0
3324  *
3325  * Selects osc1_clk
3326  */
3327 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_OSC1_CLK 0x0
3328 /*
3329  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0
3330  *
3331  * Selects fpga_ptp_ref_clk
3332  */
3333 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_FPGA_PTP_REF_CLK 0x1
3334
3335 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
3336 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_LSB 4
3337 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
3338 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_MSB 4
3339 /* The width in bits of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
3340 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_WIDTH 1
3341 /* The mask used to set the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field value. */
3342 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_SET_MSK 0x00000010
3343 /* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field value. */
3344 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_CLR_MSK 0xffffffef
3345 /* The reset value of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
3346 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_RESET 0x0
3347 /* Extracts the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 field value from a register. */
3348 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_GET(value) (((value) & 0x00000010) >> 4)
3349 /* Produces a ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field value suitable for setting the register. */
3350 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_SET(value) (((value) << 4) & 0x00000010)
3351
3352 /*
3353  * Field : PTP Clock Select - ptpclksel_1
3354  *
3355  * Selects the source of the 1588 PTP reference clock. This is sampled by an EMAC
3356  * module when it exits from reset. The field array index corresponds to the EMAC
3357  * index.
3358  *
3359  * Field Enumeration Values:
3360  *
3361  * Enum | Value | Description
3362  * :---------------------------------------------------|:------|:-------------------------
3363  * ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_OSC1_CLK | 0x0 | Selects osc1_clk
3364  * ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_FPGA_PTP_REF_CLK | 0x1 | Selects fpga_ptp_ref_clk
3365  *
3366  * Field Access Macros:
3367  *
3368  */
3369 /*
3370  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1
3371  *
3372  * Selects osc1_clk
3373  */
3374 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_OSC1_CLK 0x0
3375 /*
3376  * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1
3377  *
3378  * Selects fpga_ptp_ref_clk
3379  */
3380 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_FPGA_PTP_REF_CLK 0x1
3381
3382 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
3383 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_LSB 5
3384 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
3385 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_MSB 5
3386 /* The width in bits of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
3387 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_WIDTH 1
3388 /* The mask used to set the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field value. */
3389 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_SET_MSK 0x00000020
3390 /* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field value. */
3391 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_CLR_MSK 0xffffffdf
3392 /* The reset value of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
3393 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_RESET 0x0
3394 /* Extracts the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 field value from a register. */
3395 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_GET(value) (((value) & 0x00000020) >> 5)
3396 /* Produces a ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field value suitable for setting the register. */
3397 #define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_SET(value) (((value) << 5) & 0x00000020)
3398
3399 #ifndef __ASSEMBLY__
3400 /*
3401  * WARNING: The C register and register group struct declarations are provided for
3402  * convenience and illustrative purposes. They should, however, be used with
3403  * caution as the C language standard provides no guarantees about the alignment or
3404  * atomicity of device memory accesses. The recommended practice for writing
3405  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3406  * alt_write_word() functions.
3407  *
3408  * The struct declaration for register ALT_SYSMGR_EMAC_CTL.
3409  */
3411 {
3412  uint32_t physel_0 : 2; /* PHY Interface Select */
3413  uint32_t physel_1 : 2; /* PHY Interface Select */
3414  uint32_t ptpclksel_0 : 1; /* PTP Clock Select */
3415  uint32_t ptpclksel_1 : 1; /* PTP Clock Select */
3416  uint32_t : 26; /* *UNDEFINED* */
3417 };
3418
3419 /* The typedef declaration for register ALT_SYSMGR_EMAC_CTL. */
3420 typedef volatile struct ALT_SYSMGR_EMAC_CTL_s ALT_SYSMGR_EMAC_CTL_t;
3421 #endif /* __ASSEMBLY__ */
3422
3423 /* The byte offset of the ALT_SYSMGR_EMAC_CTL register from the beginning of the component. */
3424 #define ALT_SYSMGR_EMAC_CTL_OFST 0x0
3425
3426 /*
3427  * Register : EMAC L3 Master AxCACHE Register - l3master
3428  *
3429  * Controls the L3 master ARCACHE and AWCACHE AXI signals.
3430  *
3431  * These register bits should be updated only during system initialization prior to
3432  * removing the peripheral from reset. They may not be changed dynamically during
3433  * peripheral operation
3434  *
3435  * All fields are reset by a cold or warm reset.
3436  *
3437  * Register Layout
3438  *
3439  * Bits | Access | Reset | Description
3440  * :--------|:-------|:------|:-------------
3441  * [3:0] | RW | 0x0 | EMAC ARCACHE
3442  * [7:4] | RW | 0x0 | EMAC ARCACHE
3443  * [11:8] | RW | 0x0 | EMAC AWCACHE
3444  * [15:12] | RW | 0x0 | EMAC AWCACHE
3445  * [31:16] | ??? | 0x0 | *UNDEFINED*
3446  *
3447  */
3448 /*
3449  * Field : EMAC ARCACHE - arcache_0
3450  *
3451  * Specifies the values of the 2 EMAC ARCACHE signals.
3452  *
3453  * The field array index corresponds to the EMAC index.
3454  *
3455  * Field Enumeration Values:
3456  *
3457  * Enum | Value | Description
3458  * :-------------------------------------------------------|:------|:-------------------------------------------------
3459  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF | 0x0 | Noncacheable and nonbufferable.
3460  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_BUFF | 0x1 | Bufferable only.
3461  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_NONALLOC | 0x2 | Cacheable, but do not allocate.
3462  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC | 0x3 | Cacheable and bufferable, but do not allocate.
3463  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD1 | 0x4 | Reserved.
3464  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD2 | 0x5 | Reserved.
3465  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6 | Cacheable write-through, allocate on reads only.
3466  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7 | Cacheable write-back, allocate on reads only.
3467  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD3 | 0x8 | Reserved.
3468  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD4 | 0x9 | Reserved.
3469  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa | Cacheable write-through, allocate on writes
3470  * : | | only.
3471  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb | Cacheable write-back, allocate on writes only.
3472  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD5 | 0xc | Reserved.
3473  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD6 | 0xd | Reserved.
3474  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC | 0xe | Cacheable write-through, allocate on both reads
3475  * : | | and writes.
3476  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC | 0xf | Cacheable write-back, allocate on both reads and
3477  * : | | writes.
3478  *
3479  * Field Access Macros:
3480  *
3481  */
3482 /*
3483  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3484  *
3485  * Noncacheable and nonbufferable.
3486  */
3487 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF 0x0
3488 /*
3489  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3490  *
3491  * Bufferable only.
3492  */
3493 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_BUFF 0x1
3494 /*
3495  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3496  *
3497  * Cacheable, but do not allocate.
3498  */
3499 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_NONALLOC 0x2
3500 /*
3501  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3502  *
3503  * Cacheable and bufferable, but do not allocate.
3504  */
3505 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC 0x3
3506 /*
3507  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3508  *
3509  * Reserved.
3510  */
3511 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD1 0x4
3512 /*
3513  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3514  *
3515  * Reserved.
3516  */
3517 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD2 0x5
3518 /*
3519  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3520  *
3521  * Cacheable write-through, allocate on reads only.
3522  */
3523 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC 0x6
3524 /*
3525  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3526  *
3527  * Cacheable write-back, allocate on reads only.
3528  */
3529 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC 0x7
3530 /*
3531  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3532  *
3533  * Reserved.
3534  */
3535 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD3 0x8
3536 /*
3537  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3538  *
3539  * Reserved.
3540  */
3541 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD4 0x9
3542 /*
3543  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3544  *
3545  * Cacheable write-through, allocate on writes only.
3546  */
3547 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC 0xa
3548 /*
3549  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3550  *
3551  * Cacheable write-back, allocate on writes only.
3552  */
3553 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC 0xb
3554 /*
3555  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3556  *
3557  * Reserved.
3558  */
3559 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD5 0xc
3560 /*
3561  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3562  *
3563  * Reserved.
3564  */
3565 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD6 0xd
3566 /*
3567  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3568  *
3569  * Cacheable write-through, allocate on both reads and writes.
3570  */
3571 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC 0xe
3572 /*
3573  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
3574  *
3575  * Cacheable write-back, allocate on both reads and writes.
3576  */
3577 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC 0xf
3578
3579 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
3580 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_LSB 0
3581 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
3582 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_MSB 3
3583 /* The width in bits of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
3584 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_WIDTH 4
3585 /* The mask used to set the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field value. */
3586 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_SET_MSK 0x0000000f
3587 /* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field value. */
3588 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_CLR_MSK 0xfffffff0
3589 /* The reset value of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
3590 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_RESET 0x0
3591 /* Extracts the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 field value from a register. */
3592 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_GET(value) (((value) & 0x0000000f) >> 0)
3593 /* Produces a ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field value suitable for setting the register. */
3594 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_SET(value) (((value) << 0) & 0x0000000f)
3595
3596 /*
3597  * Field : EMAC ARCACHE - arcache_1
3598  *
3599  * Specifies the values of the 2 EMAC ARCACHE signals.
3600  *
3601  * The field array index corresponds to the EMAC index.
3602  *
3603  * Field Enumeration Values:
3604  *
3605  * Enum | Value | Description
3606  * :-------------------------------------------------------|:------|:-------------------------------------------------
3607  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_NONCACHE_NONBUFF | 0x0 | Noncacheable and nonbufferable.
3608  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_BUFF | 0x1 | Bufferable only.
3609  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_NONALLOC | 0x2 | Cacheable, but do not allocate.
3610  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_BUFF_NONALLOC | 0x3 | Cacheable and bufferable, but do not allocate.
3611  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD1 | 0x4 | Reserved.
3612  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD2 | 0x5 | Reserved.
3613  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_RDALLOC | 0x6 | Cacheable write-through, allocate on reads only.
3614  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_RDALLOC | 0x7 | Cacheable write-back, allocate on reads only.
3615  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD3 | 0x8 | Reserved.
3616  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD4 | 0x9 | Reserved.
3617  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_WRALLOC | 0xa | Cacheable write-through, allocate on writes
3618  * : | | only.
3619  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_WRALLOC | 0xb | Cacheable write-back, allocate on writes only.
3620  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD5 | 0xc | Reserved.
3621  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD6 | 0xd | Reserved.
3622  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_ALLOC | 0xe | Cacheable write-through, allocate on both reads
3623  * : | | and writes.
3624  * ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_ALLOC | 0xf | Cacheable write-back, allocate on both reads and
3625  * : | | writes.
3626  *
3627  * Field Access Macros:
3628  *
3629  */
3630 /*
3631  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3632  *
3633  * Noncacheable and nonbufferable.
3634  */
3635 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_NONCACHE_NONBUFF 0x0
3636 /*
3637  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3638  *
3639  * Bufferable only.
3640  */
3641 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_BUFF 0x1
3642 /*
3643  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3644  *
3645  * Cacheable, but do not allocate.
3646  */
3647 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_NONALLOC 0x2
3648 /*
3649  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3650  *
3651  * Cacheable and bufferable, but do not allocate.
3652  */
3653 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_BUFF_NONALLOC 0x3
3654 /*
3655  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3656  *
3657  * Reserved.
3658  */
3659 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD1 0x4
3660 /*
3661  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3662  *
3663  * Reserved.
3664  */
3665 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD2 0x5
3666 /*
3667  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3668  *
3669  * Cacheable write-through, allocate on reads only.
3670  */
3671 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_RDALLOC 0x6
3672 /*
3673  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3674  *
3675  * Cacheable write-back, allocate on reads only.
3676  */
3677 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_RDALLOC 0x7
3678 /*
3679  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3680  *
3681  * Reserved.
3682  */
3683 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD3 0x8
3684 /*
3685  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3686  *
3687  * Reserved.
3688  */
3689 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD4 0x9
3690 /*
3691  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3692  *
3693  * Cacheable write-through, allocate on writes only.
3694  */
3695 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_WRALLOC 0xa
3696 /*
3697  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3698  *
3699  * Cacheable write-back, allocate on writes only.
3700  */
3701 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_WRALLOC 0xb
3702 /*
3703  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3704  *
3705  * Reserved.
3706  */
3707 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD5 0xc
3708 /*
3709  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3710  *
3711  * Reserved.
3712  */
3713 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD6 0xd
3714 /*
3715  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3716  *
3717  * Cacheable write-through, allocate on both reads and writes.
3718  */
3719 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_ALLOC 0xe
3720 /*
3721  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
3722  *
3723  * Cacheable write-back, allocate on both reads and writes.
3724  */
3725 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_ALLOC 0xf
3726
3727 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
3728 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_LSB 4
3729 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
3730 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_MSB 7
3731 /* The width in bits of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
3732 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_WIDTH 4
3733 /* The mask used to set the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field value. */
3734 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_SET_MSK 0x000000f0
3735 /* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field value. */
3736 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_CLR_MSK 0xffffff0f
3737 /* The reset value of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
3738 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_RESET 0x0
3739 /* Extracts the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 field value from a register. */
3740 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_GET(value) (((value) & 0x000000f0) >> 4)
3741 /* Produces a ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field value suitable for setting the register. */
3742 #define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_SET(value) (((value) << 4) & 0x000000f0)
3743
3744 /*
3745  * Field : EMAC AWCACHE - awcache_0
3746  *
3747  * Specifies the values of the 2 EMAC AWCACHE signals.
3748  *
3749  * The field array index corresponds to the EMAC index.
3750  *
3751  * Field Enumeration Values:
3752  *
3753  * Enum | Value | Description
3754  * :-------------------------------------------------------|:------|:-------------------------------------------------
3755  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF | 0x0 | Noncacheable and nonbufferable.
3756  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_BUFF | 0x1 | Bufferable only.
3757  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_NONALLOC | 0x2 | Cacheable, but do not allocate.
3758  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC | 0x3 | Cacheable and bufferable, but do not allocate.
3759  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD1 | 0x4 | Reserved.
3760  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD2 | 0x5 | Reserved.
3761  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6 | Cacheable write-through, allocate on reads only.
3762  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7 | Cacheable write-back, allocate on reads only.
3763  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD3 | 0x8 | Reserved.
3764  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD4 | 0x9 | Reserved.
3765  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa | Cacheable write-through, allocate on writes
3766  * : | | only.
3767  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb | Cacheable write-back, allocate on writes only.
3768  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD5 | 0xc | Reserved.
3769  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD6 | 0xd | Reserved.
3770  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC | 0xe | Cacheable write-through, allocate on both reads
3771  * : | | and writes.
3772  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC | 0xf | Cacheable write-back, allocate on both reads and
3773  * : | | writes.
3774  *
3775  * Field Access Macros:
3776  *
3777  */
3778 /*
3779  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3780  *
3781  * Noncacheable and nonbufferable.
3782  */
3783 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF 0x0
3784 /*
3785  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3786  *
3787  * Bufferable only.
3788  */
3789 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_BUFF 0x1
3790 /*
3791  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3792  *
3793  * Cacheable, but do not allocate.
3794  */
3795 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_NONALLOC 0x2
3796 /*
3797  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3798  *
3799  * Cacheable and bufferable, but do not allocate.
3800  */
3801 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC 0x3
3802 /*
3803  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3804  *
3805  * Reserved.
3806  */
3807 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD1 0x4
3808 /*
3809  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3810  *
3811  * Reserved.
3812  */
3813 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD2 0x5
3814 /*
3815  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3816  *
3817  * Cacheable write-through, allocate on reads only.
3818  */
3819 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC 0x6
3820 /*
3821  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3822  *
3823  * Cacheable write-back, allocate on reads only.
3824  */
3825 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC 0x7
3826 /*
3827  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3828  *
3829  * Reserved.
3830  */
3831 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD3 0x8
3832 /*
3833  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3834  *
3835  * Reserved.
3836  */
3837 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD4 0x9
3838 /*
3839  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3840  *
3841  * Cacheable write-through, allocate on writes only.
3842  */
3843 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC 0xa
3844 /*
3845  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3846  *
3847  * Cacheable write-back, allocate on writes only.
3848  */
3849 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC 0xb
3850 /*
3851  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3852  *
3853  * Reserved.
3854  */
3855 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD5 0xc
3856 /*
3857  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3858  *
3859  * Reserved.
3860  */
3861 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD6 0xd
3862 /*
3863  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3864  *
3865  * Cacheable write-through, allocate on both reads and writes.
3866  */
3867 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC 0xe
3868 /*
3869  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
3870  *
3871  * Cacheable write-back, allocate on both reads and writes.
3872  */
3873 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC 0xf
3874
3875 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
3876 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_LSB 8
3877 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
3878 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_MSB 11
3879 /* The width in bits of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
3880 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_WIDTH 4
3881 /* The mask used to set the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field value. */
3882 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_SET_MSK 0x00000f00
3883 /* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field value. */
3884 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_CLR_MSK 0xfffff0ff
3885 /* The reset value of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
3886 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_RESET 0x0
3887 /* Extracts the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 field value from a register. */
3888 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_GET(value) (((value) & 0x00000f00) >> 8)
3889 /* Produces a ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field value suitable for setting the register. */
3890 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_SET(value) (((value) << 8) & 0x00000f00)
3891
3892 /*
3893  * Field : EMAC AWCACHE - awcache_1
3894  *
3895  * Specifies the values of the 2 EMAC AWCACHE signals.
3896  *
3897  * The field array index corresponds to the EMAC index.
3898  *
3899  * Field Enumeration Values:
3900  *
3901  * Enum | Value | Description
3902  * :-------------------------------------------------------|:------|:-------------------------------------------------
3903  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_NONCACHE_NONBUFF | 0x0 | Noncacheable and nonbufferable.
3904  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_BUFF | 0x1 | Bufferable only.
3905  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_NONALLOC | 0x2 | Cacheable, but do not allocate.
3906  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_BUFF_NONALLOC | 0x3 | Cacheable and bufferable, but do not allocate.
3907  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD1 | 0x4 | Reserved.
3908  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD2 | 0x5 | Reserved.
3909  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_RDALLOC | 0x6 | Cacheable write-through, allocate on reads only.
3910  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_RDALLOC | 0x7 | Cacheable write-back, allocate on reads only.
3911  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD3 | 0x8 | Reserved.
3912  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD4 | 0x9 | Reserved.
3913  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_WRALLOC | 0xa | Cacheable write-through, allocate on writes
3914  * : | | only.
3915  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_WRALLOC | 0xb | Cacheable write-back, allocate on writes only.
3916  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD5 | 0xc | Reserved.
3917  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD6 | 0xd | Reserved.
3918  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_ALLOC | 0xe | Cacheable write-through, allocate on both reads
3919  * : | | and writes.
3920  * ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_ALLOC | 0xf | Cacheable write-back, allocate on both reads and
3921  * : | | writes.
3922  *
3923  * Field Access Macros:
3924  *
3925  */
3926 /*
3927  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3928  *
3929  * Noncacheable and nonbufferable.
3930  */
3931 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_NONCACHE_NONBUFF 0x0
3932 /*
3933  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3934  *
3935  * Bufferable only.
3936  */
3937 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_BUFF 0x1
3938 /*
3939  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3940  *
3941  * Cacheable, but do not allocate.
3942  */
3943 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_NONALLOC 0x2
3944 /*
3945  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3946  *
3947  * Cacheable and bufferable, but do not allocate.
3948  */
3949 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_BUFF_NONALLOC 0x3
3950 /*
3951  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3952  *
3953  * Reserved.
3954  */
3955 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD1 0x4
3956 /*
3957  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3958  *
3959  * Reserved.
3960  */
3961 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD2 0x5
3962 /*
3963  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3964  *
3965  * Cacheable write-through, allocate on reads only.
3966  */
3967 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_RDALLOC 0x6
3968 /*
3969  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3970  *
3971  * Cacheable write-back, allocate on reads only.
3972  */
3973 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_RDALLOC 0x7
3974 /*
3975  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3976  *
3977  * Reserved.
3978  */
3979 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD3 0x8
3980 /*
3981  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3982  *
3983  * Reserved.
3984  */
3985 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD4 0x9
3986 /*
3987  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3988  *
3989  * Cacheable write-through, allocate on writes only.
3990  */
3991 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_WRALLOC 0xa
3992 /*
3993  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
3994  *
3995  * Cacheable write-back, allocate on writes only.
3996  */
3997 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_WRALLOC 0xb
3998 /*
3999  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
4000  *
4001  * Reserved.
4002  */
4003 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD5 0xc
4004 /*
4005  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
4006  *
4007  * Reserved.
4008  */
4009 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD6 0xd
4010 /*
4011  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
4012  *
4013  * Cacheable write-through, allocate on both reads and writes.
4014  */
4015 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_ALLOC 0xe
4016 /*
4017  * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
4018  *
4019  * Cacheable write-back, allocate on both reads and writes.
4020  */
4021 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_ALLOC 0xf
4022
4023 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
4024 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_LSB 12
4025 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
4026 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_MSB 15
4027 /* The width in bits of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
4028 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_WIDTH 4
4029 /* The mask used to set the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field value. */
4030 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_SET_MSK 0x0000f000
4031 /* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field value. */
4032 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_CLR_MSK 0xffff0fff
4033 /* The reset value of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
4034 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_RESET 0x0
4035 /* Extracts the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 field value from a register. */
4036 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_GET(value) (((value) & 0x0000f000) >> 12)
4037 /* Produces a ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field value suitable for setting the register. */
4038 #define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_SET(value) (((value) << 12) & 0x0000f000)
4039
4040 #ifndef __ASSEMBLY__
4041 /*
4042  * WARNING: The C register and register group struct declarations are provided for
4043  * convenience and illustrative purposes. They should, however, be used with
4044  * caution as the C language standard provides no guarantees about the alignment or
4045  * atomicity of device memory accesses. The recommended practice for writing
4046  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4047  * alt_write_word() functions.
4048  *
4049  * The struct declaration for register ALT_SYSMGR_EMAC_L3MST.
4050  */
4052 {
4053  uint32_t arcache_0 : 4; /* EMAC ARCACHE */
4054  uint32_t arcache_1 : 4; /* EMAC ARCACHE */
4055  uint32_t awcache_0 : 4; /* EMAC AWCACHE */
4056  uint32_t awcache_1 : 4; /* EMAC AWCACHE */
4057  uint32_t : 16; /* *UNDEFINED* */
4058 };
4059
4060 /* The typedef declaration for register ALT_SYSMGR_EMAC_L3MST. */
4061 typedef volatile struct ALT_SYSMGR_EMAC_L3MST_s ALT_SYSMGR_EMAC_L3MST_t;
4062 #endif /* __ASSEMBLY__ */
4063
4064 /* The byte offset of the ALT_SYSMGR_EMAC_L3MST register from the beginning of the component. */
4065 #define ALT_SYSMGR_EMAC_L3MST_OFST 0x4
4066
4067 #ifndef __ASSEMBLY__
4068 /*
4069  * WARNING: The C register and register group struct declarations are provided for
4070  * convenience and illustrative purposes. They should, however, be used with
4071  * caution as the C language standard provides no guarantees about the alignment or
4072  * atomicity of device memory accesses. The recommended practice for writing
4073  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4074  * alt_write_word() functions.
4075  *
4076  * The struct declaration for register group ALT_SYSMGR_EMAC.
4077  */
4079 {
4080  volatile ALT_SYSMGR_EMAC_CTL_t ctrl; /* ALT_SYSMGR_EMAC_CTL */
4081  volatile ALT_SYSMGR_EMAC_L3MST_t l3master; /* ALT_SYSMGR_EMAC_L3MST */
4082  volatile uint32_t _pad_0x8_0x10[2]; /* *UNDEFINED* */
4083 };
4084
4085 /* The typedef declaration for register group ALT_SYSMGR_EMAC. */
4086 typedef volatile struct ALT_SYSMGR_EMAC_s ALT_SYSMGR_EMAC_t;
4087 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_EMAC. */
4089 {
4090  volatile uint32_t ctrl; /* ALT_SYSMGR_EMAC_CTL */
4091  volatile uint32_t l3master; /* ALT_SYSMGR_EMAC_L3MST */
4092  volatile uint32_t _pad_0x8_0x10[2]; /* *UNDEFINED* */
4093 };
4094
4095 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_EMAC. */
4096 typedef volatile struct ALT_SYSMGR_EMAC_raw_s ALT_SYSMGR_EMAC_raw_t;
4097 #endif /* __ASSEMBLY__ */
4098
4099
4100 /*
4101  * Register Group : DMA Controller Group - ALT_SYSMGR_DMA
4102  * DMA Controller Group
4103  *
4104  * Registers used by the DMA Controller to enable secured system support and select
4105  * DMA channels.
4106  *
4107  */
4108 /*
4109  * Register : Control Register - ctrl
4110  *
4111  * Registers used by the DMA Controller. All fields are reset by a cold or warm
4112  * reset.
4113  *
4114  * These register bits should be updated during system initialization prior to
4115  * removing the DMA controller from reset. They may not be changed dynamically
4116  * during DMA operation.
4117  *
4118  * Register Layout
4119  *
4120  * Bits | Access | Reset | Description
4121  * :--------|:-------|:------|:------------------------
4122  * [0] | RW | 0x0 | Channel Select
4123  * [1] | RW | 0x0 | Channel Select
4124  * [2] | RW | 0x0 | Channel Select
4125  * [3] | RW | 0x0 | Channel Select
4126  * [4] | RW | 0x0 | Manager Thread Security
4127  * [12:5] | RW | 0x0 | IRQ Security
4128  * [31:13] | ??? | 0x0 | *UNDEFINED*
4129  *
4130  */
4131 /*
4132  * Field : Channel Select - chansel_0
4133  *
4134  * Controls mux that selects whether FPGA or CAN connects to one of the DMA
4135  * peripheral request interfaces.The peripheral request interface index equals the
4136  * array index + 4. For example, array index 0 is for peripheral request index 4.
4137  *
4138  * Field Enumeration Values:
4139  *
4140  * Enum | Value | Description
4141  * :------------------------------------|:------|:-----------------------------------------
4142  * ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_FPGA | 0x0 | FPGA drives peripheral request interface
4143  * ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_CAN | 0x1 | CAN drives peripheral request interface
4144  *
4145  * Field Access Macros:
4146  *
4147  */
4148 /*
4149  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_0
4150  *
4151  * FPGA drives peripheral request interface
4152  */
4153 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_FPGA 0x0
4154 /*
4155  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_0
4156  *
4157  * CAN drives peripheral request interface
4158  */
4159 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_CAN 0x1
4160
4161 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
4162 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_LSB 0
4163 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
4164 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_MSB 0
4165 /* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
4166 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_WIDTH 1
4167 /* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field value. */
4168 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_SET_MSK 0x00000001
4169 /* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field value. */
4170 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_CLR_MSK 0xfffffffe
4171 /* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
4172 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_RESET 0x0
4173 /* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_0 field value from a register. */
4174 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_GET(value) (((value) & 0x00000001) >> 0)
4175 /* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field value suitable for setting the register. */
4176 #define ALT_SYSMGR_DMA_CTL_CHANSEL_0_SET(value) (((value) << 0) & 0x00000001)
4177
4178 /*
4179  * Field : Channel Select - chansel_1
4180  *
4181  * Controls mux that selects whether FPGA or CAN connects to one of the DMA
4182  * peripheral request interfaces.The peripheral request interface index equals the
4183  * array index + 4. For example, array index 0 is for peripheral request index 4.
4184  *
4185  * Field Enumeration Values:
4186  *
4187  * Enum | Value | Description
4188  * :------------------------------------|:------|:-----------------------------------------
4189  * ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_FPGA | 0x0 | FPGA drives peripheral request interface
4190  * ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_CAN | 0x1 | CAN drives peripheral request interface
4191  *
4192  * Field Access Macros:
4193  *
4194  */
4195 /*
4196  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_1
4197  *
4198  * FPGA drives peripheral request interface
4199  */
4200 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_FPGA 0x0
4201 /*
4202  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_1
4203  *
4204  * CAN drives peripheral request interface
4205  */
4206 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_CAN 0x1
4207
4208 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
4209 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_LSB 1
4210 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
4211 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_MSB 1
4212 /* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
4213 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_WIDTH 1
4214 /* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field value. */
4215 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_SET_MSK 0x00000002
4216 /* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field value. */
4217 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_CLR_MSK 0xfffffffd
4218 /* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
4219 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_RESET 0x0
4220 /* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_1 field value from a register. */
4221 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_GET(value) (((value) & 0x00000002) >> 1)
4222 /* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field value suitable for setting the register. */
4223 #define ALT_SYSMGR_DMA_CTL_CHANSEL_1_SET(value) (((value) << 1) & 0x00000002)
4224
4225 /*
4226  * Field : Channel Select - chansel_2
4227  *
4228  * Controls mux that selects whether FPGA or CAN connects to one of the DMA
4229  * peripheral request interfaces.The peripheral request interface index equals the
4230  * array index + 4. For example, array index 0 is for peripheral request index 4.
4231  *
4232  * Field Enumeration Values:
4233  *
4234  * Enum | Value | Description
4235  * :------------------------------------|:------|:-----------------------------------------
4236  * ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_FPGA | 0x0 | FPGA drives peripheral request interface
4237  * ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_CAN | 0x1 | CAN drives peripheral request interface
4238  *
4239  * Field Access Macros:
4240  *
4241  */
4242 /*
4243  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_2
4244  *
4245  * FPGA drives peripheral request interface
4246  */
4247 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_FPGA 0x0
4248 /*
4249  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_2
4250  *
4251  * CAN drives peripheral request interface
4252  */
4253 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_CAN 0x1
4254
4255 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
4256 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_LSB 2
4257 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
4258 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_MSB 2
4259 /* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
4260 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_WIDTH 1
4261 /* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field value. */
4262 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_SET_MSK 0x00000004
4263 /* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field value. */
4264 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_CLR_MSK 0xfffffffb
4265 /* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
4266 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_RESET 0x0
4267 /* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_2 field value from a register. */
4268 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_GET(value) (((value) & 0x00000004) >> 2)
4269 /* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field value suitable for setting the register. */
4270 #define ALT_SYSMGR_DMA_CTL_CHANSEL_2_SET(value) (((value) << 2) & 0x00000004)
4271
4272 /*
4273  * Field : Channel Select - chansel_3
4274  *
4275  * Controls mux that selects whether FPGA or CAN connects to one of the DMA
4276  * peripheral request interfaces.The peripheral request interface index equals the
4277  * array index + 4. For example, array index 0 is for peripheral request index 4.
4278  *
4279  * Field Enumeration Values:
4280  *
4281  * Enum | Value | Description
4282  * :------------------------------------|:------|:-----------------------------------------
4283  * ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_FPGA | 0x0 | FPGA drives peripheral request interface
4284  * ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_CAN | 0x1 | CAN drives peripheral request interface
4285  *
4286  * Field Access Macros:
4287  *
4288  */
4289 /*
4290  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_3
4291  *
4292  * FPGA drives peripheral request interface
4293  */
4294 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_FPGA 0x0
4295 /*
4296  * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_3
4297  *
4298  * CAN drives peripheral request interface
4299  */
4300 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_CAN 0x1
4301
4302 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
4303 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_LSB 3
4304 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
4305 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_MSB 3
4306 /* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
4307 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_WIDTH 1
4308 /* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field value. */
4309 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_SET_MSK 0x00000008
4310 /* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field value. */
4311 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_CLR_MSK 0xfffffff7
4312 /* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
4313 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_RESET 0x0
4314 /* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_3 field value from a register. */
4315 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_GET(value) (((value) & 0x00000008) >> 3)
4316 /* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field value suitable for setting the register. */
4317 #define ALT_SYSMGR_DMA_CTL_CHANSEL_3_SET(value) (((value) << 3) & 0x00000008)
4318
4319 /*
4320  * Field : Manager Thread Security - mgrnonsecure
4321  *
4322  * Specifies the security state of the DMA manager thread.
4323  *
4324  * 0 = assigns DMA manager to the Secure state.
4325  *
4326  * 1 = assigns DMA manager to the Non-secure state.
4327  *
4328  * Sampled by the DMA controller when it exits from reset.
4329  *
4330  * Field Access Macros:
4331  *
4332  */
4333 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
4334 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_LSB 4
4335 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
4336 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_MSB 4
4337 /* The width in bits of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
4338 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_WIDTH 1
4339 /* The mask used to set the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field value. */
4340 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_SET_MSK 0x00000010
4341 /* The mask used to clear the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field value. */
4342 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_CLR_MSK 0xffffffef
4343 /* The reset value of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
4344 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_RESET 0x0
4345 /* Extracts the ALT_SYSMGR_DMA_CTL_MGRNONSECURE field value from a register. */
4346 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_GET(value) (((value) & 0x00000010) >> 4)
4347 /* Produces a ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field value suitable for setting the register. */
4348 #define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_SET(value) (((value) << 4) & 0x00000010)
4349
4350 /*
4351  * Field : IRQ Security - irqnonsecure
4352  *
4353  * Specifies the security state of an event-interrupt resource.
4354  *
4355  * If bit index [x] is 0, the DMAC assigns event<x> or irq[x] to the Secure state.
4356  *
4357  * If bit index [x] is 1, the DMAC assigns event<x> or irq[x] to the Non-secure
4358  * state.
4359  *
4360  * Field Access Macros:
4361  *
4362  */
4363 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
4364 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_LSB 5
4365 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
4366 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_MSB 12
4367 /* The width in bits of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
4368 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_WIDTH 8
4369 /* The mask used to set the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field value. */
4370 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_SET_MSK 0x00001fe0
4371 /* The mask used to clear the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field value. */
4372 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_CLR_MSK 0xffffe01f
4373 /* The reset value of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
4374 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_RESET 0x0
4375 /* Extracts the ALT_SYSMGR_DMA_CTL_IRQNONSECURE field value from a register. */
4376 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_GET(value) (((value) & 0x00001fe0) >> 5)
4377 /* Produces a ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field value suitable for setting the register. */
4378 #define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_SET(value) (((value) << 5) & 0x00001fe0)
4379
4380 #ifndef __ASSEMBLY__
4381 /*
4382  * WARNING: The C register and register group struct declarations are provided for
4383  * convenience and illustrative purposes. They should, however, be used with
4384  * caution as the C language standard provides no guarantees about the alignment or
4385  * atomicity of device memory accesses. The recommended practice for writing
4386  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4387  * alt_write_word() functions.
4388  *
4389  * The struct declaration for register ALT_SYSMGR_DMA_CTL.
4390  */
4392 {
4393  uint32_t chansel_0 : 1; /* Channel Select */
4394  uint32_t chansel_1 : 1; /* Channel Select */
4395  uint32_t chansel_2 : 1; /* Channel Select */
4396  uint32_t chansel_3 : 1; /* Channel Select */
4397  uint32_t mgrnonsecure : 1; /* Manager Thread Security */
4398  uint32_t irqnonsecure : 8; /* IRQ Security */
4399  uint32_t : 19; /* *UNDEFINED* */
4400 };
4401
4402 /* The typedef declaration for register ALT_SYSMGR_DMA_CTL. */
4403 typedef volatile struct ALT_SYSMGR_DMA_CTL_s ALT_SYSMGR_DMA_CTL_t;
4404 #endif /* __ASSEMBLY__ */
4405
4406 /* The byte offset of the ALT_SYSMGR_DMA_CTL register from the beginning of the component. */
4407 #define ALT_SYSMGR_DMA_CTL_OFST 0x0
4408
4409 /*
4410  * Register : Peripheral Security Register - persecurity
4411  *
4412  * Controls the security state of a peripheral request interface. Sampled by the
4413  * DMA controller when it exits from reset.
4414  *
4415  * These register bits should be updated during system initialization prior to
4416  * removing the DMA controller from reset. They may not be changed dynamically
4417  * during DMA operation.
4418  *
4419  * Register Layout
4420  *
4421  * Bits | Access | Reset | Description
4422  * :-------|:-------|:------|:----------------------
4423  * [31:0] | RW | 0x0 | Peripheral Non-Secure
4424  *
4425  */
4426 /*
4427  * Field : Peripheral Non-Secure - nonsecure
4428  *
4429  * If bit index [x] is 0, the DMA controller assigns peripheral request interface x
4430  * to the Secure state.
4431  *
4432  * If bit index [x] is 1, the DMA controller assigns peripheral request interface x
4433  * to the Non-secure state.
4434  *
4435  * Reset by a cold or warm reset.
4436  *
4437  * Field Access Macros:
4438  *
4439  */
4440 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
4441 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_LSB 0
4442 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
4443 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_MSB 31
4444 /* The width in bits of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
4445 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_WIDTH 32
4446 /* The mask used to set the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field value. */
4447 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_SET_MSK 0xffffffff
4448 /* The mask used to clear the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field value. */
4449 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_CLR_MSK 0x00000000
4450 /* The reset value of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
4451 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_RESET 0x0
4452 /* Extracts the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE field value from a register. */
4453 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_GET(value) (((value) & 0xffffffff) >> 0)
4454 /* Produces a ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field value suitable for setting the register. */
4455 #define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_SET(value) (((value) << 0) & 0xffffffff)
4456
4457 #ifndef __ASSEMBLY__
4458 /*
4459  * WARNING: The C register and register group struct declarations are provided for
4460  * convenience and illustrative purposes. They should, however, be used with
4461  * caution as the C language standard provides no guarantees about the alignment or
4462  * atomicity of device memory accesses. The recommended practice for writing
4463  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4464  * alt_write_word() functions.
4465  *
4466  * The struct declaration for register ALT_SYSMGR_DMA_PERSECURITY.
4467  */
4469 {
4470  uint32_t nonsecure : 32; /* Peripheral Non-Secure */
4471 };
4472
4473 /* The typedef declaration for register ALT_SYSMGR_DMA_PERSECURITY. */
4474 typedef volatile struct ALT_SYSMGR_DMA_PERSECURITY_s ALT_SYSMGR_DMA_PERSECURITY_t;
4475 #endif /* __ASSEMBLY__ */
4476
4477 /* The byte offset of the ALT_SYSMGR_DMA_PERSECURITY register from the beginning of the component. */
4478 #define ALT_SYSMGR_DMA_PERSECURITY_OFST 0x4
4479
4480 #ifndef __ASSEMBLY__
4481 /*
4482  * WARNING: The C register and register group struct declarations are provided for
4483  * convenience and illustrative purposes. They should, however, be used with
4484  * caution as the C language standard provides no guarantees about the alignment or
4485  * atomicity of device memory accesses. The recommended practice for writing
4486  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4487  * alt_write_word() functions.
4488  *
4489  * The struct declaration for register group ALT_SYSMGR_DMA.
4490  */
4492 {
4493  volatile ALT_SYSMGR_DMA_CTL_t ctrl; /* ALT_SYSMGR_DMA_CTL */
4494  volatile ALT_SYSMGR_DMA_PERSECURITY_t persecurity; /* ALT_SYSMGR_DMA_PERSECURITY */
4495 };
4496
4497 /* The typedef declaration for register group ALT_SYSMGR_DMA. */
4498 typedef volatile struct ALT_SYSMGR_DMA_s ALT_SYSMGR_DMA_t;
4499 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_DMA. */
4501 {
4502  volatile uint32_t ctrl; /* ALT_SYSMGR_DMA_CTL */
4503  volatile uint32_t persecurity; /* ALT_SYSMGR_DMA_PERSECURITY */
4504 };
4505
4506 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_DMA. */
4507 typedef volatile struct ALT_SYSMGR_DMA_raw_s ALT_SYSMGR_DMA_raw_t;
4508 #endif /* __ASSEMBLY__ */
4509
4510
4511 /*
4512  * Register Group : Preloader (initial software) Group - ALT_SYSMGR_ISW
4513  * Preloader (initial software) Group
4514  *
4515  * Registers used by preloader code and the OS.
4516  *
4517  * All registers are only reset by a cold reset (ignore warm reset).
4518  *
4519  */
4520 /*
4521  * Register : Preloader to OS Handoff Information - handoff
4522  *
4523  * These registers are used to store handoff infomation between the preloader and
4524  * the OS. These 8 registers can be used to store any information. The contents of
4525  * these registers have no impact on the state of the HPS hardware.
4526  *
4527  * Register Layout
4528  *
4529  * Bits | Access | Reset | Description
4530  * :-------|:-------|:------|:------------------------------
4531  * [31:0] | RW | 0x0 | Preloader Handoff Information
4532  *
4533  */
4534 /*
4535  * Field : Preloader Handoff Information - value
4536  *
4537  * Preloader Handoff Information.
4538  *
4539  * Field Access Macros:
4540  *
4541  */
4542 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
4543 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_LSB 0
4544 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
4545 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_MSB 31
4546 /* The width in bits of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
4547 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_WIDTH 32
4548 /* The mask used to set the ALT_SYSMGR_ISW_HANDOFF_VALUE register field value. */
4549 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_SET_MSK 0xffffffff
4550 /* The mask used to clear the ALT_SYSMGR_ISW_HANDOFF_VALUE register field value. */
4551 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_CLR_MSK 0x00000000
4552 /* The reset value of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
4553 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_RESET 0x0
4554 /* Extracts the ALT_SYSMGR_ISW_HANDOFF_VALUE field value from a register. */
4555 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
4556 /* Produces a ALT_SYSMGR_ISW_HANDOFF_VALUE register field value suitable for setting the register. */
4557 #define ALT_SYSMGR_ISW_HANDOFF_VALUE_SET(value) (((value) << 0) & 0xffffffff)
4558
4559 #ifndef __ASSEMBLY__
4560 /*
4561  * WARNING: The C register and register group struct declarations are provided for
4562  * convenience and illustrative purposes. They should, however, be used with
4563  * caution as the C language standard provides no guarantees about the alignment or
4564  * atomicity of device memory accesses. The recommended practice for writing
4565  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4566  * alt_write_word() functions.
4567  *
4568  * The struct declaration for register ALT_SYSMGR_ISW_HANDOFF.
4569  */
4571 {
4572  uint32_t value : 32; /* Preloader Handoff Information */
4573 };
4574
4575 /* The typedef declaration for register ALT_SYSMGR_ISW_HANDOFF. */
4576 typedef volatile struct ALT_SYSMGR_ISW_HANDOFF_s ALT_SYSMGR_ISW_HANDOFF_t;
4577 #endif /* __ASSEMBLY__ */
4578
4579 /* The byte offset of the ALT_SYSMGR_ISW_HANDOFF register from the beginning of the component. */
4580 #define ALT_SYSMGR_ISW_HANDOFF_OFST 0x0
4581
4582 #ifndef __ASSEMBLY__
4583 /*
4584  * WARNING: The C register and register group struct declarations are provided for
4585  * convenience and illustrative purposes. They should, however, be used with
4586  * caution as the C language standard provides no guarantees about the alignment or
4587  * atomicity of device memory accesses. The recommended practice for writing
4588  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4589  * alt_write_word() functions.
4590  *
4591  * The struct declaration for register group ALT_SYSMGR_ISW.
4592  */
4594 {
4595  volatile ALT_SYSMGR_ISW_HANDOFF_t handoff[8]; /* ALT_SYSMGR_ISW_HANDOFF */
4596 };
4597
4598 /* The typedef declaration for register group ALT_SYSMGR_ISW. */
4599 typedef volatile struct ALT_SYSMGR_ISW_s ALT_SYSMGR_ISW_t;
4600 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_ISW. */
4602 {
4603  volatile uint32_t handoff[8]; /* ALT_SYSMGR_ISW_HANDOFF */
4604 };
4605
4606 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ISW. */
4607 typedef volatile struct ALT_SYSMGR_ISW_raw_s ALT_SYSMGR_ISW_raw_t;
4608 #endif /* __ASSEMBLY__ */
4609
4610
4611 /*
4612  * Register Group : Boot ROM Code Register Group - ALT_SYSMGR_ROMCODE
4613  * Boot ROM Code Register Group
4614  *
4615  * Registers used by the Boot ROM code. All fields are only reset by a cold reset
4616  * (ignore warm reset).
4617  *
4618  */
4619 /*
4620  * Register : Control Register - ctrl
4621  *
4622  * Contains information used to control Boot ROM code.
4623  *
4624  * Register Layout
4625  *
4626  * Bits | Access | Reset | Description
4627  * :-------|:-------|:------|:-------------------------------------------
4628  * [0] | RW | 0x0 | Warm Reset Configure Pin Mux for Boot Pins
4629  * [1] | RW | 0x0 | Warm Reset Configure IOs for Boot Pins
4630  * [31:2] | ??? | 0x0 | *UNDEFINED*
4631  *
4632  */
4633 /*
4634  * Field : Warm Reset Configure Pin Mux for Boot Pins - warmrstcfgpinmux
4635  *
4636  * Specifies whether the Boot ROM code configures the pin mux for boot pins after a
4637  * warm reset. Note that the Boot ROM code always configures the pin mux for boot
4638  * pins after a cold reset. After the Boot ROM code configures the pin mux for boot
4639  * pins, it always disables this field. It is up to user software to enable this
4640  * field if it wants a different behavior.
4641  *
4642  * Field Enumeration Values:
4643  *
4644  * Enum | Value | Description
4645  * :-----------------------------------------------|:------|:----------------------------------------------
4646  * ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_DISD | 0x0 | Boot ROM code will not configure pin mux for
4647  * : | | boot pins after a warm reset
4648  * ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_END | 0x1 | Boot ROM code will configure pin mux for boot
4649  * : | | pins after a warm reset
4650  *
4651  * Field Access Macros:
4652  *
4653  */
4654 /*
4655  * Enumerated value for register field ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX
4656  *
4657  * Boot ROM code will not configure pin mux for boot pins after a warm reset
4658  */
4659 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_DISD 0x0
4660 /*
4661  * Enumerated value for register field ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX
4662  *
4663  * Boot ROM code will configure pin mux for boot pins after a warm reset
4664  */
4665 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_END 0x1
4666
4667 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
4668 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_LSB 0
4669 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
4670 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_MSB 0
4671 /* The width in bits of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
4672 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_WIDTH 1
4673 /* The mask used to set the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field value. */
4674 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_SET_MSK 0x00000001
4675 /* The mask used to clear the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field value. */
4676 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_CLR_MSK 0xfffffffe
4677 /* The reset value of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
4678 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_RESET 0x0
4679 /* Extracts the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX field value from a register. */
4680 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_GET(value) (((value) & 0x00000001) >> 0)
4681 /* Produces a ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field value suitable for setting the register. */
4682 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_SET(value) (((value) << 0) & 0x00000001)
4683
4684 /*
4685  * Field : Warm Reset Configure IOs for Boot Pins - warmrstcfgio
4686  *
4687  * Specifies whether the Boot ROM code configures the IOs used by boot after a warm
4688  * reset. Note that the Boot ROM code always configures the IOs used by boot after
4689  * a cold reset. After the Boot ROM code configures the IOs used by boot, it always
4690  * disables this field. It is up to user software to enable this field if it wants
4691  * a different behavior.
4692  *
4693  * Field Enumeration Values:
4694  *
4695  * Enum | Value | Description
4696  * :-------------------------------------------|:------|:----------------------------------------------
4697  * ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_DISD | 0x0 | Boot ROM code will not configure IOs used by
4698  * : | | boot after a warm reset
4699  * ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_END | 0x1 | Boot ROM code will configure IOs used by boot
4700  * : | | after a warm reset
4701  *
4702  * Field Access Macros:
4703  *
4704  */
4705 /*
4706  * Enumerated value for register field ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO
4707  *
4708  * Boot ROM code will not configure IOs used by boot after a warm reset
4709  */
4710 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_DISD 0x0
4711 /*
4712  * Enumerated value for register field ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO
4713  *
4714  * Boot ROM code will configure IOs used by boot after a warm reset
4715  */
4716 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_END 0x1
4717
4718 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
4719 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_LSB 1
4720 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
4721 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_MSB 1
4722 /* The width in bits of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
4723 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_WIDTH 1
4724 /* The mask used to set the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field value. */
4725 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_SET_MSK 0x00000002
4726 /* The mask used to clear the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field value. */
4727 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_CLR_MSK 0xfffffffd
4728 /* The reset value of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
4729 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_RESET 0x0
4730 /* Extracts the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO field value from a register. */
4731 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_GET(value) (((value) & 0x00000002) >> 1)
4732 /* Produces a ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field value suitable for setting the register. */
4733 #define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_SET(value) (((value) << 1) & 0x00000002)
4734
4735 #ifndef __ASSEMBLY__
4736 /*
4737  * WARNING: The C register and register group struct declarations are provided for
4738  * convenience and illustrative purposes. They should, however, be used with
4739  * caution as the C language standard provides no guarantees about the alignment or
4740  * atomicity of device memory accesses. The recommended practice for writing
4741  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4742  * alt_write_word() functions.
4743  *
4744  * The struct declaration for register ALT_SYSMGR_ROMCODE_CTL.
4745  */
4747 {
4748  uint32_t warmrstcfgpinmux : 1; /* Warm Reset Configure Pin Mux for Boot Pins */
4749  uint32_t warmrstcfgio : 1; /* Warm Reset Configure IOs for Boot Pins */
4750  uint32_t : 30; /* *UNDEFINED* */
4751 };
4752
4753 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_CTL. */
4754 typedef volatile struct ALT_SYSMGR_ROMCODE_CTL_s ALT_SYSMGR_ROMCODE_CTL_t;
4755 #endif /* __ASSEMBLY__ */
4756
4757 /* The byte offset of the ALT_SYSMGR_ROMCODE_CTL register from the beginning of the component. */
4758 #define ALT_SYSMGR_ROMCODE_CTL_OFST 0x0
4759
4760 /*
4761  * Register : CPU1 Start Address Register - cpu1startaddr
4762  *
4763  * When CPU1 is released from reset and the Boot ROM is located at the CPU1 reset
4764  * exception address (the typical case), the Boot ROM reset handler code reads the
4765  * address stored in this register and jumps it to hand off execution to user
4766  * software.
4767  *
4768  * Register Layout
4769  *
4770  * Bits | Access | Reset | Description
4771  * :-------|:-------|:------|:------------
4772  * [31:0] | RW | 0x0 | Address
4773  *
4774  */
4775 /*
4776  * Field : Address - value
4777  *
4778  * Address for CPU1 to start executing at after coming out of reset.
4779  *
4780  * Field Access Macros:
4781  *
4782  */
4783 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
4784 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_LSB 0
4785 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
4786 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_MSB 31
4787 /* The width in bits of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
4788 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_WIDTH 32
4789 /* The mask used to set the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field value. */
4790 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_SET_MSK 0xffffffff
4791 /* The mask used to clear the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field value. */
4792 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_CLR_MSK 0x00000000
4793 /* The reset value of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
4794 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_RESET 0x0
4795 /* Extracts the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE field value from a register. */
4796 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
4797 /* Produces a ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field value suitable for setting the register. */
4798 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_SET(value) (((value) << 0) & 0xffffffff)
4799
4800 #ifndef __ASSEMBLY__
4801 /*
4802  * WARNING: The C register and register group struct declarations are provided for
4803  * convenience and illustrative purposes. They should, however, be used with
4804  * caution as the C language standard provides no guarantees about the alignment or
4805  * atomicity of device memory accesses. The recommended practice for writing
4806  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4807  * alt_write_word() functions.
4808  *
4809  * The struct declaration for register ALT_SYSMGR_ROMCODE_CPU1STARTADDR.
4810  */
4812 {
4813  uint32_t value : 32; /* Address */
4814 };
4815
4816 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_CPU1STARTADDR. */
4817 typedef volatile struct ALT_SYSMGR_ROMCODE_CPU1STARTADDR_s ALT_SYSMGR_ROMCODE_CPU1STARTADDR_t;
4818 #endif /* __ASSEMBLY__ */
4819
4820 /* The byte offset of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR register from the beginning of the component. */
4821 #define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_OFST 0x4
4822
4823 /*
4824  * Register : Preloader (initial software) State Register - initswstate
4825  *
4826  * The preloader software (loaded by the Boot ROM) writes the magic value
4827  * 0x49535756 (ISWV in ASCII) to this register when it has reached a valid state.
4828  *
4829  * Register Layout
4830  *
4831  * Bits | Access | Reset | Description
4832  * :-------|:-------|:------|:------------
4833  * [31:0] | RW | 0x0 | Value
4834  *
4835  */
4836 /*
4837  * Field : Value - value
4838  *
4839  * Written with magic value.
4840  *
4841  * Field Enumeration Values:
4842  *
4843  * Enum | Value | Description
4844  * :-----------------------------------------------|:-----------|:------------
4845  * ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_INVALID | 0x0 |
4846  * ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_VALID | 0x49535756 |
4847  *
4848  * Field Access Macros:
4849  *
4850  */
4851 /*
4852  * Enumerated value for register field ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE
4853  *
4854  */
4855 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_INVALID 0x0
4856 /*
4857  * Enumerated value for register field ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE
4858  *
4859  */
4860 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_VALID 0x49535756
4861
4862 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
4863 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_LSB 0
4864 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
4865 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_MSB 31
4866 /* The width in bits of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
4867 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_WIDTH 32
4868 /* The mask used to set the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field value. */
4869 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_SET_MSK 0xffffffff
4870 /* The mask used to clear the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field value. */
4871 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_CLR_MSK 0x00000000
4872 /* The reset value of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
4873 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_RESET 0x0
4874 /* Extracts the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE field value from a register. */
4875 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
4876 /* Produces a ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field value suitable for setting the register. */
4877 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_SET(value) (((value) << 0) & 0xffffffff)
4878
4879 #ifndef __ASSEMBLY__
4880 /*
4881  * WARNING: The C register and register group struct declarations are provided for
4882  * convenience and illustrative purposes. They should, however, be used with
4883  * caution as the C language standard provides no guarantees about the alignment or
4884  * atomicity of device memory accesses. The recommended practice for writing
4885  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4886  * alt_write_word() functions.
4887  *
4888  * The struct declaration for register ALT_SYSMGR_ROMCODE_INITSWSTATE.
4889  */
4891 {
4892  uint32_t value : 32; /* Value */
4893 };
4894
4895 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_INITSWSTATE. */
4896 typedef volatile struct ALT_SYSMGR_ROMCODE_INITSWSTATE_s ALT_SYSMGR_ROMCODE_INITSWSTATE_t;
4897 #endif /* __ASSEMBLY__ */
4898
4899 /* The byte offset of the ALT_SYSMGR_ROMCODE_INITSWSTATE register from the beginning of the component. */
4900 #define ALT_SYSMGR_ROMCODE_INITSWSTATE_OFST 0x8
4901
4902 /*
4903  * Register : Preloader (initial software) Last Image Loaded Register - initswlastld
4904  *
4905  * Contains the index of the last preloader software image loaded by the Boot ROM
4906  * from the boot device.
4907  *
4908  * Register Layout
4909  *
4910  * Bits | Access | Reset | Description
4911  * :-------|:-------|:------|:------------
4912  * [1:0] | RW | 0x0 | Index
4913  * [31:2] | ??? | 0x0 | *UNDEFINED*
4914  *
4915  */
4916 /*
4917  * Field : Index - index
4918  *
4919  * Index of last image loaded.
4920  *
4921  * Field Access Macros:
4922  *
4923  */
4924 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
4925 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_LSB 0
4926 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
4927 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_MSB 1
4928 /* The width in bits of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
4929 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_WIDTH 2
4930 /* The mask used to set the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field value. */
4931 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_SET_MSK 0x00000003
4932 /* The mask used to clear the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field value. */
4933 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_CLR_MSK 0xfffffffc
4934 /* The reset value of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
4935 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_RESET 0x0
4936 /* Extracts the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX field value from a register. */
4937 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_GET(value) (((value) & 0x00000003) >> 0)
4938 /* Produces a ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field value suitable for setting the register. */
4939 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_SET(value) (((value) << 0) & 0x00000003)
4940
4941 #ifndef __ASSEMBLY__
4942 /*
4943  * WARNING: The C register and register group struct declarations are provided for
4944  * convenience and illustrative purposes. They should, however, be used with
4945  * caution as the C language standard provides no guarantees about the alignment or
4946  * atomicity of device memory accesses. The recommended practice for writing
4947  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4948  * alt_write_word() functions.
4949  *
4950  * The struct declaration for register ALT_SYSMGR_ROMCODE_INITSWLASTLD.
4951  */
4953 {
4954  uint32_t index : 2; /* Index */
4955  uint32_t : 30; /* *UNDEFINED* */
4956 };
4957
4958 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_INITSWLASTLD. */
4959 typedef volatile struct ALT_SYSMGR_ROMCODE_INITSWLASTLD_s ALT_SYSMGR_ROMCODE_INITSWLASTLD_t;
4960 #endif /* __ASSEMBLY__ */
4961
4962 /* The byte offset of the ALT_SYSMGR_ROMCODE_INITSWLASTLD register from the beginning of the component. */
4963 #define ALT_SYSMGR_ROMCODE_INITSWLASTLD_OFST 0xc
4964
4965 /*
4966  * Register : Boot ROM Software State Register - bootromswstate
4967  *
4968  * 32-bits general purpose register used by the Boot ROM code. Actual usage is
4969  * defined in the Boot ROM source code.
4970  *
4971  * Register Layout
4972  *
4973  * Bits | Access | Reset | Description
4974  * :-------|:-------|:------|:------------------------
4975  * [31:0] | RW | 0x0 | Boot ROM Software State
4976  *
4977  */
4978 /*
4979  * Field : Boot ROM Software State - value
4980  *
4981  * Reserved for Boot ROM use.
4982  *
4983  * Field Access Macros:
4984  *
4985  */
4986 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
4987 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_LSB 0
4988 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
4989 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_MSB 31
4990 /* The width in bits of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
4991 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_WIDTH 32
4992 /* The mask used to set the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field value. */
4993 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_SET_MSK 0xffffffff
4994 /* The mask used to clear the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field value. */
4995 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_CLR_MSK 0x00000000
4996 /* The reset value of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
4997 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_RESET 0x0
4998 /* Extracts the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE field value from a register. */
4999 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
5000 /* Produces a ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field value suitable for setting the register. */
5001 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_SET(value) (((value) << 0) & 0xffffffff)
5002
5003 #ifndef __ASSEMBLY__
5004 /*
5005  * WARNING: The C register and register group struct declarations are provided for
5006  * convenience and illustrative purposes. They should, however, be used with
5007  * caution as the C language standard provides no guarantees about the alignment or
5008  * atomicity of device memory accesses. The recommended practice for writing
5009  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5010  * alt_write_word() functions.
5011  *
5012  * The struct declaration for register ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE.
5013  */
5015 {
5016  uint32_t value : 32; /* Boot ROM Software State */
5017 };
5018
5019 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE. */
5020 typedef volatile struct ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_s ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_t;
5021 #endif /* __ASSEMBLY__ */
5022
5023 /* The byte offset of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE register from the beginning of the component. */
5024 #define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_OFST 0x10
5025
5026 /*
5027  * Register Group : Warm Boot from On-Chip RAM Group - ALT_SYSMGR_ROMCODE_WARMRAM
5028  * Warm Boot from On-Chip RAM Group
5029  *
5030  * Registers used by the Boot ROM code to support booting from the On-chip RAM on a
5031  * warm reset. All these registers must be written by user software before a warm
5032  * reset occurs to make use of this feature.
5033  *
5034  */
5035 /*
5036  * Register : Enable Register - enable
5037  *
5038  * Enables or disables the warm reset from On-chip RAM feature.
5039  *
5040  * Register Layout
5041  *
5042  * Bits | Access | Reset | Description
5043  * :-------|:-------|:------|:----------------------------
5044  * [31:0] | RW | 0x0 | Warm Reset from On-chip RAM
5045  *
5046  */
5047 /*
5048  * Field : Warm Reset from On-chip RAM - magic
5049  *
5050  * Controls whether Boot ROM will attempt to boot from the contents of the On-chip
5051  * RAM on a warm reset. When this feature is enabled, the Boot ROM code will not
5052  * configure boot IOs, the pin mux, or clocks.
5053  *
5054  * Note that the enable value is a 32-bit magic value (provided by the enum).
5055  *
5056  * Field Enumeration Values:
5057  *
5058  * Enum | Value | Description
5059  * :-------------------------------------------|:-----------|:------------------------------------------------
5060  * ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_DISD | 0x0 | Boot ROM code will not attempt to boot from On-
5061  * : | | chip RAM on a warm reset
5062  * ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_END | 0xae9efebc | Boot ROM code will attempt to boot from On-chip
5063  * : | | RAM on a warm reset
5064  *
5065  * Field Access Macros:
5066  *
5067  */
5068 /*
5069  * Enumerated value for register field ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC
5070  *
5071  * Boot ROM code will not attempt to boot from On-chip RAM on a warm reset
5072  */
5073 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_DISD 0x0
5074 /*
5075  * Enumerated value for register field ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC
5076  *
5077  * Boot ROM code will attempt to boot from On-chip RAM on a warm reset
5078  */
5079 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_END 0xae9efebc
5080
5081 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
5082 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_LSB 0
5083 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
5084 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_MSB 31
5085 /* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
5086 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_WIDTH 32
5087 /* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field value. */
5088 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_SET_MSK 0xffffffff
5089 /* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field value. */
5090 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_CLR_MSK 0x00000000
5091 /* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
5092 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_RESET 0x0
5093 /* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC field value from a register. */
5094 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_GET(value) (((value) & 0xffffffff) >> 0)
5095 /* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field value suitable for setting the register. */
5096 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_SET(value) (((value) << 0) & 0xffffffff)
5097
5098 #ifndef __ASSEMBLY__
5099 /*
5100  * WARNING: The C register and register group struct declarations are provided for
5101  * convenience and illustrative purposes. They should, however, be used with
5102  * caution as the C language standard provides no guarantees about the alignment or
5103  * atomicity of device memory accesses. The recommended practice for writing
5104  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5105  * alt_write_word() functions.
5106  *
5107  * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EN.
5108  */
5110 {
5111  uint32_t magic : 32; /* Warm Reset from On-chip RAM */
5112 };
5113
5114 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EN. */
5115 typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_EN_s ALT_SYSMGR_ROMCODE_WARMRAM_EN_t;
5116 #endif /* __ASSEMBLY__ */
5117
5118 /* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_EN register from the beginning of the component. */
5119 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_OFST 0x0
5120 /* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EN register. */
5121 #define ALT_SYSMGR_ROMCODE_WARMRAM_EN_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_EN_OFST))
5122
5123 /*
5124  * Register : Data Start Register - datastart
5125  *
5126  * Offset into On-chip RAM of the start of the region for CRC validation
5127  *
5128  * Register Layout
5129  *
5130  * Bits | Access | Reset | Description
5131  * :--------|:-------|:------|:------------------
5132  * [15:0] | RW | 0x0 | Data Start Offset
5133  * [31:16] | ??? | 0x0 | *UNDEFINED*
5134  *
5135  */
5136 /*
5137  * Field : Data Start Offset - offset
5138  *
5139  * Contains the byte offset into the On-chip RAM of the start of the On-chip RAM
5140  * region for the warm boot CRC validation. The offset must be an integer multiple
5141  * of 4 (i.e. aligned to a word). The Boot ROM code will set the top 16 bits to
5142  * 0xFFFF and clear the bottom 2 bits.
5143  *
5144  * Field Access Macros:
5145  *
5146  */
5147 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
5148 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_LSB 0
5149 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
5150 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_MSB 15
5151 /* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
5152 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_WIDTH 16
5153 /* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field value. */
5154 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_SET_MSK 0x0000ffff
5155 /* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field value. */
5156 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_CLR_MSK 0xffff0000
5157 /* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
5158 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_RESET 0x0
5159 /* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET field value from a register. */
5160 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_GET(value) (((value) & 0x0000ffff) >> 0)
5161 /* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field value suitable for setting the register. */
5162 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_SET(value) (((value) << 0) & 0x0000ffff)
5163
5164 #ifndef __ASSEMBLY__
5165 /*
5166  * WARNING: The C register and register group struct declarations are provided for
5167  * convenience and illustrative purposes. They should, however, be used with
5168  * caution as the C language standard provides no guarantees about the alignment or
5169  * atomicity of device memory accesses. The recommended practice for writing
5170  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5171  * alt_write_word() functions.
5172  *
5173  * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART.
5174  */
5176 {
5177  uint32_t offset : 16; /* Data Start Offset */
5178  uint32_t : 16; /* *UNDEFINED* */
5179 };
5180
5181 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART. */
5182 typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_s ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_t;
5183 #endif /* __ASSEMBLY__ */
5184
5185 /* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART register from the beginning of the component. */
5186 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFST 0x4
5187 /* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART register. */
5188 #define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFST))
5189
5190 /*
5191  * Register : Length Register - length
5192  *
5193  * Length of region in On-chip RAM for CRC validation.
5194  *
5195  * Register Layout
5196  *
5197  * Bits | Access | Reset | Description
5198  * :--------|:-------|:------|:------------
5199  * [15:0] | RW | 0x0 | Size
5200  * [31:16] | ??? | 0x0 | *UNDEFINED*
5201  *
5202  */
5203 /*
5204  * Field : Size - size
5205  *
5206  * Contains the length (in bytes) of the region in the On-chip RAM for the warm
5207  * boot CRC validation.
5208  *
5209  * If the length is 0, the Boot ROM won't perform CRC calculation and CRC check to
5210  * avoid overhead caused by CRC validation.
5211  *
5212  * If the START + LENGTH exceeds the maximum offset into the On-chip RAM, the Boot
5213  * ROM won't boot from the On-chip RAM.
5214  *
5215  * The length must be an integer multiple of 4.
5216  *
5217  * The Boot ROM code will clear the top 16 bits and the bottom 2 bits.
5218  *
5219  * Field Access Macros:
5220  *
5221  */
5222 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
5223 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_LSB 0
5224 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
5225 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_MSB 15
5226 /* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
5227 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_WIDTH 16
5228 /* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field value. */
5229 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_SET_MSK 0x0000ffff
5230 /* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field value. */
5231 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_CLR_MSK 0xffff0000
5232 /* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
5233 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_RESET 0x0
5234 /* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE field value from a register. */
5235 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_GET(value) (((value) & 0x0000ffff) >> 0)
5236 /* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field value suitable for setting the register. */
5237 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_SET(value) (((value) << 0) & 0x0000ffff)
5238
5239 #ifndef __ASSEMBLY__
5240 /*
5241  * WARNING: The C register and register group struct declarations are provided for
5242  * convenience and illustrative purposes. They should, however, be used with
5243  * caution as the C language standard provides no guarantees about the alignment or
5244  * atomicity of device memory accesses. The recommended practice for writing
5245  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5246  * alt_write_word() functions.
5247  *
5248  * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_LEN.
5249  */
5251 {
5252  uint32_t size : 16; /* Size */
5253  uint32_t : 16; /* *UNDEFINED* */
5254 };
5255
5256 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_LEN. */
5257 typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_LEN_s ALT_SYSMGR_ROMCODE_WARMRAM_LEN_t;
5258 #endif /* __ASSEMBLY__ */
5259
5260 /* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN register from the beginning of the component. */
5261 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_OFST 0x8
5262 /* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN register. */
5263 #define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_LEN_OFST))
5264
5265 /*
5266  * Register : Execution Register - execution
5267  *
5268  * Offset into On-chip RAM to enter to on a warm boot.
5269  *
5270  * Register Layout
5271  *
5272  * Bits | Access | Reset | Description
5273  * :--------|:-------|:------|:-----------------
5274  * [15:0] | RW | 0x0 | Execution Offset
5275  * [31:16] | ??? | 0x0 | *UNDEFINED*
5276  *
5277  */
5278 /*
5279  * Field : Execution Offset - offset
5280  *
5281  * Contains the byte offset into the On-chip RAM that the Boot ROM will jump to if
5282  * the CRC validation succeeds.
5283  *
5284  * The Boot ROM code will set the top 16 bits to 0xFFFF.
5285  *
5286  * Field Access Macros:
5287  *
5288  */
5289 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
5290 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_LSB 0
5291 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
5292 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_MSB 15
5293 /* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
5294 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_WIDTH 16
5295 /* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field value. */
5296 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_SET_MSK 0x0000ffff
5297 /* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field value. */
5298 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_CLR_MSK 0xffff0000
5299 /* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
5300 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_RESET 0x0
5301 /* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET field value from a register. */
5302 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_GET(value) (((value) & 0x0000ffff) >> 0)
5303 /* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field value suitable for setting the register. */
5304 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_SET(value) (((value) << 0) & 0x0000ffff)
5305
5306 #ifndef __ASSEMBLY__
5307 /*
5308  * WARNING: The C register and register group struct declarations are provided for
5309  * convenience and illustrative purposes. They should, however, be used with
5310  * caution as the C language standard provides no guarantees about the alignment or
5311  * atomicity of device memory accesses. The recommended practice for writing
5312  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5313  * alt_write_word() functions.
5314  *
5315  * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION.
5316  */
5318 {
5319  uint32_t offset : 16; /* Execution Offset */
5320  uint32_t : 16; /* *UNDEFINED* */
5321 };
5322
5323 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION. */
5324 typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_s ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_t;
5325 #endif /* __ASSEMBLY__ */
5326
5327 /* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION register from the beginning of the component. */
5328 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFST 0xc
5329 /* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION register. */
5330 #define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFST))
5331
5332 /*
5333  * Register : Expected CRC Register - crc
5334  *
5335  * Length of region in On-chip RAM for CRC validation.
5336  *
5337  * Register Layout
5338  *
5339  * Bits | Access | Reset | Description
5340  * :-------|:-------|:-----------|:-------------
5341  * [31:0] | RW | 0xe763552a | Expected CRC
5342  *
5343  */
5344 /*
5345  * Field : Expected CRC - expected
5346  *
5347  * Contains the expected CRC of the region in the On-chip RAM.The Boot ROM code
5348  * calculates the actual CRC for all bytes in the region specified by the DATA
5349  * START an LENGTH registers. The contents of the EXECUTION register (after it has
5350  * been read and modified by the Boot ROM code) is also included in the CRC
5351  * calculation. The contents of the EXECUTION register is added to the CRC
5352  * accumulator a byte at a time starting with the least significant byte. If the
5353  * actual CRC doesn't match the expected CRC value in this register, the Boot ROM
5354  * won't boot from the On-chip RAM.
5355  *
5356  * The CRC is a standard CRC32 with the polynomial:
5357  *
5358  * x^32 + x^26 + x^23 + x^22 + x^16 + x^12 + x^11 + x^10 + x^8 + x^7 + x^5 + x^4 +
5359  * x^2 + x + 1
5360  *
5361  * There is no reflection of the bits and the initial value of the remainder is
5362  * 0xFFFFFFFF and the final value is exclusive ORed with 0xFFFFFFFF.
5363  *
5364  * Field Access Macros:
5365  *
5366  */
5367 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
5368 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_LSB 0
5369 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
5370 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_MSB 31
5371 /* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
5372 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_WIDTH 32
5373 /* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field value. */
5374 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_SET_MSK 0xffffffff
5375 /* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field value. */
5376 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_CLR_MSK 0x00000000
5377 /* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
5378 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_RESET 0xe763552a
5379 /* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED field value from a register. */
5380 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_GET(value) (((value) & 0xffffffff) >> 0)
5381 /* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field value suitable for setting the register. */
5382 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_SET(value) (((value) << 0) & 0xffffffff)
5383
5384 #ifndef __ASSEMBLY__
5385 /*
5386  * WARNING: The C register and register group struct declarations are provided for
5387  * convenience and illustrative purposes. They should, however, be used with
5388  * caution as the C language standard provides no guarantees about the alignment or
5389  * atomicity of device memory accesses. The recommended practice for writing
5390  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5391  * alt_write_word() functions.
5392  *
5393  * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_CRC.
5394  */
5396 {
5397  uint32_t expected : 32; /* Expected CRC */
5398 };
5399
5400 /* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_CRC. */
5401 typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_CRC_s ALT_SYSMGR_ROMCODE_WARMRAM_CRC_t;
5402 #endif /* __ASSEMBLY__ */
5403
5404 /* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC register from the beginning of the component. */
5405 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_OFST 0x10
5406 /* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC register. */
5407 #define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_CRC_OFST))
5408
5409 #ifndef __ASSEMBLY__
5410 /*
5411  * WARNING: The C register and register group struct declarations are provided for
5412  * convenience and illustrative purposes. They should, however, be used with
5413  * caution as the C language standard provides no guarantees about the alignment or
5414  * atomicity of device memory accesses. The recommended practice for writing
5415  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5416  * alt_write_word() functions.
5417  *
5418  * The struct declaration for register group ALT_SYSMGR_ROMCODE_WARMRAM.
5419  */
5421 {
5422  volatile ALT_SYSMGR_ROMCODE_WARMRAM_EN_t enable; /* ALT_SYSMGR_ROMCODE_WARMRAM_EN */
5423  volatile ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_t datastart; /* ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART */
5424  volatile ALT_SYSMGR_ROMCODE_WARMRAM_LEN_t length; /* ALT_SYSMGR_ROMCODE_WARMRAM_LEN */
5425  volatile ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_t execution; /* ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION */
5426  volatile ALT_SYSMGR_ROMCODE_WARMRAM_CRC_t crc; /* ALT_SYSMGR_ROMCODE_WARMRAM_CRC */
5427  volatile uint32_t _pad_0x14_0x20[3]; /* *UNDEFINED* */
5428 };
5429
5430 /* The typedef declaration for register group ALT_SYSMGR_ROMCODE_WARMRAM. */
5431 typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_s ALT_SYSMGR_ROMCODE_WARMRAM_t;
5432 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE_WARMRAM. */
5434 {
5435  volatile uint32_t enable; /* ALT_SYSMGR_ROMCODE_WARMRAM_EN */
5436  volatile uint32_t datastart; /* ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART */
5437  volatile uint32_t length; /* ALT_SYSMGR_ROMCODE_WARMRAM_LEN */
5438  volatile uint32_t execution; /* ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION */
5439  volatile uint32_t crc; /* ALT_SYSMGR_ROMCODE_WARMRAM_CRC */
5440  volatile uint32_t _pad_0x14_0x20[3]; /* *UNDEFINED* */
5441 };
5442
5443 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE_WARMRAM. */
5444 typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_raw_s ALT_SYSMGR_ROMCODE_WARMRAM_raw_t;
5445 #endif /* __ASSEMBLY__ */
5446
5447
5448 #ifndef __ASSEMBLY__
5449 /*
5450  * WARNING: The C register and register group struct declarations are provided for
5451  * convenience and illustrative purposes. They should, however, be used with
5452  * caution as the C language standard provides no guarantees about the alignment or
5453  * atomicity of device memory accesses. The recommended practice for writing
5454  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5455  * alt_write_word() functions.
5456  *
5457  * The struct declaration for register group ALT_SYSMGR_ROMCODE.
5458  */
5460 {
5461  volatile ALT_SYSMGR_ROMCODE_CTL_t ctrl; /* ALT_SYSMGR_ROMCODE_CTL */
5462  volatile ALT_SYSMGR_ROMCODE_CPU1STARTADDR_t cpu1startaddr; /* ALT_SYSMGR_ROMCODE_CPU1STARTADDR */
5463  volatile ALT_SYSMGR_ROMCODE_INITSWSTATE_t initswstate; /* ALT_SYSMGR_ROMCODE_INITSWSTATE */
5464  volatile ALT_SYSMGR_ROMCODE_INITSWLASTLD_t initswlastld; /* ALT_SYSMGR_ROMCODE_INITSWLASTLD */
5465  volatile ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_t bootromswstate; /* ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE */
5466  volatile uint32_t _pad_0x14_0x1f[3]; /* *UNDEFINED* */
5467  volatile ALT_SYSMGR_ROMCODE_WARMRAM_t romcodegrp_warmramgrp; /* ALT_SYSMGR_ROMCODE_WARMRAM */
5468 };
5469
5470 /* The typedef declaration for register group ALT_SYSMGR_ROMCODE. */
5471 typedef volatile struct ALT_SYSMGR_ROMCODE_s ALT_SYSMGR_ROMCODE_t;
5472 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE. */
5474 {
5475  volatile uint32_t ctrl; /* ALT_SYSMGR_ROMCODE_CTL */
5476  volatile uint32_t cpu1startaddr; /* ALT_SYSMGR_ROMCODE_CPU1STARTADDR */
5477  volatile uint32_t initswstate; /* ALT_SYSMGR_ROMCODE_INITSWSTATE */
5478  volatile uint32_t initswlastld; /* ALT_SYSMGR_ROMCODE_INITSWLASTLD */
5479  volatile uint32_t bootromswstate; /* ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE */
5480  volatile uint32_t _pad_0x14_0x1f[3]; /* *UNDEFINED* */
5481  volatile ALT_SYSMGR_ROMCODE_WARMRAM_raw_t romcodegrp_warmramgrp; /* ALT_SYSMGR_ROMCODE_WARMRAM */
5482 };
5483
5484 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE. */
5485 typedef volatile struct ALT_SYSMGR_ROMCODE_raw_s ALT_SYSMGR_ROMCODE_raw_t;
5486 #endif /* __ASSEMBLY__ */
5487
5488
5489 /*
5490  * Register Group : Boot ROM Hardware Register Group - ALT_SYSMGR_ROMHW
5491  * Boot ROM Hardware Register Group
5492  *
5493  * Registers used by the Boot ROM hardware, not the code within it.
5494  *
5495  */
5496 /*
5497  * Register : Boot ROM Hardware Control Register - ctrl
5498  *
5499  * Controls behavior of Boot ROM hardware.
5500  *
5501  * All fields are only reset by a cold reset (ignore warm reset).
5502  *
5503  * Register Layout
5504  *
5505  * Bits | Access | Reset | Description
5506  * :-------|:-------|:------|:-----------------------------------
5507  * [0] | RW | 0x0 | Wait State
5508  * [1] | RW | 0x1 | Enable Safe Mode Warm Reset Update
5509  * [31:2] | ??? | 0x0 | *UNDEFINED*
5510  *
5511  */
5512 /*
5513  * Field : Wait State - waitstate
5514  *
5515  * Controls the number of wait states applied to the Boot ROM's read operation.
5516  *
5517  * This field is cleared on a cold reset and optionally updated by hardware upon
5518  * deassertion of warm reset.
5519  *
5520  * Field Enumeration Values:
5521  *
5522  * Enum | Value | Description
5523  * :-------------------------------------|:------|:-------------------------------------------------
5524  * ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_DIS | 0x0 | No wait states are applied to the Boom ROM's
5525  * : | | read operation.
5526  * ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_EN | 0x1 | A single wait state is applied to the Boot ROM's
5527  * : | | read operation.
5528  *
5529  * Field Access Macros:
5530  *
5531  */
5532 /*
5533  * Enumerated value for register field ALT_SYSMGR_ROMHW_CTL_WAITSTATE
5534  *
5535  * No wait states are applied to the Boom ROM's read operation.
5536  */
5537 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_DIS 0x0
5538 /*
5539  * Enumerated value for register field ALT_SYSMGR_ROMHW_CTL_WAITSTATE
5540  *
5541  * A single wait state is applied to the Boot ROM's read operation.
5542  */
5543 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_EN 0x1
5544
5545 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
5546 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_LSB 0
5547 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
5548 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_MSB 0
5549 /* The width in bits of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
5550 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_WIDTH 1
5551 /* The mask used to set the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field value. */
5552 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_SET_MSK 0x00000001
5553 /* The mask used to clear the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field value. */
5554 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_CLR_MSK 0xfffffffe
5555 /* The reset value of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
5556 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_RESET 0x0
5557 /* Extracts the ALT_SYSMGR_ROMHW_CTL_WAITSTATE field value from a register. */
5558 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_GET(value) (((value) & 0x00000001) >> 0)
5559 /* Produces a ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field value suitable for setting the register. */
5560 #define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_SET(value) (((value) << 0) & 0x00000001)
5561
5562 /*
5563  * Field : Enable Safe Mode Warm Reset Update - ensfmdwru
5564  *
5565  * Controls whether the wait state bit is updated upon deassertion of warm reset.
5566  *
5567  * This field is set on a cold reset.
5568  *
5569  * Field Enumeration Values:
5570  *
5571  * Enum | Value | Description
5572  * :-------------------------------------|:------|:-----------------------------------------------
5573  * ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_DIS | 0x0 | Wait state bit is not updated upon deassertion
5574  * : | | of warm reset.
5575  * ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_EN | 0x1 | Wait state bit is updated upon deassertion of
5576  * : | | warm reset. It's value is updated based on the
5577  * : | | control bit from clock manager which specifies
5578  * : | | whether clock manager will be in safe mode or
5579  * : | | not after warm reset.
5580  *
5581  * Field Access Macros:
5582  *
5583  */
5584 /*
5585  * Enumerated value for register field ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU
5586  *
5587  * Wait state bit is not updated upon deassertion of warm reset.
5588  */
5589 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_DIS 0x0
5590 /*
5591  * Enumerated value for register field ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU
5592  *
5593  * Wait state bit is updated upon deassertion of warm reset.
5594  *
5595  * It's value is updated based on the control bit from clock manager which
5596  * specifies whether clock manager will be in safe mode or not after warm reset.
5597  */
5598 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_EN 0x1
5599
5600 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
5601 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_LSB 1
5602 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
5603 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_MSB 1
5604 /* The width in bits of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
5605 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_WIDTH 1
5606 /* The mask used to set the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field value. */
5607 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_SET_MSK 0x00000002
5608 /* The mask used to clear the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field value. */
5609 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_CLR_MSK 0xfffffffd
5610 /* The reset value of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
5611 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_RESET 0x1
5612 /* Extracts the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU field value from a register. */
5613 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_GET(value) (((value) & 0x00000002) >> 1)
5614 /* Produces a ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field value suitable for setting the register. */
5615 #define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_SET(value) (((value) << 1) & 0x00000002)
5616
5617 #ifndef __ASSEMBLY__
5618 /*
5619  * WARNING: The C register and register group struct declarations are provided for
5620  * convenience and illustrative purposes. They should, however, be used with
5621  * caution as the C language standard provides no guarantees about the alignment or
5622  * atomicity of device memory accesses. The recommended practice for writing
5623  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5624  * alt_write_word() functions.
5625  *
5626  * The struct declaration for register ALT_SYSMGR_ROMHW_CTL.
5627  */
5629 {
5630  uint32_t waitstate : 1; /* Wait State */
5631  uint32_t ensfmdwru : 1; /* Enable Safe Mode Warm Reset Update */
5632  uint32_t : 30; /* *UNDEFINED* */
5633 };
5634
5635 /* The typedef declaration for register ALT_SYSMGR_ROMHW_CTL. */
5636 typedef volatile struct ALT_SYSMGR_ROMHW_CTL_s ALT_SYSMGR_ROMHW_CTL_t;
5637 #endif /* __ASSEMBLY__ */
5638
5639 /* The byte offset of the ALT_SYSMGR_ROMHW_CTL register from the beginning of the component. */
5640 #define ALT_SYSMGR_ROMHW_CTL_OFST 0x0
5641
5642 #ifndef __ASSEMBLY__
5643 /*
5644  * WARNING: The C register and register group struct declarations are provided for
5645  * convenience and illustrative purposes. They should, however, be used with
5646  * caution as the C language standard provides no guarantees about the alignment or
5647  * atomicity of device memory accesses. The recommended practice for writing
5648  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5649  * alt_write_word() functions.
5650  *
5651  * The struct declaration for register group ALT_SYSMGR_ROMHW.
5652  */
5654 {
5655  volatile ALT_SYSMGR_ROMHW_CTL_t ctrl; /* ALT_SYSMGR_ROMHW_CTL */
5656 };
5657
5658 /* The typedef declaration for register group ALT_SYSMGR_ROMHW. */
5659 typedef volatile struct ALT_SYSMGR_ROMHW_s ALT_SYSMGR_ROMHW_t;
5660 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_ROMHW. */
5662 {
5663  volatile uint32_t ctrl; /* ALT_SYSMGR_ROMHW_CTL */
5664 };
5665
5666 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ROMHW. */
5667 typedef volatile struct ALT_SYSMGR_ROMHW_raw_s ALT_SYSMGR_ROMHW_raw_t;
5668 #endif /* __ASSEMBLY__ */
5669
5670
5671 /*
5672  * Register Group : SDMMC Controller Group - ALT_SYSMGR_SDMMC
5673  * SDMMC Controller Group
5674  *
5675  * Registers related to SDMMC Controller which aren't located inside the SDMMC
5676  * itself.
5677  *
5678  */
5679 /*
5680  * Register : Control Register - ctrl
5681  *
5682  * Registers used by the SDMMC Controller. All fields are reset by a cold or warm
5683  * reset.
5684  *
5685  * Register Layout
5686  *
5687  * Bits | Access | Reset | Description
5688  * :-------|:-------|:------|:--------------------------------
5689  * [2:0] | RW | 0x0 | Drive Clock Phase Shift Select
5690  * [5:3] | RW | 0x0 | Sample Clock Phase Shift Select
5691  * [6] | RW | 0x0 | Feedback Clock Select
5692  * [31:7] | ??? | 0x0 | *UNDEFINED*
5693  *
5694  */
5695 /*
5696  * Field : Drive Clock Phase Shift Select - drvsel
5697  *
5698  * Select which phase shift of the clock for cclk_in_drv.
5699  *
5700  * Field Enumeration Values:
5701  *
5702  * Enum | Value | Description
5703  * :-----------------------------------------|:------|:--------------------------------------------
5704  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES0 | 0x0 | 0 degrees phase shifted clock is selected
5705  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES45 | 0x1 | 45 degrees phase shifted clock is selected
5706  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES90 | 0x2 | 90 degrees phase shifted clock is selected
5707  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES135 | 0x3 | 135 degrees phase shifted clock is selected
5708  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES180 | 0x4 | 180 degrees phase shifted clock is selected
5709  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES225 | 0x5 | 225 degrees phase shifted clock is selected
5710  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES270 | 0x6 | 270 degrees phase shifted clock is selected
5711  * ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES315 | 0x7 | 315 degrees phase shifted clock is selected
5712  *
5713  * Field Access Macros:
5714  *
5715  */
5716 /*
5717  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5718  *
5719  * 0 degrees phase shifted clock is selected
5720  */
5721 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES0 0x0
5722 /*
5723  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5724  *
5725  * 45 degrees phase shifted clock is selected
5726  */
5727 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES45 0x1
5728 /*
5729  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5730  *
5731  * 90 degrees phase shifted clock is selected
5732  */
5733 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES90 0x2
5734 /*
5735  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5736  *
5737  * 135 degrees phase shifted clock is selected
5738  */
5739 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES135 0x3
5740 /*
5741  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5742  *
5743  * 180 degrees phase shifted clock is selected
5744  */
5745 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES180 0x4
5746 /*
5747  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5748  *
5749  * 225 degrees phase shifted clock is selected
5750  */
5751 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES225 0x5
5752 /*
5753  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5754  *
5755  * 270 degrees phase shifted clock is selected
5756  */
5757 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES270 0x6
5758 /*
5759  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
5760  *
5761  * 315 degrees phase shifted clock is selected
5762  */
5763 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES315 0x7
5764
5765 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
5766 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_LSB 0
5767 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
5768 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_MSB 2
5769 /* The width in bits of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
5770 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_WIDTH 3
5771 /* The mask used to set the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field value. */
5772 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_SET_MSK 0x00000007
5773 /* The mask used to clear the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field value. */
5774 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_CLR_MSK 0xfffffff8
5775 /* The reset value of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
5776 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_RESET 0x0
5777 /* Extracts the ALT_SYSMGR_SDMMC_CTL_DRVSEL field value from a register. */
5778 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_GET(value) (((value) & 0x00000007) >> 0)
5779 /* Produces a ALT_SYSMGR_SDMMC_CTL_DRVSEL register field value suitable for setting the register. */
5780 #define ALT_SYSMGR_SDMMC_CTL_DRVSEL_SET(value) (((value) << 0) & 0x00000007)
5781
5782 /*
5783  * Field : Sample Clock Phase Shift Select - smplsel
5784  *
5785  * Select which phase shift of the clock for cclk_in_sample.
5786  *
5787  * Field Enumeration Values:
5788  *
5789  * Enum | Value | Description
5790  * :------------------------------------------|:------|:--------------------------------------------
5791  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES0 | 0x0 | 0 degrees phase shifted clock is selected
5792  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES45 | 0x1 | 45 degrees phase shifted clock is selected
5793  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES90 | 0x2 | 90 degrees phase shifted clock is selected
5794  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES135 | 0x3 | 135 degrees phase shifted clock is selected
5795  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES180 | 0x4 | 180 degrees phase shifted clock is selected
5796  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES225 | 0x5 | 225 degrees phase shifted clock is selected
5797  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES270 | 0x6 | 270 degrees phase shifted clock is selected
5798  * ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES315 | 0x7 | 315 degrees phase shifted clock is selected
5799  *
5800  * Field Access Macros:
5801  *
5802  */
5803 /*
5804  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5805  *
5806  * 0 degrees phase shifted clock is selected
5807  */
5808 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES0 0x0
5809 /*
5810  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5811  *
5812  * 45 degrees phase shifted clock is selected
5813  */
5814 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES45 0x1
5815 /*
5816  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5817  *
5818  * 90 degrees phase shifted clock is selected
5819  */
5820 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES90 0x2
5821 /*
5822  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5823  *
5824  * 135 degrees phase shifted clock is selected
5825  */
5826 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES135 0x3
5827 /*
5828  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5829  *
5830  * 180 degrees phase shifted clock is selected
5831  */
5832 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES180 0x4
5833 /*
5834  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5835  *
5836  * 225 degrees phase shifted clock is selected
5837  */
5838 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES225 0x5
5839 /*
5840  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5841  *
5842  * 270 degrees phase shifted clock is selected
5843  */
5844 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES270 0x6
5845 /*
5846  * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
5847  *
5848  * 315 degrees phase shifted clock is selected
5849  */
5850 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES315 0x7
5851
5852 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
5853 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_LSB 3
5854 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
5855 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_MSB 5
5856 /* The width in bits of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
5857 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_WIDTH 3
5858 /* The mask used to set the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field value. */
5859 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_SET_MSK 0x00000038
5860 /* The mask used to clear the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field value. */
5861 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_CLR_MSK 0xffffffc7
5862 /* The reset value of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
5863 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_RESET 0x0
5864 /* Extracts the ALT_SYSMGR_SDMMC_CTL_SMPLSEL field value from a register. */
5865 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_GET(value) (((value) & 0x00000038) >> 3)
5866 /* Produces a ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field value suitable for setting the register. */
5867 #define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_SET(value) (((value) << 3) & 0x00000038)
5868
5869 /*
5870  * Field : Feedback Clock Select - fbclksel
5871  *
5872  * Select which fb_clk to be used as cclk_in_sample.
5873  *
5874  * If 0, cclk_in_sample is driven by internal phase shifted cclk_in.
5875  *
5876  * If 1, cclk_in_sample is driven by fb_clk_in. No phase shifting is provided
5877  * internally on cclk_in_sample.
5878  *
5879  * Note: Using the feedback clock (setting this bit to 1) is not a supported use
5880  * model.
5881  *
5882  * Field Access Macros:
5883  *
5884  */
5885 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
5886 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_LSB 6
5887 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
5888 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_MSB 6
5889 /* The width in bits of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
5890 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_WIDTH 1
5891 /* The mask used to set the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field value. */
5892 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_SET_MSK 0x00000040
5893 /* The mask used to clear the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field value. */
5894 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_CLR_MSK 0xffffffbf
5895 /* The reset value of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
5896 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_RESET 0x0
5897 /* Extracts the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL field value from a register. */
5898 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_GET(value) (((value) & 0x00000040) >> 6)
5899 /* Produces a ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field value suitable for setting the register. */
5900 #define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_SET(value) (((value) << 6) & 0x00000040)
5901
5902 #ifndef __ASSEMBLY__
5903 /*
5904  * WARNING: The C register and register group struct declarations are provided for
5905  * convenience and illustrative purposes. They should, however, be used with
5906  * caution as the C language standard provides no guarantees about the alignment or
5907  * atomicity of device memory accesses. The recommended practice for writing
5908  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5909  * alt_write_word() functions.
5910  *
5911  * The struct declaration for register ALT_SYSMGR_SDMMC_CTL.
5912  */
5914 {
5915  uint32_t drvsel : 3; /* Drive Clock Phase Shift Select */
5916  uint32_t smplsel : 3; /* Sample Clock Phase Shift Select */
5917  uint32_t fbclksel : 1; /* Feedback Clock Select */
5918  uint32_t : 25; /* *UNDEFINED* */
5919 };
5920
5921 /* The typedef declaration for register ALT_SYSMGR_SDMMC_CTL. */
5922 typedef volatile struct ALT_SYSMGR_SDMMC_CTL_s ALT_SYSMGR_SDMMC_CTL_t;
5923 #endif /* __ASSEMBLY__ */
5924
5925 /* The byte offset of the ALT_SYSMGR_SDMMC_CTL register from the beginning of the component. */
5926 #define ALT_SYSMGR_SDMMC_CTL_OFST 0x0
5927
5928 /*
5929  * Register : SD/MMC L3 Master HPROT Register - l3master
5930  *
5931  * Controls the L3 master HPROT AHB-Lite signal.
5932  *
5933  * These register bits should be updated only during system initialization prior to
5934  * removing the peripheral from reset. They may not be changed dynamically during
5935  * peripheral operation
5936  *
5937  * All fields are reset by a cold or warm reset.
5938  *
5939  * Register Layout
5940  *
5941  * Bits | Access | Reset | Description
5942  * :-------|:-------|:------|:-------------------------
5943  * [0] | RW | 0x1 | SD/MMC HPROT Data/Opcode
5944  * [1] | RW | 0x1 | SD/MMC HPROT Privileged
5945  * [2] | RW | 0x0 | SD/MMC HPROT Bufferable
5946  * [3] | RW | 0x0 | SD/MMC HPROT Cacheable
5947  * [31:4] | ??? | 0x0 | *UNDEFINED*
5948  *
5949  */
5950 /*
5951  * Field : SD/MMC HPROT Data/Opcode - hprotdata_0
5952  *
5953  * Specifies if the L3 master access is for data or opcode for the SD/MMC module.
5954  *
5955  * Field Enumeration Values:
5956  *
5957  * Enum | Value | Description
5958  * :--------------------------------------------|:------|:-------------
5959  * ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_OPCODE | 0x0 | Opcode fetch
5960  * ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_DATA | 0x1 | Data access
5961  *
5962  * Field Access Macros:
5963  *
5964  */
5965 /*
5966  * Enumerated value for register field ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0
5967  *
5968  * Opcode fetch
5969  */
5970 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_OPCODE 0x0
5971 /*
5972  * Enumerated value for register field ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0
5973  *
5974  * Data access
5975  */
5976 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_DATA 0x1
5977
5978 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
5979 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_LSB 0
5980 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
5981 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_MSB 0
5982 /* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
5983 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_WIDTH 1
5984 /* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field value. */
5985 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_SET_MSK 0x00000001
5986 /* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field value. */
5987 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_CLR_MSK 0xfffffffe
5988 /* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
5989 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_RESET 0x1
5990 /* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 field value from a register. */
5991 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_GET(value) (((value) & 0x00000001) >> 0)
5992 /* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field value suitable for setting the register. */
5993 #define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_SET(value) (((value) << 0) & 0x00000001)
5994
5995 /*
5996  * Field : SD/MMC HPROT Privileged - hprotpriv_0
5997  *
5998  * If 1, L3 master accesses for the SD/MMC module are privileged.
5999  *
6000  * Field Access Macros:
6001  *
6002  */
6003 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
6004 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_LSB 1
6005 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
6006 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_MSB 1
6007 /* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
6008 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_WIDTH 1
6009 /* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field value. */
6010 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_SET_MSK 0x00000002
6011 /* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field value. */
6012 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_CLR_MSK 0xfffffffd
6013 /* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
6014 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_RESET 0x1
6015 /* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 field value from a register. */
6016 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_GET(value) (((value) & 0x00000002) >> 1)
6017 /* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field value suitable for setting the register. */
6018 #define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_SET(value) (((value) << 1) & 0x00000002)
6019
6020 /*
6021  * Field : SD/MMC HPROT Bufferable - hprotbuff_0
6022  *
6023  * If 1, L3 master accesses for the SD/MMC module are bufferable.
6024  *
6025  * Field Access Macros:
6026  *
6027  */
6028 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
6029 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_LSB 2
6030 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
6031 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_MSB 2
6032 /* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
6033 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_WIDTH 1
6034 /* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field value. */
6035 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_SET_MSK 0x00000004
6036 /* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field value. */
6037 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_CLR_MSK 0xfffffffb
6038 /* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
6039 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_RESET 0x0
6040 /* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 field value from a register. */
6041 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_GET(value) (((value) & 0x00000004) >> 2)
6042 /* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field value suitable for setting the register. */
6043 #define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_SET(value) (((value) << 2) & 0x00000004)
6044
6045 /*
6046  * Field : SD/MMC HPROT Cacheable - hprotcache_0
6047  *
6048  * If 1, L3 master accesses for the SD/MMC module are cacheable.
6049  *
6050  * Field Access Macros:
6051  *
6052  */
6053 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
6054 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_LSB 3
6055 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
6056 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_MSB 3
6057 /* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
6058 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_WIDTH 1
6059 /* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field value. */
6060 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_SET_MSK 0x00000008
6061 /* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field value. */
6062 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_CLR_MSK 0xfffffff7
6063 /* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
6064 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_RESET 0x0
6065 /* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 field value from a register. */
6066 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_GET(value) (((value) & 0x00000008) >> 3)
6067 /* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field value suitable for setting the register. */
6068 #define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_SET(value) (((value) << 3) & 0x00000008)
6069
6070 #ifndef __ASSEMBLY__
6071 /*
6072  * WARNING: The C register and register group struct declarations are provided for
6073  * convenience and illustrative purposes. They should, however, be used with
6074  * caution as the C language standard provides no guarantees about the alignment or
6075  * atomicity of device memory accesses. The recommended practice for writing
6076  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6077  * alt_write_word() functions.
6078  *
6079  * The struct declaration for register ALT_SYSMGR_SDMMC_L3MST.
6080  */
6082 {
6083  uint32_t hprotdata_0 : 1; /* SD/MMC HPROT Data/Opcode */
6084  uint32_t hprotpriv_0 : 1; /* SD/MMC HPROT Privileged */
6085  uint32_t hprotbuff_0 : 1; /* SD/MMC HPROT Bufferable */
6086  uint32_t hprotcache_0 : 1; /* SD/MMC HPROT Cacheable */
6087  uint32_t : 28; /* *UNDEFINED* */
6088 };
6089
6090 /* The typedef declaration for register ALT_SYSMGR_SDMMC_L3MST. */
6091 typedef volatile struct ALT_SYSMGR_SDMMC_L3MST_s ALT_SYSMGR_SDMMC_L3MST_t;
6092 #endif /* __ASSEMBLY__ */
6093
6094 /* The byte offset of the ALT_SYSMGR_SDMMC_L3MST register from the beginning of the component. */
6095 #define ALT_SYSMGR_SDMMC_L3MST_OFST 0x4
6096
6097 #ifndef __ASSEMBLY__
6098 /*
6099  * WARNING: The C register and register group struct declarations are provided for
6100  * convenience and illustrative purposes. They should, however, be used with
6101  * caution as the C language standard provides no guarantees about the alignment or
6102  * atomicity of device memory accesses. The recommended practice for writing
6103  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6104  * alt_write_word() functions.
6105  *
6106  * The struct declaration for register group ALT_SYSMGR_SDMMC.
6107  */
6109 {
6110  volatile ALT_SYSMGR_SDMMC_CTL_t ctrl; /* ALT_SYSMGR_SDMMC_CTL */
6111  volatile ALT_SYSMGR_SDMMC_L3MST_t l3master; /* ALT_SYSMGR_SDMMC_L3MST */
6112 };
6113
6114 /* The typedef declaration for register group ALT_SYSMGR_SDMMC. */
6115 typedef volatile struct ALT_SYSMGR_SDMMC_s ALT_SYSMGR_SDMMC_t;
6116 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_SDMMC. */
6118 {
6119  volatile uint32_t ctrl; /* ALT_SYSMGR_SDMMC_CTL */
6120  volatile uint32_t l3master; /* ALT_SYSMGR_SDMMC_L3MST */
6121 };
6122
6123 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_SDMMC. */
6124 typedef volatile struct ALT_SYSMGR_SDMMC_raw_s ALT_SYSMGR_SDMMC_raw_t;
6125 #endif /* __ASSEMBLY__ */
6126
6127
6128 /*
6129  * Register Group : NAND Flash Controller Register Group - ALT_SYSMGR_NAND
6130  * NAND Flash Controller Register Group
6131  *
6132  * Registers related to NAND Flash Controller which aren't located in the NAND
6133  * Flash Controller itself.
6134  *
6135  */
6136 /*
6137  * Register : Bootstrap Control Register - bootstrap
6138  *
6139  * Bootstrap fields sampled by NAND Flash Controller when released from reset.
6140  *
6141  * All fields are reset by a cold or warm reset.
6142  *
6143  * Register Layout
6144  *
6145  * Bits | Access | Reset | Description
6146  * :-------|:-------|:------|:--------------------------------------
6147  * [0] | RW | 0x0 | Bootstrap Inhibit Initialization
6148  * [1] | RW | 0x0 | Bootstrap 512 Byte Device
6149  * [2] | RW | 0x0 | Bootstrap Inhibit Load Block 0 Page 0
6150  * [3] | RW | 0x0 | Bootstrap Two Row Address Cycles
6151  * [31:4] | ??? | 0x0 | *UNDEFINED*
6152  *
6153  */
6154 /*
6155  * Field : Bootstrap Inhibit Initialization - noinit
6156  *
6157  * If 1, inhibits NAND Flash Controller from performing initialization when coming
6158  * out of reset. Instead, software must program all registers pertaining to device
6159  * parameters like page size, width, etc.
6160  *
6161  * Field Access Macros:
6162  *
6163  */
6164 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
6165 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_LSB 0
6166 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
6167 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_MSB 0
6168 /* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
6169 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_WIDTH 1
6170 /* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field value. */
6171 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_SET_MSK 0x00000001
6172 /* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field value. */
6173 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_CLR_MSK 0xfffffffe
6174 /* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
6175 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_RESET 0x0
6176 /* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT field value from a register. */
6177 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_GET(value) (((value) & 0x00000001) >> 0)
6178 /* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field value suitable for setting the register. */
6179 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_SET(value) (((value) << 0) & 0x00000001)
6180
6181 /*
6182  * Field : Bootstrap 512 Byte Device - page512
6183  *
6184  * If 1, NAND device has a 512 byte page size.
6185  *
6186  * Field Access Macros:
6187  *
6188  */
6189 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
6190 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_LSB 1
6191 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
6192 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_MSB 1
6193 /* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
6194 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_WIDTH 1
6195 /* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field value. */
6196 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_SET_MSK 0x00000002
6197 /* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field value. */
6198 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_CLR_MSK 0xfffffffd
6199 /* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
6200 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_RESET 0x0
6201 /* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 field value from a register. */
6202 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_GET(value) (((value) & 0x00000002) >> 1)
6203 /* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field value suitable for setting the register. */
6204 #define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_SET(value) (((value) << 1) & 0x00000002)
6205
6206 /*
6207  * Field : Bootstrap Inhibit Load Block 0 Page 0 - noloadb0p0
6208  *
6209  * If 1, inhibits NAND Flash Controller from loading page 0 of block 0 of the NAND
6210  * device as part of the initialization procedure.
6211  *
6212  * Field Access Macros:
6213  *
6214  */
6215 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
6216 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_LSB 2
6217 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
6218 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_MSB 2
6219 /* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
6220 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_WIDTH 1
6221 /* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field value. */
6222 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_SET_MSK 0x00000004
6223 /* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field value. */
6224 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_CLR_MSK 0xfffffffb
6225 /* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
6226 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_RESET 0x0
6227 /* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 field value from a register. */
6228 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_GET(value) (((value) & 0x00000004) >> 2)
6229 /* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field value suitable for setting the register. */
6230 #define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_SET(value) (((value) << 2) & 0x00000004)
6231
6232 /*
6233  * Field : Bootstrap Two Row Address Cycles - tworowaddr
6234  *
6235  * If 1, NAND device requires only 2 row address cycles instead of the normal 3 row
6236  * address cycles.
6237  *
6238  * Field Access Macros:
6239  *
6240  */
6241 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
6242 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_LSB 3
6243 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
6244 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_MSB 3
6245 /* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
6246 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_WIDTH 1
6247 /* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field value. */
6248 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_SET_MSK 0x00000008
6249 /* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field value. */
6250 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_CLR_MSK 0xfffffff7
6251 /* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
6252 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_RESET 0x0
6253 /* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR field value from a register. */
6254 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_GET(value) (((value) & 0x00000008) >> 3)
6255 /* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field value suitable for setting the register. */
6256 #define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_SET(value) (((value) << 3) & 0x00000008)
6257
6258 #ifndef __ASSEMBLY__
6259 /*
6260  * WARNING: The C register and register group struct declarations are provided for
6261  * convenience and illustrative purposes. They should, however, be used with
6262  * caution as the C language standard provides no guarantees about the alignment or
6263  * atomicity of device memory accesses. The recommended practice for writing
6264  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6265  * alt_write_word() functions.
6266  *
6267  * The struct declaration for register ALT_SYSMGR_NAND_BOOTSTRAP.
6268  */
6270 {
6271  uint32_t noinit : 1; /* Bootstrap Inhibit Initialization */
6272  uint32_t page512 : 1; /* Bootstrap 512 Byte Device */
6273  uint32_t noloadb0p0 : 1; /* Bootstrap Inhibit Load Block 0 Page 0 */
6274  uint32_t tworowaddr : 1; /* Bootstrap Two Row Address Cycles */
6275  uint32_t : 28; /* *UNDEFINED* */
6276 };
6277
6278 /* The typedef declaration for register ALT_SYSMGR_NAND_BOOTSTRAP. */
6279 typedef volatile struct ALT_SYSMGR_NAND_BOOTSTRAP_s ALT_SYSMGR_NAND_BOOTSTRAP_t;
6280 #endif /* __ASSEMBLY__ */
6281
6282 /* The byte offset of the ALT_SYSMGR_NAND_BOOTSTRAP register from the beginning of the component. */
6283 #define ALT_SYSMGR_NAND_BOOTSTRAP_OFST 0x0
6284
6285 /*
6286  * Register : NAND L3 Master AxCACHE Register - l3master
6287  *
6288  * Controls the L3 master ARCACHE and AWCACHE AXI signals.
6289  *
6290  * These register bits should be updated only during system initialization prior to
6291  * removing the peripheral from reset. They may not be changed dynamically during
6292  * peripheral operation
6293  *
6294  * All fields are reset by a cold or warm reset.
6295  *
6296  * Register Layout
6297  *
6298  * Bits | Access | Reset | Description
6299  * :-------|:-------|:------|:-------------
6300  * [3:0] | RW | 0x0 | NAND ARCACHE
6301  * [7:4] | RW | 0x0 | NAND AWCACHE
6302  * [31:8] | ??? | 0x0 | *UNDEFINED*
6303  *
6304  */
6305 /*
6306  * Field : NAND ARCACHE - arcache_0
6307  *
6308  * Specifies the value of the module ARCACHE signal.
6309  *
6310  * Field Enumeration Values:
6311  *
6312  * Enum | Value | Description
6313  * :-------------------------------------------------------|:------|:-------------------------------------------------
6314  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF | 0x0 | Noncacheable and nonbufferable.
6315  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_BUFF | 0x1 | Bufferable only.
6316  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_NONALLOC | 0x2 | Cacheable, but do not allocate.
6317  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC | 0x3 | Cacheable and bufferable, but do not allocate.
6318  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD1 | 0x4 | Reserved.
6319  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD2 | 0x5 | Reserved.
6320  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6 | Cacheable write-through, allocate on reads only.
6321  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7 | Cacheable write-back, allocate on reads only.
6322  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD3 | 0x8 | Reserved.
6323  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD4 | 0x9 | Reserved.
6324  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa | Cacheable write-through, allocate on writes
6325  * : | | only.
6326  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb | Cacheable write-back, allocate on writes only.
6327  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD5 | 0xc | Reserved.
6328  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD6 | 0xd | Reserved.
6329  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC | 0xe | Cacheable write-through, allocate on both reads
6330  * : | | and writes.
6331  * ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC | 0xf | Cacheable write-back, allocate on both reads and
6332  * : | | writes.
6333  *
6334  * Field Access Macros:
6335  *
6336  */
6337 /*
6338  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6339  *
6340  * Noncacheable and nonbufferable.
6341  */
6342 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF 0x0
6343 /*
6344  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6345  *
6346  * Bufferable only.
6347  */
6348 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_BUFF 0x1
6349 /*
6350  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6351  *
6352  * Cacheable, but do not allocate.
6353  */
6354 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_NONALLOC 0x2
6355 /*
6356  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6357  *
6358  * Cacheable and bufferable, but do not allocate.
6359  */
6360 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC 0x3
6361 /*
6362  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6363  *
6364  * Reserved.
6365  */
6366 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD1 0x4
6367 /*
6368  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6369  *
6370  * Reserved.
6371  */
6372 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD2 0x5
6373 /*
6374  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6375  *
6376  * Cacheable write-through, allocate on reads only.
6377  */
6378 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC 0x6
6379 /*
6380  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6381  *
6382  * Cacheable write-back, allocate on reads only.
6383  */
6384 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC 0x7
6385 /*
6386  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6387  *
6388  * Reserved.
6389  */
6390 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD3 0x8
6391 /*
6392  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6393  *
6394  * Reserved.
6395  */
6396 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD4 0x9
6397 /*
6398  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6399  *
6400  * Cacheable write-through, allocate on writes only.
6401  */
6402 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC 0xa
6403 /*
6404  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6405  *
6406  * Cacheable write-back, allocate on writes only.
6407  */
6408 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC 0xb
6409 /*
6410  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6411  *
6412  * Reserved.
6413  */
6414 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD5 0xc
6415 /*
6416  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6417  *
6418  * Reserved.
6419  */
6420 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD6 0xd
6421 /*
6422  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6423  *
6424  * Cacheable write-through, allocate on both reads and writes.
6425  */
6426 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC 0xe
6427 /*
6428  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
6429  *
6430  * Cacheable write-back, allocate on both reads and writes.
6431  */
6432 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC 0xf
6433
6434 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
6435 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_LSB 0
6436 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
6437 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_MSB 3
6438 /* The width in bits of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
6439 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_WIDTH 4
6440 /* The mask used to set the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field value. */
6441 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_SET_MSK 0x0000000f
6442 /* The mask used to clear the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field value. */
6443 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_CLR_MSK 0xfffffff0
6444 /* The reset value of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
6445 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_RESET 0x0
6446 /* Extracts the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 field value from a register. */
6447 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_GET(value) (((value) & 0x0000000f) >> 0)
6448 /* Produces a ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field value suitable for setting the register. */
6449 #define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_SET(value) (((value) << 0) & 0x0000000f)
6450
6451 /*
6452  * Field : NAND AWCACHE - awcache_0
6453  *
6454  * Specifies the value of the module AWCACHE signal.
6455  *
6456  * Field Enumeration Values:
6457  *
6458  * Enum | Value | Description
6459  * :-------------------------------------------------------|:------|:-------------------------------------------------
6460  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF | 0x0 | Noncacheable and nonbufferable.
6461  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_BUFF | 0x1 | Bufferable only.
6462  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_NONALLOC | 0x2 | Cacheable, but do not allocate.
6463  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC | 0x3 | Cacheable and bufferable, but do not allocate.
6464  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD1 | 0x4 | Reserved.
6465  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD2 | 0x5 | Reserved.
6466  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6 | Cacheable write-through, allocate on reads only.
6467  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7 | Cacheable write-back, allocate on reads only.
6468  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD3 | 0x8 | Reserved.
6469  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD4 | 0x9 | Reserved.
6470  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa | Cacheable write-through, allocate on writes
6471  * : | | only.
6472  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb | Cacheable write-back, allocate on writes only.
6473  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD5 | 0xc | Reserved.
6474  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD6 | 0xd | Reserved.
6475  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC | 0xe | Cacheable write-through, allocate on both reads
6476  * : | | and writes.
6477  * ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC | 0xf | Cacheable write-back, allocate on both reads and
6478  * : | | writes.
6479  *
6480  * Field Access Macros:
6481  *
6482  */
6483 /*
6484  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6485  *
6486  * Noncacheable and nonbufferable.
6487  */
6488 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF 0x0
6489 /*
6490  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6491  *
6492  * Bufferable only.
6493  */
6494 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_BUFF 0x1
6495 /*
6496  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6497  *
6498  * Cacheable, but do not allocate.
6499  */
6500 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_NONALLOC 0x2
6501 /*
6502  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6503  *
6504  * Cacheable and bufferable, but do not allocate.
6505  */
6506 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC 0x3
6507 /*
6508  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6509  *
6510  * Reserved.
6511  */
6512 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD1 0x4
6513 /*
6514  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6515  *
6516  * Reserved.
6517  */
6518 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD2 0x5
6519 /*
6520  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6521  *
6522  * Cacheable write-through, allocate on reads only.
6523  */
6524 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC 0x6
6525 /*
6526  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6527  *
6528  * Cacheable write-back, allocate on reads only.
6529  */
6530 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC 0x7
6531 /*
6532  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6533  *
6534  * Reserved.
6535  */
6536 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD3 0x8
6537 /*
6538  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6539  *
6540  * Reserved.
6541  */
6542 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD4 0x9
6543 /*
6544  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6545  *
6546  * Cacheable write-through, allocate on writes only.
6547  */
6548 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC 0xa
6549 /*
6550  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6551  *
6552  * Cacheable write-back, allocate on writes only.
6553  */
6554 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC 0xb
6555 /*
6556  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6557  *
6558  * Reserved.
6559  */
6560 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD5 0xc
6561 /*
6562  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6563  *
6564  * Reserved.
6565  */
6566 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD6 0xd
6567 /*
6568  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6569  *
6570  * Cacheable write-through, allocate on both reads and writes.
6571  */
6572 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC 0xe
6573 /*
6574  * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
6575  *
6576  * Cacheable write-back, allocate on both reads and writes.
6577  */
6578 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC 0xf
6579
6580 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
6581 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_LSB 4
6582 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
6583 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_MSB 7
6584 /* The width in bits of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
6585 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_WIDTH 4
6586 /* The mask used to set the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field value. */
6587 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_SET_MSK 0x000000f0
6588 /* The mask used to clear the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field value. */
6589 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_CLR_MSK 0xffffff0f
6590 /* The reset value of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
6591 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_RESET 0x0
6592 /* Extracts the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 field value from a register. */
6593 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_GET(value) (((value) & 0x000000f0) >> 4)
6594 /* Produces a ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field value suitable for setting the register. */
6595 #define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_SET(value) (((value) << 4) & 0x000000f0)
6596
6597 #ifndef __ASSEMBLY__
6598 /*
6599  * WARNING: The C register and register group struct declarations are provided for
6600  * convenience and illustrative purposes. They should, however, be used with
6601  * caution as the C language standard provides no guarantees about the alignment or
6602  * atomicity of device memory accesses. The recommended practice for writing
6603  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6604  * alt_write_word() functions.
6605  *
6606  * The struct declaration for register ALT_SYSMGR_NAND_L3MST.
6607  */
6609 {
6610  uint32_t arcache_0 : 4; /* NAND ARCACHE */
6611  uint32_t awcache_0 : 4; /* NAND AWCACHE */
6612  uint32_t : 24; /* *UNDEFINED* */
6613 };
6614
6615 /* The typedef declaration for register ALT_SYSMGR_NAND_L3MST. */
6616 typedef volatile struct ALT_SYSMGR_NAND_L3MST_s ALT_SYSMGR_NAND_L3MST_t;
6617 #endif /* __ASSEMBLY__ */
6618
6619 /* The byte offset of the ALT_SYSMGR_NAND_L3MST register from the beginning of the component. */
6620 #define ALT_SYSMGR_NAND_L3MST_OFST 0x4
6621
6622 #ifndef __ASSEMBLY__
6623 /*
6624  * WARNING: The C register and register group struct declarations are provided for
6625  * convenience and illustrative purposes. They should, however, be used with
6626  * caution as the C language standard provides no guarantees about the alignment or
6627  * atomicity of device memory accesses. The recommended practice for writing
6628  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6629  * alt_write_word() functions.
6630  *
6631  * The struct declaration for register group ALT_SYSMGR_NAND.
6632  */
6634 {
6635  volatile ALT_SYSMGR_NAND_BOOTSTRAP_t bootstrap; /* ALT_SYSMGR_NAND_BOOTSTRAP */
6636  volatile ALT_SYSMGR_NAND_L3MST_t l3master; /* ALT_SYSMGR_NAND_L3MST */
6637 };
6638
6639 /* The typedef declaration for register group ALT_SYSMGR_NAND. */
6640 typedef volatile struct ALT_SYSMGR_NAND_s ALT_SYSMGR_NAND_t;
6641 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_NAND. */
6643 {
6644  volatile uint32_t bootstrap; /* ALT_SYSMGR_NAND_BOOTSTRAP */
6645  volatile uint32_t l3master; /* ALT_SYSMGR_NAND_L3MST */
6646 };
6647
6648 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_NAND. */
6649 typedef volatile struct ALT_SYSMGR_NAND_raw_s ALT_SYSMGR_NAND_raw_t;
6650 #endif /* __ASSEMBLY__ */
6651
6652
6653 /*
6654  * Register Group : USB Controller Group - ALT_SYSMGR_USB
6655  * USB Controller Group
6656  *
6657  * Registers related to USB Controllers which aren't located inside the USB
6658  * controllers themselves.
6659  *
6660  */
6661 /*
6662  * Register : USB L3 Master HPROT Register - l3master
6663  *
6664  * Controls the L3 master HPROT AHB-Lite signal.
6665  *
6666  * These register bits should be updated only during system initialization prior to
6667  * removing the peripheral from reset. They may not be changed dynamically during
6668  * peripheral operation
6669  *
6670  * All fields are reset by a cold or warm reset.
6671  *
6672  * Register Layout
6673  *
6674  * Bits | Access | Reset | Description
6675  * :-------|:-------|:------|:----------------------
6676  * [0] | RW | 0x1 | USB HPROT Data/Opcode
6677  * [1] | RW | 0x1 | USB HPROT Data/Opcode
6678  * [2] | RW | 0x1 | USB HPROT Privileged
6679  * [3] | RW | 0x1 | USB HPROT Privileged
6680  * [4] | RW | 0x0 | USB HPROT Bufferable
6681  * [5] | RW | 0x0 | USB HPROT Bufferable
6682  * [6] | RW | 0x0 | USB HPROT Cacheable
6683  * [7] | RW | 0x0 | USB HPROT Cacheable
6684  * [31:8] | ??? | 0x0 | *UNDEFINED*
6685  *
6686  */
6687 /*
6688  * Field : USB HPROT Data/Opcode - hprotdata_0
6689  *
6690  * Specifies if the L3 master access is for data or opcode for the USB modules.
6691  *
6692  * The field array index corresponds to the USB index.
6693  *
6694  * Field Enumeration Values:
6695  *
6696  * Enum | Value | Description
6697  * :------------------------------------------|:------|:-------------
6698  * ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_OPCODE | 0x0 | Opcode fetch
6699  * ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_DATA | 0x1 | Data access
6700  *
6701  * Field Access Macros:
6702  *
6703  */
6704 /*
6705  * Enumerated value for register field ALT_SYSMGR_USB_L3MST_HPROTDATA_0
6706  *
6707  * Opcode fetch
6708  */
6709 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_OPCODE 0x0
6710 /*
6711  * Enumerated value for register field ALT_SYSMGR_USB_L3MST_HPROTDATA_0
6712  *
6713  * Data access
6714  */
6715 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_DATA 0x1
6716
6717 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
6718 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_LSB 0
6719 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
6720 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_MSB 0
6721 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
6722 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_WIDTH 1
6723 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field value. */
6724 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_SET_MSK 0x00000001
6725 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field value. */
6726 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_CLR_MSK 0xfffffffe
6727 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
6728 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_RESET 0x1
6729 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 field value from a register. */
6730 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_GET(value) (((value) & 0x00000001) >> 0)
6731 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field value suitable for setting the register. */
6732 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_SET(value) (((value) << 0) & 0x00000001)
6733
6734 /*
6735  * Field : USB HPROT Data/Opcode - hprotdata_1
6736  *
6737  * Specifies if the L3 master access is for data or opcode for the USB modules.
6738  *
6739  * The field array index corresponds to the USB index.
6740  *
6741  * Field Enumeration Values:
6742  *
6743  * Enum | Value | Description
6744  * :------------------------------------------|:------|:-------------
6745  * ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_OPCODE | 0x0 | Opcode fetch
6746  * ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_DATA | 0x1 | Data access
6747  *
6748  * Field Access Macros:
6749  *
6750  */
6751 /*
6752  * Enumerated value for register field ALT_SYSMGR_USB_L3MST_HPROTDATA_1
6753  *
6754  * Opcode fetch
6755  */
6756 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_OPCODE 0x0
6757 /*
6758  * Enumerated value for register field ALT_SYSMGR_USB_L3MST_HPROTDATA_1
6759  *
6760  * Data access
6761  */
6762 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_DATA 0x1
6763
6764 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
6765 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_LSB 1
6766 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
6767 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_MSB 1
6768 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
6769 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_WIDTH 1
6770 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field value. */
6771 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_SET_MSK 0x00000002
6772 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field value. */
6773 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_CLR_MSK 0xfffffffd
6774 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
6775 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_RESET 0x1
6776 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 field value from a register. */
6777 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_GET(value) (((value) & 0x00000002) >> 1)
6778 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field value suitable for setting the register. */
6779 #define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_SET(value) (((value) << 1) & 0x00000002)
6780
6781 /*
6782  * Field : USB HPROT Privileged - hprotpriv_0
6783  *
6784  * If 1, L3 master accesses for the USB modules are privileged.
6785  *
6786  * The field array index corresponds to the USB index.
6787  *
6788  * Field Access Macros:
6789  *
6790  */
6791 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
6792 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_LSB 2
6793 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
6794 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_MSB 2
6795 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
6796 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_WIDTH 1
6797 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field value. */
6798 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_SET_MSK 0x00000004
6799 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field value. */
6800 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_CLR_MSK 0xfffffffb
6801 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
6802 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_RESET 0x1
6803 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 field value from a register. */
6804 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_GET(value) (((value) & 0x00000004) >> 2)
6805 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field value suitable for setting the register. */
6806 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_SET(value) (((value) << 2) & 0x00000004)
6807
6808 /*
6809  * Field : USB HPROT Privileged - hprotpriv_1
6810  *
6811  * If 1, L3 master accesses for the USB modules are privileged.
6812  *
6813  * The field array index corresponds to the USB index.
6814  *
6815  * Field Access Macros:
6816  *
6817  */
6818 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
6819 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_LSB 3
6820 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
6821 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_MSB 3
6822 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
6823 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_WIDTH 1
6824 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field value. */
6825 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_SET_MSK 0x00000008
6826 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field value. */
6827 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_CLR_MSK 0xfffffff7
6828 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
6829 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_RESET 0x1
6830 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 field value from a register. */
6831 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_GET(value) (((value) & 0x00000008) >> 3)
6832 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field value suitable for setting the register. */
6833 #define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_SET(value) (((value) << 3) & 0x00000008)
6834
6835 /*
6836  * Field : USB HPROT Bufferable - hprotbuff_0
6837  *
6838  * If 1, L3 master accesses for the USB modules are bufferable.
6839  *
6840  * The field array index corresponds to the USB index.
6841  *
6842  * Field Access Macros:
6843  *
6844  */
6845 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
6846 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_LSB 4
6847 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
6848 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_MSB 4
6849 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
6850 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_WIDTH 1
6851 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field value. */
6852 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_SET_MSK 0x00000010
6853 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field value. */
6854 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_CLR_MSK 0xffffffef
6855 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
6856 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_RESET 0x0
6857 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 field value from a register. */
6858 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_GET(value) (((value) & 0x00000010) >> 4)
6859 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field value suitable for setting the register. */
6860 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_SET(value) (((value) << 4) & 0x00000010)
6861
6862 /*
6863  * Field : USB HPROT Bufferable - hprotbuff_1
6864  *
6865  * If 1, L3 master accesses for the USB modules are bufferable.
6866  *
6867  * The field array index corresponds to the USB index.
6868  *
6869  * Field Access Macros:
6870  *
6871  */
6872 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
6873 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_LSB 5
6874 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
6875 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_MSB 5
6876 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
6877 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_WIDTH 1
6878 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field value. */
6879 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_SET_MSK 0x00000020
6880 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field value. */
6881 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_CLR_MSK 0xffffffdf
6882 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
6883 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_RESET 0x0
6884 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 field value from a register. */
6885 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_GET(value) (((value) & 0x00000020) >> 5)
6886 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field value suitable for setting the register. */
6887 #define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_SET(value) (((value) << 5) & 0x00000020)
6888
6889 /*
6890  * Field : USB HPROT Cacheable - hprotcache_0
6891  *
6892  * If 1, L3 master accesses for the USB modules are cacheable.
6893  *
6894  * The field array index corresponds to the USB index.
6895  *
6896  * Field Access Macros:
6897  *
6898  */
6899 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
6900 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_LSB 6
6901 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
6902 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_MSB 6
6903 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
6904 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_WIDTH 1
6905 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field value. */
6906 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_SET_MSK 0x00000040
6907 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field value. */
6908 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_CLR_MSK 0xffffffbf
6909 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
6910 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_RESET 0x0
6911 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 field value from a register. */
6912 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_GET(value) (((value) & 0x00000040) >> 6)
6913 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field value suitable for setting the register. */
6914 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_SET(value) (((value) << 6) & 0x00000040)
6915
6916 /*
6917  * Field : USB HPROT Cacheable - hprotcache_1
6918  *
6919  * If 1, L3 master accesses for the USB modules are cacheable.
6920  *
6921  * The field array index corresponds to the USB index.
6922  *
6923  * Field Access Macros:
6924  *
6925  */
6926 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
6927 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_LSB 7
6928 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
6929 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_MSB 7
6930 /* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
6931 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_WIDTH 1
6932 /* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field value. */
6933 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_SET_MSK 0x00000080
6934 /* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field value. */
6935 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_CLR_MSK 0xffffff7f
6936 /* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
6937 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_RESET 0x0
6938 /* Extracts the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 field value from a register. */
6939 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_GET(value) (((value) & 0x00000080) >> 7)
6940 /* Produces a ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field value suitable for setting the register. */
6941 #define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_SET(value) (((value) << 7) & 0x00000080)
6942
6943 #ifndef __ASSEMBLY__
6944 /*
6945  * WARNING: The C register and register group struct declarations are provided for
6946  * convenience and illustrative purposes. They should, however, be used with
6947  * caution as the C language standard provides no guarantees about the alignment or
6948  * atomicity of device memory accesses. The recommended practice for writing
6949  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6950  * alt_write_word() functions.
6951  *
6952  * The struct declaration for register ALT_SYSMGR_USB_L3MST.
6953  */
6955 {
6956  uint32_t hprotdata_0 : 1; /* USB HPROT Data/Opcode */
6957  uint32_t hprotdata_1 : 1; /* USB HPROT Data/Opcode */
6958  uint32_t hprotpriv_0 : 1; /* USB HPROT Privileged */
6959  uint32_t hprotpriv_1 : 1; /* USB HPROT Privileged */
6960  uint32_t hprotbuff_0 : 1; /* USB HPROT Bufferable */
6961  uint32_t hprotbuff_1 : 1; /* USB HPROT Bufferable */
6962  uint32_t hprotcache_0 : 1; /* USB HPROT Cacheable */
6963  uint32_t hprotcache_1 : 1; /* USB HPROT Cacheable */
6964  uint32_t : 24; /* *UNDEFINED* */
6965 };
6966
6967 /* The typedef declaration for register ALT_SYSMGR_USB_L3MST. */
6968 typedef volatile struct ALT_SYSMGR_USB_L3MST_s ALT_SYSMGR_USB_L3MST_t;
6969 #endif /* __ASSEMBLY__ */
6970
6971 /* The byte offset of the ALT_SYSMGR_USB_L3MST register from the beginning of the component. */
6972 #define ALT_SYSMGR_USB_L3MST_OFST 0x0
6973
6974 #ifndef __ASSEMBLY__
6975 /*
6976  * WARNING: The C register and register group struct declarations are provided for
6977  * convenience and illustrative purposes. They should, however, be used with
6978  * caution as the C language standard provides no guarantees about the alignment or
6979  * atomicity of device memory accesses. The recommended practice for writing
6980  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6981  * alt_write_word() functions.
6982  *
6983  * The struct declaration for register group ALT_SYSMGR_USB.
6984  */
6986 {
6987  volatile ALT_SYSMGR_USB_L3MST_t l3master; /* ALT_SYSMGR_USB_L3MST */
6988 };
6989
6990 /* The typedef declaration for register group ALT_SYSMGR_USB. */
6991 typedef volatile struct ALT_SYSMGR_USB_s ALT_SYSMGR_USB_t;
6992 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_USB. */
6994 {
6995  volatile uint32_t l3master; /* ALT_SYSMGR_USB_L3MST */
6996 };
6997
6998 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_USB. */
6999 typedef volatile struct ALT_SYSMGR_USB_raw_s ALT_SYSMGR_USB_raw_t;
7000 #endif /* __ASSEMBLY__ */
7001
7002
7003 /*
7004  * Register Group : ECC Management Register Group - ALT_SYSMGR_ECC
7005  * ECC Management Register Group
7006  *
7007  * ECC error status and control for all ECC-protected HPS RAM blocks.
7008  *
7009  */
7010 /*
7011  * Register : L2 Data RAM ECC Enable Register - l2
7012  *
7013  * This register is used to enable ECC on the L2 Data RAM. ECC errors can be
7014  * injected into the write path using bits in this register. This register contains
7015  * interrupt status of the ECC single/double bit error.
7016  *
7017  * Only reset by a cold reset (ignores warm reset).
7018  *
7019  * Register Layout
7020  *
7021  * Bits | Access | Reset | Description
7022  * :-------|:-------|:------|:---------------------------------------------------------
7023  * [0] | RW | 0x0 | L2 Data RAM ECC Enable
7024  * [1] | RW | 0x0 | L2 Data RAM ECC inject single, correctable Error
7025  * [2] | RW | 0x0 | L2 Data RAM ECC inject double bit, non-correctable error
7026  * [31:3] | ??? | 0x0 | *UNDEFINED*
7027  *
7028  */
7029 /*
7030  * Field : L2 Data RAM ECC Enable - en
7031  *
7032  * Enable ECC for L2 Data RAM
7033  *
7034  * Field Access Macros:
7035  *
7036  */
7037 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_L2_EN register field. */
7038 #define ALT_SYSMGR_ECC_L2_EN_LSB 0
7039 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_L2_EN register field. */
7040 #define ALT_SYSMGR_ECC_L2_EN_MSB 0
7041 /* The width in bits of the ALT_SYSMGR_ECC_L2_EN register field. */
7042 #define ALT_SYSMGR_ECC_L2_EN_WIDTH 1
7043 /* The mask used to set the ALT_SYSMGR_ECC_L2_EN register field value. */
7044 #define ALT_SYSMGR_ECC_L2_EN_SET_MSK 0x00000001
7045 /* The mask used to clear the ALT_SYSMGR_ECC_L2_EN register field value. */
7046 #define ALT_SYSMGR_ECC_L2_EN_CLR_MSK 0xfffffffe
7047 /* The reset value of the ALT_SYSMGR_ECC_L2_EN register field. */
7048 #define ALT_SYSMGR_ECC_L2_EN_RESET 0x0
7049 /* Extracts the ALT_SYSMGR_ECC_L2_EN field value from a register. */
7050 #define ALT_SYSMGR_ECC_L2_EN_GET(value) (((value) & 0x00000001) >> 0)
7051 /* Produces a ALT_SYSMGR_ECC_L2_EN register field value suitable for setting the register. */
7052 #define ALT_SYSMGR_ECC_L2_EN_SET(value) (((value) << 0) & 0x00000001)
7053
7054 /*
7055  * Field : L2 Data RAM ECC inject single, correctable Error - injs
7056  *
7057  * Changing this bit from zero to one injects a single, correctable error into the
7058  * L2 Data RAM. This only injects one error into the L2 Data RAM.
7059  *
7060  * Field Access Macros:
7061  *
7062  */
7063 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_L2_INJS register field. */
7064 #define ALT_SYSMGR_ECC_L2_INJS_LSB 1
7065 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_L2_INJS register field. */
7066 #define ALT_SYSMGR_ECC_L2_INJS_MSB 1
7067 /* The width in bits of the ALT_SYSMGR_ECC_L2_INJS register field. */
7068 #define ALT_SYSMGR_ECC_L2_INJS_WIDTH 1
7069 /* The mask used to set the ALT_SYSMGR_ECC_L2_INJS register field value. */
7070 #define ALT_SYSMGR_ECC_L2_INJS_SET_MSK 0x00000002
7071 /* The mask used to clear the ALT_SYSMGR_ECC_L2_INJS register field value. */
7072 #define ALT_SYSMGR_ECC_L2_INJS_CLR_MSK 0xfffffffd
7073 /* The reset value of the ALT_SYSMGR_ECC_L2_INJS register field. */
7074 #define ALT_SYSMGR_ECC_L2_INJS_RESET 0x0
7075 /* Extracts the ALT_SYSMGR_ECC_L2_INJS field value from a register. */
7076 #define ALT_SYSMGR_ECC_L2_INJS_GET(value) (((value) & 0x00000002) >> 1)
7077 /* Produces a ALT_SYSMGR_ECC_L2_INJS register field value suitable for setting the register. */
7078 #define ALT_SYSMGR_ECC_L2_INJS_SET(value) (((value) << 1) & 0x00000002)
7079
7080 /*
7081  * Field : L2 Data RAM ECC inject double bit, non-correctable error - injd
7082  *
7083  * Changing this bit from zero to one injects a double, non-correctable error into
7084  * the L2 Data RAM. This only injects one double bit error into the L2 Data RAM.
7085  *
7086  * Field Access Macros:
7087  *
7088  */
7089 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_L2_INJD register field. */
7090 #define ALT_SYSMGR_ECC_L2_INJD_LSB 2
7091 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_L2_INJD register field. */
7092 #define ALT_SYSMGR_ECC_L2_INJD_MSB 2
7093 /* The width in bits of the ALT_SYSMGR_ECC_L2_INJD register field. */
7094 #define ALT_SYSMGR_ECC_L2_INJD_WIDTH 1
7095 /* The mask used to set the ALT_SYSMGR_ECC_L2_INJD register field value. */
7096 #define ALT_SYSMGR_ECC_L2_INJD_SET_MSK 0x00000004
7097 /* The mask used to clear the ALT_SYSMGR_ECC_L2_INJD register field value. */
7098 #define ALT_SYSMGR_ECC_L2_INJD_CLR_MSK 0xfffffffb
7099 /* The reset value of the ALT_SYSMGR_ECC_L2_INJD register field. */
7100 #define ALT_SYSMGR_ECC_L2_INJD_RESET 0x0
7101 /* Extracts the ALT_SYSMGR_ECC_L2_INJD field value from a register. */
7102 #define ALT_SYSMGR_ECC_L2_INJD_GET(value) (((value) & 0x00000004) >> 2)
7103 /* Produces a ALT_SYSMGR_ECC_L2_INJD register field value suitable for setting the register. */
7104 #define ALT_SYSMGR_ECC_L2_INJD_SET(value) (((value) << 2) & 0x00000004)
7105
7106 #ifndef __ASSEMBLY__
7107 /*
7108  * WARNING: The C register and register group struct declarations are provided for
7109  * convenience and illustrative purposes. They should, however, be used with
7110  * caution as the C language standard provides no guarantees about the alignment or
7111  * atomicity of device memory accesses. The recommended practice for writing
7112  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
7113  * alt_write_word() functions.
7114  *
7115  * The struct declaration for register ALT_SYSMGR_ECC_L2.
7116  */
7118 {
7119  uint32_t en : 1; /* L2 Data RAM ECC Enable */
7120  uint32_t injs : 1; /* L2 Data RAM ECC inject single, correctable Error */
7121  uint32_t injd : 1; /* L2 Data RAM ECC inject double bit, non-correctable error */
7122  uint32_t : 29; /* *UNDEFINED* */
7123 };
7124
7125 /* The typedef declaration for register ALT_SYSMGR_ECC_L2. */
7126 typedef volatile struct ALT_SYSMGR_ECC_L2_s ALT_SYSMGR_ECC_L2_t;
7127 #endif /* __ASSEMBLY__ */
7128
7129 /* The byte offset of the ALT_SYSMGR_ECC_L2 register from the beginning of the component. */
7130 #define ALT_SYSMGR_ECC_L2_OFST 0x0
7131
7132 /*
7133  * Register : On-chip RAM ECC Enable Register - ocram
7134  *
7135  * This register is used to enable ECC on the On-chip RAM. ECC errors can be
7136  * injected into the write path using bits in this register. This register contains
7137  * interrupt status of the ECC single/double bit error.
7138  *
7139  * Only reset by a cold reset (ignores warm reset).
7140  *
7141  * Register Layout
7142  *
7143  * Bits | Access | Reset | Description
7144  * :-------|:-------|:------|:-------------------------------------------------------------------
7145  * [0] | RW | 0x0 | On-chip RAM ECC Enable
7146  * [1] | RW | 0x0 | On-chip RAM ECC inject single, correctable Error
7147  * [2] | RW | 0x0 | On-chip RAM ECC inject double bit, non-correctable error
7148  * [3] | RW | 0x0 | On-chip RAM ECC single, correctable error interrupt status
7149  * [4] | RW | 0x0 | On-chip RAM ECC double bit, non-correctable error interrupt status
7150  * [31:5] | ??? | 0x0 | *UNDEFINED*
7151  *
7152  */
7153 /*
7154  * Field : On-chip RAM ECC Enable - en
7155  *
7156  * Enable ECC for On-chip RAM
7157  *
7158  * Field Access Macros:
7159  *
7160  */
7161 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
7162 #define ALT_SYSMGR_ECC_OCRAM_EN_LSB 0
7163 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
7164 #define ALT_SYSMGR_ECC_OCRAM_EN_MSB 0
7165 /* The width in bits of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
7166 #define ALT_SYSMGR_ECC_OCRAM_EN_WIDTH 1
7167 /* The mask used to set the ALT_SYSMGR_ECC_OCRAM_EN register field value. */
7168 #define ALT_SYSMGR_ECC_OCRAM_EN_SET_MSK 0x00000001
7169 /* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_EN register field value. */
7170 #define ALT_SYSMGR_ECC_OCRAM_EN_CLR_MSK 0xfffffffe
7171 /* The reset value of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
7172 #define ALT_SYSMGR_ECC_OCRAM_EN_RESET 0x0
7173 /* Extracts the ALT_SYSMGR_ECC_OCRAM_EN field value from a register. */
7174 #define ALT_SYSMGR_ECC_OCRAM_EN_GET(value) (((value) & 0x00000001) >> 0)
7175 /* Produces a ALT_SYSMGR_ECC_OCRAM_EN register field value suitable for setting the register. */
7176 #define ALT_SYSMGR_ECC_OCRAM_EN_SET(value) (((value) << 0) & 0x00000001)
7177
7178 /*
7179  * Field : On-chip RAM ECC inject single, correctable Error - injs
7180  *
7181  * Changing this bit from zero to one injects a single, correctable error into the
7182  * On-chip RAM. This only injects one error into the On-chip RAM.
7183  *
7184  * Field Access Macros:
7185  *
7186  */
7187 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
7188 #define ALT_SYSMGR_ECC_OCRAM_INJS_LSB 1
7189 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
7190 #define ALT_SYSMGR_ECC_OCRAM_INJS_MSB 1
7191 /* The width in bits of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
7192 #define ALT_SYSMGR_ECC_OCRAM_INJS_WIDTH 1
7193 /* The mask used to set the ALT_SYSMGR_ECC_OCRAM_INJS register field value. */
7194 #define ALT_SYSMGR_ECC_OCRAM_INJS_SET_MSK 0x00000002
7195 /* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_INJS register field value. */
7196 #define ALT_SYSMGR_ECC_OCRAM_INJS_CLR_MSK 0xfffffffd
7197 /* The reset value of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
7198 #define ALT_SYSMGR_ECC_OCRAM_INJS_RESET 0x0
7199 /* Extracts the ALT_SYSMGR_ECC_OCRAM_INJS field value from a register. */
7200 #define ALT_SYSMGR_ECC_OCRAM_INJS_GET(value) (((value) & 0x00000002) >> 1)
7201 /* Produces a ALT_SYSMGR_ECC_OCRAM_INJS register field value suitable for setting the register. */
7202 #define ALT_SYSMGR_ECC_OCRAM_INJS_SET(value) (((value) << 1) & 0x00000002)
7203
7204 /*
7205  * Field : On-chip RAM ECC inject double bit, non-correctable error - injd
7206  *
7207  * Changing this bit from zero to one injects a double, non-correctable error into
7208  * the On-chip RAM. This only injects one double bit error into the On-chip RAM.
7209  *
7210  * Field Access Macros:
7211  *
7212  */
7213 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
7214 #define ALT_SYSMGR_ECC_OCRAM_INJD_LSB 2
7215 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
7216 #define ALT_SYSMGR_ECC_OCRAM_INJD_MSB 2
7217 /* The width in bits of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
7218 #define ALT_SYSMGR_ECC_OCRAM_INJD_WIDTH 1
7219 /* The mask used to set the ALT_SYSMGR_ECC_OCRAM_INJD register field value. */
7220 #define ALT_SYSMGR_ECC_OCRAM_INJD_SET_MSK 0x00000004
7221 /* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_INJD register field value. */
7222 #define ALT_SYSMGR_ECC_OCRAM_INJD_CLR_MSK 0xfffffffb
7223 /* The reset value of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
7224 #define ALT_SYSMGR_ECC_OCRAM_INJD_RESET 0x0
7225 /* Extracts the ALT_SYSMGR_ECC_OCRAM_INJD field value from a register. */
7226 #define ALT_SYSMGR_ECC_OCRAM_INJD_GET(value) (((value) & 0x00000004) >> 2)
7227 /* Produces a ALT_SYSMGR_ECC_OCRAM_INJD register field value suitable for setting the register. */
7228 #define ALT_SYSMGR_ECC_OCRAM_INJD_SET(value) (((value) << 2) & 0x00000004)
7229
7230 /*
7231  * Field : On-chip RAM ECC single, correctable error interrupt status - serr
7232  *
7233  * This bit is an interrupt status bit for On-chip RAM ECC single, correctable
7234  * error. It is set by hardware when single, correctable error occurs in On-chip
7235  * RAM. Software needs to write 1 into this bit to clear the interrupt status.
7236  *
7237  * Field Access Macros:
7238  *
7239  */
7240 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
7241 #define ALT_SYSMGR_ECC_OCRAM_SERR_LSB 3
7242 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
7243 #define ALT_SYSMGR_ECC_OCRAM_SERR_MSB 3
7244 /* The width in bits of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
7245 #define ALT_SYSMGR_ECC_OCRAM_SERR_WIDTH 1
7246 /* The mask used to set the ALT_SYSMGR_ECC_OCRAM_SERR register field value. */
7247 #define ALT_SYSMGR_ECC_OCRAM_SERR_SET_MSK 0x00000008
7248 /* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_SERR register field value. */
7249 #define ALT_SYSMGR_ECC_OCRAM_SERR_CLR_MSK 0xfffffff7
7250 /* The reset value of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
7251 #define ALT_SYSMGR_ECC_OCRAM_SERR_RESET 0x0
7252 /* Extracts the ALT_SYSMGR_ECC_OCRAM_SERR field value from a register. */
7253 #define ALT_SYSMGR_ECC_OCRAM_SERR_GET(value) (((value) & 0x00000008) >> 3)
7254 /* Produces a ALT_SYSMGR_ECC_OCRAM_SERR register field value suitable for setting the register. */
7255 #define ALT_SYSMGR_ECC_OCRAM_SERR_SET(value) (((value) << 3) & 0x00000008)
7256
7257 /*
7258  * Field : On-chip RAM ECC double bit, non-correctable error interrupt status - derr
7259  *
7260  * This bit is an interrupt status bit for On-chip RAM ECC double bit, non-
7261  * correctable error. It is set by hardware when double bit, non-correctable error
7262  * occurs in On-chip RAM. Software needs to write 1 into this bit to clear the
7263  * interrupt status.
7264  *
7265  * Field Access Macros:
7266  *
7267  */
7268 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
7269 #define ALT_SYSMGR_ECC_OCRAM_DERR_LSB 4
7270 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
7271 #define ALT_SYSMGR_ECC_OCRAM_DERR_MSB 4
7272 /* The width in bits of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
7273 #define ALT_SYSMGR_ECC_OCRAM_DERR_WIDTH 1
7274 /* The mask used to set the ALT_SYSMGR_ECC_OCRAM_DERR register field value. */
7275 #define ALT_SYSMGR_ECC_OCRAM_DERR_SET_MSK 0x00000010
7276 /* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_DERR register field value. */
7277 #define ALT_SYSMGR_ECC_OCRAM_DERR_CLR_MSK 0xffffffef
7278 /* The reset value of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
7279 #define ALT_SYSMGR_ECC_OCRAM_DERR_RESET 0x0
7280 /* Extracts the ALT_SYSMGR_ECC_OCRAM_DERR field value from a register. */
7281 #define ALT_SYSMGR_ECC_OCRAM_DERR_GET(value) (((value) & 0x00000010) >> 4)
7282 /* Produces a ALT_SYSMGR_ECC_OCRAM_DERR register field value suitable for setting the register. */
7283 #define ALT_SYSMGR_ECC_OCRAM_DERR_SET(value) (((value) << 4) & 0x00000010)
7284
7285 #ifndef __ASSEMBLY__
7286 /*
7287  * WARNING: The C register and register group struct declarations are provided for
7288  * convenience and illustrative purposes. They should, however, be used with
7289  * caution as the C language standard provides no guarantees about the alignment or
7290  * atomicity of device memory accesses. The recommended practice for writing
7291  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
7292  * alt_write_word() functions.
7293  *
7294  * The struct declaration for register ALT_SYSMGR_ECC_OCRAM.
7295  */
7297 {
7298  uint32_t en : 1; /* On-chip RAM ECC Enable */
7299  uint32_t injs : 1; /* On-chip RAM ECC inject single, correctable Error */
7300  uint32_t injd : 1; /* On-chip RAM ECC inject double bit, non-correctable error */
7301  uint32_t serr : 1; /* On-chip RAM ECC single, correctable error interrupt status */
7302  uint32_t derr : 1; /* On-chip RAM ECC double bit, non-correctable error interrupt status */
7303  uint32_t : 27; /* *UNDEFINED* */
7304 };
7305
7306 /* The typedef declaration for register ALT_SYSMGR_ECC_OCRAM. */
7307 typedef volatile struct ALT_SYSMGR_ECC_OCRAM_s ALT_SYSMGR_ECC_OCRAM_t;
7308 #endif /* __ASSEMBLY__ */
7309
7310 /* The byte offset of the ALT_SYSMGR_ECC_OCRAM register from the beginning of the component. */
7311 #define ALT_SYSMGR_ECC_OCRAM_OFST 0x4
7312
7313 /*
7314  * Register : USB0 RAM ECC Enable Register - usb0
7315  *
7316  * This register is used to enable ECC on the USB0 RAM. ECC errors can be injected
7317  * into the write path using bits in this register. This register contains
7318  * interrupt status of the ECC single/double bit error.
7319  *
7320  * Only reset by a cold reset (ignores warm reset).
7321  *
7322  * Register Layout
7323  *
7324  * Bits | Access | Reset | Description
7325  * :-------|:-------|:------|:----------------------------------------------------------------
7326  * [0] | RW | 0x0 | USB0 RAM ECC Enable
7327  * [1] | RW | 0x0 | USB0 RAM ECC inject single, correctable Error
7328  * [2] | RW | 0x0 | USB0 RAM ECC inject double bit, non-correctable error
7329  * [3] | RW | 0x0 | USB0 RAM ECC single, correctable error interrupt status
7330  * [4] | RW | 0x0 | USB0 RAM ECC double bit, non-correctable error interrupt status
7331  * [31:5] | ??? | 0x0 | *UNDEFINED*
7332  *
7333  */
7334 /*
7335  * Field : USB0 RAM ECC Enable - en
7336  *
7337  * Enable ECC for USB0 RAM
7338  *
7339  * Field Access Macros:
7340  *
7341  */
7342 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_EN register field. */
7343 #define ALT_SYSMGR_ECC_USB0_EN_LSB 0
7344 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_EN register field. */
7345 #define ALT_SYSMGR_ECC_USB0_EN_MSB 0
7346 /* The width in bits of the ALT_SYSMGR_ECC_USB0_EN register field. */
7347 #define ALT_SYSMGR_ECC_USB0_EN_WIDTH 1
7348 /* The mask used to set the ALT_SYSMGR_ECC_USB0_EN register field value. */
7349 #define ALT_SYSMGR_ECC_USB0_EN_SET_MSK 0x00000001
7350 /* The mask used to clear the ALT_SYSMGR_ECC_USB0_EN register field value. */
7351 #define ALT_SYSMGR_ECC_USB0_EN_CLR_MSK 0xfffffffe
7352 /* The reset value of the ALT_SYSMGR_ECC_USB0_EN register field. */
7353 #define ALT_SYSMGR_ECC_USB0_EN_RESET 0x0
7354 /* Extracts the ALT_SYSMGR_ECC_USB0_EN field value from a register. */
7355 #define ALT_SYSMGR_ECC_USB0_EN_GET(value) (((value) & 0x00000001) >> 0)
7356 /* Produces a ALT_SYSMGR_ECC_USB0_EN register field value suitable for setting the register. */
7357 #define ALT_SYSMGR_ECC_USB0_EN_SET(value) (((value) << 0) & 0x00000001)
7358
7359 /*
7360  * Field : USB0 RAM ECC inject single, correctable Error - injs
7361  *
7362  * Changing this bit from zero to one injects a single, correctable error into the
7363  * USB0 RAM. This only injects one error into the USB0 RAM.
7364  *
7365  * Field Access Macros:
7366  *
7367  */
7368 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_INJS register field. */
7369 #define ALT_SYSMGR_ECC_USB0_INJS_LSB 1
7370 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_INJS register field. */
7371 #define ALT_SYSMGR_ECC_USB0_INJS_MSB 1
7372 /* The width in bits of the ALT_SYSMGR_ECC_USB0_INJS register field. */
7373 #define ALT_SYSMGR_ECC_USB0_INJS_WIDTH 1
7374 /* The mask used to set the ALT_SYSMGR_ECC_USB0_INJS register field value. */
7375 #define ALT_SYSMGR_ECC_USB0_INJS_SET_MSK 0x00000002
7376 /* The mask used to clear the ALT_SYSMGR_ECC_USB0_INJS register field value. */
7377 #define ALT_SYSMGR_ECC_USB0_INJS_CLR_MSK 0xfffffffd
7378 /* The reset value of the ALT_SYSMGR_ECC_USB0_INJS register field. */
7379 #define ALT_SYSMGR_ECC_USB0_INJS_RESET 0x0
7380 /* Extracts the ALT_SYSMGR_ECC_USB0_INJS field value from a register. */
7381 #define ALT_SYSMGR_ECC_USB0_INJS_GET(value) (((value) & 0x00000002) >> 1)
7382 /* Produces a ALT_SYSMGR_ECC_USB0_INJS register field value suitable for setting the register. */
7383 #define ALT_SYSMGR_ECC_USB0_INJS_SET(value) (((value) << 1) & 0x00000002)
7384
7385 /*
7386  * Field : USB0 RAM ECC inject double bit, non-correctable error - injd
7387  *
7388  * Changing this bit from zero to one injects a double, non-correctable error into
7389  * the USB0 RAM. This only injects one double bit error into the USB0 RAM.
7390  *
7391  * Field Access Macros:
7392  *
7393  */
7394 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_INJD register field. */
7395 #define ALT_SYSMGR_ECC_USB0_INJD_LSB 2
7396 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_INJD register field. */
7397 #define ALT_SYSMGR_ECC_USB0_INJD_MSB 2
7398 /* The width in bits of the ALT_SYSMGR_ECC_USB0_INJD register field. */
7399 #define ALT_SYSMGR_ECC_USB0_INJD_WIDTH 1
7400 /* The mask used to set the ALT_SYSMGR_ECC_USB0_INJD register field value. */
7401 #define ALT_SYSMGR_ECC_USB0_INJD_SET_MSK 0x00000004
7402 /* The mask used to clear the ALT_SYSMGR_ECC_USB0_INJD register field value. */
7403 #define ALT_SYSMGR_ECC_USB0_INJD_CLR_MSK 0xfffffffb
7404 /* The reset value of the ALT_SYSMGR_ECC_USB0_INJD register field. */
7405 #define ALT_SYSMGR_ECC_USB0_INJD_RESET 0x0
7406 /* Extracts the ALT_SYSMGR_ECC_USB0_INJD field value from a register. */
7407 #define ALT_SYSMGR_ECC_USB0_INJD_GET(value) (((value) & 0x00000004) >> 2)
7408 /* Produces a ALT_SYSMGR_ECC_USB0_INJD register field value suitable for setting the register. */
7409 #define ALT_SYSMGR_ECC_USB0_INJD_SET(value) (((value) << 2) & 0x00000004)
7410
7411 /*
7412  * Field : USB0 RAM ECC single, correctable error interrupt status - serr
7413  *
7414  * This bit is an interrupt status bit for USB0 RAM ECC single, correctable error.
7415  * It is set by hardware when single, correctable error occurs in USB0 RAM.
7416  * Software needs to write 1 into this bit to clear the interrupt status.
7417  *
7418  * Field Access Macros:
7419  *
7420  */
7421 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_SERR register field. */
7422 #define ALT_SYSMGR_ECC_USB0_SERR_LSB 3
7423 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_SERR register field. */
7424 #define ALT_SYSMGR_ECC_USB0_SERR_MSB 3
7425 /* The width in bits of the ALT_SYSMGR_ECC_USB0_SERR register field. */
7426 #define ALT_SYSMGR_ECC_USB0_SERR_WIDTH 1
7427 /* The mask used to set the ALT_SYSMGR_ECC_USB0_SERR register field value. */
7428 #define ALT_SYSMGR_ECC_USB0_SERR_SET_MSK 0x00000008
7429 /* The mask used to clear the ALT_SYSMGR_ECC_USB0_SERR register field value. */
7430 #define ALT_SYSMGR_ECC_USB0_SERR_CLR_MSK 0xfffffff7
7431 /* The reset value of the ALT_SYSMGR_ECC_USB0_SERR register field. */
7432 #define ALT_SYSMGR_ECC_USB0_SERR_RESET 0x0
7433 /* Extracts the ALT_SYSMGR_ECC_USB0_SERR field value from a register. */
7434 #define ALT_SYSMGR_ECC_USB0_SERR_GET(value) (((value) & 0x00000008) >> 3)
7435 /* Produces a ALT_SYSMGR_ECC_USB0_SERR register field value suitable for setting the register. */
7436 #define ALT_SYSMGR_ECC_USB0_SERR_SET(value) (((value) << 3) & 0x00000008)
7437
7438 /*
7439  * Field : USB0 RAM ECC double bit, non-correctable error interrupt status - derr
7440  *
7441  * This bit is an interrupt status bit for USB0 RAM ECC double bit, non-correctable
7442  * error. It is set by hardware when double bit, non-correctable error occurs in
7443  * USB0 RAM. Software needs to write 1 into this bit to clear the interrupt status.
7444  *
7445  * Field Access Macros:
7446  *
7447  */
7448 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_DERR register field. */
7449 #define ALT_SYSMGR_ECC_USB0_DERR_LSB 4
7450 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_DERR register field. */
7451 #define ALT_SYSMGR_ECC_USB0_DERR_MSB 4
7452 /* The width in bits of the ALT_SYSMGR_ECC_USB0_DERR register field. */
7453 #define ALT_SYSMGR_ECC_USB0_DERR_WIDTH 1
7454 /* The mask used to set the ALT_SYSMGR_ECC_USB0_DERR register field value. */
7455 #define ALT_SYSMGR_ECC_USB0_DERR_SET_MSK 0x00000010
7456 /* The mask used to clear the ALT_SYSMGR_ECC_USB0_DERR register field value. */
7457 #define ALT_SYSMGR_ECC_USB0_DERR_CLR_MSK 0xffffffef
7458 /* The reset value of the ALT_SYSMGR_ECC_USB0_DERR register field. */
7459 #define ALT_SYSMGR_ECC_USB0_DERR_RESET 0x0
7460 /* Extracts the ALT_SYSMGR_ECC_USB0_DERR field value from a register. */
7461 #define ALT_SYSMGR_ECC_USB0_DERR_GET(value) (((value) & 0x00000010) >> 4)
7462 /* Produces a ALT_SYSMGR_ECC_USB0_DERR register field value suitable for setting the register. */
7463 #define ALT_SYSMGR_ECC_USB0_DERR_SET(value) (((value) << 4) & 0x00000010)
7464
7465 #ifndef __ASSEMBLY__
7466 /*
7467  * WARNING: The C register and register group struct declarations are provided for
7468  * convenience and illustrative purposes. They should, however, be used with
7469  * caution as the C language standard provides no guarantees about the alignment or
7470  * atomicity of device memory accesses. The recommended practice for writing
7471  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
7472  * alt_write_word() functions.
7473  *
7474  * The struct declaration for register ALT_SYSMGR_ECC_USB0.
7475  */
7477 {
7478  uint32_t en : 1; /* USB0 RAM ECC Enable */
7479  uint32_t injs : 1; /* USB0 RAM ECC inject single, correctable Error */
7480  uint32_t injd : 1; /* USB0 RAM ECC inject double bit, non-correctable error */
7481  uint32_t serr : 1; /* USB0 RAM ECC single, correctable error interrupt status */
7482  uint32_t derr : 1; /* USB0 RAM ECC double bit, non-correctable error interrupt status */
7483  uint32_t : 27; /* *UNDEFINED* */
7484 };
7485
7486 /* The typedef declaration for register ALT_SYSMGR_ECC_USB0. */
7487 typedef volatile struct ALT_SYSMGR_ECC_USB0_s ALT_SYSMGR_ECC_USB0_t;
7488 #endif /* __ASSEMBLY__ */
7489
7490 /* The byte offset of the ALT_SYSMGR_ECC_USB0 register from the beginning of the component. */
7491 #define ALT_SYSMGR_ECC_USB0_OFST 0x8
7492
7493 /*
7494  * Register : USB1 RAM ECC Enable Register - usb1
7495  *
7496  * This register is used to enable ECC on the USB1 RAM. ECC errors can be injected
7497  * into the write path using bits in this register. This register contains
7498  * interrupt status of the ECC single/double bit error.
7499  *
7500  * Only reset by a cold reset (ignores warm reset).
7501  *
7502  * Register Layout
7503  *
7504  * Bits | Access | Reset | Description
7505  * :-------|:-------|:------|:----------------------------------------------------------------
7506  * [0] | RW | 0x0 | USB1 RAM ECC Enable
7507  * [1] | RW | 0x0 | USB1 RAM ECC inject single, correctable Error
7508  * [2] | RW | 0x0 | USB1 RAM ECC inject double bit, non-correctable error
7509  * [3] | RW | 0x0 | USB1 RAM ECC single, correctable error interrupt status
7510  * [4] | RW | 0x0 | USB1 RAM ECC double bit, non-correctable error interrupt status
7511  * [31:5] | ??? | 0x0 | *UNDEFINED*
7512  *
7513  */
7514 /*
7515  * Field : USB1 RAM ECC Enable - en
7516  *
7517  * Enable ECC for USB1 RAM
7518  *
7519  * Field Access Macros:
7520  *
7521  */
7522 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_EN register field. */
7523 #define ALT_SYSMGR_ECC_USB1_EN_LSB 0
7524 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_EN register field. */
7525 #define ALT_SYSMGR_ECC_USB1_EN_MSB 0
7526 /* The width in bits of the ALT_SYSMGR_ECC_USB1_EN register field. */
7527 #define ALT_SYSMGR_ECC_USB1_EN_WIDTH 1
7528 /* The mask used to set the ALT_SYSMGR_ECC_USB1_EN register field value. */
7529 #define ALT_SYSMGR_ECC_USB1_EN_SET_MSK 0x00000001
7530 /* The mask used to clear the ALT_SYSMGR_ECC_USB1_EN register field value. */
7531 #define ALT_SYSMGR_ECC_USB1_EN_CLR_MSK 0xfffffffe
7532 /* The reset value of the ALT_SYSMGR_ECC_USB1_EN register field. */
7533 #define ALT_SYSMGR_ECC_USB1_EN_RESET 0x0
7534 /* Extracts the ALT_SYSMGR_ECC_USB1_EN field value from a register. */
7535 #define ALT_SYSMGR_ECC_USB1_EN_GET(value) (((value) & 0x00000001) >> 0)
7536 /* Produces a ALT_SYSMGR_ECC_USB1_EN register field value suitable for setting the register. */
7537 #define ALT_SYSMGR_ECC_USB1_EN_SET(value) (((value) << 0) & 0x00000001)
7538
7539 /*
7540  * Field : USB1 RAM ECC inject single, correctable Error - injs
7541  *
7542  * Changing this bit from zero to one injects a single, correctable error into the
7543  * USB1 RAM. This only injects one error into the USB1 RAM.
7544  *
7545  * Field Access Macros:
7546  *
7547  */
7548 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_INJS register field. */
7549 #define ALT_SYSMGR_ECC_USB1_INJS_LSB 1
7550 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_INJS register field. */
7551 #define ALT_SYSMGR_ECC_USB1_INJS_MSB 1
7552 /* The width in bits of the ALT_SYSMGR_ECC_USB1_INJS register field. */
7553 #define ALT_SYSMGR_ECC_USB1_INJS_WIDTH 1
7554 /* The mask used to set the ALT_SYSMGR_ECC_USB1_INJS register field value. */
7555 #define ALT_SYSMGR_ECC_USB1_INJS_SET_MSK 0x00000002
7556 /* The mask used to clear the ALT_SYSMGR_ECC_USB1_INJS register field value. */
7557 #define ALT_SYSMGR_ECC_USB1_INJS_CLR_MSK 0xfffffffd
7558 /* The reset value of the ALT_SYSMGR_ECC_USB1_INJS register field. */
7559 #define ALT_SYSMGR_ECC_USB1_INJS_RESET 0x0
7560 /* Extracts the ALT_SYSMGR_ECC_USB1_INJS field value from a register. */
7561 #define ALT_SYSMGR_ECC_USB1_INJS_GET(value) (((value) & 0x00000002) >> 1)
7562 /* Produces a ALT_SYSMGR_ECC_USB1_INJS register field value suitable for setting the register. */
7563 #define ALT_SYSMGR_ECC_USB1_INJS_SET(value) (((value) << 1) & 0x00000002)
7564
7565 /*
7566  * Field : USB1 RAM ECC inject double bit, non-correctable error - injd
7567  *
7568  * Changing this bit from zero to one injects a double, non-correctable error into
7569  * the USB1 RAM. This only injects one double bit error into the USB1 RAM.
7570  *
7571  * Field Access Macros:
7572  *
7573  */
7574 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_INJD register field. */
7575 #define ALT_SYSMGR_ECC_USB1_INJD_LSB 2
7576 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_INJD register field. */
7577 #define ALT_SYSMGR_ECC_USB1_INJD_MSB 2
7578 /* The width in bits of the ALT_SYSMGR_ECC_USB1_INJD register field. */
7579 #define ALT_SYSMGR_ECC_USB1_INJD_WIDTH 1
7580 /* The mask used to set the ALT_SYSMGR_ECC_USB1_INJD register field value. */
7581 #define ALT_SYSMGR_ECC_USB1_INJD_SET_MSK 0x00000004
7582 /* The mask used to clear the ALT_SYSMGR_ECC_USB1_INJD register field value. */
7583 #define ALT_SYSMGR_ECC_USB1_INJD_CLR_MSK 0xfffffffb
7584 /* The reset value of the ALT_SYSMGR_ECC_USB1_INJD register field. */
7585 #define ALT_SYSMGR_ECC_USB1_INJD_RESET 0x0
7586 /* Extracts the ALT_SYSMGR_ECC_USB1_INJD field value from a register. */
7587 #define ALT_SYSMGR_ECC_USB1_INJD_GET(value) (((value) & 0x00000004) >> 2)
7588 /* Produces a ALT_SYSMGR_ECC_USB1_INJD register field value suitable for setting the register. */
7589 #define ALT_SYSMGR_ECC_USB1_INJD_SET(value) (((value) << 2) & 0x00000004)
7590
7591 /*
7592  * Field : USB1 RAM ECC single, correctable error interrupt status - serr
7593  *
7594  * This bit is an interrupt status bit for USB1 RAM ECC single, correctable error.
7595  * It is set by hardware when single, correctable error occurs in USB1 RAM.
7596  * Software needs to write 1 into this bit to clear the interrupt status.
7597  *
7598  * Field Access Macros:
7599  *
7600  */
7601 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_SERR register field. */
7602 #define ALT_SYSMGR_ECC_USB1_SERR_LSB 3
7603 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_SERR register field. */
7604 #define ALT_SYSMGR_ECC_USB1_SERR_MSB 3
7605 /* The width in bits of the ALT_SYSMGR_ECC_USB1_SERR register field. */
7606 #define ALT_SYSMGR_ECC_USB1_SERR_WIDTH 1
7607 /* The mask used to set the ALT_SYSMGR_ECC_USB1_SERR register field value. */
7608 #define ALT_SYSMGR_ECC_USB1_SERR_SET_MSK 0x00000008
7609 /* The mask used to clear the ALT_SYSMGR_ECC_USB1_SERR register field value. */
7610 #define ALT_SYSMGR_ECC_USB1_SERR_CLR_MSK 0xfffffff7
7611 /* The reset value of the ALT_SYSMGR_ECC_USB1_SERR register field. */
7612 #define ALT_SYSMGR_ECC_USB1_SERR_RESET 0x0
7613 /* Extracts the ALT_SYSMGR_ECC_USB1_SERR field value from a register. */
7614 #define ALT_SYSMGR_ECC_USB1_SERR_GET(value) (((value) & 0x00000008) >> 3)
7615 /* Produces a ALT_SYSMGR_ECC_USB1_SERR register field value suitable for setting the register. */
7616 #define ALT_SYSMGR_ECC_USB1_SERR_SET(value) (((value) << 3) & 0x00000008)
7617
7618 /*
7619  * Field : USB1 RAM ECC double bit, non-correctable error interrupt status - derr
7620  *
7621  * This bit is an interrupt status bit for USB1 RAM ECC double bit, non-correctable
7622  * error. It is set by hardware when double bit, non-correctable error occurs in
7623  * USB1 RAM. Software needs to write 1 into this bit to clear the interrupt status.
7624  *
7625  * Field Access Macros:
7626  *
7627  */
7628 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_DERR register field. */
7629 #define ALT_SYSMGR_ECC_USB1_DERR_LSB 4
7630 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_DERR register field. */
7631 #define ALT_SYSMGR_ECC_USB1_DERR_MSB 4
7632 /* The width in bits of the ALT_SYSMGR_ECC_USB1_DERR register field. */
7633 #define ALT_SYSMGR_ECC_USB1_DERR_WIDTH 1
7634 /* The mask used to set the ALT_SYSMGR_ECC_USB1_DERR register field value. */
7635 #define ALT_SYSMGR_ECC_USB1_DERR_SET_MSK 0x00000010
7636 /* The mask used to clear the ALT_SYSMGR_ECC_USB1_DERR register field value. */
7637 #define ALT_SYSMGR_ECC_USB1_DERR_CLR_MSK 0xffffffef
7638 /* The reset value of the ALT_SYSMGR_ECC_USB1_DERR register field. */
7639 #define ALT_SYSMGR_ECC_USB1_DERR_RESET 0x0
7640 /* Extracts the ALT_SYSMGR_ECC_USB1_DERR field value from a register. */
7641 #define ALT_SYSMGR_ECC_USB1_DERR_GET(value) (((value) & 0x00000010) >> 4)
7642 /* Produces a ALT_SYSMGR_ECC_USB1_DERR register field value suitable for setting the register. */
7643 #define ALT_SYSMGR_ECC_USB1_DERR_SET(value) (((value) << 4) & 0x00000010)
7644
7645 #ifndef __ASSEMBLY__
7646 /*
7647  * WARNING: The C register and register group struct declarations are provided for
7648  * convenience and illustrative purposes. They should, however, be used with
7649  * caution as the C language standard provides no guarantees about the alignment or
7650  * atomicity of device memory accesses. The recommended practice for writing
7651  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
7652  * alt_write_word() functions.
7653  *
7654  * The struct declaration for register ALT_SYSMGR_ECC_USB1.
7655  */
7657 {
7658  uint32_t en : 1; /* USB1 RAM ECC Enable */
7659  uint32_t injs : 1; /* USB1 RAM ECC inject single, correctable Error */
7660  uint32_t injd : 1; /* USB1 RAM ECC inject double bit, non-correctable error */
7661  uint32_t serr : 1; /* USB1 RAM ECC single, correctable error interrupt status */
7662  uint32_t derr : 1; /* USB1 RAM ECC double bit, non-correctable error interrupt status */
7663  uint32_t : 27; /* *UNDEFINED* */
7664 };
7665
7666 /* The typedef declaration for register ALT_SYSMGR_ECC_USB1. */
7667 typedef volatile struct ALT_SYSMGR_ECC_USB1_s ALT_SYSMGR_ECC_USB1_t;
7668 #endif /* __ASSEMBLY__ */
7669
7670 /* The byte offset of the ALT_SYSMGR_ECC_USB1 register from the beginning of the component. */
7671 #define ALT_SYSMGR_ECC_USB1_OFST 0xc
7672
7673 /*
7674  * Register : EMAC0 RAM ECC Enable Register - emac0
7675  *
7676  * This register is used to enable ECC on the EMAC0 RAM. ECC errors can be injected
7677  * into the write path using bits in this register. This register contains
7678  * interrupt status of the ECC single/double bit error.
7679  *
7680  * Only reset by a cold reset (ignores warm reset).
7681  *
7682  * Register Layout
7683  *
7684  * Bits | Access | Reset | Description
7685  * :-------|:-------|:------|:------------------------------------------------------------------------
7686  * [0] | RW | 0x0 | EMAC0 RAM ECC Enable
7687  * [1] | RW | 0x0 | EMAC0 TXFIFO RAM ECC inject single, correctable Error
7688  * [2] | RW | 0x0 | EMAC0 TXFIFO RAM ECC inject double bit, non-correctable error
7689  * [3] | RW | 0x0 | EMAC0 RXFIFO RAM ECC inject single, correctable Error
7690  * [4] | RW | 0x0 | EMAC0 RXFIFO RAM ECC inject double bit, non-correctable error
7691  * [5] | RW | 0x0 | EMAC0 TXFIFO RAM ECC single, correctable error interrupt status
7692  * [6] | RW | 0x0 | EMAC0 TXFIFO RAM ECC double bit, non-correctable error interrupt status
7693  * [7] | RW | 0x0 | EMAC0 RXFIFO RAM ECC single, correctable error interrupt status
7694  * [8] | RW | 0x0 | EMAC0 RXFIFO RAM ECC double bit, non-correctable error interrupt status
7695  * [31:9] | ??? | 0x0 | *UNDEFINED*
7696  *
7697  */
7698 /*
7699  * Field : EMAC0 RAM ECC Enable - en
7700  *
7701  * Enable ECC for EMAC0 RAM
7702  *
7703  * Field Access Macros:
7704  *
7705  */
7706 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
7707 #define ALT_SYSMGR_ECC_EMAC0_EN_LSB 0
7708 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
7709 #define ALT_SYSMGR_ECC_EMAC0_EN_MSB 0
7710 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
7711 #define ALT_SYSMGR_ECC_EMAC0_EN_WIDTH 1
7712 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_EN register field value. */
7713 #define ALT_SYSMGR_ECC_EMAC0_EN_SET_MSK 0x00000001
7714 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_EN register field value. */
7715 #define ALT_SYSMGR_ECC_EMAC0_EN_CLR_MSK 0xfffffffe
7716 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
7717 #define ALT_SYSMGR_ECC_EMAC0_EN_RESET 0x0
7718 /* Extracts the ALT_SYSMGR_ECC_EMAC0_EN field value from a register. */
7719 #define ALT_SYSMGR_ECC_EMAC0_EN_GET(value) (((value) & 0x00000001) >> 0)
7720 /* Produces a ALT_SYSMGR_ECC_EMAC0_EN register field value suitable for setting the register. */
7721 #define ALT_SYSMGR_ECC_EMAC0_EN_SET(value) (((value) << 0) & 0x00000001)
7722
7723 /*
7724  * Field : EMAC0 TXFIFO RAM ECC inject single, correctable Error - txfifoinjs
7725  *
7726  * Changing this bit from zero to one injects a single, correctable error into the
7727  * EMAC0 TXFIFO RAM. This only injects one error into the EMAC0 TXFIFO RAM.
7728  *
7729  * Field Access Macros:
7730  *
7731  */
7732 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
7733 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_LSB 1
7734 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
7735 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_MSB 1
7736 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
7737 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_WIDTH 1
7738 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field value. */
7739 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_SET_MSK 0x00000002
7740 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field value. */
7741 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_CLR_MSK 0xfffffffd
7742 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
7743 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_RESET 0x0
7744 /* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS field value from a register. */
7745 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_GET(value) (((value) & 0x00000002) >> 1)
7746 /* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field value suitable for setting the register. */
7747 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_SET(value) (((value) << 1) & 0x00000002)
7748
7749 /*
7750  * Field : EMAC0 TXFIFO RAM ECC inject double bit, non-correctable error - txfifoinjd
7751  *
7752  * Changing this bit from zero to one injects a double, non-correctable error into
7753  * the EMAC0 TXFIFO RAM. This only injects one double bit error into the EMAC0
7754  * TXFIFO RAM.
7755  *
7756  * Field Access Macros:
7757  *
7758  */
7759 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
7760 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_LSB 2
7761 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
7762 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_MSB 2
7763 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
7764 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_WIDTH 1
7765 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field value. */
7766 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_SET_MSK 0x00000004
7767 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field value. */
7768 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_CLR_MSK 0xfffffffb
7769 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
7770 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_RESET 0x0
7771 /* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD field value from a register. */
7772 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_GET(value) (((value) & 0x00000004) >> 2)
7773 /* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field value suitable for setting the register. */
7774 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_SET(value) (((value) << 2) & 0x00000004)
7775
7776 /*
7777  * Field : EMAC0 RXFIFO RAM ECC inject single, correctable Error - rxfifoinjs
7778  *
7779  * Changing this bit from zero to one injects a single, correctable error into the
7780  * EMAC0 RXFIFO RAM. This only injects one error into the EMAC0 RXFIFO RAM.
7781  *
7782  * Field Access Macros:
7783  *
7784  */
7785 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
7786 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_LSB 3
7787 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
7788 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_MSB 3
7789 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
7790 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_WIDTH 1
7791 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field value. */
7792 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_SET_MSK 0x00000008
7793 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field value. */
7794 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_CLR_MSK 0xfffffff7
7795 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
7796 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_RESET 0x0
7797 /* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS field value from a register. */
7798 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_GET(value) (((value) & 0x00000008) >> 3)
7799 /* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field value suitable for setting the register. */
7800 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_SET(value) (((value) << 3) & 0x00000008)
7801
7802 /*
7803  * Field : EMAC0 RXFIFO RAM ECC inject double bit, non-correctable error - rxfifoinjd
7804  *
7805  * Changing this bit from zero to one injects a double, non-correctable error into
7806  * the EMAC0 RXFIFO RAM. This only injects one double bit error into the EMAC0
7807  * RXFIFO RAM.
7808  *
7809  * Field Access Macros:
7810  *
7811  */
7812 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
7813 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_LSB 4
7814 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
7815 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_MSB 4
7816 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
7817 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_WIDTH 1
7818 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field value. */
7819 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_SET_MSK 0x00000010
7820 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field value. */
7821 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_CLR_MSK 0xffffffef
7822 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
7823 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_RESET 0x0
7824 /* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD field value from a register. */
7825 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_GET(value) (((value) & 0x00000010) >> 4)
7826 /* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field value suitable for setting the register. */
7827 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_SET(value) (((value) << 4) & 0x00000010)
7828
7829 /*
7830  * Field : EMAC0 TXFIFO RAM ECC single, correctable error interrupt status - txfifoserr
7831  *
7832  * This bit is an interrupt status bit for EMAC0 TXFIFO RAM ECC single, correctable
7833  * error. It is set by hardware when single, correctable error occurs in EMAC0
7834  * TXFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
7835  * status.
7836  *
7837  * Field Access Macros:
7838  *
7839  */
7840 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
7841 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_LSB 5
7842 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
7843 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_MSB 5
7844 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
7845 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_WIDTH 1
7846 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field value. */
7847 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_SET_MSK 0x00000020
7848 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field value. */
7849 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_CLR_MSK 0xffffffdf
7850 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
7851 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_RESET 0x0
7852 /* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR field value from a register. */
7853 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_GET(value) (((value) & 0x00000020) >> 5)
7854 /* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field value suitable for setting the register. */
7855 #define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_SET(value) (((value) << 5) & 0x00000020)
7856
7857 /*
7858  * Field : EMAC0 TXFIFO RAM ECC double bit, non-correctable error interrupt status - txfifoderr
7859  *
7860  * This bit is an interrupt status bit for EMAC0 TXFIFO RAM ECC double bit, non-
7861  * correctable error. It is set by hardware when double bit, non-correctable error
7862  * occurs in EMAC0 TXFIFO RAM. Software needs to write 1 into this bit to clear the
7863  * interrupt status.
7864  *
7865  * Field Access Macros:
7866  *
7867  */
7868 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
7869 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_LSB 6
7870 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
7871 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_MSB 6
7872 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
7873 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_WIDTH 1
7874 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field value. */
7875 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_SET_MSK 0x00000040
7876 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field value. */
7877 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_CLR_MSK 0xffffffbf
7878 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
7879 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_RESET 0x0
7880 /* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR field value from a register. */
7881 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_GET(value) (((value) & 0x00000040) >> 6)
7882 /* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field value suitable for setting the register. */
7883 #define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_SET(value) (((value) << 6) & 0x00000040)
7884
7885 /*
7886  * Field : EMAC0 RXFIFO RAM ECC single, correctable error interrupt status - rxfifoserr
7887  *
7888  * This bit is an interrupt status bit for EMAC0 RXFIFO RAM ECC single, correctable
7889  * error. It is set by hardware when single, correctable error occurs in EMAC0
7890  * RXFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
7891  * status.
7892  *
7893  * Field Access Macros:
7894  *
7895  */
7896 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
7897 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_LSB 7
7898 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
7899 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_MSB 7
7900 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
7901 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_WIDTH 1
7902 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field value. */
7903 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_SET_MSK 0x00000080
7904 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field value. */
7905 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_CLR_MSK 0xffffff7f
7906 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
7907 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_RESET 0x0
7908 /* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR field value from a register. */
7909 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_GET(value) (((value) & 0x00000080) >> 7)
7910 /* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field value suitable for setting the register. */
7911 #define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_SET(value) (((value) << 7) & 0x00000080)
7912
7913 /*
7914  * Field : EMAC0 RXFIFO RAM ECC double bit, non-correctable error interrupt status - rxfifoderr
7915  *
7916  * This bit is an interrupt status bit for EMAC0 RXFIFO RAM ECC double bit, non-
7917  * correctable error. It is set by hardware when double bit, non-correctable error
7918  * occurs in EMAC0 RXFIFO RAM. Software needs to write 1 into this bit to clear the
7919  * interrupt status.
7920  *
7921  * Field Access Macros:
7922  *
7923  */
7924 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
7925 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_LSB 8
7926 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
7927 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_MSB 8
7928 /* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
7929 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_WIDTH 1
7930 /* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field value. */
7931 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_SET_MSK 0x00000100
7932 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field value. */
7933 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_CLR_MSK 0xfffffeff
7934 /* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
7935 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_RESET 0x0
7936 /* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR field value from a register. */
7937 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_GET(value) (((value) & 0x00000100) >> 8)
7938 /* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field value suitable for setting the register. */
7939 #define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_SET(value) (((value) << 8) & 0x00000100)
7940
7941 #ifndef __ASSEMBLY__
7942 /*
7943  * WARNING: The C register and register group struct declarations are provided for
7944  * convenience and illustrative purposes. They should, however, be used with
7945  * caution as the C language standard provides no guarantees about the alignment or
7946  * atomicity of device memory accesses. The recommended practice for writing
7947  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
7948  * alt_write_word() functions.
7949  *
7950  * The struct declaration for register ALT_SYSMGR_ECC_EMAC0.
7951  */
7953 {
7954  uint32_t en : 1; /* EMAC0 RAM ECC Enable */
7955  uint32_t txfifoinjs : 1; /* EMAC0 TXFIFO RAM ECC inject single, correctable Error */
7956  uint32_t txfifoinjd : 1; /* EMAC0 TXFIFO RAM ECC inject double bit, non-correctable error */
7957  uint32_t rxfifoinjs : 1; /* EMAC0 RXFIFO RAM ECC inject single, correctable Error */
7958  uint32_t rxfifoinjd : 1; /* EMAC0 RXFIFO RAM ECC inject double bit, non-correctable error */
7959  uint32_t txfifoserr : 1; /* EMAC0 TXFIFO RAM ECC single, correctable error interrupt status */
7960  uint32_t txfifoderr : 1; /* EMAC0 TXFIFO RAM ECC double bit, non-correctable error interrupt status */
7961  uint32_t rxfifoserr : 1; /* EMAC0 RXFIFO RAM ECC single, correctable error interrupt status */
7962  uint32_t rxfifoderr : 1; /* EMAC0 RXFIFO RAM ECC double bit, non-correctable error interrupt status */
7963  uint32_t : 23; /* *UNDEFINED* */
7964 };
7965
7966 /* The typedef declaration for register ALT_SYSMGR_ECC_EMAC0. */
7967 typedef volatile struct ALT_SYSMGR_ECC_EMAC0_s ALT_SYSMGR_ECC_EMAC0_t;
7968 #endif /* __ASSEMBLY__ */
7969
7970 /* The byte offset of the ALT_SYSMGR_ECC_EMAC0 register from the beginning of the component. */
7971 #define ALT_SYSMGR_ECC_EMAC0_OFST 0x10
7972
7973 /*
7974  * Register : EMAC1 RAM ECC Enable Register - emac1
7975  *
7976  * This register is used to enable ECC on the EMAC1 RAM. ECC errors can be injected
7977  * into the write path using bits in this register. This register contains
7978  * interrupt status of the ECC single/double bit error.
7979  *
7980  * Only reset by a cold reset (ignores warm reset).
7981  *
7982  * Register Layout
7983  *
7984  * Bits | Access | Reset | Description
7985  * :-------|:-------|:------|:------------------------------------------------------------------------
7986  * [0] | RW | 0x0 | EMAC1 RAM ECC Enable
7987  * [1] | RW | 0x0 | EMAC1 TXFIFO RAM ECC inject single, correctable Error
7988  * [2] | RW | 0x0 | EMAC1 TXFIFO RAM ECC inject double bit, non-correctable error
7989  * [3] | RW | 0x0 | EMAC1 RXFIFO RAM ECC inject single, correctable Error
7990  * [4] | RW | 0x0 | EMAC1 RXFIFO RAM ECC inject double bit, non-correctable error
7991  * [5] | RW | 0x0 | EMAC1 TXFIFO RAM ECC single, correctable error interrupt status
7992  * [6] | RW | 0x0 | EMAC1 TXFIFO RAM ECC double bit, non-correctable error interrupt status
7993  * [7] | RW | 0x0 | EMAC1 RXFIFO RAM ECC single, correctable error interrupt status
7994  * [8] | RW | 0x0 | EMAC1 RXFIFO RAM ECC double bit, non-correctable error interrupt status
7995  * [31:9] | ??? | 0x0 | *UNDEFINED*
7996  *
7997  */
7998 /*
7999  * Field : EMAC1 RAM ECC Enable - en
8000  *
8001  * Enable ECC for EMAC1 RAM
8002  *
8003  * Field Access Macros:
8004  *
8005  */
8006 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
8007 #define ALT_SYSMGR_ECC_EMAC1_EN_LSB 0
8008 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
8009 #define ALT_SYSMGR_ECC_EMAC1_EN_MSB 0
8010 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
8011 #define ALT_SYSMGR_ECC_EMAC1_EN_WIDTH 1
8012 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_EN register field value. */
8013 #define ALT_SYSMGR_ECC_EMAC1_EN_SET_MSK 0x00000001
8014 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_EN register field value. */
8015 #define ALT_SYSMGR_ECC_EMAC1_EN_CLR_MSK 0xfffffffe
8016 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
8017 #define ALT_SYSMGR_ECC_EMAC1_EN_RESET 0x0
8018 /* Extracts the ALT_SYSMGR_ECC_EMAC1_EN field value from a register. */
8019 #define ALT_SYSMGR_ECC_EMAC1_EN_GET(value) (((value) & 0x00000001) >> 0)
8020 /* Produces a ALT_SYSMGR_ECC_EMAC1_EN register field value suitable for setting the register. */
8021 #define ALT_SYSMGR_ECC_EMAC1_EN_SET(value) (((value) << 0) & 0x00000001)
8022
8023 /*
8024  * Field : EMAC1 TXFIFO RAM ECC inject single, correctable Error - txfifoinjs
8025  *
8026  * Changing this bit from zero to one injects a single, correctable error into the
8027  * EMAC1 TXFIFO RAM. This only injects one error into the EMAC1 TXFIFO RAM.
8028  *
8029  * Field Access Macros:
8030  *
8031  */
8032 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
8033 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_LSB 1
8034 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
8035 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_MSB 1
8036 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
8037 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_WIDTH 1
8038 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field value. */
8039 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_SET_MSK 0x00000002
8040 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field value. */
8041 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_CLR_MSK 0xfffffffd
8042 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
8043 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_RESET 0x0
8044 /* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS field value from a register. */
8045 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_GET(value) (((value) & 0x00000002) >> 1)
8046 /* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field value suitable for setting the register. */
8047 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_SET(value) (((value) << 1) & 0x00000002)
8048
8049 /*
8050  * Field : EMAC1 TXFIFO RAM ECC inject double bit, non-correctable error - txfifoinjd
8051  *
8052  * Changing this bit from zero to one injects a double, non-correctable error into
8053  * the EMAC1 TXFIFO RAM. This only injects one double bit error into the EMAC1
8054  * TXFIFO RAM.
8055  *
8056  * Field Access Macros:
8057  *
8058  */
8059 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
8060 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_LSB 2
8061 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
8062 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_MSB 2
8063 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
8064 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_WIDTH 1
8065 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field value. */
8066 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_SET_MSK 0x00000004
8067 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field value. */
8068 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_CLR_MSK 0xfffffffb
8069 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
8070 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_RESET 0x0
8071 /* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD field value from a register. */
8072 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_GET(value) (((value) & 0x00000004) >> 2)
8073 /* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field value suitable for setting the register. */
8074 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_SET(value) (((value) << 2) & 0x00000004)
8075
8076 /*
8077  * Field : EMAC1 RXFIFO RAM ECC inject single, correctable Error - rxfifoinjs
8078  *
8079  * Changing this bit from zero to one injects a single, correctable error into the
8080  * EMAC1 RXFIFO RAM. This only injects one error into the EMAC1 RXFIFO RAM.
8081  *
8082  * Field Access Macros:
8083  *
8084  */
8085 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
8086 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_LSB 3
8087 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
8088 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_MSB 3
8089 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
8090 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_WIDTH 1
8091 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field value. */
8092 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_SET_MSK 0x00000008
8093 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field value. */
8094 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_CLR_MSK 0xfffffff7
8095 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
8096 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_RESET 0x0
8097 /* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS field value from a register. */
8098 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_GET(value) (((value) & 0x00000008) >> 3)
8099 /* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field value suitable for setting the register. */
8100 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_SET(value) (((value) << 3) & 0x00000008)
8101
8102 /*
8103  * Field : EMAC1 RXFIFO RAM ECC inject double bit, non-correctable error - rxfifoinjd
8104  *
8105  * Changing this bit from zero to one injects a double, non-correctable error into
8106  * the EMAC1 RXFIFO RAM. This only injects one double bit error into the EMAC1
8107  * RXFIFO RAM.
8108  *
8109  * Field Access Macros:
8110  *
8111  */
8112 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
8113 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_LSB 4
8114 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
8115 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_MSB 4
8116 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
8117 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_WIDTH 1
8118 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field value. */
8119 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_SET_MSK 0x00000010
8120 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field value. */
8121 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_CLR_MSK 0xffffffef
8122 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
8123 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_RESET 0x0
8124 /* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD field value from a register. */
8125 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_GET(value) (((value) & 0x00000010) >> 4)
8126 /* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field value suitable for setting the register. */
8127 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_SET(value) (((value) << 4) & 0x00000010)
8128
8129 /*
8130  * Field : EMAC1 TXFIFO RAM ECC single, correctable error interrupt status - txfifoserr
8131  *
8132  * This bit is an interrupt status bit for EMAC1 TXFIFO RAM ECC single, correctable
8133  * error. It is set by hardware when single, correctable error occurs in EMAC1
8134  * TXFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
8135  * status.
8136  *
8137  * Field Access Macros:
8138  *
8139  */
8140 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
8141 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_LSB 5
8142 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
8143 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_MSB 5
8144 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
8145 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_WIDTH 1
8146 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field value. */
8147 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_SET_MSK 0x00000020
8148 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field value. */
8149 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_CLR_MSK 0xffffffdf
8150 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
8151 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_RESET 0x0
8152 /* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR field value from a register. */
8153 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_GET(value) (((value) & 0x00000020) >> 5)
8154 /* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field value suitable for setting the register. */
8155 #define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_SET(value) (((value) << 5) & 0x00000020)
8156
8157 /*
8158  * Field : EMAC1 TXFIFO RAM ECC double bit, non-correctable error interrupt status - txfifoderr
8159  *
8160  * This bit is an interrupt status bit for EMAC1 TXFIFO RAM ECC double bit, non-
8161  * correctable error. It is set by hardware when double bit, non-correctable error
8162  * occurs in EMAC1 TXFIFO RAM. Software needs to write 1 into this bit to clear the
8163  * interrupt status.
8164  *
8165  * Field Access Macros:
8166  *
8167  */
8168 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
8169 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_LSB 6
8170 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
8171 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_MSB 6
8172 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
8173 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_WIDTH 1
8174 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field value. */
8175 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_SET_MSK 0x00000040
8176 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field value. */
8177 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_CLR_MSK 0xffffffbf
8178 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
8179 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_RESET 0x0
8180 /* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR field value from a register. */
8181 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_GET(value) (((value) & 0x00000040) >> 6)
8182 /* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field value suitable for setting the register. */
8183 #define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_SET(value) (((value) << 6) & 0x00000040)
8184
8185 /*
8186  * Field : EMAC1 RXFIFO RAM ECC single, correctable error interrupt status - rxfifoserr
8187  *
8188  * This bit is an interrupt status bit for EMAC1 RXFIFO RAM ECC single, correctable
8189  * error. It is set by hardware when single, correctable error occurs in EMAC1
8190  * RXFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
8191  * status.
8192  *
8193  * Field Access Macros:
8194  *
8195  */
8196 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
8197 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_LSB 7
8198 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
8199 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_MSB 7
8200 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
8201 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_WIDTH 1
8202 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field value. */
8203 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_SET_MSK 0x00000080
8204 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field value. */
8205 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_CLR_MSK 0xffffff7f
8206 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
8207 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_RESET 0x0
8208 /* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR field value from a register. */
8209 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_GET(value) (((value) & 0x00000080) >> 7)
8210 /* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field value suitable for setting the register. */
8211 #define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_SET(value) (((value) << 7) & 0x00000080)
8212
8213 /*
8214  * Field : EMAC1 RXFIFO RAM ECC double bit, non-correctable error interrupt status - rxfifoderr
8215  *
8216  * This bit is an interrupt status bit for EMAC1 RXFIFO RAM ECC double bit, non-
8217  * correctable error. It is set by hardware when double bit, non-correctable error
8218  * occurs in EMAC1 RXFIFO RAM. Software needs to write 1 into this bit to clear the
8219  * interrupt status.
8220  *
8221  * Field Access Macros:
8222  *
8223  */
8224 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
8225 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_LSB 8
8226 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
8227 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_MSB 8
8228 /* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
8229 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_WIDTH 1
8230 /* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field value. */
8231 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_SET_MSK 0x00000100
8232 /* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field value. */
8233 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_CLR_MSK 0xfffffeff
8234 /* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
8235 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_RESET 0x0
8236 /* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR field value from a register. */
8237 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_GET(value) (((value) & 0x00000100) >> 8)
8238 /* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field value suitable for setting the register. */
8239 #define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_SET(value) (((value) << 8) & 0x00000100)
8240
8241 #ifndef __ASSEMBLY__
8242 /*
8243  * WARNING: The C register and register group struct declarations are provided for
8244  * convenience and illustrative purposes. They should, however, be used with
8245  * caution as the C language standard provides no guarantees about the alignment or
8246  * atomicity of device memory accesses. The recommended practice for writing
8247  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
8248  * alt_write_word() functions.
8249  *
8250  * The struct declaration for register ALT_SYSMGR_ECC_EMAC1.
8251  */
8253 {
8254  uint32_t en : 1; /* EMAC1 RAM ECC Enable */
8255  uint32_t txfifoinjs : 1; /* EMAC1 TXFIFO RAM ECC inject single, correctable Error */
8256  uint32_t txfifoinjd : 1; /* EMAC1 TXFIFO RAM ECC inject double bit, non-correctable error */
8257  uint32_t rxfifoinjs : 1; /* EMAC1 RXFIFO RAM ECC inject single, correctable Error */
8258  uint32_t rxfifoinjd : 1; /* EMAC1 RXFIFO RAM ECC inject double bit, non-correctable error */
8259  uint32_t txfifoserr : 1; /* EMAC1 TXFIFO RAM ECC single, correctable error interrupt status */
8260  uint32_t txfifoderr : 1; /* EMAC1 TXFIFO RAM ECC double bit, non-correctable error interrupt status */
8261  uint32_t rxfifoserr : 1; /* EMAC1 RXFIFO RAM ECC single, correctable error interrupt status */
8262  uint32_t rxfifoderr : 1; /* EMAC1 RXFIFO RAM ECC double bit, non-correctable error interrupt status */
8263  uint32_t : 23; /* *UNDEFINED* */
8264 };
8265
8266 /* The typedef declaration for register ALT_SYSMGR_ECC_EMAC1. */
8267 typedef volatile struct ALT_SYSMGR_ECC_EMAC1_s ALT_SYSMGR_ECC_EMAC1_t;
8268 #endif /* __ASSEMBLY__ */
8269
8270 /* The byte offset of the ALT_SYSMGR_ECC_EMAC1 register from the beginning of the component. */
8271 #define ALT_SYSMGR_ECC_EMAC1_OFST 0x14
8272
8273 /*
8274  * Register : DMA RAM ECC Enable Register - dma
8275  *
8276  * This register is used to enable ECC on the DMA RAM. ECC errors can be injected
8277  * into the write path using bits in this register. This register contains
8278  * interrupt status of the ECC single/double bit error.
8279  *
8280  * Only reset by a cold reset (ignores warm reset).
8281  *
8282  * Register Layout
8283  *
8284  * Bits | Access | Reset | Description
8285  * :-------|:-------|:------|:---------------------------------------------------------------
8286  * [0] | RW | 0x0 | DMA RAM ECC Enable
8287  * [1] | RW | 0x0 | DMA RAM ECC inject single, correctable Error
8288  * [2] | RW | 0x0 | DMA RAM ECC inject double bit, non-correctable error
8289  * [3] | RW | 0x0 | DMA RAM ECC single, correctable error interrupt status
8290  * [4] | RW | 0x0 | DMA RAM ECC double bit, non-correctable error interrupt status
8291  * [31:5] | ??? | 0x0 | *UNDEFINED*
8292  *
8293  */
8294 /*
8295  * Field : DMA RAM ECC Enable - en
8296  *
8297  * Enable ECC for DMA RAM
8298  *
8299  * Field Access Macros:
8300  *
8301  */
8302 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_EN register field. */
8303 #define ALT_SYSMGR_ECC_DMA_EN_LSB 0
8304 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_EN register field. */
8305 #define ALT_SYSMGR_ECC_DMA_EN_MSB 0
8306 /* The width in bits of the ALT_SYSMGR_ECC_DMA_EN register field. */
8307 #define ALT_SYSMGR_ECC_DMA_EN_WIDTH 1
8308 /* The mask used to set the ALT_SYSMGR_ECC_DMA_EN register field value. */
8309 #define ALT_SYSMGR_ECC_DMA_EN_SET_MSK 0x00000001
8310 /* The mask used to clear the ALT_SYSMGR_ECC_DMA_EN register field value. */
8311 #define ALT_SYSMGR_ECC_DMA_EN_CLR_MSK 0xfffffffe
8312 /* The reset value of the ALT_SYSMGR_ECC_DMA_EN register field. */
8313 #define ALT_SYSMGR_ECC_DMA_EN_RESET 0x0
8314 /* Extracts the ALT_SYSMGR_ECC_DMA_EN field value from a register. */
8315 #define ALT_SYSMGR_ECC_DMA_EN_GET(value) (((value) & 0x00000001) >> 0)
8316 /* Produces a ALT_SYSMGR_ECC_DMA_EN register field value suitable for setting the register. */
8317 #define ALT_SYSMGR_ECC_DMA_EN_SET(value) (((value) << 0) & 0x00000001)
8318
8319 /*
8320  * Field : DMA RAM ECC inject single, correctable Error - injs
8321  *
8322  * Changing this bit from zero to one injects a single, correctable error into the
8323  * DMA RAM. This only injects one error into the DMA RAM.
8324  *
8325  * Field Access Macros:
8326  *
8327  */
8328 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_INJS register field. */
8329 #define ALT_SYSMGR_ECC_DMA_INJS_LSB 1
8330 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_INJS register field. */
8331 #define ALT_SYSMGR_ECC_DMA_INJS_MSB 1
8332 /* The width in bits of the ALT_SYSMGR_ECC_DMA_INJS register field. */
8333 #define ALT_SYSMGR_ECC_DMA_INJS_WIDTH 1
8334 /* The mask used to set the ALT_SYSMGR_ECC_DMA_INJS register field value. */
8335 #define ALT_SYSMGR_ECC_DMA_INJS_SET_MSK 0x00000002
8336 /* The mask used to clear the ALT_SYSMGR_ECC_DMA_INJS register field value. */
8337 #define ALT_SYSMGR_ECC_DMA_INJS_CLR_MSK 0xfffffffd
8338 /* The reset value of the ALT_SYSMGR_ECC_DMA_INJS register field. */
8339 #define ALT_SYSMGR_ECC_DMA_INJS_RESET 0x0
8340 /* Extracts the ALT_SYSMGR_ECC_DMA_INJS field value from a register. */
8341 #define ALT_SYSMGR_ECC_DMA_INJS_GET(value) (((value) & 0x00000002) >> 1)
8342 /* Produces a ALT_SYSMGR_ECC_DMA_INJS register field value suitable for setting the register. */
8343 #define ALT_SYSMGR_ECC_DMA_INJS_SET(value) (((value) << 1) & 0x00000002)
8344
8345 /*
8346  * Field : DMA RAM ECC inject double bit, non-correctable error - injd
8347  *
8348  * Changing this bit from zero to one injects a double, non-correctable error into
8349  * the DMA RAM. This only injects one double bit error into the DMA RAM.
8350  *
8351  * Field Access Macros:
8352  *
8353  */
8354 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_INJD register field. */
8355 #define ALT_SYSMGR_ECC_DMA_INJD_LSB 2
8356 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_INJD register field. */
8357 #define ALT_SYSMGR_ECC_DMA_INJD_MSB 2
8358 /* The width in bits of the ALT_SYSMGR_ECC_DMA_INJD register field. */
8359 #define ALT_SYSMGR_ECC_DMA_INJD_WIDTH 1
8360 /* The mask used to set the ALT_SYSMGR_ECC_DMA_INJD register field value. */
8361 #define ALT_SYSMGR_ECC_DMA_INJD_SET_MSK 0x00000004
8362 /* The mask used to clear the ALT_SYSMGR_ECC_DMA_INJD register field value. */
8363 #define ALT_SYSMGR_ECC_DMA_INJD_CLR_MSK 0xfffffffb
8364 /* The reset value of the ALT_SYSMGR_ECC_DMA_INJD register field. */
8365 #define ALT_SYSMGR_ECC_DMA_INJD_RESET 0x0
8366 /* Extracts the ALT_SYSMGR_ECC_DMA_INJD field value from a register. */
8367 #define ALT_SYSMGR_ECC_DMA_INJD_GET(value) (((value) & 0x00000004) >> 2)
8368 /* Produces a ALT_SYSMGR_ECC_DMA_INJD register field value suitable for setting the register. */
8369 #define ALT_SYSMGR_ECC_DMA_INJD_SET(value) (((value) << 2) & 0x00000004)
8370
8371 /*
8372  * Field : DMA RAM ECC single, correctable error interrupt status - serr
8373  *
8374  * This bit is an interrupt status bit for DMA RAM ECC single, correctable error.
8375  * It is set by hardware when single, correctable error occurs in DMA RAM. Software
8376  * needs to write 1 into this bit to clear the interrupt status.
8377  *
8378  * Field Access Macros:
8379  *
8380  */
8381 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_SERR register field. */
8382 #define ALT_SYSMGR_ECC_DMA_SERR_LSB 3
8383 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_SERR register field. */
8384 #define ALT_SYSMGR_ECC_DMA_SERR_MSB 3
8385 /* The width in bits of the ALT_SYSMGR_ECC_DMA_SERR register field. */
8386 #define ALT_SYSMGR_ECC_DMA_SERR_WIDTH 1
8387 /* The mask used to set the ALT_SYSMGR_ECC_DMA_SERR register field value. */
8388 #define ALT_SYSMGR_ECC_DMA_SERR_SET_MSK 0x00000008
8389 /* The mask used to clear the ALT_SYSMGR_ECC_DMA_SERR register field value. */
8390 #define ALT_SYSMGR_ECC_DMA_SERR_CLR_MSK 0xfffffff7
8391 /* The reset value of the ALT_SYSMGR_ECC_DMA_SERR register field. */
8392 #define ALT_SYSMGR_ECC_DMA_SERR_RESET 0x0
8393 /* Extracts the ALT_SYSMGR_ECC_DMA_SERR field value from a register. */
8394 #define ALT_SYSMGR_ECC_DMA_SERR_GET(value) (((value) & 0x00000008) >> 3)
8395 /* Produces a ALT_SYSMGR_ECC_DMA_SERR register field value suitable for setting the register. */
8396 #define ALT_SYSMGR_ECC_DMA_SERR_SET(value) (((value) << 3) & 0x00000008)
8397
8398 /*
8399  * Field : DMA RAM ECC double bit, non-correctable error interrupt status - derr
8400  *
8401  * This bit is an interrupt status bit for DMA RAM ECC double bit, non-correctable
8402  * error. It is set by hardware when double bit, non-correctable error occurs in
8403  * DMA RAM. Software needs to write 1 into this bit to clear the interrupt status.
8404  *
8405  * Field Access Macros:
8406  *
8407  */
8408 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_DERR register field. */
8409 #define ALT_SYSMGR_ECC_DMA_DERR_LSB 4
8410 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_DERR register field. */
8411 #define ALT_SYSMGR_ECC_DMA_DERR_MSB 4
8412 /* The width in bits of the ALT_SYSMGR_ECC_DMA_DERR register field. */
8413 #define ALT_SYSMGR_ECC_DMA_DERR_WIDTH 1
8414 /* The mask used to set the ALT_SYSMGR_ECC_DMA_DERR register field value. */
8415 #define ALT_SYSMGR_ECC_DMA_DERR_SET_MSK 0x00000010
8416 /* The mask used to clear the ALT_SYSMGR_ECC_DMA_DERR register field value. */
8417 #define ALT_SYSMGR_ECC_DMA_DERR_CLR_MSK 0xffffffef
8418 /* The reset value of the ALT_SYSMGR_ECC_DMA_DERR register field. */
8419 #define ALT_SYSMGR_ECC_DMA_DERR_RESET 0x0
8420 /* Extracts the ALT_SYSMGR_ECC_DMA_DERR field value from a register. */
8421 #define ALT_SYSMGR_ECC_DMA_DERR_GET(value) (((value) & 0x00000010) >> 4)
8422 /* Produces a ALT_SYSMGR_ECC_DMA_DERR register field value suitable for setting the register. */
8423 #define ALT_SYSMGR_ECC_DMA_DERR_SET(value) (((value) << 4) & 0x00000010)
8424
8425 #ifndef __ASSEMBLY__
8426 /*
8427  * WARNING: The C register and register group struct declarations are provided for
8428  * convenience and illustrative purposes. They should, however, be used with
8429  * caution as the C language standard provides no guarantees about the alignment or
8430  * atomicity of device memory accesses. The recommended practice for writing
8431  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
8432  * alt_write_word() functions.
8433  *
8434  * The struct declaration for register ALT_SYSMGR_ECC_DMA.
8435  */
8437 {
8438  uint32_t en : 1; /* DMA RAM ECC Enable */
8439  uint32_t injs : 1; /* DMA RAM ECC inject single, correctable Error */
8440  uint32_t injd : 1; /* DMA RAM ECC inject double bit, non-correctable error */
8441  uint32_t serr : 1; /* DMA RAM ECC single, correctable error interrupt status */
8442  uint32_t derr : 1; /* DMA RAM ECC double bit, non-correctable error interrupt status */
8443  uint32_t : 27; /* *UNDEFINED* */
8444 };
8445
8446 /* The typedef declaration for register ALT_SYSMGR_ECC_DMA. */
8447 typedef volatile struct ALT_SYSMGR_ECC_DMA_s ALT_SYSMGR_ECC_DMA_t;
8448 #endif /* __ASSEMBLY__ */
8449
8450 /* The byte offset of the ALT_SYSMGR_ECC_DMA register from the beginning of the component. */
8451 #define ALT_SYSMGR_ECC_DMA_OFST 0x18
8452
8453 /*
8454  * Register : CAN0 RAM ECC Enable Register - can0
8455  *
8456  * This register is used to enable ECC on the CAN0 RAM. ECC errors can be injected
8457  * into the write path using bits in this register. This register contains
8458  * interrupt status of the ECC single/double bit error.
8459  *
8460  * Only reset by a cold reset (ignores warm reset).
8461  *
8462  * Register Layout
8463  *
8464  * Bits | Access | Reset | Description
8465  * :-------|:-------|:------|:----------------------------------------------------------------
8466  * [0] | RW | 0x0 | CAN0 RAM ECC Enable
8467  * [1] | RW | 0x0 | CAN0 RAM ECC inject single, correctable Error
8468  * [2] | RW | 0x0 | CAN0 RAM ECC inject double bit, non-correctable error
8469  * [3] | RW | 0x0 | CAN0 RAM ECC single, correctable error interrupt status
8470  * [4] | RW | 0x0 | CAN0 RAM ECC double bit, non-correctable error interrupt status
8471  * [31:5] | ??? | 0x0 | *UNDEFINED*
8472  *
8473  */
8474 /*
8475  * Field : CAN0 RAM ECC Enable - en
8476  *
8477  * Enable ECC for CAN0 RAM
8478  *
8479  * Field Access Macros:
8480  *
8481  */
8482 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_EN register field. */
8483 #define ALT_SYSMGR_ECC_CAN0_EN_LSB 0
8484 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_EN register field. */
8485 #define ALT_SYSMGR_ECC_CAN0_EN_MSB 0
8486 /* The width in bits of the ALT_SYSMGR_ECC_CAN0_EN register field. */
8487 #define ALT_SYSMGR_ECC_CAN0_EN_WIDTH 1
8488 /* The mask used to set the ALT_SYSMGR_ECC_CAN0_EN register field value. */
8489 #define ALT_SYSMGR_ECC_CAN0_EN_SET_MSK 0x00000001
8490 /* The mask used to clear the ALT_SYSMGR_ECC_CAN0_EN register field value. */
8491 #define ALT_SYSMGR_ECC_CAN0_EN_CLR_MSK 0xfffffffe
8492 /* The reset value of the ALT_SYSMGR_ECC_CAN0_EN register field. */
8493 #define ALT_SYSMGR_ECC_CAN0_EN_RESET 0x0
8494 /* Extracts the ALT_SYSMGR_ECC_CAN0_EN field value from a register. */
8495 #define ALT_SYSMGR_ECC_CAN0_EN_GET(value) (((value) & 0x00000001) >> 0)
8496 /* Produces a ALT_SYSMGR_ECC_CAN0_EN register field value suitable for setting the register. */
8497 #define ALT_SYSMGR_ECC_CAN0_EN_SET(value) (((value) << 0) & 0x00000001)
8498
8499 /*
8500  * Field : CAN0 RAM ECC inject single, correctable Error - injs
8501  *
8502  * Changing this bit from zero to one injects a single, correctable error into the
8503  * CAN0 RAM. This only injects one error into the CAN0 RAM.
8504  *
8505  * Field Access Macros:
8506  *
8507  */
8508 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
8509 #define ALT_SYSMGR_ECC_CAN0_INJS_LSB 1
8510 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
8511 #define ALT_SYSMGR_ECC_CAN0_INJS_MSB 1
8512 /* The width in bits of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
8513 #define ALT_SYSMGR_ECC_CAN0_INJS_WIDTH 1
8514 /* The mask used to set the ALT_SYSMGR_ECC_CAN0_INJS register field value. */
8515 #define ALT_SYSMGR_ECC_CAN0_INJS_SET_MSK 0x00000002
8516 /* The mask used to clear the ALT_SYSMGR_ECC_CAN0_INJS register field value. */
8517 #define ALT_SYSMGR_ECC_CAN0_INJS_CLR_MSK 0xfffffffd
8518 /* The reset value of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
8519 #define ALT_SYSMGR_ECC_CAN0_INJS_RESET 0x0
8520 /* Extracts the ALT_SYSMGR_ECC_CAN0_INJS field value from a register. */
8521 #define ALT_SYSMGR_ECC_CAN0_INJS_GET(value) (((value) & 0x00000002) >> 1)
8522 /* Produces a ALT_SYSMGR_ECC_CAN0_INJS register field value suitable for setting the register. */
8523 #define ALT_SYSMGR_ECC_CAN0_INJS_SET(value) (((value) << 1) & 0x00000002)
8524
8525 /*
8526  * Field : CAN0 RAM ECC inject double bit, non-correctable error - injd
8527  *
8528  * Changing this bit from zero to one injects a double, non-correctable error into
8529  * the CAN0 RAM. This only injects one double bit error into the CAN0 RAM.
8530  *
8531  * Field Access Macros:
8532  *
8533  */
8534 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
8535 #define ALT_SYSMGR_ECC_CAN0_INJD_LSB 2
8536 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
8537 #define ALT_SYSMGR_ECC_CAN0_INJD_MSB 2
8538 /* The width in bits of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
8539 #define ALT_SYSMGR_ECC_CAN0_INJD_WIDTH 1
8540 /* The mask used to set the ALT_SYSMGR_ECC_CAN0_INJD register field value. */
8541 #define ALT_SYSMGR_ECC_CAN0_INJD_SET_MSK 0x00000004
8542 /* The mask used to clear the ALT_SYSMGR_ECC_CAN0_INJD register field value. */
8543 #define ALT_SYSMGR_ECC_CAN0_INJD_CLR_MSK 0xfffffffb
8544 /* The reset value of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
8545 #define ALT_SYSMGR_ECC_CAN0_INJD_RESET 0x0
8546 /* Extracts the ALT_SYSMGR_ECC_CAN0_INJD field value from a register. */
8547 #define ALT_SYSMGR_ECC_CAN0_INJD_GET(value) (((value) & 0x00000004) >> 2)
8548 /* Produces a ALT_SYSMGR_ECC_CAN0_INJD register field value suitable for setting the register. */
8549 #define ALT_SYSMGR_ECC_CAN0_INJD_SET(value) (((value) << 2) & 0x00000004)
8550
8551 /*
8552  * Field : CAN0 RAM ECC single, correctable error interrupt status - serr
8553  *
8554  * This bit is an interrupt status bit for CAN0 RAM ECC single, correctable error.
8555  * It is set by hardware when single, correctable error occurs in CAN0 RAM.
8556  * Software needs to write 1 into this bit to clear the interrupt status.
8557  *
8558  * Field Access Macros:
8559  *
8560  */
8561 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
8562 #define ALT_SYSMGR_ECC_CAN0_SERR_LSB 3
8563 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
8564 #define ALT_SYSMGR_ECC_CAN0_SERR_MSB 3
8565 /* The width in bits of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
8566 #define ALT_SYSMGR_ECC_CAN0_SERR_WIDTH 1
8567 /* The mask used to set the ALT_SYSMGR_ECC_CAN0_SERR register field value. */
8568 #define ALT_SYSMGR_ECC_CAN0_SERR_SET_MSK 0x00000008
8569 /* The mask used to clear the ALT_SYSMGR_ECC_CAN0_SERR register field value. */
8570 #define ALT_SYSMGR_ECC_CAN0_SERR_CLR_MSK 0xfffffff7
8571 /* The reset value of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
8572 #define ALT_SYSMGR_ECC_CAN0_SERR_RESET 0x0
8573 /* Extracts the ALT_SYSMGR_ECC_CAN0_SERR field value from a register. */
8574 #define ALT_SYSMGR_ECC_CAN0_SERR_GET(value) (((value) & 0x00000008) >> 3)
8575 /* Produces a ALT_SYSMGR_ECC_CAN0_SERR register field value suitable for setting the register. */
8576 #define ALT_SYSMGR_ECC_CAN0_SERR_SET(value) (((value) << 3) & 0x00000008)
8577
8578 /*
8579  * Field : CAN0 RAM ECC double bit, non-correctable error interrupt status - derr
8580  *
8581  * This bit is an interrupt status bit for CAN0 RAM ECC double bit, non-correctable
8582  * error. It is set by hardware when double bit, non-correctable error occurs in
8583  * CAN0 RAM. Software needs to write 1 into this bit to clear the interrupt status.
8584  *
8585  * Field Access Macros:
8586  *
8587  */
8588 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
8589 #define ALT_SYSMGR_ECC_CAN0_DERR_LSB 4
8590 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
8591 #define ALT_SYSMGR_ECC_CAN0_DERR_MSB 4
8592 /* The width in bits of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
8593 #define ALT_SYSMGR_ECC_CAN0_DERR_WIDTH 1
8594 /* The mask used to set the ALT_SYSMGR_ECC_CAN0_DERR register field value. */
8595 #define ALT_SYSMGR_ECC_CAN0_DERR_SET_MSK 0x00000010
8596 /* The mask used to clear the ALT_SYSMGR_ECC_CAN0_DERR register field value. */
8597 #define ALT_SYSMGR_ECC_CAN0_DERR_CLR_MSK 0xffffffef
8598 /* The reset value of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
8599 #define ALT_SYSMGR_ECC_CAN0_DERR_RESET 0x0
8600 /* Extracts the ALT_SYSMGR_ECC_CAN0_DERR field value from a register. */
8601 #define ALT_SYSMGR_ECC_CAN0_DERR_GET(value) (((value) & 0x00000010) >> 4)
8602 /* Produces a ALT_SYSMGR_ECC_CAN0_DERR register field value suitable for setting the register. */
8603 #define ALT_SYSMGR_ECC_CAN0_DERR_SET(value) (((value) << 4) & 0x00000010)
8604
8605 #ifndef __ASSEMBLY__
8606 /*
8607  * WARNING: The C register and register group struct declarations are provided for
8608  * convenience and illustrative purposes. They should, however, be used with
8609  * caution as the C language standard provides no guarantees about the alignment or
8610  * atomicity of device memory accesses. The recommended practice for writing
8611  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
8612  * alt_write_word() functions.
8613  *
8614  * The struct declaration for register ALT_SYSMGR_ECC_CAN0.
8615  */
8617 {
8618  uint32_t en : 1; /* CAN0 RAM ECC Enable */
8619  uint32_t injs : 1; /* CAN0 RAM ECC inject single, correctable Error */
8620  uint32_t injd : 1; /* CAN0 RAM ECC inject double bit, non-correctable error */
8621  uint32_t serr : 1; /* CAN0 RAM ECC single, correctable error interrupt status */
8622  uint32_t derr : 1; /* CAN0 RAM ECC double bit, non-correctable error interrupt status */
8623  uint32_t : 27; /* *UNDEFINED* */
8624 };
8625
8626 /* The typedef declaration for register ALT_SYSMGR_ECC_CAN0. */
8627 typedef volatile struct ALT_SYSMGR_ECC_CAN0_s ALT_SYSMGR_ECC_CAN0_t;
8628 #endif /* __ASSEMBLY__ */
8629
8630 /* The byte offset of the ALT_SYSMGR_ECC_CAN0 register from the beginning of the component. */
8631 #define ALT_SYSMGR_ECC_CAN0_OFST 0x1c
8632
8633 /*
8634  * Register : CAN1 RAM ECC Enable Register - can1
8635  *
8636  * This register is used to enable ECC on the CAN1 RAM. ECC errors can be injected
8637  * into the write path using bits in this register. This register contains
8638  * interrupt status of the ECC single/double bit error.
8639  *
8640  * Only reset by a cold reset (ignores warm reset).
8641  *
8642  * Register Layout
8643  *
8644  * Bits | Access | Reset | Description
8645  * :-------|:-------|:------|:----------------------------------------------------------------
8646  * [0] | RW | 0x0 | CAN1 RAM ECC Enable
8647  * [1] | RW | 0x0 | CAN1 RAM ECC inject single, correctable Error
8648  * [2] | RW | 0x0 | CAN1 RAM ECC inject double bit, non-correctable error
8649  * [3] | RW | 0x0 | CAN1 RAM ECC single, correctable error interrupt status
8650  * [4] | RW | 0x0 | CAN1 RAM ECC double bit, non-correctable error interrupt status
8651  * [31:5] | ??? | 0x0 | *UNDEFINED*
8652  *
8653  */
8654 /*
8655  * Field : CAN1 RAM ECC Enable - en
8656  *
8657  * Enable ECC for CAN1 RAM
8658  *
8659  * Field Access Macros:
8660  *
8661  */
8662 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_EN register field. */
8663 #define ALT_SYSMGR_ECC_CAN1_EN_LSB 0
8664 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_EN register field. */
8665 #define ALT_SYSMGR_ECC_CAN1_EN_MSB 0
8666 /* The width in bits of the ALT_SYSMGR_ECC_CAN1_EN register field. */
8667 #define ALT_SYSMGR_ECC_CAN1_EN_WIDTH 1
8668 /* The mask used to set the ALT_SYSMGR_ECC_CAN1_EN register field value. */
8669 #define ALT_SYSMGR_ECC_CAN1_EN_SET_MSK 0x00000001
8670 /* The mask used to clear the ALT_SYSMGR_ECC_CAN1_EN register field value. */
8671 #define ALT_SYSMGR_ECC_CAN1_EN_CLR_MSK 0xfffffffe
8672 /* The reset value of the ALT_SYSMGR_ECC_CAN1_EN register field. */
8673 #define ALT_SYSMGR_ECC_CAN1_EN_RESET 0x0
8674 /* Extracts the ALT_SYSMGR_ECC_CAN1_EN field value from a register. */
8675 #define ALT_SYSMGR_ECC_CAN1_EN_GET(value) (((value) & 0x00000001) >> 0)
8676 /* Produces a ALT_SYSMGR_ECC_CAN1_EN register field value suitable for setting the register. */
8677 #define ALT_SYSMGR_ECC_CAN1_EN_SET(value) (((value) << 0) & 0x00000001)
8678
8679 /*
8680  * Field : CAN1 RAM ECC inject single, correctable Error - injs
8681  *
8682  * Changing this bit from zero to one injects a single, correctable error into the
8683  * CAN1 RAM. This only injects one error into the CAN1 RAM.
8684  *
8685  * Field Access Macros:
8686  *
8687  */
8688 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
8689 #define ALT_SYSMGR_ECC_CAN1_INJS_LSB 1
8690 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
8691 #define ALT_SYSMGR_ECC_CAN1_INJS_MSB 1
8692 /* The width in bits of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
8693 #define ALT_SYSMGR_ECC_CAN1_INJS_WIDTH 1
8694 /* The mask used to set the ALT_SYSMGR_ECC_CAN1_INJS register field value. */
8695 #define ALT_SYSMGR_ECC_CAN1_INJS_SET_MSK 0x00000002
8696 /* The mask used to clear the ALT_SYSMGR_ECC_CAN1_INJS register field value. */
8697 #define ALT_SYSMGR_ECC_CAN1_INJS_CLR_MSK 0xfffffffd
8698 /* The reset value of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
8699 #define ALT_SYSMGR_ECC_CAN1_INJS_RESET 0x0
8700 /* Extracts the ALT_SYSMGR_ECC_CAN1_INJS field value from a register. */
8701 #define ALT_SYSMGR_ECC_CAN1_INJS_GET(value) (((value) & 0x00000002) >> 1)
8702 /* Produces a ALT_SYSMGR_ECC_CAN1_INJS register field value suitable for setting the register. */
8703 #define ALT_SYSMGR_ECC_CAN1_INJS_SET(value) (((value) << 1) & 0x00000002)
8704
8705 /*
8706  * Field : CAN1 RAM ECC inject double bit, non-correctable error - injd
8707  *
8708  * Changing this bit from zero to one injects a double, non-correctable error into
8709  * the CAN1 RAM. This only injects one double bit error into the CAN1 RAM.
8710  *
8711  * Field Access Macros:
8712  *
8713  */
8714 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
8715 #define ALT_SYSMGR_ECC_CAN1_INJD_LSB 2
8716 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
8717 #define ALT_SYSMGR_ECC_CAN1_INJD_MSB 2
8718 /* The width in bits of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
8719 #define ALT_SYSMGR_ECC_CAN1_INJD_WIDTH 1
8720 /* The mask used to set the ALT_SYSMGR_ECC_CAN1_INJD register field value. */
8721 #define ALT_SYSMGR_ECC_CAN1_INJD_SET_MSK 0x00000004
8722 /* The mask used to clear the ALT_SYSMGR_ECC_CAN1_INJD register field value. */
8723 #define ALT_SYSMGR_ECC_CAN1_INJD_CLR_MSK 0xfffffffb
8724 /* The reset value of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
8725 #define ALT_SYSMGR_ECC_CAN1_INJD_RESET 0x0
8726 /* Extracts the ALT_SYSMGR_ECC_CAN1_INJD field value from a register. */
8727 #define ALT_SYSMGR_ECC_CAN1_INJD_GET(value) (((value) & 0x00000004) >> 2)
8728 /* Produces a ALT_SYSMGR_ECC_CAN1_INJD register field value suitable for setting the register. */
8729 #define ALT_SYSMGR_ECC_CAN1_INJD_SET(value) (((value) << 2) & 0x00000004)
8730
8731 /*
8732  * Field : CAN1 RAM ECC single, correctable error interrupt status - serr
8733  *
8734  * This bit is an interrupt status bit for CAN1 RAM ECC single, correctable error.
8735  * It is set by hardware when single, correctable error occurs in CAN1 RAM.
8736  * Software needs to write 1 into this bit to clear the interrupt status.
8737  *
8738  * Field Access Macros:
8739  *
8740  */
8741 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
8742 #define ALT_SYSMGR_ECC_CAN1_SERR_LSB 3
8743 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
8744 #define ALT_SYSMGR_ECC_CAN1_SERR_MSB 3
8745 /* The width in bits of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
8746 #define ALT_SYSMGR_ECC_CAN1_SERR_WIDTH 1
8747 /* The mask used to set the ALT_SYSMGR_ECC_CAN1_SERR register field value. */
8748 #define ALT_SYSMGR_ECC_CAN1_SERR_SET_MSK 0x00000008
8749 /* The mask used to clear the ALT_SYSMGR_ECC_CAN1_SERR register field value. */
8750 #define ALT_SYSMGR_ECC_CAN1_SERR_CLR_MSK 0xfffffff7
8751 /* The reset value of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
8752 #define ALT_SYSMGR_ECC_CAN1_SERR_RESET 0x0
8753 /* Extracts the ALT_SYSMGR_ECC_CAN1_SERR field value from a register. */
8754 #define ALT_SYSMGR_ECC_CAN1_SERR_GET(value) (((value) & 0x00000008) >> 3)
8755 /* Produces a ALT_SYSMGR_ECC_CAN1_SERR register field value suitable for setting the register. */
8756 #define ALT_SYSMGR_ECC_CAN1_SERR_SET(value) (((value) << 3) & 0x00000008)
8757
8758 /*
8759  * Field : CAN1 RAM ECC double bit, non-correctable error interrupt status - derr
8760  *
8761  * This bit is an interrupt status bit for CAN1 RAM ECC double bit, non-correctable
8762  * error. It is set by hardware when double bit, non-correctable error occurs in
8763  * CAN1 RAM. Software needs to write 1 into this bit to clear the interrupt status.
8764  *
8765  * Field Access Macros:
8766  *
8767  */
8768 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
8769 #define ALT_SYSMGR_ECC_CAN1_DERR_LSB 4
8770 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
8771 #define ALT_SYSMGR_ECC_CAN1_DERR_MSB 4
8772 /* The width in bits of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
8773 #define ALT_SYSMGR_ECC_CAN1_DERR_WIDTH 1
8774 /* The mask used to set the ALT_SYSMGR_ECC_CAN1_DERR register field value. */
8775 #define ALT_SYSMGR_ECC_CAN1_DERR_SET_MSK 0x00000010
8776 /* The mask used to clear the ALT_SYSMGR_ECC_CAN1_DERR register field value. */
8777 #define ALT_SYSMGR_ECC_CAN1_DERR_CLR_MSK 0xffffffef
8778 /* The reset value of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
8779 #define ALT_SYSMGR_ECC_CAN1_DERR_RESET 0x0
8780 /* Extracts the ALT_SYSMGR_ECC_CAN1_DERR field value from a register. */
8781 #define ALT_SYSMGR_ECC_CAN1_DERR_GET(value) (((value) & 0x00000010) >> 4)
8782 /* Produces a ALT_SYSMGR_ECC_CAN1_DERR register field value suitable for setting the register. */
8783 #define ALT_SYSMGR_ECC_CAN1_DERR_SET(value) (((value) << 4) & 0x00000010)
8784
8785 #ifndef __ASSEMBLY__
8786 /*
8787  * WARNING: The C register and register group struct declarations are provided for
8788  * convenience and illustrative purposes. They should, however, be used with
8789  * caution as the C language standard provides no guarantees about the alignment or
8790  * atomicity of device memory accesses. The recommended practice for writing
8791  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
8792  * alt_write_word() functions.
8793  *
8794  * The struct declaration for register ALT_SYSMGR_ECC_CAN1.
8795  */
8797 {
8798  uint32_t en : 1; /* CAN1 RAM ECC Enable */
8799  uint32_t injs : 1; /* CAN1 RAM ECC inject single, correctable Error */
8800  uint32_t injd : 1; /* CAN1 RAM ECC inject double bit, non-correctable error */
8801  uint32_t serr : 1; /* CAN1 RAM ECC single, correctable error interrupt status */
8802  uint32_t derr : 1; /* CAN1 RAM ECC double bit, non-correctable error interrupt status */
8803  uint32_t : 27; /* *UNDEFINED* */
8804 };
8805
8806 /* The typedef declaration for register ALT_SYSMGR_ECC_CAN1. */
8807 typedef volatile struct ALT_SYSMGR_ECC_CAN1_s ALT_SYSMGR_ECC_CAN1_t;
8808 #endif /* __ASSEMBLY__ */
8809
8810 /* The byte offset of the ALT_SYSMGR_ECC_CAN1 register from the beginning of the component. */
8811 #define ALT_SYSMGR_ECC_CAN1_OFST 0x20
8812
8813 /*
8814  * Register : NAND RAM ECC Enable Register - nand
8815  *
8816  * This register is used to enable ECC on the NAND RAM. ECC errors can be injected
8817  * into the write path using bits in this register. This register contains
8818  * interrupt status of the ECC single/double bit error.
8819  *
8820  * Only reset by a cold reset (ignores warm reset).
8821  *
8822  * Register Layout
8823  *
8824  * Bits | Access | Reset | Description
8825  * :--------|:-------|:------|:--------------------------------------------------------------------------
8826  * [0] | RW | 0x0 | NAND RAM ECC Enable
8827  * [1] | RW | 0x0 | NAND ECCBUFFER RAM ECC inject single, correctable Error
8828  * [2] | RW | 0x0 | NAND ECCBUFFER RAM ECC inject double bit, non-correctable error
8829  * [3] | RW | 0x0 | NAND WRFIFO RAM ECC inject single, correctable Error
8830  * [4] | RW | 0x0 | NAND WRFIFO RAM ECC inject double bit, non-correctable error
8831  * [5] | RW | 0x0 | NAND RDFIFO RAM ECC inject single, correctable Error
8832  * [6] | RW | 0x0 | NAND RDFIFO RAM ECC inject double bit, non-correctable error
8833  * [7] | RW | 0x0 | NAND ECCBUFFER RAM ECC single, correctable error interrupt status
8834  * [8] | RW | 0x0 | NAND ECCBUFFER RAM ECC double bit, non-correctable error interrupt status
8835  * [9] | RW | 0x0 | NAND WRFIFO RAM ECC single, correctable error interrupt status
8836  * [10] | RW | 0x0 | NAND WRFIFO RAM ECC double bit, non-correctable error interrupt status
8837  * [11] | RW | 0x0 | NAND RDFIFO RAM ECC single, correctable error interrupt status
8838  * [12] | RW | 0x0 | NAND RDFIFO RAM ECC double bit, non-correctable error interrupt status
8839  * [31:13] | ??? | 0x0 | *UNDEFINED*
8840  *
8841  */
8842 /*
8843  * Field : NAND RAM ECC Enable - en
8844  *
8845  * Enable ECC for NAND RAM
8846  *
8847  * Field Access Macros:
8848  *
8849  */
8850 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_EN register field. */
8851 #define ALT_SYSMGR_ECC_NAND_EN_LSB 0
8852 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_EN register field. */
8853 #define ALT_SYSMGR_ECC_NAND_EN_MSB 0
8854 /* The width in bits of the ALT_SYSMGR_ECC_NAND_EN register field. */
8855 #define ALT_SYSMGR_ECC_NAND_EN_WIDTH 1
8856 /* The mask used to set the ALT_SYSMGR_ECC_NAND_EN register field value. */
8857 #define ALT_SYSMGR_ECC_NAND_EN_SET_MSK 0x00000001
8858 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_EN register field value. */
8859 #define ALT_SYSMGR_ECC_NAND_EN_CLR_MSK 0xfffffffe
8860 /* The reset value of the ALT_SYSMGR_ECC_NAND_EN register field. */
8861 #define ALT_SYSMGR_ECC_NAND_EN_RESET 0x0
8862 /* Extracts the ALT_SYSMGR_ECC_NAND_EN field value from a register. */
8863 #define ALT_SYSMGR_ECC_NAND_EN_GET(value) (((value) & 0x00000001) >> 0)
8864 /* Produces a ALT_SYSMGR_ECC_NAND_EN register field value suitable for setting the register. */
8865 #define ALT_SYSMGR_ECC_NAND_EN_SET(value) (((value) << 0) & 0x00000001)
8866
8867 /*
8868  * Field : NAND ECCBUFFER RAM ECC inject single, correctable Error - eccbufinjs
8869  *
8870  * Changing this bit from zero to one injects a single, correctable error into the
8871  * NAND ECCBUFFER RAM. This only injects one error into the NAND ECCBUFFER RAM.
8872  *
8873  * Field Access Macros:
8874  *
8875  */
8876 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
8877 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_LSB 1
8878 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
8879 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_MSB 1
8880 /* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
8881 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_WIDTH 1
8882 /* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field value. */
8883 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_SET_MSK 0x00000002
8884 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field value. */
8885 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_CLR_MSK 0xfffffffd
8886 /* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
8887 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_RESET 0x0
8888 /* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFINJS field value from a register. */
8889 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_GET(value) (((value) & 0x00000002) >> 1)
8890 /* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field value suitable for setting the register. */
8891 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_SET(value) (((value) << 1) & 0x00000002)
8892
8893 /*
8894  * Field : NAND ECCBUFFER RAM ECC inject double bit, non-correctable error - eccbufinjd
8895  *
8896  * Changing this bit from zero to one injects a double, non-correctable error into
8897  * the NAND ECCBUFFER RAM. This only injects one double bit error into the NAND
8898  * ECCBUFFER RAM.
8899  *
8900  * Field Access Macros:
8901  *
8902  */
8903 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
8904 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_LSB 2
8905 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
8906 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_MSB 2
8907 /* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
8908 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_WIDTH 1
8909 /* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field value. */
8910 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_SET_MSK 0x00000004
8911 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field value. */
8912 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_CLR_MSK 0xfffffffb
8913 /* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
8914 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_RESET 0x0
8915 /* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFINJD field value from a register. */
8916 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_GET(value) (((value) & 0x00000004) >> 2)
8917 /* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field value suitable for setting the register. */
8918 #define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_SET(value) (((value) << 2) & 0x00000004)
8919
8920 /*
8921  * Field : NAND WRFIFO RAM ECC inject single, correctable Error - wrfifoinjs
8922  *
8923  * Changing this bit from zero to one injects a single, correctable error into the
8924  * NAND WRFIFO RAM. This only injects one error into the NAND WRFIFO RAM.
8925  *
8926  * Field Access Macros:
8927  *
8928  */
8929 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
8930 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_LSB 3
8931 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
8932 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_MSB 3
8933 /* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
8934 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_WIDTH 1
8935 /* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field value. */
8936 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_SET_MSK 0x00000008
8937 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field value. */
8938 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_CLR_MSK 0xfffffff7
8939 /* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
8940 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_RESET 0x0
8941 /* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFOINJS field value from a register. */
8942 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_GET(value) (((value) & 0x00000008) >> 3)
8943 /* Produces a ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field value suitable for setting the register. */
8944 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_SET(value) (((value) << 3) & 0x00000008)
8945
8946 /*
8947  * Field : NAND WRFIFO RAM ECC inject double bit, non-correctable error - wrfifoinjd
8948  *
8949  * Changing this bit from zero to one injects a double, non-correctable error into
8950  * the NAND WRFIFO RAM. This only injects one double bit error into the NAND WRFIFO
8951  * RAM.
8952  *
8953  * Field Access Macros:
8954  *
8955  */
8956 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
8957 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_LSB 4
8958 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
8959 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_MSB 4
8960 /* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
8961 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_WIDTH 1
8962 /* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field value. */
8963 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_SET_MSK 0x00000010
8964 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field value. */
8965 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_CLR_MSK 0xffffffef
8966 /* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
8967 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_RESET 0x0
8968 /* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFOINJD field value from a register. */
8969 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_GET(value) (((value) & 0x00000010) >> 4)
8970 /* Produces a ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field value suitable for setting the register. */
8971 #define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_SET(value) (((value) << 4) & 0x00000010)
8972
8973 /*
8974  * Field : NAND RDFIFO RAM ECC inject single, correctable Error - rdfifoinjs
8975  *
8976  * Changing this bit from zero to one injects a single, correctable error into the
8977  * NAND RDFIFO RAM. This only injects one error into the NAND RDFIFO RAM.
8978  *
8979  * Field Access Macros:
8980  *
8981  */
8982 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
8983 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_LSB 5
8984 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
8985 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_MSB 5
8986 /* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
8987 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_WIDTH 1
8988 /* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field value. */
8989 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_SET_MSK 0x00000020
8990 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field value. */
8991 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_CLR_MSK 0xffffffdf
8992 /* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
8993 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_RESET 0x0
8994 /* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFOINJS field value from a register. */
8995 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_GET(value) (((value) & 0x00000020) >> 5)
8996 /* Produces a ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field value suitable for setting the register. */
8997 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_SET(value) (((value) << 5) & 0x00000020)
8998
8999 /*
9000  * Field : NAND RDFIFO RAM ECC inject double bit, non-correctable error - rdfifoinjd
9001  *
9002  * Changing this bit from zero to one injects a double, non-correctable error into
9003  * the NAND RDFIFO RAM. This only injects one double bit error into the NAND RDFIFO
9004  * RAM.
9005  *
9006  * Field Access Macros:
9007  *
9008  */
9009 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
9010 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_LSB 6
9011 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
9012 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_MSB 6
9013 /* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
9014 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_WIDTH 1
9015 /* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field value. */
9016 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_SET_MSK 0x00000040
9017 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field value. */
9018 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_CLR_MSK 0xffffffbf
9019 /* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
9020 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_RESET 0x0
9021 /* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFOINJD field value from a register. */
9022 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_GET(value) (((value) & 0x00000040) >> 6)
9023 /* Produces a ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field value suitable for setting the register. */
9024 #define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_SET(value) (((value) << 6) & 0x00000040)
9025
9026 /*
9027  * Field : NAND ECCBUFFER RAM ECC single, correctable error interrupt status - eccbufserr
9028  *
9029  * This bit is an interrupt status bit for NAND ECCBUFFER RAM ECC single,
9030  * correctable error. It is set by hardware when single, correctable error occurs
9031  * in NAND ECCBUFFER RAM. Software needs to write 1 into this bit to clear the
9032  * interrupt status.
9033  *
9034  * Field Access Macros:
9035  *
9036  */
9037 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
9038 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_LSB 7
9039 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
9040 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_MSB 7
9041 /* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
9042 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_WIDTH 1
9043 /* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field value. */
9044 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_SET_MSK 0x00000080
9045 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field value. */
9046 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_CLR_MSK 0xffffff7f
9047 /* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
9048 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_RESET 0x0
9049 /* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFSERR field value from a register. */
9050 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_GET(value) (((value) & 0x00000080) >> 7)
9051 /* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field value suitable for setting the register. */
9052 #define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_SET(value) (((value) << 7) & 0x00000080)
9053
9054 /*
9055  * Field : NAND ECCBUFFER RAM ECC double bit, non-correctable error interrupt status - eccbufderr
9056  *
9057  * This bit is an interrupt status bit for NAND ECCBUFFER RAM ECC double bit, non-
9058  * correctable error. It is set by hardware when double bit, non-correctable error
9059  * occurs in NAND ECCBUFFER RAM. Software needs to write 1 into this bit to clear
9060  * the interrupt status.
9061  *
9062  * Field Access Macros:
9063  *
9064  */
9065 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
9066 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_LSB 8
9067 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
9068 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_MSB 8
9069 /* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
9070 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_WIDTH 1
9071 /* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field value. */
9072 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_SET_MSK 0x00000100
9073 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field value. */
9074 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_CLR_MSK 0xfffffeff
9075 /* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
9076 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_RESET 0x0
9077 /* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFDERR field value from a register. */
9078 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_GET(value) (((value) & 0x00000100) >> 8)
9079 /* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field value suitable for setting the register. */
9080 #define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_SET(value) (((value) << 8) & 0x00000100)
9081
9082 /*
9083  * Field : NAND WRFIFO RAM ECC single, correctable error interrupt status - wrfifoserr
9084  *
9085  * This bit is an interrupt status bit for NAND WRFIFO RAM ECC single, correctable
9086  * error. It is set by hardware when single, correctable error occurs in NAND
9087  * WRFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
9088  * status.
9089  *
9090  * Field Access Macros:
9091  *
9092  */
9093 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
9094 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_LSB 9
9095 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
9096 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_MSB 9
9097 /* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
9098 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_WIDTH 1
9099 /* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field value. */
9100 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_SET_MSK 0x00000200
9101 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field value. */
9102 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_CLR_MSK 0xfffffdff
9103 /* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
9104 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_RESET 0x0
9105 /* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFOSERR field value from a register. */
9106 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_GET(value) (((value) & 0x00000200) >> 9)
9107 /* Produces a ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field value suitable for setting the register. */
9108 #define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_SET(value) (((value) << 9) & 0x00000200)
9109
9110 /*
9111  * Field : NAND WRFIFO RAM ECC double bit, non-correctable error interrupt status - wrfifoderr
9112  *
9113  * This bit is an interrupt status bit for NAND WRFIFO RAM ECC double bit, non-
9114  * correctable error. It is set by hardware when double bit, non-correctable error
9115  * occurs in NAND WRFIFO RAM. Software needs to write 1 into this bit to clear the
9116  * interrupt status.
9117  *
9118  * Field Access Macros:
9119  *
9120  */
9121 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
9122 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_LSB 10
9123 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
9124 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_MSB 10
9125 /* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
9126 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_WIDTH 1
9127 /* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field value. */
9128 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_SET_MSK 0x00000400
9129 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field value. */
9130 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_CLR_MSK 0xfffffbff
9131 /* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
9132 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_RESET 0x0
9133 /* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFODERR field value from a register. */
9134 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_GET(value) (((value) & 0x00000400) >> 10)
9135 /* Produces a ALT_SYSMGR_ECC_NAND_WRFIFODERR register field value suitable for setting the register. */
9136 #define ALT_SYSMGR_ECC_NAND_WRFIFODERR_SET(value) (((value) << 10) & 0x00000400)
9137
9138 /*
9139  * Field : NAND RDFIFO RAM ECC single, correctable error interrupt status - rdfifoserr
9140  *
9141  * This bit is an interrupt status bit for NAND RDFIFO RAM ECC single, correctable
9142  * error. It is set by hardware when single, correctable error occurs in NAND
9143  * RDFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
9144  * status.
9145  *
9146  * Field Access Macros:
9147  *
9148  */
9149 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
9150 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_LSB 11
9151 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
9152 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_MSB 11
9153 /* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
9154 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_WIDTH 1
9155 /* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field value. */
9156 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_SET_MSK 0x00000800
9157 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field value. */
9158 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_CLR_MSK 0xfffff7ff
9159 /* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
9160 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_RESET 0x0
9161 /* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFOSERR field value from a register. */
9162 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_GET(value) (((value) & 0x00000800) >> 11)
9163 /* Produces a ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field value suitable for setting the register. */
9164 #define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_SET(value) (((value) << 11) & 0x00000800)
9165
9166 /*
9167  * Field : NAND RDFIFO RAM ECC double bit, non-correctable error interrupt status - rdfifoderr
9168  *
9169  * This bit is an interrupt status bit for NAND RDFIFO RAM ECC double bit, non-
9170  * correctable error. It is set by hardware when double bit, non-correctable error
9171  * occurs in NAND RDFIFO RAM. Software needs to write 1 into this bit to clear the
9172  * interrupt status.
9173  *
9174  * Field Access Macros:
9175  *
9176  */
9177 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
9178 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_LSB 12
9179 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
9180 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_MSB 12
9181 /* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
9182 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_WIDTH 1
9183 /* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field value. */
9184 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_SET_MSK 0x00001000
9185 /* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field value. */
9186 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_CLR_MSK 0xffffefff
9187 /* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
9188 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_RESET 0x0
9189 /* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFODERR field value from a register. */
9190 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_GET(value) (((value) & 0x00001000) >> 12)
9191 /* Produces a ALT_SYSMGR_ECC_NAND_RDFIFODERR register field value suitable for setting the register. */
9192 #define ALT_SYSMGR_ECC_NAND_RDFIFODERR_SET(value) (((value) << 12) & 0x00001000)
9193
9194 #ifndef __ASSEMBLY__
9195 /*
9196  * WARNING: The C register and register group struct declarations are provided for
9197  * convenience and illustrative purposes. They should, however, be used with
9198  * caution as the C language standard provides no guarantees about the alignment or
9199  * atomicity of device memory accesses. The recommended practice for writing
9200  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
9201  * alt_write_word() functions.
9202  *
9203  * The struct declaration for register ALT_SYSMGR_ECC_NAND.
9204  */
9206 {
9207  uint32_t en : 1; /* NAND RAM ECC Enable */
9208  uint32_t eccbufinjs : 1; /* NAND ECCBUFFER RAM ECC inject single, correctable Error */
9209  uint32_t eccbufinjd : 1; /* NAND ECCBUFFER RAM ECC inject double bit, non-correctable error */
9210  uint32_t wrfifoinjs : 1; /* NAND WRFIFO RAM ECC inject single, correctable Error */
9211  uint32_t wrfifoinjd : 1; /* NAND WRFIFO RAM ECC inject double bit, non-correctable error */
9212  uint32_t rdfifoinjs : 1; /* NAND RDFIFO RAM ECC inject single, correctable Error */
9213  uint32_t rdfifoinjd : 1; /* NAND RDFIFO RAM ECC inject double bit, non-correctable error */
9214  uint32_t eccbufserr : 1; /* NAND ECCBUFFER RAM ECC single, correctable error interrupt status */
9215  uint32_t eccbufderr : 1; /* NAND ECCBUFFER RAM ECC double bit, non-correctable error interrupt status */
9216  uint32_t wrfifoserr : 1; /* NAND WRFIFO RAM ECC single, correctable error interrupt status */
9217  uint32_t wrfifoderr : 1; /* NAND WRFIFO RAM ECC double bit, non-correctable error interrupt status */
9218  uint32_t rdfifoserr : 1; /* NAND RDFIFO RAM ECC single, correctable error interrupt status */
9219  uint32_t rdfifoderr : 1; /* NAND RDFIFO RAM ECC double bit, non-correctable error interrupt status */
9220  uint32_t : 19; /* *UNDEFINED* */
9221 };
9222
9223 /* The typedef declaration for register ALT_SYSMGR_ECC_NAND. */
9224 typedef volatile struct ALT_SYSMGR_ECC_NAND_s ALT_SYSMGR_ECC_NAND_t;
9225 #endif /* __ASSEMBLY__ */
9226
9227 /* The byte offset of the ALT_SYSMGR_ECC_NAND register from the beginning of the component. */
9228 #define ALT_SYSMGR_ECC_NAND_OFST 0x24
9229
9230 /*
9231  * Register : QSPI RAM ECC Enable Register - qspi
9232  *
9233  * This register is used to enable ECC on the QSPI RAM. ECC errors can be injected
9234  * into the write path using bits in this register. This register contains
9235  * interrupt status of the ECC single/double bit error.
9236  *
9237  * Only reset by a cold reset (ignores warm reset).
9238  *
9239  * Register Layout
9240  *
9241  * Bits | Access | Reset | Description
9242  * :-------|:-------|:------|:----------------------------------------------------------------
9243  * [0] | RW | 0x0 | QSPI RAM ECC Enable
9244  * [1] | RW | 0x0 | QSPI RAM ECC inject single, correctable Error
9245  * [2] | RW | 0x0 | QSPI RAM ECC inject double bit, non-correctable error
9246  * [3] | RW | 0x0 | QSPI RAM ECC single, correctable error interrupt status
9247  * [4] | RW | 0x0 | QSPI RAM ECC double bit, non-correctable error interrupt status
9248  * [31:5] | ??? | 0x0 | *UNDEFINED*
9249  *
9250  */
9251 /*
9252  * Field : QSPI RAM ECC Enable - en
9253  *
9254  * Enable ECC for QSPI RAM
9255  *
9256  * Field Access Macros:
9257  *
9258  */
9259 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_EN register field. */
9260 #define ALT_SYSMGR_ECC_QSPI_EN_LSB 0
9261 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_EN register field. */
9262 #define ALT_SYSMGR_ECC_QSPI_EN_MSB 0
9263 /* The width in bits of the ALT_SYSMGR_ECC_QSPI_EN register field. */
9264 #define ALT_SYSMGR_ECC_QSPI_EN_WIDTH 1
9265 /* The mask used to set the ALT_SYSMGR_ECC_QSPI_EN register field value. */
9266 #define ALT_SYSMGR_ECC_QSPI_EN_SET_MSK 0x00000001
9267 /* The mask used to clear the ALT_SYSMGR_ECC_QSPI_EN register field value. */
9268 #define ALT_SYSMGR_ECC_QSPI_EN_CLR_MSK 0xfffffffe
9269 /* The reset value of the ALT_SYSMGR_ECC_QSPI_EN register field. */
9270 #define ALT_SYSMGR_ECC_QSPI_EN_RESET 0x0
9271 /* Extracts the ALT_SYSMGR_ECC_QSPI_EN field value from a register. */
9272 #define ALT_SYSMGR_ECC_QSPI_EN_GET(value) (((value) & 0x00000001) >> 0)
9273 /* Produces a ALT_SYSMGR_ECC_QSPI_EN register field value suitable for setting the register. */
9274 #define ALT_SYSMGR_ECC_QSPI_EN_SET(value) (((value) << 0) & 0x00000001)
9275
9276 /*
9277  * Field : QSPI RAM ECC inject single, correctable Error - injs
9278  *
9279  * Changing this bit from zero to one injects a single, correctable error into the
9280  * QSPI RAM. This only injects one error into the QSPI RAM.
9281  *
9282  * Field Access Macros:
9283  *
9284  */
9285 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
9286 #define ALT_SYSMGR_ECC_QSPI_INJS_LSB 1
9287 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
9288 #define ALT_SYSMGR_ECC_QSPI_INJS_MSB 1
9289 /* The width in bits of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
9290 #define ALT_SYSMGR_ECC_QSPI_INJS_WIDTH 1
9291 /* The mask used to set the ALT_SYSMGR_ECC_QSPI_INJS register field value. */
9292 #define ALT_SYSMGR_ECC_QSPI_INJS_SET_MSK 0x00000002
9293 /* The mask used to clear the ALT_SYSMGR_ECC_QSPI_INJS register field value. */
9294 #define ALT_SYSMGR_ECC_QSPI_INJS_CLR_MSK 0xfffffffd
9295 /* The reset value of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
9296 #define ALT_SYSMGR_ECC_QSPI_INJS_RESET 0x0
9297 /* Extracts the ALT_SYSMGR_ECC_QSPI_INJS field value from a register. */
9298 #define ALT_SYSMGR_ECC_QSPI_INJS_GET(value) (((value) & 0x00000002) >> 1)
9299 /* Produces a ALT_SYSMGR_ECC_QSPI_INJS register field value suitable for setting the register. */
9300 #define ALT_SYSMGR_ECC_QSPI_INJS_SET(value) (((value) << 1) & 0x00000002)
9301
9302 /*
9303  * Field : QSPI RAM ECC inject double bit, non-correctable error - injd
9304  *
9305  * Changing this bit from zero to one injects a double, non-correctable error into
9306  * the QSPI RAM. This only injects one double bit error into the QSPI RAM.
9307  *
9308  * Field Access Macros:
9309  *
9310  */
9311 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
9312 #define ALT_SYSMGR_ECC_QSPI_INJD_LSB 2
9313 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
9314 #define ALT_SYSMGR_ECC_QSPI_INJD_MSB 2
9315 /* The width in bits of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
9316 #define ALT_SYSMGR_ECC_QSPI_INJD_WIDTH 1
9317 /* The mask used to set the ALT_SYSMGR_ECC_QSPI_INJD register field value. */
9318 #define ALT_SYSMGR_ECC_QSPI_INJD_SET_MSK 0x00000004
9319 /* The mask used to clear the ALT_SYSMGR_ECC_QSPI_INJD register field value. */
9320 #define ALT_SYSMGR_ECC_QSPI_INJD_CLR_MSK 0xfffffffb
9321 /* The reset value of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
9322 #define ALT_SYSMGR_ECC_QSPI_INJD_RESET 0x0
9323 /* Extracts the ALT_SYSMGR_ECC_QSPI_INJD field value from a register. */
9324 #define ALT_SYSMGR_ECC_QSPI_INJD_GET(value) (((value) & 0x00000004) >> 2)
9325 /* Produces a ALT_SYSMGR_ECC_QSPI_INJD register field value suitable for setting the register. */
9326 #define ALT_SYSMGR_ECC_QSPI_INJD_SET(value) (((value) << 2) & 0x00000004)
9327
9328 /*
9329  * Field : QSPI RAM ECC single, correctable error interrupt status - serr
9330  *
9331  * This bit is an interrupt status bit for QSPI RAM ECC single, correctable error.
9332  * It is set by hardware when single, correctable error occurs in QSPI RAM.
9333  * Software needs to write 1 into this bit to clear the interrupt status.
9334  *
9335  * Field Access Macros:
9336  *
9337  */
9338 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
9339 #define ALT_SYSMGR_ECC_QSPI_SERR_LSB 3
9340 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
9341 #define ALT_SYSMGR_ECC_QSPI_SERR_MSB 3
9342 /* The width in bits of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
9343 #define ALT_SYSMGR_ECC_QSPI_SERR_WIDTH 1
9344 /* The mask used to set the ALT_SYSMGR_ECC_QSPI_SERR register field value. */
9345 #define ALT_SYSMGR_ECC_QSPI_SERR_SET_MSK 0x00000008
9346 /* The mask used to clear the ALT_SYSMGR_ECC_QSPI_SERR register field value. */
9347 #define ALT_SYSMGR_ECC_QSPI_SERR_CLR_MSK 0xfffffff7
9348 /* The reset value of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
9349 #define ALT_SYSMGR_ECC_QSPI_SERR_RESET 0x0
9350 /* Extracts the ALT_SYSMGR_ECC_QSPI_SERR field value from a register. */
9351 #define ALT_SYSMGR_ECC_QSPI_SERR_GET(value) (((value) & 0x00000008) >> 3)
9352 /* Produces a ALT_SYSMGR_ECC_QSPI_SERR register field value suitable for setting the register. */
9353 #define ALT_SYSMGR_ECC_QSPI_SERR_SET(value) (((value) << 3) & 0x00000008)
9354
9355 /*
9356  * Field : QSPI RAM ECC double bit, non-correctable error interrupt status - derr
9357  *
9358  * This bit is an interrupt status bit for QSPI RAM ECC double bit, non-correctable
9359  * error. It is set by hardware when double bit, non-correctable error occurs in
9360  * QSPI RAM. Software needs to write 1 into this bit to clear the interrupt status.
9361  *
9362  * Field Access Macros:
9363  *
9364  */
9365 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
9366 #define ALT_SYSMGR_ECC_QSPI_DERR_LSB 4
9367 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
9368 #define ALT_SYSMGR_ECC_QSPI_DERR_MSB 4
9369 /* The width in bits of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
9370 #define ALT_SYSMGR_ECC_QSPI_DERR_WIDTH 1
9371 /* The mask used to set the ALT_SYSMGR_ECC_QSPI_DERR register field value. */
9372 #define ALT_SYSMGR_ECC_QSPI_DERR_SET_MSK 0x00000010
9373 /* The mask used to clear the ALT_SYSMGR_ECC_QSPI_DERR register field value. */
9374 #define ALT_SYSMGR_ECC_QSPI_DERR_CLR_MSK 0xffffffef
9375 /* The reset value of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
9376 #define ALT_SYSMGR_ECC_QSPI_DERR_RESET 0x0
9377 /* Extracts the ALT_SYSMGR_ECC_QSPI_DERR field value from a register. */
9378 #define ALT_SYSMGR_ECC_QSPI_DERR_GET(value) (((value) & 0x00000010) >> 4)
9379 /* Produces a ALT_SYSMGR_ECC_QSPI_DERR register field value suitable for setting the register. */
9380 #define ALT_SYSMGR_ECC_QSPI_DERR_SET(value) (((value) << 4) & 0x00000010)
9381
9382 #ifndef __ASSEMBLY__
9383 /*
9384  * WARNING: The C register and register group struct declarations are provided for
9385  * convenience and illustrative purposes. They should, however, be used with
9386  * caution as the C language standard provides no guarantees about the alignment or
9387  * atomicity of device memory accesses. The recommended practice for writing
9388  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
9389  * alt_write_word() functions.
9390  *
9391  * The struct declaration for register ALT_SYSMGR_ECC_QSPI.
9392  */
9394 {
9395  uint32_t en : 1; /* QSPI RAM ECC Enable */
9396  uint32_t injs : 1; /* QSPI RAM ECC inject single, correctable Error */
9397  uint32_t injd : 1; /* QSPI RAM ECC inject double bit, non-correctable error */
9398  uint32_t serr : 1; /* QSPI RAM ECC single, correctable error interrupt status */
9399  uint32_t derr : 1; /* QSPI RAM ECC double bit, non-correctable error interrupt status */
9400  uint32_t : 27; /* *UNDEFINED* */
9401 };
9402
9403 /* The typedef declaration for register ALT_SYSMGR_ECC_QSPI. */
9404 typedef volatile struct ALT_SYSMGR_ECC_QSPI_s ALT_SYSMGR_ECC_QSPI_t;
9405 #endif /* __ASSEMBLY__ */
9406
9407 /* The byte offset of the ALT_SYSMGR_ECC_QSPI register from the beginning of the component. */
9408 #define ALT_SYSMGR_ECC_QSPI_OFST 0x28
9409
9410 /*
9411  * Register : SDMMC RAM ECC Enable Register - sdmmc
9412  *
9413  * This register is used to enable ECC on the SDMMC RAM.ECC errors can be injected
9414  * into the write path using bits in this register.
9415  *
9416  * Only reset by a cold reset (ignores warm reset).
9417  *
9418  * Register Layout
9419  *
9420  * Bits | Access | Reset | Description
9421  * :-------|:-------|:------|:------------------------------------------------------------------------
9422  * [0] | RW | 0x0 | SDMMC RAM ECC Enable
9423  * [1] | RW | 0x0 | SDMMC Port A RAM ECC inject single, correctable Error at Port A
9424  * [2] | RW | 0x0 | SDMMC Port A RAM ECC inject double bit, non-correctable error at Port A
9425  * [3] | RW | 0x0 | SDMMC Port B RAM ECC inject single, correctable Error at Port B
9426  * [4] | RW | 0x0 | SDMMC Port B RAM ECC inject double bit, non-correctable error at Port B
9427  * [5] | RW | 0x0 | SDMMC Port A RAM ECC single, correctable error interrupt status
9428  * [6] | RW | 0x0 | SDMMC Port A RAM ECC double bit, non-correctable error interrupt status
9429  * [7] | RW | 0x0 | SDMMC Port B RAM ECC single, correctable error interrupt status
9430  * [8] | RW | 0x0 | SDMMC Port B RAM ECC double bit, non-correctable error interrupt status
9431  * [31:9] | ??? | 0x0 | *UNDEFINED*
9432  *
9433  */
9434 /*
9435  * Field : SDMMC RAM ECC Enable - en
9436  *
9437  * Enable ECC for SDMMC RAM
9438  *
9439  * Field Access Macros:
9440  *
9441  */
9442 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
9443 #define ALT_SYSMGR_ECC_SDMMC_EN_LSB 0
9444 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
9445 #define ALT_SYSMGR_ECC_SDMMC_EN_MSB 0
9446 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
9447 #define ALT_SYSMGR_ECC_SDMMC_EN_WIDTH 1
9448 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_EN register field value. */
9449 #define ALT_SYSMGR_ECC_SDMMC_EN_SET_MSK 0x00000001
9450 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_EN register field value. */
9451 #define ALT_SYSMGR_ECC_SDMMC_EN_CLR_MSK 0xfffffffe
9452 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
9453 #define ALT_SYSMGR_ECC_SDMMC_EN_RESET 0x0
9454 /* Extracts the ALT_SYSMGR_ECC_SDMMC_EN field value from a register. */
9455 #define ALT_SYSMGR_ECC_SDMMC_EN_GET(value) (((value) & 0x00000001) >> 0)
9456 /* Produces a ALT_SYSMGR_ECC_SDMMC_EN register field value suitable for setting the register. */
9457 #define ALT_SYSMGR_ECC_SDMMC_EN_SET(value) (((value) << 0) & 0x00000001)
9458
9459 /*
9460  * Field : SDMMC Port A RAM ECC inject single, correctable Error at Port A - injsporta
9461  *
9462  * Changing this bit from zero to one injects a single, correctable error into the
9463  * SDMMC RAM at Port A. This only injects one error into the SDMMC RAM at Port A.
9464  *
9465  * Field Access Macros:
9466  *
9467  */
9468 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
9469 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_LSB 1
9470 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
9471 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_MSB 1
9472 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
9473 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_WIDTH 1
9474 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field value. */
9475 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_SET_MSK 0x00000002
9476 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field value. */
9477 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_CLR_MSK 0xfffffffd
9478 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
9479 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_RESET 0x0
9480 /* Extracts the ALT_SYSMGR_ECC_SDMMC_INJSPORTA field value from a register. */
9481 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_GET(value) (((value) & 0x00000002) >> 1)
9482 /* Produces a ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field value suitable for setting the register. */
9483 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_SET(value) (((value) << 1) & 0x00000002)
9484
9485 /*
9486  * Field : SDMMC Port A RAM ECC inject double bit, non-correctable error at Port A - injdporta
9487  *
9488  * Changing this bit from zero to one injects a double, non-correctable error into
9489  * the SDMMC RAM at Port A. This only injects one double bit error into the SDMMC
9490  * RAM at Port A.
9491  *
9492  * Field Access Macros:
9493  *
9494  */
9495 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
9496 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_LSB 2
9497 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
9498 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_MSB 2
9499 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
9500 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_WIDTH 1
9501 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field value. */
9502 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_SET_MSK 0x00000004
9503 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field value. */
9504 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_CLR_MSK 0xfffffffb
9505 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
9506 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_RESET 0x0
9507 /* Extracts the ALT_SYSMGR_ECC_SDMMC_INJDPORTA field value from a register. */
9508 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_GET(value) (((value) & 0x00000004) >> 2)
9509 /* Produces a ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field value suitable for setting the register. */
9510 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_SET(value) (((value) << 2) & 0x00000004)
9511
9512 /*
9513  * Field : SDMMC Port B RAM ECC inject single, correctable Error at Port B - injsportb
9514  *
9515  * Changing this bit from zero to one injects a single, correctable error into the
9516  * SDMMC RAM at Port B. This only injects one error into the SDMMC RAM at Port B.
9517  *
9518  * Field Access Macros:
9519  *
9520  */
9521 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
9522 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_LSB 3
9523 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
9524 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_MSB 3
9525 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
9526 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_WIDTH 1
9527 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field value. */
9528 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_SET_MSK 0x00000008
9529 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field value. */
9530 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_CLR_MSK 0xfffffff7
9531 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
9532 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_RESET 0x0
9533 /* Extracts the ALT_SYSMGR_ECC_SDMMC_INJSPORTB field value from a register. */
9534 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_GET(value) (((value) & 0x00000008) >> 3)
9535 /* Produces a ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field value suitable for setting the register. */
9536 #define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_SET(value) (((value) << 3) & 0x00000008)
9537
9538 /*
9539  * Field : SDMMC Port B RAM ECC inject double bit, non-correctable error at Port B - injdportb
9540  *
9541  * Changing this bit from zero to one injects a double, non-correctable error into
9542  * the SDMMC RAM at Port B. This only injects one double bit error into the SDMMC
9543  * RAM at Port B.
9544  *
9545  * Field Access Macros:
9546  *
9547  */
9548 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
9549 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_LSB 4
9550 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
9551 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_MSB 4
9552 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
9553 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_WIDTH 1
9554 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field value. */
9555 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_SET_MSK 0x00000010
9556 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field value. */
9557 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_CLR_MSK 0xffffffef
9558 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
9559 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_RESET 0x0
9560 /* Extracts the ALT_SYSMGR_ECC_SDMMC_INJDPORTB field value from a register. */
9561 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_GET(value) (((value) & 0x00000010) >> 4)
9562 /* Produces a ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field value suitable for setting the register. */
9563 #define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_SET(value) (((value) << 4) & 0x00000010)
9564
9565 /*
9566  * Field : SDMMC Port A RAM ECC single, correctable error interrupt status - serrporta
9567  *
9568  * This bit is an interrupt status bit for SDMMC Port A RAM ECC single, correctable
9569  * error. It is set by hardware when single, correctable error occurs in SDMMC Port
9570  * A RAM. Software needs to write 1 into this bit to clear the interrupt status.
9571  *
9572  * Field Access Macros:
9573  *
9574  */
9575 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
9576 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_LSB 5
9577 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
9578 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_MSB 5
9579 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
9580 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_WIDTH 1
9581 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field value. */
9582 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_SET_MSK 0x00000020
9583 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field value. */
9584 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_CLR_MSK 0xffffffdf
9585 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
9586 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_RESET 0x0
9587 /* Extracts the ALT_SYSMGR_ECC_SDMMC_SERRPORTA field value from a register. */
9588 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_GET(value) (((value) & 0x00000020) >> 5)
9589 /* Produces a ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field value suitable for setting the register. */
9590 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_SET(value) (((value) << 5) & 0x00000020)
9591
9592 /*
9593  * Field : SDMMC Port A RAM ECC double bit, non-correctable error interrupt status - derrporta
9594  *
9595  * This bit is an interrupt status bit for SDMMC Port A RAM ECC double bit, non-
9596  * correctable error. It is set by hardware when double bit, non-correctable error
9597  * occurs in SDMMC Port A RAM. Software needs to write 1 into this bit to clear the
9598  * interrupt status.
9599  *
9600  * Field Access Macros:
9601  *
9602  */
9603 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
9604 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_LSB 6
9605 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
9606 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_MSB 6
9607 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
9608 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_WIDTH 1
9609 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field value. */
9610 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_SET_MSK 0x00000040
9611 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field value. */
9612 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_CLR_MSK 0xffffffbf
9613 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
9614 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_RESET 0x0
9615 /* Extracts the ALT_SYSMGR_ECC_SDMMC_DERRPORTA field value from a register. */
9616 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_GET(value) (((value) & 0x00000040) >> 6)
9617 /* Produces a ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field value suitable for setting the register. */
9618 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_SET(value) (((value) << 6) & 0x00000040)
9619
9620 /*
9621  * Field : SDMMC Port B RAM ECC single, correctable error interrupt status - serrportb
9622  *
9623  * This bit is an interrupt status bit for SDMMC Port B RAM ECC single, correctable
9624  * error. It is set by hardware when single, correctable error occurs in SDMMC Port
9625  * B RAM. Software needs to write 1 into this bit to clear the interrupt status.
9626  *
9627  * Field Access Macros:
9628  *
9629  */
9630 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
9631 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_LSB 7
9632 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
9633 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_MSB 7
9634 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
9635 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_WIDTH 1
9636 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field value. */
9637 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_SET_MSK 0x00000080
9638 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field value. */
9639 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_CLR_MSK 0xffffff7f
9640 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
9641 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_RESET 0x0
9642 /* Extracts the ALT_SYSMGR_ECC_SDMMC_SERRPORTB field value from a register. */
9643 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_GET(value) (((value) & 0x00000080) >> 7)
9644 /* Produces a ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field value suitable for setting the register. */
9645 #define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_SET(value) (((value) << 7) & 0x00000080)
9646
9647 /*
9648  * Field : SDMMC Port B RAM ECC double bit, non-correctable error interrupt status - derrportb
9649  *
9650  * This bit is an interrupt status bit for SDMMC Port B RAM ECC double bit, non-
9651  * correctable error. It is set by hardware when double bit, non-correctable error
9652  * occurs in SDMMC Port B RAM. Software needs to write 1 into this bit to clear the
9653  * interrupt status.
9654  *
9655  * Field Access Macros:
9656  *
9657  */
9658 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
9659 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_LSB 8
9660 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
9661 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_MSB 8
9662 /* The width in bits of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
9663 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_WIDTH 1
9664 /* The mask used to set the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field value. */
9665 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_SET_MSK 0x00000100
9666 /* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field value. */
9667 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_CLR_MSK 0xfffffeff
9668 /* The reset value of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
9669 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_RESET 0x0
9670 /* Extracts the ALT_SYSMGR_ECC_SDMMC_DERRPORTB field value from a register. */
9671 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_GET(value) (((value) & 0x00000100) >> 8)
9672 /* Produces a ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field value suitable for setting the register. */
9673 #define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_SET(value) (((value) << 8) & 0x00000100)
9674
9675 #ifndef __ASSEMBLY__
9676 /*
9677  * WARNING: The C register and register group struct declarations are provided for
9678  * convenience and illustrative purposes. They should, however, be used with
9679  * caution as the C language standard provides no guarantees about the alignment or
9680  * atomicity of device memory accesses. The recommended practice for writing
9681  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
9682  * alt_write_word() functions.
9683  *
9684  * The struct declaration for register ALT_SYSMGR_ECC_SDMMC.
9685  */
9687 {
9688  uint32_t en : 1; /* SDMMC RAM ECC Enable */
9689  uint32_t injsporta : 1; /* SDMMC Port A RAM ECC inject single, correctable Error at Port A */
9690  uint32_t injdporta : 1; /* SDMMC Port A RAM ECC inject double bit, non-correctable error at Port A */
9691  uint32_t injsportb : 1; /* SDMMC Port B RAM ECC inject single, correctable Error at Port B */
9692  uint32_t injdportb : 1; /* SDMMC Port B RAM ECC inject double bit, non-correctable error at Port B */
9693  uint32_t serrporta : 1; /* SDMMC Port A RAM ECC single, correctable error interrupt status */
9694  uint32_t derrporta : 1; /* SDMMC Port A RAM ECC double bit, non-correctable error interrupt status */
9695  uint32_t serrportb : 1; /* SDMMC Port B RAM ECC single, correctable error interrupt status */
9696  uint32_t derrportb : 1; /* SDMMC Port B RAM ECC double bit, non-correctable error interrupt status */
9697  uint32_t : 23; /* *UNDEFINED* */
9698 };
9699
9700 /* The typedef declaration for register ALT_SYSMGR_ECC_SDMMC. */
9701 typedef volatile struct ALT_SYSMGR_ECC_SDMMC_s ALT_SYSMGR_ECC_SDMMC_t;
9702 #endif /* __ASSEMBLY__ */
9703
9704 /* The byte offset of the ALT_SYSMGR_ECC_SDMMC register from the beginning of the component. */
9705 #define ALT_SYSMGR_ECC_SDMMC_OFST 0x2c
9706
9707 #ifndef __ASSEMBLY__
9708 /*
9709  * WARNING: The C register and register group struct declarations are provided for
9710  * convenience and illustrative purposes. They should, however, be used with
9711  * caution as the C language standard provides no guarantees about the alignment or
9712  * atomicity of device memory accesses. The recommended practice for writing
9713  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
9714  * alt_write_word() functions.
9715  *
9716  * The struct declaration for register group ALT_SYSMGR_ECC.
9717  */
9719 {
9720  volatile ALT_SYSMGR_ECC_L2_t l2; /* ALT_SYSMGR_ECC_L2 */
9721  volatile ALT_SYSMGR_ECC_OCRAM_t ocram; /* ALT_SYSMGR_ECC_OCRAM */
9722  volatile ALT_SYSMGR_ECC_USB0_t usb0; /* ALT_SYSMGR_ECC_USB0 */
9723  volatile ALT_SYSMGR_ECC_USB1_t usb1; /* ALT_SYSMGR_ECC_USB1 */
9724  volatile ALT_SYSMGR_ECC_EMAC0_t emac0; /* ALT_SYSMGR_ECC_EMAC0 */
9725  volatile ALT_SYSMGR_ECC_EMAC1_t emac1; /* ALT_SYSMGR_ECC_EMAC1 */
9726  volatile ALT_SYSMGR_ECC_DMA_t dma; /* ALT_SYSMGR_ECC_DMA */
9727  volatile ALT_SYSMGR_ECC_CAN0_t can0; /* ALT_SYSMGR_ECC_CAN0 */
9728  volatile ALT_SYSMGR_ECC_CAN1_t can1; /* ALT_SYSMGR_ECC_CAN1 */
9729  volatile ALT_SYSMGR_ECC_NAND_t nand; /* ALT_SYSMGR_ECC_NAND */
9730  volatile ALT_SYSMGR_ECC_QSPI_t qspi; /* ALT_SYSMGR_ECC_QSPI */
9731  volatile ALT_SYSMGR_ECC_SDMMC_t sdmmc; /* ALT_SYSMGR_ECC_SDMMC */
9732  volatile uint32_t _pad_0x30_0x40[4]; /* *UNDEFINED* */
9733 };
9734
9735 /* The typedef declaration for register group ALT_SYSMGR_ECC. */
9736 typedef volatile struct ALT_SYSMGR_ECC_s ALT_SYSMGR_ECC_t;
9737 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_ECC. */
9739 {
9740  volatile uint32_t l2; /* ALT_SYSMGR_ECC_L2 */
9741  volatile uint32_t ocram; /* ALT_SYSMGR_ECC_OCRAM */
9742  volatile uint32_t usb0; /* ALT_SYSMGR_ECC_USB0 */
9743  volatile uint32_t usb1; /* ALT_SYSMGR_ECC_USB1 */
9744  volatile uint32_t emac0; /* ALT_SYSMGR_ECC_EMAC0 */
9745  volatile uint32_t emac1; /* ALT_SYSMGR_ECC_EMAC1 */
9746  volatile uint32_t dma; /* ALT_SYSMGR_ECC_DMA */
9747  volatile uint32_t can0; /* ALT_SYSMGR_ECC_CAN0 */
9748  volatile uint32_t can1; /* ALT_SYSMGR_ECC_CAN1 */
9749  volatile uint32_t nand; /* ALT_SYSMGR_ECC_NAND */
9750  volatile uint32_t qspi; /* ALT_SYSMGR_ECC_QSPI */
9751  volatile uint32_t sdmmc; /* ALT_SYSMGR_ECC_SDMMC */
9752  volatile uint32_t _pad_0x30_0x40[4]; /* *UNDEFINED* */
9753 };
9754
9755 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ECC. */
9756 typedef volatile struct ALT_SYSMGR_ECC_raw_s ALT_SYSMGR_ECC_raw_t;
9757 #endif /* __ASSEMBLY__ */
9758
9759
9760 /*
9761  * Register Group : Pin Mux Control Group - ALT_SYSMGR_PINMUX
9762  * Pin Mux Control Group
9763  *
9764  * Controls Pin Mux selections
9765  *
9766  * NOTE: These registers should not be modified after IO configuration.There is no
9767  * support for dynamically changing the Pin Mux selections.
9768  *
9769  */
9770 /*
9771  * Register : emac0_tx_clk Mux Selection Register - EMACIO0
9772  *
9773  * This register is used to control the peripherals connected to emac0_tx_clk
9774  *
9775  * Only reset by a cold reset (ignores warm reset).
9776  *
9777  * NOTE: These registers should not be modified after IO configuration.There is no
9778  * support for dynamically changing the Pin Mux selections.
9779  *
9780  * Register Layout
9781  *
9782  * Bits | Access | Reset | Description
9783  * :-------|:-------|:------|:---------------------------------
9784  * [1:0] | RW | 0x0 | emac0_tx_clk Mux Selection Field
9785  * [31:2] | ??? | 0x0 | *UNDEFINED*
9786  *
9787  */
9788 /*
9789  * Field : emac0_tx_clk Mux Selection Field - sel
9790  *
9791  * Select peripheral signals connected emac0_tx_clk.
9792  *
9793  * 0 : Pin is connected to GPIO/LoanIO number 0.
9794  *
9795  * 1 : Pin is connected to Peripheral signal not applicable.
9796  *
9797  * 2 : Pin is connected to Peripheral signal not applicable.
9798  *
9799  * 3 : Pin is connected to Peripheral signal RGMII0.TX_CLK.
9800  *
9801  * Field Access Macros:
9802  *
9803  */
9804 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
9805 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_LSB 0
9806 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
9807 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_MSB 1
9808 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
9809 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_WIDTH 2
9810 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field value. */
9811 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_SET_MSK 0x00000003
9812 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field value. */
9813 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_CLR_MSK 0xfffffffc
9814 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
9815 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_RESET 0x0
9816 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO0_SEL field value from a register. */
9817 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
9818 /* Produces a ALT_SYSMGR_PINMUX_EMACIO0_SEL register field value suitable for setting the register. */
9819 #define ALT_SYSMGR_PINMUX_EMACIO0_SEL_SET(value) (((value) << 0) & 0x00000003)
9820
9821 #ifndef __ASSEMBLY__
9822 /*
9823  * WARNING: The C register and register group struct declarations are provided for
9824  * convenience and illustrative purposes. They should, however, be used with
9825  * caution as the C language standard provides no guarantees about the alignment or
9826  * atomicity of device memory accesses. The recommended practice for writing
9827  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
9828  * alt_write_word() functions.
9829  *
9830  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO0.
9831  */
9833 {
9834  uint32_t sel : 2; /* emac0_tx_clk Mux Selection Field */
9835  uint32_t : 30; /* *UNDEFINED* */
9836 };
9837
9838 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO0. */
9839 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO0_s ALT_SYSMGR_PINMUX_EMACIO0_t;
9840 #endif /* __ASSEMBLY__ */
9841
9842 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO0 register from the beginning of the component. */
9843 #define ALT_SYSMGR_PINMUX_EMACIO0_OFST 0x0
9844
9845 /*
9846  * Register : emac0_tx_d0 Mux Selection Register - EMACIO1
9847  *
9848  * This register is used to control the peripherals connected to emac0_tx_d0
9849  *
9850  * Only reset by a cold reset (ignores warm reset).
9851  *
9852  * NOTE: These registers should not be modified after IO configuration.There is no
9853  * support for dynamically changing the Pin Mux selections.
9854  *
9855  * Register Layout
9856  *
9857  * Bits | Access | Reset | Description
9858  * :-------|:-------|:------|:--------------------------------
9859  * [1:0] | RW | 0x0 | emac0_tx_d0 Mux Selection Field
9860  * [31:2] | ??? | 0x0 | *UNDEFINED*
9861  *
9862  */
9863 /*
9864  * Field : emac0_tx_d0 Mux Selection Field - sel
9865  *
9866  * Select peripheral signals connected emac0_tx_d0.
9867  *
9868  * 0 : Pin is connected to GPIO/LoanIO number 1.
9869  *
9870  * 1 : Pin is connected to Peripheral signal not applicable.
9871  *
9872  * 2 : Pin is connected to Peripheral signal USB1.D0.
9873  *
9874  * 3 : Pin is connected to Peripheral signal RGMII0.TXD0.
9875  *
9876  * Field Access Macros:
9877  *
9878  */
9879 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
9880 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_LSB 0
9881 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
9882 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_MSB 1
9883 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
9884 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_WIDTH 2
9885 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field value. */
9886 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_SET_MSK 0x00000003
9887 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field value. */
9888 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_CLR_MSK 0xfffffffc
9889 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
9890 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_RESET 0x0
9891 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO1_SEL field value from a register. */
9892 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
9893 /* Produces a ALT_SYSMGR_PINMUX_EMACIO1_SEL register field value suitable for setting the register. */
9894 #define ALT_SYSMGR_PINMUX_EMACIO1_SEL_SET(value) (((value) << 0) & 0x00000003)
9895
9896 #ifndef __ASSEMBLY__
9897 /*
9898  * WARNING: The C register and register group struct declarations are provided for
9899  * convenience and illustrative purposes. They should, however, be used with
9900  * caution as the C language standard provides no guarantees about the alignment or
9901  * atomicity of device memory accesses. The recommended practice for writing
9902  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
9903  * alt_write_word() functions.
9904  *
9905  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO1.
9906  */
9908 {
9909  uint32_t sel : 2; /* emac0_tx_d0 Mux Selection Field */
9910  uint32_t : 30; /* *UNDEFINED* */
9911 };
9912
9913 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO1. */
9914 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO1_s ALT_SYSMGR_PINMUX_EMACIO1_t;
9915 #endif /* __ASSEMBLY__ */
9916
9917 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO1 register from the beginning of the component. */
9918 #define ALT_SYSMGR_PINMUX_EMACIO1_OFST 0x4
9919
9920 /*
9921  * Register : emac0_tx_d1 Mux Selection Register - EMACIO2
9922  *
9923  * This register is used to control the peripherals connected to emac0_tx_d1
9924  *
9925  * Only reset by a cold reset (ignores warm reset).
9926  *
9927  * NOTE: These registers should not be modified after IO configuration.There is no
9928  * support for dynamically changing the Pin Mux selections.
9929  *
9930  * Register Layout
9931  *
9932  * Bits | Access | Reset | Description
9933  * :-------|:-------|:------|:--------------------------------
9934  * [1:0] | RW | 0x0 | emac0_tx_d1 Mux Selection Field
9935  * [31:2] | ??? | 0x0 | *UNDEFINED*
9936  *
9937  */
9938 /*
9939  * Field : emac0_tx_d1 Mux Selection Field - sel
9940  *
9941  * Select peripheral signals connected emac0_tx_d1.
9942  *
9943  * 0 : Pin is connected to GPIO/LoanIO number 2.
9944  *
9945  * 1 : Pin is connected to Peripheral signal not applicable.
9946  *
9947  * 2 : Pin is connected to Peripheral signal USB1.D1.
9948  *
9949  * 3 : Pin is connected to Peripheral signal RGMII0.TXD1.
9950  *
9951  * Field Access Macros:
9952  *
9953  */
9954 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
9955 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_LSB 0
9956 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
9957 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_MSB 1
9958 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
9959 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_WIDTH 2
9960 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field value. */
9961 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_SET_MSK 0x00000003
9962 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field value. */
9963 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_CLR_MSK 0xfffffffc
9964 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
9965 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_RESET 0x0
9966 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO2_SEL field value from a register. */
9967 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
9968 /* Produces a ALT_SYSMGR_PINMUX_EMACIO2_SEL register field value suitable for setting the register. */
9969 #define ALT_SYSMGR_PINMUX_EMACIO2_SEL_SET(value) (((value) << 0) & 0x00000003)
9970
9971 #ifndef __ASSEMBLY__
9972 /*
9973  * WARNING: The C register and register group struct declarations are provided for
9974  * convenience and illustrative purposes. They should, however, be used with
9975  * caution as the C language standard provides no guarantees about the alignment or
9976  * atomicity of device memory accesses. The recommended practice for writing
9977  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
9978  * alt_write_word() functions.
9979  *
9980  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO2.
9981  */
9983 {
9984  uint32_t sel : 2; /* emac0_tx_d1 Mux Selection Field */
9985  uint32_t : 30; /* *UNDEFINED* */
9986 };
9987
9988 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO2. */
9989 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO2_s ALT_SYSMGR_PINMUX_EMACIO2_t;
9990 #endif /* __ASSEMBLY__ */
9991
9992 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO2 register from the beginning of the component. */
9993 #define ALT_SYSMGR_PINMUX_EMACIO2_OFST 0x8
9994
9995 /*
9996  * Register : emac0_tx_d2 Mux Selection Register - EMACIO3
9997  *
9998  * This register is used to control the peripherals connected to emac0_tx_d2
9999  *
10000  * Only reset by a cold reset (ignores warm reset).
10001  *
10002  * NOTE: These registers should not be modified after IO configuration.There is no
10003  * support for dynamically changing the Pin Mux selections.
10004  *
10005  * Register Layout
10006  *
10007  * Bits | Access | Reset | Description
10008  * :-------|:-------|:------|:--------------------------------
10009  * [1:0] | RW | 0x0 | emac0_tx_d2 Mux Selection Field
10010  * [31:2] | ??? | 0x0 | *UNDEFINED*
10011  *
10012  */
10013 /*
10014  * Field : emac0_tx_d2 Mux Selection Field - sel
10015  *
10016  * Select peripheral signals connected emac0_tx_d2.
10017  *
10018  * 0 : Pin is connected to GPIO/LoanIO number 3.
10019  *
10020  * 1 : Pin is connected to Peripheral signal not applicable.
10021  *
10022  * 2 : Pin is connected to Peripheral signal USB1.D2.
10023  *
10024  * 3 : Pin is connected to Peripheral signal RGMII0.TXD2.
10025  *
10026  * Field Access Macros:
10027  *
10028  */
10029 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
10030 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_LSB 0
10031 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
10032 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_MSB 1
10033 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
10034 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_WIDTH 2
10035 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field value. */
10036 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_SET_MSK 0x00000003
10037 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field value. */
10038 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_CLR_MSK 0xfffffffc
10039 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
10040 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_RESET 0x0
10041 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO3_SEL field value from a register. */
10042 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
10043 /* Produces a ALT_SYSMGR_PINMUX_EMACIO3_SEL register field value suitable for setting the register. */
10044 #define ALT_SYSMGR_PINMUX_EMACIO3_SEL_SET(value) (((value) << 0) & 0x00000003)
10045
10046 #ifndef __ASSEMBLY__
10047 /*
10048  * WARNING: The C register and register group struct declarations are provided for
10049  * convenience and illustrative purposes. They should, however, be used with
10050  * caution as the C language standard provides no guarantees about the alignment or
10051  * atomicity of device memory accesses. The recommended practice for writing
10052  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10053  * alt_write_word() functions.
10054  *
10055  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO3.
10056  */
10058 {
10059  uint32_t sel : 2; /* emac0_tx_d2 Mux Selection Field */
10060  uint32_t : 30; /* *UNDEFINED* */
10061 };
10062
10063 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO3. */
10064 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO3_s ALT_SYSMGR_PINMUX_EMACIO3_t;
10065 #endif /* __ASSEMBLY__ */
10066
10067 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO3 register from the beginning of the component. */
10068 #define ALT_SYSMGR_PINMUX_EMACIO3_OFST 0xc
10069
10070 /*
10071  * Register : emac0_tx_d3 Mux Selection Register - EMACIO4
10072  *
10073  * This register is used to control the peripherals connected to emac0_tx_d3
10074  *
10075  * Only reset by a cold reset (ignores warm reset).
10076  *
10077  * NOTE: These registers should not be modified after IO configuration.There is no
10078  * support for dynamically changing the Pin Mux selections.
10079  *
10080  * Register Layout
10081  *
10082  * Bits | Access | Reset | Description
10083  * :-------|:-------|:------|:--------------------------------
10084  * [1:0] | RW | 0x0 | emac0_tx_d3 Mux Selection Field
10085  * [31:2] | ??? | 0x0 | *UNDEFINED*
10086  *
10087  */
10088 /*
10089  * Field : emac0_tx_d3 Mux Selection Field - sel
10090  *
10091  * Select peripheral signals connected emac0_tx_d3.
10092  *
10093  * 0 : Pin is connected to GPIO/LoanIO number 4.
10094  *
10095  * 1 : Pin is connected to Peripheral signal not applicable.
10096  *
10097  * 2 : Pin is connected to Peripheral signal USB1.D3.
10098  *
10099  * 3 : Pin is connected to Peripheral signal RGMII0.TXD3.
10100  *
10101  * Field Access Macros:
10102  *
10103  */
10104 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
10105 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_LSB 0
10106 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
10107 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_MSB 1
10108 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
10109 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_WIDTH 2
10110 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field value. */
10111 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_SET_MSK 0x00000003
10112 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field value. */
10113 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_CLR_MSK 0xfffffffc
10114 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
10115 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_RESET 0x0
10116 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO4_SEL field value from a register. */
10117 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
10118 /* Produces a ALT_SYSMGR_PINMUX_EMACIO4_SEL register field value suitable for setting the register. */
10119 #define ALT_SYSMGR_PINMUX_EMACIO4_SEL_SET(value) (((value) << 0) & 0x00000003)
10120
10121 #ifndef __ASSEMBLY__
10122 /*
10123  * WARNING: The C register and register group struct declarations are provided for
10124  * convenience and illustrative purposes. They should, however, be used with
10125  * caution as the C language standard provides no guarantees about the alignment or
10126  * atomicity of device memory accesses. The recommended practice for writing
10127  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10128  * alt_write_word() functions.
10129  *
10130  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO4.
10131  */
10133 {
10134  uint32_t sel : 2; /* emac0_tx_d3 Mux Selection Field */
10135  uint32_t : 30; /* *UNDEFINED* */
10136 };
10137
10138 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO4. */
10139 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO4_s ALT_SYSMGR_PINMUX_EMACIO4_t;
10140 #endif /* __ASSEMBLY__ */
10141
10142 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO4 register from the beginning of the component. */
10143 #define ALT_SYSMGR_PINMUX_EMACIO4_OFST 0x10
10144
10145 /*
10146  * Register : emac0_rx_d0 Mux Selection Register - EMACIO5
10147  *
10148  * This register is used to control the peripherals connected to emac0_rx_d0
10149  *
10150  * Only reset by a cold reset (ignores warm reset).
10151  *
10152  * NOTE: These registers should not be modified after IO configuration.There is no
10153  * support for dynamically changing the Pin Mux selections.
10154  *
10155  * Register Layout
10156  *
10157  * Bits | Access | Reset | Description
10158  * :-------|:-------|:------|:--------------------------------
10159  * [1:0] | RW | 0x0 | emac0_rx_d0 Mux Selection Field
10160  * [31:2] | ??? | 0x0 | *UNDEFINED*
10161  *
10162  */
10163 /*
10164  * Field : emac0_rx_d0 Mux Selection Field - sel
10165  *
10166  * Select peripheral signals connected emac0_rx_d0.
10167  *
10168  * 0 : Pin is connected to GPIO/LoanIO number 5.
10169  *
10170  * 1 : Pin is connected to Peripheral signal not applicable.
10171  *
10172  * 2 : Pin is connected to Peripheral signal USB1.D4.
10173  *
10174  * 3 : Pin is connected to Peripheral signal RGMII0.RXD0.
10175  *
10176  * Field Access Macros:
10177  *
10178  */
10179 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
10180 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_LSB 0
10181 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
10182 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_MSB 1
10183 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
10184 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_WIDTH 2
10185 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field value. */
10186 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_SET_MSK 0x00000003
10187 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field value. */
10188 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_CLR_MSK 0xfffffffc
10189 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
10190 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_RESET 0x0
10191 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO5_SEL field value from a register. */
10192 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
10193 /* Produces a ALT_SYSMGR_PINMUX_EMACIO5_SEL register field value suitable for setting the register. */
10194 #define ALT_SYSMGR_PINMUX_EMACIO5_SEL_SET(value) (((value) << 0) & 0x00000003)
10195
10196 #ifndef __ASSEMBLY__
10197 /*
10198  * WARNING: The C register and register group struct declarations are provided for
10199  * convenience and illustrative purposes. They should, however, be used with
10200  * caution as the C language standard provides no guarantees about the alignment or
10201  * atomicity of device memory accesses. The recommended practice for writing
10202  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10203  * alt_write_word() functions.
10204  *
10205  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO5.
10206  */
10208 {
10209  uint32_t sel : 2; /* emac0_rx_d0 Mux Selection Field */
10210  uint32_t : 30; /* *UNDEFINED* */
10211 };
10212
10213 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO5. */
10214 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO5_s ALT_SYSMGR_PINMUX_EMACIO5_t;
10215 #endif /* __ASSEMBLY__ */
10216
10217 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO5 register from the beginning of the component. */
10218 #define ALT_SYSMGR_PINMUX_EMACIO5_OFST 0x14
10219
10220 /*
10221  * Register : emac0_mdio Mux Selection Register - EMACIO6
10222  *
10223  * This register is used to control the peripherals connected to emac0_mdio
10224  *
10225  * Only reset by a cold reset (ignores warm reset).
10226  *
10227  * NOTE: These registers should not be modified after IO configuration.There is no
10228  * support for dynamically changing the Pin Mux selections.
10229  *
10230  * Register Layout
10231  *
10232  * Bits | Access | Reset | Description
10233  * :-------|:-------|:------|:-------------------------------
10234  * [1:0] | RW | 0x0 | emac0_mdio Mux Selection Field
10235  * [31:2] | ??? | 0x0 | *UNDEFINED*
10236  *
10237  */
10238 /*
10239  * Field : emac0_mdio Mux Selection Field - sel
10240  *
10241  * Select peripheral signals connected emac0_mdio.
10242  *
10243  * 0 : Pin is connected to GPIO/LoanIO number 6.
10244  *
10245  * 1 : Pin is connected to Peripheral signal I2C2.SDA.
10246  *
10247  * 2 : Pin is connected to Peripheral signal USB1.D5.
10248  *
10249  * 3 : Pin is connected to Peripheral signal RGMII0.MDIO.
10250  *
10251  * Field Access Macros:
10252  *
10253  */
10254 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
10255 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_LSB 0
10256 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
10257 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_MSB 1
10258 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
10259 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_WIDTH 2
10260 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field value. */
10261 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_SET_MSK 0x00000003
10262 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field value. */
10263 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_CLR_MSK 0xfffffffc
10264 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
10265 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_RESET 0x0
10266 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO6_SEL field value from a register. */
10267 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
10268 /* Produces a ALT_SYSMGR_PINMUX_EMACIO6_SEL register field value suitable for setting the register. */
10269 #define ALT_SYSMGR_PINMUX_EMACIO6_SEL_SET(value) (((value) << 0) & 0x00000003)
10270
10271 #ifndef __ASSEMBLY__
10272 /*
10273  * WARNING: The C register and register group struct declarations are provided for
10274  * convenience and illustrative purposes. They should, however, be used with
10275  * caution as the C language standard provides no guarantees about the alignment or
10276  * atomicity of device memory accesses. The recommended practice for writing
10277  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10278  * alt_write_word() functions.
10279  *
10280  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO6.
10281  */
10283 {
10284  uint32_t sel : 2; /* emac0_mdio Mux Selection Field */
10285  uint32_t : 30; /* *UNDEFINED* */
10286 };
10287
10288 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO6. */
10289 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO6_s ALT_SYSMGR_PINMUX_EMACIO6_t;
10290 #endif /* __ASSEMBLY__ */
10291
10292 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO6 register from the beginning of the component. */
10293 #define ALT_SYSMGR_PINMUX_EMACIO6_OFST 0x18
10294
10295 /*
10296  * Register : emac0_mdc Mux Selection Register - EMACIO7
10297  *
10298  * This register is used to control the peripherals connected to emac0_mdc
10299  *
10300  * Only reset by a cold reset (ignores warm reset).
10301  *
10302  * NOTE: These registers should not be modified after IO configuration.There is no
10303  * support for dynamically changing the Pin Mux selections.
10304  *
10305  * Register Layout
10306  *
10307  * Bits | Access | Reset | Description
10308  * :-------|:-------|:------|:------------------------------
10309  * [1:0] | RW | 0x0 | emac0_mdc Mux Selection Field
10310  * [31:2] | ??? | 0x0 | *UNDEFINED*
10311  *
10312  */
10313 /*
10314  * Field : emac0_mdc Mux Selection Field - sel
10315  *
10316  * Select peripheral signals connected emac0_mdc.
10317  *
10318  * 0 : Pin is connected to GPIO/LoanIO number 7.
10319  *
10320  * 1 : Pin is connected to Peripheral signal I2C2.SCL.
10321  *
10322  * 2 : Pin is connected to Peripheral signal USB1.D6.
10323  *
10324  * 3 : Pin is connected to Peripheral signal RGMII0.MDC.
10325  *
10326  * Field Access Macros:
10327  *
10328  */
10329 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
10330 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_LSB 0
10331 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
10332 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_MSB 1
10333 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
10334 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_WIDTH 2
10335 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field value. */
10336 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_SET_MSK 0x00000003
10337 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field value. */
10338 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_CLR_MSK 0xfffffffc
10339 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
10340 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_RESET 0x0
10341 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO7_SEL field value from a register. */
10342 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
10343 /* Produces a ALT_SYSMGR_PINMUX_EMACIO7_SEL register field value suitable for setting the register. */
10344 #define ALT_SYSMGR_PINMUX_EMACIO7_SEL_SET(value) (((value) << 0) & 0x00000003)
10345
10346 #ifndef __ASSEMBLY__
10347 /*
10348  * WARNING: The C register and register group struct declarations are provided for
10349  * convenience and illustrative purposes. They should, however, be used with
10350  * caution as the C language standard provides no guarantees about the alignment or
10351  * atomicity of device memory accesses. The recommended practice for writing
10352  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10353  * alt_write_word() functions.
10354  *
10355  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO7.
10356  */
10358 {
10359  uint32_t sel : 2; /* emac0_mdc Mux Selection Field */
10360  uint32_t : 30; /* *UNDEFINED* */
10361 };
10362
10363 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO7. */
10364 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO7_s ALT_SYSMGR_PINMUX_EMACIO7_t;
10365 #endif /* __ASSEMBLY__ */
10366
10367 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO7 register from the beginning of the component. */
10368 #define ALT_SYSMGR_PINMUX_EMACIO7_OFST 0x1c
10369
10370 /*
10371  * Register : emac0_rx_ctl Mux Selection Register - EMACIO8
10372  *
10373  * This register is used to control the peripherals connected to emac0_rx_ctl
10374  *
10375  * Only reset by a cold reset (ignores warm reset).
10376  *
10377  * NOTE: These registers should not be modified after IO configuration.There is no
10378  * support for dynamically changing the Pin Mux selections.
10379  *
10380  * Register Layout
10381  *
10382  * Bits | Access | Reset | Description
10383  * :-------|:-------|:------|:---------------------------------
10384  * [1:0] | RW | 0x0 | emac0_rx_ctl Mux Selection Field
10385  * [31:2] | ??? | 0x0 | *UNDEFINED*
10386  *
10387  */
10388 /*
10389  * Field : emac0_rx_ctl Mux Selection Field - sel
10390  *
10391  * Select peripheral signals connected emac0_rx_ctl.
10392  *
10393  * 0 : Pin is connected to GPIO/LoanIO number 8.
10394  *
10395  * 1 : Pin is connected to Peripheral signal not applicable.
10396  *
10397  * 2 : Pin is connected to Peripheral signal USB1.D7.
10398  *
10399  * 3 : Pin is connected to Peripheral signal RGMII0.RX_CTL.
10400  *
10401  * Field Access Macros:
10402  *
10403  */
10404 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
10405 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_LSB 0
10406 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
10407 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_MSB 1
10408 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
10409 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_WIDTH 2
10410 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field value. */
10411 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_SET_MSK 0x00000003
10412 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field value. */
10413 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_CLR_MSK 0xfffffffc
10414 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
10415 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_RESET 0x0
10416 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO8_SEL field value from a register. */
10417 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
10418 /* Produces a ALT_SYSMGR_PINMUX_EMACIO8_SEL register field value suitable for setting the register. */
10419 #define ALT_SYSMGR_PINMUX_EMACIO8_SEL_SET(value) (((value) << 0) & 0x00000003)
10420
10421 #ifndef __ASSEMBLY__
10422 /*
10423  * WARNING: The C register and register group struct declarations are provided for
10424  * convenience and illustrative purposes. They should, however, be used with
10425  * caution as the C language standard provides no guarantees about the alignment or
10426  * atomicity of device memory accesses. The recommended practice for writing
10427  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10428  * alt_write_word() functions.
10429  *
10430  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO8.
10431  */
10433 {
10434  uint32_t sel : 2; /* emac0_rx_ctl Mux Selection Field */
10435  uint32_t : 30; /* *UNDEFINED* */
10436 };
10437
10438 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO8. */
10439 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO8_s ALT_SYSMGR_PINMUX_EMACIO8_t;
10440 #endif /* __ASSEMBLY__ */
10441
10442 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO8 register from the beginning of the component. */
10443 #define ALT_SYSMGR_PINMUX_EMACIO8_OFST 0x20
10444
10445 /*
10446  * Register : emac0_tx_ctl Mux Selection Register - EMACIO9
10447  *
10448  * This register is used to control the peripherals connected to emac0_tx_ctl
10449  *
10450  * Only reset by a cold reset (ignores warm reset).
10451  *
10452  * NOTE: These registers should not be modified after IO configuration.There is no
10453  * support for dynamically changing the Pin Mux selections.
10454  *
10455  * Register Layout
10456  *
10457  * Bits | Access | Reset | Description
10458  * :-------|:-------|:------|:---------------------------------
10459  * [1:0] | RW | 0x0 | emac0_tx_ctl Mux Selection Field
10460  * [31:2] | ??? | 0x0 | *UNDEFINED*
10461  *
10462  */
10463 /*
10464  * Field : emac0_tx_ctl Mux Selection Field - sel
10465  *
10466  * Select peripheral signals connected emac0_tx_ctl.
10467  *
10468  * 0 : Pin is connected to GPIO/LoanIO number 9.
10469  *
10470  * 1 : Pin is connected to Peripheral signal not applicable.
10471  *
10472  * 2 : Pin is connected to Peripheral signal not applicable.
10473  *
10474  * 3 : Pin is connected to Peripheral signal RGMII0.TX_CTL.
10475  *
10476  * Field Access Macros:
10477  *
10478  */
10479 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
10480 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_LSB 0
10481 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
10482 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_MSB 1
10483 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
10484 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_WIDTH 2
10485 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field value. */
10486 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_SET_MSK 0x00000003
10487 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field value. */
10488 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_CLR_MSK 0xfffffffc
10489 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
10490 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_RESET 0x0
10491 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO9_SEL field value from a register. */
10492 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
10493 /* Produces a ALT_SYSMGR_PINMUX_EMACIO9_SEL register field value suitable for setting the register. */
10494 #define ALT_SYSMGR_PINMUX_EMACIO9_SEL_SET(value) (((value) << 0) & 0x00000003)
10495
10496 #ifndef __ASSEMBLY__
10497 /*
10498  * WARNING: The C register and register group struct declarations are provided for
10499  * convenience and illustrative purposes. They should, however, be used with
10500  * caution as the C language standard provides no guarantees about the alignment or
10501  * atomicity of device memory accesses. The recommended practice for writing
10502  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10503  * alt_write_word() functions.
10504  *
10505  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO9.
10506  */
10508 {
10509  uint32_t sel : 2; /* emac0_tx_ctl Mux Selection Field */
10510  uint32_t : 30; /* *UNDEFINED* */
10511 };
10512
10513 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO9. */
10514 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO9_s ALT_SYSMGR_PINMUX_EMACIO9_t;
10515 #endif /* __ASSEMBLY__ */
10516
10517 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO9 register from the beginning of the component. */
10518 #define ALT_SYSMGR_PINMUX_EMACIO9_OFST 0x24
10519
10520 /*
10521  * Register : emac0_rx_clk Mux Selection Register - EMACIO10
10522  *
10523  * This register is used to control the peripherals connected to emac0_rx_clk
10524  *
10525  * Only reset by a cold reset (ignores warm reset).
10526  *
10527  * NOTE: These registers should not be modified after IO configuration.There is no
10528  * support for dynamically changing the Pin Mux selections.
10529  *
10530  * Register Layout
10531  *
10532  * Bits | Access | Reset | Description
10533  * :-------|:-------|:------|:---------------------------------
10534  * [1:0] | RW | 0x0 | emac0_rx_clk Mux Selection Field
10535  * [31:2] | ??? | 0x0 | *UNDEFINED*
10536  *
10537  */
10538 /*
10539  * Field : emac0_rx_clk Mux Selection Field - sel
10540  *
10541  * Select peripheral signals connected emac0_rx_clk.
10542  *
10543  * 0 : Pin is connected to GPIO/LoanIO number 10.
10544  *
10545  * 1 : Pin is connected to Peripheral signal not applicable.
10546  *
10547  * 2 : Pin is connected to Peripheral signal USB1.CLK.
10548  *
10549  * 3 : Pin is connected to Peripheral signal RGMII0.RX_CLK.
10550  *
10551  * Field Access Macros:
10552  *
10553  */
10554 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
10555 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_LSB 0
10556 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
10557 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_MSB 1
10558 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
10559 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_WIDTH 2
10560 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field value. */
10561 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_SET_MSK 0x00000003
10562 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field value. */
10563 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_CLR_MSK 0xfffffffc
10564 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
10565 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_RESET 0x0
10566 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO10_SEL field value from a register. */
10567 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_GET(value) (((value) & 0x00000003) >> 0)
10568 /* Produces a ALT_SYSMGR_PINMUX_EMACIO10_SEL register field value suitable for setting the register. */
10569 #define ALT_SYSMGR_PINMUX_EMACIO10_SEL_SET(value) (((value) << 0) & 0x00000003)
10570
10571 #ifndef __ASSEMBLY__
10572 /*
10573  * WARNING: The C register and register group struct declarations are provided for
10574  * convenience and illustrative purposes. They should, however, be used with
10575  * caution as the C language standard provides no guarantees about the alignment or
10576  * atomicity of device memory accesses. The recommended practice for writing
10577  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10578  * alt_write_word() functions.
10579  *
10580  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO10.
10581  */
10583 {
10584  uint32_t sel : 2; /* emac0_rx_clk Mux Selection Field */
10585  uint32_t : 30; /* *UNDEFINED* */
10586 };
10587
10588 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO10. */
10589 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO10_s ALT_SYSMGR_PINMUX_EMACIO10_t;
10590 #endif /* __ASSEMBLY__ */
10591
10592 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO10 register from the beginning of the component. */
10593 #define ALT_SYSMGR_PINMUX_EMACIO10_OFST 0x28
10594
10595 /*
10596  * Register : emac0_rx_d1 Mux Selection Register - EMACIO11
10597  *
10598  * This register is used to control the peripherals connected to emac0_rx_d1
10599  *
10600  * Only reset by a cold reset (ignores warm reset).
10601  *
10602  * NOTE: These registers should not be modified after IO configuration.There is no
10603  * support for dynamically changing the Pin Mux selections.
10604  *
10605  * Register Layout
10606  *
10607  * Bits | Access | Reset | Description
10608  * :-------|:-------|:------|:--------------------------------
10609  * [1:0] | RW | 0x0 | emac0_rx_d1 Mux Selection Field
10610  * [31:2] | ??? | 0x0 | *UNDEFINED*
10611  *
10612  */
10613 /*
10614  * Field : emac0_rx_d1 Mux Selection Field - sel
10615  *
10616  * Select peripheral signals connected emac0_rx_d1.
10617  *
10618  * 0 : Pin is connected to GPIO/LoanIO number 11.
10619  *
10620  * 1 : Pin is connected to Peripheral signal not applicable.
10621  *
10622  * 2 : Pin is connected to Peripheral signal USB1.STP.
10623  *
10624  * 3 : Pin is connected to Peripheral signal RGMII0.RXD1.
10625  *
10626  * Field Access Macros:
10627  *
10628  */
10629 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
10630 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_LSB 0
10631 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
10632 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_MSB 1
10633 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
10634 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_WIDTH 2
10635 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field value. */
10636 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_SET_MSK 0x00000003
10637 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field value. */
10638 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_CLR_MSK 0xfffffffc
10639 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
10640 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_RESET 0x0
10641 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO11_SEL field value from a register. */
10642 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_GET(value) (((value) & 0x00000003) >> 0)
10643 /* Produces a ALT_SYSMGR_PINMUX_EMACIO11_SEL register field value suitable for setting the register. */
10644 #define ALT_SYSMGR_PINMUX_EMACIO11_SEL_SET(value) (((value) << 0) & 0x00000003)
10645
10646 #ifndef __ASSEMBLY__
10647 /*
10648  * WARNING: The C register and register group struct declarations are provided for
10649  * convenience and illustrative purposes. They should, however, be used with
10650  * caution as the C language standard provides no guarantees about the alignment or
10651  * atomicity of device memory accesses. The recommended practice for writing
10652  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10653  * alt_write_word() functions.
10654  *
10655  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO11.
10656  */
10658 {
10659  uint32_t sel : 2; /* emac0_rx_d1 Mux Selection Field */
10660  uint32_t : 30; /* *UNDEFINED* */
10661 };
10662
10663 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO11. */
10664 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO11_s ALT_SYSMGR_PINMUX_EMACIO11_t;
10665 #endif /* __ASSEMBLY__ */
10666
10667 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO11 register from the beginning of the component. */
10668 #define ALT_SYSMGR_PINMUX_EMACIO11_OFST 0x2c
10669
10670 /*
10671  * Register : emac0_rx_d2 Mux Selection Register - EMACIO12
10672  *
10673  * This register is used to control the peripherals connected to emac0_rx_d2
10674  *
10675  * Only reset by a cold reset (ignores warm reset).
10676  *
10677  * NOTE: These registers should not be modified after IO configuration.There is no
10678  * support for dynamically changing the Pin Mux selections.
10679  *
10680  * Register Layout
10681  *
10682  * Bits | Access | Reset | Description
10683  * :-------|:-------|:------|:--------------------------------
10684  * [1:0] | RW | 0x0 | emac0_rx_d2 Mux Selection Field
10685  * [31:2] | ??? | 0x0 | *UNDEFINED*
10686  *
10687  */
10688 /*
10689  * Field : emac0_rx_d2 Mux Selection Field - sel
10690  *
10691  * Select peripheral signals connected emac0_rx_d2.
10692  *
10693  * 0 : Pin is connected to GPIO/LoanIO number 12.
10694  *
10695  * 1 : Pin is connected to Peripheral signal not applicable.
10696  *
10697  * 2 : Pin is connected to Peripheral signal USB1.DIR.
10698  *
10699  * 3 : Pin is connected to Peripheral signal RGMII0.RXD2.
10700  *
10701  * Field Access Macros:
10702  *
10703  */
10704 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
10705 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_LSB 0
10706 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
10707 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_MSB 1
10708 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
10709 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_WIDTH 2
10710 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field value. */
10711 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_SET_MSK 0x00000003
10712 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field value. */
10713 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_CLR_MSK 0xfffffffc
10714 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
10715 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_RESET 0x0
10716 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO12_SEL field value from a register. */
10717 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_GET(value) (((value) & 0x00000003) >> 0)
10718 /* Produces a ALT_SYSMGR_PINMUX_EMACIO12_SEL register field value suitable for setting the register. */
10719 #define ALT_SYSMGR_PINMUX_EMACIO12_SEL_SET(value) (((value) << 0) & 0x00000003)
10720
10721 #ifndef __ASSEMBLY__
10722 /*
10723  * WARNING: The C register and register group struct declarations are provided for
10724  * convenience and illustrative purposes. They should, however, be used with
10725  * caution as the C language standard provides no guarantees about the alignment or
10726  * atomicity of device memory accesses. The recommended practice for writing
10727  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10728  * alt_write_word() functions.
10729  *
10730  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO12.
10731  */
10733 {
10734  uint32_t sel : 2; /* emac0_rx_d2 Mux Selection Field */
10735  uint32_t : 30; /* *UNDEFINED* */
10736 };
10737
10738 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO12. */
10739 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO12_s ALT_SYSMGR_PINMUX_EMACIO12_t;
10740 #endif /* __ASSEMBLY__ */
10741
10742 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO12 register from the beginning of the component. */
10743 #define ALT_SYSMGR_PINMUX_EMACIO12_OFST 0x30
10744
10745 /*
10746  * Register : emac0_rx_d3 Mux Selection Register - EMACIO13
10747  *
10748  * This register is used to control the peripherals connected to emac0_rx_d3
10749  *
10750  * Only reset by a cold reset (ignores warm reset).
10751  *
10752  * NOTE: These registers should not be modified after IO configuration.There is no
10753  * support for dynamically changing the Pin Mux selections.
10754  *
10755  * Register Layout
10756  *
10757  * Bits | Access | Reset | Description
10758  * :-------|:-------|:------|:--------------------------------
10759  * [1:0] | RW | 0x0 | emac0_rx_d3 Mux Selection Field
10760  * [31:2] | ??? | 0x0 | *UNDEFINED*
10761  *
10762  */
10763 /*
10764  * Field : emac0_rx_d3 Mux Selection Field - sel
10765  *
10766  * Select peripheral signals connected emac0_rx_d3.
10767  *
10768  * 0 : Pin is connected to GPIO/LoanIO number 13.
10769  *
10770  * 1 : Pin is connected to Peripheral signal not applicable.
10771  *
10772  * 2 : Pin is connected to Peripheral signal USB1.NXT.
10773  *
10774  * 3 : Pin is connected to Peripheral signal RGMII0.RXD3.
10775  *
10776  * Field Access Macros:
10777  *
10778  */
10779 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
10780 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_LSB 0
10781 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
10782 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_MSB 1
10783 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
10784 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_WIDTH 2
10785 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field value. */
10786 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_SET_MSK 0x00000003
10787 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field value. */
10788 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_CLR_MSK 0xfffffffc
10789 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
10790 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_RESET 0x0
10791 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO13_SEL field value from a register. */
10792 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_GET(value) (((value) & 0x00000003) >> 0)
10793 /* Produces a ALT_SYSMGR_PINMUX_EMACIO13_SEL register field value suitable for setting the register. */
10794 #define ALT_SYSMGR_PINMUX_EMACIO13_SEL_SET(value) (((value) << 0) & 0x00000003)
10795
10796 #ifndef __ASSEMBLY__
10797 /*
10798  * WARNING: The C register and register group struct declarations are provided for
10799  * convenience and illustrative purposes. They should, however, be used with
10800  * caution as the C language standard provides no guarantees about the alignment or
10801  * atomicity of device memory accesses. The recommended practice for writing
10802  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10803  * alt_write_word() functions.
10804  *
10805  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO13.
10806  */
10808 {
10809  uint32_t sel : 2; /* emac0_rx_d3 Mux Selection Field */
10810  uint32_t : 30; /* *UNDEFINED* */
10811 };
10812
10813 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO13. */
10814 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO13_s ALT_SYSMGR_PINMUX_EMACIO13_t;
10815 #endif /* __ASSEMBLY__ */
10816
10817 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO13 register from the beginning of the component. */
10818 #define ALT_SYSMGR_PINMUX_EMACIO13_OFST 0x34
10819
10820 /*
10821  * Register : emac1_tx_clk Mux Selection Register - EMACIO14
10822  *
10823  * This register is used to control the peripherals connected to emac1_tx_clk
10824  *
10825  * Only reset by a cold reset (ignores warm reset).
10826  *
10827  * NOTE: These registers should not be modified after IO configuration.There is no
10828  * support for dynamically changing the Pin Mux selections.
10829  *
10830  * Register Layout
10831  *
10832  * Bits | Access | Reset | Description
10833  * :-------|:-------|:------|:---------------------------------
10834  * [1:0] | RW | 0x0 | emac1_tx_clk Mux Selection Field
10835  * [31:2] | ??? | 0x0 | *UNDEFINED*
10836  *
10837  */
10838 /*
10839  * Field : emac1_tx_clk Mux Selection Field - sel
10840  *
10841  * Select peripheral signals connected emac1_tx_clk.
10842  *
10843  * 0 : Pin is connected to GPIO/LoanIO number 48.
10844  *
10845  * 1 : Pin is connected to Peripheral signal not applicable.
10846  *
10847  * 2 : Pin is connected to Peripheral signal not applicable.
10848  *
10849  * 3 : Pin is connected to Peripheral signal RGMII1.TX_CLK.
10850  *
10851  * Field Access Macros:
10852  *
10853  */
10854 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
10855 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_LSB 0
10856 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
10857 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_MSB 1
10858 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
10859 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_WIDTH 2
10860 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field value. */
10861 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_SET_MSK 0x00000003
10862 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field value. */
10863 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_CLR_MSK 0xfffffffc
10864 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
10865 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_RESET 0x0
10866 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO14_SEL field value from a register. */
10867 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_GET(value) (((value) & 0x00000003) >> 0)
10868 /* Produces a ALT_SYSMGR_PINMUX_EMACIO14_SEL register field value suitable for setting the register. */
10869 #define ALT_SYSMGR_PINMUX_EMACIO14_SEL_SET(value) (((value) << 0) & 0x00000003)
10870
10871 #ifndef __ASSEMBLY__
10872 /*
10873  * WARNING: The C register and register group struct declarations are provided for
10874  * convenience and illustrative purposes. They should, however, be used with
10875  * caution as the C language standard provides no guarantees about the alignment or
10876  * atomicity of device memory accesses. The recommended practice for writing
10877  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10878  * alt_write_word() functions.
10879  *
10880  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO14.
10881  */
10883 {
10884  uint32_t sel : 2; /* emac1_tx_clk Mux Selection Field */
10885  uint32_t : 30; /* *UNDEFINED* */
10886 };
10887
10888 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO14. */
10889 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO14_s ALT_SYSMGR_PINMUX_EMACIO14_t;
10890 #endif /* __ASSEMBLY__ */
10891
10892 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO14 register from the beginning of the component. */
10893 #define ALT_SYSMGR_PINMUX_EMACIO14_OFST 0x38
10894
10895 /*
10896  * Register : emac1_tx_d0 Mux Selection Register - EMACIO15
10897  *
10898  * This register is used to control the peripherals connected to emac1_tx_d0
10899  *
10900  * Only reset by a cold reset (ignores warm reset).
10901  *
10902  * NOTE: These registers should not be modified after IO configuration.There is no
10903  * support for dynamically changing the Pin Mux selections.
10904  *
10905  * Register Layout
10906  *
10907  * Bits | Access | Reset | Description
10908  * :-------|:-------|:------|:--------------------------------
10909  * [1:0] | RW | 0x0 | emac1_tx_d0 Mux Selection Field
10910  * [31:2] | ??? | 0x0 | *UNDEFINED*
10911  *
10912  */
10913 /*
10914  * Field : emac1_tx_d0 Mux Selection Field - sel
10915  *
10916  * Select peripheral signals connected emac1_tx_d0.
10917  *
10918  * 0 : Pin is connected to GPIO/LoanIO number 49.
10919  *
10920  * 1 : Pin is connected to Peripheral signal not applicable.
10921  *
10922  * 2 : Pin is connected to Peripheral signal not applicable.
10923  *
10924  * 3 : Pin is connected to Peripheral signal RGMII1.TXD0.
10925  *
10926  * Field Access Macros:
10927  *
10928  */
10929 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
10930 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_LSB 0
10931 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
10932 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_MSB 1
10933 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
10934 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_WIDTH 2
10935 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field value. */
10936 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_SET_MSK 0x00000003
10937 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field value. */
10938 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_CLR_MSK 0xfffffffc
10939 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
10940 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_RESET 0x0
10941 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO15_SEL field value from a register. */
10942 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_GET(value) (((value) & 0x00000003) >> 0)
10943 /* Produces a ALT_SYSMGR_PINMUX_EMACIO15_SEL register field value suitable for setting the register. */
10944 #define ALT_SYSMGR_PINMUX_EMACIO15_SEL_SET(value) (((value) << 0) & 0x00000003)
10945
10946 #ifndef __ASSEMBLY__
10947 /*
10948  * WARNING: The C register and register group struct declarations are provided for
10949  * convenience and illustrative purposes. They should, however, be used with
10950  * caution as the C language standard provides no guarantees about the alignment or
10951  * atomicity of device memory accesses. The recommended practice for writing
10952  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
10953  * alt_write_word() functions.
10954  *
10955  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO15.
10956  */
10958 {
10959  uint32_t sel : 2; /* emac1_tx_d0 Mux Selection Field */
10960  uint32_t : 30; /* *UNDEFINED* */
10961 };
10962
10963 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO15. */
10964 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO15_s ALT_SYSMGR_PINMUX_EMACIO15_t;
10965 #endif /* __ASSEMBLY__ */
10966
10967 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO15 register from the beginning of the component. */
10968 #define ALT_SYSMGR_PINMUX_EMACIO15_OFST 0x3c
10969
10970 /*
10971  * Register : emac1_tx_d1 Mux Selection Register - EMACIO16
10972  *
10973  * This register is used to control the peripherals connected to emac1_tx_d1
10974  *
10975  * Only reset by a cold reset (ignores warm reset).
10976  *
10977  * NOTE: These registers should not be modified after IO configuration.There is no
10978  * support for dynamically changing the Pin Mux selections.
10979  *
10980  * Register Layout
10981  *
10982  * Bits | Access | Reset | Description
10983  * :-------|:-------|:------|:--------------------------------
10984  * [1:0] | RW | 0x0 | emac1_tx_d1 Mux Selection Field
10985  * [31:2] | ??? | 0x0 | *UNDEFINED*
10986  *
10987  */
10988 /*
10989  * Field : emac1_tx_d1 Mux Selection Field - sel
10990  *
10991  * Select peripheral signals connected emac1_tx_d1.
10992  *
10993  * 0 : Pin is connected to GPIO/LoanIO number 50.
10994  *
10995  * 1 : Pin is connected to Peripheral signal not applicable.
10996  *
10997  * 2 : Pin is connected to Peripheral signal not applicable.
10998  *
10999  * 3 : Pin is connected to Peripheral signal RGMII1.TXD1.
11000  *
11001  * Field Access Macros:
11002  *
11003  */
11004 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
11005 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_LSB 0
11006 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
11007 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_MSB 1
11008 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
11009 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_WIDTH 2
11010 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field value. */
11011 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_SET_MSK 0x00000003
11012 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field value. */
11013 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_CLR_MSK 0xfffffffc
11014 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
11015 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_RESET 0x0
11016 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO16_SEL field value from a register. */
11017 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_GET(value) (((value) & 0x00000003) >> 0)
11018 /* Produces a ALT_SYSMGR_PINMUX_EMACIO16_SEL register field value suitable for setting the register. */
11019 #define ALT_SYSMGR_PINMUX_EMACIO16_SEL_SET(value) (((value) << 0) & 0x00000003)
11020
11021 #ifndef __ASSEMBLY__
11022 /*
11023  * WARNING: The C register and register group struct declarations are provided for
11024  * convenience and illustrative purposes. They should, however, be used with
11025  * caution as the C language standard provides no guarantees about the alignment or
11026  * atomicity of device memory accesses. The recommended practice for writing
11027  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11028  * alt_write_word() functions.
11029  *
11030  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO16.
11031  */
11033 {
11034  uint32_t sel : 2; /* emac1_tx_d1 Mux Selection Field */
11035  uint32_t : 30; /* *UNDEFINED* */
11036 };
11037
11038 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO16. */
11039 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO16_s ALT_SYSMGR_PINMUX_EMACIO16_t;
11040 #endif /* __ASSEMBLY__ */
11041
11042 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO16 register from the beginning of the component. */
11043 #define ALT_SYSMGR_PINMUX_EMACIO16_OFST 0x40
11044
11045 /*
11046  * Register : emac1_tx_ctl Mux Selection Register - EMACIO17
11047  *
11048  * This register is used to control the peripherals connected to emac1_tx_ctl
11049  *
11050  * Only reset by a cold reset (ignores warm reset).
11051  *
11052  * NOTE: These registers should not be modified after IO configuration.There is no
11053  * support for dynamically changing the Pin Mux selections.
11054  *
11055  * Register Layout
11056  *
11057  * Bits | Access | Reset | Description
11058  * :-------|:-------|:------|:---------------------------------
11059  * [1:0] | RW | 0x0 | emac1_tx_ctl Mux Selection Field
11060  * [31:2] | ??? | 0x0 | *UNDEFINED*
11061  *
11062  */
11063 /*
11064  * Field : emac1_tx_ctl Mux Selection Field - sel
11065  *
11066  * Select peripheral signals connected emac1_tx_ctl.
11067  *
11068  * 0 : Pin is connected to GPIO/LoanIO number 51.
11069  *
11070  * 1 : Pin is connected to Peripheral signal not applicable.
11071  *
11072  * 2 : Pin is connected to Peripheral signal not applicable.
11073  *
11074  * 3 : Pin is connected to Peripheral signal RGMII1.TX_CTL.
11075  *
11076  * Field Access Macros:
11077  *
11078  */
11079 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
11080 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_LSB 0
11081 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
11082 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_MSB 1
11083 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
11084 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_WIDTH 2
11085 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field value. */
11086 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_SET_MSK 0x00000003
11087 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field value. */
11088 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_CLR_MSK 0xfffffffc
11089 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
11090 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_RESET 0x0
11091 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO17_SEL field value from a register. */
11092 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_GET(value) (((value) & 0x00000003) >> 0)
11093 /* Produces a ALT_SYSMGR_PINMUX_EMACIO17_SEL register field value suitable for setting the register. */
11094 #define ALT_SYSMGR_PINMUX_EMACIO17_SEL_SET(value) (((value) << 0) & 0x00000003)
11095
11096 #ifndef __ASSEMBLY__
11097 /*
11098  * WARNING: The C register and register group struct declarations are provided for
11099  * convenience and illustrative purposes. They should, however, be used with
11100  * caution as the C language standard provides no guarantees about the alignment or
11101  * atomicity of device memory accesses. The recommended practice for writing
11102  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11103  * alt_write_word() functions.
11104  *
11105  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO17.
11106  */
11108 {
11109  uint32_t sel : 2; /* emac1_tx_ctl Mux Selection Field */
11110  uint32_t : 30; /* *UNDEFINED* */
11111 };
11112
11113 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO17. */
11114 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO17_s ALT_SYSMGR_PINMUX_EMACIO17_t;
11115 #endif /* __ASSEMBLY__ */
11116
11117 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO17 register from the beginning of the component. */
11118 #define ALT_SYSMGR_PINMUX_EMACIO17_OFST 0x44
11119
11120 /*
11121  * Register : emac1_rx_d0 Mux Selection Register - EMACIO18
11122  *
11123  * This register is used to control the peripherals connected to emac1_rx_d0
11124  *
11125  * Only reset by a cold reset (ignores warm reset).
11126  *
11127  * NOTE: These registers should not be modified after IO configuration.There is no
11128  * support for dynamically changing the Pin Mux selections.
11129  *
11130  * Register Layout
11131  *
11132  * Bits | Access | Reset | Description
11133  * :-------|:-------|:------|:--------------------------------
11134  * [1:0] | RW | 0x0 | emac1_rx_d0 Mux Selection Field
11135  * [31:2] | ??? | 0x0 | *UNDEFINED*
11136  *
11137  */
11138 /*
11139  * Field : emac1_rx_d0 Mux Selection Field - sel
11140  *
11141  * Select peripheral signals connected emac1_rx_d0.
11142  *
11143  * 0 : Pin is connected to GPIO/LoanIO number 52.
11144  *
11145  * 1 : Pin is connected to Peripheral signal not applicable.
11146  *
11147  * 2 : Pin is connected to Peripheral signal not applicable.
11148  *
11149  * 3 : Pin is connected to Peripheral signal RGMII1.RXD0.
11150  *
11151  * Field Access Macros:
11152  *
11153  */
11154 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
11155 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_LSB 0
11156 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
11157 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_MSB 1
11158 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
11159 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_WIDTH 2
11160 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field value. */
11161 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_SET_MSK 0x00000003
11162 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field value. */
11163 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_CLR_MSK 0xfffffffc
11164 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
11165 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_RESET 0x0
11166 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO18_SEL field value from a register. */
11167 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_GET(value) (((value) & 0x00000003) >> 0)
11168 /* Produces a ALT_SYSMGR_PINMUX_EMACIO18_SEL register field value suitable for setting the register. */
11169 #define ALT_SYSMGR_PINMUX_EMACIO18_SEL_SET(value) (((value) << 0) & 0x00000003)
11170
11171 #ifndef __ASSEMBLY__
11172 /*
11173  * WARNING: The C register and register group struct declarations are provided for
11174  * convenience and illustrative purposes. They should, however, be used with
11175  * caution as the C language standard provides no guarantees about the alignment or
11176  * atomicity of device memory accesses. The recommended practice for writing
11177  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11178  * alt_write_word() functions.
11179  *
11180  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO18.
11181  */
11183 {
11184  uint32_t sel : 2; /* emac1_rx_d0 Mux Selection Field */
11185  uint32_t : 30; /* *UNDEFINED* */
11186 };
11187
11188 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO18. */
11189 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO18_s ALT_SYSMGR_PINMUX_EMACIO18_t;
11190 #endif /* __ASSEMBLY__ */
11191
11192 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO18 register from the beginning of the component. */
11193 #define ALT_SYSMGR_PINMUX_EMACIO18_OFST 0x48
11194
11195 /*
11196  * Register : emac1_rx_d1 Mux Selection Register - EMACIO19
11197  *
11198  * This register is used to control the peripherals connected to emac1_rx_d1
11199  *
11200  * Only reset by a cold reset (ignores warm reset).
11201  *
11202  * NOTE: These registers should not be modified after IO configuration.There is no
11203  * support for dynamically changing the Pin Mux selections.
11204  *
11205  * Register Layout
11206  *
11207  * Bits | Access | Reset | Description
11208  * :-------|:-------|:------|:--------------------------------
11209  * [1:0] | RW | 0x0 | emac1_rx_d1 Mux Selection Field
11210  * [31:2] | ??? | 0x0 | *UNDEFINED*
11211  *
11212  */
11213 /*
11214  * Field : emac1_rx_d1 Mux Selection Field - sel
11215  *
11216  * Select peripheral signals connected emac1_rx_d1.
11217  *
11218  * 0 : Pin is connected to GPIO/LoanIO number 53.
11219  *
11220  * 1 : Pin is connected to Peripheral signal not applicable.
11221  *
11222  * 2 : Pin is connected to Peripheral signal not applicable.
11223  *
11224  * 3 : Pin is connected to Peripheral signal RGMII1.RXD1.
11225  *
11226  * Field Access Macros:
11227  *
11228  */
11229 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
11230 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_LSB 0
11231 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
11232 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_MSB 1
11233 /* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
11234 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_WIDTH 2
11235 /* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field value. */
11236 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_SET_MSK 0x00000003
11237 /* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field value. */
11238 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_CLR_MSK 0xfffffffc
11239 /* The reset value of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
11240 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_RESET 0x0
11241 /* Extracts the ALT_SYSMGR_PINMUX_EMACIO19_SEL field value from a register. */
11242 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_GET(value) (((value) & 0x00000003) >> 0)
11243 /* Produces a ALT_SYSMGR_PINMUX_EMACIO19_SEL register field value suitable for setting the register. */
11244 #define ALT_SYSMGR_PINMUX_EMACIO19_SEL_SET(value) (((value) << 0) & 0x00000003)
11245
11246 #ifndef __ASSEMBLY__
11247 /*
11248  * WARNING: The C register and register group struct declarations are provided for
11249  * convenience and illustrative purposes. They should, however, be used with
11250  * caution as the C language standard provides no guarantees about the alignment or
11251  * atomicity of device memory accesses. The recommended practice for writing
11252  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11253  * alt_write_word() functions.
11254  *
11255  * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO19.
11256  */
11258 {
11259  uint32_t sel : 2; /* emac1_rx_d1 Mux Selection Field */
11260  uint32_t : 30; /* *UNDEFINED* */
11261 };
11262
11263 /* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO19. */
11264 typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO19_s ALT_SYSMGR_PINMUX_EMACIO19_t;
11265 #endif /* __ASSEMBLY__ */
11266
11267 /* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO19 register from the beginning of the component. */
11268 #define ALT_SYSMGR_PINMUX_EMACIO19_OFST 0x4c
11269
11270 /*
11271  * Register : sdmmc_cmd Mux Selection Register - FLASHIO0
11272  *
11273  * This register is used to control the peripherals connected to sdmmc_cmd
11274  *
11275  * Only reset by a cold reset (ignores warm reset).
11276  *
11277  * NOTE: These registers should not be modified after IO configuration.There is no
11278  * support for dynamically changing the Pin Mux selections.
11279  *
11280  * Register Layout
11281  *
11282  * Bits | Access | Reset | Description
11283  * :-------|:-------|:------|:------------------------------
11284  * [1:0] | RW | 0x0 | sdmmc_cmd Mux Selection Field
11285  * [31:2] | ??? | 0x0 | *UNDEFINED*
11286  *
11287  */
11288 /*
11289  * Field : sdmmc_cmd Mux Selection Field - sel
11290  *
11291  * Select peripheral signals connected sdmmc_cmd.
11292  *
11293  * 0 : Pin is connected to GPIO/LoanIO number 36.
11294  *
11295  * 1 : Pin is connected to Peripheral signal not applicable.
11296  *
11297  * 2 : Pin is connected to Peripheral signal USB0.D0.
11298  *
11299  * 3 : Pin is connected to Peripheral signal SDMMC.CMD.
11300  *
11301  * Field Access Macros:
11302  *
11303  */
11304 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
11305 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_LSB 0
11306 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
11307 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_MSB 1
11308 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
11309 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_WIDTH 2
11310 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field value. */
11311 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_SET_MSK 0x00000003
11312 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field value. */
11313 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_CLR_MSK 0xfffffffc
11314 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
11315 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_RESET 0x0
11316 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO0_SEL field value from a register. */
11317 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
11318 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field value suitable for setting the register. */
11319 #define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_SET(value) (((value) << 0) & 0x00000003)
11320
11321 #ifndef __ASSEMBLY__
11322 /*
11323  * WARNING: The C register and register group struct declarations are provided for
11324  * convenience and illustrative purposes. They should, however, be used with
11325  * caution as the C language standard provides no guarantees about the alignment or
11326  * atomicity of device memory accesses. The recommended practice for writing
11327  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11328  * alt_write_word() functions.
11329  *
11330  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO0.
11331  */
11333 {
11334  uint32_t sel : 2; /* sdmmc_cmd Mux Selection Field */
11335  uint32_t : 30; /* *UNDEFINED* */
11336 };
11337
11338 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO0. */
11339 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO0_s ALT_SYSMGR_PINMUX_FLSHIO0_t;
11340 #endif /* __ASSEMBLY__ */
11341
11342 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO0 register from the beginning of the component. */
11343 #define ALT_SYSMGR_PINMUX_FLSHIO0_OFST 0x50
11344
11345 /*
11346  * Register : sdmmc_pwren Mux Selection Register - FLASHIO1
11347  *
11348  * This register is used to control the peripherals connected to sdmmc_pwren
11349  *
11350  * Only reset by a cold reset (ignores warm reset).
11351  *
11352  * NOTE: These registers should not be modified after IO configuration.There is no
11353  * support for dynamically changing the Pin Mux selections.
11354  *
11355  * Register Layout
11356  *
11357  * Bits | Access | Reset | Description
11358  * :-------|:-------|:------|:--------------------------------
11359  * [1:0] | RW | 0x0 | sdmmc_pwren Mux Selection Field
11360  * [31:2] | ??? | 0x0 | *UNDEFINED*
11361  *
11362  */
11363 /*
11364  * Field : sdmmc_pwren Mux Selection Field - sel
11365  *
11366  * Select peripheral signals connected sdmmc_pwren.
11367  *
11368  * 0 : Pin is connected to GPIO/LoanIO number 37.
11369  *
11370  * 1 : Pin is connected to Peripheral signal not applicable.
11371  *
11372  * 2 : Pin is connected to Peripheral signal USB0.D1.
11373  *
11374  * 3 : Pin is connected to Peripheral signal SDMMC.PWREN.
11375  *
11376  * Field Access Macros:
11377  *
11378  */
11379 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
11380 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_LSB 0
11381 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
11382 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_MSB 1
11383 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
11384 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_WIDTH 2
11385 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field value. */
11386 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_SET_MSK 0x00000003
11387 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field value. */
11388 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_CLR_MSK 0xfffffffc
11389 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
11390 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_RESET 0x0
11391 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO1_SEL field value from a register. */
11392 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
11393 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field value suitable for setting the register. */
11394 #define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_SET(value) (((value) << 0) & 0x00000003)
11395
11396 #ifndef __ASSEMBLY__
11397 /*
11398  * WARNING: The C register and register group struct declarations are provided for
11399  * convenience and illustrative purposes. They should, however, be used with
11400  * caution as the C language standard provides no guarantees about the alignment or
11401  * atomicity of device memory accesses. The recommended practice for writing
11402  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11403  * alt_write_word() functions.
11404  *
11405  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO1.
11406  */
11408 {
11409  uint32_t sel : 2; /* sdmmc_pwren Mux Selection Field */
11410  uint32_t : 30; /* *UNDEFINED* */
11411 };
11412
11413 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO1. */
11414 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO1_s ALT_SYSMGR_PINMUX_FLSHIO1_t;
11415 #endif /* __ASSEMBLY__ */
11416
11417 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO1 register from the beginning of the component. */
11418 #define ALT_SYSMGR_PINMUX_FLSHIO1_OFST 0x54
11419
11420 /*
11421  * Register : sdmmc_d0 Mux Selection Register - FLASHIO2
11422  *
11423  * This register is used to control the peripherals connected to sdmmc_d0
11424  *
11425  * Only reset by a cold reset (ignores warm reset).
11426  *
11427  * NOTE: These registers should not be modified after IO configuration.There is no
11428  * support for dynamically changing the Pin Mux selections.
11429  *
11430  * Register Layout
11431  *
11432  * Bits | Access | Reset | Description
11433  * :-------|:-------|:------|:-----------------------------
11434  * [1:0] | RW | 0x0 | sdmmc_d0 Mux Selection Field
11435  * [31:2] | ??? | 0x0 | *UNDEFINED*
11436  *
11437  */
11438 /*
11439  * Field : sdmmc_d0 Mux Selection Field - sel
11440  *
11441  * Select peripheral signals connected sdmmc_d0.
11442  *
11443  * 0 : Pin is connected to GPIO/LoanIO number 38.
11444  *
11445  * 1 : Pin is connected to Peripheral signal not applicable.
11446  *
11447  * 2 : Pin is connected to Peripheral signal USB0.D2.
11448  *
11449  * 3 : Pin is connected to Peripheral signal SDMMC.D0.
11450  *
11451  * Field Access Macros:
11452  *
11453  */
11454 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
11455 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_LSB 0
11456 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
11457 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_MSB 1
11458 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
11459 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_WIDTH 2
11460 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field value. */
11461 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_SET_MSK 0x00000003
11462 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field value. */
11463 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_CLR_MSK 0xfffffffc
11464 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
11465 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_RESET 0x0
11466 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO2_SEL field value from a register. */
11467 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
11468 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field value suitable for setting the register. */
11469 #define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_SET(value) (((value) << 0) & 0x00000003)
11470
11471 #ifndef __ASSEMBLY__
11472 /*
11473  * WARNING: The C register and register group struct declarations are provided for
11474  * convenience and illustrative purposes. They should, however, be used with
11475  * caution as the C language standard provides no guarantees about the alignment or
11476  * atomicity of device memory accesses. The recommended practice for writing
11477  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11478  * alt_write_word() functions.
11479  *
11480  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO2.
11481  */
11483 {
11484  uint32_t sel : 2; /* sdmmc_d0 Mux Selection Field */
11485  uint32_t : 30; /* *UNDEFINED* */
11486 };
11487
11488 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO2. */
11489 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO2_s ALT_SYSMGR_PINMUX_FLSHIO2_t;
11490 #endif /* __ASSEMBLY__ */
11491
11492 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO2 register from the beginning of the component. */
11493 #define ALT_SYSMGR_PINMUX_FLSHIO2_OFST 0x58
11494
11495 /*
11496  * Register : sdmmc_d1 Mux Selection Register - FLASHIO3
11497  *
11498  * This register is used to control the peripherals connected to sdmmc_d1
11499  *
11500  * Only reset by a cold reset (ignores warm reset).
11501  *
11502  * NOTE: These registers should not be modified after IO configuration.There is no
11503  * support for dynamically changing the Pin Mux selections.
11504  *
11505  * Register Layout
11506  *
11507  * Bits | Access | Reset | Description
11508  * :-------|:-------|:------|:-----------------------------
11509  * [1:0] | RW | 0x0 | sdmmc_d1 Mux Selection Field
11510  * [31:2] | ??? | 0x0 | *UNDEFINED*
11511  *
11512  */
11513 /*
11514  * Field : sdmmc_d1 Mux Selection Field - sel
11515  *
11516  * Select peripheral signals connected sdmmc_d1.
11517  *
11518  * 0 : Pin is connected to GPIO/LoanIO number 39.
11519  *
11520  * 1 : Pin is connected to Peripheral signal not applicable.
11521  *
11522  * 2 : Pin is connected to Peripheral signal USB0.D3.
11523  *
11524  * 3 : Pin is connected to Peripheral signal SDMMC.D1.
11525  *
11526  * Field Access Macros:
11527  *
11528  */
11529 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
11530 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_LSB 0
11531 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
11532 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_MSB 1
11533 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
11534 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_WIDTH 2
11535 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field value. */
11536 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_SET_MSK 0x00000003
11537 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field value. */
11538 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_CLR_MSK 0xfffffffc
11539 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
11540 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_RESET 0x0
11541 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO3_SEL field value from a register. */
11542 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
11543 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field value suitable for setting the register. */
11544 #define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_SET(value) (((value) << 0) & 0x00000003)
11545
11546 #ifndef __ASSEMBLY__
11547 /*
11548  * WARNING: The C register and register group struct declarations are provided for
11549  * convenience and illustrative purposes. They should, however, be used with
11550  * caution as the C language standard provides no guarantees about the alignment or
11551  * atomicity of device memory accesses. The recommended practice for writing
11552  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11553  * alt_write_word() functions.
11554  *
11555  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO3.
11556  */
11558 {
11559  uint32_t sel : 2; /* sdmmc_d1 Mux Selection Field */
11560  uint32_t : 30; /* *UNDEFINED* */
11561 };
11562
11563 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO3. */
11564 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO3_s ALT_SYSMGR_PINMUX_FLSHIO3_t;
11565 #endif /* __ASSEMBLY__ */
11566
11567 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO3 register from the beginning of the component. */
11568 #define ALT_SYSMGR_PINMUX_FLSHIO3_OFST 0x5c
11569
11570 /*
11571  * Register : sdmmc_d4 Mux Selection Register - FLASHIO4
11572  *
11573  * This register is used to control the peripherals connected to sdmmc_d4
11574  *
11575  * Only reset by a cold reset (ignores warm reset).
11576  *
11577  * NOTE: These registers should not be modified after IO configuration.There is no
11578  * support for dynamically changing the Pin Mux selections.
11579  *
11580  * Register Layout
11581  *
11582  * Bits | Access | Reset | Description
11583  * :-------|:-------|:------|:-----------------------------
11584  * [1:0] | RW | 0x0 | sdmmc_d4 Mux Selection Field
11585  * [31:2] | ??? | 0x0 | *UNDEFINED*
11586  *
11587  */
11588 /*
11589  * Field : sdmmc_d4 Mux Selection Field - sel
11590  *
11591  * Select peripheral signals connected sdmmc_d4.
11592  *
11593  * 0 : Pin is connected to GPIO/LoanIO number 40.
11594  *
11595  * 1 : Pin is connected to Peripheral signal not applicable.
11596  *
11597  * 2 : Pin is connected to Peripheral signal USB0.D4.
11598  *
11599  * 3 : Pin is connected to Peripheral signal SDMMC.D4.
11600  *
11601  * Field Access Macros:
11602  *
11603  */
11604 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
11605 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_LSB 0
11606 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
11607 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_MSB 1
11608 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
11609 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_WIDTH 2
11610 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field value. */
11611 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_SET_MSK 0x00000003
11612 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field value. */
11613 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_CLR_MSK 0xfffffffc
11614 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
11615 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_RESET 0x0
11616 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO4_SEL field value from a register. */
11617 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
11618 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field value suitable for setting the register. */
11619 #define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_SET(value) (((value) << 0) & 0x00000003)
11620
11621 #ifndef __ASSEMBLY__
11622 /*
11623  * WARNING: The C register and register group struct declarations are provided for
11624  * convenience and illustrative purposes. They should, however, be used with
11625  * caution as the C language standard provides no guarantees about the alignment or
11626  * atomicity of device memory accesses. The recommended practice for writing
11627  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11628  * alt_write_word() functions.
11629  *
11630  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO4.
11631  */
11633 {
11634  uint32_t sel : 2; /* sdmmc_d4 Mux Selection Field */
11635  uint32_t : 30; /* *UNDEFINED* */
11636 };
11637
11638 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO4. */
11639 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO4_s ALT_SYSMGR_PINMUX_FLSHIO4_t;
11640 #endif /* __ASSEMBLY__ */
11641
11642 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO4 register from the beginning of the component. */
11643 #define ALT_SYSMGR_PINMUX_FLSHIO4_OFST 0x60
11644
11645 /*
11646  * Register : sdmmc_d5 Mux Selection Register - FLASHIO5
11647  *
11648  * This register is used to control the peripherals connected to sdmmc_d5
11649  *
11650  * Only reset by a cold reset (ignores warm reset).
11651  *
11652  * NOTE: These registers should not be modified after IO configuration.There is no
11653  * support for dynamically changing the Pin Mux selections.
11654  *
11655  * Register Layout
11656  *
11657  * Bits | Access | Reset | Description
11658  * :-------|:-------|:------|:-----------------------------
11659  * [1:0] | RW | 0x0 | sdmmc_d5 Mux Selection Field
11660  * [31:2] | ??? | 0x0 | *UNDEFINED*
11661  *
11662  */
11663 /*
11664  * Field : sdmmc_d5 Mux Selection Field - sel
11665  *
11666  * Select peripheral signals connected sdmmc_d5.
11667  *
11668  * 0 : Pin is connected to GPIO/LoanIO number 41.
11669  *
11670  * 1 : Pin is connected to Peripheral signal not applicable.
11671  *
11672  * 2 : Pin is connected to Peripheral signal USB0.D5.
11673  *
11674  * 3 : Pin is connected to Peripheral signal SDMMC.D5.
11675  *
11676  * Field Access Macros:
11677  *
11678  */
11679 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
11680 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_LSB 0
11681 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
11682 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_MSB 1
11683 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
11684 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_WIDTH 2
11685 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field value. */
11686 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_SET_MSK 0x00000003
11687 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field value. */
11688 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_CLR_MSK 0xfffffffc
11689 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
11690 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_RESET 0x0
11691 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO5_SEL field value from a register. */
11692 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
11693 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field value suitable for setting the register. */
11694 #define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_SET(value) (((value) << 0) & 0x00000003)
11695
11696 #ifndef __ASSEMBLY__
11697 /*
11698  * WARNING: The C register and register group struct declarations are provided for
11699  * convenience and illustrative purposes. They should, however, be used with
11700  * caution as the C language standard provides no guarantees about the alignment or
11701  * atomicity of device memory accesses. The recommended practice for writing
11702  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11703  * alt_write_word() functions.
11704  *
11705  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO5.
11706  */
11708 {
11709  uint32_t sel : 2; /* sdmmc_d5 Mux Selection Field */
11710  uint32_t : 30; /* *UNDEFINED* */
11711 };
11712
11713 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO5. */
11714 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO5_s ALT_SYSMGR_PINMUX_FLSHIO5_t;
11715 #endif /* __ASSEMBLY__ */
11716
11717 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO5 register from the beginning of the component. */
11718 #define ALT_SYSMGR_PINMUX_FLSHIO5_OFST 0x64
11719
11720 /*
11721  * Register : sdmmc_d6 Mux Selection Register - FLASHIO6
11722  *
11723  * This register is used to control the peripherals connected to sdmmc_d6
11724  *
11725  * Only reset by a cold reset (ignores warm reset).
11726  *
11727  * NOTE: These registers should not be modified after IO configuration.There is no
11728  * support for dynamically changing the Pin Mux selections.
11729  *
11730  * Register Layout
11731  *
11732  * Bits | Access | Reset | Description
11733  * :-------|:-------|:------|:-----------------------------
11734  * [1:0] | RW | 0x0 | sdmmc_d6 Mux Selection Field
11735  * [31:2] | ??? | 0x0 | *UNDEFINED*
11736  *
11737  */
11738 /*
11739  * Field : sdmmc_d6 Mux Selection Field - sel
11740  *
11741  * Select peripheral signals connected sdmmc_d6.
11742  *
11743  * 0 : Pin is connected to GPIO/LoanIO number 42.
11744  *
11745  * 1 : Pin is connected to Peripheral signal not applicable.
11746  *
11747  * 2 : Pin is connected to Peripheral signal USB0.D6.
11748  *
11749  * 3 : Pin is connected to Peripheral signal SDMMC.D6.
11750  *
11751  * Field Access Macros:
11752  *
11753  */
11754 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
11755 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_LSB 0
11756 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
11757 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_MSB 1
11758 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
11759 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_WIDTH 2
11760 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field value. */
11761 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_SET_MSK 0x00000003
11762 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field value. */
11763 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_CLR_MSK 0xfffffffc
11764 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
11765 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_RESET 0x0
11766 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO6_SEL field value from a register. */
11767 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
11768 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field value suitable for setting the register. */
11769 #define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_SET(value) (((value) << 0) & 0x00000003)
11770
11771 #ifndef __ASSEMBLY__
11772 /*
11773  * WARNING: The C register and register group struct declarations are provided for
11774  * convenience and illustrative purposes. They should, however, be used with
11775  * caution as the C language standard provides no guarantees about the alignment or
11776  * atomicity of device memory accesses. The recommended practice for writing
11777  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11778  * alt_write_word() functions.
11779  *
11780  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO6.
11781  */
11783 {
11784  uint32_t sel : 2; /* sdmmc_d6 Mux Selection Field */
11785  uint32_t : 30; /* *UNDEFINED* */
11786 };
11787
11788 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO6. */
11789 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO6_s ALT_SYSMGR_PINMUX_FLSHIO6_t;
11790 #endif /* __ASSEMBLY__ */
11791
11792 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO6 register from the beginning of the component. */
11793 #define ALT_SYSMGR_PINMUX_FLSHIO6_OFST 0x68
11794
11795 /*
11796  * Register : sdmmc_d7 Mux Selection Register - FLASHIO7
11797  *
11798  * This register is used to control the peripherals connected to sdmmc_d7
11799  *
11800  * Only reset by a cold reset (ignores warm reset).
11801  *
11802  * NOTE: These registers should not be modified after IO configuration.There is no
11803  * support for dynamically changing the Pin Mux selections.
11804  *
11805  * Register Layout
11806  *
11807  * Bits | Access | Reset | Description
11808  * :-------|:-------|:------|:-----------------------------
11809  * [1:0] | RW | 0x0 | sdmmc_d7 Mux Selection Field
11810  * [31:2] | ??? | 0x0 | *UNDEFINED*
11811  *
11812  */
11813 /*
11814  * Field : sdmmc_d7 Mux Selection Field - sel
11815  *
11816  * Select peripheral signals connected sdmmc_d7.
11817  *
11818  * 0 : Pin is connected to GPIO/LoanIO number 43.
11819  *
11820  * 1 : Pin is connected to Peripheral signal not applicable.
11821  *
11822  * 2 : Pin is connected to Peripheral signal USB0.D7.
11823  *
11824  * 3 : Pin is connected to Peripheral signal SDMMC.D7.
11825  *
11826  * Field Access Macros:
11827  *
11828  */
11829 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
11830 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_LSB 0
11831 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
11832 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_MSB 1
11833 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
11834 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_WIDTH 2
11835 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field value. */
11836 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_SET_MSK 0x00000003
11837 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field value. */
11838 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_CLR_MSK 0xfffffffc
11839 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
11840 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_RESET 0x0
11841 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO7_SEL field value from a register. */
11842 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
11843 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field value suitable for setting the register. */
11844 #define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_SET(value) (((value) << 0) & 0x00000003)
11845
11846 #ifndef __ASSEMBLY__
11847 /*
11848  * WARNING: The C register and register group struct declarations are provided for
11849  * convenience and illustrative purposes. They should, however, be used with
11850  * caution as the C language standard provides no guarantees about the alignment or
11851  * atomicity of device memory accesses. The recommended practice for writing
11852  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11853  * alt_write_word() functions.
11854  *
11855  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO7.
11856  */
11858 {
11859  uint32_t sel : 2; /* sdmmc_d7 Mux Selection Field */
11860  uint32_t : 30; /* *UNDEFINED* */
11861 };
11862
11863 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO7. */
11864 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO7_s ALT_SYSMGR_PINMUX_FLSHIO7_t;
11865 #endif /* __ASSEMBLY__ */
11866
11867 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO7 register from the beginning of the component. */
11868 #define ALT_SYSMGR_PINMUX_FLSHIO7_OFST 0x6c
11869
11870 /*
11871  * Register : sdmmc_clk_in Mux Selection Register - FLASHIO8
11872  *
11873  * This register is used to control the peripherals connected to sdmmc_clk_in
11874  *
11875  * Only reset by a cold reset (ignores warm reset).
11876  *
11877  * NOTE: These registers should not be modified after IO configuration.There is no
11878  * support for dynamically changing the Pin Mux selections.
11879  *
11880  * Register Layout
11881  *
11882  * Bits | Access | Reset | Description
11883  * :-------|:-------|:------|:---------------------------------
11884  * [1:0] | RW | 0x0 | sdmmc_clk_in Mux Selection Field
11885  * [31:2] | ??? | 0x0 | *UNDEFINED*
11886  *
11887  */
11888 /*
11889  * Field : sdmmc_clk_in Mux Selection Field - sel
11890  *
11891  * Select peripheral signals connected sdmmc_clk_in.
11892  *
11893  * 0 : Pin is connected to GPIO/LoanIO number 44.
11894  *
11895  * 1 : Pin is connected to Peripheral signal not applicable.
11896  *
11897  * 2 : Pin is connected to Peripheral signal USB0.CLK.
11898  *
11899  * 3 : Pin is connected to Peripheral signal SDMMC.CLK_IN.
11900  *
11901  * Field Access Macros:
11902  *
11903  */
11904 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
11905 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_LSB 0
11906 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
11907 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_MSB 1
11908 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
11909 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_WIDTH 2
11910 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field value. */
11911 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_SET_MSK 0x00000003
11912 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field value. */
11913 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_CLR_MSK 0xfffffffc
11914 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
11915 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_RESET 0x0
11916 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO8_SEL field value from a register. */
11917 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
11918 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field value suitable for setting the register. */
11919 #define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_SET(value) (((value) << 0) & 0x00000003)
11920
11921 #ifndef __ASSEMBLY__
11922 /*
11923  * WARNING: The C register and register group struct declarations are provided for
11924  * convenience and illustrative purposes. They should, however, be used with
11925  * caution as the C language standard provides no guarantees about the alignment or
11926  * atomicity of device memory accesses. The recommended practice for writing
11927  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
11928  * alt_write_word() functions.
11929  *
11930  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO8.
11931  */
11933 {
11934  uint32_t sel : 2; /* sdmmc_clk_in Mux Selection Field */
11935  uint32_t : 30; /* *UNDEFINED* */
11936 };
11937
11938 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO8. */
11939 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO8_s ALT_SYSMGR_PINMUX_FLSHIO8_t;
11940 #endif /* __ASSEMBLY__ */
11941
11942 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO8 register from the beginning of the component. */
11943 #define ALT_SYSMGR_PINMUX_FLSHIO8_OFST 0x70
11944
11945 /*
11946  * Register : sdmmc_clk Mux Selection Register - FLASHIO9
11947  *
11948  * This register is used to control the peripherals connected to sdmmc_clk
11949  *
11950  * Only reset by a cold reset (ignores warm reset).
11951  *
11952  * NOTE: These registers should not be modified after IO configuration.There is no
11953  * support for dynamically changing the Pin Mux selections.
11954  *
11955  * Register Layout
11956  *
11957  * Bits | Access | Reset | Description
11958  * :-------|:-------|:------|:------------------------------
11959  * [1:0] | RW | 0x0 | sdmmc_clk Mux Selection Field
11960  * [31:2] | ??? | 0x0 | *UNDEFINED*
11961  *
11962  */
11963 /*
11964  * Field : sdmmc_clk Mux Selection Field - sel
11965  *
11966  * Select peripheral signals connected sdmmc_clk.
11967  *
11968  * 0 : Pin is connected to GPIO/LoanIO number 45.
11969  *
11970  * 1 : Pin is connected to Peripheral signal not applicable.
11971  *
11972  * 2 : Pin is connected to Peripheral signal USB0.STP.
11973  *
11974  * 3 : Pin is connected to Peripheral signal SDMMC.CLK.
11975  *
11976  * Field Access Macros:
11977  *
11978  */
11979 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
11980 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_LSB 0
11981 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
11982 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_MSB 1
11983 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
11984 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_WIDTH 2
11985 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field value. */
11986 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_SET_MSK 0x00000003
11987 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field value. */
11988 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_CLR_MSK 0xfffffffc
11989 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
11990 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_RESET 0x0
11991 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO9_SEL field value from a register. */
11992 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
11993 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field value suitable for setting the register. */
11994 #define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_SET(value) (((value) << 0) & 0x00000003)
11995
11996 #ifndef __ASSEMBLY__
11997 /*
11998  * WARNING: The C register and register group struct declarations are provided for
11999  * convenience and illustrative purposes. They should, however, be used with
12000  * caution as the C language standard provides no guarantees about the alignment or
12001  * atomicity of device memory accesses. The recommended practice for writing
12002  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12003  * alt_write_word() functions.
12004  *
12005  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO9.
12006  */
12008 {
12009  uint32_t sel : 2; /* sdmmc_clk Mux Selection Field */
12010  uint32_t : 30; /* *UNDEFINED* */
12011 };
12012
12013 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO9. */
12014 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO9_s ALT_SYSMGR_PINMUX_FLSHIO9_t;
12015 #endif /* __ASSEMBLY__ */
12016
12017 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO9 register from the beginning of the component. */
12018 #define ALT_SYSMGR_PINMUX_FLSHIO9_OFST 0x74
12019
12020 /*
12021  * Register : sdmmc_d2 Mux Selection Register - FLASHIO10
12022  *
12023  * This register is used to control the peripherals connected to sdmmc_d2
12024  *
12025  * Only reset by a cold reset (ignores warm reset).
12026  *
12027  * NOTE: These registers should not be modified after IO configuration.There is no
12028  * support for dynamically changing the Pin Mux selections.
12029  *
12030  * Register Layout
12031  *
12032  * Bits | Access | Reset | Description
12033  * :-------|:-------|:------|:-----------------------------
12034  * [1:0] | RW | 0x0 | sdmmc_d2 Mux Selection Field
12035  * [31:2] | ??? | 0x0 | *UNDEFINED*
12036  *
12037  */
12038 /*
12039  * Field : sdmmc_d2 Mux Selection Field - sel
12040  *
12041  * Select peripheral signals connected sdmmc_d2.
12042  *
12043  * 0 : Pin is connected to GPIO/LoanIO number 46.
12044  *
12045  * 1 : Pin is connected to Peripheral signal not applicable.
12046  *
12047  * 2 : Pin is connected to Peripheral signal USB0.DIR.
12048  *
12049  * 3 : Pin is connected to Peripheral signal SDMMC.D2.
12050  *
12051  * Field Access Macros:
12052  *
12053  */
12054 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
12055 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_LSB 0
12056 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
12057 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_MSB 1
12058 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
12059 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_WIDTH 2
12060 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field value. */
12061 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_SET_MSK 0x00000003
12062 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field value. */
12063 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_CLR_MSK 0xfffffffc
12064 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
12065 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_RESET 0x0
12066 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO10_SEL field value from a register. */
12067 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_GET(value) (((value) & 0x00000003) >> 0)
12068 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field value suitable for setting the register. */
12069 #define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_SET(value) (((value) << 0) & 0x00000003)
12070
12071 #ifndef __ASSEMBLY__
12072 /*
12073  * WARNING: The C register and register group struct declarations are provided for
12074  * convenience and illustrative purposes. They should, however, be used with
12075  * caution as the C language standard provides no guarantees about the alignment or
12076  * atomicity of device memory accesses. The recommended practice for writing
12077  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12078  * alt_write_word() functions.
12079  *
12080  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO10.
12081  */
12083 {
12084  uint32_t sel : 2; /* sdmmc_d2 Mux Selection Field */
12085  uint32_t : 30; /* *UNDEFINED* */
12086 };
12087
12088 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO10. */
12089 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO10_s ALT_SYSMGR_PINMUX_FLSHIO10_t;
12090 #endif /* __ASSEMBLY__ */
12091
12092 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO10 register from the beginning of the component. */
12093 #define ALT_SYSMGR_PINMUX_FLSHIO10_OFST 0x78
12094
12095 /*
12096  * Register : sdmmc_d3 Mux Selection Register - FLASHIO11
12097  *
12098  * This register is used to control the peripherals connected to sdmmc_d3
12099  *
12100  * Only reset by a cold reset (ignores warm reset).
12101  *
12102  * NOTE: These registers should not be modified after IO configuration.There is no
12103  * support for dynamically changing the Pin Mux selections.
12104  *
12105  * Register Layout
12106  *
12107  * Bits | Access | Reset | Description
12108  * :-------|:-------|:------|:-----------------------------
12109  * [1:0] | RW | 0x0 | sdmmc_d3 Mux Selection Field
12110  * [31:2] | ??? | 0x0 | *UNDEFINED*
12111  *
12112  */
12113 /*
12114  * Field : sdmmc_d3 Mux Selection Field - sel
12115  *
12116  * Select peripheral signals connected sdmmc_d3.
12117  *
12118  * 0 : Pin is connected to GPIO/LoanIO number 47.
12119  *
12120  * 1 : Pin is connected to Peripheral signal not applicable.
12121  *
12122  * 2 : Pin is connected to Peripheral signal USB0.NXT.
12123  *
12124  * 3 : Pin is connected to Peripheral signal SDMMC.D3.
12125  *
12126  * Field Access Macros:
12127  *
12128  */
12129 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
12130 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_LSB 0
12131 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
12132 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_MSB 1
12133 /* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
12134 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_WIDTH 2
12135 /* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field value. */
12136 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_SET_MSK 0x00000003
12137 /* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field value. */
12138 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_CLR_MSK 0xfffffffc
12139 /* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
12140 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_RESET 0x0
12141 /* Extracts the ALT_SYSMGR_PINMUX_FLSHIO11_SEL field value from a register. */
12142 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_GET(value) (((value) & 0x00000003) >> 0)
12143 /* Produces a ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field value suitable for setting the register. */
12144 #define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_SET(value) (((value) << 0) & 0x00000003)
12145
12146 #ifndef __ASSEMBLY__
12147 /*
12148  * WARNING: The C register and register group struct declarations are provided for
12149  * convenience and illustrative purposes. They should, however, be used with
12150  * caution as the C language standard provides no guarantees about the alignment or
12151  * atomicity of device memory accesses. The recommended practice for writing
12152  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12153  * alt_write_word() functions.
12154  *
12155  * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO11.
12156  */
12158 {
12159  uint32_t sel : 2; /* sdmmc_d3 Mux Selection Field */
12160  uint32_t : 30; /* *UNDEFINED* */
12161 };
12162
12163 /* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO11. */
12164 typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO11_s ALT_SYSMGR_PINMUX_FLSHIO11_t;
12165 #endif /* __ASSEMBLY__ */
12166
12167 /* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO11 register from the beginning of the component. */
12168 #define ALT_SYSMGR_PINMUX_FLSHIO11_OFST 0x7c
12169
12170 /*
12171  * Register : trace_clk Mux Selection Register - GENERALIO0
12172  *
12173  * This register is used to control the peripherals connected to trace_clk
12174  *
12175  * Only reset by a cold reset (ignores warm reset).
12176  *
12177  * NOTE: These registers should not be modified after IO configuration.There is no
12178  * support for dynamically changing the Pin Mux selections.
12179  *
12180  * Register Layout
12181  *
12182  * Bits | Access | Reset | Description
12183  * :-------|:-------|:------|:------------------------------
12184  * [1:0] | RW | 0x0 | trace_clk Mux Selection Field
12185  * [31:2] | ??? | 0x0 | *UNDEFINED*
12186  *
12187  */
12188 /*
12189  * Field : trace_clk Mux Selection Field - sel
12190  *
12191  * Select peripheral signals connected trace_clk.
12192  *
12193  * 0 : Pin is connected to GPIO/LoanIO number 48.
12194  *
12195  * 1 : Pin is connected to Peripheral signal not applicable.
12196  *
12197  * 2 : Pin is connected to Peripheral signal not applicable.
12198  *
12199  * 3 : Pin is connected to Peripheral signal TRACE.CLK.
12200  *
12201  * Field Access Macros:
12202  *
12203  */
12204 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
12205 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_LSB 0
12206 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
12207 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_MSB 1
12208 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
12209 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_WIDTH 2
12210 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field value. */
12211 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_SET_MSK 0x00000003
12212 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field value. */
12213 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_CLR_MSK 0xfffffffc
12214 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
12215 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_RESET 0x0
12216 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO0_SEL field value from a register. */
12217 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
12218 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field value suitable for setting the register. */
12219 #define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_SET(value) (((value) << 0) & 0x00000003)
12220
12221 #ifndef __ASSEMBLY__
12222 /*
12223  * WARNING: The C register and register group struct declarations are provided for
12224  * convenience and illustrative purposes. They should, however, be used with
12225  * caution as the C language standard provides no guarantees about the alignment or
12226  * atomicity of device memory accesses. The recommended practice for writing
12227  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12228  * alt_write_word() functions.
12229  *
12230  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO0.
12231  */
12233 {
12234  uint32_t sel : 2; /* trace_clk Mux Selection Field */
12235  uint32_t : 30; /* *UNDEFINED* */
12236 };
12237
12238 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO0. */
12239 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO0_s ALT_SYSMGR_PINMUX_GENERALIO0_t;
12240 #endif /* __ASSEMBLY__ */
12241
12242 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO0 register from the beginning of the component. */
12243 #define ALT_SYSMGR_PINMUX_GENERALIO0_OFST 0x80
12244
12245 /*
12246  * Register : trace_d0 Mux Selection Register - GENERALIO1
12247  *
12248  * This register is used to control the peripherals connected to trace_d0
12249  *
12250  * Only reset by a cold reset (ignores warm reset).
12251  *
12252  * NOTE: These registers should not be modified after IO configuration.There is no
12253  * support for dynamically changing the Pin Mux selections.
12254  *
12255  * Register Layout
12256  *
12257  * Bits | Access | Reset | Description
12258  * :-------|:-------|:------|:-----------------------------
12259  * [1:0] | RW | 0x0 | trace_d0 Mux Selection Field
12260  * [31:2] | ??? | 0x0 | *UNDEFINED*
12261  *
12262  */
12263 /*
12264  * Field : trace_d0 Mux Selection Field - sel
12265  *
12266  * Select peripheral signals connected trace_d0.
12267  *
12268  * 0 : Pin is connected to GPIO/LoanIO number 49.
12269  *
12270  * 1 : Pin is connected to Peripheral signal UART0.RX.
12271  *
12272  * 2 : Pin is connected to Peripheral signal SPIS0.CLK.
12273  *
12274  * 3 : Pin is connected to Peripheral signal TRACE.D0.
12275  *
12276  * Field Access Macros:
12277  *
12278  */
12279 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
12280 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_LSB 0
12281 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
12282 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_MSB 1
12283 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
12284 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_WIDTH 2
12285 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field value. */
12286 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_SET_MSK 0x00000003
12287 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field value. */
12288 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_CLR_MSK 0xfffffffc
12289 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
12290 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_RESET 0x0
12291 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO1_SEL field value from a register. */
12292 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
12293 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field value suitable for setting the register. */
12294 #define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_SET(value) (((value) << 0) & 0x00000003)
12295
12296 #ifndef __ASSEMBLY__
12297 /*
12298  * WARNING: The C register and register group struct declarations are provided for
12299  * convenience and illustrative purposes. They should, however, be used with
12300  * caution as the C language standard provides no guarantees about the alignment or
12301  * atomicity of device memory accesses. The recommended practice for writing
12302  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12303  * alt_write_word() functions.
12304  *
12305  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO1.
12306  */
12308 {
12309  uint32_t sel : 2; /* trace_d0 Mux Selection Field */
12310  uint32_t : 30; /* *UNDEFINED* */
12311 };
12312
12313 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO1. */
12314 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO1_s ALT_SYSMGR_PINMUX_GENERALIO1_t;
12315 #endif /* __ASSEMBLY__ */
12316
12317 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO1 register from the beginning of the component. */
12318 #define ALT_SYSMGR_PINMUX_GENERALIO1_OFST 0x84
12319
12320 /*
12321  * Register : trace_d1 Mux Selection Register - GENERALIO2
12322  *
12323  * This register is used to control the peripherals connected to trace_d1
12324  *
12325  * Only reset by a cold reset (ignores warm reset).
12326  *
12327  * NOTE: These registers should not be modified after IO configuration.There is no
12328  * support for dynamically changing the Pin Mux selections.
12329  *
12330  * Register Layout
12331  *
12332  * Bits | Access | Reset | Description
12333  * :-------|:-------|:------|:-----------------------------
12334  * [1:0] | RW | 0x0 | trace_d1 Mux Selection Field
12335  * [31:2] | ??? | 0x0 | *UNDEFINED*
12336  *
12337  */
12338 /*
12339  * Field : trace_d1 Mux Selection Field - sel
12340  *
12341  * Select peripheral signals connected trace_d1.
12342  *
12343  * 0 : Pin is connected to GPIO/LoanIO number 50.
12344  *
12345  * 1 : Pin is connected to Peripheral signal UART0.TX.
12346  *
12347  * 2 : Pin is connected to Peripheral signal SPIS0.MOSI.
12348  *
12349  * 3 : Pin is connected to Peripheral signal TRACE.D1.
12350  *
12351  * Field Access Macros:
12352  *
12353  */
12354 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
12355 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_LSB 0
12356 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
12357 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_MSB 1
12358 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
12359 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_WIDTH 2
12360 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field value. */
12361 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_SET_MSK 0x00000003
12362 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field value. */
12363 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_CLR_MSK 0xfffffffc
12364 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
12365 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_RESET 0x0
12366 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO2_SEL field value from a register. */
12367 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
12368 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field value suitable for setting the register. */
12369 #define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_SET(value) (((value) << 0) & 0x00000003)
12370
12371 #ifndef __ASSEMBLY__
12372 /*
12373  * WARNING: The C register and register group struct declarations are provided for
12374  * convenience and illustrative purposes. They should, however, be used with
12375  * caution as the C language standard provides no guarantees about the alignment or
12376  * atomicity of device memory accesses. The recommended practice for writing
12377  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12378  * alt_write_word() functions.
12379  *
12380  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO2.
12381  */
12383 {
12384  uint32_t sel : 2; /* trace_d1 Mux Selection Field */
12385  uint32_t : 30; /* *UNDEFINED* */
12386 };
12387
12388 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO2. */
12389 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO2_s ALT_SYSMGR_PINMUX_GENERALIO2_t;
12390 #endif /* __ASSEMBLY__ */
12391
12392 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO2 register from the beginning of the component. */
12393 #define ALT_SYSMGR_PINMUX_GENERALIO2_OFST 0x88
12394
12395 /*
12396  * Register : trace_d2 Mux Selection Register - GENERALIO3
12397  *
12398  * This register is used to control the peripherals connected to trace_d2
12399  *
12400  * Only reset by a cold reset (ignores warm reset).
12401  *
12402  * NOTE: These registers should not be modified after IO configuration.There is no
12403  * support for dynamically changing the Pin Mux selections.
12404  *
12405  * Register Layout
12406  *
12407  * Bits | Access | Reset | Description
12408  * :-------|:-------|:------|:-----------------------------
12409  * [1:0] | RW | 0x0 | trace_d2 Mux Selection Field
12410  * [31:2] | ??? | 0x0 | *UNDEFINED*
12411  *
12412  */
12413 /*
12414  * Field : trace_d2 Mux Selection Field - sel
12415  *
12416  * Select peripheral signals connected trace_d2.
12417  *
12418  * 0 : Pin is connected to GPIO/LoanIO number 51.
12419  *
12420  * 1 : Pin is connected to Peripheral signal I2C1.SDA.
12421  *
12422  * 2 : Pin is connected to Peripheral signal SPIS0.MISO.
12423  *
12424  * 3 : Pin is connected to Peripheral signal TRACE.D2.
12425  *
12426  * Field Access Macros:
12427  *
12428  */
12429 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
12430 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_LSB 0
12431 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
12432 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_MSB 1
12433 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
12434 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_WIDTH 2
12435 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field value. */
12436 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_SET_MSK 0x00000003
12437 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field value. */
12438 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_CLR_MSK 0xfffffffc
12439 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
12440 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_RESET 0x0
12441 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO3_SEL field value from a register. */
12442 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
12443 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field value suitable for setting the register. */
12444 #define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_SET(value) (((value) << 0) & 0x00000003)
12445
12446 #ifndef __ASSEMBLY__
12447 /*
12448  * WARNING: The C register and register group struct declarations are provided for
12449  * convenience and illustrative purposes. They should, however, be used with
12450  * caution as the C language standard provides no guarantees about the alignment or
12451  * atomicity of device memory accesses. The recommended practice for writing
12452  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12453  * alt_write_word() functions.
12454  *
12455  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO3.
12456  */
12458 {
12459  uint32_t sel : 2; /* trace_d2 Mux Selection Field */
12460  uint32_t : 30; /* *UNDEFINED* */
12461 };
12462
12463 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO3. */
12464 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO3_s ALT_SYSMGR_PINMUX_GENERALIO3_t;
12465 #endif /* __ASSEMBLY__ */
12466
12467 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO3 register from the beginning of the component. */
12468 #define ALT_SYSMGR_PINMUX_GENERALIO3_OFST 0x8c
12469
12470 /*
12471  * Register : trace_d3 Mux Selection Register - GENERALIO4
12472  *
12473  * This register is used to control the peripherals connected to trace_d3
12474  *
12475  * Only reset by a cold reset (ignores warm reset).
12476  *
12477  * NOTE: These registers should not be modified after IO configuration.There is no
12478  * support for dynamically changing the Pin Mux selections.
12479  *
12480  * Register Layout
12481  *
12482  * Bits | Access | Reset | Description
12483  * :-------|:-------|:------|:-----------------------------
12484  * [1:0] | RW | 0x0 | trace_d3 Mux Selection Field
12485  * [31:2] | ??? | 0x0 | *UNDEFINED*
12486  *
12487  */
12488 /*
12489  * Field : trace_d3 Mux Selection Field - sel
12490  *
12491  * Select peripheral signals connected trace_d3.
12492  *
12493  * 0 : Pin is connected to GPIO/LoanIO number 52.
12494  *
12495  * 1 : Pin is connected to Peripheral signal I2C1.SCL.
12496  *
12497  * 2 : Pin is connected to Peripheral signal SPIS0.SS0.
12498  *
12499  * 3 : Pin is connected to Peripheral signal TRACE.D3.
12500  *
12501  * Field Access Macros:
12502  *
12503  */
12504 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
12505 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_LSB 0
12506 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
12507 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_MSB 1
12508 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
12509 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_WIDTH 2
12510 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field value. */
12511 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_SET_MSK 0x00000003
12512 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field value. */
12513 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_CLR_MSK 0xfffffffc
12514 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
12515 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_RESET 0x0
12516 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO4_SEL field value from a register. */
12517 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
12518 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field value suitable for setting the register. */
12519 #define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_SET(value) (((value) << 0) & 0x00000003)
12520
12521 #ifndef __ASSEMBLY__
12522 /*
12523  * WARNING: The C register and register group struct declarations are provided for
12524  * convenience and illustrative purposes. They should, however, be used with
12525  * caution as the C language standard provides no guarantees about the alignment or
12526  * atomicity of device memory accesses. The recommended practice for writing
12527  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12528  * alt_write_word() functions.
12529  *
12530  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO4.
12531  */
12533 {
12534  uint32_t sel : 2; /* trace_d3 Mux Selection Field */
12535  uint32_t : 30; /* *UNDEFINED* */
12536 };
12537
12538 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO4. */
12539 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO4_s ALT_SYSMGR_PINMUX_GENERALIO4_t;
12540 #endif /* __ASSEMBLY__ */
12541
12542 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO4 register from the beginning of the component. */
12543 #define ALT_SYSMGR_PINMUX_GENERALIO4_OFST 0x90
12544
12545 /*
12546  * Register : trace_d4 Mux Selection Register - GENERALIO5
12547  *
12548  * This register is used to control the peripherals connected to trace_d4
12549  *
12550  * Only reset by a cold reset (ignores warm reset).
12551  *
12552  * NOTE: These registers should not be modified after IO configuration.There is no
12553  * support for dynamically changing the Pin Mux selections.
12554  *
12555  * Register Layout
12556  *
12557  * Bits | Access | Reset | Description
12558  * :-------|:-------|:------|:-----------------------------
12559  * [1:0] | RW | 0x0 | trace_d4 Mux Selection Field
12560  * [31:2] | ??? | 0x0 | *UNDEFINED*
12561  *
12562  */
12563 /*
12564  * Field : trace_d4 Mux Selection Field - sel
12565  *
12566  * Select peripheral signals connected trace_d4.
12567  *
12568  * 0 : Pin is connected to GPIO/LoanIO number 53.
12569  *
12570  * 1 : Pin is connected to Peripheral signal CAN1.RX.
12571  *
12572  * 2 : Pin is connected to Peripheral signal SPIS1.CLK.
12573  *
12574  * 3 : Pin is connected to Peripheral signal TRACE.D4.
12575  *
12576  * Field Access Macros:
12577  *
12578  */
12579 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
12580 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_LSB 0
12581 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
12582 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_MSB 1
12583 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
12584 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_WIDTH 2
12585 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field value. */
12586 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_SET_MSK 0x00000003
12587 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field value. */
12588 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_CLR_MSK 0xfffffffc
12589 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
12590 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_RESET 0x0
12591 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO5_SEL field value from a register. */
12592 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
12593 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field value suitable for setting the register. */
12594 #define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_SET(value) (((value) << 0) & 0x00000003)
12595
12596 #ifndef __ASSEMBLY__
12597 /*
12598  * WARNING: The C register and register group struct declarations are provided for
12599  * convenience and illustrative purposes. They should, however, be used with
12600  * caution as the C language standard provides no guarantees about the alignment or
12601  * atomicity of device memory accesses. The recommended practice for writing
12602  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12603  * alt_write_word() functions.
12604  *
12605  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO5.
12606  */
12608 {
12609  uint32_t sel : 2; /* trace_d4 Mux Selection Field */
12610  uint32_t : 30; /* *UNDEFINED* */
12611 };
12612
12613 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO5. */
12614 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO5_s ALT_SYSMGR_PINMUX_GENERALIO5_t;
12615 #endif /* __ASSEMBLY__ */
12616
12617 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO5 register from the beginning of the component. */
12618 #define ALT_SYSMGR_PINMUX_GENERALIO5_OFST 0x94
12619
12620 /*
12621  * Register : trace_d5 Mux Selection Register - GENERALIO6
12622  *
12623  * This register is used to control the peripherals connected to trace_d5
12624  *
12625  * Only reset by a cold reset (ignores warm reset).
12626  *
12627  * NOTE: These registers should not be modified after IO configuration.There is no
12628  * support for dynamically changing the Pin Mux selections.
12629  *
12630  * Register Layout
12631  *
12632  * Bits | Access | Reset | Description
12633  * :-------|:-------|:------|:-----------------------------
12634  * [1:0] | RW | 0x0 | trace_d5 Mux Selection Field
12635  * [31:2] | ??? | 0x0 | *UNDEFINED*
12636  *
12637  */
12638 /*
12639  * Field : trace_d5 Mux Selection Field - sel
12640  *
12641  * Select peripheral signals connected trace_d5.
12642  *
12643  * 0 : Pin is connected to GPIO/LoanIO number 54.
12644  *
12645  * 1 : Pin is connected to Peripheral signal CAN1.TX.
12646  *
12647  * 2 : Pin is connected to Peripheral signal SPIS1.MOSI.
12648  *
12649  * 3 : Pin is connected to Peripheral signal TRACE.D5.
12650  *
12651  * Field Access Macros:
12652  *
12653  */
12654 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
12655 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_LSB 0
12656 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
12657 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_MSB 1
12658 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
12659 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_WIDTH 2
12660 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field value. */
12661 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_SET_MSK 0x00000003
12662 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field value. */
12663 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_CLR_MSK 0xfffffffc
12664 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
12665 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_RESET 0x0
12666 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO6_SEL field value from a register. */
12667 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
12668 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field value suitable for setting the register. */
12669 #define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_SET(value) (((value) << 0) & 0x00000003)
12670
12671 #ifndef __ASSEMBLY__
12672 /*
12673  * WARNING: The C register and register group struct declarations are provided for
12674  * convenience and illustrative purposes. They should, however, be used with
12675  * caution as the C language standard provides no guarantees about the alignment or
12676  * atomicity of device memory accesses. The recommended practice for writing
12677  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12678  * alt_write_word() functions.
12679  *
12680  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO6.
12681  */
12683 {
12684  uint32_t sel : 2; /* trace_d5 Mux Selection Field */
12685  uint32_t : 30; /* *UNDEFINED* */
12686 };
12687
12688 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO6. */
12689 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO6_s ALT_SYSMGR_PINMUX_GENERALIO6_t;
12690 #endif /* __ASSEMBLY__ */
12691
12692 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO6 register from the beginning of the component. */
12693 #define ALT_SYSMGR_PINMUX_GENERALIO6_OFST 0x98
12694
12695 /*
12696  * Register : trace_d6 Mux Selection Register - GENERALIO7
12697  *
12698  * This register is used to control the peripherals connected to trace_d6
12699  *
12700  * Only reset by a cold reset (ignores warm reset).
12701  *
12702  * NOTE: These registers should not be modified after IO configuration.There is no
12703  * support for dynamically changing the Pin Mux selections.
12704  *
12705  * Register Layout
12706  *
12707  * Bits | Access | Reset | Description
12708  * :-------|:-------|:------|:-----------------------------
12709  * [1:0] | RW | 0x0 | trace_d6 Mux Selection Field
12710  * [31:2] | ??? | 0x0 | *UNDEFINED*
12711  *
12712  */
12713 /*
12714  * Field : trace_d6 Mux Selection Field - sel
12715  *
12716  * Select peripheral signals connected trace_d6.
12717  *
12718  * 0 : Pin is connected to GPIO/LoanIO number 55.
12719  *
12720  * 1 : Pin is connected to Peripheral signal I2C0.SDA.
12721  *
12722  * 2 : Pin is connected to Peripheral signal SPIS1.SS0.
12723  *
12724  * 3 : Pin is connected to Peripheral signal TRACE.D6.
12725  *
12726  * Field Access Macros:
12727  *
12728  */
12729 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
12730 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_LSB 0
12731 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
12732 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_MSB 1
12733 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
12734 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_WIDTH 2
12735 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field value. */
12736 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_SET_MSK 0x00000003
12737 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field value. */
12738 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_CLR_MSK 0xfffffffc
12739 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
12740 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_RESET 0x0
12741 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO7_SEL field value from a register. */
12742 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
12743 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field value suitable for setting the register. */
12744 #define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_SET(value) (((value) << 0) & 0x00000003)
12745
12746 #ifndef __ASSEMBLY__
12747 /*
12748  * WARNING: The C register and register group struct declarations are provided for
12749  * convenience and illustrative purposes. They should, however, be used with
12750  * caution as the C language standard provides no guarantees about the alignment or
12751  * atomicity of device memory accesses. The recommended practice for writing
12752  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12753  * alt_write_word() functions.
12754  *
12755  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO7.
12756  */
12758 {
12759  uint32_t sel : 2; /* trace_d6 Mux Selection Field */
12760  uint32_t : 30; /* *UNDEFINED* */
12761 };
12762
12763 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO7. */
12764 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO7_s ALT_SYSMGR_PINMUX_GENERALIO7_t;
12765 #endif /* __ASSEMBLY__ */
12766
12767 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO7 register from the beginning of the component. */
12768 #define ALT_SYSMGR_PINMUX_GENERALIO7_OFST 0x9c
12769
12770 /*
12771  * Register : trace_d7 Mux Selection Register - GENERALIO8
12772  *
12773  * This register is used to control the peripherals connected to trace_d7
12774  *
12775  * Only reset by a cold reset (ignores warm reset).
12776  *
12777  * NOTE: These registers should not be modified after IO configuration.There is no
12778  * support for dynamically changing the Pin Mux selections.
12779  *
12780  * Register Layout
12781  *
12782  * Bits | Access | Reset | Description
12783  * :-------|:-------|:------|:-----------------------------
12784  * [1:0] | RW | 0x0 | trace_d7 Mux Selection Field
12785  * [31:2] | ??? | 0x0 | *UNDEFINED*
12786  *
12787  */
12788 /*
12789  * Field : trace_d7 Mux Selection Field - sel
12790  *
12791  * Select peripheral signals connected trace_d7.
12792  *
12793  * 0 : Pin is connected to GPIO/LoanIO number 56.
12794  *
12795  * 1 : Pin is connected to Peripheral signal I2C0.SCL.
12796  *
12797  * 2 : Pin is connected to Peripheral signal SPIS1.MISO.
12798  *
12799  * 3 : Pin is connected to Peripheral signal TRACE.D7.
12800  *
12801  * Field Access Macros:
12802  *
12803  */
12804 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
12805 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_LSB 0
12806 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
12807 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_MSB 1
12808 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
12809 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_WIDTH 2
12810 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field value. */
12811 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_SET_MSK 0x00000003
12812 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field value. */
12813 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_CLR_MSK 0xfffffffc
12814 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
12815 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_RESET 0x0
12816 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO8_SEL field value from a register. */
12817 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
12818 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field value suitable for setting the register. */
12819 #define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_SET(value) (((value) << 0) & 0x00000003)
12820
12821 #ifndef __ASSEMBLY__
12822 /*
12823  * WARNING: The C register and register group struct declarations are provided for
12824  * convenience and illustrative purposes. They should, however, be used with
12825  * caution as the C language standard provides no guarantees about the alignment or
12826  * atomicity of device memory accesses. The recommended practice for writing
12827  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12828  * alt_write_word() functions.
12829  *
12830  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO8.
12831  */
12833 {
12834  uint32_t sel : 2; /* trace_d7 Mux Selection Field */
12835  uint32_t : 30; /* *UNDEFINED* */
12836 };
12837
12838 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO8. */
12839 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO8_s ALT_SYSMGR_PINMUX_GENERALIO8_t;
12840 #endif /* __ASSEMBLY__ */
12841
12842 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO8 register from the beginning of the component. */
12843 #define ALT_SYSMGR_PINMUX_GENERALIO8_OFST 0xa0
12844
12845 /*
12846  * Register : spim0_clk Mux Selection Register - GENERALIO9
12847  *
12848  * This register is used to control the peripherals connected to spim0_clk
12849  *
12850  * Only reset by a cold reset (ignores warm reset).
12851  *
12852  * NOTE: These registers should not be modified after IO configuration.There is no
12853  * support for dynamically changing the Pin Mux selections.
12854  *
12855  * Register Layout
12856  *
12857  * Bits | Access | Reset | Description
12858  * :-------|:-------|:------|:------------------------------
12859  * [1:0] | RW | 0x0 | spim0_clk Mux Selection Field
12860  * [31:2] | ??? | 0x0 | *UNDEFINED*
12861  *
12862  */
12863 /*
12864  * Field : spim0_clk Mux Selection Field - sel
12865  *
12866  * Select peripheral signals connected spim0_clk.
12867  *
12868  * 0 : Pin is connected to GPIO/LoanIO number 57.
12869  *
12870  * 1 : Pin is connected to Peripheral signal UART0.CTS.
12871  *
12872  * 2 : Pin is connected to Peripheral signal I2C1.SDA.
12873  *
12874  * 3 : Pin is connected to Peripheral signal SPIM0.CLK.
12875  *
12876  * Field Access Macros:
12877  *
12878  */
12879 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
12880 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_LSB 0
12881 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
12882 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_MSB 1
12883 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
12884 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_WIDTH 2
12885 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field value. */
12886 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_SET_MSK 0x00000003
12887 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field value. */
12888 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_CLR_MSK 0xfffffffc
12889 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
12890 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_RESET 0x0
12891 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO9_SEL field value from a register. */
12892 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
12893 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field value suitable for setting the register. */
12894 #define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_SET(value) (((value) << 0) & 0x00000003)
12895
12896 #ifndef __ASSEMBLY__
12897 /*
12898  * WARNING: The C register and register group struct declarations are provided for
12899  * convenience and illustrative purposes. They should, however, be used with
12900  * caution as the C language standard provides no guarantees about the alignment or
12901  * atomicity of device memory accesses. The recommended practice for writing
12902  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12903  * alt_write_word() functions.
12904  *
12905  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO9.
12906  */
12908 {
12909  uint32_t sel : 2; /* spim0_clk Mux Selection Field */
12910  uint32_t : 30; /* *UNDEFINED* */
12911 };
12912
12913 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO9. */
12914 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO9_s ALT_SYSMGR_PINMUX_GENERALIO9_t;
12915 #endif /* __ASSEMBLY__ */
12916
12917 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO9 register from the beginning of the component. */
12918 #define ALT_SYSMGR_PINMUX_GENERALIO9_OFST 0xa4
12919
12920 /*
12921  * Register : spim0_mosi Mux Selection Register - GENERALIO10
12922  *
12923  * This register is used to control the peripherals connected to spim0_mosi
12924  *
12925  * Only reset by a cold reset (ignores warm reset).
12926  *
12927  * NOTE: These registers should not be modified after IO configuration.There is no
12928  * support for dynamically changing the Pin Mux selections.
12929  *
12930  * Register Layout
12931  *
12932  * Bits | Access | Reset | Description
12933  * :-------|:-------|:------|:-------------------------------
12934  * [1:0] | RW | 0x0 | spim0_mosi Mux Selection Field
12935  * [31:2] | ??? | 0x0 | *UNDEFINED*
12936  *
12937  */
12938 /*
12939  * Field : spim0_mosi Mux Selection Field - sel
12940  *
12941  * Select peripheral signals connected spim0_mosi.
12942  *
12943  * 0 : Pin is connected to GPIO/LoanIO number 58.
12944  *
12945  * 1 : Pin is connected to Peripheral signal UART0.RTS.
12946  *
12947  * 2 : Pin is connected to Peripheral signal I2C1.SCL.
12948  *
12949  * 3 : Pin is connected to Peripheral signal SPIM0.MOSI.
12950  *
12951  * Field Access Macros:
12952  *
12953  */
12954 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
12955 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_LSB 0
12956 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
12957 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_MSB 1
12958 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
12959 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_WIDTH 2
12960 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field value. */
12961 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_SET_MSK 0x00000003
12962 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field value. */
12963 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_CLR_MSK 0xfffffffc
12964 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
12965 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_RESET 0x0
12966 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO10_SEL field value from a register. */
12967 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_GET(value) (((value) & 0x00000003) >> 0)
12968 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field value suitable for setting the register. */
12969 #define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_SET(value) (((value) << 0) & 0x00000003)
12970
12971 #ifndef __ASSEMBLY__
12972 /*
12973  * WARNING: The C register and register group struct declarations are provided for
12974  * convenience and illustrative purposes. They should, however, be used with
12975  * caution as the C language standard provides no guarantees about the alignment or
12976  * atomicity of device memory accesses. The recommended practice for writing
12977  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
12978  * alt_write_word() functions.
12979  *
12980  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO10.
12981  */
12983 {
12984  uint32_t sel : 2; /* spim0_mosi Mux Selection Field */
12985  uint32_t : 30; /* *UNDEFINED* */
12986 };
12987
12988 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO10. */
12989 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO10_s ALT_SYSMGR_PINMUX_GENERALIO10_t;
12990 #endif /* __ASSEMBLY__ */
12991
12992 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO10 register from the beginning of the component. */
12993 #define ALT_SYSMGR_PINMUX_GENERALIO10_OFST 0xa8
12994
12995 /*
12996  * Register : spim0_miso Mux Selection Register - GENERALIO11
12997  *
12998  * This register is used to control the peripherals connected to spim0_miso
12999  *
13000  * Only reset by a cold reset (ignores warm reset).
13001  *
13002  * NOTE: These registers should not be modified after IO configuration.There is no
13003  * support for dynamically changing the Pin Mux selections.
13004  *
13005  * Register Layout
13006  *
13007  * Bits | Access | Reset | Description
13008  * :-------|:-------|:------|:-------------------------------
13009  * [1:0] | RW | 0x0 | spim0_miso Mux Selection Field
13010  * [31:2] | ??? | 0x0 | *UNDEFINED*
13011  *
13012  */
13013 /*
13014  * Field : spim0_miso Mux Selection Field - sel
13015  *
13016  * Select peripheral signals connected spim0_miso.
13017  *
13018  * 0 : Pin is connected to GPIO/LoanIO number 59.
13019  *
13020  * 1 : Pin is connected to Peripheral signal UART1.CTS.
13021  *
13022  * 2 : Pin is connected to Peripheral signal CAN1.RX.
13023  *
13024  * 3 : Pin is connected to Peripheral signal SPIM0.MISO.
13025  *
13026  * Field Access Macros:
13027  *
13028  */
13029 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
13030 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_LSB 0
13031 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
13032 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_MSB 1
13033 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
13034 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_WIDTH 2
13035 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field value. */
13036 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_SET_MSK 0x00000003
13037 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field value. */
13038 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_CLR_MSK 0xfffffffc
13039 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
13040 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_RESET 0x0
13041 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO11_SEL field value from a register. */
13042 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_GET(value) (((value) & 0x00000003) >> 0)
13043 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field value suitable for setting the register. */
13044 #define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_SET(value) (((value) << 0) & 0x00000003)
13045
13046 #ifndef __ASSEMBLY__
13047 /*
13048  * WARNING: The C register and register group struct declarations are provided for
13049  * convenience and illustrative purposes. They should, however, be used with
13050  * caution as the C language standard provides no guarantees about the alignment or
13051  * atomicity of device memory accesses. The recommended practice for writing
13052  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13053  * alt_write_word() functions.
13054  *
13055  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO11.
13056  */
13058 {
13059  uint32_t sel : 2; /* spim0_miso Mux Selection Field */
13060  uint32_t : 30; /* *UNDEFINED* */
13061 };
13062
13063 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO11. */
13064 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO11_s ALT_SYSMGR_PINMUX_GENERALIO11_t;
13065 #endif /* __ASSEMBLY__ */
13066
13067 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO11 register from the beginning of the component. */
13068 #define ALT_SYSMGR_PINMUX_GENERALIO11_OFST 0xac
13069
13070 /*
13071  * Register : spim0_ss0 Mux Selection Register - GENERALIO12
13072  *
13073  * This register is used to control the peripherals connected to spim0_ss0
13074  *
13075  * Only reset by a cold reset (ignores warm reset).
13076  *
13077  * NOTE: These registers should not be modified after IO configuration.There is no
13078  * support for dynamically changing the Pin Mux selections.
13079  *
13080  * Register Layout
13081  *
13082  * Bits | Access | Reset | Description
13083  * :-------|:-------|:------|:------------------------------
13084  * [1:0] | RW | 0x0 | spim0_ss0 Mux Selection Field
13085  * [31:2] | ??? | 0x0 | *UNDEFINED*
13086  *
13087  */
13088 /*
13089  * Field : spim0_ss0 Mux Selection Field - sel
13090  *
13091  * Select peripheral signals connected spim0_ss0.
13092  *
13093  * 0 : Pin is connected to GPIO/LoanIO number 60.
13094  *
13095  * 1 : Pin is connected to Peripheral signal UART1.RTS.
13096  *
13097  * 2 : Pin is connected to Peripheral signal CAN1.TX.
13098  *
13099  * 3 : Pin is connected to Peripheral signal SPIM0.SS0.
13100  *
13101  * Field Access Macros:
13102  *
13103  */
13104 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
13105 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_LSB 0
13106 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
13107 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_MSB 1
13108 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
13109 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_WIDTH 2
13110 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field value. */
13111 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_SET_MSK 0x00000003
13112 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field value. */
13113 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_CLR_MSK 0xfffffffc
13114 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
13115 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_RESET 0x0
13116 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO12_SEL field value from a register. */
13117 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_GET(value) (((value) & 0x00000003) >> 0)
13118 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field value suitable for setting the register. */
13119 #define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_SET(value) (((value) << 0) & 0x00000003)
13120
13121 #ifndef __ASSEMBLY__
13122 /*
13123  * WARNING: The C register and register group struct declarations are provided for
13124  * convenience and illustrative purposes. They should, however, be used with
13125  * caution as the C language standard provides no guarantees about the alignment or
13126  * atomicity of device memory accesses. The recommended practice for writing
13127  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13128  * alt_write_word() functions.
13129  *
13130  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO12.
13131  */
13133 {
13134  uint32_t sel : 2; /* spim0_ss0 Mux Selection Field */
13135  uint32_t : 30; /* *UNDEFINED* */
13136 };
13137
13138 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO12. */
13139 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO12_s ALT_SYSMGR_PINMUX_GENERALIO12_t;
13140 #endif /* __ASSEMBLY__ */
13141
13142 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO12 register from the beginning of the component. */
13143 #define ALT_SYSMGR_PINMUX_GENERALIO12_OFST 0xb0
13144
13145 /*
13146  * Register : uart0_rx Mux Selection Register - GENERALIO13
13147  *
13148  * This register is used to control the peripherals connected to uart0_rx
13149  *
13150  * Only reset by a cold reset (ignores warm reset).
13151  *
13152  * NOTE: These registers should not be modified after IO configuration.There is no
13153  * support for dynamically changing the Pin Mux selections.
13154  *
13155  * Register Layout
13156  *
13157  * Bits | Access | Reset | Description
13158  * :-------|:-------|:------|:-----------------------------
13159  * [1:0] | RW | 0x0 | uart0_rx Mux Selection Field
13160  * [31:2] | ??? | 0x0 | *UNDEFINED*
13161  *
13162  */
13163 /*
13164  * Field : uart0_rx Mux Selection Field - sel
13165  *
13166  * Select peripheral signals connected uart0_rx.
13167  *
13168  * 0 : Pin is connected to GPIO/LoanIO number 61.
13169  *
13170  * 1 : Pin is connected to Peripheral signal SPIM0.SS1.
13171  *
13172  * 2 : Pin is connected to Peripheral signal CAN0.RX.
13173  *
13174  * 3 : Pin is connected to Peripheral signal UART0.RX.
13175  *
13176  * Field Access Macros:
13177  *
13178  */
13179 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
13180 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_LSB 0
13181 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
13182 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_MSB 1
13183 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
13184 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_WIDTH 2
13185 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field value. */
13186 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_SET_MSK 0x00000003
13187 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field value. */
13188 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_CLR_MSK 0xfffffffc
13189 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
13190 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_RESET 0x0
13191 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO13_SEL field value from a register. */
13192 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_GET(value) (((value) & 0x00000003) >> 0)
13193 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field value suitable for setting the register. */
13194 #define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_SET(value) (((value) << 0) & 0x00000003)
13195
13196 #ifndef __ASSEMBLY__
13197 /*
13198  * WARNING: The C register and register group struct declarations are provided for
13199  * convenience and illustrative purposes. They should, however, be used with
13200  * caution as the C language standard provides no guarantees about the alignment or
13201  * atomicity of device memory accesses. The recommended practice for writing
13202  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13203  * alt_write_word() functions.
13204  *
13205  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO13.
13206  */
13208 {
13209  uint32_t sel : 2; /* uart0_rx Mux Selection Field */
13210  uint32_t : 30; /* *UNDEFINED* */
13211 };
13212
13213 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO13. */
13214 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO13_s ALT_SYSMGR_PINMUX_GENERALIO13_t;
13215 #endif /* __ASSEMBLY__ */
13216
13217 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO13 register from the beginning of the component. */
13218 #define ALT_SYSMGR_PINMUX_GENERALIO13_OFST 0xb4
13219
13220 /*
13221  * Register : uart0_tx Mux Selection Register - GENERALIO14
13222  *
13223  * This register is used to control the peripherals connected to uart0_tx
13224  *
13225  * Only reset by a cold reset (ignores warm reset).
13226  *
13227  * NOTE: These registers should not be modified after IO configuration.There is no
13228  * support for dynamically changing the Pin Mux selections.
13229  *
13230  * Register Layout
13231  *
13232  * Bits | Access | Reset | Description
13233  * :-------|:-------|:------|:-----------------------------
13234  * [1:0] | RW | 0x0 | uart0_tx Mux Selection Field
13235  * [31:2] | ??? | 0x0 | *UNDEFINED*
13236  *
13237  */
13238 /*
13239  * Field : uart0_tx Mux Selection Field - sel
13240  *
13241  * Select peripheral signals connected uart0_tx.
13242  *
13243  * 0 : Pin is connected to GPIO/LoanIO number 62.
13244  *
13245  * 1 : Pin is connected to Peripheral signal SPIM1.SS1.
13246  *
13247  * 2 : Pin is connected to Peripheral signal CAN0.TX.
13248  *
13249  * 3 : Pin is connected to Peripheral signal UART0.TX.
13250  *
13251  * Field Access Macros:
13252  *
13253  */
13254 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
13255 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_LSB 0
13256 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
13257 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_MSB 1
13258 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
13259 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_WIDTH 2
13260 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field value. */
13261 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_SET_MSK 0x00000003
13262 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field value. */
13263 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_CLR_MSK 0xfffffffc
13264 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
13265 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_RESET 0x0
13266 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO14_SEL field value from a register. */
13267 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_GET(value) (((value) & 0x00000003) >> 0)
13268 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field value suitable for setting the register. */
13269 #define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_SET(value) (((value) << 0) & 0x00000003)
13270
13271 #ifndef __ASSEMBLY__
13272 /*
13273  * WARNING: The C register and register group struct declarations are provided for
13274  * convenience and illustrative purposes. They should, however, be used with
13275  * caution as the C language standard provides no guarantees about the alignment or
13276  * atomicity of device memory accesses. The recommended practice for writing
13277  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13278  * alt_write_word() functions.
13279  *
13280  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO14.
13281  */
13283 {
13284  uint32_t sel : 2; /* uart0_tx Mux Selection Field */
13285  uint32_t : 30; /* *UNDEFINED* */
13286 };
13287
13288 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO14. */
13289 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO14_s ALT_SYSMGR_PINMUX_GENERALIO14_t;
13290 #endif /* __ASSEMBLY__ */
13291
13292 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO14 register from the beginning of the component. */
13293 #define ALT_SYSMGR_PINMUX_GENERALIO14_OFST 0xb8
13294
13295 /*
13296  * Register : i2c0_sda Mux Selection Register - GENERALIO15
13297  *
13298  * This register is used to control the peripherals connected to i2c0_sda
13299  *
13300  * Only reset by a cold reset (ignores warm reset).
13301  *
13302  * NOTE: These registers should not be modified after IO configuration.There is no
13303  * support for dynamically changing the Pin Mux selections.
13304  *
13305  * Register Layout
13306  *
13307  * Bits | Access | Reset | Description
13308  * :-------|:-------|:------|:-----------------------------
13309  * [1:0] | RW | 0x0 | i2c0_sda Mux Selection Field
13310  * [31:2] | ??? | 0x0 | *UNDEFINED*
13311  *
13312  */
13313 /*
13314  * Field : i2c0_sda Mux Selection Field - sel
13315  *
13316  * Select peripheral signals connected i2c0_sda.
13317  *
13318  * 0 : Pin is connected to GPIO/LoanIO number 63.
13319  *
13320  * 1 : Pin is connected to Peripheral signal SPIM1.CLK.
13321  *
13322  * 2 : Pin is connected to Peripheral signal UART1.RX.
13323  *
13324  * 3 : Pin is connected to Peripheral signal I2C0.SDA.
13325  *
13326  * Field Access Macros:
13327  *
13328  */
13329 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
13330 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_LSB 0
13331 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
13332 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_MSB 1
13333 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
13334 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_WIDTH 2
13335 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field value. */
13336 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_SET_MSK 0x00000003
13337 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field value. */
13338 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_CLR_MSK 0xfffffffc
13339 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
13340 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_RESET 0x0
13341 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO15_SEL field value from a register. */
13342 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_GET(value) (((value) & 0x00000003) >> 0)
13343 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field value suitable for setting the register. */
13344 #define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_SET(value) (((value) << 0) & 0x00000003)
13345
13346 #ifndef __ASSEMBLY__
13347 /*
13348  * WARNING: The C register and register group struct declarations are provided for
13349  * convenience and illustrative purposes. They should, however, be used with
13350  * caution as the C language standard provides no guarantees about the alignment or
13351  * atomicity of device memory accesses. The recommended practice for writing
13352  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13353  * alt_write_word() functions.
13354  *
13355  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO15.
13356  */
13358 {
13359  uint32_t sel : 2; /* i2c0_sda Mux Selection Field */
13360  uint32_t : 30; /* *UNDEFINED* */
13361 };
13362
13363 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO15. */
13364 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO15_s ALT_SYSMGR_PINMUX_GENERALIO15_t;
13365 #endif /* __ASSEMBLY__ */
13366
13367 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO15 register from the beginning of the component. */
13368 #define ALT_SYSMGR_PINMUX_GENERALIO15_OFST 0xbc
13369
13370 /*
13371  * Register : i2c0_scl Mux Selection Register - GENERALIO16
13372  *
13373  * This register is used to control the peripherals connected to i2c0_scl
13374  *
13375  * Only reset by a cold reset (ignores warm reset).
13376  *
13377  * NOTE: These registers should not be modified after IO configuration.There is no
13378  * support for dynamically changing the Pin Mux selections.
13379  *
13380  * Register Layout
13381  *
13382  * Bits | Access | Reset | Description
13383  * :-------|:-------|:------|:-----------------------------
13384  * [1:0] | RW | 0x0 | i2c0_scl Mux Selection Field
13385  * [31:2] | ??? | 0x0 | *UNDEFINED*
13386  *
13387  */
13388 /*
13389  * Field : i2c0_scl Mux Selection Field - sel
13390  *
13391  * Select peripheral signals connected i2c0_scl.
13392  *
13393  * 0 : Pin is connected to GPIO/LoanIO number 64.
13394  *
13395  * 1 : Pin is connected to Peripheral signal SPIM1.MOSI.
13396  *
13397  * 2 : Pin is connected to Peripheral signal UART1.TX.
13398  *
13399  * 3 : Pin is connected to Peripheral signal I2C0.SCL.
13400  *
13401  * Field Access Macros:
13402  *
13403  */
13404 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
13405 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_LSB 0
13406 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
13407 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_MSB 1
13408 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
13409 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_WIDTH 2
13410 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field value. */
13411 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_SET_MSK 0x00000003
13412 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field value. */
13413 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_CLR_MSK 0xfffffffc
13414 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
13415 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_RESET 0x0
13416 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO16_SEL field value from a register. */
13417 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_GET(value) (((value) & 0x00000003) >> 0)
13418 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field value suitable for setting the register. */
13419 #define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_SET(value) (((value) << 0) & 0x00000003)
13420
13421 #ifndef __ASSEMBLY__
13422 /*
13423  * WARNING: The C register and register group struct declarations are provided for
13424  * convenience and illustrative purposes. They should, however, be used with
13425  * caution as the C language standard provides no guarantees about the alignment or
13426  * atomicity of device memory accesses. The recommended practice for writing
13427  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13428  * alt_write_word() functions.
13429  *
13430  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO16.
13431  */
13433 {
13434  uint32_t sel : 2; /* i2c0_scl Mux Selection Field */
13435  uint32_t : 30; /* *UNDEFINED* */
13436 };
13437
13438 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO16. */
13439 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO16_s ALT_SYSMGR_PINMUX_GENERALIO16_t;
13440 #endif /* __ASSEMBLY__ */
13441
13442 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO16 register from the beginning of the component. */
13443 #define ALT_SYSMGR_PINMUX_GENERALIO16_OFST 0xc0
13444
13445 /*
13446  * Register : can0_rx Mux Selection Register - GENERALIO17
13447  *
13448  * This register is used to control the peripherals connected to can0_rx
13449  *
13450  * Only reset by a cold reset (ignores warm reset).
13451  *
13452  * NOTE: These registers should not be modified after IO configuration.There is no
13453  * support for dynamically changing the Pin Mux selections.
13454  *
13455  * Register Layout
13456  *
13457  * Bits | Access | Reset | Description
13458  * :-------|:-------|:------|:----------------------------
13459  * [1:0] | RW | 0x0 | can0_rx Mux Selection Field
13460  * [31:2] | ??? | 0x0 | *UNDEFINED*
13461  *
13462  */
13463 /*
13464  * Field : can0_rx Mux Selection Field - sel
13465  *
13466  * Select peripheral signals connected can0_rx.
13467  *
13468  * 0 : Pin is connected to GPIO/LoanIO number 65.
13469  *
13470  * 1 : Pin is connected to Peripheral signal SPIM1.MISO.
13471  *
13472  * 2 : Pin is connected to Peripheral signal UART0.RX.
13473  *
13474  * 3 : Pin is connected to Peripheral signal CAN0.RX.
13475  *
13476  * Field Access Macros:
13477  *
13478  */
13479 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
13480 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_LSB 0
13481 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
13482 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_MSB 1
13483 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
13484 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_WIDTH 2
13485 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field value. */
13486 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_SET_MSK 0x00000003
13487 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field value. */
13488 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_CLR_MSK 0xfffffffc
13489 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
13490 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_RESET 0x0
13491 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO17_SEL field value from a register. */
13492 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_GET(value) (((value) & 0x00000003) >> 0)
13493 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field value suitable for setting the register. */
13494 #define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_SET(value) (((value) << 0) & 0x00000003)
13495
13496 #ifndef __ASSEMBLY__
13497 /*
13498  * WARNING: The C register and register group struct declarations are provided for
13499  * convenience and illustrative purposes. They should, however, be used with
13500  * caution as the C language standard provides no guarantees about the alignment or
13501  * atomicity of device memory accesses. The recommended practice for writing
13502  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13503  * alt_write_word() functions.
13504  *
13505  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO17.
13506  */
13508 {
13509  uint32_t sel : 2; /* can0_rx Mux Selection Field */
13510  uint32_t : 30; /* *UNDEFINED* */
13511 };
13512
13513 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO17. */
13514 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO17_s ALT_SYSMGR_PINMUX_GENERALIO17_t;
13515 #endif /* __ASSEMBLY__ */
13516
13517 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO17 register from the beginning of the component. */
13518 #define ALT_SYSMGR_PINMUX_GENERALIO17_OFST 0xc4
13519
13520 /*
13521  * Register : can0_tx Mux Selection Register - GENERALIO18
13522  *
13523  * This register is used to control the peripherals connected to can0_tx
13524  *
13525  * Only reset by a cold reset (ignores warm reset).
13526  *
13527  * NOTE: These registers should not be modified after IO configuration.There is no
13528  * support for dynamically changing the Pin Mux selections.
13529  *
13530  * Register Layout
13531  *
13532  * Bits | Access | Reset | Description
13533  * :-------|:-------|:------|:----------------------------
13534  * [1:0] | RW | 0x0 | can0_tx Mux Selection Field
13535  * [31:2] | ??? | 0x0 | *UNDEFINED*
13536  *
13537  */
13538 /*
13539  * Field : can0_tx Mux Selection Field - sel
13540  *
13541  * Select peripheral signals connected can0_tx.
13542  *
13543  * 0 : Pin is connected to GPIO/LoanIO number 66.
13544  *
13545  * 1 : Pin is connected to Peripheral signal SPIM1.SS0.
13546  *
13547  * 2 : Pin is connected to Peripheral signal UART0.TX.
13548  *
13549  * 3 : Pin is connected to Peripheral signal CAN0.TX.
13550  *
13551  * Field Access Macros:
13552  *
13553  */
13554 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
13555 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_LSB 0
13556 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
13557 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_MSB 1
13558 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
13559 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_WIDTH 2
13560 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field value. */
13561 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_SET_MSK 0x00000003
13562 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field value. */
13563 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_CLR_MSK 0xfffffffc
13564 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
13565 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_RESET 0x0
13566 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO18_SEL field value from a register. */
13567 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_GET(value) (((value) & 0x00000003) >> 0)
13568 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field value suitable for setting the register. */
13569 #define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_SET(value) (((value) << 0) & 0x00000003)
13570
13571 #ifndef __ASSEMBLY__
13572 /*
13573  * WARNING: The C register and register group struct declarations are provided for
13574  * convenience and illustrative purposes. They should, however, be used with
13575  * caution as the C language standard provides no guarantees about the alignment or
13576  * atomicity of device memory accesses. The recommended practice for writing
13577  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13578  * alt_write_word() functions.
13579  *
13580  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO18.
13581  */
13583 {
13584  uint32_t sel : 2; /* can0_tx Mux Selection Field */
13585  uint32_t : 30; /* *UNDEFINED* */
13586 };
13587
13588 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO18. */
13589 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO18_s ALT_SYSMGR_PINMUX_GENERALIO18_t;
13590 #endif /* __ASSEMBLY__ */
13591
13592 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO18 register from the beginning of the component. */
13593 #define ALT_SYSMGR_PINMUX_GENERALIO18_OFST 0xc8
13594
13595 /*
13596  * Register : spis1_clk Mux Selection Register - GENERALIO19
13597  *
13598  * This register is used to control the peripherals connected to spis1_clk
13599  *
13600  * Only reset by a cold reset (ignores warm reset).
13601  *
13602  * NOTE: These registers should not be modified after IO configuration.There is no
13603  * support for dynamically changing the Pin Mux selections.
13604  *
13605  * Register Layout
13606  *
13607  * Bits | Access | Reset | Description
13608  * :-------|:-------|:------|:------------------------------
13609  * [1:0] | RW | 0x0 | spis1_clk Mux Selection Field
13610  * [31:2] | ??? | 0x0 | *UNDEFINED*
13611  *
13612  */
13613 /*
13614  * Field : spis1_clk Mux Selection Field - sel
13615  *
13616  * Select peripheral signals connected spis1_clk.
13617  *
13618  * 0 : Pin is connected to GPIO/LoanIO number 67.
13619  *
13620  * 1 : Pin is connected to Peripheral signal not applicable.
13621  *
13622  * 2 : Pin is connected to Peripheral signal SPIM1.CLK.
13623  *
13624  * 3 : Pin is connected to Peripheral signal SPIS1.CLK.
13625  *
13626  * Field Access Macros:
13627  *
13628  */
13629 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
13630 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_LSB 0
13631 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
13632 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_MSB 1
13633 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
13634 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_WIDTH 2
13635 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field value. */
13636 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_SET_MSK 0x00000003
13637 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field value. */
13638 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_CLR_MSK 0xfffffffc
13639 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
13640 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_RESET 0x0
13641 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO19_SEL field value from a register. */
13642 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_GET(value) (((value) & 0x00000003) >> 0)
13643 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field value suitable for setting the register. */
13644 #define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_SET(value) (((value) << 0) & 0x00000003)
13645
13646 #ifndef __ASSEMBLY__
13647 /*
13648  * WARNING: The C register and register group struct declarations are provided for
13649  * convenience and illustrative purposes. They should, however, be used with
13650  * caution as the C language standard provides no guarantees about the alignment or
13651  * atomicity of device memory accesses. The recommended practice for writing
13652  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13653  * alt_write_word() functions.
13654  *
13655  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO19.
13656  */
13658 {
13659  uint32_t sel : 2; /* spis1_clk Mux Selection Field */
13660  uint32_t : 30; /* *UNDEFINED* */
13661 };
13662
13663 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO19. */
13664 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO19_s ALT_SYSMGR_PINMUX_GENERALIO19_t;
13665 #endif /* __ASSEMBLY__ */
13666
13667 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO19 register from the beginning of the component. */
13668 #define ALT_SYSMGR_PINMUX_GENERALIO19_OFST 0xcc
13669
13670 /*
13671  * Register : spis1_mosi Mux Selection Register - GENERALIO20
13672  *
13673  * This register is used to control the peripherals connected to spis1_mosi
13674  *
13675  * Only reset by a cold reset (ignores warm reset).
13676  *
13677  * NOTE: These registers should not be modified after IO configuration.There is no
13678  * support for dynamically changing the Pin Mux selections.
13679  *
13680  * Register Layout
13681  *
13682  * Bits | Access | Reset | Description
13683  * :-------|:-------|:------|:-------------------------------
13684  * [1:0] | RW | 0x0 | spis1_mosi Mux Selection Field
13685  * [31:2] | ??? | 0x0 | *UNDEFINED*
13686  *
13687  */
13688 /*
13689  * Field : spis1_mosi Mux Selection Field - sel
13690  *
13691  * Select peripheral signals connected spis1_mosi.
13692  *
13693  * 0 : Pin is connected to GPIO/LoanIO number 68.
13694  *
13695  * 1 : Pin is connected to Peripheral signal not applicable.
13696  *
13697  * 2 : Pin is connected to Peripheral signal SPIM1.MOSI.
13698  *
13699  * 3 : Pin is connected to Peripheral signal SPIS1.MOSI.
13700  *
13701  * Field Access Macros:
13702  *
13703  */
13704 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
13705 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_LSB 0
13706 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
13707 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_MSB 1
13708 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
13709 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_WIDTH 2
13710 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field value. */
13711 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_SET_MSK 0x00000003
13712 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field value. */
13713 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_CLR_MSK 0xfffffffc
13714 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
13715 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_RESET 0x0
13716 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO20_SEL field value from a register. */
13717 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_GET(value) (((value) & 0x00000003) >> 0)
13718 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field value suitable for setting the register. */
13719 #define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_SET(value) (((value) << 0) & 0x00000003)
13720
13721 #ifndef __ASSEMBLY__
13722 /*
13723  * WARNING: The C register and register group struct declarations are provided for
13724  * convenience and illustrative purposes. They should, however, be used with
13725  * caution as the C language standard provides no guarantees about the alignment or
13726  * atomicity of device memory accesses. The recommended practice for writing
13727  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13728  * alt_write_word() functions.
13729  *
13730  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO20.
13731  */
13733 {
13734  uint32_t sel : 2; /* spis1_mosi Mux Selection Field */
13735  uint32_t : 30; /* *UNDEFINED* */
13736 };
13737
13738 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO20. */
13739 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO20_s ALT_SYSMGR_PINMUX_GENERALIO20_t;
13740 #endif /* __ASSEMBLY__ */
13741
13742 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO20 register from the beginning of the component. */
13743 #define ALT_SYSMGR_PINMUX_GENERALIO20_OFST 0xd0
13744
13745 /*
13746  * Register : spis1_miso Mux Selection Register - GENERALIO21
13747  *
13748  * This register is used to control the peripherals connected to spis1_miso
13749  *
13750  * Only reset by a cold reset (ignores warm reset).
13751  *
13752  * NOTE: These registers should not be modified after IO configuration.There is no
13753  * support for dynamically changing the Pin Mux selections.
13754  *
13755  * Register Layout
13756  *
13757  * Bits | Access | Reset | Description
13758  * :-------|:-------|:------|:-------------------------------
13759  * [1:0] | RW | 0x0 | spis1_miso Mux Selection Field
13760  * [31:2] | ??? | 0x0 | *UNDEFINED*
13761  *
13762  */
13763 /*
13764  * Field : spis1_miso Mux Selection Field - sel
13765  *
13766  * Select peripheral signals connected spis1_miso.
13767  *
13768  * 0 : Pin is connected to GPIO/LoanIO number 69.
13769  *
13770  * 1 : Pin is connected to Peripheral signal not applicable.
13771  *
13772  * 2 : Pin is connected to Peripheral signal SPIM1.MISO.
13773  *
13774  * 3 : Pin is connected to Peripheral signal SPIS1.MISO.
13775  *
13776  * Field Access Macros:
13777  *
13778  */
13779 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
13780 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_LSB 0
13781 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
13782 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_MSB 1
13783 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
13784 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_WIDTH 2
13785 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field value. */
13786 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_SET_MSK 0x00000003
13787 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field value. */
13788 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_CLR_MSK 0xfffffffc
13789 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
13790 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_RESET 0x0
13791 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO21_SEL field value from a register. */
13792 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_GET(value) (((value) & 0x00000003) >> 0)
13793 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field value suitable for setting the register. */
13794 #define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_SET(value) (((value) << 0) & 0x00000003)
13795
13796 #ifndef __ASSEMBLY__
13797 /*
13798  * WARNING: The C register and register group struct declarations are provided for
13799  * convenience and illustrative purposes. They should, however, be used with
13800  * caution as the C language standard provides no guarantees about the alignment or
13801  * atomicity of device memory accesses. The recommended practice for writing
13802  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13803  * alt_write_word() functions.
13804  *
13805  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO21.
13806  */
13808 {
13809  uint32_t sel : 2; /* spis1_miso Mux Selection Field */
13810  uint32_t : 30; /* *UNDEFINED* */
13811 };
13812
13813 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO21. */
13814 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO21_s ALT_SYSMGR_PINMUX_GENERALIO21_t;
13815 #endif /* __ASSEMBLY__ */
13816
13817 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO21 register from the beginning of the component. */
13818 #define ALT_SYSMGR_PINMUX_GENERALIO21_OFST 0xd4
13819
13820 /*
13821  * Register : spis1_ss0 Mux Selection Register - GENERALIO22
13822  *
13823  * This register is used to control the peripherals connected to spis1_ss0
13824  *
13825  * Only reset by a cold reset (ignores warm reset).
13826  *
13827  * NOTE: These registers should not be modified after IO configuration.There is no
13828  * support for dynamically changing the Pin Mux selections.
13829  *
13830  * Register Layout
13831  *
13832  * Bits | Access | Reset | Description
13833  * :-------|:-------|:------|:------------------------------
13834  * [1:0] | RW | 0x0 | spis1_ss0 Mux Selection Field
13835  * [31:2] | ??? | 0x0 | *UNDEFINED*
13836  *
13837  */
13838 /*
13839  * Field : spis1_ss0 Mux Selection Field - sel
13840  *
13841  * Select peripheral signals connected spis1_ss0.
13842  *
13843  * 0 : Pin is connected to GPIO/LoanIO number 70.
13844  *
13845  * 1 : Pin is connected to Peripheral signal not applicable.
13846  *
13847  * 2 : Pin is connected to Peripheral signal SPIM1.SS0.
13848  *
13849  * 3 : Pin is connected to Peripheral signal SPIS1.SS0.
13850  *
13851  * Field Access Macros:
13852  *
13853  */
13854 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
13855 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_LSB 0
13856 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
13857 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_MSB 1
13858 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
13859 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_WIDTH 2
13860 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field value. */
13861 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_SET_MSK 0x00000003
13862 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field value. */
13863 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_CLR_MSK 0xfffffffc
13864 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
13865 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_RESET 0x0
13866 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO22_SEL field value from a register. */
13867 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_GET(value) (((value) & 0x00000003) >> 0)
13868 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field value suitable for setting the register. */
13869 #define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_SET(value) (((value) << 0) & 0x00000003)
13870
13871 #ifndef __ASSEMBLY__
13872 /*
13873  * WARNING: The C register and register group struct declarations are provided for
13874  * convenience and illustrative purposes. They should, however, be used with
13875  * caution as the C language standard provides no guarantees about the alignment or
13876  * atomicity of device memory accesses. The recommended practice for writing
13877  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13878  * alt_write_word() functions.
13879  *
13880  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO22.
13881  */
13883 {
13884  uint32_t sel : 2; /* spis1_ss0 Mux Selection Field */
13885  uint32_t : 30; /* *UNDEFINED* */
13886 };
13887
13888 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO22. */
13889 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO22_s ALT_SYSMGR_PINMUX_GENERALIO22_t;
13890 #endif /* __ASSEMBLY__ */
13891
13892 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO22 register from the beginning of the component. */
13893 #define ALT_SYSMGR_PINMUX_GENERALIO22_OFST 0xd8
13894
13895 /*
13896  * Register : uart1_rx Mux Selection Register - GENERALIO23
13897  *
13898  * This register is used to control the peripherals connected to uart1_rx
13899  *
13900  * Only reset by a cold reset (ignores warm reset).
13901  *
13902  * NOTE: These registers should not be modified after IO configuration.There is no
13903  * support for dynamically changing the Pin Mux selections.
13904  *
13905  * Register Layout
13906  *
13907  * Bits | Access | Reset | Description
13908  * :-------|:-------|:------|:-----------------------------
13909  * [1:0] | RW | 0x0 | uart1_rx Mux Selection Field
13910  * [31:2] | ??? | 0x0 | *UNDEFINED*
13911  *
13912  */
13913 /*
13914  * Field : uart1_rx Mux Selection Field - sel
13915  *
13916  * Select peripheral signals connected uart1_rx.
13917  *
13918  * 0 : Pin is connected to GPIO/LoanIO number 62.
13919  *
13920  * 1 : Pin is connected to Peripheral signal not applicable.
13921  *
13922  * 2 : Pin is connected to Peripheral signal SPIM1.SS1.
13923  *
13924  * 3 : Pin is connected to Peripheral signal UART1.RX.
13925  *
13926  * Field Access Macros:
13927  *
13928  */
13929 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
13930 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_LSB 0
13931 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
13932 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_MSB 1
13933 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
13934 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_WIDTH 2
13935 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field value. */
13936 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_SET_MSK 0x00000003
13937 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field value. */
13938 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_CLR_MSK 0xfffffffc
13939 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
13940 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_RESET 0x0
13941 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO23_SEL field value from a register. */
13942 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_GET(value) (((value) & 0x00000003) >> 0)
13943 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field value suitable for setting the register. */
13944 #define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_SET(value) (((value) << 0) & 0x00000003)
13945
13946 #ifndef __ASSEMBLY__
13947 /*
13948  * WARNING: The C register and register group struct declarations are provided for
13949  * convenience and illustrative purposes. They should, however, be used with
13950  * caution as the C language standard provides no guarantees about the alignment or
13951  * atomicity of device memory accesses. The recommended practice for writing
13952  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
13953  * alt_write_word() functions.
13954  *
13955  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO23.
13956  */
13958 {
13959  uint32_t sel : 2; /* uart1_rx Mux Selection Field */
13960  uint32_t : 30; /* *UNDEFINED* */
13961 };
13962
13963 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO23. */
13964 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO23_s ALT_SYSMGR_PINMUX_GENERALIO23_t;
13965 #endif /* __ASSEMBLY__ */
13966
13967 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO23 register from the beginning of the component. */
13968 #define ALT_SYSMGR_PINMUX_GENERALIO23_OFST 0xdc
13969
13970 /*
13971  * Register : uart1_tx Mux Selection Register - GENERALIO24
13972  *
13973  * This register is used to control the peripherals connected to uart1_tx
13974  *
13975  * Only reset by a cold reset (ignores warm reset).
13976  *
13977  * NOTE: These registers should not be modified after IO configuration.There is no
13978  * support for dynamically changing the Pin Mux selections.
13979  *
13980  * Register Layout
13981  *
13982  * Bits | Access | Reset | Description
13983  * :-------|:-------|:------|:-----------------------------
13984  * [1:0] | RW | 0x0 | uart1_tx Mux Selection Field
13985  * [31:2] | ??? | 0x0 | *UNDEFINED*
13986  *
13987  */
13988 /*
13989  * Field : uart1_tx Mux Selection Field - sel
13990  *
13991  * Select peripheral signals connected uart1_tx.
13992  *
13993  * 0 : Pin is connected to GPIO/LoanIO number 63.
13994  *
13995  * 1 : Pin is connected to Peripheral signal not applicable.
13996  *
13997  * 2 : Pin is connected to Peripheral signal SPIM0.CLK.
13998  *
13999  * 3 : Pin is connected to Peripheral signal UART1.TX.
14000  *
14001  * Field Access Macros:
14002  *
14003  */
14004 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
14005 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_LSB 0
14006 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
14007 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_MSB 1
14008 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
14009 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_WIDTH 2
14010 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field value. */
14011 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_SET_MSK 0x00000003
14012 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field value. */
14013 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_CLR_MSK 0xfffffffc
14014 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
14015 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_RESET 0x0
14016 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO24_SEL field value from a register. */
14017 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_GET(value) (((value) & 0x00000003) >> 0)
14018 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field value suitable for setting the register. */
14019 #define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_SET(value) (((value) << 0) & 0x00000003)
14020
14021 #ifndef __ASSEMBLY__
14022 /*
14023  * WARNING: The C register and register group struct declarations are provided for
14024  * convenience and illustrative purposes. They should, however, be used with
14025  * caution as the C language standard provides no guarantees about the alignment or
14026  * atomicity of device memory accesses. The recommended practice for writing
14027  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14028  * alt_write_word() functions.
14029  *
14030  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO24.
14031  */
14033 {
14034  uint32_t sel : 2; /* uart1_tx Mux Selection Field */
14035  uint32_t : 30; /* *UNDEFINED* */
14036 };
14037
14038 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO24. */
14039 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO24_s ALT_SYSMGR_PINMUX_GENERALIO24_t;
14040 #endif /* __ASSEMBLY__ */
14041
14042 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO24 register from the beginning of the component. */
14043 #define ALT_SYSMGR_PINMUX_GENERALIO24_OFST 0xe0
14044
14045 /*
14046  * Register : i2c1_sda Mux Selection Register - GENERALIO25
14047  *
14048  * This register is used to control the peripherals connected to i2c1_sda
14049  *
14050  * Only reset by a cold reset (ignores warm reset).
14051  *
14052  * NOTE: These registers should not be modified after IO configuration.There is no
14053  * support for dynamically changing the Pin Mux selections.
14054  *
14055  * Register Layout
14056  *
14057  * Bits | Access | Reset | Description
14058  * :-------|:-------|:------|:-----------------------------
14059  * [1:0] | RW | 0x0 | i2c1_sda Mux Selection Field
14060  * [31:2] | ??? | 0x0 | *UNDEFINED*
14061  *
14062  */
14063 /*
14064  * Field : i2c1_sda Mux Selection Field - sel
14065  *
14066  * Select peripheral signals connected i2c1_sda.
14067  *
14068  * 0 : Pin is connected to GPIO/LoanIO number 64.
14069  *
14070  * 1 : Pin is connected to Peripheral signal not applicable.
14071  *
14072  * 2 : Pin is connected to Peripheral signal SPIM0.MOSI.
14073  *
14074  * 3 : Pin is connected to Peripheral signal I2C1.SDA.
14075  *
14076  * Field Access Macros:
14077  *
14078  */
14079 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
14080 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_LSB 0
14081 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
14082 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_MSB 1
14083 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
14084 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_WIDTH 2
14085 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field value. */
14086 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_SET_MSK 0x00000003
14087 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field value. */
14088 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_CLR_MSK 0xfffffffc
14089 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
14090 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_RESET 0x0
14091 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO25_SEL field value from a register. */
14092 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_GET(value) (((value) & 0x00000003) >> 0)
14093 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field value suitable for setting the register. */
14094 #define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_SET(value) (((value) << 0) & 0x00000003)
14095
14096 #ifndef __ASSEMBLY__
14097 /*
14098  * WARNING: The C register and register group struct declarations are provided for
14099  * convenience and illustrative purposes. They should, however, be used with
14100  * caution as the C language standard provides no guarantees about the alignment or
14101  * atomicity of device memory accesses. The recommended practice for writing
14102  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14103  * alt_write_word() functions.
14104  *
14105  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO25.
14106  */
14108 {
14109  uint32_t sel : 2; /* i2c1_sda Mux Selection Field */
14110  uint32_t : 30; /* *UNDEFINED* */
14111 };
14112
14113 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO25. */
14114 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO25_s ALT_SYSMGR_PINMUX_GENERALIO25_t;
14115 #endif /* __ASSEMBLY__ */
14116
14117 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO25 register from the beginning of the component. */
14118 #define ALT_SYSMGR_PINMUX_GENERALIO25_OFST 0xe4
14119
14120 /*
14121  * Register : i2c1_scl Mux Selection Register - GENERALIO26
14122  *
14123  * This register is used to control the peripherals connected to i2c1_scl
14124  *
14125  * Only reset by a cold reset (ignores warm reset).
14126  *
14127  * NOTE: These registers should not be modified after IO configuration.There is no
14128  * support for dynamically changing the Pin Mux selections.
14129  *
14130  * Register Layout
14131  *
14132  * Bits | Access | Reset | Description
14133  * :-------|:-------|:------|:-----------------------------
14134  * [1:0] | RW | 0x0 | i2c1_scl Mux Selection Field
14135  * [31:2] | ??? | 0x0 | *UNDEFINED*
14136  *
14137  */
14138 /*
14139  * Field : i2c1_scl Mux Selection Field - sel
14140  *
14141  * Select peripheral signals connected i2c1_scl.
14142  *
14143  * 0 : Pin is connected to GPIO/LoanIO number 65.
14144  *
14145  * 1 : Pin is connected to Peripheral signal not applicable.
14146  *
14147  * 2 : Pin is connected to Peripheral signal SPIM0.MISO.
14148  *
14149  * 3 : Pin is connected to Peripheral signal I2C1.SCL.
14150  *
14151  * Field Access Macros:
14152  *
14153  */
14154 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
14155 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_LSB 0
14156 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
14157 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_MSB 1
14158 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
14159 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_WIDTH 2
14160 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field value. */
14161 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_SET_MSK 0x00000003
14162 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field value. */
14163 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_CLR_MSK 0xfffffffc
14164 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
14165 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_RESET 0x0
14166 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO26_SEL field value from a register. */
14167 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_GET(value) (((value) & 0x00000003) >> 0)
14168 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field value suitable for setting the register. */
14169 #define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_SET(value) (((value) << 0) & 0x00000003)
14170
14171 #ifndef __ASSEMBLY__
14172 /*
14173  * WARNING: The C register and register group struct declarations are provided for
14174  * convenience and illustrative purposes. They should, however, be used with
14175  * caution as the C language standard provides no guarantees about the alignment or
14176  * atomicity of device memory accesses. The recommended practice for writing
14177  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14178  * alt_write_word() functions.
14179  *
14180  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO26.
14181  */
14183 {
14184  uint32_t sel : 2; /* i2c1_scl Mux Selection Field */
14185  uint32_t : 30; /* *UNDEFINED* */
14186 };
14187
14188 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO26. */
14189 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO26_s ALT_SYSMGR_PINMUX_GENERALIO26_t;
14190 #endif /* __ASSEMBLY__ */
14191
14192 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO26 register from the beginning of the component. */
14193 #define ALT_SYSMGR_PINMUX_GENERALIO26_OFST 0xe8
14194
14195 /*
14196  * Register : spim0_ss0_alt Mux Selection Register - GENERALIO27
14197  *
14198  * This register is used to control the peripherals connected to spim0_ss0_alt
14199  *
14200  * Only reset by a cold reset (ignores warm reset).
14201  *
14202  * NOTE: These registers should not be modified after IO configuration.There is no
14203  * support for dynamically changing the Pin Mux selections.
14204  *
14205  * Register Layout
14206  *
14207  * Bits | Access | Reset | Description
14208  * :-------|:-------|:------|:----------------------------------
14209  * [1:0] | RW | 0x0 | spim0_ss0_alt Mux Selection Field
14210  * [31:2] | ??? | 0x0 | *UNDEFINED*
14211  *
14212  */
14213 /*
14214  * Field : spim0_ss0_alt Mux Selection Field - sel
14215  *
14216  * Select peripheral signals connected spim0_ss0_alt.
14217  *
14218  * 0 : Pin is connected to GPIO/LoanIO number 66.
14219  *
14220  * 1 : Pin is connected to Peripheral signal not applicable.
14221  *
14222  * 2 : Pin is connected to Peripheral signal SPIM0.SS0.
14223  *
14224  * 3 : Pin is connected to Peripheral signal not applicable.
14225  *
14226  * Field Access Macros:
14227  *
14228  */
14229 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
14230 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_LSB 0
14231 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
14232 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_MSB 1
14233 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
14234 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_WIDTH 2
14235 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field value. */
14236 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_SET_MSK 0x00000003
14237 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field value. */
14238 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_CLR_MSK 0xfffffffc
14239 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
14240 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_RESET 0x0
14241 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO27_SEL field value from a register. */
14242 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_GET(value) (((value) & 0x00000003) >> 0)
14243 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field value suitable for setting the register. */
14244 #define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_SET(value) (((value) << 0) & 0x00000003)
14245
14246 #ifndef __ASSEMBLY__
14247 /*
14248  * WARNING: The C register and register group struct declarations are provided for
14249  * convenience and illustrative purposes. They should, however, be used with
14250  * caution as the C language standard provides no guarantees about the alignment or
14251  * atomicity of device memory accesses. The recommended practice for writing
14252  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14253  * alt_write_word() functions.
14254  *
14255  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO27.
14256  */
14258 {
14259  uint32_t sel : 2; /* spim0_ss0_alt Mux Selection Field */
14260  uint32_t : 30; /* *UNDEFINED* */
14261 };
14262
14263 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO27. */
14264 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO27_s ALT_SYSMGR_PINMUX_GENERALIO27_t;
14265 #endif /* __ASSEMBLY__ */
14266
14267 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO27 register from the beginning of the component. */
14268 #define ALT_SYSMGR_PINMUX_GENERALIO27_OFST 0xec
14269
14270 /*
14271  * Register : spis0_clk Mux Selection Register - GENERALIO28
14272  *
14273  * This register is used to control the peripherals connected to spis0_clk
14274  *
14275  * Only reset by a cold reset (ignores warm reset).
14276  *
14277  * NOTE: These registers should not be modified after IO configuration.There is no
14278  * support for dynamically changing the Pin Mux selections.
14279  *
14280  * Register Layout
14281  *
14282  * Bits | Access | Reset | Description
14283  * :-------|:-------|:------|:------------------------------
14284  * [1:0] | RW | 0x0 | spis0_clk Mux Selection Field
14285  * [31:2] | ??? | 0x0 | *UNDEFINED*
14286  *
14287  */
14288 /*
14289  * Field : spis0_clk Mux Selection Field - sel
14290  *
14291  * Select peripheral signals connected spis0_clk.
14292  *
14293  * 0 : Pin is connected to GPIO/LoanIO number 67.
14294  *
14295  * 1 : Pin is connected to Peripheral signal not applicable.
14296  *
14297  * 2 : Pin is connected to Peripheral signal SPIM0.SS1.
14298  *
14299  * 3 : Pin is connected to Peripheral signal SPIS0.CLK.
14300  *
14301  * Field Access Macros:
14302  *
14303  */
14304 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
14305 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_LSB 0
14306 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
14307 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_MSB 1
14308 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
14309 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_WIDTH 2
14310 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field value. */
14311 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_SET_MSK 0x00000003
14312 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field value. */
14313 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_CLR_MSK 0xfffffffc
14314 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
14315 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_RESET 0x0
14316 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO28_SEL field value from a register. */
14317 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_GET(value) (((value) & 0x00000003) >> 0)
14318 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field value suitable for setting the register. */
14319 #define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_SET(value) (((value) << 0) & 0x00000003)
14320
14321 #ifndef __ASSEMBLY__
14322 /*
14323  * WARNING: The C register and register group struct declarations are provided for
14324  * convenience and illustrative purposes. They should, however, be used with
14325  * caution as the C language standard provides no guarantees about the alignment or
14326  * atomicity of device memory accesses. The recommended practice for writing
14327  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14328  * alt_write_word() functions.
14329  *
14330  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO28.
14331  */
14333 {
14334  uint32_t sel : 2; /* spis0_clk Mux Selection Field */
14335  uint32_t : 30; /* *UNDEFINED* */
14336 };
14337
14338 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO28. */
14339 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO28_s ALT_SYSMGR_PINMUX_GENERALIO28_t;
14340 #endif /* __ASSEMBLY__ */
14341
14342 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO28 register from the beginning of the component. */
14343 #define ALT_SYSMGR_PINMUX_GENERALIO28_OFST 0xf0
14344
14345 /*
14346  * Register : spis0_mosi Mux Selection Register - GENERALIO29
14347  *
14348  * This register is used to control the peripherals connected to spis0_mosi
14349  *
14350  * Only reset by a cold reset (ignores warm reset).
14351  *
14352  * NOTE: These registers should not be modified after IO configuration.There is no
14353  * support for dynamically changing the Pin Mux selections.
14354  *
14355  * Register Layout
14356  *
14357  * Bits | Access | Reset | Description
14358  * :-------|:-------|:------|:-------------------------------
14359  * [1:0] | RW | 0x0 | spis0_mosi Mux Selection Field
14360  * [31:2] | ??? | 0x0 | *UNDEFINED*
14361  *
14362  */
14363 /*
14364  * Field : spis0_mosi Mux Selection Field - sel
14365  *
14366  * Select peripheral signals connected spis0_mosi.
14367  *
14368  * 0 : Pin is connected to GPIO/LoanIO number 68.
14369  *
14370  * 1 : Pin is connected to Peripheral signal not applicable.
14371  *
14372  * 2 : Pin is connected to Peripheral signal not applicable.
14373  *
14374  * 3 : Pin is connected to Peripheral signal SPIS0.MOSI.
14375  *
14376  * Field Access Macros:
14377  *
14378  */
14379 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
14380 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_LSB 0
14381 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
14382 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_MSB 1
14383 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
14384 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_WIDTH 2
14385 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field value. */
14386 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_SET_MSK 0x00000003
14387 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field value. */
14388 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_CLR_MSK 0xfffffffc
14389 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
14390 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_RESET 0x0
14391 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO29_SEL field value from a register. */
14392 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_GET(value) (((value) & 0x00000003) >> 0)
14393 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field value suitable for setting the register. */
14394 #define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_SET(value) (((value) << 0) & 0x00000003)
14395
14396 #ifndef __ASSEMBLY__
14397 /*
14398  * WARNING: The C register and register group struct declarations are provided for
14399  * convenience and illustrative purposes. They should, however, be used with
14400  * caution as the C language standard provides no guarantees about the alignment or
14401  * atomicity of device memory accesses. The recommended practice for writing
14402  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14403  * alt_write_word() functions.
14404  *
14405  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO29.
14406  */
14408 {
14409  uint32_t sel : 2; /* spis0_mosi Mux Selection Field */
14410  uint32_t : 30; /* *UNDEFINED* */
14411 };
14412
14413 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO29. */
14414 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO29_s ALT_SYSMGR_PINMUX_GENERALIO29_t;
14415 #endif /* __ASSEMBLY__ */
14416
14417 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO29 register from the beginning of the component. */
14418 #define ALT_SYSMGR_PINMUX_GENERALIO29_OFST 0xf4
14419
14420 /*
14421  * Register : spis0_miso Mux Selection Register - GENERALIO30
14422  *
14423  * This register is used to control the peripherals connected to spis0_miso
14424  *
14425  * Only reset by a cold reset (ignores warm reset).
14426  *
14427  * NOTE: These registers should not be modified after IO configuration.There is no
14428  * support for dynamically changing the Pin Mux selections.
14429  *
14430  * Register Layout
14431  *
14432  * Bits | Access | Reset | Description
14433  * :-------|:-------|:------|:-------------------------------
14434  * [1:0] | RW | 0x0 | spis0_miso Mux Selection Field
14435  * [31:2] | ??? | 0x0 | *UNDEFINED*
14436  *
14437  */
14438 /*
14439  * Field : spis0_miso Mux Selection Field - sel
14440  *
14441  * Select peripheral signals connected spis0_miso.
14442  *
14443  * 0 : Pin is connected to GPIO/LoanIO number 69.
14444  *
14445  * 1 : Pin is connected to Peripheral signal not applicable.
14446  *
14447  * 2 : Pin is connected to Peripheral signal not applicable.
14448  *
14449  * 3 : Pin is connected to Peripheral signal SPIS0.MISO.
14450  *
14451  * Field Access Macros:
14452  *
14453  */
14454 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
14455 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_LSB 0
14456 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
14457 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_MSB 1
14458 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
14459 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_WIDTH 2
14460 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field value. */
14461 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_SET_MSK 0x00000003
14462 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field value. */
14463 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_CLR_MSK 0xfffffffc
14464 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
14465 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_RESET 0x0
14466 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO30_SEL field value from a register. */
14467 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_GET(value) (((value) & 0x00000003) >> 0)
14468 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field value suitable for setting the register. */
14469 #define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_SET(value) (((value) << 0) & 0x00000003)
14470
14471 #ifndef __ASSEMBLY__
14472 /*
14473  * WARNING: The C register and register group struct declarations are provided for
14474  * convenience and illustrative purposes. They should, however, be used with
14475  * caution as the C language standard provides no guarantees about the alignment or
14476  * atomicity of device memory accesses. The recommended practice for writing
14477  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14478  * alt_write_word() functions.
14479  *
14480  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO30.
14481  */
14483 {
14484  uint32_t sel : 2; /* spis0_miso Mux Selection Field */
14485  uint32_t : 30; /* *UNDEFINED* */
14486 };
14487
14488 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO30. */
14489 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO30_s ALT_SYSMGR_PINMUX_GENERALIO30_t;
14490 #endif /* __ASSEMBLY__ */
14491
14492 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO30 register from the beginning of the component. */
14493 #define ALT_SYSMGR_PINMUX_GENERALIO30_OFST 0xf8
14494
14495 /*
14496  * Register : spis0_ss0 Mux Selection Register - GENERALIO31
14497  *
14498  * This register is used to control the peripherals connected to spis0_ss0
14499  *
14500  * Only reset by a cold reset (ignores warm reset).
14501  *
14502  * NOTE: These registers should not be modified after IO configuration.There is no
14503  * support for dynamically changing the Pin Mux selections.
14504  *
14505  * Register Layout
14506  *
14507  * Bits | Access | Reset | Description
14508  * :-------|:-------|:------|:------------------------------
14509  * [1:0] | RW | 0x0 | spis0_ss0 Mux Selection Field
14510  * [31:2] | ??? | 0x0 | *UNDEFINED*
14511  *
14512  */
14513 /*
14514  * Field : spis0_ss0 Mux Selection Field - sel
14515  *
14516  * Select peripheral signals connected spis0_ss0.
14517  *
14518  * 0 : Pin is connected to GPIO/LoanIO number 70.
14519  *
14520  * 1 : Pin is connected to Peripheral signal not applicable.
14521  *
14522  * 2 : Pin is connected to Peripheral signal not applicable.
14523  *
14524  * 3 : Pin is connected to Peripheral signal SPIS0.SS0.
14525  *
14526  * Field Access Macros:
14527  *
14528  */
14529 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
14530 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_LSB 0
14531 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
14532 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_MSB 1
14533 /* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
14534 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_WIDTH 2
14535 /* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field value. */
14536 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_SET_MSK 0x00000003
14537 /* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field value. */
14538 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_CLR_MSK 0xfffffffc
14539 /* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
14540 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_RESET 0x0
14541 /* Extracts the ALT_SYSMGR_PINMUX_GENERALIO31_SEL field value from a register. */
14542 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_GET(value) (((value) & 0x00000003) >> 0)
14543 /* Produces a ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field value suitable for setting the register. */
14544 #define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_SET(value) (((value) << 0) & 0x00000003)
14545
14546 #ifndef __ASSEMBLY__
14547 /*
14548  * WARNING: The C register and register group struct declarations are provided for
14549  * convenience and illustrative purposes. They should, however, be used with
14550  * caution as the C language standard provides no guarantees about the alignment or
14551  * atomicity of device memory accesses. The recommended practice for writing
14552  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14553  * alt_write_word() functions.
14554  *
14555  * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO31.
14556  */
14558 {
14559  uint32_t sel : 2; /* spis0_ss0 Mux Selection Field */
14560  uint32_t : 30; /* *UNDEFINED* */
14561 };
14562
14563 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO31. */
14564 typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO31_s ALT_SYSMGR_PINMUX_GENERALIO31_t;
14565 #endif /* __ASSEMBLY__ */
14566
14567 /* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO31 register from the beginning of the component. */
14568 #define ALT_SYSMGR_PINMUX_GENERALIO31_OFST 0xfc
14569
14570 /*
14571  * Register : nand_ale Mux Selection Register - MIXED1IO0
14572  *
14573  * This register is used to control the peripherals connected to nand_ale
14574  *
14575  * Only reset by a cold reset (ignores warm reset).
14576  *
14577  * NOTE: These registers should not be modified after IO configuration.There is no
14578  * support for dynamically changing the Pin Mux selections.
14579  *
14580  * Register Layout
14581  *
14582  * Bits | Access | Reset | Description
14583  * :-------|:-------|:------|:-----------------------------
14584  * [1:0] | RW | 0x0 | nand_ale Mux Selection Field
14585  * [31:2] | ??? | 0x0 | *UNDEFINED*
14586  *
14587  */
14588 /*
14589  * Field : nand_ale Mux Selection Field - sel
14590  *
14591  * Select peripheral signals connected nand_ale.
14592  *
14593  * 0 : Pin is connected to GPIO/LoanIO number 14.
14594  *
14595  * 1 : Pin is connected to Peripheral signal QSPI.SS3.
14596  *
14597  * 2 : Pin is connected to Peripheral signal RGMII1.TX_CLK.
14598  *
14599  * 3 : Pin is connected to Peripheral signal NAND.ale.
14600  *
14601  * Field Access Macros:
14602  *
14603  */
14604 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
14605 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_LSB 0
14606 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
14607 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_MSB 1
14608 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
14609 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_WIDTH 2
14610 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field value. */
14611 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_SET_MSK 0x00000003
14612 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field value. */
14613 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_CLR_MSK 0xfffffffc
14614 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
14615 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_RESET 0x0
14616 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL field value from a register. */
14617 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
14618 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field value suitable for setting the register. */
14619 #define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_SET(value) (((value) << 0) & 0x00000003)
14620
14621 #ifndef __ASSEMBLY__
14622 /*
14623  * WARNING: The C register and register group struct declarations are provided for
14624  * convenience and illustrative purposes. They should, however, be used with
14625  * caution as the C language standard provides no guarantees about the alignment or
14626  * atomicity of device memory accesses. The recommended practice for writing
14627  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14628  * alt_write_word() functions.
14629  *
14630  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO0.
14631  */
14633 {
14634  uint32_t sel : 2; /* nand_ale Mux Selection Field */
14635  uint32_t : 30; /* *UNDEFINED* */
14636 };
14637
14638 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO0. */
14639 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO0_s ALT_SYSMGR_PINMUX_MIXED1IO0_t;
14640 #endif /* __ASSEMBLY__ */
14641
14642 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO0 register from the beginning of the component. */
14643 #define ALT_SYSMGR_PINMUX_MIXED1IO0_OFST 0x100
14644
14645 /*
14646  * Register : nand_ce Mux Selection Register - MIXED1IO1
14647  *
14648  * This register is used to control the peripherals connected to nand_ce
14649  *
14650  * Only reset by a cold reset (ignores warm reset).
14651  *
14652  * NOTE: These registers should not be modified after IO configuration.There is no
14653  * support for dynamically changing the Pin Mux selections.
14654  *
14655  * Register Layout
14656  *
14657  * Bits | Access | Reset | Description
14658  * :-------|:-------|:------|:----------------------------
14659  * [1:0] | RW | 0x0 | nand_ce Mux Selection Field
14660  * [31:2] | ??? | 0x0 | *UNDEFINED*
14661  *
14662  */
14663 /*
14664  * Field : nand_ce Mux Selection Field - sel
14665  *
14666  * Select peripheral signals connected nand_ce.
14667  *
14668  * 0 : Pin is connected to GPIO/LoanIO number 15.
14669  *
14670  * 1 : Pin is connected to Peripheral signal USB1.D0.
14671  *
14672  * 2 : Pin is connected to Peripheral signal RGMII1.TXD0.
14673  *
14674  * 3 : Pin is connected to Peripheral signal NAND.ce.
14675  *
14676  * Field Access Macros:
14677  *
14678  */
14679 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
14680 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_LSB 0
14681 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
14682 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_MSB 1
14683 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
14684 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_WIDTH 2
14685 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field value. */
14686 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_SET_MSK 0x00000003
14687 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field value. */
14688 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_CLR_MSK 0xfffffffc
14689 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
14690 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_RESET 0x0
14691 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL field value from a register. */
14692 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
14693 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field value suitable for setting the register. */
14694 #define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_SET(value) (((value) << 0) & 0x00000003)
14695
14696 #ifndef __ASSEMBLY__
14697 /*
14698  * WARNING: The C register and register group struct declarations are provided for
14699  * convenience and illustrative purposes. They should, however, be used with
14700  * caution as the C language standard provides no guarantees about the alignment or
14701  * atomicity of device memory accesses. The recommended practice for writing
14702  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14703  * alt_write_word() functions.
14704  *
14705  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO1.
14706  */
14708 {
14709  uint32_t sel : 2; /* nand_ce Mux Selection Field */
14710  uint32_t : 30; /* *UNDEFINED* */
14711 };
14712
14713 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO1. */
14714 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO1_s ALT_SYSMGR_PINMUX_MIXED1IO1_t;
14715 #endif /* __ASSEMBLY__ */
14716
14717 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO1 register from the beginning of the component. */
14718 #define ALT_SYSMGR_PINMUX_MIXED1IO1_OFST 0x104
14719
14720 /*
14721  * Register : nand_cle Mux Selection Register - MIXED1IO2
14722  *
14723  * This register is used to control the peripherals connected to nand_cle
14724  *
14725  * Only reset by a cold reset (ignores warm reset).
14726  *
14727  * NOTE: These registers should not be modified after IO configuration.There is no
14728  * support for dynamically changing the Pin Mux selections.
14729  *
14730  * Register Layout
14731  *
14732  * Bits | Access | Reset | Description
14733  * :-------|:-------|:------|:-----------------------------
14734  * [1:0] | RW | 0x0 | nand_cle Mux Selection Field
14735  * [31:2] | ??? | 0x0 | *UNDEFINED*
14736  *
14737  */
14738 /*
14739  * Field : nand_cle Mux Selection Field - sel
14740  *
14741  * Select peripheral signals connected nand_cle.
14742  *
14743  * 0 : Pin is connected to GPIO/LoanIO number 16.
14744  *
14745  * 1 : Pin is connected to Peripheral signal USB1.D1.
14746  *
14747  * 2 : Pin is connected to Peripheral signal RGMII1.TXD1.
14748  *
14749  * 3 : Pin is connected to Peripheral signal NAND.cle.
14750  *
14751  * Field Access Macros:
14752  *
14753  */
14754 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
14755 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_LSB 0
14756 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
14757 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_MSB 1
14758 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
14759 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_WIDTH 2
14760 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field value. */
14761 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_SET_MSK 0x00000003
14762 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field value. */
14763 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_CLR_MSK 0xfffffffc
14764 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
14765 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_RESET 0x0
14766 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL field value from a register. */
14767 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
14768 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field value suitable for setting the register. */
14769 #define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_SET(value) (((value) << 0) & 0x00000003)
14770
14771 #ifndef __ASSEMBLY__
14772 /*
14773  * WARNING: The C register and register group struct declarations are provided for
14774  * convenience and illustrative purposes. They should, however, be used with
14775  * caution as the C language standard provides no guarantees about the alignment or
14776  * atomicity of device memory accesses. The recommended practice for writing
14777  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14778  * alt_write_word() functions.
14779  *
14780  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO2.
14781  */
14783 {
14784  uint32_t sel : 2; /* nand_cle Mux Selection Field */
14785  uint32_t : 30; /* *UNDEFINED* */
14786 };
14787
14788 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO2. */
14789 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO2_s ALT_SYSMGR_PINMUX_MIXED1IO2_t;
14790 #endif /* __ASSEMBLY__ */
14791
14792 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO2 register from the beginning of the component. */
14793 #define ALT_SYSMGR_PINMUX_MIXED1IO2_OFST 0x108
14794
14795 /*
14796  * Register : nand_re Mux Selection Register - MIXED1IO3
14797  *
14798  * This register is used to control the peripherals connected to nand_re
14799  *
14800  * Only reset by a cold reset (ignores warm reset).
14801  *
14802  * NOTE: These registers should not be modified after IO configuration.There is no
14803  * support for dynamically changing the Pin Mux selections.
14804  *
14805  * Register Layout
14806  *
14807  * Bits | Access | Reset | Description
14808  * :-------|:-------|:------|:----------------------------
14809  * [1:0] | RW | 0x0 | nand_re Mux Selection Field
14810  * [31:2] | ??? | 0x0 | *UNDEFINED*
14811  *
14812  */
14813 /*
14814  * Field : nand_re Mux Selection Field - sel
14815  *
14816  * Select peripheral signals connected nand_re.
14817  *
14818  * 0 : Pin is connected to GPIO/LoanIO number 17.
14819  *
14820  * 1 : Pin is connected to Peripheral signal USB1.D2.
14821  *
14822  * 2 : Pin is connected to Peripheral signal RGMII1.TXD2.
14823  *
14824  * 3 : Pin is connected to Peripheral signal NAND.re.
14825  *
14826  * Field Access Macros:
14827  *
14828  */
14829 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
14830 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_LSB 0
14831 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
14832 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_MSB 1
14833 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
14834 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_WIDTH 2
14835 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field value. */
14836 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_SET_MSK 0x00000003
14837 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field value. */
14838 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_CLR_MSK 0xfffffffc
14839 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
14840 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_RESET 0x0
14841 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL field value from a register. */
14842 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
14843 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field value suitable for setting the register. */
14844 #define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_SET(value) (((value) << 0) & 0x00000003)
14845
14846 #ifndef __ASSEMBLY__
14847 /*
14848  * WARNING: The C register and register group struct declarations are provided for
14849  * convenience and illustrative purposes. They should, however, be used with
14850  * caution as the C language standard provides no guarantees about the alignment or
14851  * atomicity of device memory accesses. The recommended practice for writing
14852  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14853  * alt_write_word() functions.
14854  *
14855  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO3.
14856  */
14858 {
14859  uint32_t sel : 2; /* nand_re Mux Selection Field */
14860  uint32_t : 30; /* *UNDEFINED* */
14861 };
14862
14863 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO3. */
14864 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO3_s ALT_SYSMGR_PINMUX_MIXED1IO3_t;
14865 #endif /* __ASSEMBLY__ */
14866
14867 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO3 register from the beginning of the component. */
14868 #define ALT_SYSMGR_PINMUX_MIXED1IO3_OFST 0x10c
14869
14870 /*
14871  * Register : nand_rb Mux Selection Register - MIXED1IO4
14872  *
14873  * This register is used to control the peripherals connected to nand_rb
14874  *
14875  * Only reset by a cold reset (ignores warm reset).
14876  *
14877  * NOTE: These registers should not be modified after IO configuration.There is no
14878  * support for dynamically changing the Pin Mux selections.
14879  *
14880  * Register Layout
14881  *
14882  * Bits | Access | Reset | Description
14883  * :-------|:-------|:------|:----------------------------
14884  * [1:0] | RW | 0x0 | nand_rb Mux Selection Field
14885  * [31:2] | ??? | 0x0 | *UNDEFINED*
14886  *
14887  */
14888 /*
14889  * Field : nand_rb Mux Selection Field - sel
14890  *
14891  * Select peripheral signals connected nand_rb.
14892  *
14893  * 0 : Pin is connected to GPIO/LoanIO number 18.
14894  *
14895  * 1 : Pin is connected to Peripheral signal USB1.D3.
14896  *
14897  * 2 : Pin is connected to Peripheral signal RGMII1.TXD3.
14898  *
14899  * 3 : Pin is connected to Peripheral signal NAND.rb.
14900  *
14901  * Field Access Macros:
14902  *
14903  */
14904 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
14905 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_LSB 0
14906 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
14907 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_MSB 1
14908 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
14909 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_WIDTH 2
14910 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field value. */
14911 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_SET_MSK 0x00000003
14912 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field value. */
14913 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_CLR_MSK 0xfffffffc
14914 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
14915 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_RESET 0x0
14916 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL field value from a register. */
14917 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
14918 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field value suitable for setting the register. */
14919 #define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_SET(value) (((value) << 0) & 0x00000003)
14920
14921 #ifndef __ASSEMBLY__
14922 /*
14923  * WARNING: The C register and register group struct declarations are provided for
14924  * convenience and illustrative purposes. They should, however, be used with
14925  * caution as the C language standard provides no guarantees about the alignment or
14926  * atomicity of device memory accesses. The recommended practice for writing
14927  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
14928  * alt_write_word() functions.
14929  *
14930  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO4.
14931  */
14933 {
14934  uint32_t sel : 2; /* nand_rb Mux Selection Field */
14935  uint32_t : 30; /* *UNDEFINED* */
14936 };
14937
14938 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO4. */
14939 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO4_s ALT_SYSMGR_PINMUX_MIXED1IO4_t;
14940 #endif /* __ASSEMBLY__ */
14941
14942 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO4 register from the beginning of the component. */
14943 #define ALT_SYSMGR_PINMUX_MIXED1IO4_OFST 0x110
14944
14945 /*
14946  * Register : nand_dq0 Mux Selection Register - MIXED1IO5
14947  *
14948  * This register is used to control the peripherals connected to nand_dq0
14949  *
14950  * Only reset by a cold reset (ignores warm reset).
14951  *
14952  * NOTE: These registers should not be modified after IO configuration.There is no
14953  * support for dynamically changing the Pin Mux selections.
14954  *
14955  * Register Layout
14956  *
14957  * Bits | Access | Reset | Description
14958  * :-------|:-------|:------|:-----------------------------
14959  * [1:0] | RW | 0x0 | nand_dq0 Mux Selection Field
14960  * [31:2] | ??? | 0x0 | *UNDEFINED*
14961  *
14962  */
14963 /*
14964  * Field : nand_dq0 Mux Selection Field - sel
14965  *
14966  * Select peripheral signals connected nand_dq0.
14967  *
14968  * 0 : Pin is connected to GPIO/LoanIO number 19.
14969  *
14970  * 1 : Pin is connected to Peripheral signal not applicable.
14971  *
14972  * 2 : Pin is connected to Peripheral signal RGMII1.RXD0.
14973  *
14974  * 3 : Pin is connected to Peripheral signal NAND.dq0.
14975  *
14976  * Field Access Macros:
14977  *
14978  */
14979 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
14980 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_LSB 0
14981 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
14982 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_MSB 1
14983 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
14984 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_WIDTH 2
14985 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field value. */
14986 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_SET_MSK 0x00000003
14987 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field value. */
14988 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_CLR_MSK 0xfffffffc
14989 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
14990 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_RESET 0x0
14991 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL field value from a register. */
14992 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
14993 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field value suitable for setting the register. */
14994 #define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_SET(value) (((value) << 0) & 0x00000003)
14995
14996 #ifndef __ASSEMBLY__
14997 /*
14998  * WARNING: The C register and register group struct declarations are provided for
14999  * convenience and illustrative purposes. They should, however, be used with
15000  * caution as the C language standard provides no guarantees about the alignment or
15001  * atomicity of device memory accesses. The recommended practice for writing
15002  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15003  * alt_write_word() functions.
15004  *
15005  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO5.
15006  */
15008 {
15009  uint32_t sel : 2; /* nand_dq0 Mux Selection Field */
15010  uint32_t : 30; /* *UNDEFINED* */
15011 };
15012
15013 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO5. */
15014 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO5_s ALT_SYSMGR_PINMUX_MIXED1IO5_t;
15015 #endif /* __ASSEMBLY__ */
15016
15017 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO5 register from the beginning of the component. */
15018 #define ALT_SYSMGR_PINMUX_MIXED1IO5_OFST 0x114
15019
15020 /*
15021  * Register : nand_dq1 Mux Selection Register - MIXED1IO6
15022  *
15023  * This register is used to control the peripherals connected to nand_dq1
15024  *
15025  * Only reset by a cold reset (ignores warm reset).
15026  *
15027  * NOTE: These registers should not be modified after IO configuration.There is no
15028  * support for dynamically changing the Pin Mux selections.
15029  *
15030  * Register Layout
15031  *
15032  * Bits | Access | Reset | Description
15033  * :-------|:-------|:------|:-----------------------------
15034  * [1:0] | RW | 0x0 | nand_dq1 Mux Selection Field
15035  * [31:2] | ??? | 0x0 | *UNDEFINED*
15036  *
15037  */
15038 /*
15039  * Field : nand_dq1 Mux Selection Field - sel
15040  *
15041  * Select peripheral signals connected nand_dq1.
15042  *
15043  * 0 : Pin is connected to GPIO/LoanIO number 20.
15044  *
15045  * 1 : Pin is connected to Peripheral signal I2C3.SDA.
15046  *
15047  * 2 : Pin is connected to Peripheral signal RGMII1.MDIO.
15048  *
15049  * 3 : Pin is connected to Peripheral signal NAND.dq1.
15050  *
15051  * Field Access Macros:
15052  *
15053  */
15054 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
15055 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_LSB 0
15056 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
15057 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_MSB 1
15058 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
15059 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_WIDTH 2
15060 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field value. */
15061 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_SET_MSK 0x00000003
15062 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field value. */
15063 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_CLR_MSK 0xfffffffc
15064 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
15065 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_RESET 0x0
15066 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL field value from a register. */
15067 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
15068 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field value suitable for setting the register. */
15069 #define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_SET(value) (((value) << 0) & 0x00000003)
15070
15071 #ifndef __ASSEMBLY__
15072 /*
15073  * WARNING: The C register and register group struct declarations are provided for
15074  * convenience and illustrative purposes. They should, however, be used with
15075  * caution as the C language standard provides no guarantees about the alignment or
15076  * atomicity of device memory accesses. The recommended practice for writing
15077  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15078  * alt_write_word() functions.
15079  *
15080  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO6.
15081  */
15083 {
15084  uint32_t sel : 2; /* nand_dq1 Mux Selection Field */
15085  uint32_t : 30; /* *UNDEFINED* */
15086 };
15087
15088 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO6. */
15089 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO6_s ALT_SYSMGR_PINMUX_MIXED1IO6_t;
15090 #endif /* __ASSEMBLY__ */
15091
15092 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO6 register from the beginning of the component. */
15093 #define ALT_SYSMGR_PINMUX_MIXED1IO6_OFST 0x118
15094
15095 /*
15096  * Register : nand_dq2 Mux Selection Register - MIXED1IO7
15097  *
15098  * This register is used to control the peripherals connected to nand_dq2
15099  *
15100  * Only reset by a cold reset (ignores warm reset).
15101  *
15102  * NOTE: These registers should not be modified after IO configuration.There is no
15103  * support for dynamically changing the Pin Mux selections.
15104  *
15105  * Register Layout
15106  *
15107  * Bits | Access | Reset | Description
15108  * :-------|:-------|:------|:-----------------------------
15109  * [1:0] | RW | 0x0 | nand_dq2 Mux Selection Field
15110  * [31:2] | ??? | 0x0 | *UNDEFINED*
15111  *
15112  */
15113 /*
15114  * Field : nand_dq2 Mux Selection Field - sel
15115  *
15116  * Select peripheral signals connected nand_dq2.
15117  *
15118  * 0 : Pin is connected to GPIO/LoanIO number 21.
15119  *
15120  * 1 : Pin is connected to Peripheral signal I2C3.SCL.
15121  *
15122  * 2 : Pin is connected to Peripheral signal RGMII1.MDC.
15123  *
15124  * 3 : Pin is connected to Peripheral signal NAND.dq2.
15125  *
15126  * Field Access Macros:
15127  *
15128  */
15129 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
15130 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_LSB 0
15131 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
15132 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_MSB 1
15133 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
15134 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_WIDTH 2
15135 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field value. */
15136 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_SET_MSK 0x00000003
15137 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field value. */
15138 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_CLR_MSK 0xfffffffc
15139 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
15140 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_RESET 0x0
15141 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL field value from a register. */
15142 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
15143 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field value suitable for setting the register. */
15144 #define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_SET(value) (((value) << 0) & 0x00000003)
15145
15146 #ifndef __ASSEMBLY__
15147 /*
15148  * WARNING: The C register and register group struct declarations are provided for
15149  * convenience and illustrative purposes. They should, however, be used with
15150  * caution as the C language standard provides no guarantees about the alignment or
15151  * atomicity of device memory accesses. The recommended practice for writing
15152  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15153  * alt_write_word() functions.
15154  *
15155  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO7.
15156  */
15158 {
15159  uint32_t sel : 2; /* nand_dq2 Mux Selection Field */
15160  uint32_t : 30; /* *UNDEFINED* */
15161 };
15162
15163 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO7. */
15164 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO7_s ALT_SYSMGR_PINMUX_MIXED1IO7_t;
15165 #endif /* __ASSEMBLY__ */
15166
15167 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO7 register from the beginning of the component. */
15168 #define ALT_SYSMGR_PINMUX_MIXED1IO7_OFST 0x11c
15169
15170 /*
15171  * Register : nand_dq3 Mux Selection Register - MIXED1IO8
15172  *
15173  * This register is used to control the peripherals connected to nand_dq3
15174  *
15175  * Only reset by a cold reset (ignores warm reset).
15176  *
15177  * NOTE: These registers should not be modified after IO configuration.There is no
15178  * support for dynamically changing the Pin Mux selections.
15179  *
15180  * Register Layout
15181  *
15182  * Bits | Access | Reset | Description
15183  * :-------|:-------|:------|:-----------------------------
15184  * [1:0] | RW | 0x0 | nand_dq3 Mux Selection Field
15185  * [31:2] | ??? | 0x0 | *UNDEFINED*
15186  *
15187  */
15188 /*
15189  * Field : nand_dq3 Mux Selection Field - sel
15190  *
15191  * Select peripheral signals connected nand_dq3.
15192  *
15193  * 0 : Pin is connected to GPIO/LoanIO number 22.
15194  *
15195  * 1 : Pin is connected to Peripheral signal USB1.D4.
15196  *
15197  * 2 : Pin is connected to Peripheral signal RGMII1.RX_CTL.
15198  *
15199  * 3 : Pin is connected to Peripheral signal NAND.dq3.
15200  *
15201  * Field Access Macros:
15202  *
15203  */
15204 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
15205 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_LSB 0
15206 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
15207 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_MSB 1
15208 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
15209 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_WIDTH 2
15210 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field value. */
15211 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_SET_MSK 0x00000003
15212 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field value. */
15213 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_CLR_MSK 0xfffffffc
15214 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
15215 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_RESET 0x0
15216 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL field value from a register. */
15217 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
15218 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field value suitable for setting the register. */
15219 #define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_SET(value) (((value) << 0) & 0x00000003)
15220
15221 #ifndef __ASSEMBLY__
15222 /*
15223  * WARNING: The C register and register group struct declarations are provided for
15224  * convenience and illustrative purposes. They should, however, be used with
15225  * caution as the C language standard provides no guarantees about the alignment or
15226  * atomicity of device memory accesses. The recommended practice for writing
15227  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15228  * alt_write_word() functions.
15229  *
15230  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO8.
15231  */
15233 {
15234  uint32_t sel : 2; /* nand_dq3 Mux Selection Field */
15235  uint32_t : 30; /* *UNDEFINED* */
15236 };
15237
15238 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO8. */
15239 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO8_s ALT_SYSMGR_PINMUX_MIXED1IO8_t;
15240 #endif /* __ASSEMBLY__ */
15241
15242 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO8 register from the beginning of the component. */
15243 #define ALT_SYSMGR_PINMUX_MIXED1IO8_OFST 0x120
15244
15245 /*
15246  * Register : nand_dq4 Mux Selection Register - MIXED1IO9
15247  *
15248  * This register is used to control the peripherals connected to nand_dq4
15249  *
15250  * Only reset by a cold reset (ignores warm reset).
15251  *
15252  * NOTE: These registers should not be modified after IO configuration.There is no
15253  * support for dynamically changing the Pin Mux selections.
15254  *
15255  * Register Layout
15256  *
15257  * Bits | Access | Reset | Description
15258  * :-------|:-------|:------|:-----------------------------
15259  * [1:0] | RW | 0x0 | nand_dq4 Mux Selection Field
15260  * [31:2] | ??? | 0x0 | *UNDEFINED*
15261  *
15262  */
15263 /*
15264  * Field : nand_dq4 Mux Selection Field - sel
15265  *
15266  * Select peripheral signals connected nand_dq4.
15267  *
15268  * 0 : Pin is connected to GPIO/LoanIO number 23.
15269  *
15270  * 1 : Pin is connected to Peripheral signal USB1.D5.
15271  *
15272  * 2 : Pin is connected to Peripheral signal RGMII1.TX_CTL.
15273  *
15274  * 3 : Pin is connected to Peripheral signal NAND.dq4.
15275  *
15276  * Field Access Macros:
15277  *
15278  */
15279 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
15280 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_LSB 0
15281 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
15282 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_MSB 1
15283 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
15284 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_WIDTH 2
15285 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field value. */
15286 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_SET_MSK 0x00000003
15287 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field value. */
15288 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_CLR_MSK 0xfffffffc
15289 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
15290 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_RESET 0x0
15291 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL field value from a register. */
15292 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
15293 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field value suitable for setting the register. */
15294 #define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_SET(value) (((value) << 0) & 0x00000003)
15295
15296 #ifndef __ASSEMBLY__
15297 /*
15298  * WARNING: The C register and register group struct declarations are provided for
15299  * convenience and illustrative purposes. They should, however, be used with
15300  * caution as the C language standard provides no guarantees about the alignment or
15301  * atomicity of device memory accesses. The recommended practice for writing
15302  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15303  * alt_write_word() functions.
15304  *
15305  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO9.
15306  */
15308 {
15309  uint32_t sel : 2; /* nand_dq4 Mux Selection Field */
15310  uint32_t : 30; /* *UNDEFINED* */
15311 };
15312
15313 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO9. */
15314 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO9_s ALT_SYSMGR_PINMUX_MIXED1IO9_t;
15315 #endif /* __ASSEMBLY__ */
15316
15317 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO9 register from the beginning of the component. */
15318 #define ALT_SYSMGR_PINMUX_MIXED1IO9_OFST 0x124
15319
15320 /*
15321  * Register : nand_dq5 Mux Selection Register - MIXED1IO10
15322  *
15323  * This register is used to control the peripherals connected to nand_dq5
15324  *
15325  * Only reset by a cold reset (ignores warm reset).
15326  *
15327  * NOTE: These registers should not be modified after IO configuration.There is no
15328  * support for dynamically changing the Pin Mux selections.
15329  *
15330  * Register Layout
15331  *
15332  * Bits | Access | Reset | Description
15333  * :-------|:-------|:------|:-----------------------------
15334  * [1:0] | RW | 0x0 | nand_dq5 Mux Selection Field
15335  * [31:2] | ??? | 0x0 | *UNDEFINED*
15336  *
15337  */
15338 /*
15339  * Field : nand_dq5 Mux Selection Field - sel
15340  *
15341  * Select peripheral signals connected nand_dq5.
15342  *
15343  * 0 : Pin is connected to GPIO/LoanIO number 24.
15344  *
15345  * 1 : Pin is connected to Peripheral signal USB1.D6.
15346  *
15347  * 2 : Pin is connected to Peripheral signal RGMII1.RX_CLK.
15348  *
15349  * 3 : Pin is connected to Peripheral signal NAND.dq5.
15350  *
15351  * Field Access Macros:
15352  *
15353  */
15354 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO10_SEL register field. */
15355 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_LSB 0
15356 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO10_SEL register field. */
15357 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_MSB 1
15358 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO10_SEL register field. */
15359 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_WIDTH 2
15360 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO10_SEL register field value. */
15361 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_SET_MSK 0x00000003
15362 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO10_SEL register field value. */
15363 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_CLR_MSK 0xfffffffc
15364 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO10_SEL register field. */
15365 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_RESET 0x0
15366 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO10_SEL field value from a register. */
15367 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_GET(value) (((value) & 0x00000003) >> 0)
15368 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO10_SEL register field value suitable for setting the register. */
15369 #define ALT_SYSMGR_PINMUX_MIXED1IO10_SEL_SET(value) (((value) << 0) & 0x00000003)
15370
15371 #ifndef __ASSEMBLY__
15372 /*
15373  * WARNING: The C register and register group struct declarations are provided for
15374  * convenience and illustrative purposes. They should, however, be used with
15375  * caution as the C language standard provides no guarantees about the alignment or
15376  * atomicity of device memory accesses. The recommended practice for writing
15377  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15378  * alt_write_word() functions.
15379  *
15380  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO10.
15381  */
15383 {
15384  uint32_t sel : 2; /* nand_dq5 Mux Selection Field */
15385  uint32_t : 30; /* *UNDEFINED* */
15386 };
15387
15388 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO10. */
15389 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO10_s ALT_SYSMGR_PINMUX_MIXED1IO10_t;
15390 #endif /* __ASSEMBLY__ */
15391
15392 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO10 register from the beginning of the component. */
15393 #define ALT_SYSMGR_PINMUX_MIXED1IO10_OFST 0x128
15394
15395 /*
15396  * Register : nand_dq6 Mux Selection Register - MIXED1IO11
15397  *
15398  * This register is used to control the peripherals connected to nand_dq6
15399  *
15400  * Only reset by a cold reset (ignores warm reset).
15401  *
15402  * NOTE: These registers should not be modified after IO configuration.There is no
15403  * support for dynamically changing the Pin Mux selections.
15404  *
15405  * Register Layout
15406  *
15407  * Bits | Access | Reset | Description
15408  * :-------|:-------|:------|:-----------------------------
15409  * [1:0] | RW | 0x0 | nand_dq6 Mux Selection Field
15410  * [31:2] | ??? | 0x0 | *UNDEFINED*
15411  *
15412  */
15413 /*
15414  * Field : nand_dq6 Mux Selection Field - sel
15415  *
15416  * Select peripheral signals connected nand_dq6.
15417  *
15418  * 0 : Pin is connected to GPIO/LoanIO number 25.
15419  *
15420  * 1 : Pin is connected to Peripheral signal USB1.D7.
15421  *
15422  * 2 : Pin is connected to Peripheral signal RGMII1.RXD1.
15423  *
15424  * 3 : Pin is connected to Peripheral signal NAND.dq6.
15425  *
15426  * Field Access Macros:
15427  *
15428  */
15429 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO11_SEL register field. */
15430 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_LSB 0
15431 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO11_SEL register field. */
15432 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_MSB 1
15433 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO11_SEL register field. */
15434 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_WIDTH 2
15435 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO11_SEL register field value. */
15436 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_SET_MSK 0x00000003
15437 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO11_SEL register field value. */
15438 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_CLR_MSK 0xfffffffc
15439 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO11_SEL register field. */
15440 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_RESET 0x0
15441 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO11_SEL field value from a register. */
15442 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_GET(value) (((value) & 0x00000003) >> 0)
15443 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO11_SEL register field value suitable for setting the register. */
15444 #define ALT_SYSMGR_PINMUX_MIXED1IO11_SEL_SET(value) (((value) << 0) & 0x00000003)
15445
15446 #ifndef __ASSEMBLY__
15447 /*
15448  * WARNING: The C register and register group struct declarations are provided for
15449  * convenience and illustrative purposes. They should, however, be used with
15450  * caution as the C language standard provides no guarantees about the alignment or
15451  * atomicity of device memory accesses. The recommended practice for writing
15452  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15453  * alt_write_word() functions.
15454  *
15455  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO11.
15456  */
15458 {
15459  uint32_t sel : 2; /* nand_dq6 Mux Selection Field */
15460  uint32_t : 30; /* *UNDEFINED* */
15461 };
15462
15463 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO11. */
15464 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO11_s ALT_SYSMGR_PINMUX_MIXED1IO11_t;
15465 #endif /* __ASSEMBLY__ */
15466
15467 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO11 register from the beginning of the component. */
15468 #define ALT_SYSMGR_PINMUX_MIXED1IO11_OFST 0x12c
15469
15470 /*
15471  * Register : nand_dq7 Mux Selection Register - MIXED1IO12
15472  *
15473  * This register is used to control the peripherals connected to nand_dq7
15474  *
15475  * Only reset by a cold reset (ignores warm reset).
15476  *
15477  * NOTE: These registers should not be modified after IO configuration.There is no
15478  * support for dynamically changing the Pin Mux selections.
15479  *
15480  * Register Layout
15481  *
15482  * Bits | Access | Reset | Description
15483  * :-------|:-------|:------|:-----------------------------
15484  * [1:0] | RW | 0x0 | nand_dq7 Mux Selection Field
15485  * [31:2] | ??? | 0x0 | *UNDEFINED*
15486  *
15487  */
15488 /*
15489  * Field : nand_dq7 Mux Selection Field - sel
15490  *
15491  * Select peripheral signals connected nand_dq7.
15492  *
15493  * 0 : Pin is connected to GPIO/LoanIO number 26.
15494  *
15495  * 1 : Pin is connected to Peripheral signal not applicable.
15496  *
15497  * 2 : Pin is connected to Peripheral signal RGMII1.RXD2.
15498  *
15499  * 3 : Pin is connected to Peripheral signal NAND.dq7.
15500  *
15501  * Field Access Macros:
15502  *
15503  */
15504 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO12_SEL register field. */
15505 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_LSB 0
15506 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO12_SEL register field. */
15507 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_MSB 1
15508 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO12_SEL register field. */
15509 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_WIDTH 2
15510 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO12_SEL register field value. */
15511 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_SET_MSK 0x00000003
15512 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO12_SEL register field value. */
15513 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_CLR_MSK 0xfffffffc
15514 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO12_SEL register field. */
15515 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_RESET 0x0
15516 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO12_SEL field value from a register. */
15517 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_GET(value) (((value) & 0x00000003) >> 0)
15518 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO12_SEL register field value suitable for setting the register. */
15519 #define ALT_SYSMGR_PINMUX_MIXED1IO12_SEL_SET(value) (((value) << 0) & 0x00000003)
15520
15521 #ifndef __ASSEMBLY__
15522 /*
15523  * WARNING: The C register and register group struct declarations are provided for
15524  * convenience and illustrative purposes. They should, however, be used with
15525  * caution as the C language standard provides no guarantees about the alignment or
15526  * atomicity of device memory accesses. The recommended practice for writing
15527  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15528  * alt_write_word() functions.
15529  *
15530  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO12.
15531  */
15533 {
15534  uint32_t sel : 2; /* nand_dq7 Mux Selection Field */
15535  uint32_t : 30; /* *UNDEFINED* */
15536 };
15537
15538 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO12. */
15539 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO12_s ALT_SYSMGR_PINMUX_MIXED1IO12_t;
15540 #endif /* __ASSEMBLY__ */
15541
15542 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO12 register from the beginning of the component. */
15543 #define ALT_SYSMGR_PINMUX_MIXED1IO12_OFST 0x130
15544
15545 /*
15546  * Register : nand_wp Mux Selection Register - MIXED1IO13
15547  *
15548  * This register is used to control the peripherals connected to nand_wp
15549  *
15550  * Only reset by a cold reset (ignores warm reset).
15551  *
15552  * NOTE: These registers should not be modified after IO configuration.There is no
15553  * support for dynamically changing the Pin Mux selections.
15554  *
15555  * Register Layout
15556  *
15557  * Bits | Access | Reset | Description
15558  * :-------|:-------|:------|:----------------------------
15559  * [1:0] | RW | 0x0 | nand_wp Mux Selection Field
15560  * [31:2] | ??? | 0x0 | *UNDEFINED*
15561  *
15562  */
15563 /*
15564  * Field : nand_wp Mux Selection Field - sel
15565  *
15566  * Select peripheral signals connected nand_wp.
15567  *
15568  * 0 : Pin is connected to GPIO/LoanIO number 27.
15569  *
15570  * 1 : Pin is connected to Peripheral signal QSPI.SS2.
15571  *
15572  * 2 : Pin is connected to Peripheral signal RGMII1.RXD3.
15573  *
15574  * 3 : Pin is connected to Peripheral signal NAND.wp.
15575  *
15576  * Field Access Macros:
15577  *
15578  */
15579 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO13_SEL register field. */
15580 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_LSB 0
15581 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO13_SEL register field. */
15582 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_MSB 1
15583 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO13_SEL register field. */
15584 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_WIDTH 2
15585 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO13_SEL register field value. */
15586 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_SET_MSK 0x00000003
15587 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO13_SEL register field value. */
15588 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_CLR_MSK 0xfffffffc
15589 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO13_SEL register field. */
15590 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_RESET 0x0
15591 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO13_SEL field value from a register. */
15592 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_GET(value) (((value) & 0x00000003) >> 0)
15593 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO13_SEL register field value suitable for setting the register. */
15594 #define ALT_SYSMGR_PINMUX_MIXED1IO13_SEL_SET(value) (((value) << 0) & 0x00000003)
15595
15596 #ifndef __ASSEMBLY__
15597 /*
15598  * WARNING: The C register and register group struct declarations are provided for
15599  * convenience and illustrative purposes. They should, however, be used with
15600  * caution as the C language standard provides no guarantees about the alignment or
15601  * atomicity of device memory accesses. The recommended practice for writing
15602  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15603  * alt_write_word() functions.
15604  *
15605  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO13.
15606  */
15608 {
15609  uint32_t sel : 2; /* nand_wp Mux Selection Field */
15610  uint32_t : 30; /* *UNDEFINED* */
15611 };
15612
15613 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO13. */
15614 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO13_s ALT_SYSMGR_PINMUX_MIXED1IO13_t;
15615 #endif /* __ASSEMBLY__ */
15616
15617 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO13 register from the beginning of the component. */
15618 #define ALT_SYSMGR_PINMUX_MIXED1IO13_OFST 0x134
15619
15620 /*
15621  * Register : nand_we Mux Selection Register - MIXED1IO14
15622  *
15623  * This register is used to control the peripherals connected to nand_we
15624  *
15625  * Only reset by a cold reset (ignores warm reset).
15626  *
15627  * NOTE: These registers should not be modified after IO configuration.There is no
15628  * support for dynamically changing the Pin Mux selections.
15629  *
15630  * Register Layout
15631  *
15632  * Bits | Access | Reset | Description
15633  * :-------|:-------|:------|:----------------------------
15634  * [1:0] | RW | 0x0 | nand_we Mux Selection Field
15635  * [31:2] | ??? | 0x0 | *UNDEFINED*
15636  *
15637  */
15638 /*
15639  * Field : nand_we Mux Selection Field - sel
15640  *
15641  * Select peripheral signals connected nand_we.
15642  *
15643  * 0 : Pin is connected to GPIO/LoanIO number 28.
15644  *
15645  * 1 : Pin is connected to Peripheral signal not applicable.
15646  *
15647  * 2 : Pin is connected to Peripheral signal QSPI.SS1.
15648  *
15649  * 3 : Pin is connected to Peripheral signal NAND.we.
15650  *
15651  * Field Access Macros:
15652  *
15653  */
15654 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO14_SEL register field. */
15655 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_LSB 0
15656 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO14_SEL register field. */
15657 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_MSB 1
15658 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO14_SEL register field. */
15659 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_WIDTH 2
15660 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO14_SEL register field value. */
15661 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_SET_MSK 0x00000003
15662 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO14_SEL register field value. */
15663 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_CLR_MSK 0xfffffffc
15664 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO14_SEL register field. */
15665 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_RESET 0x0
15666 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO14_SEL field value from a register. */
15667 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_GET(value) (((value) & 0x00000003) >> 0)
15668 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO14_SEL register field value suitable for setting the register. */
15669 #define ALT_SYSMGR_PINMUX_MIXED1IO14_SEL_SET(value) (((value) << 0) & 0x00000003)
15670
15671 #ifndef __ASSEMBLY__
15672 /*
15673  * WARNING: The C register and register group struct declarations are provided for
15674  * convenience and illustrative purposes. They should, however, be used with
15675  * caution as the C language standard provides no guarantees about the alignment or
15676  * atomicity of device memory accesses. The recommended practice for writing
15677  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15678  * alt_write_word() functions.
15679  *
15680  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO14.
15681  */
15683 {
15684  uint32_t sel : 2; /* nand_we Mux Selection Field */
15685  uint32_t : 30; /* *UNDEFINED* */
15686 };
15687
15688 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO14. */
15689 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO14_s ALT_SYSMGR_PINMUX_MIXED1IO14_t;
15690 #endif /* __ASSEMBLY__ */
15691
15692 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO14 register from the beginning of the component. */
15693 #define ALT_SYSMGR_PINMUX_MIXED1IO14_OFST 0x138
15694
15695 /*
15696  * Register : qspi_io0 Mux Selection Register - MIXED1IO15
15697  *
15698  * This register is used to control the peripherals connected to qspi_io0
15699  *
15700  * Only reset by a cold reset (ignores warm reset).
15701  *
15702  * NOTE: These registers should not be modified after IO configuration.There is no
15703  * support for dynamically changing the Pin Mux selections.
15704  *
15705  * Register Layout
15706  *
15707  * Bits | Access | Reset | Description
15708  * :-------|:-------|:------|:-----------------------------
15709  * [1:0] | RW | 0x0 | qspi_io0 Mux Selection Field
15710  * [31:2] | ??? | 0x0 | *UNDEFINED*
15711  *
15712  */
15713 /*
15714  * Field : qspi_io0 Mux Selection Field - sel
15715  *
15716  * Select peripheral signals connected qspi_io0.
15717  *
15718  * 0 : Pin is connected to GPIO/LoanIO number 29.
15719  *
15720  * 1 : Pin is connected to Peripheral signal USB1.CLK.
15721  *
15722  * 2 : Pin is connected to Peripheral signal not applicable.
15723  *
15724  * 3 : Pin is connected to Peripheral signal QSPI.IO0.
15725  *
15726  * Field Access Macros:
15727  *
15728  */
15729 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO15_SEL register field. */
15730 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_LSB 0
15731 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO15_SEL register field. */
15732 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_MSB 1
15733 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO15_SEL register field. */
15734 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_WIDTH 2
15735 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO15_SEL register field value. */
15736 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_SET_MSK 0x00000003
15737 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO15_SEL register field value. */
15738 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_CLR_MSK 0xfffffffc
15739 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO15_SEL register field. */
15740 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_RESET 0x0
15741 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO15_SEL field value from a register. */
15742 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_GET(value) (((value) & 0x00000003) >> 0)
15743 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO15_SEL register field value suitable for setting the register. */
15744 #define ALT_SYSMGR_PINMUX_MIXED1IO15_SEL_SET(value) (((value) << 0) & 0x00000003)
15745
15746 #ifndef __ASSEMBLY__
15747 /*
15748  * WARNING: The C register and register group struct declarations are provided for
15749  * convenience and illustrative purposes. They should, however, be used with
15750  * caution as the C language standard provides no guarantees about the alignment or
15751  * atomicity of device memory accesses. The recommended practice for writing
15752  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15753  * alt_write_word() functions.
15754  *
15755  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO15.
15756  */
15758 {
15759  uint32_t sel : 2; /* qspi_io0 Mux Selection Field */
15760  uint32_t : 30; /* *UNDEFINED* */
15761 };
15762
15763 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO15. */
15764 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO15_s ALT_SYSMGR_PINMUX_MIXED1IO15_t;
15765 #endif /* __ASSEMBLY__ */
15766
15767 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO15 register from the beginning of the component. */
15768 #define ALT_SYSMGR_PINMUX_MIXED1IO15_OFST 0x13c
15769
15770 /*
15771  * Register : qspi_io1 Mux Selection Register - MIXED1IO16
15772  *
15773  * This register is used to control the peripherals connected to qspi_io1
15774  *
15775  * Only reset by a cold reset (ignores warm reset).
15776  *
15777  * NOTE: These registers should not be modified after IO configuration.There is no
15778  * support for dynamically changing the Pin Mux selections.
15779  *
15780  * Register Layout
15781  *
15782  * Bits | Access | Reset | Description
15783  * :-------|:-------|:------|:-----------------------------
15784  * [1:0] | RW | 0x0 | qspi_io1 Mux Selection Field
15785  * [31:2] | ??? | 0x0 | *UNDEFINED*
15786  *
15787  */
15788 /*
15789  * Field : qspi_io1 Mux Selection Field - sel
15790  *
15791  * Select peripheral signals connected qspi_io1.
15792  *
15793  * 0 : Pin is connected to GPIO/LoanIO number 30.
15794  *
15795  * 1 : Pin is connected to Peripheral signal USB1.STP.
15796  *
15797  * 2 : Pin is connected to Peripheral signal not applicable.
15798  *
15799  * 3 : Pin is connected to Peripheral signal QSPI.IO1.
15800  *
15801  * Field Access Macros:
15802  *
15803  */
15804 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO16_SEL register field. */
15805 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_LSB 0
15806 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO16_SEL register field. */
15807 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_MSB 1
15808 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO16_SEL register field. */
15809 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_WIDTH 2
15810 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO16_SEL register field value. */
15811 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_SET_MSK 0x00000003
15812 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO16_SEL register field value. */
15813 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_CLR_MSK 0xfffffffc
15814 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO16_SEL register field. */
15815 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_RESET 0x0
15816 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO16_SEL field value from a register. */
15817 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_GET(value) (((value) & 0x00000003) >> 0)
15818 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO16_SEL register field value suitable for setting the register. */
15819 #define ALT_SYSMGR_PINMUX_MIXED1IO16_SEL_SET(value) (((value) << 0) & 0x00000003)
15820
15821 #ifndef __ASSEMBLY__
15822 /*
15823  * WARNING: The C register and register group struct declarations are provided for
15824  * convenience and illustrative purposes. They should, however, be used with
15825  * caution as the C language standard provides no guarantees about the alignment or
15826  * atomicity of device memory accesses. The recommended practice for writing
15827  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15828  * alt_write_word() functions.
15829  *
15830  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO16.
15831  */
15833 {
15834  uint32_t sel : 2; /* qspi_io1 Mux Selection Field */
15835  uint32_t : 30; /* *UNDEFINED* */
15836 };
15837
15838 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO16. */
15839 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO16_s ALT_SYSMGR_PINMUX_MIXED1IO16_t;
15840 #endif /* __ASSEMBLY__ */
15841
15842 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO16 register from the beginning of the component. */
15843 #define ALT_SYSMGR_PINMUX_MIXED1IO16_OFST 0x140
15844
15845 /*
15846  * Register : qspi_io2 Mux Selection Register - MIXED1IO17
15847  *
15848  * This register is used to control the peripherals connected to qspi_io2
15849  *
15850  * Only reset by a cold reset (ignores warm reset).
15851  *
15852  * NOTE: These registers should not be modified after IO configuration.There is no
15853  * support for dynamically changing the Pin Mux selections.
15854  *
15855  * Register Layout
15856  *
15857  * Bits | Access | Reset | Description
15858  * :-------|:-------|:------|:-----------------------------
15859  * [1:0] | RW | 0x0 | qspi_io2 Mux Selection Field
15860  * [31:2] | ??? | 0x0 | *UNDEFINED*
15861  *
15862  */
15863 /*
15864  * Field : qspi_io2 Mux Selection Field - sel
15865  *
15866  * Select peripheral signals connected qspi_io2.
15867  *
15868  * 0 : Pin is connected to GPIO/LoanIO number 31.
15869  *
15870  * 1 : Pin is connected to Peripheral signal USB1.DIR.
15871  *
15872  * 2 : Pin is connected to Peripheral signal not applicable.
15873  *
15874  * 3 : Pin is connected to Peripheral signal QSPI.IO2.
15875  *
15876  * Field Access Macros:
15877  *
15878  */
15879 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO17_SEL register field. */
15880 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_LSB 0
15881 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO17_SEL register field. */
15882 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_MSB 1
15883 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO17_SEL register field. */
15884 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_WIDTH 2
15885 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO17_SEL register field value. */
15886 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_SET_MSK 0x00000003
15887 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO17_SEL register field value. */
15888 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_CLR_MSK 0xfffffffc
15889 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO17_SEL register field. */
15890 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_RESET 0x0
15891 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO17_SEL field value from a register. */
15892 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_GET(value) (((value) & 0x00000003) >> 0)
15893 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO17_SEL register field value suitable for setting the register. */
15894 #define ALT_SYSMGR_PINMUX_MIXED1IO17_SEL_SET(value) (((value) << 0) & 0x00000003)
15895
15896 #ifndef __ASSEMBLY__
15897 /*
15898  * WARNING: The C register and register group struct declarations are provided for
15899  * convenience and illustrative purposes. They should, however, be used with
15900  * caution as the C language standard provides no guarantees about the alignment or
15901  * atomicity of device memory accesses. The recommended practice for writing
15902  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15903  * alt_write_word() functions.
15904  *
15905  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO17.
15906  */
15908 {
15909  uint32_t sel : 2; /* qspi_io2 Mux Selection Field */
15910  uint32_t : 30; /* *UNDEFINED* */
15911 };
15912
15913 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO17. */
15914 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO17_s ALT_SYSMGR_PINMUX_MIXED1IO17_t;
15915 #endif /* __ASSEMBLY__ */
15916
15917 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO17 register from the beginning of the component. */
15918 #define ALT_SYSMGR_PINMUX_MIXED1IO17_OFST 0x144
15919
15920 /*
15921  * Register : qspi_io3 Mux Selection Register - MIXED1IO18
15922  *
15923  * This register is used to control the peripherals connected to qspi_io3
15924  *
15925  * Only reset by a cold reset (ignores warm reset).
15926  *
15927  * NOTE: These registers should not be modified after IO configuration.There is no
15928  * support for dynamically changing the Pin Mux selections.
15929  *
15930  * Register Layout
15931  *
15932  * Bits | Access | Reset | Description
15933  * :-------|:-------|:------|:-----------------------------
15934  * [1:0] | RW | 0x0 | qspi_io3 Mux Selection Field
15935  * [31:2] | ??? | 0x0 | *UNDEFINED*
15936  *
15937  */
15938 /*
15939  * Field : qspi_io3 Mux Selection Field - sel
15940  *
15941  * Select peripheral signals connected qspi_io3.
15942  *
15943  * 0 : Pin is connected to GPIO/LoanIO number 32.
15944  *
15945  * 1 : Pin is connected to Peripheral signal USB1.NXT.
15946  *
15947  * 2 : Pin is connected to Peripheral signal not applicable.
15948  *
15949  * 3 : Pin is connected to Peripheral signal QSPI.IO3.
15950  *
15951  * Field Access Macros:
15952  *
15953  */
15954 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO18_SEL register field. */
15955 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_LSB 0
15956 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO18_SEL register field. */
15957 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_MSB 1
15958 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO18_SEL register field. */
15959 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_WIDTH 2
15960 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO18_SEL register field value. */
15961 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_SET_MSK 0x00000003
15962 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO18_SEL register field value. */
15963 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_CLR_MSK 0xfffffffc
15964 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO18_SEL register field. */
15965 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_RESET 0x0
15966 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO18_SEL field value from a register. */
15967 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_GET(value) (((value) & 0x00000003) >> 0)
15968 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO18_SEL register field value suitable for setting the register. */
15969 #define ALT_SYSMGR_PINMUX_MIXED1IO18_SEL_SET(value) (((value) << 0) & 0x00000003)
15970
15971 #ifndef __ASSEMBLY__
15972 /*
15973  * WARNING: The C register and register group struct declarations are provided for
15974  * convenience and illustrative purposes. They should, however, be used with
15975  * caution as the C language standard provides no guarantees about the alignment or
15976  * atomicity of device memory accesses. The recommended practice for writing
15977  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
15978  * alt_write_word() functions.
15979  *
15980  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO18.
15981  */
15983 {
15984  uint32_t sel : 2; /* qspi_io3 Mux Selection Field */
15985  uint32_t : 30; /* *UNDEFINED* */
15986 };
15987
15988 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO18. */
15989 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO18_s ALT_SYSMGR_PINMUX_MIXED1IO18_t;
15990 #endif /* __ASSEMBLY__ */
15991
15992 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO18 register from the beginning of the component. */
15993 #define ALT_SYSMGR_PINMUX_MIXED1IO18_OFST 0x148
15994
15995 /*
15996  * Register : qspi_ss0 Mux Selection Register - MIXED1IO19
15997  *
15998  * This register is used to control the peripherals connected to qspi_ss0
15999  *
16000  * Only reset by a cold reset (ignores warm reset).
16001  *
16002  * NOTE: These registers should not be modified after IO configuration.There is no
16003  * support for dynamically changing the Pin Mux selections.
16004  *
16005  * Register Layout
16006  *
16007  * Bits | Access | Reset | Description
16008  * :-------|:-------|:------|:-----------------------------
16009  * [1:0] | RW | 0x0 | qspi_ss0 Mux Selection Field
16010  * [31:2] | ??? | 0x0 | *UNDEFINED*
16011  *
16012  */
16013 /*
16014  * Field : qspi_ss0 Mux Selection Field - sel
16015  *
16016  * Select peripheral signals connected qspi_ss0.
16017  *
16018  * 0 : Pin is connected to GPIO/LoanIO number 33.
16019  *
16020  * 1 : Pin is connected to Peripheral signal not applicable.
16021  *
16022  * 2 : Pin is connected to Peripheral signal not applicable.
16023  *
16024  * 3 : Pin is connected to Peripheral signal QSPI.SS0.
16025  *
16026  * Field Access Macros:
16027  *
16028  */
16029 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO19_SEL register field. */
16030 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_LSB 0
16031 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO19_SEL register field. */
16032 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_MSB 1
16033 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO19_SEL register field. */
16034 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_WIDTH 2
16035 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO19_SEL register field value. */
16036 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_SET_MSK 0x00000003
16037 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO19_SEL register field value. */
16038 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_CLR_MSK 0xfffffffc
16039 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO19_SEL register field. */
16040 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_RESET 0x0
16041 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO19_SEL field value from a register. */
16042 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_GET(value) (((value) & 0x00000003) >> 0)
16043 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO19_SEL register field value suitable for setting the register. */
16044 #define ALT_SYSMGR_PINMUX_MIXED1IO19_SEL_SET(value) (((value) << 0) & 0x00000003)
16045
16046 #ifndef __ASSEMBLY__
16047 /*
16048  * WARNING: The C register and register group struct declarations are provided for
16049  * convenience and illustrative purposes. They should, however, be used with
16050  * caution as the C language standard provides no guarantees about the alignment or
16051  * atomicity of device memory accesses. The recommended practice for writing
16052  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16053  * alt_write_word() functions.
16054  *
16055  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO19.
16056  */
16058 {
16059  uint32_t sel : 2; /* qspi_ss0 Mux Selection Field */
16060  uint32_t : 30; /* *UNDEFINED* */
16061 };
16062
16063 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO19. */
16064 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO19_s ALT_SYSMGR_PINMUX_MIXED1IO19_t;
16065 #endif /* __ASSEMBLY__ */
16066
16067 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO19 register from the beginning of the component. */
16068 #define ALT_SYSMGR_PINMUX_MIXED1IO19_OFST 0x14c
16069
16070 /*
16071  * Register : qpsi_clk Mux Selection Register - MIXED1IO20
16072  *
16073  * This register is used to control the peripherals connected to qpsi_clk
16074  *
16075  * Only reset by a cold reset (ignores warm reset).
16076  *
16077  * NOTE: These registers should not be modified after IO configuration.There is no
16078  * support for dynamically changing the Pin Mux selections.
16079  *
16080  * Register Layout
16081  *
16082  * Bits | Access | Reset | Description
16083  * :-------|:-------|:------|:-----------------------------
16084  * [1:0] | RW | 0x0 | qpsi_clk Mux Selection Field
16085  * [31:2] | ??? | 0x0 | *UNDEFINED*
16086  *
16087  */
16088 /*
16089  * Field : qpsi_clk Mux Selection Field - sel
16090  *
16091  * Select peripheral signals connected qpsi_clk.
16092  *
16093  * 0 : Pin is connected to GPIO/LoanIO number 34.
16094  *
16095  * 1 : Pin is connected to Peripheral signal not applicable.
16096  *
16097  * 2 : Pin is connected to Peripheral signal not applicable.
16098  *
16099  * 3 : Pin is connected to Peripheral signal QSPI.CLK.
16100  *
16101  * Field Access Macros:
16102  *
16103  */
16104 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO20_SEL register field. */
16105 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_LSB 0
16106 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO20_SEL register field. */
16107 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_MSB 1
16108 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO20_SEL register field. */
16109 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_WIDTH 2
16110 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO20_SEL register field value. */
16111 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_SET_MSK 0x00000003
16112 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO20_SEL register field value. */
16113 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_CLR_MSK 0xfffffffc
16114 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO20_SEL register field. */
16115 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_RESET 0x0
16116 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO20_SEL field value from a register. */
16117 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_GET(value) (((value) & 0x00000003) >> 0)
16118 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO20_SEL register field value suitable for setting the register. */
16119 #define ALT_SYSMGR_PINMUX_MIXED1IO20_SEL_SET(value) (((value) << 0) & 0x00000003)
16120
16121 #ifndef __ASSEMBLY__
16122 /*
16123  * WARNING: The C register and register group struct declarations are provided for
16124  * convenience and illustrative purposes. They should, however, be used with
16125  * caution as the C language standard provides no guarantees about the alignment or
16126  * atomicity of device memory accesses. The recommended practice for writing
16127  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16128  * alt_write_word() functions.
16129  *
16130  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO20.
16131  */
16133 {
16134  uint32_t sel : 2; /* qpsi_clk Mux Selection Field */
16135  uint32_t : 30; /* *UNDEFINED* */
16136 };
16137
16138 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO20. */
16139 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO20_s ALT_SYSMGR_PINMUX_MIXED1IO20_t;
16140 #endif /* __ASSEMBLY__ */
16141
16142 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO20 register from the beginning of the component. */
16143 #define ALT_SYSMGR_PINMUX_MIXED1IO20_OFST 0x150
16144
16145 /*
16146  * Register : qspi_ss1 Mux Selection Register - MIXED1IO21
16147  *
16148  * This register is used to control the peripherals connected to qspi_ss1
16149  *
16150  * Only reset by a cold reset (ignores warm reset).
16151  *
16152  * NOTE: These registers should not be modified after IO configuration.There is no
16153  * support for dynamically changing the Pin Mux selections.
16154  *
16155  * Register Layout
16156  *
16157  * Bits | Access | Reset | Description
16158  * :-------|:-------|:------|:-----------------------------
16159  * [1:0] | RW | 0x0 | qspi_ss1 Mux Selection Field
16160  * [31:2] | ??? | 0x0 | *UNDEFINED*
16161  *
16162  */
16163 /*
16164  * Field : qspi_ss1 Mux Selection Field - sel
16165  *
16166  * Select peripheral signals connected qspi_ss1.
16167  *
16168  * 0 : Pin is connected to GPIO/LoanIO number 35.
16169  *
16170  * 1 : Pin is connected to Peripheral signal not applicable.
16171  *
16172  * 2 : Pin is connected to Peripheral signal not applicable.
16173  *
16174  * 3 : Pin is connected to Peripheral signal QSPI.SS1.
16175  *
16176  * Field Access Macros:
16177  *
16178  */
16179 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO21_SEL register field. */
16180 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_LSB 0
16181 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO21_SEL register field. */
16182 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_MSB 1
16183 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO21_SEL register field. */
16184 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_WIDTH 2
16185 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO21_SEL register field value. */
16186 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_SET_MSK 0x00000003
16187 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO21_SEL register field value. */
16188 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_CLR_MSK 0xfffffffc
16189 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO21_SEL register field. */
16190 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_RESET 0x0
16191 /* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO21_SEL field value from a register. */
16192 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_GET(value) (((value) & 0x00000003) >> 0)
16193 /* Produces a ALT_SYSMGR_PINMUX_MIXED1IO21_SEL register field value suitable for setting the register. */
16194 #define ALT_SYSMGR_PINMUX_MIXED1IO21_SEL_SET(value) (((value) << 0) & 0x00000003)
16195
16196 #ifndef __ASSEMBLY__
16197 /*
16198  * WARNING: The C register and register group struct declarations are provided for
16199  * convenience and illustrative purposes. They should, however, be used with
16200  * caution as the C language standard provides no guarantees about the alignment or
16201  * atomicity of device memory accesses. The recommended practice for writing
16202  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16203  * alt_write_word() functions.
16204  *
16205  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO21.
16206  */
16208 {
16209  uint32_t sel : 2; /* qspi_ss1 Mux Selection Field */
16210  uint32_t : 30; /* *UNDEFINED* */
16211 };
16212
16213 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO21. */
16214 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO21_s ALT_SYSMGR_PINMUX_MIXED1IO21_t;
16215 #endif /* __ASSEMBLY__ */
16216
16217 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO21 register from the beginning of the component. */
16218 #define ALT_SYSMGR_PINMUX_MIXED1IO21_OFST 0x154
16219
16220 /*
16221  * Register : emac1_mdio Mux Selection Register - MIXED2IO0
16222  *
16223  * This register is used to control the peripherals connected to emac1_mdio
16224  *
16225  * Only reset by a cold reset (ignores warm reset).
16226  *
16227  * NOTE: These registers should not be modified after IO configuration.There is no
16228  * support for dynamically changing the Pin Mux selections.
16229  *
16230  * Register Layout
16231  *
16232  * Bits | Access | Reset | Description
16233  * :-------|:-------|:------|:-------------------------------
16234  * [1:0] | RW | 0x0 | emac1_mdio Mux Selection Field
16235  * [31:2] | ??? | 0x0 | *UNDEFINED*
16236  *
16237  */
16238 /*
16239  * Field : emac1_mdio Mux Selection Field - sel
16240  *
16241  * Select peripheral signals connected emac1_mdio.
16242  *
16243  * 0 : Pin is connected to GPIO/LoanIO number 54.
16244  *
16245  * 1 : Pin is connected to Peripheral signal SPIS0.CLK.
16246  *
16247  * 2 : Pin is connected to Peripheral signal SPIM0.CLK.
16248  *
16249  * 3 : Pin is connected to Peripheral signal RGMII1.MDIO.
16250  *
16251  * Field Access Macros:
16252  *
16253  */
16254 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO0_SEL register field. */
16255 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_LSB 0
16256 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO0_SEL register field. */
16257 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_MSB 1
16258 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO0_SEL register field. */
16259 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_WIDTH 2
16260 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO0_SEL register field value. */
16261 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_SET_MSK 0x00000003
16262 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO0_SEL register field value. */
16263 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_CLR_MSK 0xfffffffc
16264 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO0_SEL register field. */
16265 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_RESET 0x0
16266 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO0_SEL field value from a register. */
16267 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
16268 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO0_SEL register field value suitable for setting the register. */
16269 #define ALT_SYSMGR_PINMUX_MIXED2IO0_SEL_SET(value) (((value) << 0) & 0x00000003)
16270
16271 #ifndef __ASSEMBLY__
16272 /*
16273  * WARNING: The C register and register group struct declarations are provided for
16274  * convenience and illustrative purposes. They should, however, be used with
16275  * caution as the C language standard provides no guarantees about the alignment or
16276  * atomicity of device memory accesses. The recommended practice for writing
16277  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16278  * alt_write_word() functions.
16279  *
16280  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO0.
16281  */
16283 {
16284  uint32_t sel : 2; /* emac1_mdio Mux Selection Field */
16285  uint32_t : 30; /* *UNDEFINED* */
16286 };
16287
16288 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO0. */
16289 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO0_s ALT_SYSMGR_PINMUX_MIXED2IO0_t;
16290 #endif /* __ASSEMBLY__ */
16291
16292 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO0 register from the beginning of the component. */
16293 #define ALT_SYSMGR_PINMUX_MIXED2IO0_OFST 0x158
16294
16295 /*
16296  * Register : emac1_mdc Mux Selection Register - MIXED2IO1
16297  *
16298  * This register is used to control the peripherals connected to emac1_mdc
16299  *
16300  * Only reset by a cold reset (ignores warm reset).
16301  *
16302  * NOTE: These registers should not be modified after IO configuration.There is no
16303  * support for dynamically changing the Pin Mux selections.
16304  *
16305  * Register Layout
16306  *
16307  * Bits | Access | Reset | Description
16308  * :-------|:-------|:------|:------------------------------
16309  * [1:0] | RW | 0x0 | emac1_mdc Mux Selection Field
16310  * [31:2] | ??? | 0x0 | *UNDEFINED*
16311  *
16312  */
16313 /*
16314  * Field : emac1_mdc Mux Selection Field - sel
16315  *
16316  * Select peripheral signals connected emac1_mdc.
16317  *
16318  * 0 : Pin is connected to GPIO/LoanIO number 55.
16319  *
16320  * 1 : Pin is connected to Peripheral signal SPIS0.MOSI.
16321  *
16322  * 2 : Pin is connected to Peripheral signal SPIM0.MOSI.
16323  *
16324  * 3 : Pin is connected to Peripheral signal RGMII1.MDC.
16325  *
16326  * Field Access Macros:
16327  *
16328  */
16329 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO1_SEL register field. */
16330 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_LSB 0
16331 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO1_SEL register field. */
16332 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_MSB 1
16333 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO1_SEL register field. */
16334 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_WIDTH 2
16335 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO1_SEL register field value. */
16336 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_SET_MSK 0x00000003
16337 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO1_SEL register field value. */
16338 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_CLR_MSK 0xfffffffc
16339 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO1_SEL register field. */
16340 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_RESET 0x0
16341 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO1_SEL field value from a register. */
16342 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
16343 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO1_SEL register field value suitable for setting the register. */
16344 #define ALT_SYSMGR_PINMUX_MIXED2IO1_SEL_SET(value) (((value) << 0) & 0x00000003)
16345
16346 #ifndef __ASSEMBLY__
16347 /*
16348  * WARNING: The C register and register group struct declarations are provided for
16349  * convenience and illustrative purposes. They should, however, be used with
16350  * caution as the C language standard provides no guarantees about the alignment or
16351  * atomicity of device memory accesses. The recommended practice for writing
16352  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16353  * alt_write_word() functions.
16354  *
16355  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO1.
16356  */
16358 {
16359  uint32_t sel : 2; /* emac1_mdc Mux Selection Field */
16360  uint32_t : 30; /* *UNDEFINED* */
16361 };
16362
16363 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO1. */
16364 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO1_s ALT_SYSMGR_PINMUX_MIXED2IO1_t;
16365 #endif /* __ASSEMBLY__ */
16366
16367 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO1 register from the beginning of the component. */
16368 #define ALT_SYSMGR_PINMUX_MIXED2IO1_OFST 0x15c
16369
16370 /*
16371  * Register : emac1_tx_d2 Mux Selection Register - MIXED2IO2
16372  *
16373  * This register is used to control the peripherals connected to emac1_tx_d2
16374  *
16375  * Only reset by a cold reset (ignores warm reset).
16376  *
16377  * NOTE: These registers should not be modified after IO configuration.There is no
16378  * support for dynamically changing the Pin Mux selections.
16379  *
16380  * Register Layout
16381  *
16382  * Bits | Access | Reset | Description
16383  * :-------|:-------|:------|:--------------------------------
16384  * [1:0] | RW | 0x0 | emac1_tx_d2 Mux Selection Field
16385  * [31:2] | ??? | 0x0 | *UNDEFINED*
16386  *
16387  */
16388 /*
16389  * Field : emac1_tx_d2 Mux Selection Field - sel
16390  *
16391  * Select peripheral signals connected emac1_tx_d2.
16392  *
16393  * 0 : Pin is connected to GPIO/LoanIO number 56.
16394  *
16395  * 1 : Pin is connected to Peripheral signal SPIS0.MISO.
16396  *
16397  * 2 : Pin is connected to Peripheral signal SPIM0.MISO.
16398  *
16399  * 3 : Pin is connected to Peripheral signal RGMII1.TXD2.
16400  *
16401  * Field Access Macros:
16402  *
16403  */
16404 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO2_SEL register field. */
16405 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_LSB 0
16406 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO2_SEL register field. */
16407 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_MSB 1
16408 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO2_SEL register field. */
16409 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_WIDTH 2
16410 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO2_SEL register field value. */
16411 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_SET_MSK 0x00000003
16412 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO2_SEL register field value. */
16413 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_CLR_MSK 0xfffffffc
16414 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO2_SEL register field. */
16415 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_RESET 0x0
16416 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO2_SEL field value from a register. */
16417 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
16418 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO2_SEL register field value suitable for setting the register. */
16419 #define ALT_SYSMGR_PINMUX_MIXED2IO2_SEL_SET(value) (((value) << 0) & 0x00000003)
16420
16421 #ifndef __ASSEMBLY__
16422 /*
16423  * WARNING: The C register and register group struct declarations are provided for
16424  * convenience and illustrative purposes. They should, however, be used with
16425  * caution as the C language standard provides no guarantees about the alignment or
16426  * atomicity of device memory accesses. The recommended practice for writing
16427  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16428  * alt_write_word() functions.
16429  *
16430  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO2.
16431  */
16433 {
16434  uint32_t sel : 2; /* emac1_tx_d2 Mux Selection Field */
16435  uint32_t : 30; /* *UNDEFINED* */
16436 };
16437
16438 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO2. */
16439 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO2_s ALT_SYSMGR_PINMUX_MIXED2IO2_t;
16440 #endif /* __ASSEMBLY__ */
16441
16442 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO2 register from the beginning of the component. */
16443 #define ALT_SYSMGR_PINMUX_MIXED2IO2_OFST 0x160
16444
16445 /*
16446  * Register : emac1_tx_d3 Mux Selection Register - MIXED2IO3
16447  *
16448  * This register is used to control the peripherals connected to emac1_tx_d3
16449  *
16450  * Only reset by a cold reset (ignores warm reset).
16451  *
16452  * NOTE: These registers should not be modified after IO configuration.There is no
16453  * support for dynamically changing the Pin Mux selections.
16454  *
16455  * Register Layout
16456  *
16457  * Bits | Access | Reset | Description
16458  * :-------|:-------|:------|:--------------------------------
16459  * [1:0] | RW | 0x0 | emac1_tx_d3 Mux Selection Field
16460  * [31:2] | ??? | 0x0 | *UNDEFINED*
16461  *
16462  */
16463 /*
16464  * Field : emac1_tx_d3 Mux Selection Field - sel
16465  *
16466  * Select peripheral signals connected emac1_tx_d3.
16467  *
16468  * 0 : Pin is connected to GPIO/LoanIO number 57.
16469  *
16470  * 1 : Pin is connected to Peripheral signal SPIS0.SS0.
16471  *
16472  * 2 : Pin is connected to Peripheral signal SPIM0.SS0.
16473  *
16474  * 3 : Pin is connected to Peripheral signal RGMII1.TXD3.
16475  *
16476  * Field Access Macros:
16477  *
16478  */
16479 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO3_SEL register field. */
16480 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_LSB 0
16481 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO3_SEL register field. */
16482 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_MSB 1
16483 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO3_SEL register field. */
16484 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_WIDTH 2
16485 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO3_SEL register field value. */
16486 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_SET_MSK 0x00000003
16487 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO3_SEL register field value. */
16488 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_CLR_MSK 0xfffffffc
16489 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO3_SEL register field. */
16490 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_RESET 0x0
16491 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO3_SEL field value from a register. */
16492 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
16493 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO3_SEL register field value suitable for setting the register. */
16494 #define ALT_SYSMGR_PINMUX_MIXED2IO3_SEL_SET(value) (((value) << 0) & 0x00000003)
16495
16496 #ifndef __ASSEMBLY__
16497 /*
16498  * WARNING: The C register and register group struct declarations are provided for
16499  * convenience and illustrative purposes. They should, however, be used with
16500  * caution as the C language standard provides no guarantees about the alignment or
16501  * atomicity of device memory accesses. The recommended practice for writing
16502  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16503  * alt_write_word() functions.
16504  *
16505  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO3.
16506  */
16508 {
16509  uint32_t sel : 2; /* emac1_tx_d3 Mux Selection Field */
16510  uint32_t : 30; /* *UNDEFINED* */
16511 };
16512
16513 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO3. */
16514 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO3_s ALT_SYSMGR_PINMUX_MIXED2IO3_t;
16515 #endif /* __ASSEMBLY__ */
16516
16517 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO3 register from the beginning of the component. */
16518 #define ALT_SYSMGR_PINMUX_MIXED2IO3_OFST 0x164
16519
16520 /*
16521  * Register : emac1_rx_clk Mux Selection Register - MIXED2IO4
16522  *
16523  * This register is used to control the peripherals connected to emac1_rx_clk
16524  *
16525  * Only reset by a cold reset (ignores warm reset).
16526  *
16527  * NOTE: These registers should not be modified after IO configuration.There is no
16528  * support for dynamically changing the Pin Mux selections.
16529  *
16530  * Register Layout
16531  *
16532  * Bits | Access | Reset | Description
16533  * :-------|:-------|:------|:---------------------------------
16534  * [1:0] | RW | 0x0 | emac1_rx_clk Mux Selection Field
16535  * [31:2] | ??? | 0x0 | *UNDEFINED*
16536  *
16537  */
16538 /*
16539  * Field : emac1_rx_clk Mux Selection Field - sel
16540  *
16541  * Select peripheral signals connected emac1_rx_clk.
16542  *
16543  * 0 : Pin is connected to GPIO/LoanIO number 58.
16544  *
16545  * 1 : Pin is connected to Peripheral signal SPIM1.CLK.
16546  *
16547  * 2 : Pin is connected to Peripheral signal SPIS1.CLK.
16548  *
16549  * 3 : Pin is connected to Peripheral signal RGMII1.RX_CLK.
16550  *
16551  * Field Access Macros:
16552  *
16553  */
16554 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO4_SEL register field. */
16555 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_LSB 0
16556 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO4_SEL register field. */
16557 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_MSB 1
16558 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO4_SEL register field. */
16559 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_WIDTH 2
16560 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO4_SEL register field value. */
16561 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_SET_MSK 0x00000003
16562 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO4_SEL register field value. */
16563 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_CLR_MSK 0xfffffffc
16564 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO4_SEL register field. */
16565 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_RESET 0x0
16566 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO4_SEL field value from a register. */
16567 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
16568 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO4_SEL register field value suitable for setting the register. */
16569 #define ALT_SYSMGR_PINMUX_MIXED2IO4_SEL_SET(value) (((value) << 0) & 0x00000003)
16570
16571 #ifndef __ASSEMBLY__
16572 /*
16573  * WARNING: The C register and register group struct declarations are provided for
16574  * convenience and illustrative purposes. They should, however, be used with
16575  * caution as the C language standard provides no guarantees about the alignment or
16576  * atomicity of device memory accesses. The recommended practice for writing
16577  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16578  * alt_write_word() functions.
16579  *
16580  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO4.
16581  */
16583 {
16584  uint32_t sel : 2; /* emac1_rx_clk Mux Selection Field */
16585  uint32_t : 30; /* *UNDEFINED* */
16586 };
16587
16588 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO4. */
16589 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO4_s ALT_SYSMGR_PINMUX_MIXED2IO4_t;
16590 #endif /* __ASSEMBLY__ */
16591
16592 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO4 register from the beginning of the component. */
16593 #define ALT_SYSMGR_PINMUX_MIXED2IO4_OFST 0x168
16594
16595 /*
16596  * Register : emac1_rx_ctl Mux Selection Register - MIXED2IO5
16597  *
16598  * This register is used to control the peripherals connected to emac1_rx_ctl
16599  *
16600  * Only reset by a cold reset (ignores warm reset).
16601  *
16602  * NOTE: These registers should not be modified after IO configuration.There is no
16603  * support for dynamically changing the Pin Mux selections.
16604  *
16605  * Register Layout
16606  *
16607  * Bits | Access | Reset | Description
16608  * :-------|:-------|:------|:---------------------------------
16609  * [1:0] | RW | 0x0 | emac1_rx_ctl Mux Selection Field
16610  * [31:2] | ??? | 0x0 | *UNDEFINED*
16611  *
16612  */
16613 /*
16614  * Field : emac1_rx_ctl Mux Selection Field - sel
16615  *
16616  * Select peripheral signals connected emac1_rx_ctl.
16617  *
16618  * 0 : Pin is connected to GPIO/LoanIO number 59.
16619  *
16620  * 1 : Pin is connected to Peripheral signal SPIM1.MOSI.
16621  *
16622  * 2 : Pin is connected to Peripheral signal SPIS1.MOSI.
16623  *
16624  * 3 : Pin is connected to Peripheral signal RGMII1.RX_CTL.
16625  *
16626  * Field Access Macros:
16627  *
16628  */
16629 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO5_SEL register field. */
16630 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_LSB 0
16631 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO5_SEL register field. */
16632 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_MSB 1
16633 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO5_SEL register field. */
16634 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_WIDTH 2
16635 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO5_SEL register field value. */
16636 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_SET_MSK 0x00000003
16637 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO5_SEL register field value. */
16638 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_CLR_MSK 0xfffffffc
16639 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO5_SEL register field. */
16640 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_RESET 0x0
16641 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO5_SEL field value from a register. */
16642 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
16643 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO5_SEL register field value suitable for setting the register. */
16644 #define ALT_SYSMGR_PINMUX_MIXED2IO5_SEL_SET(value) (((value) << 0) & 0x00000003)
16645
16646 #ifndef __ASSEMBLY__
16647 /*
16648  * WARNING: The C register and register group struct declarations are provided for
16649  * convenience and illustrative purposes. They should, however, be used with
16650  * caution as the C language standard provides no guarantees about the alignment or
16651  * atomicity of device memory accesses. The recommended practice for writing
16652  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16653  * alt_write_word() functions.
16654  *
16655  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO5.
16656  */
16658 {
16659  uint32_t sel : 2; /* emac1_rx_ctl Mux Selection Field */
16660  uint32_t : 30; /* *UNDEFINED* */
16661 };
16662
16663 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO5. */
16664 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO5_s ALT_SYSMGR_PINMUX_MIXED2IO5_t;
16665 #endif /* __ASSEMBLY__ */
16666
16667 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO5 register from the beginning of the component. */
16668 #define ALT_SYSMGR_PINMUX_MIXED2IO5_OFST 0x16c
16669
16670 /*
16671  * Register : emac1_rx_d2 Mux Selection Register - MIXED2IO6
16672  *
16673  * This register is used to control the peripherals connected to emac1_rx_d2
16674  *
16675  * Only reset by a cold reset (ignores warm reset).
16676  *
16677  * NOTE: These registers should not be modified after IO configuration.There is no
16678  * support for dynamically changing the Pin Mux selections.
16679  *
16680  * Register Layout
16681  *
16682  * Bits | Access | Reset | Description
16683  * :-------|:-------|:------|:--------------------------------
16684  * [1:0] | RW | 0x0 | emac1_rx_d2 Mux Selection Field
16685  * [31:2] | ??? | 0x0 | *UNDEFINED*
16686  *
16687  */
16688 /*
16689  * Field : emac1_rx_d2 Mux Selection Field - sel
16690  *
16691  * Select peripheral signals connected emac1_rx_d2.
16692  *
16693  * 0 : Pin is connected to GPIO/LoanIO number 60.
16694  *
16695  * 1 : Pin is connected to Peripheral signal SPIM1.MISO.
16696  *
16697  * 2 : Pin is connected to Peripheral signal SPIS1.MISO.
16698  *
16699  * 3 : Pin is connected to Peripheral signal RGMII1.RXD2.
16700  *
16701  * Field Access Macros:
16702  *
16703  */
16704 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO6_SEL register field. */
16705 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_LSB 0
16706 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO6_SEL register field. */
16707 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_MSB 1
16708 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO6_SEL register field. */
16709 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_WIDTH 2
16710 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO6_SEL register field value. */
16711 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_SET_MSK 0x00000003
16712 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO6_SEL register field value. */
16713 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_CLR_MSK 0xfffffffc
16714 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO6_SEL register field. */
16715 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_RESET 0x0
16716 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO6_SEL field value from a register. */
16717 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
16718 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO6_SEL register field value suitable for setting the register. */
16719 #define ALT_SYSMGR_PINMUX_MIXED2IO6_SEL_SET(value) (((value) << 0) & 0x00000003)
16720
16721 #ifndef __ASSEMBLY__
16722 /*
16723  * WARNING: The C register and register group struct declarations are provided for
16724  * convenience and illustrative purposes. They should, however, be used with
16725  * caution as the C language standard provides no guarantees about the alignment or
16726  * atomicity of device memory accesses. The recommended practice for writing
16727  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16728  * alt_write_word() functions.
16729  *
16730  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO6.
16731  */
16733 {
16734  uint32_t sel : 2; /* emac1_rx_d2 Mux Selection Field */
16735  uint32_t : 30; /* *UNDEFINED* */
16736 };
16737
16738 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO6. */
16739 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO6_s ALT_SYSMGR_PINMUX_MIXED2IO6_t;
16740 #endif /* __ASSEMBLY__ */
16741
16742 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO6 register from the beginning of the component. */
16743 #define ALT_SYSMGR_PINMUX_MIXED2IO6_OFST 0x170
16744
16745 /*
16746  * Register : emac1_rx_d3 Mux Selection Register - MIXED2IO7
16747  *
16748  * This register is used to control the peripherals connected to emac1_rx_d3
16749  *
16750  * Only reset by a cold reset (ignores warm reset).
16751  *
16752  * NOTE: These registers should not be modified after IO configuration.There is no
16753  * support for dynamically changing the Pin Mux selections.
16754  *
16755  * Register Layout
16756  *
16757  * Bits | Access | Reset | Description
16758  * :-------|:-------|:------|:--------------------------------
16759  * [1:0] | RW | 0x0 | emac1_rx_d3 Mux Selection Field
16760  * [31:2] | ??? | 0x0 | *UNDEFINED*
16761  *
16762  */
16763 /*
16764  * Field : emac1_rx_d3 Mux Selection Field - sel
16765  *
16766  * Select peripheral signals connected emac1_rx_d3.
16767  *
16768  * 0 : Pin is connected to GPIO/LoanIO number 61.
16769  *
16770  * 1 : Pin is connected to Peripheral signal SPIM1.SS0.
16771  *
16772  * 2 : Pin is connected to Peripheral signal SPIS1.SS0.
16773  *
16774  * 3 : Pin is connected to Peripheral signal RGMII1.RXD3.
16775  *
16776  * Field Access Macros:
16777  *
16778  */
16779 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO7_SEL register field. */
16780 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_LSB 0
16781 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED2IO7_SEL register field. */
16782 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_MSB 1
16783 /* The width in bits of the ALT_SYSMGR_PINMUX_MIXED2IO7_SEL register field. */
16784 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_WIDTH 2
16785 /* The mask used to set the ALT_SYSMGR_PINMUX_MIXED2IO7_SEL register field value. */
16786 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_SET_MSK 0x00000003
16787 /* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED2IO7_SEL register field value. */
16788 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_CLR_MSK 0xfffffffc
16789 /* The reset value of the ALT_SYSMGR_PINMUX_MIXED2IO7_SEL register field. */
16790 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_RESET 0x0
16791 /* Extracts the ALT_SYSMGR_PINMUX_MIXED2IO7_SEL field value from a register. */
16792 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
16793 /* Produces a ALT_SYSMGR_PINMUX_MIXED2IO7_SEL register field value suitable for setting the register. */
16794 #define ALT_SYSMGR_PINMUX_MIXED2IO7_SEL_SET(value) (((value) << 0) & 0x00000003)
16795
16796 #ifndef __ASSEMBLY__
16797 /*
16798  * WARNING: The C register and register group struct declarations are provided for
16799  * convenience and illustrative purposes. They should, however, be used with
16800  * caution as the C language standard provides no guarantees about the alignment or
16801  * atomicity of device memory accesses. The recommended practice for writing
16802  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16803  * alt_write_word() functions.
16804  *
16805  * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED2IO7.
16806  */
16808 {
16809  uint32_t sel : 2; /* emac1_rx_d3 Mux Selection Field */
16810  uint32_t : 30; /* *UNDEFINED* */
16811 };
16812
16813 /* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED2IO7. */
16814 typedef volatile struct ALT_SYSMGR_PINMUX_MIXED2IO7_s ALT_SYSMGR_PINMUX_MIXED2IO7_t;
16815 #endif /* __ASSEMBLY__ */
16816
16817 /* The byte offset of the ALT_SYSMGR_PINMUX_MIXED2IO7 register from the beginning of the component. */
16818 #define ALT_SYSMGR_PINMUX_MIXED2IO7_OFST 0x174
16819
16820 /*
16821  * Register : GPIO/LoanIO 48 Input Mux Selection Register - GPLINMUX48
16822  *
16823  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
16824  * the input signal for GPIO/LoanIO 48.
16825  *
16826  * Only reset by a cold reset (ignores warm reset).
16827  *
16828  * NOTE: These registers should not be modified after IO configuration.There is no
16829  * support for dynamically changing the Pin Mux selections.
16830  *
16831  * Register Layout
16832  *
16833  * Bits | Access | Reset | Description
16834  * :-------|:-------|:------|:----------------------------------------
16835  * [0] | RW | 0x0 | GPIO/Loan IO48Input Mux Selection Field
16836  * [31:1] | ??? | 0x0 | *UNDEFINED*
16837  *
16838  */
16839 /*
16840  * Field : GPIO/Loan IO48Input Mux Selection Field - sel
16841  *
16842  * Select source for GPIO/LoanIO 48.
16843  *
16844  * 0 : Source for GPIO/LoanIO 48 is GENERALIO0.
16845  *
16846  * 1 : Source for GPIO/LoanIO 48 is EMACIO14.
16847  *
16848  * Field Access Macros:
16849  *
16850  */
16851 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX48_SEL register field. */
16852 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_LSB 0
16853 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX48_SEL register field. */
16854 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_MSB 0
16855 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX48_SEL register field. */
16856 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_WIDTH 1
16857 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX48_SEL register field value. */
16858 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_SET_MSK 0x00000001
16859 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX48_SEL register field value. */
16860 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_CLR_MSK 0xfffffffe
16861 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX48_SEL register field. */
16862 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_RESET 0x0
16863 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX48_SEL field value from a register. */
16864 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_GET(value) (((value) & 0x00000001) >> 0)
16865 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX48_SEL register field value suitable for setting the register. */
16866 #define ALT_SYSMGR_PINMUX_GPLINMUX48_SEL_SET(value) (((value) << 0) & 0x00000001)
16867
16868 #ifndef __ASSEMBLY__
16869 /*
16870  * WARNING: The C register and register group struct declarations are provided for
16871  * convenience and illustrative purposes. They should, however, be used with
16872  * caution as the C language standard provides no guarantees about the alignment or
16873  * atomicity of device memory accesses. The recommended practice for writing
16874  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16875  * alt_write_word() functions.
16876  *
16877  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX48.
16878  */
16880 {
16881  uint32_t sel : 1; /* GPIO/Loan IO48Input Mux Selection Field */
16882  uint32_t : 31; /* *UNDEFINED* */
16883 };
16884
16885 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX48. */
16886 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX48_s ALT_SYSMGR_PINMUX_GPLINMUX48_t;
16887 #endif /* __ASSEMBLY__ */
16888
16889 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX48 register from the beginning of the component. */
16890 #define ALT_SYSMGR_PINMUX_GPLINMUX48_OFST 0x178
16891
16892 /*
16893  * Register : GPIO/LoanIO 49 Input Mux Selection Register - GPLINMUX49
16894  *
16895  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
16896  * the input signal for GPIO/LoanIO 49.
16897  *
16898  * Only reset by a cold reset (ignores warm reset).
16899  *
16900  * NOTE: These registers should not be modified after IO configuration.There is no
16901  * support for dynamically changing the Pin Mux selections.
16902  *
16903  * Register Layout
16904  *
16905  * Bits | Access | Reset | Description
16906  * :-------|:-------|:------|:----------------------------------------
16907  * [0] | RW | 0x0 | GPIO/Loan IO49Input Mux Selection Field
16908  * [31:1] | ??? | 0x0 | *UNDEFINED*
16909  *
16910  */
16911 /*
16912  * Field : GPIO/Loan IO49Input Mux Selection Field - sel
16913  *
16914  * Select source for GPIO/LoanIO 49.
16915  *
16916  * 0 : Source for GPIO/LoanIO 49 is GENERALIO1.
16917  *
16918  * 1 : Source for GPIO/LoanIO 49 is EMACIO15.
16919  *
16920  * Field Access Macros:
16921  *
16922  */
16923 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX49_SEL register field. */
16924 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_LSB 0
16925 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX49_SEL register field. */
16926 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_MSB 0
16927 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX49_SEL register field. */
16928 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_WIDTH 1
16929 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX49_SEL register field value. */
16930 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_SET_MSK 0x00000001
16931 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX49_SEL register field value. */
16932 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_CLR_MSK 0xfffffffe
16933 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX49_SEL register field. */
16934 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_RESET 0x0
16935 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX49_SEL field value from a register. */
16936 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_GET(value) (((value) & 0x00000001) >> 0)
16937 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX49_SEL register field value suitable for setting the register. */
16938 #define ALT_SYSMGR_PINMUX_GPLINMUX49_SEL_SET(value) (((value) << 0) & 0x00000001)
16939
16940 #ifndef __ASSEMBLY__
16941 /*
16942  * WARNING: The C register and register group struct declarations are provided for
16943  * convenience and illustrative purposes. They should, however, be used with
16944  * caution as the C language standard provides no guarantees about the alignment or
16945  * atomicity of device memory accesses. The recommended practice for writing
16946  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
16947  * alt_write_word() functions.
16948  *
16949  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX49.
16950  */
16952 {
16953  uint32_t sel : 1; /* GPIO/Loan IO49Input Mux Selection Field */
16954  uint32_t : 31; /* *UNDEFINED* */
16955 };
16956
16957 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX49. */
16958 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX49_s ALT_SYSMGR_PINMUX_GPLINMUX49_t;
16959 #endif /* __ASSEMBLY__ */
16960
16961 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX49 register from the beginning of the component. */
16962 #define ALT_SYSMGR_PINMUX_GPLINMUX49_OFST 0x17c
16963
16964 /*
16965  * Register : GPIO/LoanIO 50 Input Mux Selection Register - GPLINMUX50
16966  *
16967  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
16968  * the input signal for GPIO/LoanIO 50.
16969  *
16970  * Only reset by a cold reset (ignores warm reset).
16971  *
16972  * NOTE: These registers should not be modified after IO configuration.There is no
16973  * support for dynamically changing the Pin Mux selections.
16974  *
16975  * Register Layout
16976  *
16977  * Bits | Access | Reset | Description
16978  * :-------|:-------|:------|:----------------------------------------
16979  * [0] | RW | 0x0 | GPIO/Loan IO50Input Mux Selection Field
16980  * [31:1] | ??? | 0x0 | *UNDEFINED*
16981  *
16982  */
16983 /*
16984  * Field : GPIO/Loan IO50Input Mux Selection Field - sel
16985  *
16986  * Select source for GPIO/LoanIO 50.
16987  *
16988  * 0 : Source for GPIO/LoanIO 50 is GENERALIO2.
16989  *
16990  * 1 : Source for GPIO/LoanIO 50 is EMACIO16.
16991  *
16992  * Field Access Macros:
16993  *
16994  */
16995 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX50_SEL register field. */
16996 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_LSB 0
16997 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX50_SEL register field. */
16998 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_MSB 0
16999 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX50_SEL register field. */
17000 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_WIDTH 1
17001 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX50_SEL register field value. */
17002 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_SET_MSK 0x00000001
17003 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX50_SEL register field value. */
17004 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_CLR_MSK 0xfffffffe
17005 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX50_SEL register field. */
17006 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_RESET 0x0
17007 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX50_SEL field value from a register. */
17008 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_GET(value) (((value) & 0x00000001) >> 0)
17009 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX50_SEL register field value suitable for setting the register. */
17010 #define ALT_SYSMGR_PINMUX_GPLINMUX50_SEL_SET(value) (((value) << 0) & 0x00000001)
17011
17012 #ifndef __ASSEMBLY__
17013 /*
17014  * WARNING: The C register and register group struct declarations are provided for
17015  * convenience and illustrative purposes. They should, however, be used with
17016  * caution as the C language standard provides no guarantees about the alignment or
17017  * atomicity of device memory accesses. The recommended practice for writing
17018  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17019  * alt_write_word() functions.
17020  *
17021  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX50.
17022  */
17024 {
17025  uint32_t sel : 1; /* GPIO/Loan IO50Input Mux Selection Field */
17026  uint32_t : 31; /* *UNDEFINED* */
17027 };
17028
17029 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX50. */
17030 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX50_s ALT_SYSMGR_PINMUX_GPLINMUX50_t;
17031 #endif /* __ASSEMBLY__ */
17032
17033 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX50 register from the beginning of the component. */
17034 #define ALT_SYSMGR_PINMUX_GPLINMUX50_OFST 0x180
17035
17036 /*
17037  * Register : GPIO/LoanIO 51 Input Mux Selection Register - GPLINMUX51
17038  *
17039  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17040  * the input signal for GPIO/LoanIO 51.
17041  *
17042  * Only reset by a cold reset (ignores warm reset).
17043  *
17044  * NOTE: These registers should not be modified after IO configuration.There is no
17045  * support for dynamically changing the Pin Mux selections.
17046  *
17047  * Register Layout
17048  *
17049  * Bits | Access | Reset | Description
17050  * :-------|:-------|:------|:----------------------------------------
17051  * [0] | RW | 0x0 | GPIO/Loan IO51Input Mux Selection Field
17052  * [31:1] | ??? | 0x0 | *UNDEFINED*
17053  *
17054  */
17055 /*
17056  * Field : GPIO/Loan IO51Input Mux Selection Field - sel
17057  *
17058  * Select source for GPIO/LoanIO 51.
17059  *
17060  * 0 : Source for GPIO/LoanIO 51 is GENERALIO3.
17061  *
17062  * 1 : Source for GPIO/LoanIO 51 is EMACIO17.
17063  *
17064  * Field Access Macros:
17065  *
17066  */
17067 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX51_SEL register field. */
17068 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_LSB 0
17069 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX51_SEL register field. */
17070 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_MSB 0
17071 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX51_SEL register field. */
17072 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_WIDTH 1
17073 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX51_SEL register field value. */
17074 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_SET_MSK 0x00000001
17075 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX51_SEL register field value. */
17076 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_CLR_MSK 0xfffffffe
17077 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX51_SEL register field. */
17078 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_RESET 0x0
17079 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX51_SEL field value from a register. */
17080 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_GET(value) (((value) & 0x00000001) >> 0)
17081 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX51_SEL register field value suitable for setting the register. */
17082 #define ALT_SYSMGR_PINMUX_GPLINMUX51_SEL_SET(value) (((value) << 0) & 0x00000001)
17083
17084 #ifndef __ASSEMBLY__
17085 /*
17086  * WARNING: The C register and register group struct declarations are provided for
17087  * convenience and illustrative purposes. They should, however, be used with
17088  * caution as the C language standard provides no guarantees about the alignment or
17089  * atomicity of device memory accesses. The recommended practice for writing
17090  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17091  * alt_write_word() functions.
17092  *
17093  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX51.
17094  */
17096 {
17097  uint32_t sel : 1; /* GPIO/Loan IO51Input Mux Selection Field */
17098  uint32_t : 31; /* *UNDEFINED* */
17099 };
17100
17101 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX51. */
17102 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX51_s ALT_SYSMGR_PINMUX_GPLINMUX51_t;
17103 #endif /* __ASSEMBLY__ */
17104
17105 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX51 register from the beginning of the component. */
17106 #define ALT_SYSMGR_PINMUX_GPLINMUX51_OFST 0x184
17107
17108 /*
17109  * Register : GPIO/LoanIO 52 Input Mux Selection Register - GPLINMUX52
17110  *
17111  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17112  * the input signal for GPIO/LoanIO 52.
17113  *
17114  * Only reset by a cold reset (ignores warm reset).
17115  *
17116  * NOTE: These registers should not be modified after IO configuration.There is no
17117  * support for dynamically changing the Pin Mux selections.
17118  *
17119  * Register Layout
17120  *
17121  * Bits | Access | Reset | Description
17122  * :-------|:-------|:------|:----------------------------------------
17123  * [0] | RW | 0x0 | GPIO/Loan IO52Input Mux Selection Field
17124  * [31:1] | ??? | 0x0 | *UNDEFINED*
17125  *
17126  */
17127 /*
17128  * Field : GPIO/Loan IO52Input Mux Selection Field - sel
17129  *
17130  * Select source for GPIO/LoanIO 52.
17131  *
17132  * 0 : Source for GPIO/LoanIO 52 is GENERALIO4.
17133  *
17134  * 1 : Source for GPIO/LoanIO 52 is EMACIO18.
17135  *
17136  * Field Access Macros:
17137  *
17138  */
17139 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX52_SEL register field. */
17140 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_LSB 0
17141 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX52_SEL register field. */
17142 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_MSB 0
17143 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX52_SEL register field. */
17144 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_WIDTH 1
17145 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX52_SEL register field value. */
17146 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_SET_MSK 0x00000001
17147 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX52_SEL register field value. */
17148 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_CLR_MSK 0xfffffffe
17149 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX52_SEL register field. */
17150 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_RESET 0x0
17151 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX52_SEL field value from a register. */
17152 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_GET(value) (((value) & 0x00000001) >> 0)
17153 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX52_SEL register field value suitable for setting the register. */
17154 #define ALT_SYSMGR_PINMUX_GPLINMUX52_SEL_SET(value) (((value) << 0) & 0x00000001)
17155
17156 #ifndef __ASSEMBLY__
17157 /*
17158  * WARNING: The C register and register group struct declarations are provided for
17159  * convenience and illustrative purposes. They should, however, be used with
17160  * caution as the C language standard provides no guarantees about the alignment or
17161  * atomicity of device memory accesses. The recommended practice for writing
17162  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17163  * alt_write_word() functions.
17164  *
17165  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX52.
17166  */
17168 {
17169  uint32_t sel : 1; /* GPIO/Loan IO52Input Mux Selection Field */
17170  uint32_t : 31; /* *UNDEFINED* */
17171 };
17172
17173 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX52. */
17174 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX52_s ALT_SYSMGR_PINMUX_GPLINMUX52_t;
17175 #endif /* __ASSEMBLY__ */
17176
17177 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX52 register from the beginning of the component. */
17178 #define ALT_SYSMGR_PINMUX_GPLINMUX52_OFST 0x188
17179
17180 /*
17181  * Register : GPIO/LoanIO 53 Input Mux Selection Register - GPLINMUX53
17182  *
17183  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17184  * the input signal for GPIO/LoanIO 53.
17185  *
17186  * Only reset by a cold reset (ignores warm reset).
17187  *
17188  * NOTE: These registers should not be modified after IO configuration.There is no
17189  * support for dynamically changing the Pin Mux selections.
17190  *
17191  * Register Layout
17192  *
17193  * Bits | Access | Reset | Description
17194  * :-------|:-------|:------|:----------------------------------------
17195  * [0] | RW | 0x0 | GPIO/Loan IO53Input Mux Selection Field
17196  * [31:1] | ??? | 0x0 | *UNDEFINED*
17197  *
17198  */
17199 /*
17200  * Field : GPIO/Loan IO53Input Mux Selection Field - sel
17201  *
17202  * Select source for GPIO/LoanIO 53.
17203  *
17204  * 0 : Source for GPIO/LoanIO 53 is GENERALIO5.
17205  *
17206  * 1 : Source for GPIO/LoanIO 53 is EMACIO19.
17207  *
17208  * Field Access Macros:
17209  *
17210  */
17211 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX53_SEL register field. */
17212 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_LSB 0
17213 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX53_SEL register field. */
17214 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_MSB 0
17215 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX53_SEL register field. */
17216 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_WIDTH 1
17217 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX53_SEL register field value. */
17218 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_SET_MSK 0x00000001
17219 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX53_SEL register field value. */
17220 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_CLR_MSK 0xfffffffe
17221 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX53_SEL register field. */
17222 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_RESET 0x0
17223 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX53_SEL field value from a register. */
17224 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_GET(value) (((value) & 0x00000001) >> 0)
17225 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX53_SEL register field value suitable for setting the register. */
17226 #define ALT_SYSMGR_PINMUX_GPLINMUX53_SEL_SET(value) (((value) << 0) & 0x00000001)
17227
17228 #ifndef __ASSEMBLY__
17229 /*
17230  * WARNING: The C register and register group struct declarations are provided for
17231  * convenience and illustrative purposes. They should, however, be used with
17232  * caution as the C language standard provides no guarantees about the alignment or
17233  * atomicity of device memory accesses. The recommended practice for writing
17234  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17235  * alt_write_word() functions.
17236  *
17237  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX53.
17238  */
17240 {
17241  uint32_t sel : 1; /* GPIO/Loan IO53Input Mux Selection Field */
17242  uint32_t : 31; /* *UNDEFINED* */
17243 };
17244
17245 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX53. */
17246 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX53_s ALT_SYSMGR_PINMUX_GPLINMUX53_t;
17247 #endif /* __ASSEMBLY__ */
17248
17249 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX53 register from the beginning of the component. */
17250 #define ALT_SYSMGR_PINMUX_GPLINMUX53_OFST 0x18c
17251
17252 /*
17253  * Register : GPIO/LoanIO 54 Input Mux Selection Register - GPLINMUX54
17254  *
17255  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17256  * the input signal for GPIO/LoanIO 54.
17257  *
17258  * Only reset by a cold reset (ignores warm reset).
17259  *
17260  * NOTE: These registers should not be modified after IO configuration.There is no
17261  * support for dynamically changing the Pin Mux selections.
17262  *
17263  * Register Layout
17264  *
17265  * Bits | Access | Reset | Description
17266  * :-------|:-------|:------|:----------------------------------------
17267  * [0] | RW | 0x0 | GPIO/Loan IO54Input Mux Selection Field
17268  * [31:1] | ??? | 0x0 | *UNDEFINED*
17269  *
17270  */
17271 /*
17272  * Field : GPIO/Loan IO54Input Mux Selection Field - sel
17273  *
17274  * Select source for GPIO/LoanIO 54.
17275  *
17276  * 0 : Source for GPIO/LoanIO 54 is GENERALIO6.
17277  *
17278  * 1 : Source for GPIO/LoanIO 54 is MIXED2IO0.
17279  *
17280  * Field Access Macros:
17281  *
17282  */
17283 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX54_SEL register field. */
17284 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_LSB 0
17285 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX54_SEL register field. */
17286 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_MSB 0
17287 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX54_SEL register field. */
17288 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_WIDTH 1
17289 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX54_SEL register field value. */
17290 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_SET_MSK 0x00000001
17291 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX54_SEL register field value. */
17292 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_CLR_MSK 0xfffffffe
17293 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX54_SEL register field. */
17294 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_RESET 0x0
17295 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX54_SEL field value from a register. */
17296 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_GET(value) (((value) & 0x00000001) >> 0)
17297 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX54_SEL register field value suitable for setting the register. */
17298 #define ALT_SYSMGR_PINMUX_GPLINMUX54_SEL_SET(value) (((value) << 0) & 0x00000001)
17299
17300 #ifndef __ASSEMBLY__
17301 /*
17302  * WARNING: The C register and register group struct declarations are provided for
17303  * convenience and illustrative purposes. They should, however, be used with
17304  * caution as the C language standard provides no guarantees about the alignment or
17305  * atomicity of device memory accesses. The recommended practice for writing
17306  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17307  * alt_write_word() functions.
17308  *
17309  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX54.
17310  */
17312 {
17313  uint32_t sel : 1; /* GPIO/Loan IO54Input Mux Selection Field */
17314  uint32_t : 31; /* *UNDEFINED* */
17315 };
17316
17317 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX54. */
17318 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX54_s ALT_SYSMGR_PINMUX_GPLINMUX54_t;
17319 #endif /* __ASSEMBLY__ */
17320
17321 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX54 register from the beginning of the component. */
17322 #define ALT_SYSMGR_PINMUX_GPLINMUX54_OFST 0x190
17323
17324 /*
17325  * Register : GPIO/LoanIO 55 Input Mux Selection Register - GPLINMUX55
17326  *
17327  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17328  * the input signal for GPIO/LoanIO 55.
17329  *
17330  * Only reset by a cold reset (ignores warm reset).
17331  *
17332  * NOTE: These registers should not be modified after IO configuration.There is no
17333  * support for dynamically changing the Pin Mux selections.
17334  *
17335  * Register Layout
17336  *
17337  * Bits | Access | Reset | Description
17338  * :-------|:-------|:------|:----------------------------------------
17339  * [0] | RW | 0x0 | GPIO/Loan IO55Input Mux Selection Field
17340  * [31:1] | ??? | 0x0 | *UNDEFINED*
17341  *
17342  */
17343 /*
17344  * Field : GPIO/Loan IO55Input Mux Selection Field - sel
17345  *
17346  * Select source for GPIO/LoanIO 55.
17347  *
17348  * 0 : Source for GPIO/LoanIO 55 is GENERALIO7.
17349  *
17350  * 1 : Source for GPIO/LoanIO 55 is MIXED2IO1.
17351  *
17352  * Field Access Macros:
17353  *
17354  */
17355 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX55_SEL register field. */
17356 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_LSB 0
17357 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX55_SEL register field. */
17358 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_MSB 0
17359 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX55_SEL register field. */
17360 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_WIDTH 1
17361 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX55_SEL register field value. */
17362 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_SET_MSK 0x00000001
17363 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX55_SEL register field value. */
17364 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_CLR_MSK 0xfffffffe
17365 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX55_SEL register field. */
17366 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_RESET 0x0
17367 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX55_SEL field value from a register. */
17368 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_GET(value) (((value) & 0x00000001) >> 0)
17369 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX55_SEL register field value suitable for setting the register. */
17370 #define ALT_SYSMGR_PINMUX_GPLINMUX55_SEL_SET(value) (((value) << 0) & 0x00000001)
17371
17372 #ifndef __ASSEMBLY__
17373 /*
17374  * WARNING: The C register and register group struct declarations are provided for
17375  * convenience and illustrative purposes. They should, however, be used with
17376  * caution as the C language standard provides no guarantees about the alignment or
17377  * atomicity of device memory accesses. The recommended practice for writing
17378  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17379  * alt_write_word() functions.
17380  *
17381  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX55.
17382  */
17384 {
17385  uint32_t sel : 1; /* GPIO/Loan IO55Input Mux Selection Field */
17386  uint32_t : 31; /* *UNDEFINED* */
17387 };
17388
17389 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX55. */
17390 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX55_s ALT_SYSMGR_PINMUX_GPLINMUX55_t;
17391 #endif /* __ASSEMBLY__ */
17392
17393 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX55 register from the beginning of the component. */
17394 #define ALT_SYSMGR_PINMUX_GPLINMUX55_OFST 0x194
17395
17396 /*
17397  * Register : GPIO/LoanIO 56 Input Mux Selection Register - GPLINMUX56
17398  *
17399  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17400  * the input signal for GPIO/LoanIO 56.
17401  *
17402  * Only reset by a cold reset (ignores warm reset).
17403  *
17404  * NOTE: These registers should not be modified after IO configuration.There is no
17405  * support for dynamically changing the Pin Mux selections.
17406  *
17407  * Register Layout
17408  *
17409  * Bits | Access | Reset | Description
17410  * :-------|:-------|:------|:----------------------------------------
17411  * [0] | RW | 0x0 | GPIO/Loan IO56Input Mux Selection Field
17412  * [31:1] | ??? | 0x0 | *UNDEFINED*
17413  *
17414  */
17415 /*
17416  * Field : GPIO/Loan IO56Input Mux Selection Field - sel
17417  *
17418  * Select source for GPIO/LoanIO 56.
17419  *
17420  * 0 : Source for GPIO/LoanIO 56 is GENERALIO8.
17421  *
17422  * 1 : Source for GPIO/LoanIO 56 is MIXED2IO2.
17423  *
17424  * Field Access Macros:
17425  *
17426  */
17427 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX56_SEL register field. */
17428 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_LSB 0
17429 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX56_SEL register field. */
17430 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_MSB 0
17431 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX56_SEL register field. */
17432 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_WIDTH 1
17433 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX56_SEL register field value. */
17434 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_SET_MSK 0x00000001
17435 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX56_SEL register field value. */
17436 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_CLR_MSK 0xfffffffe
17437 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX56_SEL register field. */
17438 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_RESET 0x0
17439 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX56_SEL field value from a register. */
17440 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_GET(value) (((value) & 0x00000001) >> 0)
17441 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX56_SEL register field value suitable for setting the register. */
17442 #define ALT_SYSMGR_PINMUX_GPLINMUX56_SEL_SET(value) (((value) << 0) & 0x00000001)
17443
17444 #ifndef __ASSEMBLY__
17445 /*
17446  * WARNING: The C register and register group struct declarations are provided for
17447  * convenience and illustrative purposes. They should, however, be used with
17448  * caution as the C language standard provides no guarantees about the alignment or
17449  * atomicity of device memory accesses. The recommended practice for writing
17450  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17451  * alt_write_word() functions.
17452  *
17453  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX56.
17454  */
17456 {
17457  uint32_t sel : 1; /* GPIO/Loan IO56Input Mux Selection Field */
17458  uint32_t : 31; /* *UNDEFINED* */
17459 };
17460
17461 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX56. */
17462 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX56_s ALT_SYSMGR_PINMUX_GPLINMUX56_t;
17463 #endif /* __ASSEMBLY__ */
17464
17465 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX56 register from the beginning of the component. */
17466 #define ALT_SYSMGR_PINMUX_GPLINMUX56_OFST 0x198
17467
17468 /*
17469  * Register : GPIO/LoanIO 57 Input Mux Selection Register - GPLINMUX57
17470  *
17471  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17472  * the input signal for GPIO/LoanIO 57.
17473  *
17474  * Only reset by a cold reset (ignores warm reset).
17475  *
17476  * NOTE: These registers should not be modified after IO configuration.There is no
17477  * support for dynamically changing the Pin Mux selections.
17478  *
17479  * Register Layout
17480  *
17481  * Bits | Access | Reset | Description
17482  * :-------|:-------|:------|:----------------------------------------
17483  * [0] | RW | 0x0 | GPIO/Loan IO57Input Mux Selection Field
17484  * [31:1] | ??? | 0x0 | *UNDEFINED*
17485  *
17486  */
17487 /*
17488  * Field : GPIO/Loan IO57Input Mux Selection Field - sel
17489  *
17490  * Select source for GPIO/LoanIO 57.
17491  *
17492  * 0 : Source for GPIO/LoanIO 57 is GENERALIO9.
17493  *
17494  * 1 : Source for GPIO/LoanIO 57 is MIXED2IO3.
17495  *
17496  * Field Access Macros:
17497  *
17498  */
17499 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX57_SEL register field. */
17500 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_LSB 0
17501 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX57_SEL register field. */
17502 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_MSB 0
17503 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX57_SEL register field. */
17504 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_WIDTH 1
17505 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX57_SEL register field value. */
17506 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_SET_MSK 0x00000001
17507 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX57_SEL register field value. */
17508 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_CLR_MSK 0xfffffffe
17509 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX57_SEL register field. */
17510 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_RESET 0x0
17511 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX57_SEL field value from a register. */
17512 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_GET(value) (((value) & 0x00000001) >> 0)
17513 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX57_SEL register field value suitable for setting the register. */
17514 #define ALT_SYSMGR_PINMUX_GPLINMUX57_SEL_SET(value) (((value) << 0) & 0x00000001)
17515
17516 #ifndef __ASSEMBLY__
17517 /*
17518  * WARNING: The C register and register group struct declarations are provided for
17519  * convenience and illustrative purposes. They should, however, be used with
17520  * caution as the C language standard provides no guarantees about the alignment or
17521  * atomicity of device memory accesses. The recommended practice for writing
17522  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17523  * alt_write_word() functions.
17524  *
17525  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX57.
17526  */
17528 {
17529  uint32_t sel : 1; /* GPIO/Loan IO57Input Mux Selection Field */
17530  uint32_t : 31; /* *UNDEFINED* */
17531 };
17532
17533 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX57. */
17534 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX57_s ALT_SYSMGR_PINMUX_GPLINMUX57_t;
17535 #endif /* __ASSEMBLY__ */
17536
17537 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX57 register from the beginning of the component. */
17538 #define ALT_SYSMGR_PINMUX_GPLINMUX57_OFST 0x19c
17539
17540 /*
17541  * Register : GPIO/LoanIO 58 Input Mux Selection Register - GPLINMUX58
17542  *
17543  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17544  * the input signal for GPIO/LoanIO 58.
17545  *
17546  * Only reset by a cold reset (ignores warm reset).
17547  *
17548  * NOTE: These registers should not be modified after IO configuration.There is no
17549  * support for dynamically changing the Pin Mux selections.
17550  *
17551  * Register Layout
17552  *
17553  * Bits | Access | Reset | Description
17554  * :-------|:-------|:------|:----------------------------------------
17555  * [0] | RW | 0x0 | GPIO/Loan IO58Input Mux Selection Field
17556  * [31:1] | ??? | 0x0 | *UNDEFINED*
17557  *
17558  */
17559 /*
17560  * Field : GPIO/Loan IO58Input Mux Selection Field - sel
17561  *
17562  * Select source for GPIO/LoanIO 58.
17563  *
17564  * 0 : Source for GPIO/LoanIO 58 is GENERALIO10.
17565  *
17566  * 1 : Source for GPIO/LoanIO 58 is MIXED2IO4.
17567  *
17568  * Field Access Macros:
17569  *
17570  */
17571 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX58_SEL register field. */
17572 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_LSB 0
17573 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX58_SEL register field. */
17574 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_MSB 0
17575 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX58_SEL register field. */
17576 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_WIDTH 1
17577 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX58_SEL register field value. */
17578 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_SET_MSK 0x00000001
17579 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX58_SEL register field value. */
17580 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_CLR_MSK 0xfffffffe
17581 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX58_SEL register field. */
17582 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_RESET 0x0
17583 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX58_SEL field value from a register. */
17584 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_GET(value) (((value) & 0x00000001) >> 0)
17585 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX58_SEL register field value suitable for setting the register. */
17586 #define ALT_SYSMGR_PINMUX_GPLINMUX58_SEL_SET(value) (((value) << 0) & 0x00000001)
17587
17588 #ifndef __ASSEMBLY__
17589 /*
17590  * WARNING: The C register and register group struct declarations are provided for
17591  * convenience and illustrative purposes. They should, however, be used with
17592  * caution as the C language standard provides no guarantees about the alignment or
17593  * atomicity of device memory accesses. The recommended practice for writing
17594  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17595  * alt_write_word() functions.
17596  *
17597  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX58.
17598  */
17600 {
17601  uint32_t sel : 1; /* GPIO/Loan IO58Input Mux Selection Field */
17602  uint32_t : 31; /* *UNDEFINED* */
17603 };
17604
17605 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX58. */
17606 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX58_s ALT_SYSMGR_PINMUX_GPLINMUX58_t;
17607 #endif /* __ASSEMBLY__ */
17608
17609 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX58 register from the beginning of the component. */
17610 #define ALT_SYSMGR_PINMUX_GPLINMUX58_OFST 0x1a0
17611
17612 /*
17613  * Register : GPIO/LoanIO 59 Input Mux Selection Register - GPLINMUX59
17614  *
17615  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17616  * the input signal for GPIO/LoanIO 59.
17617  *
17618  * Only reset by a cold reset (ignores warm reset).
17619  *
17620  * NOTE: These registers should not be modified after IO configuration.There is no
17621  * support for dynamically changing the Pin Mux selections.
17622  *
17623  * Register Layout
17624  *
17625  * Bits | Access | Reset | Description
17626  * :-------|:-------|:------|:----------------------------------------
17627  * [0] | RW | 0x0 | GPIO/Loan IO59Input Mux Selection Field
17628  * [31:1] | ??? | 0x0 | *UNDEFINED*
17629  *
17630  */
17631 /*
17632  * Field : GPIO/Loan IO59Input Mux Selection Field - sel
17633  *
17634  * Select source for GPIO/LoanIO 59.
17635  *
17636  * 0 : Source for GPIO/LoanIO 59 is GENERALIO11.
17637  *
17638  * 1 : Source for GPIO/LoanIO 59 is MIXED2IO5.
17639  *
17640  * Field Access Macros:
17641  *
17642  */
17643 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX59_SEL register field. */
17644 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_LSB 0
17645 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX59_SEL register field. */
17646 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_MSB 0
17647 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX59_SEL register field. */
17648 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_WIDTH 1
17649 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX59_SEL register field value. */
17650 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_SET_MSK 0x00000001
17651 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX59_SEL register field value. */
17652 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_CLR_MSK 0xfffffffe
17653 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX59_SEL register field. */
17654 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_RESET 0x0
17655 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX59_SEL field value from a register. */
17656 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_GET(value) (((value) & 0x00000001) >> 0)
17657 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX59_SEL register field value suitable for setting the register. */
17658 #define ALT_SYSMGR_PINMUX_GPLINMUX59_SEL_SET(value) (((value) << 0) & 0x00000001)
17659
17660 #ifndef __ASSEMBLY__
17661 /*
17662  * WARNING: The C register and register group struct declarations are provided for
17663  * convenience and illustrative purposes. They should, however, be used with
17664  * caution as the C language standard provides no guarantees about the alignment or
17665  * atomicity of device memory accesses. The recommended practice for writing
17666  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17667  * alt_write_word() functions.
17668  *
17669  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX59.
17670  */
17672 {
17673  uint32_t sel : 1; /* GPIO/Loan IO59Input Mux Selection Field */
17674  uint32_t : 31; /* *UNDEFINED* */
17675 };
17676
17677 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX59. */
17678 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX59_s ALT_SYSMGR_PINMUX_GPLINMUX59_t;
17679 #endif /* __ASSEMBLY__ */
17680
17681 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX59 register from the beginning of the component. */
17682 #define ALT_SYSMGR_PINMUX_GPLINMUX59_OFST 0x1a4
17683
17684 /*
17685  * Register : GPIO/LoanIO 60 Input Mux Selection Register - GPLINMUX60
17686  *
17687  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17688  * the input signal for GPIO/LoanIO 60.
17689  *
17690  * Only reset by a cold reset (ignores warm reset).
17691  *
17692  * NOTE: These registers should not be modified after IO configuration.There is no
17693  * support for dynamically changing the Pin Mux selections.
17694  *
17695  * Register Layout
17696  *
17697  * Bits | Access | Reset | Description
17698  * :-------|:-------|:------|:----------------------------------------
17699  * [0] | RW | 0x0 | GPIO/Loan IO60Input Mux Selection Field
17700  * [31:1] | ??? | 0x0 | *UNDEFINED*
17701  *
17702  */
17703 /*
17704  * Field : GPIO/Loan IO60Input Mux Selection Field - sel
17705  *
17706  * Select source for GPIO/LoanIO 60.
17707  *
17708  * 0 : Source for GPIO/LoanIO 60 is GENERALIO12.
17709  *
17710  * 1 : Source for GPIO/LoanIO 60 is MIXED2IO6.
17711  *
17712  * Field Access Macros:
17713  *
17714  */
17715 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX60_SEL register field. */
17716 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_LSB 0
17717 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX60_SEL register field. */
17718 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_MSB 0
17719 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX60_SEL register field. */
17720 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_WIDTH 1
17721 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX60_SEL register field value. */
17722 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_SET_MSK 0x00000001
17723 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX60_SEL register field value. */
17724 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_CLR_MSK 0xfffffffe
17725 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX60_SEL register field. */
17726 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_RESET 0x0
17727 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX60_SEL field value from a register. */
17728 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_GET(value) (((value) & 0x00000001) >> 0)
17729 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX60_SEL register field value suitable for setting the register. */
17730 #define ALT_SYSMGR_PINMUX_GPLINMUX60_SEL_SET(value) (((value) << 0) & 0x00000001)
17731
17732 #ifndef __ASSEMBLY__
17733 /*
17734  * WARNING: The C register and register group struct declarations are provided for
17735  * convenience and illustrative purposes. They should, however, be used with
17736  * caution as the C language standard provides no guarantees about the alignment or
17737  * atomicity of device memory accesses. The recommended practice for writing
17738  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17739  * alt_write_word() functions.
17740  *
17741  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX60.
17742  */
17744 {
17745  uint32_t sel : 1; /* GPIO/Loan IO60Input Mux Selection Field */
17746  uint32_t : 31; /* *UNDEFINED* */
17747 };
17748
17749 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX60. */
17750 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX60_s ALT_SYSMGR_PINMUX_GPLINMUX60_t;
17751 #endif /* __ASSEMBLY__ */
17752
17753 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX60 register from the beginning of the component. */
17754 #define ALT_SYSMGR_PINMUX_GPLINMUX60_OFST 0x1a8
17755
17756 /*
17757  * Register : GPIO/LoanIO 61 Input Mux Selection Register - GPLINMUX61
17758  *
17759  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17760  * the input signal for GPIO/LoanIO 61.
17761  *
17762  * Only reset by a cold reset (ignores warm reset).
17763  *
17764  * NOTE: These registers should not be modified after IO configuration.There is no
17765  * support for dynamically changing the Pin Mux selections.
17766  *
17767  * Register Layout
17768  *
17769  * Bits | Access | Reset | Description
17770  * :-------|:-------|:------|:----------------------------------------
17771  * [0] | RW | 0x0 | GPIO/Loan IO61Input Mux Selection Field
17772  * [31:1] | ??? | 0x0 | *UNDEFINED*
17773  *
17774  */
17775 /*
17776  * Field : GPIO/Loan IO61Input Mux Selection Field - sel
17777  *
17778  * Select source for GPIO/LoanIO 61.
17779  *
17780  * 0 : Source for GPIO/LoanIO 61 is GENERALIO13.
17781  *
17782  * 1 : Source for GPIO/LoanIO 61 is MIXED2IO7.
17783  *
17784  * Field Access Macros:
17785  *
17786  */
17787 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX61_SEL register field. */
17788 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_LSB 0
17789 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX61_SEL register field. */
17790 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_MSB 0
17791 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX61_SEL register field. */
17792 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_WIDTH 1
17793 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX61_SEL register field value. */
17794 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_SET_MSK 0x00000001
17795 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX61_SEL register field value. */
17796 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_CLR_MSK 0xfffffffe
17797 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX61_SEL register field. */
17798 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_RESET 0x0
17799 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX61_SEL field value from a register. */
17800 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_GET(value) (((value) & 0x00000001) >> 0)
17801 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX61_SEL register field value suitable for setting the register. */
17802 #define ALT_SYSMGR_PINMUX_GPLINMUX61_SEL_SET(value) (((value) << 0) & 0x00000001)
17803
17804 #ifndef __ASSEMBLY__
17805 /*
17806  * WARNING: The C register and register group struct declarations are provided for
17807  * convenience and illustrative purposes. They should, however, be used with
17808  * caution as the C language standard provides no guarantees about the alignment or
17809  * atomicity of device memory accesses. The recommended practice for writing
17810  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17811  * alt_write_word() functions.
17812  *
17813  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX61.
17814  */
17816 {
17817  uint32_t sel : 1; /* GPIO/Loan IO61Input Mux Selection Field */
17818  uint32_t : 31; /* *UNDEFINED* */
17819 };
17820
17821 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX61. */
17822 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX61_s ALT_SYSMGR_PINMUX_GPLINMUX61_t;
17823 #endif /* __ASSEMBLY__ */
17824
17825 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX61 register from the beginning of the component. */
17826 #define ALT_SYSMGR_PINMUX_GPLINMUX61_OFST 0x1ac
17827
17828 /*
17829  * Register : GPIO/LoanIO 62 Input Mux Selection Register - GPLINMUX62
17830  *
17831  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17832  * the input signal for GPIO/LoanIO 62.
17833  *
17834  * Only reset by a cold reset (ignores warm reset).
17835  *
17836  * NOTE: These registers should not be modified after IO configuration.There is no
17837  * support for dynamically changing the Pin Mux selections.
17838  *
17839  * Register Layout
17840  *
17841  * Bits | Access | Reset | Description
17842  * :-------|:-------|:------|:----------------------------------------
17843  * [0] | RW | 0x0 | GPIO/Loan IO62Input Mux Selection Field
17844  * [31:1] | ??? | 0x0 | *UNDEFINED*
17845  *
17846  */
17847 /*
17848  * Field : GPIO/Loan IO62Input Mux Selection Field - sel
17849  *
17850  * Select source for GPIO/LoanIO 62.
17851  *
17852  * 0 : Source for GPIO/LoanIO 62 is GENERALIO14.
17853  *
17854  * 1 : Source for GPIO/LoanIO 62 is GENERALIO23.
17855  *
17856  * Field Access Macros:
17857  *
17858  */
17859 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX62_SEL register field. */
17860 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_LSB 0
17861 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX62_SEL register field. */
17862 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_MSB 0
17863 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX62_SEL register field. */
17864 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_WIDTH 1
17865 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX62_SEL register field value. */
17866 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_SET_MSK 0x00000001
17867 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX62_SEL register field value. */
17868 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_CLR_MSK 0xfffffffe
17869 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX62_SEL register field. */
17870 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_RESET 0x0
17871 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX62_SEL field value from a register. */
17872 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_GET(value) (((value) & 0x00000001) >> 0)
17873 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX62_SEL register field value suitable for setting the register. */
17874 #define ALT_SYSMGR_PINMUX_GPLINMUX62_SEL_SET(value) (((value) << 0) & 0x00000001)
17875
17876 #ifndef __ASSEMBLY__
17877 /*
17878  * WARNING: The C register and register group struct declarations are provided for
17879  * convenience and illustrative purposes. They should, however, be used with
17880  * caution as the C language standard provides no guarantees about the alignment or
17881  * atomicity of device memory accesses. The recommended practice for writing
17882  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17883  * alt_write_word() functions.
17884  *
17885  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX62.
17886  */
17888 {
17889  uint32_t sel : 1; /* GPIO/Loan IO62Input Mux Selection Field */
17890  uint32_t : 31; /* *UNDEFINED* */
17891 };
17892
17893 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX62. */
17894 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX62_s ALT_SYSMGR_PINMUX_GPLINMUX62_t;
17895 #endif /* __ASSEMBLY__ */
17896
17897 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX62 register from the beginning of the component. */
17898 #define ALT_SYSMGR_PINMUX_GPLINMUX62_OFST 0x1b0
17899
17900 /*
17901  * Register : GPIO/LoanIO 63 Input Mux Selection Register - GPLINMUX63
17902  *
17903  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17904  * the input signal for GPIO/LoanIO 63.
17905  *
17906  * Only reset by a cold reset (ignores warm reset).
17907  *
17908  * NOTE: These registers should not be modified after IO configuration.There is no
17909  * support for dynamically changing the Pin Mux selections.
17910  *
17911  * Register Layout
17912  *
17913  * Bits | Access | Reset | Description
17914  * :-------|:-------|:------|:----------------------------------------
17915  * [0] | RW | 0x0 | GPIO/Loan IO63Input Mux Selection Field
17916  * [31:1] | ??? | 0x0 | *UNDEFINED*
17917  *
17918  */
17919 /*
17920  * Field : GPIO/Loan IO63Input Mux Selection Field - sel
17921  *
17922  * Select source for GPIO/LoanIO 63.
17923  *
17924  * 0 : Source for GPIO/LoanIO 63 is GENERALIO15.
17925  *
17926  * 1 : Source for GPIO/LoanIO 63 is GENERALIO24.
17927  *
17928  * Field Access Macros:
17929  *
17930  */
17931 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX63_SEL register field. */
17932 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_LSB 0
17933 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX63_SEL register field. */
17934 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_MSB 0
17935 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX63_SEL register field. */
17936 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_WIDTH 1
17937 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX63_SEL register field value. */
17938 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_SET_MSK 0x00000001
17939 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX63_SEL register field value. */
17940 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_CLR_MSK 0xfffffffe
17941 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX63_SEL register field. */
17942 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_RESET 0x0
17943 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX63_SEL field value from a register. */
17944 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_GET(value) (((value) & 0x00000001) >> 0)
17945 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX63_SEL register field value suitable for setting the register. */
17946 #define ALT_SYSMGR_PINMUX_GPLINMUX63_SEL_SET(value) (((value) << 0) & 0x00000001)
17947
17948 #ifndef __ASSEMBLY__
17949 /*
17950  * WARNING: The C register and register group struct declarations are provided for
17951  * convenience and illustrative purposes. They should, however, be used with
17952  * caution as the C language standard provides no guarantees about the alignment or
17953  * atomicity of device memory accesses. The recommended practice for writing
17954  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
17955  * alt_write_word() functions.
17956  *
17957  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX63.
17958  */
17960 {
17961  uint32_t sel : 1; /* GPIO/Loan IO63Input Mux Selection Field */
17962  uint32_t : 31; /* *UNDEFINED* */
17963 };
17964
17965 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX63. */
17966 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX63_s ALT_SYSMGR_PINMUX_GPLINMUX63_t;
17967 #endif /* __ASSEMBLY__ */
17968
17969 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX63 register from the beginning of the component. */
17970 #define ALT_SYSMGR_PINMUX_GPLINMUX63_OFST 0x1b4
17971
17972 /*
17973  * Register : GPIO/LoanIO 64 Input Mux Selection Register - GPLINMUX64
17974  *
17975  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
17976  * the input signal for GPIO/LoanIO 64.
17977  *
17978  * Only reset by a cold reset (ignores warm reset).
17979  *
17980  * NOTE: These registers should not be modified after IO configuration.There is no
17981  * support for dynamically changing the Pin Mux selections.
17982  *
17983  * Register Layout
17984  *
17985  * Bits | Access | Reset | Description
17986  * :-------|:-------|:------|:----------------------------------------
17987  * [0] | RW | 0x0 | GPIO/Loan IO64Input Mux Selection Field
17988  * [31:1] | ??? | 0x0 | *UNDEFINED*
17989  *
17990  */
17991 /*
17992  * Field : GPIO/Loan IO64Input Mux Selection Field - sel
17993  *
17994  * Select source for GPIO/LoanIO 64.
17995  *
17996  * 0 : Source for GPIO/LoanIO 64 is GENERALIO16.
17997  *
17998  * 1 : Source for GPIO/LoanIO 64 is GENERALIO25.
17999  *
18000  * Field Access Macros:
18001  *
18002  */
18003 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX64_SEL register field. */
18004 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_LSB 0
18005 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX64_SEL register field. */
18006 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_MSB 0
18007 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX64_SEL register field. */
18008 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_WIDTH 1
18009 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX64_SEL register field value. */
18010 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_SET_MSK 0x00000001
18011 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX64_SEL register field value. */
18012 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_CLR_MSK 0xfffffffe
18013 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX64_SEL register field. */
18014 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_RESET 0x0
18015 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX64_SEL field value from a register. */
18016 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_GET(value) (((value) & 0x00000001) >> 0)
18017 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX64_SEL register field value suitable for setting the register. */
18018 #define ALT_SYSMGR_PINMUX_GPLINMUX64_SEL_SET(value) (((value) << 0) & 0x00000001)
18019
18020 #ifndef __ASSEMBLY__
18021 /*
18022  * WARNING: The C register and register group struct declarations are provided for
18023  * convenience and illustrative purposes. They should, however, be used with
18024  * caution as the C language standard provides no guarantees about the alignment or
18025  * atomicity of device memory accesses. The recommended practice for writing
18026  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18027  * alt_write_word() functions.
18028  *
18029  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX64.
18030  */
18032 {
18033  uint32_t sel : 1; /* GPIO/Loan IO64Input Mux Selection Field */
18034  uint32_t : 31; /* *UNDEFINED* */
18035 };
18036
18037 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX64. */
18038 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX64_s ALT_SYSMGR_PINMUX_GPLINMUX64_t;
18039 #endif /* __ASSEMBLY__ */
18040
18041 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX64 register from the beginning of the component. */
18042 #define ALT_SYSMGR_PINMUX_GPLINMUX64_OFST 0x1b8
18043
18044 /*
18045  * Register : GPIO/LoanIO 65 Input Mux Selection Register - GPLINMUX65
18046  *
18047  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
18048  * the input signal for GPIO/LoanIO 65.
18049  *
18050  * Only reset by a cold reset (ignores warm reset).
18051  *
18052  * NOTE: These registers should not be modified after IO configuration.There is no
18053  * support for dynamically changing the Pin Mux selections.
18054  *
18055  * Register Layout
18056  *
18057  * Bits | Access | Reset | Description
18058  * :-------|:-------|:------|:----------------------------------------
18059  * [0] | RW | 0x0 | GPIO/Loan IO65Input Mux Selection Field
18060  * [31:1] | ??? | 0x0 | *UNDEFINED*
18061  *
18062  */
18063 /*
18064  * Field : GPIO/Loan IO65Input Mux Selection Field - sel
18065  *
18066  * Select source for GPIO/LoanIO 65.
18067  *
18068  * 0 : Source for GPIO/LoanIO 65 is GENERALIO17.
18069  *
18070  * 1 : Source for GPIO/LoanIO 65 is GENERALIO26.
18071  *
18072  * Field Access Macros:
18073  *
18074  */
18075 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX65_SEL register field. */
18076 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_LSB 0
18077 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX65_SEL register field. */
18078 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_MSB 0
18079 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX65_SEL register field. */
18080 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_WIDTH 1
18081 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX65_SEL register field value. */
18082 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_SET_MSK 0x00000001
18083 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX65_SEL register field value. */
18084 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_CLR_MSK 0xfffffffe
18085 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX65_SEL register field. */
18086 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_RESET 0x0
18087 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX65_SEL field value from a register. */
18088 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_GET(value) (((value) & 0x00000001) >> 0)
18089 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX65_SEL register field value suitable for setting the register. */
18090 #define ALT_SYSMGR_PINMUX_GPLINMUX65_SEL_SET(value) (((value) << 0) & 0x00000001)
18091
18092 #ifndef __ASSEMBLY__
18093 /*
18094  * WARNING: The C register and register group struct declarations are provided for
18095  * convenience and illustrative purposes. They should, however, be used with
18096  * caution as the C language standard provides no guarantees about the alignment or
18097  * atomicity of device memory accesses. The recommended practice for writing
18098  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18099  * alt_write_word() functions.
18100  *
18101  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX65.
18102  */
18104 {
18105  uint32_t sel : 1; /* GPIO/Loan IO65Input Mux Selection Field */
18106  uint32_t : 31; /* *UNDEFINED* */
18107 };
18108
18109 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX65. */
18110 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX65_s ALT_SYSMGR_PINMUX_GPLINMUX65_t;
18111 #endif /* __ASSEMBLY__ */
18112
18113 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX65 register from the beginning of the component. */
18114 #define ALT_SYSMGR_PINMUX_GPLINMUX65_OFST 0x1bc
18115
18116 /*
18117  * Register : GPIO/LoanIO 66 Input Mux Selection Register - GPLINMUX66
18118  *
18119  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
18120  * the input signal for GPIO/LoanIO 66.
18121  *
18122  * Only reset by a cold reset (ignores warm reset).
18123  *
18124  * NOTE: These registers should not be modified after IO configuration.There is no
18125  * support for dynamically changing the Pin Mux selections.
18126  *
18127  * Register Layout
18128  *
18129  * Bits | Access | Reset | Description
18130  * :-------|:-------|:------|:----------------------------------------
18131  * [0] | RW | 0x0 | GPIO/Loan IO66Input Mux Selection Field
18132  * [31:1] | ??? | 0x0 | *UNDEFINED*
18133  *
18134  */
18135 /*
18136  * Field : GPIO/Loan IO66Input Mux Selection Field - sel
18137  *
18138  * Select source for GPIO/LoanIO 66.
18139  *
18140  * 0 : Source for GPIO/LoanIO 66 is GENERALIO18.
18141  *
18142  * 1 : Source for GPIO/LoanIO 66 is GENERALIO27.
18143  *
18144  * Field Access Macros:
18145  *
18146  */
18147 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX66_SEL register field. */
18148 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_LSB 0
18149 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX66_SEL register field. */
18150 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_MSB 0
18151 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX66_SEL register field. */
18152 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_WIDTH 1
18153 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX66_SEL register field value. */
18154 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_SET_MSK 0x00000001
18155 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX66_SEL register field value. */
18156 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_CLR_MSK 0xfffffffe
18157 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX66_SEL register field. */
18158 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_RESET 0x0
18159 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX66_SEL field value from a register. */
18160 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_GET(value) (((value) & 0x00000001) >> 0)
18161 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX66_SEL register field value suitable for setting the register. */
18162 #define ALT_SYSMGR_PINMUX_GPLINMUX66_SEL_SET(value) (((value) << 0) & 0x00000001)
18163
18164 #ifndef __ASSEMBLY__
18165 /*
18166  * WARNING: The C register and register group struct declarations are provided for
18167  * convenience and illustrative purposes. They should, however, be used with
18168  * caution as the C language standard provides no guarantees about the alignment or
18169  * atomicity of device memory accesses. The recommended practice for writing
18170  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18171  * alt_write_word() functions.
18172  *
18173  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX66.
18174  */
18176 {
18177  uint32_t sel : 1; /* GPIO/Loan IO66Input Mux Selection Field */
18178  uint32_t : 31; /* *UNDEFINED* */
18179 };
18180
18181 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX66. */
18182 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX66_s ALT_SYSMGR_PINMUX_GPLINMUX66_t;
18183 #endif /* __ASSEMBLY__ */
18184
18185 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX66 register from the beginning of the component. */
18186 #define ALT_SYSMGR_PINMUX_GPLINMUX66_OFST 0x1c0
18187
18188 /*
18189  * Register : GPIO/LoanIO 67 Input Mux Selection Register - GPLINMUX67
18190  *
18191  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
18192  * the input signal for GPIO/LoanIO 67.
18193  *
18194  * Only reset by a cold reset (ignores warm reset).
18195  *
18196  * NOTE: These registers should not be modified after IO configuration.There is no
18197  * support for dynamically changing the Pin Mux selections.
18198  *
18199  * Register Layout
18200  *
18201  * Bits | Access | Reset | Description
18202  * :-------|:-------|:------|:----------------------------------------
18203  * [0] | RW | 0x0 | GPIO/Loan IO67Input Mux Selection Field
18204  * [31:1] | ??? | 0x0 | *UNDEFINED*
18205  *
18206  */
18207 /*
18208  * Field : GPIO/Loan IO67Input Mux Selection Field - sel
18209  *
18210  * Select source for GPIO/LoanIO 67.
18211  *
18212  * 0 : Source for GPIO/LoanIO 67 is GENERALIO19.
18213  *
18214  * 1 : Source for GPIO/LoanIO 67 is GENERALIO28.
18215  *
18216  * Field Access Macros:
18217  *
18218  */
18219 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX67_SEL register field. */
18220 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_LSB 0
18221 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX67_SEL register field. */
18222 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_MSB 0
18223 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX67_SEL register field. */
18224 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_WIDTH 1
18225 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX67_SEL register field value. */
18226 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_SET_MSK 0x00000001
18227 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX67_SEL register field value. */
18228 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_CLR_MSK 0xfffffffe
18229 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX67_SEL register field. */
18230 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_RESET 0x0
18231 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX67_SEL field value from a register. */
18232 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_GET(value) (((value) & 0x00000001) >> 0)
18233 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX67_SEL register field value suitable for setting the register. */
18234 #define ALT_SYSMGR_PINMUX_GPLINMUX67_SEL_SET(value) (((value) << 0) & 0x00000001)
18235
18236 #ifndef __ASSEMBLY__
18237 /*
18238  * WARNING: The C register and register group struct declarations are provided for
18239  * convenience and illustrative purposes. They should, however, be used with
18240  * caution as the C language standard provides no guarantees about the alignment or
18241  * atomicity of device memory accesses. The recommended practice for writing
18242  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18243  * alt_write_word() functions.
18244  *
18245  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX67.
18246  */
18248 {
18249  uint32_t sel : 1; /* GPIO/Loan IO67Input Mux Selection Field */
18250  uint32_t : 31; /* *UNDEFINED* */
18251 };
18252
18253 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX67. */
18254 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX67_s ALT_SYSMGR_PINMUX_GPLINMUX67_t;
18255 #endif /* __ASSEMBLY__ */
18256
18257 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX67 register from the beginning of the component. */
18258 #define ALT_SYSMGR_PINMUX_GPLINMUX67_OFST 0x1c4
18259
18260 /*
18261  * Register : GPIO/LoanIO 68 Input Mux Selection Register - GPLINMUX68
18262  *
18263  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
18264  * the input signal for GPIO/LoanIO 68.
18265  *
18266  * Only reset by a cold reset (ignores warm reset).
18267  *
18268  * NOTE: These registers should not be modified after IO configuration.There is no
18269  * support for dynamically changing the Pin Mux selections.
18270  *
18271  * Register Layout
18272  *
18273  * Bits | Access | Reset | Description
18274  * :-------|:-------|:------|:----------------------------------------
18275  * [0] | RW | 0x0 | GPIO/Loan IO68Input Mux Selection Field
18276  * [31:1] | ??? | 0x0 | *UNDEFINED*
18277  *
18278  */
18279 /*
18280  * Field : GPIO/Loan IO68Input Mux Selection Field - sel
18281  *
18282  * Select source for GPIO/LoanIO 68.
18283  *
18284  * 0 : Source for GPIO/LoanIO 68 is GENERALIO20.
18285  *
18286  * 1 : Source for GPIO/LoanIO 68 is GENERALIO29.
18287  *
18288  * Field Access Macros:
18289  *
18290  */
18291 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX68_SEL register field. */
18292 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_LSB 0
18293 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX68_SEL register field. */
18294 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_MSB 0
18295 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX68_SEL register field. */
18296 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_WIDTH 1
18297 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX68_SEL register field value. */
18298 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_SET_MSK 0x00000001
18299 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX68_SEL register field value. */
18300 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_CLR_MSK 0xfffffffe
18301 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX68_SEL register field. */
18302 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_RESET 0x0
18303 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX68_SEL field value from a register. */
18304 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_GET(value) (((value) & 0x00000001) >> 0)
18305 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX68_SEL register field value suitable for setting the register. */
18306 #define ALT_SYSMGR_PINMUX_GPLINMUX68_SEL_SET(value) (((value) << 0) & 0x00000001)
18307
18308 #ifndef __ASSEMBLY__
18309 /*
18310  * WARNING: The C register and register group struct declarations are provided for
18311  * convenience and illustrative purposes. They should, however, be used with
18312  * caution as the C language standard provides no guarantees about the alignment or
18313  * atomicity of device memory accesses. The recommended practice for writing
18314  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18315  * alt_write_word() functions.
18316  *
18317  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX68.
18318  */
18320 {
18321  uint32_t sel : 1; /* GPIO/Loan IO68Input Mux Selection Field */
18322  uint32_t : 31; /* *UNDEFINED* */
18323 };
18324
18325 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX68. */
18326 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX68_s ALT_SYSMGR_PINMUX_GPLINMUX68_t;
18327 #endif /* __ASSEMBLY__ */
18328
18329 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX68 register from the beginning of the component. */
18330 #define ALT_SYSMGR_PINMUX_GPLINMUX68_OFST 0x1c8
18331
18332 /*
18333  * Register : GPIO/LoanIO 69 Input Mux Selection Register - GPLINMUX69
18334  *
18335  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
18336  * the input signal for GPIO/LoanIO 69.
18337  *
18338  * Only reset by a cold reset (ignores warm reset).
18339  *
18340  * NOTE: These registers should not be modified after IO configuration.There is no
18341  * support for dynamically changing the Pin Mux selections.
18342  *
18343  * Register Layout
18344  *
18345  * Bits | Access | Reset | Description
18346  * :-------|:-------|:------|:----------------------------------------
18347  * [0] | RW | 0x0 | GPIO/Loan IO69Input Mux Selection Field
18348  * [31:1] | ??? | 0x0 | *UNDEFINED*
18349  *
18350  */
18351 /*
18352  * Field : GPIO/Loan IO69Input Mux Selection Field - sel
18353  *
18354  * Select source for GPIO/LoanIO 69.
18355  *
18356  * 0 : Source for GPIO/LoanIO 69 is GENERALIO21.
18357  *
18358  * 1 : Source for GPIO/LoanIO 69 is GENERALIO30.
18359  *
18360  * Field Access Macros:
18361  *
18362  */
18363 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX69_SEL register field. */
18364 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_LSB 0
18365 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX69_SEL register field. */
18366 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_MSB 0
18367 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX69_SEL register field. */
18368 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_WIDTH 1
18369 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX69_SEL register field value. */
18370 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_SET_MSK 0x00000001
18371 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX69_SEL register field value. */
18372 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_CLR_MSK 0xfffffffe
18373 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX69_SEL register field. */
18374 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_RESET 0x0
18375 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX69_SEL field value from a register. */
18376 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_GET(value) (((value) & 0x00000001) >> 0)
18377 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX69_SEL register field value suitable for setting the register. */
18378 #define ALT_SYSMGR_PINMUX_GPLINMUX69_SEL_SET(value) (((value) << 0) & 0x00000001)
18379
18380 #ifndef __ASSEMBLY__
18381 /*
18382  * WARNING: The C register and register group struct declarations are provided for
18383  * convenience and illustrative purposes. They should, however, be used with
18384  * caution as the C language standard provides no guarantees about the alignment or
18385  * atomicity of device memory accesses. The recommended practice for writing
18386  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18387  * alt_write_word() functions.
18388  *
18389  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX69.
18390  */
18392 {
18393  uint32_t sel : 1; /* GPIO/Loan IO69Input Mux Selection Field */
18394  uint32_t : 31; /* *UNDEFINED* */
18395 };
18396
18397 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX69. */
18398 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX69_s ALT_SYSMGR_PINMUX_GPLINMUX69_t;
18399 #endif /* __ASSEMBLY__ */
18400
18401 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX69 register from the beginning of the component. */
18402 #define ALT_SYSMGR_PINMUX_GPLINMUX69_OFST 0x1cc
18403
18404 /*
18405  * Register : GPIO/LoanIO 70 Input Mux Selection Register - GPLINMUX70
18406  *
18407  * Some GPIO/LoanIO inputs can be driven by multiple pins. This register selects
18408  * the input signal for GPIO/LoanIO 70.
18409  *
18410  * Only reset by a cold reset (ignores warm reset).
18411  *
18412  * NOTE: These registers should not be modified after IO configuration.There is no
18413  * support for dynamically changing the Pin Mux selections.
18414  *
18415  * Register Layout
18416  *
18417  * Bits | Access | Reset | Description
18418  * :-------|:-------|:------|:----------------------------------------
18419  * [0] | RW | 0x0 | GPIO/Loan IO70Input Mux Selection Field
18420  * [31:1] | ??? | 0x0 | *UNDEFINED*
18421  *
18422  */
18423 /*
18424  * Field : GPIO/Loan IO70Input Mux Selection Field - sel
18425  *
18426  * Select source for GPIO/LoanIO 70.
18427  *
18428  * 0 : Source for GPIO/LoanIO 70 is GENERALIO22.
18429  *
18430  * 1 : Source for GPIO/LoanIO 70 is GENERALIO31.
18431  *
18432  * Field Access Macros:
18433  *
18434  */
18435 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX70_SEL register field. */
18436 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_LSB 0
18437 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLINMUX70_SEL register field. */
18438 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_MSB 0
18439 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLINMUX70_SEL register field. */
18440 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_WIDTH 1
18441 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLINMUX70_SEL register field value. */
18442 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_SET_MSK 0x00000001
18443 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLINMUX70_SEL register field value. */
18444 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_CLR_MSK 0xfffffffe
18445 /* The reset value of the ALT_SYSMGR_PINMUX_GPLINMUX70_SEL register field. */
18446 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_RESET 0x0
18447 /* Extracts the ALT_SYSMGR_PINMUX_GPLINMUX70_SEL field value from a register. */
18448 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_GET(value) (((value) & 0x00000001) >> 0)
18449 /* Produces a ALT_SYSMGR_PINMUX_GPLINMUX70_SEL register field value suitable for setting the register. */
18450 #define ALT_SYSMGR_PINMUX_GPLINMUX70_SEL_SET(value) (((value) << 0) & 0x00000001)
18451
18452 #ifndef __ASSEMBLY__
18453 /*
18454  * WARNING: The C register and register group struct declarations are provided for
18455  * convenience and illustrative purposes. They should, however, be used with
18456  * caution as the C language standard provides no guarantees about the alignment or
18457  * atomicity of device memory accesses. The recommended practice for writing
18458  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18459  * alt_write_word() functions.
18460  *
18461  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLINMUX70.
18462  */
18464 {
18465  uint32_t sel : 1; /* GPIO/Loan IO70Input Mux Selection Field */
18466  uint32_t : 31; /* *UNDEFINED* */
18467 };
18468
18469 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLINMUX70. */
18470 typedef volatile struct ALT_SYSMGR_PINMUX_GPLINMUX70_s ALT_SYSMGR_PINMUX_GPLINMUX70_t;
18471 #endif /* __ASSEMBLY__ */
18472
18473 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLINMUX70 register from the beginning of the component. */
18474 #define ALT_SYSMGR_PINMUX_GPLINMUX70_OFST 0x1d0
18475
18476 /*
18477  * Register : GPIO/LoanIO 0 Output/Output Enable Mux Selection Register - GPLMUX0
18478  *
18479  * Selection between GPIO and LoanIO output and output enable for GPIO0 and
18480  * LoanIO0. These signals drive the Pin Mux. The Pin Mux must be configured to use
18481  * GPIO/LoanIO in addition to these settings
18482  *
18483  * Only reset by a cold reset (ignores warm reset).
18484  *
18485  * NOTE: These registers should not be modified after IO configuration.There is no
18486  * support for dynamically changing the Pin Mux selections.
18487  *
18488  * Register Layout
18489  *
18490  * Bits | Access | Reset | Description
18491  * :-------|:-------|:------|:---------------------------------------
18492  * [0] | RW | 0x0 | GPIO/Loan IO0Input Mux Selection Field
18493  * [31:1] | ??? | 0x0 | *UNDEFINED*
18494  *
18495  */
18496 /*
18497  * Field : GPIO/Loan IO0Input Mux Selection Field - sel
18498  *
18499  * Select source for GPIO/LoanIO 0.
18500  *
18501  * 0 : LoanIO 0 controls GPIO/LOANIO[0] output and output enable signals.
18502  *
18503  * 1 : GPIO 0 controls GPIO/LOANI[0] output and output enable signals.
18504  *
18505  * Field Access Macros:
18506  *
18507  */
18508 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX0_SEL register field. */
18509 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_LSB 0
18510 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX0_SEL register field. */
18511 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_MSB 0
18512 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX0_SEL register field. */
18513 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_WIDTH 1
18514 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX0_SEL register field value. */
18515 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_SET_MSK 0x00000001
18516 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX0_SEL register field value. */
18517 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_CLR_MSK 0xfffffffe
18518 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX0_SEL register field. */
18519 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_RESET 0x0
18520 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX0_SEL field value from a register. */
18521 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_GET(value) (((value) & 0x00000001) >> 0)
18522 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX0_SEL register field value suitable for setting the register. */
18523 #define ALT_SYSMGR_PINMUX_GPLMUX0_SEL_SET(value) (((value) << 0) & 0x00000001)
18524
18525 #ifndef __ASSEMBLY__
18526 /*
18527  * WARNING: The C register and register group struct declarations are provided for
18528  * convenience and illustrative purposes. They should, however, be used with
18529  * caution as the C language standard provides no guarantees about the alignment or
18530  * atomicity of device memory accesses. The recommended practice for writing
18531  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18532  * alt_write_word() functions.
18533  *
18534  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX0.
18535  */
18537 {
18538  uint32_t sel : 1; /* GPIO/Loan IO0Input Mux Selection Field */
18539  uint32_t : 31; /* *UNDEFINED* */
18540 };
18541
18542 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX0. */
18543 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX0_s ALT_SYSMGR_PINMUX_GPLMUX0_t;
18544 #endif /* __ASSEMBLY__ */
18545
18546 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX0 register from the beginning of the component. */
18547 #define ALT_SYSMGR_PINMUX_GPLMUX0_OFST 0x1d4
18548
18549 /*
18550  * Register : GPIO/LoanIO 1 Output/Output Enable Mux Selection Register - GPLMUX1
18551  *
18552  * Selection between GPIO and LoanIO output and output enable for GPIO1 and
18553  * LoanIO1. These signals drive the Pin Mux. The Pin Mux must be configured to use
18554  * GPIO/LoanIO in addition to these settings
18555  *
18556  * Only reset by a cold reset (ignores warm reset).
18557  *
18558  * NOTE: These registers should not be modified after IO configuration.There is no
18559  * support for dynamically changing the Pin Mux selections.
18560  *
18561  * Register Layout
18562  *
18563  * Bits | Access | Reset | Description
18564  * :-------|:-------|:------|:---------------------------------------
18565  * [0] | RW | 0x0 | GPIO/Loan IO1Input Mux Selection Field
18566  * [31:1] | ??? | 0x0 | *UNDEFINED*
18567  *
18568  */
18569 /*
18570  * Field : GPIO/Loan IO1Input Mux Selection Field - sel
18571  *
18572  * Select source for GPIO/LoanIO 1.
18573  *
18574  * 0 : LoanIO 1 controls GPIO/LOANIO[1] output and output enable signals.
18575  *
18576  * 1 : GPIO 1 controls GPIO/LOANI[1] output and output enable signals.
18577  *
18578  * Field Access Macros:
18579  *
18580  */
18581 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX1_SEL register field. */
18582 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_LSB 0
18583 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX1_SEL register field. */
18584 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_MSB 0
18585 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX1_SEL register field. */
18586 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_WIDTH 1
18587 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX1_SEL register field value. */
18588 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_SET_MSK 0x00000001
18589 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX1_SEL register field value. */
18590 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_CLR_MSK 0xfffffffe
18591 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX1_SEL register field. */
18592 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_RESET 0x0
18593 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX1_SEL field value from a register. */
18594 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_GET(value) (((value) & 0x00000001) >> 0)
18595 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX1_SEL register field value suitable for setting the register. */
18596 #define ALT_SYSMGR_PINMUX_GPLMUX1_SEL_SET(value) (((value) << 0) & 0x00000001)
18597
18598 #ifndef __ASSEMBLY__
18599 /*
18600  * WARNING: The C register and register group struct declarations are provided for
18601  * convenience and illustrative purposes. They should, however, be used with
18602  * caution as the C language standard provides no guarantees about the alignment or
18603  * atomicity of device memory accesses. The recommended practice for writing
18604  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18605  * alt_write_word() functions.
18606  *
18607  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX1.
18608  */
18610 {
18611  uint32_t sel : 1; /* GPIO/Loan IO1Input Mux Selection Field */
18612  uint32_t : 31; /* *UNDEFINED* */
18613 };
18614
18615 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX1. */
18616 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX1_s ALT_SYSMGR_PINMUX_GPLMUX1_t;
18617 #endif /* __ASSEMBLY__ */
18618
18619 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX1 register from the beginning of the component. */
18620 #define ALT_SYSMGR_PINMUX_GPLMUX1_OFST 0x1d8
18621
18622 /*
18623  * Register : GPIO/LoanIO 2 Output/Output Enable Mux Selection Register - GPLMUX2
18624  *
18625  * Selection between GPIO and LoanIO output and output enable for GPIO2 and
18626  * LoanIO2. These signals drive the Pin Mux. The Pin Mux must be configured to use
18627  * GPIO/LoanIO in addition to these settings
18628  *
18629  * Only reset by a cold reset (ignores warm reset).
18630  *
18631  * NOTE: These registers should not be modified after IO configuration.There is no
18632  * support for dynamically changing the Pin Mux selections.
18633  *
18634  * Register Layout
18635  *
18636  * Bits | Access | Reset | Description
18637  * :-------|:-------|:------|:---------------------------------------
18638  * [0] | RW | 0x0 | GPIO/Loan IO2Input Mux Selection Field
18639  * [31:1] | ??? | 0x0 | *UNDEFINED*
18640  *
18641  */
18642 /*
18643  * Field : GPIO/Loan IO2Input Mux Selection Field - sel
18644  *
18645  * Select source for GPIO/LoanIO 2.
18646  *
18647  * 0 : LoanIO 2 controls GPIO/LOANIO[2] output and output enable signals.
18648  *
18649  * 1 : GPIO 2 controls GPIO/LOANI[2] output and output enable signals.
18650  *
18651  * Field Access Macros:
18652  *
18653  */
18654 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX2_SEL register field. */
18655 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_LSB 0
18656 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX2_SEL register field. */
18657 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_MSB 0
18658 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX2_SEL register field. */
18659 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_WIDTH 1
18660 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX2_SEL register field value. */
18661 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_SET_MSK 0x00000001
18662 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX2_SEL register field value. */
18663 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_CLR_MSK 0xfffffffe
18664 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX2_SEL register field. */
18665 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_RESET 0x0
18666 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX2_SEL field value from a register. */
18667 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_GET(value) (((value) & 0x00000001) >> 0)
18668 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX2_SEL register field value suitable for setting the register. */
18669 #define ALT_SYSMGR_PINMUX_GPLMUX2_SEL_SET(value) (((value) << 0) & 0x00000001)
18670
18671 #ifndef __ASSEMBLY__
18672 /*
18673  * WARNING: The C register and register group struct declarations are provided for
18674  * convenience and illustrative purposes. They should, however, be used with
18675  * caution as the C language standard provides no guarantees about the alignment or
18676  * atomicity of device memory accesses. The recommended practice for writing
18677  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18678  * alt_write_word() functions.
18679  *
18680  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX2.
18681  */
18683 {
18684  uint32_t sel : 1; /* GPIO/Loan IO2Input Mux Selection Field */
18685  uint32_t : 31; /* *UNDEFINED* */
18686 };
18687
18688 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX2. */
18689 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX2_s ALT_SYSMGR_PINMUX_GPLMUX2_t;
18690 #endif /* __ASSEMBLY__ */
18691
18692 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX2 register from the beginning of the component. */
18693 #define ALT_SYSMGR_PINMUX_GPLMUX2_OFST 0x1dc
18694
18695 /*
18696  * Register : GPIO/LoanIO 3 Output/Output Enable Mux Selection Register - GPLMUX3
18697  *
18698  * Selection between GPIO and LoanIO output and output enable for GPIO3 and
18699  * LoanIO3. These signals drive the Pin Mux. The Pin Mux must be configured to use
18700  * GPIO/LoanIO in addition to these settings
18701  *
18702  * Only reset by a cold reset (ignores warm reset).
18703  *
18704  * NOTE: These registers should not be modified after IO configuration.There is no
18705  * support for dynamically changing the Pin Mux selections.
18706  *
18707  * Register Layout
18708  *
18709  * Bits | Access | Reset | Description
18710  * :-------|:-------|:------|:---------------------------------------
18711  * [0] | RW | 0x0 | GPIO/Loan IO3Input Mux Selection Field
18712  * [31:1] | ??? | 0x0 | *UNDEFINED*
18713  *
18714  */
18715 /*
18716  * Field : GPIO/Loan IO3Input Mux Selection Field - sel
18717  *
18718  * Select source for GPIO/LoanIO 3.
18719  *
18720  * 0 : LoanIO 3 controls GPIO/LOANIO[3] output and output enable signals.
18721  *
18722  * 1 : GPIO 3 controls GPIO/LOANI[3] output and output enable signals.
18723  *
18724  * Field Access Macros:
18725  *
18726  */
18727 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX3_SEL register field. */
18728 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_LSB 0
18729 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX3_SEL register field. */
18730 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_MSB 0
18731 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX3_SEL register field. */
18732 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_WIDTH 1
18733 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX3_SEL register field value. */
18734 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_SET_MSK 0x00000001
18735 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX3_SEL register field value. */
18736 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_CLR_MSK 0xfffffffe
18737 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX3_SEL register field. */
18738 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_RESET 0x0
18739 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX3_SEL field value from a register. */
18740 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_GET(value) (((value) & 0x00000001) >> 0)
18741 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX3_SEL register field value suitable for setting the register. */
18742 #define ALT_SYSMGR_PINMUX_GPLMUX3_SEL_SET(value) (((value) << 0) & 0x00000001)
18743
18744 #ifndef __ASSEMBLY__
18745 /*
18746  * WARNING: The C register and register group struct declarations are provided for
18747  * convenience and illustrative purposes. They should, however, be used with
18748  * caution as the C language standard provides no guarantees about the alignment or
18749  * atomicity of device memory accesses. The recommended practice for writing
18750  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18751  * alt_write_word() functions.
18752  *
18753  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX3.
18754  */
18756 {
18757  uint32_t sel : 1; /* GPIO/Loan IO3Input Mux Selection Field */
18758  uint32_t : 31; /* *UNDEFINED* */
18759 };
18760
18761 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX3. */
18762 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX3_s ALT_SYSMGR_PINMUX_GPLMUX3_t;
18763 #endif /* __ASSEMBLY__ */
18764
18765 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX3 register from the beginning of the component. */
18766 #define ALT_SYSMGR_PINMUX_GPLMUX3_OFST 0x1e0
18767
18768 /*
18769  * Register : GPIO/LoanIO 4 Output/Output Enable Mux Selection Register - GPLMUX4
18770  *
18771  * Selection between GPIO and LoanIO output and output enable for GPIO4 and
18772  * LoanIO4. These signals drive the Pin Mux. The Pin Mux must be configured to use
18773  * GPIO/LoanIO in addition to these settings
18774  *
18775  * Only reset by a cold reset (ignores warm reset).
18776  *
18777  * NOTE: These registers should not be modified after IO configuration.There is no
18778  * support for dynamically changing the Pin Mux selections.
18779  *
18780  * Register Layout
18781  *
18782  * Bits | Access | Reset | Description
18783  * :-------|:-------|:------|:---------------------------------------
18784  * [0] | RW | 0x0 | GPIO/Loan IO4Input Mux Selection Field
18785  * [31:1] | ??? | 0x0 | *UNDEFINED*
18786  *
18787  */
18788 /*
18789  * Field : GPIO/Loan IO4Input Mux Selection Field - sel
18790  *
18791  * Select source for GPIO/LoanIO 4.
18792  *
18793  * 0 : LoanIO 4 controls GPIO/LOANIO[4] output and output enable signals.
18794  *
18795  * 1 : GPIO 4 controls GPIO/LOANI[4] output and output enable signals.
18796  *
18797  * Field Access Macros:
18798  *
18799  */
18800 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX4_SEL register field. */
18801 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_LSB 0
18802 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX4_SEL register field. */
18803 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_MSB 0
18804 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX4_SEL register field. */
18805 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_WIDTH 1
18806 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX4_SEL register field value. */
18807 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_SET_MSK 0x00000001
18808 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX4_SEL register field value. */
18809 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_CLR_MSK 0xfffffffe
18810 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX4_SEL register field. */
18811 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_RESET 0x0
18812 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX4_SEL field value from a register. */
18813 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_GET(value) (((value) & 0x00000001) >> 0)
18814 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX4_SEL register field value suitable for setting the register. */
18815 #define ALT_SYSMGR_PINMUX_GPLMUX4_SEL_SET(value) (((value) << 0) & 0x00000001)
18816
18817 #ifndef __ASSEMBLY__
18818 /*
18819  * WARNING: The C register and register group struct declarations are provided for
18820  * convenience and illustrative purposes. They should, however, be used with
18821  * caution as the C language standard provides no guarantees about the alignment or
18822  * atomicity of device memory accesses. The recommended practice for writing
18823  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18824  * alt_write_word() functions.
18825  *
18826  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX4.
18827  */
18829 {
18830  uint32_t sel : 1; /* GPIO/Loan IO4Input Mux Selection Field */
18831  uint32_t : 31; /* *UNDEFINED* */
18832 };
18833
18834 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX4. */
18835 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX4_s ALT_SYSMGR_PINMUX_GPLMUX4_t;
18836 #endif /* __ASSEMBLY__ */
18837
18838 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX4 register from the beginning of the component. */
18839 #define ALT_SYSMGR_PINMUX_GPLMUX4_OFST 0x1e4
18840
18841 /*
18842  * Register : GPIO/LoanIO 5 Output/Output Enable Mux Selection Register - GPLMUX5
18843  *
18844  * Selection between GPIO and LoanIO output and output enable for GPIO5 and
18845  * LoanIO5. These signals drive the Pin Mux. The Pin Mux must be configured to use
18846  * GPIO/LoanIO in addition to these settings
18847  *
18848  * Only reset by a cold reset (ignores warm reset).
18849  *
18850  * NOTE: These registers should not be modified after IO configuration.There is no
18851  * support for dynamically changing the Pin Mux selections.
18852  *
18853  * Register Layout
18854  *
18855  * Bits | Access | Reset | Description
18856  * :-------|:-------|:------|:---------------------------------------
18857  * [0] | RW | 0x0 | GPIO/Loan IO5Input Mux Selection Field
18858  * [31:1] | ??? | 0x0 | *UNDEFINED*
18859  *
18860  */
18861 /*
18862  * Field : GPIO/Loan IO5Input Mux Selection Field - sel
18863  *
18864  * Select source for GPIO/LoanIO 5.
18865  *
18866  * 0 : LoanIO 5 controls GPIO/LOANIO[5] output and output enable signals.
18867  *
18868  * 1 : GPIO 5 controls GPIO/LOANI[5] output and output enable signals.
18869  *
18870  * Field Access Macros:
18871  *
18872  */
18873 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX5_SEL register field. */
18874 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_LSB 0
18875 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX5_SEL register field. */
18876 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_MSB 0
18877 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX5_SEL register field. */
18878 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_WIDTH 1
18879 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX5_SEL register field value. */
18880 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_SET_MSK 0x00000001
18881 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX5_SEL register field value. */
18882 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_CLR_MSK 0xfffffffe
18883 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX5_SEL register field. */
18884 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_RESET 0x0
18885 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX5_SEL field value from a register. */
18886 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_GET(value) (((value) & 0x00000001) >> 0)
18887 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX5_SEL register field value suitable for setting the register. */
18888 #define ALT_SYSMGR_PINMUX_GPLMUX5_SEL_SET(value) (((value) << 0) & 0x00000001)
18889
18890 #ifndef __ASSEMBLY__
18891 /*
18892  * WARNING: The C register and register group struct declarations are provided for
18893  * convenience and illustrative purposes. They should, however, be used with
18894  * caution as the C language standard provides no guarantees about the alignment or
18895  * atomicity of device memory accesses. The recommended practice for writing
18896  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18897  * alt_write_word() functions.
18898  *
18899  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX5.
18900  */
18902 {
18903  uint32_t sel : 1; /* GPIO/Loan IO5Input Mux Selection Field */
18904  uint32_t : 31; /* *UNDEFINED* */
18905 };
18906
18907 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX5. */
18908 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX5_s ALT_SYSMGR_PINMUX_GPLMUX5_t;
18909 #endif /* __ASSEMBLY__ */
18910
18911 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX5 register from the beginning of the component. */
18912 #define ALT_SYSMGR_PINMUX_GPLMUX5_OFST 0x1e8
18913
18914 /*
18915  * Register : GPIO/LoanIO 6 Output/Output Enable Mux Selection Register - GPLMUX6
18916  *
18917  * Selection between GPIO and LoanIO output and output enable for GPIO6 and
18918  * LoanIO6. These signals drive the Pin Mux. The Pin Mux must be configured to use
18919  * GPIO/LoanIO in addition to these settings
18920  *
18921  * Only reset by a cold reset (ignores warm reset).
18922  *
18923  * NOTE: These registers should not be modified after IO configuration.There is no
18924  * support for dynamically changing the Pin Mux selections.
18925  *
18926  * Register Layout
18927  *
18928  * Bits | Access | Reset | Description
18929  * :-------|:-------|:------|:---------------------------------------
18930  * [0] | RW | 0x0 | GPIO/Loan IO6Input Mux Selection Field
18931  * [31:1] | ??? | 0x0 | *UNDEFINED*
18932  *
18933  */
18934 /*
18935  * Field : GPIO/Loan IO6Input Mux Selection Field - sel
18936  *
18937  * Select source for GPIO/LoanIO 6.
18938  *
18939  * 0 : LoanIO 6 controls GPIO/LOANIO[6] output and output enable signals.
18940  *
18941  * 1 : GPIO 6 controls GPIO/LOANI[6] output and output enable signals.
18942  *
18943  * Field Access Macros:
18944  *
18945  */
18946 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX6_SEL register field. */
18947 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_LSB 0
18948 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX6_SEL register field. */
18949 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_MSB 0
18950 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX6_SEL register field. */
18951 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_WIDTH 1
18952 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX6_SEL register field value. */
18953 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_SET_MSK 0x00000001
18954 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX6_SEL register field value. */
18955 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_CLR_MSK 0xfffffffe
18956 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX6_SEL register field. */
18957 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_RESET 0x0
18958 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX6_SEL field value from a register. */
18959 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_GET(value) (((value) & 0x00000001) >> 0)
18960 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX6_SEL register field value suitable for setting the register. */
18961 #define ALT_SYSMGR_PINMUX_GPLMUX6_SEL_SET(value) (((value) << 0) & 0x00000001)
18962
18963 #ifndef __ASSEMBLY__
18964 /*
18965  * WARNING: The C register and register group struct declarations are provided for
18966  * convenience and illustrative purposes. They should, however, be used with
18967  * caution as the C language standard provides no guarantees about the alignment or
18968  * atomicity of device memory accesses. The recommended practice for writing
18969  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
18970  * alt_write_word() functions.
18971  *
18972  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX6.
18973  */
18975 {
18976  uint32_t sel : 1; /* GPIO/Loan IO6Input Mux Selection Field */
18977  uint32_t : 31; /* *UNDEFINED* */
18978 };
18979
18980 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX6. */
18981 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX6_s ALT_SYSMGR_PINMUX_GPLMUX6_t;
18982 #endif /* __ASSEMBLY__ */
18983
18984 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX6 register from the beginning of the component. */
18985 #define ALT_SYSMGR_PINMUX_GPLMUX6_OFST 0x1ec
18986
18987 /*
18988  * Register : GPIO/LoanIO 7 Output/Output Enable Mux Selection Register - GPLMUX7
18989  *
18990  * Selection between GPIO and LoanIO output and output enable for GPIO7 and
18991  * LoanIO7. These signals drive the Pin Mux. The Pin Mux must be configured to use
18992  * GPIO/LoanIO in addition to these settings
18993  *
18994  * Only reset by a cold reset (ignores warm reset).
18995  *
18996  * NOTE: These registers should not be modified after IO configuration.There is no
18997  * support for dynamically changing the Pin Mux selections.
18998  *
18999  * Register Layout
19000  *
19001  * Bits | Access | Reset | Description
19002  * :-------|:-------|:------|:---------------------------------------
19003  * [0] | RW | 0x0 | GPIO/Loan IO7Input Mux Selection Field
19004  * [31:1] | ??? | 0x0 | *UNDEFINED*
19005  *
19006  */
19007 /*
19008  * Field : GPIO/Loan IO7Input Mux Selection Field - sel
19009  *
19010  * Select source for GPIO/LoanIO 7.
19011  *
19012  * 0 : LoanIO 7 controls GPIO/LOANIO[7] output and output enable signals.
19013  *
19014  * 1 : GPIO 7 controls GPIO/LOANI[7] output and output enable signals.
19015  *
19016  * Field Access Macros:
19017  *
19018  */
19019 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX7_SEL register field. */
19020 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_LSB 0
19021 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX7_SEL register field. */
19022 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_MSB 0
19023 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX7_SEL register field. */
19024 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_WIDTH 1
19025 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX7_SEL register field value. */
19026 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_SET_MSK 0x00000001
19027 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX7_SEL register field value. */
19028 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_CLR_MSK 0xfffffffe
19029 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX7_SEL register field. */
19030 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_RESET 0x0
19031 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX7_SEL field value from a register. */
19032 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_GET(value) (((value) & 0x00000001) >> 0)
19033 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX7_SEL register field value suitable for setting the register. */
19034 #define ALT_SYSMGR_PINMUX_GPLMUX7_SEL_SET(value) (((value) << 0) & 0x00000001)
19035
19036 #ifndef __ASSEMBLY__
19037 /*
19038  * WARNING: The C register and register group struct declarations are provided for
19039  * convenience and illustrative purposes. They should, however, be used with
19040  * caution as the C language standard provides no guarantees about the alignment or
19041  * atomicity of device memory accesses. The recommended practice for writing
19042  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19043  * alt_write_word() functions.
19044  *
19045  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX7.
19046  */
19048 {
19049  uint32_t sel : 1; /* GPIO/Loan IO7Input Mux Selection Field */
19050  uint32_t : 31; /* *UNDEFINED* */
19051 };
19052
19053 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX7. */
19054 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX7_s ALT_SYSMGR_PINMUX_GPLMUX7_t;
19055 #endif /* __ASSEMBLY__ */
19056
19057 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX7 register from the beginning of the component. */
19058 #define ALT_SYSMGR_PINMUX_GPLMUX7_OFST 0x1f0
19059
19060 /*
19061  * Register : GPIO/LoanIO 8 Output/Output Enable Mux Selection Register - GPLMUX8
19062  *
19063  * Selection between GPIO and LoanIO output and output enable for GPIO8 and
19064  * LoanIO8. These signals drive the Pin Mux. The Pin Mux must be configured to use
19065  * GPIO/LoanIO in addition to these settings
19066  *
19067  * Only reset by a cold reset (ignores warm reset).
19068  *
19069  * NOTE: These registers should not be modified after IO configuration.There is no
19070  * support for dynamically changing the Pin Mux selections.
19071  *
19072  * Register Layout
19073  *
19074  * Bits | Access | Reset | Description
19075  * :-------|:-------|:------|:---------------------------------------
19076  * [0] | RW | 0x0 | GPIO/Loan IO8Input Mux Selection Field
19077  * [31:1] | ??? | 0x0 | *UNDEFINED*
19078  *
19079  */
19080 /*
19081  * Field : GPIO/Loan IO8Input Mux Selection Field - sel
19082  *
19083  * Select source for GPIO/LoanIO 8.
19084  *
19085  * 0 : LoanIO 8 controls GPIO/LOANIO[8] output and output enable signals.
19086  *
19087  * 1 : GPIO 8 controls GPIO/LOANI[8] output and output enable signals.
19088  *
19089  * Field Access Macros:
19090  *
19091  */
19092 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX8_SEL register field. */
19093 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_LSB 0
19094 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX8_SEL register field. */
19095 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_MSB 0
19096 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX8_SEL register field. */
19097 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_WIDTH 1
19098 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX8_SEL register field value. */
19099 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_SET_MSK 0x00000001
19100 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX8_SEL register field value. */
19101 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_CLR_MSK 0xfffffffe
19102 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX8_SEL register field. */
19103 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_RESET 0x0
19104 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX8_SEL field value from a register. */
19105 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_GET(value) (((value) & 0x00000001) >> 0)
19106 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX8_SEL register field value suitable for setting the register. */
19107 #define ALT_SYSMGR_PINMUX_GPLMUX8_SEL_SET(value) (((value) << 0) & 0x00000001)
19108
19109 #ifndef __ASSEMBLY__
19110 /*
19111  * WARNING: The C register and register group struct declarations are provided for
19112  * convenience and illustrative purposes. They should, however, be used with
19113  * caution as the C language standard provides no guarantees about the alignment or
19114  * atomicity of device memory accesses. The recommended practice for writing
19115  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19116  * alt_write_word() functions.
19117  *
19118  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX8.
19119  */
19121 {
19122  uint32_t sel : 1; /* GPIO/Loan IO8Input Mux Selection Field */
19123  uint32_t : 31; /* *UNDEFINED* */
19124 };
19125
19126 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX8. */
19127 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX8_s ALT_SYSMGR_PINMUX_GPLMUX8_t;
19128 #endif /* __ASSEMBLY__ */
19129
19130 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX8 register from the beginning of the component. */
19131 #define ALT_SYSMGR_PINMUX_GPLMUX8_OFST 0x1f4
19132
19133 /*
19134  * Register : GPIO/LoanIO 9 Output/Output Enable Mux Selection Register - GPLMUX9
19135  *
19136  * Selection between GPIO and LoanIO output and output enable for GPIO9 and
19137  * LoanIO9. These signals drive the Pin Mux. The Pin Mux must be configured to use
19138  * GPIO/LoanIO in addition to these settings
19139  *
19140  * Only reset by a cold reset (ignores warm reset).
19141  *
19142  * NOTE: These registers should not be modified after IO configuration.There is no
19143  * support for dynamically changing the Pin Mux selections.
19144  *
19145  * Register Layout
19146  *
19147  * Bits | Access | Reset | Description
19148  * :-------|:-------|:------|:---------------------------------------
19149  * [0] | RW | 0x0 | GPIO/Loan IO9Input Mux Selection Field
19150  * [31:1] | ??? | 0x0 | *UNDEFINED*
19151  *
19152  */
19153 /*
19154  * Field : GPIO/Loan IO9Input Mux Selection Field - sel
19155  *
19156  * Select source for GPIO/LoanIO 9.
19157  *
19158  * 0 : LoanIO 9 controls GPIO/LOANIO[9] output and output enable signals.
19159  *
19160  * 1 : GPIO 9 controls GPIO/LOANI[9] output and output enable signals.
19161  *
19162  * Field Access Macros:
19163  *
19164  */
19165 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX9_SEL register field. */
19166 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_LSB 0
19167 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX9_SEL register field. */
19168 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_MSB 0
19169 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX9_SEL register field. */
19170 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_WIDTH 1
19171 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX9_SEL register field value. */
19172 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_SET_MSK 0x00000001
19173 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX9_SEL register field value. */
19174 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_CLR_MSK 0xfffffffe
19175 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX9_SEL register field. */
19176 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_RESET 0x0
19177 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX9_SEL field value from a register. */
19178 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_GET(value) (((value) & 0x00000001) >> 0)
19179 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX9_SEL register field value suitable for setting the register. */
19180 #define ALT_SYSMGR_PINMUX_GPLMUX9_SEL_SET(value) (((value) << 0) & 0x00000001)
19181
19182 #ifndef __ASSEMBLY__
19183 /*
19184  * WARNING: The C register and register group struct declarations are provided for
19185  * convenience and illustrative purposes. They should, however, be used with
19186  * caution as the C language standard provides no guarantees about the alignment or
19187  * atomicity of device memory accesses. The recommended practice for writing
19188  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19189  * alt_write_word() functions.
19190  *
19191  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX9.
19192  */
19194 {
19195  uint32_t sel : 1; /* GPIO/Loan IO9Input Mux Selection Field */
19196  uint32_t : 31; /* *UNDEFINED* */
19197 };
19198
19199 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX9. */
19200 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX9_s ALT_SYSMGR_PINMUX_GPLMUX9_t;
19201 #endif /* __ASSEMBLY__ */
19202
19203 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX9 register from the beginning of the component. */
19204 #define ALT_SYSMGR_PINMUX_GPLMUX9_OFST 0x1f8
19205
19206 /*
19207  * Register : GPIO/LoanIO 10 Output/Output Enable Mux Selection Register - GPLMUX10
19208  *
19209  * Selection between GPIO and LoanIO output and output enable for GPIO10 and
19210  * LoanIO10. These signals drive the Pin Mux. The Pin Mux must be configured to use
19211  * GPIO/LoanIO in addition to these settings
19212  *
19213  * Only reset by a cold reset (ignores warm reset).
19214  *
19215  * NOTE: These registers should not be modified after IO configuration.There is no
19216  * support for dynamically changing the Pin Mux selections.
19217  *
19218  * Register Layout
19219  *
19220  * Bits | Access | Reset | Description
19221  * :-------|:-------|:------|:----------------------------------------
19222  * [0] | RW | 0x0 | GPIO/Loan IO10Input Mux Selection Field
19223  * [31:1] | ??? | 0x0 | *UNDEFINED*
19224  *
19225  */
19226 /*
19227  * Field : GPIO/Loan IO10Input Mux Selection Field - sel
19228  *
19229  * Select source for GPIO/LoanIO 10.
19230  *
19231  * 0 : LoanIO 10 controls GPIO/LOANIO[10] output and output enable signals.
19232  *
19233  * 1 : GPIO 10 controls GPIO/LOANI[10] output and output enable signals.
19234  *
19235  * Field Access Macros:
19236  *
19237  */
19238 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX10_SEL register field. */
19239 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_LSB 0
19240 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX10_SEL register field. */
19241 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_MSB 0
19242 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX10_SEL register field. */
19243 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_WIDTH 1
19244 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX10_SEL register field value. */
19245 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_SET_MSK 0x00000001
19246 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX10_SEL register field value. */
19247 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_CLR_MSK 0xfffffffe
19248 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX10_SEL register field. */
19249 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_RESET 0x0
19250 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX10_SEL field value from a register. */
19251 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_GET(value) (((value) & 0x00000001) >> 0)
19252 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX10_SEL register field value suitable for setting the register. */
19253 #define ALT_SYSMGR_PINMUX_GPLMUX10_SEL_SET(value) (((value) << 0) & 0x00000001)
19254
19255 #ifndef __ASSEMBLY__
19256 /*
19257  * WARNING: The C register and register group struct declarations are provided for
19258  * convenience and illustrative purposes. They should, however, be used with
19259  * caution as the C language standard provides no guarantees about the alignment or
19260  * atomicity of device memory accesses. The recommended practice for writing
19261  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19262  * alt_write_word() functions.
19263  *
19264  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX10.
19265  */
19267 {
19268  uint32_t sel : 1; /* GPIO/Loan IO10Input Mux Selection Field */
19269  uint32_t : 31; /* *UNDEFINED* */
19270 };
19271
19272 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX10. */
19273 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX10_s ALT_SYSMGR_PINMUX_GPLMUX10_t;
19274 #endif /* __ASSEMBLY__ */
19275
19276 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX10 register from the beginning of the component. */
19277 #define ALT_SYSMGR_PINMUX_GPLMUX10_OFST 0x1fc
19278
19279 /*
19280  * Register : GPIO/LoanIO 11 Output/Output Enable Mux Selection Register - GPLMUX11
19281  *
19282  * Selection between GPIO and LoanIO output and output enable for GPIO11 and
19283  * LoanIO11. These signals drive the Pin Mux. The Pin Mux must be configured to use
19284  * GPIO/LoanIO in addition to these settings
19285  *
19286  * Only reset by a cold reset (ignores warm reset).
19287  *
19288  * NOTE: These registers should not be modified after IO configuration.There is no
19289  * support for dynamically changing the Pin Mux selections.
19290  *
19291  * Register Layout
19292  *
19293  * Bits | Access | Reset | Description
19294  * :-------|:-------|:------|:----------------------------------------
19295  * [0] | RW | 0x0 | GPIO/Loan IO11Input Mux Selection Field
19296  * [31:1] | ??? | 0x0 | *UNDEFINED*
19297  *
19298  */
19299 /*
19300  * Field : GPIO/Loan IO11Input Mux Selection Field - sel
19301  *
19302  * Select source for GPIO/LoanIO 11.
19303  *
19304  * 0 : LoanIO 11 controls GPIO/LOANIO[11] output and output enable signals.
19305  *
19306  * 1 : GPIO 11 controls GPIO/LOANI[11] output and output enable signals.
19307  *
19308  * Field Access Macros:
19309  *
19310  */
19311 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX11_SEL register field. */
19312 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_LSB 0
19313 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX11_SEL register field. */
19314 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_MSB 0
19315 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX11_SEL register field. */
19316 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_WIDTH 1
19317 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX11_SEL register field value. */
19318 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_SET_MSK 0x00000001
19319 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX11_SEL register field value. */
19320 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_CLR_MSK 0xfffffffe
19321 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX11_SEL register field. */
19322 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_RESET 0x0
19323 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX11_SEL field value from a register. */
19324 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_GET(value) (((value) & 0x00000001) >> 0)
19325 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX11_SEL register field value suitable for setting the register. */
19326 #define ALT_SYSMGR_PINMUX_GPLMUX11_SEL_SET(value) (((value) << 0) & 0x00000001)
19327
19328 #ifndef __ASSEMBLY__
19329 /*
19330  * WARNING: The C register and register group struct declarations are provided for
19331  * convenience and illustrative purposes. They should, however, be used with
19332  * caution as the C language standard provides no guarantees about the alignment or
19333  * atomicity of device memory accesses. The recommended practice for writing
19334  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19335  * alt_write_word() functions.
19336  *
19337  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX11.
19338  */
19340 {
19341  uint32_t sel : 1; /* GPIO/Loan IO11Input Mux Selection Field */
19342  uint32_t : 31; /* *UNDEFINED* */
19343 };
19344
19345 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX11. */
19346 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX11_s ALT_SYSMGR_PINMUX_GPLMUX11_t;
19347 #endif /* __ASSEMBLY__ */
19348
19349 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX11 register from the beginning of the component. */
19350 #define ALT_SYSMGR_PINMUX_GPLMUX11_OFST 0x200
19351
19352 /*
19353  * Register : GPIO/LoanIO 12 Output/Output Enable Mux Selection Register - GPLMUX12
19354  *
19355  * Selection between GPIO and LoanIO output and output enable for GPIO12 and
19356  * LoanIO12. These signals drive the Pin Mux. The Pin Mux must be configured to use
19357  * GPIO/LoanIO in addition to these settings
19358  *
19359  * Only reset by a cold reset (ignores warm reset).
19360  *
19361  * NOTE: These registers should not be modified after IO configuration.There is no
19362  * support for dynamically changing the Pin Mux selections.
19363  *
19364  * Register Layout
19365  *
19366  * Bits | Access | Reset | Description
19367  * :-------|:-------|:------|:----------------------------------------
19368  * [0] | RW | 0x0 | GPIO/Loan IO12Input Mux Selection Field
19369  * [31:1] | ??? | 0x0 | *UNDEFINED*
19370  *
19371  */
19372 /*
19373  * Field : GPIO/Loan IO12Input Mux Selection Field - sel
19374  *
19375  * Select source for GPIO/LoanIO 12.
19376  *
19377  * 0 : LoanIO 12 controls GPIO/LOANIO[12] output and output enable signals.
19378  *
19379  * 1 : GPIO 12 controls GPIO/LOANI[12] output and output enable signals.
19380  *
19381  * Field Access Macros:
19382  *
19383  */
19384 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX12_SEL register field. */
19385 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_LSB 0
19386 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX12_SEL register field. */
19387 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_MSB 0
19388 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX12_SEL register field. */
19389 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_WIDTH 1
19390 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX12_SEL register field value. */
19391 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_SET_MSK 0x00000001
19392 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX12_SEL register field value. */
19393 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_CLR_MSK 0xfffffffe
19394 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX12_SEL register field. */
19395 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_RESET 0x0
19396 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX12_SEL field value from a register. */
19397 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_GET(value) (((value) & 0x00000001) >> 0)
19398 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX12_SEL register field value suitable for setting the register. */
19399 #define ALT_SYSMGR_PINMUX_GPLMUX12_SEL_SET(value) (((value) << 0) & 0x00000001)
19400
19401 #ifndef __ASSEMBLY__
19402 /*
19403  * WARNING: The C register and register group struct declarations are provided for
19404  * convenience and illustrative purposes. They should, however, be used with
19405  * caution as the C language standard provides no guarantees about the alignment or
19406  * atomicity of device memory accesses. The recommended practice for writing
19407  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19408  * alt_write_word() functions.
19409  *
19410  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX12.
19411  */
19413 {
19414  uint32_t sel : 1; /* GPIO/Loan IO12Input Mux Selection Field */
19415  uint32_t : 31; /* *UNDEFINED* */
19416 };
19417
19418 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX12. */
19419 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX12_s ALT_SYSMGR_PINMUX_GPLMUX12_t;
19420 #endif /* __ASSEMBLY__ */
19421
19422 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX12 register from the beginning of the component. */
19423 #define ALT_SYSMGR_PINMUX_GPLMUX12_OFST 0x204
19424
19425 /*
19426  * Register : GPIO/LoanIO 13 Output/Output Enable Mux Selection Register - GPLMUX13
19427  *
19428  * Selection between GPIO and LoanIO output and output enable for GPIO13 and
19429  * LoanIO13. These signals drive the Pin Mux. The Pin Mux must be configured to use
19430  * GPIO/LoanIO in addition to these settings
19431  *
19432  * Only reset by a cold reset (ignores warm reset).
19433  *
19434  * NOTE: These registers should not be modified after IO configuration.There is no
19435  * support for dynamically changing the Pin Mux selections.
19436  *
19437  * Register Layout
19438  *
19439  * Bits | Access | Reset | Description
19440  * :-------|:-------|:------|:----------------------------------------
19441  * [0] | RW | 0x0 | GPIO/Loan IO13Input Mux Selection Field
19442  * [31:1] | ??? | 0x0 | *UNDEFINED*
19443  *
19444  */
19445 /*
19446  * Field : GPIO/Loan IO13Input Mux Selection Field - sel
19447  *
19448  * Select source for GPIO/LoanIO 13.
19449  *
19450  * 0 : LoanIO 13 controls GPIO/LOANIO[13] output and output enable signals.
19451  *
19452  * 1 : GPIO 13 controls GPIO/LOANI[13] output and output enable signals.
19453  *
19454  * Field Access Macros:
19455  *
19456  */
19457 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX13_SEL register field. */
19458 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_LSB 0
19459 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX13_SEL register field. */
19460 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_MSB 0
19461 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX13_SEL register field. */
19462 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_WIDTH 1
19463 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX13_SEL register field value. */
19464 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_SET_MSK 0x00000001
19465 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX13_SEL register field value. */
19466 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_CLR_MSK 0xfffffffe
19467 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX13_SEL register field. */
19468 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_RESET 0x0
19469 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX13_SEL field value from a register. */
19470 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_GET(value) (((value) & 0x00000001) >> 0)
19471 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX13_SEL register field value suitable for setting the register. */
19472 #define ALT_SYSMGR_PINMUX_GPLMUX13_SEL_SET(value) (((value) << 0) & 0x00000001)
19473
19474 #ifndef __ASSEMBLY__
19475 /*
19476  * WARNING: The C register and register group struct declarations are provided for
19477  * convenience and illustrative purposes. They should, however, be used with
19478  * caution as the C language standard provides no guarantees about the alignment or
19479  * atomicity of device memory accesses. The recommended practice for writing
19480  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19481  * alt_write_word() functions.
19482  *
19483  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX13.
19484  */
19486 {
19487  uint32_t sel : 1; /* GPIO/Loan IO13Input Mux Selection Field */
19488  uint32_t : 31; /* *UNDEFINED* */
19489 };
19490
19491 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX13. */
19492 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX13_s ALT_SYSMGR_PINMUX_GPLMUX13_t;
19493 #endif /* __ASSEMBLY__ */
19494
19495 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX13 register from the beginning of the component. */
19496 #define ALT_SYSMGR_PINMUX_GPLMUX13_OFST 0x208
19497
19498 /*
19499  * Register : GPIO/LoanIO 14 Output/Output Enable Mux Selection Register - GPLMUX14
19500  *
19501  * Selection between GPIO and LoanIO output and output enable for GPIO14 and
19502  * LoanIO14. These signals drive the Pin Mux. The Pin Mux must be configured to use
19503  * GPIO/LoanIO in addition to these settings
19504  *
19505  * Only reset by a cold reset (ignores warm reset).
19506  *
19507  * NOTE: These registers should not be modified after IO configuration.There is no
19508  * support for dynamically changing the Pin Mux selections.
19509  *
19510  * Register Layout
19511  *
19512  * Bits | Access | Reset | Description
19513  * :-------|:-------|:------|:----------------------------------------
19514  * [0] | RW | 0x0 | GPIO/Loan IO14Input Mux Selection Field
19515  * [31:1] | ??? | 0x0 | *UNDEFINED*
19516  *
19517  */
19518 /*
19519  * Field : GPIO/Loan IO14Input Mux Selection Field - sel
19520  *
19521  * Select source for GPIO/LoanIO 14.
19522  *
19523  * 0 : LoanIO 14 controls GPIO/LOANIO[14] output and output enable signals.
19524  *
19525  * 1 : GPIO 14 controls GPIO/LOANI[14] output and output enable signals.
19526  *
19527  * Field Access Macros:
19528  *
19529  */
19530 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX14_SEL register field. */
19531 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_LSB 0
19532 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX14_SEL register field. */
19533 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_MSB 0
19534 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX14_SEL register field. */
19535 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_WIDTH 1
19536 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX14_SEL register field value. */
19537 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_SET_MSK 0x00000001
19538 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX14_SEL register field value. */
19539 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_CLR_MSK 0xfffffffe
19540 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX14_SEL register field. */
19541 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_RESET 0x0
19542 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX14_SEL field value from a register. */
19543 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_GET(value) (((value) & 0x00000001) >> 0)
19544 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX14_SEL register field value suitable for setting the register. */
19545 #define ALT_SYSMGR_PINMUX_GPLMUX14_SEL_SET(value) (((value) << 0) & 0x00000001)
19546
19547 #ifndef __ASSEMBLY__
19548 /*
19549  * WARNING: The C register and register group struct declarations are provided for
19550  * convenience and illustrative purposes. They should, however, be used with
19551  * caution as the C language standard provides no guarantees about the alignment or
19552  * atomicity of device memory accesses. The recommended practice for writing
19553  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19554  * alt_write_word() functions.
19555  *
19556  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX14.
19557  */
19559 {
19560  uint32_t sel : 1; /* GPIO/Loan IO14Input Mux Selection Field */
19561  uint32_t : 31; /* *UNDEFINED* */
19562 };
19563
19564 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX14. */
19565 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX14_s ALT_SYSMGR_PINMUX_GPLMUX14_t;
19566 #endif /* __ASSEMBLY__ */
19567
19568 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX14 register from the beginning of the component. */
19569 #define ALT_SYSMGR_PINMUX_GPLMUX14_OFST 0x20c
19570
19571 /*
19572  * Register : GPIO/LoanIO 15 Output/Output Enable Mux Selection Register - GPLMUX15
19573  *
19574  * Selection between GPIO and LoanIO output and output enable for GPIO15 and
19575  * LoanIO15. These signals drive the Pin Mux. The Pin Mux must be configured to use
19576  * GPIO/LoanIO in addition to these settings
19577  *
19578  * Only reset by a cold reset (ignores warm reset).
19579  *
19580  * NOTE: These registers should not be modified after IO configuration.There is no
19581  * support for dynamically changing the Pin Mux selections.
19582  *
19583  * Register Layout
19584  *
19585  * Bits | Access | Reset | Description
19586  * :-------|:-------|:------|:----------------------------------------
19587  * [0] | RW | 0x0 | GPIO/Loan IO15Input Mux Selection Field
19588  * [31:1] | ??? | 0x0 | *UNDEFINED*
19589  *
19590  */
19591 /*
19592  * Field : GPIO/Loan IO15Input Mux Selection Field - sel
19593  *
19594  * Select source for GPIO/LoanIO 15.
19595  *
19596  * 0 : LoanIO 15 controls GPIO/LOANIO[15] output and output enable signals.
19597  *
19598  * 1 : GPIO 15 controls GPIO/LOANI[15] output and output enable signals.
19599  *
19600  * Field Access Macros:
19601  *
19602  */
19603 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX15_SEL register field. */
19604 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_LSB 0
19605 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX15_SEL register field. */
19606 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_MSB 0
19607 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX15_SEL register field. */
19608 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_WIDTH 1
19609 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX15_SEL register field value. */
19610 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_SET_MSK 0x00000001
19611 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX15_SEL register field value. */
19612 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_CLR_MSK 0xfffffffe
19613 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX15_SEL register field. */
19614 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_RESET 0x0
19615 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX15_SEL field value from a register. */
19616 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_GET(value) (((value) & 0x00000001) >> 0)
19617 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX15_SEL register field value suitable for setting the register. */
19618 #define ALT_SYSMGR_PINMUX_GPLMUX15_SEL_SET(value) (((value) << 0) & 0x00000001)
19619
19620 #ifndef __ASSEMBLY__
19621 /*
19622  * WARNING: The C register and register group struct declarations are provided for
19623  * convenience and illustrative purposes. They should, however, be used with
19624  * caution as the C language standard provides no guarantees about the alignment or
19625  * atomicity of device memory accesses. The recommended practice for writing
19626  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19627  * alt_write_word() functions.
19628  *
19629  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX15.
19630  */
19632 {
19633  uint32_t sel : 1; /* GPIO/Loan IO15Input Mux Selection Field */
19634  uint32_t : 31; /* *UNDEFINED* */
19635 };
19636
19637 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX15. */
19638 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX15_s ALT_SYSMGR_PINMUX_GPLMUX15_t;
19639 #endif /* __ASSEMBLY__ */
19640
19641 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX15 register from the beginning of the component. */
19642 #define ALT_SYSMGR_PINMUX_GPLMUX15_OFST 0x210
19643
19644 /*
19645  * Register : GPIO/LoanIO 16 Output/Output Enable Mux Selection Register - GPLMUX16
19646  *
19647  * Selection between GPIO and LoanIO output and output enable for GPIO16 and
19648  * LoanIO16. These signals drive the Pin Mux. The Pin Mux must be configured to use
19649  * GPIO/LoanIO in addition to these settings
19650  *
19651  * Only reset by a cold reset (ignores warm reset).
19652  *
19653  * NOTE: These registers should not be modified after IO configuration.There is no
19654  * support for dynamically changing the Pin Mux selections.
19655  *
19656  * Register Layout
19657  *
19658  * Bits | Access | Reset | Description
19659  * :-------|:-------|:------|:----------------------------------------
19660  * [0] | RW | 0x0 | GPIO/Loan IO16Input Mux Selection Field
19661  * [31:1] | ??? | 0x0 | *UNDEFINED*
19662  *
19663  */
19664 /*
19665  * Field : GPIO/Loan IO16Input Mux Selection Field - sel
19666  *
19667  * Select source for GPIO/LoanIO 16.
19668  *
19669  * 0 : LoanIO 16 controls GPIO/LOANIO[16] output and output enable signals.
19670  *
19671  * 1 : GPIO 16 controls GPIO/LOANI[16] output and output enable signals.
19672  *
19673  * Field Access Macros:
19674  *
19675  */
19676 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX16_SEL register field. */
19677 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_LSB 0
19678 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX16_SEL register field. */
19679 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_MSB 0
19680 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX16_SEL register field. */
19681 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_WIDTH 1
19682 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX16_SEL register field value. */
19683 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_SET_MSK 0x00000001
19684 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX16_SEL register field value. */
19685 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_CLR_MSK 0xfffffffe
19686 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX16_SEL register field. */
19687 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_RESET 0x0
19688 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX16_SEL field value from a register. */
19689 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_GET(value) (((value) & 0x00000001) >> 0)
19690 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX16_SEL register field value suitable for setting the register. */
19691 #define ALT_SYSMGR_PINMUX_GPLMUX16_SEL_SET(value) (((value) << 0) & 0x00000001)
19692
19693 #ifndef __ASSEMBLY__
19694 /*
19695  * WARNING: The C register and register group struct declarations are provided for
19696  * convenience and illustrative purposes. They should, however, be used with
19697  * caution as the C language standard provides no guarantees about the alignment or
19698  * atomicity of device memory accesses. The recommended practice for writing
19699  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19700  * alt_write_word() functions.
19701  *
19702  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX16.
19703  */
19705 {
19706  uint32_t sel : 1; /* GPIO/Loan IO16Input Mux Selection Field */
19707  uint32_t : 31; /* *UNDEFINED* */
19708 };
19709
19710 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX16. */
19711 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX16_s ALT_SYSMGR_PINMUX_GPLMUX16_t;
19712 #endif /* __ASSEMBLY__ */
19713
19714 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX16 register from the beginning of the component. */
19715 #define ALT_SYSMGR_PINMUX_GPLMUX16_OFST 0x214
19716
19717 /*
19718  * Register : GPIO/LoanIO 17 Output/Output Enable Mux Selection Register - GPLMUX17
19719  *
19720  * Selection between GPIO and LoanIO output and output enable for GPIO17 and
19721  * LoanIO17. These signals drive the Pin Mux. The Pin Mux must be configured to use
19722  * GPIO/LoanIO in addition to these settings
19723  *
19724  * Only reset by a cold reset (ignores warm reset).
19725  *
19726  * NOTE: These registers should not be modified after IO configuration.There is no
19727  * support for dynamically changing the Pin Mux selections.
19728  *
19729  * Register Layout
19730  *
19731  * Bits | Access | Reset | Description
19732  * :-------|:-------|:------|:----------------------------------------
19733  * [0] | RW | 0x0 | GPIO/Loan IO17Input Mux Selection Field
19734  * [31:1] | ??? | 0x0 | *UNDEFINED*
19735  *
19736  */
19737 /*
19738  * Field : GPIO/Loan IO17Input Mux Selection Field - sel
19739  *
19740  * Select source for GPIO/LoanIO 17.
19741  *
19742  * 0 : LoanIO 17 controls GPIO/LOANIO[17] output and output enable signals.
19743  *
19744  * 1 : GPIO 17 controls GPIO/LOANI[17] output and output enable signals.
19745  *
19746  * Field Access Macros:
19747  *
19748  */
19749 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX17_SEL register field. */
19750 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_LSB 0
19751 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX17_SEL register field. */
19752 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_MSB 0
19753 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX17_SEL register field. */
19754 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_WIDTH 1
19755 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX17_SEL register field value. */
19756 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_SET_MSK 0x00000001
19757 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX17_SEL register field value. */
19758 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_CLR_MSK 0xfffffffe
19759 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX17_SEL register field. */
19760 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_RESET 0x0
19761 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX17_SEL field value from a register. */
19762 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_GET(value) (((value) & 0x00000001) >> 0)
19763 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX17_SEL register field value suitable for setting the register. */
19764 #define ALT_SYSMGR_PINMUX_GPLMUX17_SEL_SET(value) (((value) << 0) & 0x00000001)
19765
19766 #ifndef __ASSEMBLY__
19767 /*
19768  * WARNING: The C register and register group struct declarations are provided for
19769  * convenience and illustrative purposes. They should, however, be used with
19770  * caution as the C language standard provides no guarantees about the alignment or
19771  * atomicity of device memory accesses. The recommended practice for writing
19772  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19773  * alt_write_word() functions.
19774  *
19775  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX17.
19776  */
19778 {
19779  uint32_t sel : 1; /* GPIO/Loan IO17Input Mux Selection Field */
19780  uint32_t : 31; /* *UNDEFINED* */
19781 };
19782
19783 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX17. */
19784 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX17_s ALT_SYSMGR_PINMUX_GPLMUX17_t;
19785 #endif /* __ASSEMBLY__ */
19786
19787 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX17 register from the beginning of the component. */
19788 #define ALT_SYSMGR_PINMUX_GPLMUX17_OFST 0x218
19789
19790 /*
19791  * Register : GPIO/LoanIO 18 Output/Output Enable Mux Selection Register - GPLMUX18
19792  *
19793  * Selection between GPIO and LoanIO output and output enable for GPIO18 and
19794  * LoanIO18. These signals drive the Pin Mux. The Pin Mux must be configured to use
19795  * GPIO/LoanIO in addition to these settings
19796  *
19797  * Only reset by a cold reset (ignores warm reset).
19798  *
19799  * NOTE: These registers should not be modified after IO configuration.There is no
19800  * support for dynamically changing the Pin Mux selections.
19801  *
19802  * Register Layout
19803  *
19804  * Bits | Access | Reset | Description
19805  * :-------|:-------|:------|:----------------------------------------
19806  * [0] | RW | 0x0 | GPIO/Loan IO18Input Mux Selection Field
19807  * [31:1] | ??? | 0x0 | *UNDEFINED*
19808  *
19809  */
19810 /*
19811  * Field : GPIO/Loan IO18Input Mux Selection Field - sel
19812  *
19813  * Select source for GPIO/LoanIO 18.
19814  *
19815  * 0 : LoanIO 18 controls GPIO/LOANIO[18] output and output enable signals.
19816  *
19817  * 1 : GPIO 18 controls GPIO/LOANI[18] output and output enable signals.
19818  *
19819  * Field Access Macros:
19820  *
19821  */
19822 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX18_SEL register field. */
19823 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_LSB 0
19824 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX18_SEL register field. */
19825 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_MSB 0
19826 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX18_SEL register field. */
19827 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_WIDTH 1
19828 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX18_SEL register field value. */
19829 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_SET_MSK 0x00000001
19830 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX18_SEL register field value. */
19831 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_CLR_MSK 0xfffffffe
19832 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX18_SEL register field. */
19833 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_RESET 0x0
19834 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX18_SEL field value from a register. */
19835 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_GET(value) (((value) & 0x00000001) >> 0)
19836 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX18_SEL register field value suitable for setting the register. */
19837 #define ALT_SYSMGR_PINMUX_GPLMUX18_SEL_SET(value) (((value) << 0) & 0x00000001)
19838
19839 #ifndef __ASSEMBLY__
19840 /*
19841  * WARNING: The C register and register group struct declarations are provided for
19842  * convenience and illustrative purposes. They should, however, be used with
19843  * caution as the C language standard provides no guarantees about the alignment or
19844  * atomicity of device memory accesses. The recommended practice for writing
19845  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19846  * alt_write_word() functions.
19847  *
19848  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX18.
19849  */
19851 {
19852  uint32_t sel : 1; /* GPIO/Loan IO18Input Mux Selection Field */
19853  uint32_t : 31; /* *UNDEFINED* */
19854 };
19855
19856 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX18. */
19857 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX18_s ALT_SYSMGR_PINMUX_GPLMUX18_t;
19858 #endif /* __ASSEMBLY__ */
19859
19860 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX18 register from the beginning of the component. */
19861 #define ALT_SYSMGR_PINMUX_GPLMUX18_OFST 0x21c
19862
19863 /*
19864  * Register : GPIO/LoanIO 19 Output/Output Enable Mux Selection Register - GPLMUX19
19865  *
19866  * Selection between GPIO and LoanIO output and output enable for GPIO19 and
19867  * LoanIO19. These signals drive the Pin Mux. The Pin Mux must be configured to use
19868  * GPIO/LoanIO in addition to these settings
19869  *
19870  * Only reset by a cold reset (ignores warm reset).
19871  *
19872  * NOTE: These registers should not be modified after IO configuration.There is no
19873  * support for dynamically changing the Pin Mux selections.
19874  *
19875  * Register Layout
19876  *
19877  * Bits | Access | Reset | Description
19878  * :-------|:-------|:------|:----------------------------------------
19879  * [0] | RW | 0x0 | GPIO/Loan IO19Input Mux Selection Field
19880  * [31:1] | ??? | 0x0 | *UNDEFINED*
19881  *
19882  */
19883 /*
19884  * Field : GPIO/Loan IO19Input Mux Selection Field - sel
19885  *
19886  * Select source for GPIO/LoanIO 19.
19887  *
19888  * 0 : LoanIO 19 controls GPIO/LOANIO[19] output and output enable signals.
19889  *
19890  * 1 : GPIO 19 controls GPIO/LOANI[19] output and output enable signals.
19891  *
19892  * Field Access Macros:
19893  *
19894  */
19895 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX19_SEL register field. */
19896 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_LSB 0
19897 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX19_SEL register field. */
19898 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_MSB 0
19899 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX19_SEL register field. */
19900 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_WIDTH 1
19901 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX19_SEL register field value. */
19902 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_SET_MSK 0x00000001
19903 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX19_SEL register field value. */
19904 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_CLR_MSK 0xfffffffe
19905 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX19_SEL register field. */
19906 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_RESET 0x0
19907 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX19_SEL field value from a register. */
19908 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_GET(value) (((value) & 0x00000001) >> 0)
19909 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX19_SEL register field value suitable for setting the register. */
19910 #define ALT_SYSMGR_PINMUX_GPLMUX19_SEL_SET(value) (((value) << 0) & 0x00000001)
19911
19912 #ifndef __ASSEMBLY__
19913 /*
19914  * WARNING: The C register and register group struct declarations are provided for
19915  * convenience and illustrative purposes. They should, however, be used with
19916  * caution as the C language standard provides no guarantees about the alignment or
19917  * atomicity of device memory accesses. The recommended practice for writing
19918  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19919  * alt_write_word() functions.
19920  *
19921  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX19.
19922  */
19924 {
19925  uint32_t sel : 1; /* GPIO/Loan IO19Input Mux Selection Field */
19926  uint32_t : 31; /* *UNDEFINED* */
19927 };
19928
19929 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX19. */
19930 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX19_s ALT_SYSMGR_PINMUX_GPLMUX19_t;
19931 #endif /* __ASSEMBLY__ */
19932
19933 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX19 register from the beginning of the component. */
19934 #define ALT_SYSMGR_PINMUX_GPLMUX19_OFST 0x220
19935
19936 /*
19937  * Register : GPIO/LoanIO 20 Output/Output Enable Mux Selection Register - GPLMUX20
19938  *
19939  * Selection between GPIO and LoanIO output and output enable for GPIO20 and
19940  * LoanIO20. These signals drive the Pin Mux. The Pin Mux must be configured to use
19941  * GPIO/LoanIO in addition to these settings
19942  *
19943  * Only reset by a cold reset (ignores warm reset).
19944  *
19945  * NOTE: These registers should not be modified after IO configuration.There is no
19946  * support for dynamically changing the Pin Mux selections.
19947  *
19948  * Register Layout
19949  *
19950  * Bits | Access | Reset | Description
19951  * :-------|:-------|:------|:----------------------------------------
19952  * [0] | RW | 0x0 | GPIO/Loan IO20Input Mux Selection Field
19953  * [31:1] | ??? | 0x0 | *UNDEFINED*
19954  *
19955  */
19956 /*
19957  * Field : GPIO/Loan IO20Input Mux Selection Field - sel
19958  *
19959  * Select source for GPIO/LoanIO 20.
19960  *
19961  * 0 : LoanIO 20 controls GPIO/LOANIO[20] output and output enable signals.
19962  *
19963  * 1 : GPIO 20 controls GPIO/LOANI[20] output and output enable signals.
19964  *
19965  * Field Access Macros:
19966  *
19967  */
19968 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX20_SEL register field. */
19969 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_LSB 0
19970 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX20_SEL register field. */
19971 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_MSB 0
19972 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX20_SEL register field. */
19973 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_WIDTH 1
19974 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX20_SEL register field value. */
19975 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_SET_MSK 0x00000001
19976 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX20_SEL register field value. */
19977 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_CLR_MSK 0xfffffffe
19978 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX20_SEL register field. */
19979 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_RESET 0x0
19980 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX20_SEL field value from a register. */
19981 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_GET(value) (((value) & 0x00000001) >> 0)
19982 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX20_SEL register field value suitable for setting the register. */
19983 #define ALT_SYSMGR_PINMUX_GPLMUX20_SEL_SET(value) (((value) << 0) & 0x00000001)
19984
19985 #ifndef __ASSEMBLY__
19986 /*
19987  * WARNING: The C register and register group struct declarations are provided for
19988  * convenience and illustrative purposes. They should, however, be used with
19989  * caution as the C language standard provides no guarantees about the alignment or
19990  * atomicity of device memory accesses. The recommended practice for writing
19991  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
19992  * alt_write_word() functions.
19993  *
19994  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX20.
19995  */
19997 {
19998  uint32_t sel : 1; /* GPIO/Loan IO20Input Mux Selection Field */
19999  uint32_t : 31; /* *UNDEFINED* */
20000 };
20001
20002 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX20. */
20003 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX20_s ALT_SYSMGR_PINMUX_GPLMUX20_t;
20004 #endif /* __ASSEMBLY__ */
20005
20006 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX20 register from the beginning of the component. */
20007 #define ALT_SYSMGR_PINMUX_GPLMUX20_OFST 0x224
20008
20009 /*
20010  * Register : GPIO/LoanIO 21 Output/Output Enable Mux Selection Register - GPLMUX21
20011  *
20012  * Selection between GPIO and LoanIO output and output enable for GPIO21 and
20013  * LoanIO21. These signals drive the Pin Mux. The Pin Mux must be configured to use
20014  * GPIO/LoanIO in addition to these settings
20015  *
20016  * Only reset by a cold reset (ignores warm reset).
20017  *
20018  * NOTE: These registers should not be modified after IO configuration.There is no
20019  * support for dynamically changing the Pin Mux selections.
20020  *
20021  * Register Layout
20022  *
20023  * Bits | Access | Reset | Description
20024  * :-------|:-------|:------|:----------------------------------------
20025  * [0] | RW | 0x0 | GPIO/Loan IO21Input Mux Selection Field
20026  * [31:1] | ??? | 0x0 | *UNDEFINED*
20027  *
20028  */
20029 /*
20030  * Field : GPIO/Loan IO21Input Mux Selection Field - sel
20031  *
20032  * Select source for GPIO/LoanIO 21.
20033  *
20034  * 0 : LoanIO 21 controls GPIO/LOANIO[21] output and output enable signals.
20035  *
20036  * 1 : GPIO 21 controls GPIO/LOANI[21] output and output enable signals.
20037  *
20038  * Field Access Macros:
20039  *
20040  */
20041 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX21_SEL register field. */
20042 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_LSB 0
20043 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX21_SEL register field. */
20044 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_MSB 0
20045 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX21_SEL register field. */
20046 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_WIDTH 1
20047 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX21_SEL register field value. */
20048 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_SET_MSK 0x00000001
20049 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX21_SEL register field value. */
20050 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_CLR_MSK 0xfffffffe
20051 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX21_SEL register field. */
20052 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_RESET 0x0
20053 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX21_SEL field value from a register. */
20054 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_GET(value) (((value) & 0x00000001) >> 0)
20055 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX21_SEL register field value suitable for setting the register. */
20056 #define ALT_SYSMGR_PINMUX_GPLMUX21_SEL_SET(value) (((value) << 0) & 0x00000001)
20057
20058 #ifndef __ASSEMBLY__
20059 /*
20060  * WARNING: The C register and register group struct declarations are provided for
20061  * convenience and illustrative purposes. They should, however, be used with
20062  * caution as the C language standard provides no guarantees about the alignment or
20063  * atomicity of device memory accesses. The recommended practice for writing
20064  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20065  * alt_write_word() functions.
20066  *
20067  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX21.
20068  */
20070 {
20071  uint32_t sel : 1; /* GPIO/Loan IO21Input Mux Selection Field */
20072  uint32_t : 31; /* *UNDEFINED* */
20073 };
20074
20075 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX21. */
20076 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX21_s ALT_SYSMGR_PINMUX_GPLMUX21_t;
20077 #endif /* __ASSEMBLY__ */
20078
20079 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX21 register from the beginning of the component. */
20080 #define ALT_SYSMGR_PINMUX_GPLMUX21_OFST 0x228
20081
20082 /*
20083  * Register : GPIO/LoanIO 22 Output/Output Enable Mux Selection Register - GPLMUX22
20084  *
20085  * Selection between GPIO and LoanIO output and output enable for GPIO22 and
20086  * LoanIO22. These signals drive the Pin Mux. The Pin Mux must be configured to use
20087  * GPIO/LoanIO in addition to these settings
20088  *
20089  * Only reset by a cold reset (ignores warm reset).
20090  *
20091  * NOTE: These registers should not be modified after IO configuration.There is no
20092  * support for dynamically changing the Pin Mux selections.
20093  *
20094  * Register Layout
20095  *
20096  * Bits | Access | Reset | Description
20097  * :-------|:-------|:------|:----------------------------------------
20098  * [0] | RW | 0x0 | GPIO/Loan IO22Input Mux Selection Field
20099  * [31:1] | ??? | 0x0 | *UNDEFINED*
20100  *
20101  */
20102 /*
20103  * Field : GPIO/Loan IO22Input Mux Selection Field - sel
20104  *
20105  * Select source for GPIO/LoanIO 22.
20106  *
20107  * 0 : LoanIO 22 controls GPIO/LOANIO[22] output and output enable signals.
20108  *
20109  * 1 : GPIO 22 controls GPIO/LOANI[22] output and output enable signals.
20110  *
20111  * Field Access Macros:
20112  *
20113  */
20114 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX22_SEL register field. */
20115 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_LSB 0
20116 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX22_SEL register field. */
20117 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_MSB 0
20118 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX22_SEL register field. */
20119 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_WIDTH 1
20120 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX22_SEL register field value. */
20121 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_SET_MSK 0x00000001
20122 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX22_SEL register field value. */
20123 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_CLR_MSK 0xfffffffe
20124 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX22_SEL register field. */
20125 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_RESET 0x0
20126 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX22_SEL field value from a register. */
20127 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_GET(value) (((value) & 0x00000001) >> 0)
20128 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX22_SEL register field value suitable for setting the register. */
20129 #define ALT_SYSMGR_PINMUX_GPLMUX22_SEL_SET(value) (((value) << 0) & 0x00000001)
20130
20131 #ifndef __ASSEMBLY__
20132 /*
20133  * WARNING: The C register and register group struct declarations are provided for
20134  * convenience and illustrative purposes. They should, however, be used with
20135  * caution as the C language standard provides no guarantees about the alignment or
20136  * atomicity of device memory accesses. The recommended practice for writing
20137  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20138  * alt_write_word() functions.
20139  *
20140  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX22.
20141  */
20143 {
20144  uint32_t sel : 1; /* GPIO/Loan IO22Input Mux Selection Field */
20145  uint32_t : 31; /* *UNDEFINED* */
20146 };
20147
20148 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX22. */
20149 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX22_s ALT_SYSMGR_PINMUX_GPLMUX22_t;
20150 #endif /* __ASSEMBLY__ */
20151
20152 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX22 register from the beginning of the component. */
20153 #define ALT_SYSMGR_PINMUX_GPLMUX22_OFST 0x22c
20154
20155 /*
20156  * Register : GPIO/LoanIO 23 Output/Output Enable Mux Selection Register - GPLMUX23
20157  *
20158  * Selection between GPIO and LoanIO output and output enable for GPIO23 and
20159  * LoanIO23. These signals drive the Pin Mux. The Pin Mux must be configured to use
20160  * GPIO/LoanIO in addition to these settings
20161  *
20162  * Only reset by a cold reset (ignores warm reset).
20163  *
20164  * NOTE: These registers should not be modified after IO configuration.There is no
20165  * support for dynamically changing the Pin Mux selections.
20166  *
20167  * Register Layout
20168  *
20169  * Bits | Access | Reset | Description
20170  * :-------|:-------|:------|:----------------------------------------
20171  * [0] | RW | 0x0 | GPIO/Loan IO23Input Mux Selection Field
20172  * [31:1] | ??? | 0x0 | *UNDEFINED*
20173  *
20174  */
20175 /*
20176  * Field : GPIO/Loan IO23Input Mux Selection Field - sel
20177  *
20178  * Select source for GPIO/LoanIO 23.
20179  *
20180  * 0 : LoanIO 23 controls GPIO/LOANIO[23] output and output enable signals.
20181  *
20182  * 1 : GPIO 23 controls GPIO/LOANI[23] output and output enable signals.
20183  *
20184  * Field Access Macros:
20185  *
20186  */
20187 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX23_SEL register field. */
20188 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_LSB 0
20189 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX23_SEL register field. */
20190 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_MSB 0
20191 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX23_SEL register field. */
20192 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_WIDTH 1
20193 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX23_SEL register field value. */
20194 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_SET_MSK 0x00000001
20195 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX23_SEL register field value. */
20196 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_CLR_MSK 0xfffffffe
20197 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX23_SEL register field. */
20198 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_RESET 0x0
20199 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX23_SEL field value from a register. */
20200 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_GET(value) (((value) & 0x00000001) >> 0)
20201 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX23_SEL register field value suitable for setting the register. */
20202 #define ALT_SYSMGR_PINMUX_GPLMUX23_SEL_SET(value) (((value) << 0) & 0x00000001)
20203
20204 #ifndef __ASSEMBLY__
20205 /*
20206  * WARNING: The C register and register group struct declarations are provided for
20207  * convenience and illustrative purposes. They should, however, be used with
20208  * caution as the C language standard provides no guarantees about the alignment or
20209  * atomicity of device memory accesses. The recommended practice for writing
20210  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20211  * alt_write_word() functions.
20212  *
20213  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX23.
20214  */
20216 {
20217  uint32_t sel : 1; /* GPIO/Loan IO23Input Mux Selection Field */
20218  uint32_t : 31; /* *UNDEFINED* */
20219 };
20220
20221 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX23. */
20222 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX23_s ALT_SYSMGR_PINMUX_GPLMUX23_t;
20223 #endif /* __ASSEMBLY__ */
20224
20225 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX23 register from the beginning of the component. */
20226 #define ALT_SYSMGR_PINMUX_GPLMUX23_OFST 0x230
20227
20228 /*
20229  * Register : GPIO/LoanIO 24 Output/Output Enable Mux Selection Register - GPLMUX24
20230  *
20231  * Selection between GPIO and LoanIO output and output enable for GPIO24 and
20232  * LoanIO24. These signals drive the Pin Mux. The Pin Mux must be configured to use
20233  * GPIO/LoanIO in addition to these settings
20234  *
20235  * Only reset by a cold reset (ignores warm reset).
20236  *
20237  * NOTE: These registers should not be modified after IO configuration.There is no
20238  * support for dynamically changing the Pin Mux selections.
20239  *
20240  * Register Layout
20241  *
20242  * Bits | Access | Reset | Description
20243  * :-------|:-------|:------|:----------------------------------------
20244  * [0] | RW | 0x0 | GPIO/Loan IO24Input Mux Selection Field
20245  * [31:1] | ??? | 0x0 | *UNDEFINED*
20246  *
20247  */
20248 /*
20249  * Field : GPIO/Loan IO24Input Mux Selection Field - sel
20250  *
20251  * Select source for GPIO/LoanIO 24.
20252  *
20253  * 0 : LoanIO 24 controls GPIO/LOANIO[24] output and output enable signals.
20254  *
20255  * 1 : GPIO 24 controls GPIO/LOANI[24] output and output enable signals.
20256  *
20257  * Field Access Macros:
20258  *
20259  */
20260 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX24_SEL register field. */
20261 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_LSB 0
20262 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX24_SEL register field. */
20263 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_MSB 0
20264 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX24_SEL register field. */
20265 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_WIDTH 1
20266 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX24_SEL register field value. */
20267 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_SET_MSK 0x00000001
20268 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX24_SEL register field value. */
20269 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_CLR_MSK 0xfffffffe
20270 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX24_SEL register field. */
20271 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_RESET 0x0
20272 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX24_SEL field value from a register. */
20273 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_GET(value) (((value) & 0x00000001) >> 0)
20274 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX24_SEL register field value suitable for setting the register. */
20275 #define ALT_SYSMGR_PINMUX_GPLMUX24_SEL_SET(value) (((value) << 0) & 0x00000001)
20276
20277 #ifndef __ASSEMBLY__
20278 /*
20279  * WARNING: The C register and register group struct declarations are provided for
20280  * convenience and illustrative purposes. They should, however, be used with
20281  * caution as the C language standard provides no guarantees about the alignment or
20282  * atomicity of device memory accesses. The recommended practice for writing
20283  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20284  * alt_write_word() functions.
20285  *
20286  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX24.
20287  */
20289 {
20290  uint32_t sel : 1; /* GPIO/Loan IO24Input Mux Selection Field */
20291  uint32_t : 31; /* *UNDEFINED* */
20292 };
20293
20294 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX24. */
20295 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX24_s ALT_SYSMGR_PINMUX_GPLMUX24_t;
20296 #endif /* __ASSEMBLY__ */
20297
20298 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX24 register from the beginning of the component. */
20299 #define ALT_SYSMGR_PINMUX_GPLMUX24_OFST 0x234
20300
20301 /*
20302  * Register : GPIO/LoanIO 25 Output/Output Enable Mux Selection Register - GPLMUX25
20303  *
20304  * Selection between GPIO and LoanIO output and output enable for GPIO25 and
20305  * LoanIO25. These signals drive the Pin Mux. The Pin Mux must be configured to use
20306  * GPIO/LoanIO in addition to these settings
20307  *
20308  * Only reset by a cold reset (ignores warm reset).
20309  *
20310  * NOTE: These registers should not be modified after IO configuration.There is no
20311  * support for dynamically changing the Pin Mux selections.
20312  *
20313  * Register Layout
20314  *
20315  * Bits | Access | Reset | Description
20316  * :-------|:-------|:------|:----------------------------------------
20317  * [0] | RW | 0x0 | GPIO/Loan IO25Input Mux Selection Field
20318  * [31:1] | ??? | 0x0 | *UNDEFINED*
20319  *
20320  */
20321 /*
20322  * Field : GPIO/Loan IO25Input Mux Selection Field - sel
20323  *
20324  * Select source for GPIO/LoanIO 25.
20325  *
20326  * 0 : LoanIO 25 controls GPIO/LOANIO[25] output and output enable signals.
20327  *
20328  * 1 : GPIO 25 controls GPIO/LOANI[25] output and output enable signals.
20329  *
20330  * Field Access Macros:
20331  *
20332  */
20333 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX25_SEL register field. */
20334 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_LSB 0
20335 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX25_SEL register field. */
20336 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_MSB 0
20337 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX25_SEL register field. */
20338 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_WIDTH 1
20339 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX25_SEL register field value. */
20340 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_SET_MSK 0x00000001
20341 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX25_SEL register field value. */
20342 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_CLR_MSK 0xfffffffe
20343 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX25_SEL register field. */
20344 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_RESET 0x0
20345 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX25_SEL field value from a register. */
20346 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_GET(value) (((value) & 0x00000001) >> 0)
20347 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX25_SEL register field value suitable for setting the register. */
20348 #define ALT_SYSMGR_PINMUX_GPLMUX25_SEL_SET(value) (((value) << 0) & 0x00000001)
20349
20350 #ifndef __ASSEMBLY__
20351 /*
20352  * WARNING: The C register and register group struct declarations are provided for
20353  * convenience and illustrative purposes. They should, however, be used with
20354  * caution as the C language standard provides no guarantees about the alignment or
20355  * atomicity of device memory accesses. The recommended practice for writing
20356  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20357  * alt_write_word() functions.
20358  *
20359  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX25.
20360  */
20362 {
20363  uint32_t sel : 1; /* GPIO/Loan IO25Input Mux Selection Field */
20364  uint32_t : 31; /* *UNDEFINED* */
20365 };
20366
20367 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX25. */
20368 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX25_s ALT_SYSMGR_PINMUX_GPLMUX25_t;
20369 #endif /* __ASSEMBLY__ */
20370
20371 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX25 register from the beginning of the component. */
20372 #define ALT_SYSMGR_PINMUX_GPLMUX25_OFST 0x238
20373
20374 /*
20375  * Register : GPIO/LoanIO 26 Output/Output Enable Mux Selection Register - GPLMUX26
20376  *
20377  * Selection between GPIO and LoanIO output and output enable for GPIO26 and
20378  * LoanIO26. These signals drive the Pin Mux. The Pin Mux must be configured to use
20379  * GPIO/LoanIO in addition to these settings
20380  *
20381  * Only reset by a cold reset (ignores warm reset).
20382  *
20383  * NOTE: These registers should not be modified after IO configuration.There is no
20384  * support for dynamically changing the Pin Mux selections.
20385  *
20386  * Register Layout
20387  *
20388  * Bits | Access | Reset | Description
20389  * :-------|:-------|:------|:----------------------------------------
20390  * [0] | RW | 0x0 | GPIO/Loan IO26Input Mux Selection Field
20391  * [31:1] | ??? | 0x0 | *UNDEFINED*
20392  *
20393  */
20394 /*
20395  * Field : GPIO/Loan IO26Input Mux Selection Field - sel
20396  *
20397  * Select source for GPIO/LoanIO 26.
20398  *
20399  * 0 : LoanIO 26 controls GPIO/LOANIO[26] output and output enable signals.
20400  *
20401  * 1 : GPIO 26 controls GPIO/LOANI[26] output and output enable signals.
20402  *
20403  * Field Access Macros:
20404  *
20405  */
20406 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX26_SEL register field. */
20407 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_LSB 0
20408 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX26_SEL register field. */
20409 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_MSB 0
20410 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX26_SEL register field. */
20411 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_WIDTH 1
20412 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX26_SEL register field value. */
20413 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_SET_MSK 0x00000001
20414 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX26_SEL register field value. */
20415 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_CLR_MSK 0xfffffffe
20416 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX26_SEL register field. */
20417 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_RESET 0x0
20418 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX26_SEL field value from a register. */
20419 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_GET(value) (((value) & 0x00000001) >> 0)
20420 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX26_SEL register field value suitable for setting the register. */
20421 #define ALT_SYSMGR_PINMUX_GPLMUX26_SEL_SET(value) (((value) << 0) & 0x00000001)
20422
20423 #ifndef __ASSEMBLY__
20424 /*
20425  * WARNING: The C register and register group struct declarations are provided for
20426  * convenience and illustrative purposes. They should, however, be used with
20427  * caution as the C language standard provides no guarantees about the alignment or
20428  * atomicity of device memory accesses. The recommended practice for writing
20429  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20430  * alt_write_word() functions.
20431  *
20432  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX26.
20433  */
20435 {
20436  uint32_t sel : 1; /* GPIO/Loan IO26Input Mux Selection Field */
20437  uint32_t : 31; /* *UNDEFINED* */
20438 };
20439
20440 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX26. */
20441 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX26_s ALT_SYSMGR_PINMUX_GPLMUX26_t;
20442 #endif /* __ASSEMBLY__ */
20443
20444 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX26 register from the beginning of the component. */
20445 #define ALT_SYSMGR_PINMUX_GPLMUX26_OFST 0x23c
20446
20447 /*
20448  * Register : GPIO/LoanIO 27 Output/Output Enable Mux Selection Register - GPLMUX27
20449  *
20450  * Selection between GPIO and LoanIO output and output enable for GPIO27 and
20451  * LoanIO27. These signals drive the Pin Mux. The Pin Mux must be configured to use
20452  * GPIO/LoanIO in addition to these settings
20453  *
20454  * Only reset by a cold reset (ignores warm reset).
20455  *
20456  * NOTE: These registers should not be modified after IO configuration.There is no
20457  * support for dynamically changing the Pin Mux selections.
20458  *
20459  * Register Layout
20460  *
20461  * Bits | Access | Reset | Description
20462  * :-------|:-------|:------|:----------------------------------------
20463  * [0] | RW | 0x0 | GPIO/Loan IO27Input Mux Selection Field
20464  * [31:1] | ??? | 0x0 | *UNDEFINED*
20465  *
20466  */
20467 /*
20468  * Field : GPIO/Loan IO27Input Mux Selection Field - sel
20469  *
20470  * Select source for GPIO/LoanIO 27.
20471  *
20472  * 0 : LoanIO 27 controls GPIO/LOANIO[27] output and output enable signals.
20473  *
20474  * 1 : GPIO 27 controls GPIO/LOANI[27] output and output enable signals.
20475  *
20476  * Field Access Macros:
20477  *
20478  */
20479 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX27_SEL register field. */
20480 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_LSB 0
20481 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX27_SEL register field. */
20482 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_MSB 0
20483 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX27_SEL register field. */
20484 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_WIDTH 1
20485 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX27_SEL register field value. */
20486 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_SET_MSK 0x00000001
20487 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX27_SEL register field value. */
20488 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_CLR_MSK 0xfffffffe
20489 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX27_SEL register field. */
20490 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_RESET 0x0
20491 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX27_SEL field value from a register. */
20492 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_GET(value) (((value) & 0x00000001) >> 0)
20493 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX27_SEL register field value suitable for setting the register. */
20494 #define ALT_SYSMGR_PINMUX_GPLMUX27_SEL_SET(value) (((value) << 0) & 0x00000001)
20495
20496 #ifndef __ASSEMBLY__
20497 /*
20498  * WARNING: The C register and register group struct declarations are provided for
20499  * convenience and illustrative purposes. They should, however, be used with
20500  * caution as the C language standard provides no guarantees about the alignment or
20501  * atomicity of device memory accesses. The recommended practice for writing
20502  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20503  * alt_write_word() functions.
20504  *
20505  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX27.
20506  */
20508 {
20509  uint32_t sel : 1; /* GPIO/Loan IO27Input Mux Selection Field */
20510  uint32_t : 31; /* *UNDEFINED* */
20511 };
20512
20513 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX27. */
20514 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX27_s ALT_SYSMGR_PINMUX_GPLMUX27_t;
20515 #endif /* __ASSEMBLY__ */
20516
20517 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX27 register from the beginning of the component. */
20518 #define ALT_SYSMGR_PINMUX_GPLMUX27_OFST 0x240
20519
20520 /*
20521  * Register : GPIO/LoanIO 28 Output/Output Enable Mux Selection Register - GPLMUX28
20522  *
20523  * Selection between GPIO and LoanIO output and output enable for GPIO28 and
20524  * LoanIO28. These signals drive the Pin Mux. The Pin Mux must be configured to use
20525  * GPIO/LoanIO in addition to these settings
20526  *
20527  * Only reset by a cold reset (ignores warm reset).
20528  *
20529  * NOTE: These registers should not be modified after IO configuration.There is no
20530  * support for dynamically changing the Pin Mux selections.
20531  *
20532  * Register Layout
20533  *
20534  * Bits | Access | Reset | Description
20535  * :-------|:-------|:------|:----------------------------------------
20536  * [0] | RW | 0x0 | GPIO/Loan IO28Input Mux Selection Field
20537  * [31:1] | ??? | 0x0 | *UNDEFINED*
20538  *
20539  */
20540 /*
20541  * Field : GPIO/Loan IO28Input Mux Selection Field - sel
20542  *
20543  * Select source for GPIO/LoanIO 28.
20544  *
20545  * 0 : LoanIO 28 controls GPIO/LOANIO[28] output and output enable signals.
20546  *
20547  * 1 : GPIO 28 controls GPIO/LOANI[28] output and output enable signals.
20548  *
20549  * Field Access Macros:
20550  *
20551  */
20552 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX28_SEL register field. */
20553 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_LSB 0
20554 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX28_SEL register field. */
20555 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_MSB 0
20556 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX28_SEL register field. */
20557 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_WIDTH 1
20558 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX28_SEL register field value. */
20559 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_SET_MSK 0x00000001
20560 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX28_SEL register field value. */
20561 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_CLR_MSK 0xfffffffe
20562 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX28_SEL register field. */
20563 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_RESET 0x0
20564 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX28_SEL field value from a register. */
20565 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_GET(value) (((value) & 0x00000001) >> 0)
20566 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX28_SEL register field value suitable for setting the register. */
20567 #define ALT_SYSMGR_PINMUX_GPLMUX28_SEL_SET(value) (((value) << 0) & 0x00000001)
20568
20569 #ifndef __ASSEMBLY__
20570 /*
20571  * WARNING: The C register and register group struct declarations are provided for
20572  * convenience and illustrative purposes. They should, however, be used with
20573  * caution as the C language standard provides no guarantees about the alignment or
20574  * atomicity of device memory accesses. The recommended practice for writing
20575  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20576  * alt_write_word() functions.
20577  *
20578  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX28.
20579  */
20581 {
20582  uint32_t sel : 1; /* GPIO/Loan IO28Input Mux Selection Field */
20583  uint32_t : 31; /* *UNDEFINED* */
20584 };
20585
20586 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX28. */
20587 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX28_s ALT_SYSMGR_PINMUX_GPLMUX28_t;
20588 #endif /* __ASSEMBLY__ */
20589
20590 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX28 register from the beginning of the component. */
20591 #define ALT_SYSMGR_PINMUX_GPLMUX28_OFST 0x244
20592
20593 /*
20594  * Register : GPIO/LoanIO 29 Output/Output Enable Mux Selection Register - GPLMUX29
20595  *
20596  * Selection between GPIO and LoanIO output and output enable for GPIO29 and
20597  * LoanIO29. These signals drive the Pin Mux. The Pin Mux must be configured to use
20598  * GPIO/LoanIO in addition to these settings
20599  *
20600  * Only reset by a cold reset (ignores warm reset).
20601  *
20602  * NOTE: These registers should not be modified after IO configuration.There is no
20603  * support for dynamically changing the Pin Mux selections.
20604  *
20605  * Register Layout
20606  *
20607  * Bits | Access | Reset | Description
20608  * :-------|:-------|:------|:----------------------------------------
20609  * [0] | RW | 0x0 | GPIO/Loan IO29Input Mux Selection Field
20610  * [31:1] | ??? | 0x0 | *UNDEFINED*
20611  *
20612  */
20613 /*
20614  * Field : GPIO/Loan IO29Input Mux Selection Field - sel
20615  *
20616  * Select source for GPIO/LoanIO 29.
20617  *
20618  * 0 : LoanIO 29 controls GPIO/LOANIO[29] output and output enable signals.
20619  *
20620  * 1 : GPIO 29 controls GPIO/LOANI[29] output and output enable signals.
20621  *
20622  * Field Access Macros:
20623  *
20624  */
20625 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX29_SEL register field. */
20626 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_LSB 0
20627 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX29_SEL register field. */
20628 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_MSB 0
20629 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX29_SEL register field. */
20630 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_WIDTH 1
20631 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX29_SEL register field value. */
20632 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_SET_MSK 0x00000001
20633 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX29_SEL register field value. */
20634 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_CLR_MSK 0xfffffffe
20635 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX29_SEL register field. */
20636 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_RESET 0x0
20637 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX29_SEL field value from a register. */
20638 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_GET(value) (((value) & 0x00000001) >> 0)
20639 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX29_SEL register field value suitable for setting the register. */
20640 #define ALT_SYSMGR_PINMUX_GPLMUX29_SEL_SET(value) (((value) << 0) & 0x00000001)
20641
20642 #ifndef __ASSEMBLY__
20643 /*
20644  * WARNING: The C register and register group struct declarations are provided for
20645  * convenience and illustrative purposes. They should, however, be used with
20646  * caution as the C language standard provides no guarantees about the alignment or
20647  * atomicity of device memory accesses. The recommended practice for writing
20648  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20649  * alt_write_word() functions.
20650  *
20651  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX29.
20652  */
20654 {
20655  uint32_t sel : 1; /* GPIO/Loan IO29Input Mux Selection Field */
20656  uint32_t : 31; /* *UNDEFINED* */
20657 };
20658
20659 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX29. */
20660 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX29_s ALT_SYSMGR_PINMUX_GPLMUX29_t;
20661 #endif /* __ASSEMBLY__ */
20662
20663 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX29 register from the beginning of the component. */
20664 #define ALT_SYSMGR_PINMUX_GPLMUX29_OFST 0x248
20665
20666 /*
20667  * Register : GPIO/LoanIO 30 Output/Output Enable Mux Selection Register - GPLMUX30
20668  *
20669  * Selection between GPIO and LoanIO output and output enable for GPIO30 and
20670  * LoanIO30. These signals drive the Pin Mux. The Pin Mux must be configured to use
20671  * GPIO/LoanIO in addition to these settings
20672  *
20673  * Only reset by a cold reset (ignores warm reset).
20674  *
20675  * NOTE: These registers should not be modified after IO configuration.There is no
20676  * support for dynamically changing the Pin Mux selections.
20677  *
20678  * Register Layout
20679  *
20680  * Bits | Access | Reset | Description
20681  * :-------|:-------|:------|:----------------------------------------
20682  * [0] | RW | 0x0 | GPIO/Loan IO30Input Mux Selection Field
20683  * [31:1] | ??? | 0x0 | *UNDEFINED*
20684  *
20685  */
20686 /*
20687  * Field : GPIO/Loan IO30Input Mux Selection Field - sel
20688  *
20689  * Select source for GPIO/LoanIO 30.
20690  *
20691  * 0 : LoanIO 30 controls GPIO/LOANIO[30] output and output enable signals.
20692  *
20693  * 1 : GPIO 30 controls GPIO/LOANI[30] output and output enable signals.
20694  *
20695  * Field Access Macros:
20696  *
20697  */
20698 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX30_SEL register field. */
20699 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_LSB 0
20700 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX30_SEL register field. */
20701 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_MSB 0
20702 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX30_SEL register field. */
20703 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_WIDTH 1
20704 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX30_SEL register field value. */
20705 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_SET_MSK 0x00000001
20706 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX30_SEL register field value. */
20707 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_CLR_MSK 0xfffffffe
20708 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX30_SEL register field. */
20709 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_RESET 0x0
20710 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX30_SEL field value from a register. */
20711 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_GET(value) (((value) & 0x00000001) >> 0)
20712 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX30_SEL register field value suitable for setting the register. */
20713 #define ALT_SYSMGR_PINMUX_GPLMUX30_SEL_SET(value) (((value) << 0) & 0x00000001)
20714
20715 #ifndef __ASSEMBLY__
20716 /*
20717  * WARNING: The C register and register group struct declarations are provided for
20718  * convenience and illustrative purposes. They should, however, be used with
20719  * caution as the C language standard provides no guarantees about the alignment or
20720  * atomicity of device memory accesses. The recommended practice for writing
20721  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20722  * alt_write_word() functions.
20723  *
20724  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX30.
20725  */
20727 {
20728  uint32_t sel : 1; /* GPIO/Loan IO30Input Mux Selection Field */
20729  uint32_t : 31; /* *UNDEFINED* */
20730 };
20731
20732 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX30. */
20733 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX30_s ALT_SYSMGR_PINMUX_GPLMUX30_t;
20734 #endif /* __ASSEMBLY__ */
20735
20736 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX30 register from the beginning of the component. */
20737 #define ALT_SYSMGR_PINMUX_GPLMUX30_OFST 0x24c
20738
20739 /*
20740  * Register : GPIO/LoanIO 31 Output/Output Enable Mux Selection Register - GPLMUX31
20741  *
20742  * Selection between GPIO and LoanIO output and output enable for GPIO31 and
20743  * LoanIO31. These signals drive the Pin Mux. The Pin Mux must be configured to use
20744  * GPIO/LoanIO in addition to these settings
20745  *
20746  * Only reset by a cold reset (ignores warm reset).
20747  *
20748  * NOTE: These registers should not be modified after IO configuration.There is no
20749  * support for dynamically changing the Pin Mux selections.
20750  *
20751  * Register Layout
20752  *
20753  * Bits | Access | Reset | Description
20754  * :-------|:-------|:------|:----------------------------------------
20755  * [0] | RW | 0x0 | GPIO/Loan IO31Input Mux Selection Field
20756  * [31:1] | ??? | 0x0 | *UNDEFINED*
20757  *
20758  */
20759 /*
20760  * Field : GPIO/Loan IO31Input Mux Selection Field - sel
20761  *
20762  * Select source for GPIO/LoanIO 31.
20763  *
20764  * 0 : LoanIO 31 controls GPIO/LOANIO[31] output and output enable signals.
20765  *
20766  * 1 : GPIO 31 controls GPIO/LOANI[31] output and output enable signals.
20767  *
20768  * Field Access Macros:
20769  *
20770  */
20771 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX31_SEL register field. */
20772 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_LSB 0
20773 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX31_SEL register field. */
20774 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_MSB 0
20775 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX31_SEL register field. */
20776 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_WIDTH 1
20777 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX31_SEL register field value. */
20778 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_SET_MSK 0x00000001
20779 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX31_SEL register field value. */
20780 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_CLR_MSK 0xfffffffe
20781 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX31_SEL register field. */
20782 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_RESET 0x0
20783 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX31_SEL field value from a register. */
20784 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_GET(value) (((value) & 0x00000001) >> 0)
20785 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX31_SEL register field value suitable for setting the register. */
20786 #define ALT_SYSMGR_PINMUX_GPLMUX31_SEL_SET(value) (((value) << 0) & 0x00000001)
20787
20788 #ifndef __ASSEMBLY__
20789 /*
20790  * WARNING: The C register and register group struct declarations are provided for
20791  * convenience and illustrative purposes. They should, however, be used with
20792  * caution as the C language standard provides no guarantees about the alignment or
20793  * atomicity of device memory accesses. The recommended practice for writing
20794  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20795  * alt_write_word() functions.
20796  *
20797  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX31.
20798  */
20800 {
20801  uint32_t sel : 1; /* GPIO/Loan IO31Input Mux Selection Field */
20802  uint32_t : 31; /* *UNDEFINED* */
20803 };
20804
20805 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX31. */
20806 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX31_s ALT_SYSMGR_PINMUX_GPLMUX31_t;
20807 #endif /* __ASSEMBLY__ */
20808
20809 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX31 register from the beginning of the component. */
20810 #define ALT_SYSMGR_PINMUX_GPLMUX31_OFST 0x250
20811
20812 /*
20813  * Register : GPIO/LoanIO 32 Output/Output Enable Mux Selection Register - GPLMUX32
20814  *
20815  * Selection between GPIO and LoanIO output and output enable for GPIO32 and
20816  * LoanIO32. These signals drive the Pin Mux. The Pin Mux must be configured to use
20817  * GPIO/LoanIO in addition to these settings
20818  *
20819  * Only reset by a cold reset (ignores warm reset).
20820  *
20821  * NOTE: These registers should not be modified after IO configuration.There is no
20822  * support for dynamically changing the Pin Mux selections.
20823  *
20824  * Register Layout
20825  *
20826  * Bits | Access | Reset | Description
20827  * :-------|:-------|:------|:----------------------------------------
20828  * [0] | RW | 0x0 | GPIO/Loan IO32Input Mux Selection Field
20829  * [31:1] | ??? | 0x0 | *UNDEFINED*
20830  *
20831  */
20832 /*
20833  * Field : GPIO/Loan IO32Input Mux Selection Field - sel
20834  *
20835  * Select source for GPIO/LoanIO 32.
20836  *
20837  * 0 : LoanIO 32 controls GPIO/LOANIO[32] output and output enable signals.
20838  *
20839  * 1 : GPIO 32 controls GPIO/LOANI[32] output and output enable signals.
20840  *
20841  * Field Access Macros:
20842  *
20843  */
20844 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX32_SEL register field. */
20845 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_LSB 0
20846 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX32_SEL register field. */
20847 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_MSB 0
20848 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX32_SEL register field. */
20849 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_WIDTH 1
20850 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX32_SEL register field value. */
20851 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_SET_MSK 0x00000001
20852 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX32_SEL register field value. */
20853 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_CLR_MSK 0xfffffffe
20854 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX32_SEL register field. */
20855 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_RESET 0x0
20856 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX32_SEL field value from a register. */
20857 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_GET(value) (((value) & 0x00000001) >> 0)
20858 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX32_SEL register field value suitable for setting the register. */
20859 #define ALT_SYSMGR_PINMUX_GPLMUX32_SEL_SET(value) (((value) << 0) & 0x00000001)
20860
20861 #ifndef __ASSEMBLY__
20862 /*
20863  * WARNING: The C register and register group struct declarations are provided for
20864  * convenience and illustrative purposes. They should, however, be used with
20865  * caution as the C language standard provides no guarantees about the alignment or
20866  * atomicity of device memory accesses. The recommended practice for writing
20867  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20868  * alt_write_word() functions.
20869  *
20870  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX32.
20871  */
20873 {
20874  uint32_t sel : 1; /* GPIO/Loan IO32Input Mux Selection Field */
20875  uint32_t : 31; /* *UNDEFINED* */
20876 };
20877
20878 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX32. */
20879 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX32_s ALT_SYSMGR_PINMUX_GPLMUX32_t;
20880 #endif /* __ASSEMBLY__ */
20881
20882 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX32 register from the beginning of the component. */
20883 #define ALT_SYSMGR_PINMUX_GPLMUX32_OFST 0x254
20884
20885 /*
20886  * Register : GPIO/LoanIO 33 Output/Output Enable Mux Selection Register - GPLMUX33
20887  *
20888  * Selection between GPIO and LoanIO output and output enable for GPIO33 and
20889  * LoanIO33. These signals drive the Pin Mux. The Pin Mux must be configured to use
20890  * GPIO/LoanIO in addition to these settings
20891  *
20892  * Only reset by a cold reset (ignores warm reset).
20893  *
20894  * NOTE: These registers should not be modified after IO configuration.There is no
20895  * support for dynamically changing the Pin Mux selections.
20896  *
20897  * Register Layout
20898  *
20899  * Bits | Access | Reset | Description
20900  * :-------|:-------|:------|:----------------------------------------
20901  * [0] | RW | 0x0 | GPIO/Loan IO33Input Mux Selection Field
20902  * [31:1] | ??? | 0x0 | *UNDEFINED*
20903  *
20904  */
20905 /*
20906  * Field : GPIO/Loan IO33Input Mux Selection Field - sel
20907  *
20908  * Select source for GPIO/LoanIO 33.
20909  *
20910  * 0 : LoanIO 33 controls GPIO/LOANIO[33] output and output enable signals.
20911  *
20912  * 1 : GPIO 33 controls GPIO/LOANI[33] output and output enable signals.
20913  *
20914  * Field Access Macros:
20915  *
20916  */
20917 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX33_SEL register field. */
20918 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_LSB 0
20919 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX33_SEL register field. */
20920 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_MSB 0
20921 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX33_SEL register field. */
20922 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_WIDTH 1
20923 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX33_SEL register field value. */
20924 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_SET_MSK 0x00000001
20925 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX33_SEL register field value. */
20926 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_CLR_MSK 0xfffffffe
20927 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX33_SEL register field. */
20928 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_RESET 0x0
20929 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX33_SEL field value from a register. */
20930 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_GET(value) (((value) & 0x00000001) >> 0)
20931 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX33_SEL register field value suitable for setting the register. */
20932 #define ALT_SYSMGR_PINMUX_GPLMUX33_SEL_SET(value) (((value) << 0) & 0x00000001)
20933
20934 #ifndef __ASSEMBLY__
20935 /*
20936  * WARNING: The C register and register group struct declarations are provided for
20937  * convenience and illustrative purposes. They should, however, be used with
20938  * caution as the C language standard provides no guarantees about the alignment or
20939  * atomicity of device memory accesses. The recommended practice for writing
20940  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
20941  * alt_write_word() functions.
20942  *
20943  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX33.
20944  */
20946 {
20947  uint32_t sel : 1; /* GPIO/Loan IO33Input Mux Selection Field */
20948  uint32_t : 31; /* *UNDEFINED* */
20949 };
20950
20951 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX33. */
20952 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX33_s ALT_SYSMGR_PINMUX_GPLMUX33_t;
20953 #endif /* __ASSEMBLY__ */
20954
20955 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX33 register from the beginning of the component. */
20956 #define ALT_SYSMGR_PINMUX_GPLMUX33_OFST 0x258
20957
20958 /*
20959  * Register : GPIO/LoanIO 34 Output/Output Enable Mux Selection Register - GPLMUX34
20960  *
20961  * Selection between GPIO and LoanIO output and output enable for GPIO34 and
20962  * LoanIO34. These signals drive the Pin Mux. The Pin Mux must be configured to use
20963  * GPIO/LoanIO in addition to these settings
20964  *
20965  * Only reset by a cold reset (ignores warm reset).
20966  *
20967  * NOTE: These registers should not be modified after IO configuration.There is no
20968  * support for dynamically changing the Pin Mux selections.
20969  *
20970  * Register Layout
20971  *
20972  * Bits | Access | Reset | Description
20973  * :-------|:-------|:------|:----------------------------------------
20974  * [0] | RW | 0x0 | GPIO/Loan IO34Input Mux Selection Field
20975  * [31:1] | ??? | 0x0 | *UNDEFINED*
20976  *
20977  */
20978 /*
20979  * Field : GPIO/Loan IO34Input Mux Selection Field - sel
20980  *
20981  * Select source for GPIO/LoanIO 34.
20982  *
20983  * 0 : LoanIO 34 controls GPIO/LOANIO[34] output and output enable signals.
20984  *
20985  * 1 : GPIO 34 controls GPIO/LOANI[34] output and output enable signals.
20986  *
20987  * Field Access Macros:
20988  *
20989  */
20990 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX34_SEL register field. */
20991 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_LSB 0
20992 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX34_SEL register field. */
20993 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_MSB 0
20994 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX34_SEL register field. */
20995 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_WIDTH 1
20996 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX34_SEL register field value. */
20997 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_SET_MSK 0x00000001
20998 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX34_SEL register field value. */
20999 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_CLR_MSK 0xfffffffe
21000 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX34_SEL register field. */
21001 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_RESET 0x0
21002 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX34_SEL field value from a register. */
21003 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_GET(value) (((value) & 0x00000001) >> 0)
21004 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX34_SEL register field value suitable for setting the register. */
21005 #define ALT_SYSMGR_PINMUX_GPLMUX34_SEL_SET(value) (((value) << 0) & 0x00000001)
21006
21007 #ifndef __ASSEMBLY__
21008 /*
21009  * WARNING: The C register and register group struct declarations are provided for
21010  * convenience and illustrative purposes. They should, however, be used with
21011  * caution as the C language standard provides no guarantees about the alignment or
21012  * atomicity of device memory accesses. The recommended practice for writing
21013  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21014  * alt_write_word() functions.
21015  *
21016  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX34.
21017  */
21019 {
21020  uint32_t sel : 1; /* GPIO/Loan IO34Input Mux Selection Field */
21021  uint32_t : 31; /* *UNDEFINED* */
21022 };
21023
21024 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX34. */
21025 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX34_s ALT_SYSMGR_PINMUX_GPLMUX34_t;
21026 #endif /* __ASSEMBLY__ */
21027
21028 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX34 register from the beginning of the component. */
21029 #define ALT_SYSMGR_PINMUX_GPLMUX34_OFST 0x25c
21030
21031 /*
21032  * Register : GPIO/LoanIO 35 Output/Output Enable Mux Selection Register - GPLMUX35
21033  *
21034  * Selection between GPIO and LoanIO output and output enable for GPIO35 and
21035  * LoanIO35. These signals drive the Pin Mux. The Pin Mux must be configured to use
21036  * GPIO/LoanIO in addition to these settings
21037  *
21038  * Only reset by a cold reset (ignores warm reset).
21039  *
21040  * NOTE: These registers should not be modified after IO configuration.There is no
21041  * support for dynamically changing the Pin Mux selections.
21042  *
21043  * Register Layout
21044  *
21045  * Bits | Access | Reset | Description
21046  * :-------|:-------|:------|:----------------------------------------
21047  * [0] | RW | 0x0 | GPIO/Loan IO35Input Mux Selection Field
21048  * [31:1] | ??? | 0x0 | *UNDEFINED*
21049  *
21050  */
21051 /*
21052  * Field : GPIO/Loan IO35Input Mux Selection Field - sel
21053  *
21054  * Select source for GPIO/LoanIO 35.
21055  *
21056  * 0 : LoanIO 35 controls GPIO/LOANIO[35] output and output enable signals.
21057  *
21058  * 1 : GPIO 35 controls GPIO/LOANI[35] output and output enable signals.
21059  *
21060  * Field Access Macros:
21061  *
21062  */
21063 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX35_SEL register field. */
21064 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_LSB 0
21065 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX35_SEL register field. */
21066 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_MSB 0
21067 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX35_SEL register field. */
21068 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_WIDTH 1
21069 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX35_SEL register field value. */
21070 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_SET_MSK 0x00000001
21071 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX35_SEL register field value. */
21072 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_CLR_MSK 0xfffffffe
21073 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX35_SEL register field. */
21074 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_RESET 0x0
21075 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX35_SEL field value from a register. */
21076 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_GET(value) (((value) & 0x00000001) >> 0)
21077 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX35_SEL register field value suitable for setting the register. */
21078 #define ALT_SYSMGR_PINMUX_GPLMUX35_SEL_SET(value) (((value) << 0) & 0x00000001)
21079
21080 #ifndef __ASSEMBLY__
21081 /*
21082  * WARNING: The C register and register group struct declarations are provided for
21083  * convenience and illustrative purposes. They should, however, be used with
21084  * caution as the C language standard provides no guarantees about the alignment or
21085  * atomicity of device memory accesses. The recommended practice for writing
21086  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21087  * alt_write_word() functions.
21088  *
21089  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX35.
21090  */
21092 {
21093  uint32_t sel : 1; /* GPIO/Loan IO35Input Mux Selection Field */
21094  uint32_t : 31; /* *UNDEFINED* */
21095 };
21096
21097 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX35. */
21098 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX35_s ALT_SYSMGR_PINMUX_GPLMUX35_t;
21099 #endif /* __ASSEMBLY__ */
21100
21101 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX35 register from the beginning of the component. */
21102 #define ALT_SYSMGR_PINMUX_GPLMUX35_OFST 0x260
21103
21104 /*
21105  * Register : GPIO/LoanIO 36 Output/Output Enable Mux Selection Register - GPLMUX36
21106  *
21107  * Selection between GPIO and LoanIO output and output enable for GPIO36 and
21108  * LoanIO36. These signals drive the Pin Mux. The Pin Mux must be configured to use
21109  * GPIO/LoanIO in addition to these settings
21110  *
21111  * Only reset by a cold reset (ignores warm reset).
21112  *
21113  * NOTE: These registers should not be modified after IO configuration.There is no
21114  * support for dynamically changing the Pin Mux selections.
21115  *
21116  * Register Layout
21117  *
21118  * Bits | Access | Reset | Description
21119  * :-------|:-------|:------|:----------------------------------------
21120  * [0] | RW | 0x0 | GPIO/Loan IO36Input Mux Selection Field
21121  * [31:1] | ??? | 0x0 | *UNDEFINED*
21122  *
21123  */
21124 /*
21125  * Field : GPIO/Loan IO36Input Mux Selection Field - sel
21126  *
21127  * Select source for GPIO/LoanIO 36.
21128  *
21129  * 0 : LoanIO 36 controls GPIO/LOANIO[36] output and output enable signals.
21130  *
21131  * 1 : GPIO 36 controls GPIO/LOANI[36] output and output enable signals.
21132  *
21133  * Field Access Macros:
21134  *
21135  */
21136 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX36_SEL register field. */
21137 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_LSB 0
21138 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX36_SEL register field. */
21139 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_MSB 0
21140 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX36_SEL register field. */
21141 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_WIDTH 1
21142 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX36_SEL register field value. */
21143 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_SET_MSK 0x00000001
21144 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX36_SEL register field value. */
21145 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_CLR_MSK 0xfffffffe
21146 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX36_SEL register field. */
21147 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_RESET 0x0
21148 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX36_SEL field value from a register. */
21149 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_GET(value) (((value) & 0x00000001) >> 0)
21150 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX36_SEL register field value suitable for setting the register. */
21151 #define ALT_SYSMGR_PINMUX_GPLMUX36_SEL_SET(value) (((value) << 0) & 0x00000001)
21152
21153 #ifndef __ASSEMBLY__
21154 /*
21155  * WARNING: The C register and register group struct declarations are provided for
21156  * convenience and illustrative purposes. They should, however, be used with
21157  * caution as the C language standard provides no guarantees about the alignment or
21158  * atomicity of device memory accesses. The recommended practice for writing
21159  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21160  * alt_write_word() functions.
21161  *
21162  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX36.
21163  */
21165 {
21166  uint32_t sel : 1; /* GPIO/Loan IO36Input Mux Selection Field */
21167  uint32_t : 31; /* *UNDEFINED* */
21168 };
21169
21170 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX36. */
21171 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX36_s ALT_SYSMGR_PINMUX_GPLMUX36_t;
21172 #endif /* __ASSEMBLY__ */
21173
21174 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX36 register from the beginning of the component. */
21175 #define ALT_SYSMGR_PINMUX_GPLMUX36_OFST 0x264
21176
21177 /*
21178  * Register : GPIO/LoanIO 37 Output/Output Enable Mux Selection Register - GPLMUX37
21179  *
21180  * Selection between GPIO and LoanIO output and output enable for GPIO37 and
21181  * LoanIO37. These signals drive the Pin Mux. The Pin Mux must be configured to use
21182  * GPIO/LoanIO in addition to these settings
21183  *
21184  * Only reset by a cold reset (ignores warm reset).
21185  *
21186  * NOTE: These registers should not be modified after IO configuration.There is no
21187  * support for dynamically changing the Pin Mux selections.
21188  *
21189  * Register Layout
21190  *
21191  * Bits | Access | Reset | Description
21192  * :-------|:-------|:------|:----------------------------------------
21193  * [0] | RW | 0x0 | GPIO/Loan IO37Input Mux Selection Field
21194  * [31:1] | ??? | 0x0 | *UNDEFINED*
21195  *
21196  */
21197 /*
21198  * Field : GPIO/Loan IO37Input Mux Selection Field - sel
21199  *
21200  * Select source for GPIO/LoanIO 37.
21201  *
21202  * 0 : LoanIO 37 controls GPIO/LOANIO[37] output and output enable signals.
21203  *
21204  * 1 : GPIO 37 controls GPIO/LOANI[37] output and output enable signals.
21205  *
21206  * Field Access Macros:
21207  *
21208  */
21209 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX37_SEL register field. */
21210 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_LSB 0
21211 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX37_SEL register field. */
21212 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_MSB 0
21213 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX37_SEL register field. */
21214 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_WIDTH 1
21215 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX37_SEL register field value. */
21216 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_SET_MSK 0x00000001
21217 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX37_SEL register field value. */
21218 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_CLR_MSK 0xfffffffe
21219 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX37_SEL register field. */
21220 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_RESET 0x0
21221 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX37_SEL field value from a register. */
21222 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_GET(value) (((value) & 0x00000001) >> 0)
21223 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX37_SEL register field value suitable for setting the register. */
21224 #define ALT_SYSMGR_PINMUX_GPLMUX37_SEL_SET(value) (((value) << 0) & 0x00000001)
21225
21226 #ifndef __ASSEMBLY__
21227 /*
21228  * WARNING: The C register and register group struct declarations are provided for
21229  * convenience and illustrative purposes. They should, however, be used with
21230  * caution as the C language standard provides no guarantees about the alignment or
21231  * atomicity of device memory accesses. The recommended practice for writing
21232  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21233  * alt_write_word() functions.
21234  *
21235  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX37.
21236  */
21238 {
21239  uint32_t sel : 1; /* GPIO/Loan IO37Input Mux Selection Field */
21240  uint32_t : 31; /* *UNDEFINED* */
21241 };
21242
21243 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX37. */
21244 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX37_s ALT_SYSMGR_PINMUX_GPLMUX37_t;
21245 #endif /* __ASSEMBLY__ */
21246
21247 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX37 register from the beginning of the component. */
21248 #define ALT_SYSMGR_PINMUX_GPLMUX37_OFST 0x268
21249
21250 /*
21251  * Register : GPIO/LoanIO 38 Output/Output Enable Mux Selection Register - GPLMUX38
21252  *
21253  * Selection between GPIO and LoanIO output and output enable for GPIO38 and
21254  * LoanIO38. These signals drive the Pin Mux. The Pin Mux must be configured to use
21255  * GPIO/LoanIO in addition to these settings
21256  *
21257  * Only reset by a cold reset (ignores warm reset).
21258  *
21259  * NOTE: These registers should not be modified after IO configuration.There is no
21260  * support for dynamically changing the Pin Mux selections.
21261  *
21262  * Register Layout
21263  *
21264  * Bits | Access | Reset | Description
21265  * :-------|:-------|:------|:----------------------------------------
21266  * [0] | RW | 0x0 | GPIO/Loan IO38Input Mux Selection Field
21267  * [31:1] | ??? | 0x0 | *UNDEFINED*
21268  *
21269  */
21270 /*
21271  * Field : GPIO/Loan IO38Input Mux Selection Field - sel
21272  *
21273  * Select source for GPIO/LoanIO 38.
21274  *
21275  * 0 : LoanIO 38 controls GPIO/LOANIO[38] output and output enable signals.
21276  *
21277  * 1 : GPIO 38 controls GPIO/LOANI[38] output and output enable signals.
21278  *
21279  * Field Access Macros:
21280  *
21281  */
21282 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX38_SEL register field. */
21283 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_LSB 0
21284 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX38_SEL register field. */
21285 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_MSB 0
21286 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX38_SEL register field. */
21287 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_WIDTH 1
21288 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX38_SEL register field value. */
21289 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_SET_MSK 0x00000001
21290 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX38_SEL register field value. */
21291 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_CLR_MSK 0xfffffffe
21292 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX38_SEL register field. */
21293 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_RESET 0x0
21294 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX38_SEL field value from a register. */
21295 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_GET(value) (((value) & 0x00000001) >> 0)
21296 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX38_SEL register field value suitable for setting the register. */
21297 #define ALT_SYSMGR_PINMUX_GPLMUX38_SEL_SET(value) (((value) << 0) & 0x00000001)
21298
21299 #ifndef __ASSEMBLY__
21300 /*
21301  * WARNING: The C register and register group struct declarations are provided for
21302  * convenience and illustrative purposes. They should, however, be used with
21303  * caution as the C language standard provides no guarantees about the alignment or
21304  * atomicity of device memory accesses. The recommended practice for writing
21305  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21306  * alt_write_word() functions.
21307  *
21308  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX38.
21309  */
21311 {
21312  uint32_t sel : 1; /* GPIO/Loan IO38Input Mux Selection Field */
21313  uint32_t : 31; /* *UNDEFINED* */
21314 };
21315
21316 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX38. */
21317 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX38_s ALT_SYSMGR_PINMUX_GPLMUX38_t;
21318 #endif /* __ASSEMBLY__ */
21319
21320 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX38 register from the beginning of the component. */
21321 #define ALT_SYSMGR_PINMUX_GPLMUX38_OFST 0x26c
21322
21323 /*
21324  * Register : GPIO/LoanIO 39 Output/Output Enable Mux Selection Register - GPLMUX39
21325  *
21326  * Selection between GPIO and LoanIO output and output enable for GPIO39 and
21327  * LoanIO39. These signals drive the Pin Mux. The Pin Mux must be configured to use
21328  * GPIO/LoanIO in addition to these settings
21329  *
21330  * Only reset by a cold reset (ignores warm reset).
21331  *
21332  * NOTE: These registers should not be modified after IO configuration.There is no
21333  * support for dynamically changing the Pin Mux selections.
21334  *
21335  * Register Layout
21336  *
21337  * Bits | Access | Reset | Description
21338  * :-------|:-------|:------|:----------------------------------------
21339  * [0] | RW | 0x0 | GPIO/Loan IO39Input Mux Selection Field
21340  * [31:1] | ??? | 0x0 | *UNDEFINED*
21341  *
21342  */
21343 /*
21344  * Field : GPIO/Loan IO39Input Mux Selection Field - sel
21345  *
21346  * Select source for GPIO/LoanIO 39.
21347  *
21348  * 0 : LoanIO 39 controls GPIO/LOANIO[39] output and output enable signals.
21349  *
21350  * 1 : GPIO 39 controls GPIO/LOANI[39] output and output enable signals.
21351  *
21352  * Field Access Macros:
21353  *
21354  */
21355 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX39_SEL register field. */
21356 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_LSB 0
21357 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX39_SEL register field. */
21358 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_MSB 0
21359 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX39_SEL register field. */
21360 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_WIDTH 1
21361 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX39_SEL register field value. */
21362 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_SET_MSK 0x00000001
21363 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX39_SEL register field value. */
21364 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_CLR_MSK 0xfffffffe
21365 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX39_SEL register field. */
21366 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_RESET 0x0
21367 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX39_SEL field value from a register. */
21368 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_GET(value) (((value) & 0x00000001) >> 0)
21369 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX39_SEL register field value suitable for setting the register. */
21370 #define ALT_SYSMGR_PINMUX_GPLMUX39_SEL_SET(value) (((value) << 0) & 0x00000001)
21371
21372 #ifndef __ASSEMBLY__
21373 /*
21374  * WARNING: The C register and register group struct declarations are provided for
21375  * convenience and illustrative purposes. They should, however, be used with
21376  * caution as the C language standard provides no guarantees about the alignment or
21377  * atomicity of device memory accesses. The recommended practice for writing
21378  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21379  * alt_write_word() functions.
21380  *
21381  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX39.
21382  */
21384 {
21385  uint32_t sel : 1; /* GPIO/Loan IO39Input Mux Selection Field */
21386  uint32_t : 31; /* *UNDEFINED* */
21387 };
21388
21389 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX39. */
21390 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX39_s ALT_SYSMGR_PINMUX_GPLMUX39_t;
21391 #endif /* __ASSEMBLY__ */
21392
21393 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX39 register from the beginning of the component. */
21394 #define ALT_SYSMGR_PINMUX_GPLMUX39_OFST 0x270
21395
21396 /*
21397  * Register : GPIO/LoanIO 40 Output/Output Enable Mux Selection Register - GPLMUX40
21398  *
21399  * Selection between GPIO and LoanIO output and output enable for GPIO40 and
21400  * LoanIO40. These signals drive the Pin Mux. The Pin Mux must be configured to use
21401  * GPIO/LoanIO in addition to these settings
21402  *
21403  * Only reset by a cold reset (ignores warm reset).
21404  *
21405  * NOTE: These registers should not be modified after IO configuration.There is no
21406  * support for dynamically changing the Pin Mux selections.
21407  *
21408  * Register Layout
21409  *
21410  * Bits | Access | Reset | Description
21411  * :-------|:-------|:------|:----------------------------------------
21412  * [0] | RW | 0x0 | GPIO/Loan IO40Input Mux Selection Field
21413  * [31:1] | ??? | 0x0 | *UNDEFINED*
21414  *
21415  */
21416 /*
21417  * Field : GPIO/Loan IO40Input Mux Selection Field - sel
21418  *
21419  * Select source for GPIO/LoanIO 40.
21420  *
21421  * 0 : LoanIO 40 controls GPIO/LOANIO[40] output and output enable signals.
21422  *
21423  * 1 : GPIO 40 controls GPIO/LOANI[40] output and output enable signals.
21424  *
21425  * Field Access Macros:
21426  *
21427  */
21428 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX40_SEL register field. */
21429 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_LSB 0
21430 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX40_SEL register field. */
21431 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_MSB 0
21432 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX40_SEL register field. */
21433 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_WIDTH 1
21434 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX40_SEL register field value. */
21435 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_SET_MSK 0x00000001
21436 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX40_SEL register field value. */
21437 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_CLR_MSK 0xfffffffe
21438 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX40_SEL register field. */
21439 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_RESET 0x0
21440 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX40_SEL field value from a register. */
21441 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_GET(value) (((value) & 0x00000001) >> 0)
21442 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX40_SEL register field value suitable for setting the register. */
21443 #define ALT_SYSMGR_PINMUX_GPLMUX40_SEL_SET(value) (((value) << 0) & 0x00000001)
21444
21445 #ifndef __ASSEMBLY__
21446 /*
21447  * WARNING: The C register and register group struct declarations are provided for
21448  * convenience and illustrative purposes. They should, however, be used with
21449  * caution as the C language standard provides no guarantees about the alignment or
21450  * atomicity of device memory accesses. The recommended practice for writing
21451  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21452  * alt_write_word() functions.
21453  *
21454  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX40.
21455  */
21457 {
21458  uint32_t sel : 1; /* GPIO/Loan IO40Input Mux Selection Field */
21459  uint32_t : 31; /* *UNDEFINED* */
21460 };
21461
21462 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX40. */
21463 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX40_s ALT_SYSMGR_PINMUX_GPLMUX40_t;
21464 #endif /* __ASSEMBLY__ */
21465
21466 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX40 register from the beginning of the component. */
21467 #define ALT_SYSMGR_PINMUX_GPLMUX40_OFST 0x274
21468
21469 /*
21470  * Register : GPIO/LoanIO 41 Output/Output Enable Mux Selection Register - GPLMUX41
21471  *
21472  * Selection between GPIO and LoanIO output and output enable for GPIO41 and
21473  * LoanIO41. These signals drive the Pin Mux. The Pin Mux must be configured to use
21474  * GPIO/LoanIO in addition to these settings
21475  *
21476  * Only reset by a cold reset (ignores warm reset).
21477  *
21478  * NOTE: These registers should not be modified after IO configuration.There is no
21479  * support for dynamically changing the Pin Mux selections.
21480  *
21481  * Register Layout
21482  *
21483  * Bits | Access | Reset | Description
21484  * :-------|:-------|:------|:----------------------------------------
21485  * [0] | RW | 0x0 | GPIO/Loan IO41Input Mux Selection Field
21486  * [31:1] | ??? | 0x0 | *UNDEFINED*
21487  *
21488  */
21489 /*
21490  * Field : GPIO/Loan IO41Input Mux Selection Field - sel
21491  *
21492  * Select source for GPIO/LoanIO 41.
21493  *
21494  * 0 : LoanIO 41 controls GPIO/LOANIO[41] output and output enable signals.
21495  *
21496  * 1 : GPIO 41 controls GPIO/LOANI[41] output and output enable signals.
21497  *
21498  * Field Access Macros:
21499  *
21500  */
21501 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX41_SEL register field. */
21502 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_LSB 0
21503 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX41_SEL register field. */
21504 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_MSB 0
21505 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX41_SEL register field. */
21506 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_WIDTH 1
21507 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX41_SEL register field value. */
21508 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_SET_MSK 0x00000001
21509 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX41_SEL register field value. */
21510 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_CLR_MSK 0xfffffffe
21511 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX41_SEL register field. */
21512 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_RESET 0x0
21513 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX41_SEL field value from a register. */
21514 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_GET(value) (((value) & 0x00000001) >> 0)
21515 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX41_SEL register field value suitable for setting the register. */
21516 #define ALT_SYSMGR_PINMUX_GPLMUX41_SEL_SET(value) (((value) << 0) & 0x00000001)
21517
21518 #ifndef __ASSEMBLY__
21519 /*
21520  * WARNING: The C register and register group struct declarations are provided for
21521  * convenience and illustrative purposes. They should, however, be used with
21522  * caution as the C language standard provides no guarantees about the alignment or
21523  * atomicity of device memory accesses. The recommended practice for writing
21524  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21525  * alt_write_word() functions.
21526  *
21527  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX41.
21528  */
21530 {
21531  uint32_t sel : 1; /* GPIO/Loan IO41Input Mux Selection Field */
21532  uint32_t : 31; /* *UNDEFINED* */
21533 };
21534
21535 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX41. */
21536 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX41_s ALT_SYSMGR_PINMUX_GPLMUX41_t;
21537 #endif /* __ASSEMBLY__ */
21538
21539 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX41 register from the beginning of the component. */
21540 #define ALT_SYSMGR_PINMUX_GPLMUX41_OFST 0x278
21541
21542 /*
21543  * Register : GPIO/LoanIO 42 Output/Output Enable Mux Selection Register - GPLMUX42
21544  *
21545  * Selection between GPIO and LoanIO output and output enable for GPIO42 and
21546  * LoanIO42. These signals drive the Pin Mux. The Pin Mux must be configured to use
21547  * GPIO/LoanIO in addition to these settings
21548  *
21549  * Only reset by a cold reset (ignores warm reset).
21550  *
21551  * NOTE: These registers should not be modified after IO configuration.There is no
21552  * support for dynamically changing the Pin Mux selections.
21553  *
21554  * Register Layout
21555  *
21556  * Bits | Access | Reset | Description
21557  * :-------|:-------|:------|:----------------------------------------
21558  * [0] | RW | 0x0 | GPIO/Loan IO42Input Mux Selection Field
21559  * [31:1] | ??? | 0x0 | *UNDEFINED*
21560  *
21561  */
21562 /*
21563  * Field : GPIO/Loan IO42Input Mux Selection Field - sel
21564  *
21565  * Select source for GPIO/LoanIO 42.
21566  *
21567  * 0 : LoanIO 42 controls GPIO/LOANIO[42] output and output enable signals.
21568  *
21569  * 1 : GPIO 42 controls GPIO/LOANI[42] output and output enable signals.
21570  *
21571  * Field Access Macros:
21572  *
21573  */
21574 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX42_SEL register field. */
21575 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_LSB 0
21576 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX42_SEL register field. */
21577 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_MSB 0
21578 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX42_SEL register field. */
21579 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_WIDTH 1
21580 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX42_SEL register field value. */
21581 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_SET_MSK 0x00000001
21582 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX42_SEL register field value. */
21583 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_CLR_MSK 0xfffffffe
21584 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX42_SEL register field. */
21585 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_RESET 0x0
21586 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX42_SEL field value from a register. */
21587 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_GET(value) (((value) & 0x00000001) >> 0)
21588 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX42_SEL register field value suitable for setting the register. */
21589 #define ALT_SYSMGR_PINMUX_GPLMUX42_SEL_SET(value) (((value) << 0) & 0x00000001)
21590
21591 #ifndef __ASSEMBLY__
21592 /*
21593  * WARNING: The C register and register group struct declarations are provided for
21594  * convenience and illustrative purposes. They should, however, be used with
21595  * caution as the C language standard provides no guarantees about the alignment or
21596  * atomicity of device memory accesses. The recommended practice for writing
21597  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21598  * alt_write_word() functions.
21599  *
21600  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX42.
21601  */
21603 {
21604  uint32_t sel : 1; /* GPIO/Loan IO42Input Mux Selection Field */
21605  uint32_t : 31; /* *UNDEFINED* */
21606 };
21607
21608 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX42. */
21609 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX42_s ALT_SYSMGR_PINMUX_GPLMUX42_t;
21610 #endif /* __ASSEMBLY__ */
21611
21612 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX42 register from the beginning of the component. */
21613 #define ALT_SYSMGR_PINMUX_GPLMUX42_OFST 0x27c
21614
21615 /*
21616  * Register : GPIO/LoanIO 43 Output/Output Enable Mux Selection Register - GPLMUX43
21617  *
21618  * Selection between GPIO and LoanIO output and output enable for GPIO43 and
21619  * LoanIO43. These signals drive the Pin Mux. The Pin Mux must be configured to use
21620  * GPIO/LoanIO in addition to these settings
21621  *
21622  * Only reset by a cold reset (ignores warm reset).
21623  *
21624  * NOTE: These registers should not be modified after IO configuration.There is no
21625  * support for dynamically changing the Pin Mux selections.
21626  *
21627  * Register Layout
21628  *
21629  * Bits | Access | Reset | Description
21630  * :-------|:-------|:------|:----------------------------------------
21631  * [0] | RW | 0x0 | GPIO/Loan IO43Input Mux Selection Field
21632  * [31:1] | ??? | 0x0 | *UNDEFINED*
21633  *
21634  */
21635 /*
21636  * Field : GPIO/Loan IO43Input Mux Selection Field - sel
21637  *
21638  * Select source for GPIO/LoanIO 43.
21639  *
21640  * 0 : LoanIO 43 controls GPIO/LOANIO[43] output and output enable signals.
21641  *
21642  * 1 : GPIO 43 controls GPIO/LOANI[43] output and output enable signals.
21643  *
21644  * Field Access Macros:
21645  *
21646  */
21647 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX43_SEL register field. */
21648 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_LSB 0
21649 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX43_SEL register field. */
21650 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_MSB 0
21651 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX43_SEL register field. */
21652 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_WIDTH 1
21653 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX43_SEL register field value. */
21654 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_SET_MSK 0x00000001
21655 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX43_SEL register field value. */
21656 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_CLR_MSK 0xfffffffe
21657 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX43_SEL register field. */
21658 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_RESET 0x0
21659 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX43_SEL field value from a register. */
21660 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_GET(value) (((value) & 0x00000001) >> 0)
21661 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX43_SEL register field value suitable for setting the register. */
21662 #define ALT_SYSMGR_PINMUX_GPLMUX43_SEL_SET(value) (((value) << 0) & 0x00000001)
21663
21664 #ifndef __ASSEMBLY__
21665 /*
21666  * WARNING: The C register and register group struct declarations are provided for
21667  * convenience and illustrative purposes. They should, however, be used with
21668  * caution as the C language standard provides no guarantees about the alignment or
21669  * atomicity of device memory accesses. The recommended practice for writing
21670  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21671  * alt_write_word() functions.
21672  *
21673  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX43.
21674  */
21676 {
21677  uint32_t sel : 1; /* GPIO/Loan IO43Input Mux Selection Field */
21678  uint32_t : 31; /* *UNDEFINED* */
21679 };
21680
21681 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX43. */
21682 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX43_s ALT_SYSMGR_PINMUX_GPLMUX43_t;
21683 #endif /* __ASSEMBLY__ */
21684
21685 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX43 register from the beginning of the component. */
21686 #define ALT_SYSMGR_PINMUX_GPLMUX43_OFST 0x280
21687
21688 /*
21689  * Register : GPIO/LoanIO 44 Output/Output Enable Mux Selection Register - GPLMUX44
21690  *
21691  * Selection between GPIO and LoanIO output and output enable for GPIO44 and
21692  * LoanIO44. These signals drive the Pin Mux. The Pin Mux must be configured to use
21693  * GPIO/LoanIO in addition to these settings
21694  *
21695  * Only reset by a cold reset (ignores warm reset).
21696  *
21697  * NOTE: These registers should not be modified after IO configuration.There is no
21698  * support for dynamically changing the Pin Mux selections.
21699  *
21700  * Register Layout
21701  *
21702  * Bits | Access | Reset | Description
21703  * :-------|:-------|:------|:----------------------------------------
21704  * [0] | RW | 0x0 | GPIO/Loan IO44Input Mux Selection Field
21705  * [31:1] | ??? | 0x0 | *UNDEFINED*
21706  *
21707  */
21708 /*
21709  * Field : GPIO/Loan IO44Input Mux Selection Field - sel
21710  *
21711  * Select source for GPIO/LoanIO 44.
21712  *
21713  * 0 : LoanIO 44 controls GPIO/LOANIO[44] output and output enable signals.
21714  *
21715  * 1 : GPIO 44 controls GPIO/LOANI[44] output and output enable signals.
21716  *
21717  * Field Access Macros:
21718  *
21719  */
21720 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX44_SEL register field. */
21721 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_LSB 0
21722 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX44_SEL register field. */
21723 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_MSB 0
21724 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX44_SEL register field. */
21725 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_WIDTH 1
21726 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX44_SEL register field value. */
21727 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_SET_MSK 0x00000001
21728 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX44_SEL register field value. */
21729 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_CLR_MSK 0xfffffffe
21730 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX44_SEL register field. */
21731 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_RESET 0x0
21732 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX44_SEL field value from a register. */
21733 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_GET(value) (((value) & 0x00000001) >> 0)
21734 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX44_SEL register field value suitable for setting the register. */
21735 #define ALT_SYSMGR_PINMUX_GPLMUX44_SEL_SET(value) (((value) << 0) & 0x00000001)
21736
21737 #ifndef __ASSEMBLY__
21738 /*
21739  * WARNING: The C register and register group struct declarations are provided for
21740  * convenience and illustrative purposes. They should, however, be used with
21741  * caution as the C language standard provides no guarantees about the alignment or
21742  * atomicity of device memory accesses. The recommended practice for writing
21743  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21744  * alt_write_word() functions.
21745  *
21746  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX44.
21747  */
21749 {
21750  uint32_t sel : 1; /* GPIO/Loan IO44Input Mux Selection Field */
21751  uint32_t : 31; /* *UNDEFINED* */
21752 };
21753
21754 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX44. */
21755 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX44_s ALT_SYSMGR_PINMUX_GPLMUX44_t;
21756 #endif /* __ASSEMBLY__ */
21757
21758 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX44 register from the beginning of the component. */
21759 #define ALT_SYSMGR_PINMUX_GPLMUX44_OFST 0x284
21760
21761 /*
21762  * Register : GPIO/LoanIO 45 Output/Output Enable Mux Selection Register - GPLMUX45
21763  *
21764  * Selection between GPIO and LoanIO output and output enable for GPIO45 and
21765  * LoanIO45. These signals drive the Pin Mux. The Pin Mux must be configured to use
21766  * GPIO/LoanIO in addition to these settings
21767  *
21768  * Only reset by a cold reset (ignores warm reset).
21769  *
21770  * NOTE: These registers should not be modified after IO configuration.There is no
21771  * support for dynamically changing the Pin Mux selections.
21772  *
21773  * Register Layout
21774  *
21775  * Bits | Access | Reset | Description
21776  * :-------|:-------|:------|:----------------------------------------
21777  * [0] | RW | 0x0 | GPIO/Loan IO45Input Mux Selection Field
21778  * [31:1] | ??? | 0x0 | *UNDEFINED*
21779  *
21780  */
21781 /*
21782  * Field : GPIO/Loan IO45Input Mux Selection Field - sel
21783  *
21784  * Select source for GPIO/LoanIO 45.
21785  *
21786  * 0 : LoanIO 45 controls GPIO/LOANIO[45] output and output enable signals.
21787  *
21788  * 1 : GPIO 45 controls GPIO/LOANI[45] output and output enable signals.
21789  *
21790  * Field Access Macros:
21791  *
21792  */
21793 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX45_SEL register field. */
21794 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_LSB 0
21795 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX45_SEL register field. */
21796 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_MSB 0
21797 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX45_SEL register field. */
21798 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_WIDTH 1
21799 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX45_SEL register field value. */
21800 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_SET_MSK 0x00000001
21801 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX45_SEL register field value. */
21802 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_CLR_MSK 0xfffffffe
21803 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX45_SEL register field. */
21804 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_RESET 0x0
21805 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX45_SEL field value from a register. */
21806 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_GET(value) (((value) & 0x00000001) >> 0)
21807 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX45_SEL register field value suitable for setting the register. */
21808 #define ALT_SYSMGR_PINMUX_GPLMUX45_SEL_SET(value) (((value) << 0) & 0x00000001)
21809
21810 #ifndef __ASSEMBLY__
21811 /*
21812  * WARNING: The C register and register group struct declarations are provided for
21813  * convenience and illustrative purposes. They should, however, be used with
21814  * caution as the C language standard provides no guarantees about the alignment or
21815  * atomicity of device memory accesses. The recommended practice for writing
21816  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21817  * alt_write_word() functions.
21818  *
21819  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX45.
21820  */
21822 {
21823  uint32_t sel : 1; /* GPIO/Loan IO45Input Mux Selection Field */
21824  uint32_t : 31; /* *UNDEFINED* */
21825 };
21826
21827 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX45. */
21828 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX45_s ALT_SYSMGR_PINMUX_GPLMUX45_t;
21829 #endif /* __ASSEMBLY__ */
21830
21831 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX45 register from the beginning of the component. */
21832 #define ALT_SYSMGR_PINMUX_GPLMUX45_OFST 0x288
21833
21834 /*
21835  * Register : GPIO/LoanIO 46 Output/Output Enable Mux Selection Register - GPLMUX46
21836  *
21837  * Selection between GPIO and LoanIO output and output enable for GPIO46 and
21838  * LoanIO46. These signals drive the Pin Mux. The Pin Mux must be configured to use
21839  * GPIO/LoanIO in addition to these settings
21840  *
21841  * Only reset by a cold reset (ignores warm reset).
21842  *
21843  * NOTE: These registers should not be modified after IO configuration.There is no
21844  * support for dynamically changing the Pin Mux selections.
21845  *
21846  * Register Layout
21847  *
21848  * Bits | Access | Reset | Description
21849  * :-------|:-------|:------|:----------------------------------------
21850  * [0] | RW | 0x0 | GPIO/Loan IO46Input Mux Selection Field
21851  * [31:1] | ??? | 0x0 | *UNDEFINED*
21852  *
21853  */
21854 /*
21855  * Field : GPIO/Loan IO46Input Mux Selection Field - sel
21856  *
21857  * Select source for GPIO/LoanIO 46.
21858  *
21859  * 0 : LoanIO 46 controls GPIO/LOANIO[46] output and output enable signals.
21860  *
21861  * 1 : GPIO 46 controls GPIO/LOANI[46] output and output enable signals.
21862  *
21863  * Field Access Macros:
21864  *
21865  */
21866 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX46_SEL register field. */
21867 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_LSB 0
21868 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX46_SEL register field. */
21869 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_MSB 0
21870 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX46_SEL register field. */
21871 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_WIDTH 1
21872 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX46_SEL register field value. */
21873 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_SET_MSK 0x00000001
21874 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX46_SEL register field value. */
21875 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_CLR_MSK 0xfffffffe
21876 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX46_SEL register field. */
21877 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_RESET 0x0
21878 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX46_SEL field value from a register. */
21879 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_GET(value) (((value) & 0x00000001) >> 0)
21880 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX46_SEL register field value suitable for setting the register. */
21881 #define ALT_SYSMGR_PINMUX_GPLMUX46_SEL_SET(value) (((value) << 0) & 0x00000001)
21882
21883 #ifndef __ASSEMBLY__
21884 /*
21885  * WARNING: The C register and register group struct declarations are provided for
21886  * convenience and illustrative purposes. They should, however, be used with
21887  * caution as the C language standard provides no guarantees about the alignment or
21888  * atomicity of device memory accesses. The recommended practice for writing
21889  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21890  * alt_write_word() functions.
21891  *
21892  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX46.
21893  */
21895 {
21896  uint32_t sel : 1; /* GPIO/Loan IO46Input Mux Selection Field */
21897  uint32_t : 31; /* *UNDEFINED* */
21898 };
21899
21900 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX46. */
21901 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX46_s ALT_SYSMGR_PINMUX_GPLMUX46_t;
21902 #endif /* __ASSEMBLY__ */
21903
21904 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX46 register from the beginning of the component. */
21905 #define ALT_SYSMGR_PINMUX_GPLMUX46_OFST 0x28c
21906
21907 /*
21908  * Register : GPIO/LoanIO 47 Output/Output Enable Mux Selection Register - GPLMUX47
21909  *
21910  * Selection between GPIO and LoanIO output and output enable for GPIO47 and
21911  * LoanIO47. These signals drive the Pin Mux. The Pin Mux must be configured to use
21912  * GPIO/LoanIO in addition to these settings
21913  *
21914  * Only reset by a cold reset (ignores warm reset).
21915  *
21916  * NOTE: These registers should not be modified after IO configuration.There is no
21917  * support for dynamically changing the Pin Mux selections.
21918  *
21919  * Register Layout
21920  *
21921  * Bits | Access | Reset | Description
21922  * :-------|:-------|:------|:----------------------------------------
21923  * [0] | RW | 0x0 | GPIO/Loan IO47Input Mux Selection Field
21924  * [31:1] | ??? | 0x0 | *UNDEFINED*
21925  *
21926  */
21927 /*
21928  * Field : GPIO/Loan IO47Input Mux Selection Field - sel
21929  *
21930  * Select source for GPIO/LoanIO 47.
21931  *
21932  * 0 : LoanIO 47 controls GPIO/LOANIO[47] output and output enable signals.
21933  *
21934  * 1 : GPIO 47 controls GPIO/LOANI[47] output and output enable signals.
21935  *
21936  * Field Access Macros:
21937  *
21938  */
21939 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX47_SEL register field. */
21940 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_LSB 0
21941 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX47_SEL register field. */
21942 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_MSB 0
21943 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX47_SEL register field. */
21944 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_WIDTH 1
21945 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX47_SEL register field value. */
21946 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_SET_MSK 0x00000001
21947 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX47_SEL register field value. */
21948 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_CLR_MSK 0xfffffffe
21949 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX47_SEL register field. */
21950 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_RESET 0x0
21951 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX47_SEL field value from a register. */
21952 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_GET(value) (((value) & 0x00000001) >> 0)
21953 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX47_SEL register field value suitable for setting the register. */
21954 #define ALT_SYSMGR_PINMUX_GPLMUX47_SEL_SET(value) (((value) << 0) & 0x00000001)
21955
21956 #ifndef __ASSEMBLY__
21957 /*
21958  * WARNING: The C register and register group struct declarations are provided for
21959  * convenience and illustrative purposes. They should, however, be used with
21960  * caution as the C language standard provides no guarantees about the alignment or
21961  * atomicity of device memory accesses. The recommended practice for writing
21962  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
21963  * alt_write_word() functions.
21964  *
21965  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX47.
21966  */
21968 {
21969  uint32_t sel : 1; /* GPIO/Loan IO47Input Mux Selection Field */
21970  uint32_t : 31; /* *UNDEFINED* */
21971 };
21972
21973 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX47. */
21974 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX47_s ALT_SYSMGR_PINMUX_GPLMUX47_t;
21975 #endif /* __ASSEMBLY__ */
21976
21977 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX47 register from the beginning of the component. */
21978 #define ALT_SYSMGR_PINMUX_GPLMUX47_OFST 0x290
21979
21980 /*
21981  * Register : GPIO/LoanIO 48 Output/Output Enable Mux Selection Register - GPLMUX48
21982  *
21983  * Selection between GPIO and LoanIO output and output enable for GPIO48 and
21984  * LoanIO48. These signals drive the Pin Mux. The Pin Mux must be configured to use
21985  * GPIO/LoanIO in addition to these settings
21986  *
21987  * Only reset by a cold reset (ignores warm reset).
21988  *
21989  * NOTE: These registers should not be modified after IO configuration.There is no
21990  * support for dynamically changing the Pin Mux selections.
21991  *
21992  * Register Layout
21993  *
21994  * Bits | Access | Reset | Description
21995  * :-------|:-------|:------|:----------------------------------------
21996  * [0] | RW | 0x0 | GPIO/Loan IO48Input Mux Selection Field
21997  * [31:1] | ??? | 0x0 | *UNDEFINED*
21998  *
21999  */
22000 /*
22001  * Field : GPIO/Loan IO48Input Mux Selection Field - sel
22002  *
22003  * Select source for GPIO/LoanIO 48.
22004  *
22005  * 0 : LoanIO 48 controls GPIO/LOANIO[48] output and output enable signals.
22006  *
22007  * 1 : GPIO 48 controls GPIO/LOANI[48] output and output enable signals.
22008  *
22009  * Field Access Macros:
22010  *
22011  */
22012 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX48_SEL register field. */
22013 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_LSB 0
22014 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX48_SEL register field. */
22015 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_MSB 0
22016 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX48_SEL register field. */
22017 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_WIDTH 1
22018 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX48_SEL register field value. */
22019 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_SET_MSK 0x00000001
22020 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX48_SEL register field value. */
22021 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_CLR_MSK 0xfffffffe
22022 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX48_SEL register field. */
22023 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_RESET 0x0
22024 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX48_SEL field value from a register. */
22025 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_GET(value) (((value) & 0x00000001) >> 0)
22026 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX48_SEL register field value suitable for setting the register. */
22027 #define ALT_SYSMGR_PINMUX_GPLMUX48_SEL_SET(value) (((value) << 0) & 0x00000001)
22028
22029 #ifndef __ASSEMBLY__
22030 /*
22031  * WARNING: The C register and register group struct declarations are provided for
22032  * convenience and illustrative purposes. They should, however, be used with
22033  * caution as the C language standard provides no guarantees about the alignment or
22034  * atomicity of device memory accesses. The recommended practice for writing
22035  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22036  * alt_write_word() functions.
22037  *
22038  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX48.
22039  */
22041 {
22042  uint32_t sel : 1; /* GPIO/Loan IO48Input Mux Selection Field */
22043  uint32_t : 31; /* *UNDEFINED* */
22044 };
22045
22046 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX48. */
22047 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX48_s ALT_SYSMGR_PINMUX_GPLMUX48_t;
22048 #endif /* __ASSEMBLY__ */
22049
22050 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX48 register from the beginning of the component. */
22051 #define ALT_SYSMGR_PINMUX_GPLMUX48_OFST 0x294
22052
22053 /*
22054  * Register : GPIO/LoanIO 49 Output/Output Enable Mux Selection Register - GPLMUX49
22055  *
22056  * Selection between GPIO and LoanIO output and output enable for GPIO49 and
22057  * LoanIO49. These signals drive the Pin Mux. The Pin Mux must be configured to use
22058  * GPIO/LoanIO in addition to these settings
22059  *
22060  * Only reset by a cold reset (ignores warm reset).
22061  *
22062  * NOTE: These registers should not be modified after IO configuration.There is no
22063  * support for dynamically changing the Pin Mux selections.
22064  *
22065  * Register Layout
22066  *
22067  * Bits | Access | Reset | Description
22068  * :-------|:-------|:------|:----------------------------------------
22069  * [0] | RW | 0x0 | GPIO/Loan IO49Input Mux Selection Field
22070  * [31:1] | ??? | 0x0 | *UNDEFINED*
22071  *
22072  */
22073 /*
22074  * Field : GPIO/Loan IO49Input Mux Selection Field - sel
22075  *
22076  * Select source for GPIO/LoanIO 49.
22077  *
22078  * 0 : LoanIO 49 controls GPIO/LOANIO[49] output and output enable signals.
22079  *
22080  * 1 : GPIO 49 controls GPIO/LOANI[49] output and output enable signals.
22081  *
22082  * Field Access Macros:
22083  *
22084  */
22085 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX49_SEL register field. */
22086 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_LSB 0
22087 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX49_SEL register field. */
22088 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_MSB 0
22089 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX49_SEL register field. */
22090 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_WIDTH 1
22091 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX49_SEL register field value. */
22092 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_SET_MSK 0x00000001
22093 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX49_SEL register field value. */
22094 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_CLR_MSK 0xfffffffe
22095 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX49_SEL register field. */
22096 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_RESET 0x0
22097 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX49_SEL field value from a register. */
22098 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_GET(value) (((value) & 0x00000001) >> 0)
22099 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX49_SEL register field value suitable for setting the register. */
22100 #define ALT_SYSMGR_PINMUX_GPLMUX49_SEL_SET(value) (((value) << 0) & 0x00000001)
22101
22102 #ifndef __ASSEMBLY__
22103 /*
22104  * WARNING: The C register and register group struct declarations are provided for
22105  * convenience and illustrative purposes. They should, however, be used with
22106  * caution as the C language standard provides no guarantees about the alignment or
22107  * atomicity of device memory accesses. The recommended practice for writing
22108  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22109  * alt_write_word() functions.
22110  *
22111  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX49.
22112  */
22114 {
22115  uint32_t sel : 1; /* GPIO/Loan IO49Input Mux Selection Field */
22116  uint32_t : 31; /* *UNDEFINED* */
22117 };
22118
22119 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX49. */
22120 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX49_s ALT_SYSMGR_PINMUX_GPLMUX49_t;
22121 #endif /* __ASSEMBLY__ */
22122
22123 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX49 register from the beginning of the component. */
22124 #define ALT_SYSMGR_PINMUX_GPLMUX49_OFST 0x298
22125
22126 /*
22127  * Register : GPIO/LoanIO 50 Output/Output Enable Mux Selection Register - GPLMUX50
22128  *
22129  * Selection between GPIO and LoanIO output and output enable for GPIO50 and
22130  * LoanIO50. These signals drive the Pin Mux. The Pin Mux must be configured to use
22131  * GPIO/LoanIO in addition to these settings
22132  *
22133  * Only reset by a cold reset (ignores warm reset).
22134  *
22135  * NOTE: These registers should not be modified after IO configuration.There is no
22136  * support for dynamically changing the Pin Mux selections.
22137  *
22138  * Register Layout
22139  *
22140  * Bits | Access | Reset | Description
22141  * :-------|:-------|:------|:----------------------------------------
22142  * [0] | RW | 0x0 | GPIO/Loan IO50Input Mux Selection Field
22143  * [31:1] | ??? | 0x0 | *UNDEFINED*
22144  *
22145  */
22146 /*
22147  * Field : GPIO/Loan IO50Input Mux Selection Field - sel
22148  *
22149  * Select source for GPIO/LoanIO 50.
22150  *
22151  * 0 : LoanIO 50 controls GPIO/LOANIO[50] output and output enable signals.
22152  *
22153  * 1 : GPIO 50 controls GPIO/LOANI[50] output and output enable signals.
22154  *
22155  * Field Access Macros:
22156  *
22157  */
22158 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX50_SEL register field. */
22159 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_LSB 0
22160 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX50_SEL register field. */
22161 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_MSB 0
22162 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX50_SEL register field. */
22163 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_WIDTH 1
22164 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX50_SEL register field value. */
22165 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_SET_MSK 0x00000001
22166 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX50_SEL register field value. */
22167 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_CLR_MSK 0xfffffffe
22168 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX50_SEL register field. */
22169 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_RESET 0x0
22170 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX50_SEL field value from a register. */
22171 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_GET(value) (((value) & 0x00000001) >> 0)
22172 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX50_SEL register field value suitable for setting the register. */
22173 #define ALT_SYSMGR_PINMUX_GPLMUX50_SEL_SET(value) (((value) << 0) & 0x00000001)
22174
22175 #ifndef __ASSEMBLY__
22176 /*
22177  * WARNING: The C register and register group struct declarations are provided for
22178  * convenience and illustrative purposes. They should, however, be used with
22179  * caution as the C language standard provides no guarantees about the alignment or
22180  * atomicity of device memory accesses. The recommended practice for writing
22181  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22182  * alt_write_word() functions.
22183  *
22184  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX50.
22185  */
22187 {
22188  uint32_t sel : 1; /* GPIO/Loan IO50Input Mux Selection Field */
22189  uint32_t : 31; /* *UNDEFINED* */
22190 };
22191
22192 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX50. */
22193 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX50_s ALT_SYSMGR_PINMUX_GPLMUX50_t;
22194 #endif /* __ASSEMBLY__ */
22195
22196 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX50 register from the beginning of the component. */
22197 #define ALT_SYSMGR_PINMUX_GPLMUX50_OFST 0x29c
22198
22199 /*
22200  * Register : GPIO/LoanIO 51 Output/Output Enable Mux Selection Register - GPLMUX51
22201  *
22202  * Selection between GPIO and LoanIO output and output enable for GPIO51 and
22203  * LoanIO51. These signals drive the Pin Mux. The Pin Mux must be configured to use
22204  * GPIO/LoanIO in addition to these settings
22205  *
22206  * Only reset by a cold reset (ignores warm reset).
22207  *
22208  * NOTE: These registers should not be modified after IO configuration.There is no
22209  * support for dynamically changing the Pin Mux selections.
22210  *
22211  * Register Layout
22212  *
22213  * Bits | Access | Reset | Description
22214  * :-------|:-------|:------|:----------------------------------------
22215  * [0] | RW | 0x0 | GPIO/Loan IO51Input Mux Selection Field
22216  * [31:1] | ??? | 0x0 | *UNDEFINED*
22217  *
22218  */
22219 /*
22220  * Field : GPIO/Loan IO51Input Mux Selection Field - sel
22221  *
22222  * Select source for GPIO/LoanIO 51.
22223  *
22224  * 0 : LoanIO 51 controls GPIO/LOANIO[51] output and output enable signals.
22225  *
22226  * 1 : GPIO 51 controls GPIO/LOANI[51] output and output enable signals.
22227  *
22228  * Field Access Macros:
22229  *
22230  */
22231 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX51_SEL register field. */
22232 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_LSB 0
22233 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX51_SEL register field. */
22234 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_MSB 0
22235 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX51_SEL register field. */
22236 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_WIDTH 1
22237 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX51_SEL register field value. */
22238 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_SET_MSK 0x00000001
22239 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX51_SEL register field value. */
22240 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_CLR_MSK 0xfffffffe
22241 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX51_SEL register field. */
22242 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_RESET 0x0
22243 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX51_SEL field value from a register. */
22244 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_GET(value) (((value) & 0x00000001) >> 0)
22245 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX51_SEL register field value suitable for setting the register. */
22246 #define ALT_SYSMGR_PINMUX_GPLMUX51_SEL_SET(value) (((value) << 0) & 0x00000001)
22247
22248 #ifndef __ASSEMBLY__
22249 /*
22250  * WARNING: The C register and register group struct declarations are provided for
22251  * convenience and illustrative purposes. They should, however, be used with
22252  * caution as the C language standard provides no guarantees about the alignment or
22253  * atomicity of device memory accesses. The recommended practice for writing
22254  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22255  * alt_write_word() functions.
22256  *
22257  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX51.
22258  */
22260 {
22261  uint32_t sel : 1; /* GPIO/Loan IO51Input Mux Selection Field */
22262  uint32_t : 31; /* *UNDEFINED* */
22263 };
22264
22265 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX51. */
22266 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX51_s ALT_SYSMGR_PINMUX_GPLMUX51_t;
22267 #endif /* __ASSEMBLY__ */
22268
22269 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX51 register from the beginning of the component. */
22270 #define ALT_SYSMGR_PINMUX_GPLMUX51_OFST 0x2a0
22271
22272 /*
22273  * Register : GPIO/LoanIO 52 Output/Output Enable Mux Selection Register - GPLMUX52
22274  *
22275  * Selection between GPIO and LoanIO output and output enable for GPIO52 and
22276  * LoanIO52. These signals drive the Pin Mux. The Pin Mux must be configured to use
22277  * GPIO/LoanIO in addition to these settings
22278  *
22279  * Only reset by a cold reset (ignores warm reset).
22280  *
22281  * NOTE: These registers should not be modified after IO configuration.There is no
22282  * support for dynamically changing the Pin Mux selections.
22283  *
22284  * Register Layout
22285  *
22286  * Bits | Access | Reset | Description
22287  * :-------|:-------|:------|:----------------------------------------
22288  * [0] | RW | 0x0 | GPIO/Loan IO52Input Mux Selection Field
22289  * [31:1] | ??? | 0x0 | *UNDEFINED*
22290  *
22291  */
22292 /*
22293  * Field : GPIO/Loan IO52Input Mux Selection Field - sel
22294  *
22295  * Select source for GPIO/LoanIO 52.
22296  *
22297  * 0 : LoanIO 52 controls GPIO/LOANIO[52] output and output enable signals.
22298  *
22299  * 1 : GPIO 52 controls GPIO/LOANI[52] output and output enable signals.
22300  *
22301  * Field Access Macros:
22302  *
22303  */
22304 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX52_SEL register field. */
22305 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_LSB 0
22306 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX52_SEL register field. */
22307 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_MSB 0
22308 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX52_SEL register field. */
22309 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_WIDTH 1
22310 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX52_SEL register field value. */
22311 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_SET_MSK 0x00000001
22312 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX52_SEL register field value. */
22313 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_CLR_MSK 0xfffffffe
22314 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX52_SEL register field. */
22315 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_RESET 0x0
22316 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX52_SEL field value from a register. */
22317 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_GET(value) (((value) & 0x00000001) >> 0)
22318 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX52_SEL register field value suitable for setting the register. */
22319 #define ALT_SYSMGR_PINMUX_GPLMUX52_SEL_SET(value) (((value) << 0) & 0x00000001)
22320
22321 #ifndef __ASSEMBLY__
22322 /*
22323  * WARNING: The C register and register group struct declarations are provided for
22324  * convenience and illustrative purposes. They should, however, be used with
22325  * caution as the C language standard provides no guarantees about the alignment or
22326  * atomicity of device memory accesses. The recommended practice for writing
22327  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22328  * alt_write_word() functions.
22329  *
22330  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX52.
22331  */
22333 {
22334  uint32_t sel : 1; /* GPIO/Loan IO52Input Mux Selection Field */
22335  uint32_t : 31; /* *UNDEFINED* */
22336 };
22337
22338 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX52. */
22339 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX52_s ALT_SYSMGR_PINMUX_GPLMUX52_t;
22340 #endif /* __ASSEMBLY__ */
22341
22342 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX52 register from the beginning of the component. */
22343 #define ALT_SYSMGR_PINMUX_GPLMUX52_OFST 0x2a4
22344
22345 /*
22346  * Register : GPIO/LoanIO 53 Output/Output Enable Mux Selection Register - GPLMUX53
22347  *
22348  * Selection between GPIO and LoanIO output and output enable for GPIO53 and
22349  * LoanIO53. These signals drive the Pin Mux. The Pin Mux must be configured to use
22350  * GPIO/LoanIO in addition to these settings
22351  *
22352  * Only reset by a cold reset (ignores warm reset).
22353  *
22354  * NOTE: These registers should not be modified after IO configuration.There is no
22355  * support for dynamically changing the Pin Mux selections.
22356  *
22357  * Register Layout
22358  *
22359  * Bits | Access | Reset | Description
22360  * :-------|:-------|:------|:----------------------------------------
22361  * [0] | RW | 0x0 | GPIO/Loan IO53Input Mux Selection Field
22362  * [31:1] | ??? | 0x0 | *UNDEFINED*
22363  *
22364  */
22365 /*
22366  * Field : GPIO/Loan IO53Input Mux Selection Field - sel
22367  *
22368  * Select source for GPIO/LoanIO 53.
22369  *
22370  * 0 : LoanIO 53 controls GPIO/LOANIO[53] output and output enable signals.
22371  *
22372  * 1 : GPIO 53 controls GPIO/LOANI[53] output and output enable signals.
22373  *
22374  * Field Access Macros:
22375  *
22376  */
22377 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX53_SEL register field. */
22378 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_LSB 0
22379 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX53_SEL register field. */
22380 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_MSB 0
22381 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX53_SEL register field. */
22382 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_WIDTH 1
22383 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX53_SEL register field value. */
22384 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_SET_MSK 0x00000001
22385 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX53_SEL register field value. */
22386 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_CLR_MSK 0xfffffffe
22387 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX53_SEL register field. */
22388 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_RESET 0x0
22389 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX53_SEL field value from a register. */
22390 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_GET(value) (((value) & 0x00000001) >> 0)
22391 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX53_SEL register field value suitable for setting the register. */
22392 #define ALT_SYSMGR_PINMUX_GPLMUX53_SEL_SET(value) (((value) << 0) & 0x00000001)
22393
22394 #ifndef __ASSEMBLY__
22395 /*
22396  * WARNING: The C register and register group struct declarations are provided for
22397  * convenience and illustrative purposes. They should, however, be used with
22398  * caution as the C language standard provides no guarantees about the alignment or
22399  * atomicity of device memory accesses. The recommended practice for writing
22400  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22401  * alt_write_word() functions.
22402  *
22403  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX53.
22404  */
22406 {
22407  uint32_t sel : 1; /* GPIO/Loan IO53Input Mux Selection Field */
22408  uint32_t : 31; /* *UNDEFINED* */
22409 };
22410
22411 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX53. */
22412 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX53_s ALT_SYSMGR_PINMUX_GPLMUX53_t;
22413 #endif /* __ASSEMBLY__ */
22414
22415 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX53 register from the beginning of the component. */
22416 #define ALT_SYSMGR_PINMUX_GPLMUX53_OFST 0x2a8
22417
22418 /*
22419  * Register : GPIO/LoanIO 54 Output/Output Enable Mux Selection Register - GPLMUX54
22420  *
22421  * Selection between GPIO and LoanIO output and output enable for GPIO54 and
22422  * LoanIO54. These signals drive the Pin Mux. The Pin Mux must be configured to use
22423  * GPIO/LoanIO in addition to these settings
22424  *
22425  * Only reset by a cold reset (ignores warm reset).
22426  *
22427  * NOTE: These registers should not be modified after IO configuration.There is no
22428  * support for dynamically changing the Pin Mux selections.
22429  *
22430  * Register Layout
22431  *
22432  * Bits | Access | Reset | Description
22433  * :-------|:-------|:------|:----------------------------------------
22434  * [0] | RW | 0x0 | GPIO/Loan IO54Input Mux Selection Field
22435  * [31:1] | ??? | 0x0 | *UNDEFINED*
22436  *
22437  */
22438 /*
22439  * Field : GPIO/Loan IO54Input Mux Selection Field - sel
22440  *
22441  * Select source for GPIO/LoanIO 54.
22442  *
22443  * 0 : LoanIO 54 controls GPIO/LOANIO[54] output and output enable signals.
22444  *
22445  * 1 : GPIO 54 controls GPIO/LOANI[54] output and output enable signals.
22446  *
22447  * Field Access Macros:
22448  *
22449  */
22450 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX54_SEL register field. */
22451 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_LSB 0
22452 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX54_SEL register field. */
22453 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_MSB 0
22454 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX54_SEL register field. */
22455 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_WIDTH 1
22456 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX54_SEL register field value. */
22457 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_SET_MSK 0x00000001
22458 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX54_SEL register field value. */
22459 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_CLR_MSK 0xfffffffe
22460 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX54_SEL register field. */
22461 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_RESET 0x0
22462 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX54_SEL field value from a register. */
22463 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_GET(value) (((value) & 0x00000001) >> 0)
22464 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX54_SEL register field value suitable for setting the register. */
22465 #define ALT_SYSMGR_PINMUX_GPLMUX54_SEL_SET(value) (((value) << 0) & 0x00000001)
22466
22467 #ifndef __ASSEMBLY__
22468 /*
22469  * WARNING: The C register and register group struct declarations are provided for
22470  * convenience and illustrative purposes. They should, however, be used with
22471  * caution as the C language standard provides no guarantees about the alignment or
22472  * atomicity of device memory accesses. The recommended practice for writing
22473  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22474  * alt_write_word() functions.
22475  *
22476  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX54.
22477  */
22479 {
22480  uint32_t sel : 1; /* GPIO/Loan IO54Input Mux Selection Field */
22481  uint32_t : 31; /* *UNDEFINED* */
22482 };
22483
22484 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX54. */
22485 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX54_s ALT_SYSMGR_PINMUX_GPLMUX54_t;
22486 #endif /* __ASSEMBLY__ */
22487
22488 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX54 register from the beginning of the component. */
22489 #define ALT_SYSMGR_PINMUX_GPLMUX54_OFST 0x2ac
22490
22491 /*
22492  * Register : GPIO/LoanIO 55 Output/Output Enable Mux Selection Register - GPLMUX55
22493  *
22494  * Selection between GPIO and LoanIO output and output enable for GPIO55 and
22495  * LoanIO55. These signals drive the Pin Mux. The Pin Mux must be configured to use
22496  * GPIO/LoanIO in addition to these settings
22497  *
22498  * Only reset by a cold reset (ignores warm reset).
22499  *
22500  * NOTE: These registers should not be modified after IO configuration.There is no
22501  * support for dynamically changing the Pin Mux selections.
22502  *
22503  * Register Layout
22504  *
22505  * Bits | Access | Reset | Description
22506  * :-------|:-------|:------|:----------------------------------------
22507  * [0] | RW | 0x0 | GPIO/Loan IO55Input Mux Selection Field
22508  * [31:1] | ??? | 0x0 | *UNDEFINED*
22509  *
22510  */
22511 /*
22512  * Field : GPIO/Loan IO55Input Mux Selection Field - sel
22513  *
22514  * Select source for GPIO/LoanIO 55.
22515  *
22516  * 0 : LoanIO 55 controls GPIO/LOANIO[55] output and output enable signals.
22517  *
22518  * 1 : GPIO 55 controls GPIO/LOANI[55] output and output enable signals.
22519  *
22520  * Field Access Macros:
22521  *
22522  */
22523 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX55_SEL register field. */
22524 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_LSB 0
22525 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX55_SEL register field. */
22526 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_MSB 0
22527 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX55_SEL register field. */
22528 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_WIDTH 1
22529 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX55_SEL register field value. */
22530 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_SET_MSK 0x00000001
22531 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX55_SEL register field value. */
22532 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_CLR_MSK 0xfffffffe
22533 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX55_SEL register field. */
22534 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_RESET 0x0
22535 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX55_SEL field value from a register. */
22536 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_GET(value) (((value) & 0x00000001) >> 0)
22537 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX55_SEL register field value suitable for setting the register. */
22538 #define ALT_SYSMGR_PINMUX_GPLMUX55_SEL_SET(value) (((value) << 0) & 0x00000001)
22539
22540 #ifndef __ASSEMBLY__
22541 /*
22542  * WARNING: The C register and register group struct declarations are provided for
22543  * convenience and illustrative purposes. They should, however, be used with
22544  * caution as the C language standard provides no guarantees about the alignment or
22545  * atomicity of device memory accesses. The recommended practice for writing
22546  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22547  * alt_write_word() functions.
22548  *
22549  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX55.
22550  */
22552 {
22553  uint32_t sel : 1; /* GPIO/Loan IO55Input Mux Selection Field */
22554  uint32_t : 31; /* *UNDEFINED* */
22555 };
22556
22557 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX55. */
22558 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX55_s ALT_SYSMGR_PINMUX_GPLMUX55_t;
22559 #endif /* __ASSEMBLY__ */
22560
22561 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX55 register from the beginning of the component. */
22562 #define ALT_SYSMGR_PINMUX_GPLMUX55_OFST 0x2b0
22563
22564 /*
22565  * Register : GPIO/LoanIO 56 Output/Output Enable Mux Selection Register - GPLMUX56
22566  *
22567  * Selection between GPIO and LoanIO output and output enable for GPIO56 and
22568  * LoanIO56. These signals drive the Pin Mux. The Pin Mux must be configured to use
22569  * GPIO/LoanIO in addition to these settings
22570  *
22571  * Only reset by a cold reset (ignores warm reset).
22572  *
22573  * NOTE: These registers should not be modified after IO configuration.There is no
22574  * support for dynamically changing the Pin Mux selections.
22575  *
22576  * Register Layout
22577  *
22578  * Bits | Access | Reset | Description
22579  * :-------|:-------|:------|:----------------------------------------
22580  * [0] | RW | 0x0 | GPIO/Loan IO56Input Mux Selection Field
22581  * [31:1] | ??? | 0x0 | *UNDEFINED*
22582  *
22583  */
22584 /*
22585  * Field : GPIO/Loan IO56Input Mux Selection Field - sel
22586  *
22587  * Select source for GPIO/LoanIO 56.
22588  *
22589  * 0 : LoanIO 56 controls GPIO/LOANIO[56] output and output enable signals.
22590  *
22591  * 1 : GPIO 56 controls GPIO/LOANI[56] output and output enable signals.
22592  *
22593  * Field Access Macros:
22594  *
22595  */
22596 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX56_SEL register field. */
22597 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_LSB 0
22598 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX56_SEL register field. */
22599 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_MSB 0
22600 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX56_SEL register field. */
22601 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_WIDTH 1
22602 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX56_SEL register field value. */
22603 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_SET_MSK 0x00000001
22604 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX56_SEL register field value. */
22605 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_CLR_MSK 0xfffffffe
22606 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX56_SEL register field. */
22607 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_RESET 0x0
22608 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX56_SEL field value from a register. */
22609 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_GET(value) (((value) & 0x00000001) >> 0)
22610 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX56_SEL register field value suitable for setting the register. */
22611 #define ALT_SYSMGR_PINMUX_GPLMUX56_SEL_SET(value) (((value) << 0) & 0x00000001)
22612
22613 #ifndef __ASSEMBLY__
22614 /*
22615  * WARNING: The C register and register group struct declarations are provided for
22616  * convenience and illustrative purposes. They should, however, be used with
22617  * caution as the C language standard provides no guarantees about the alignment or
22618  * atomicity of device memory accesses. The recommended practice for writing
22619  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22620  * alt_write_word() functions.
22621  *
22622  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX56.
22623  */
22625 {
22626  uint32_t sel : 1; /* GPIO/Loan IO56Input Mux Selection Field */
22627  uint32_t : 31; /* *UNDEFINED* */
22628 };
22629
22630 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX56. */
22631 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX56_s ALT_SYSMGR_PINMUX_GPLMUX56_t;
22632 #endif /* __ASSEMBLY__ */
22633
22634 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX56 register from the beginning of the component. */
22635 #define ALT_SYSMGR_PINMUX_GPLMUX56_OFST 0x2b4
22636
22637 /*
22638  * Register : GPIO/LoanIO 57 Output/Output Enable Mux Selection Register - GPLMUX57
22639  *
22640  * Selection between GPIO and LoanIO output and output enable for GPIO57 and
22641  * LoanIO57. These signals drive the Pin Mux. The Pin Mux must be configured to use
22642  * GPIO/LoanIO in addition to these settings
22643  *
22644  * Only reset by a cold reset (ignores warm reset).
22645  *
22646  * NOTE: These registers should not be modified after IO configuration.There is no
22647  * support for dynamically changing the Pin Mux selections.
22648  *
22649  * Register Layout
22650  *
22651  * Bits | Access | Reset | Description
22652  * :-------|:-------|:------|:----------------------------------------
22653  * [0] | RW | 0x0 | GPIO/Loan IO57Input Mux Selection Field
22654  * [31:1] | ??? | 0x0 | *UNDEFINED*
22655  *
22656  */
22657 /*
22658  * Field : GPIO/Loan IO57Input Mux Selection Field - sel
22659  *
22660  * Select source for GPIO/LoanIO 57.
22661  *
22662  * 0 : LoanIO 57 controls GPIO/LOANIO[57] output and output enable signals.
22663  *
22664  * 1 : GPIO 57 controls GPIO/LOANI[57] output and output enable signals.
22665  *
22666  * Field Access Macros:
22667  *
22668  */
22669 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX57_SEL register field. */
22670 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_LSB 0
22671 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX57_SEL register field. */
22672 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_MSB 0
22673 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX57_SEL register field. */
22674 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_WIDTH 1
22675 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX57_SEL register field value. */
22676 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_SET_MSK 0x00000001
22677 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX57_SEL register field value. */
22678 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_CLR_MSK 0xfffffffe
22679 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX57_SEL register field. */
22680 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_RESET 0x0
22681 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX57_SEL field value from a register. */
22682 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_GET(value) (((value) & 0x00000001) >> 0)
22683 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX57_SEL register field value suitable for setting the register. */
22684 #define ALT_SYSMGR_PINMUX_GPLMUX57_SEL_SET(value) (((value) << 0) & 0x00000001)
22685
22686 #ifndef __ASSEMBLY__
22687 /*
22688  * WARNING: The C register and register group struct declarations are provided for
22689  * convenience and illustrative purposes. They should, however, be used with
22690  * caution as the C language standard provides no guarantees about the alignment or
22691  * atomicity of device memory accesses. The recommended practice for writing
22692  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22693  * alt_write_word() functions.
22694  *
22695  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX57.
22696  */
22698 {
22699  uint32_t sel : 1; /* GPIO/Loan IO57Input Mux Selection Field */
22700  uint32_t : 31; /* *UNDEFINED* */
22701 };
22702
22703 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX57. */
22704 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX57_s ALT_SYSMGR_PINMUX_GPLMUX57_t;
22705 #endif /* __ASSEMBLY__ */
22706
22707 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX57 register from the beginning of the component. */
22708 #define ALT_SYSMGR_PINMUX_GPLMUX57_OFST 0x2b8
22709
22710 /*
22711  * Register : GPIO/LoanIO 58 Output/Output Enable Mux Selection Register - GPLMUX58
22712  *
22713  * Selection between GPIO and LoanIO output and output enable for GPIO58 and
22714  * LoanIO58. These signals drive the Pin Mux. The Pin Mux must be configured to use
22715  * GPIO/LoanIO in addition to these settings
22716  *
22717  * Only reset by a cold reset (ignores warm reset).
22718  *
22719  * NOTE: These registers should not be modified after IO configuration.There is no
22720  * support for dynamically changing the Pin Mux selections.
22721  *
22722  * Register Layout
22723  *
22724  * Bits | Access | Reset | Description
22725  * :-------|:-------|:------|:----------------------------------------
22726  * [0] | RW | 0x0 | GPIO/Loan IO58Input Mux Selection Field
22727  * [31:1] | ??? | 0x0 | *UNDEFINED*
22728  *
22729  */
22730 /*
22731  * Field : GPIO/Loan IO58Input Mux Selection Field - sel
22732  *
22733  * Select source for GPIO/LoanIO 58.
22734  *
22735  * 0 : LoanIO 58 controls GPIO/LOANIO[58] output and output enable signals.
22736  *
22737  * 1 : GPIO 58 controls GPIO/LOANI[58] output and output enable signals.
22738  *
22739  * Field Access Macros:
22740  *
22741  */
22742 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX58_SEL register field. */
22743 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_LSB 0
22744 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX58_SEL register field. */
22745 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_MSB 0
22746 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX58_SEL register field. */
22747 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_WIDTH 1
22748 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX58_SEL register field value. */
22749 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_SET_MSK 0x00000001
22750 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX58_SEL register field value. */
22751 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_CLR_MSK 0xfffffffe
22752 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX58_SEL register field. */
22753 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_RESET 0x0
22754 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX58_SEL field value from a register. */
22755 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_GET(value) (((value) & 0x00000001) >> 0)
22756 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX58_SEL register field value suitable for setting the register. */
22757 #define ALT_SYSMGR_PINMUX_GPLMUX58_SEL_SET(value) (((value) << 0) & 0x00000001)
22758
22759 #ifndef __ASSEMBLY__
22760 /*
22761  * WARNING: The C register and register group struct declarations are provided for
22762  * convenience and illustrative purposes. They should, however, be used with
22763  * caution as the C language standard provides no guarantees about the alignment or
22764  * atomicity of device memory accesses. The recommended practice for writing
22765  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22766  * alt_write_word() functions.
22767  *
22768  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX58.
22769  */
22771 {
22772  uint32_t sel : 1; /* GPIO/Loan IO58Input Mux Selection Field */
22773  uint32_t : 31; /* *UNDEFINED* */
22774 };
22775
22776 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX58. */
22777 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX58_s ALT_SYSMGR_PINMUX_GPLMUX58_t;
22778 #endif /* __ASSEMBLY__ */
22779
22780 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX58 register from the beginning of the component. */
22781 #define ALT_SYSMGR_PINMUX_GPLMUX58_OFST 0x2bc
22782
22783 /*
22784  * Register : GPIO/LoanIO 59 Output/Output Enable Mux Selection Register - GPLMUX59
22785  *
22786  * Selection between GPIO and LoanIO output and output enable for GPIO59 and
22787  * LoanIO59. These signals drive the Pin Mux. The Pin Mux must be configured to use
22788  * GPIO/LoanIO in addition to these settings
22789  *
22790  * Only reset by a cold reset (ignores warm reset).
22791  *
22792  * NOTE: These registers should not be modified after IO configuration.There is no
22793  * support for dynamically changing the Pin Mux selections.
22794  *
22795  * Register Layout
22796  *
22797  * Bits | Access | Reset | Description
22798  * :-------|:-------|:------|:----------------------------------------
22799  * [0] | RW | 0x0 | GPIO/Loan IO59Input Mux Selection Field
22800  * [31:1] | ??? | 0x0 | *UNDEFINED*
22801  *
22802  */
22803 /*
22804  * Field : GPIO/Loan IO59Input Mux Selection Field - sel
22805  *
22806  * Select source for GPIO/LoanIO 59.
22807  *
22808  * 0 : LoanIO 59 controls GPIO/LOANIO[59] output and output enable signals.
22809  *
22810  * 1 : GPIO 59 controls GPIO/LOANI[59] output and output enable signals.
22811  *
22812  * Field Access Macros:
22813  *
22814  */
22815 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX59_SEL register field. */
22816 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_LSB 0
22817 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX59_SEL register field. */
22818 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_MSB 0
22819 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX59_SEL register field. */
22820 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_WIDTH 1
22821 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX59_SEL register field value. */
22822 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_SET_MSK 0x00000001
22823 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX59_SEL register field value. */
22824 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_CLR_MSK 0xfffffffe
22825 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX59_SEL register field. */
22826 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_RESET 0x0
22827 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX59_SEL field value from a register. */
22828 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_GET(value) (((value) & 0x00000001) >> 0)
22829 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX59_SEL register field value suitable for setting the register. */
22830 #define ALT_SYSMGR_PINMUX_GPLMUX59_SEL_SET(value) (((value) << 0) & 0x00000001)
22831
22832 #ifndef __ASSEMBLY__
22833 /*
22834  * WARNING: The C register and register group struct declarations are provided for
22835  * convenience and illustrative purposes. They should, however, be used with
22836  * caution as the C language standard provides no guarantees about the alignment or
22837  * atomicity of device memory accesses. The recommended practice for writing
22838  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22839  * alt_write_word() functions.
22840  *
22841  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX59.
22842  */
22844 {
22845  uint32_t sel : 1; /* GPIO/Loan IO59Input Mux Selection Field */
22846  uint32_t : 31; /* *UNDEFINED* */
22847 };
22848
22849 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX59. */
22850 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX59_s ALT_SYSMGR_PINMUX_GPLMUX59_t;
22851 #endif /* __ASSEMBLY__ */
22852
22853 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX59 register from the beginning of the component. */
22854 #define ALT_SYSMGR_PINMUX_GPLMUX59_OFST 0x2c0
22855
22856 /*
22857  * Register : GPIO/LoanIO 60 Output/Output Enable Mux Selection Register - GPLMUX60
22858  *
22859  * Selection between GPIO and LoanIO output and output enable for GPIO60 and
22860  * LoanIO60. These signals drive the Pin Mux. The Pin Mux must be configured to use
22861  * GPIO/LoanIO in addition to these settings
22862  *
22863  * Only reset by a cold reset (ignores warm reset).
22864  *
22865  * NOTE: These registers should not be modified after IO configuration.There is no
22866  * support for dynamically changing the Pin Mux selections.
22867  *
22868  * Register Layout
22869  *
22870  * Bits | Access | Reset | Description
22871  * :-------|:-------|:------|:----------------------------------------
22872  * [0] | RW | 0x0 | GPIO/Loan IO60Input Mux Selection Field
22873  * [31:1] | ??? | 0x0 | *UNDEFINED*
22874  *
22875  */
22876 /*
22877  * Field : GPIO/Loan IO60Input Mux Selection Field - sel
22878  *
22879  * Select source for GPIO/LoanIO 60.
22880  *
22881  * 0 : LoanIO 60 controls GPIO/LOANIO[60] output and output enable signals.
22882  *
22883  * 1 : GPIO 60 controls GPIO/LOANI[60] output and output enable signals.
22884  *
22885  * Field Access Macros:
22886  *
22887  */
22888 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX60_SEL register field. */
22889 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_LSB 0
22890 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX60_SEL register field. */
22891 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_MSB 0
22892 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX60_SEL register field. */
22893 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_WIDTH 1
22894 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX60_SEL register field value. */
22895 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_SET_MSK 0x00000001
22896 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX60_SEL register field value. */
22897 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_CLR_MSK 0xfffffffe
22898 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX60_SEL register field. */
22899 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_RESET 0x0
22900 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX60_SEL field value from a register. */
22901 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_GET(value) (((value) & 0x00000001) >> 0)
22902 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX60_SEL register field value suitable for setting the register. */
22903 #define ALT_SYSMGR_PINMUX_GPLMUX60_SEL_SET(value) (((value) << 0) & 0x00000001)
22904
22905 #ifndef __ASSEMBLY__
22906 /*
22907  * WARNING: The C register and register group struct declarations are provided for
22908  * convenience and illustrative purposes. They should, however, be used with
22909  * caution as the C language standard provides no guarantees about the alignment or
22910  * atomicity of device memory accesses. The recommended practice for writing
22911  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22912  * alt_write_word() functions.
22913  *
22914  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX60.
22915  */
22917 {
22918  uint32_t sel : 1; /* GPIO/Loan IO60Input Mux Selection Field */
22919  uint32_t : 31; /* *UNDEFINED* */
22920 };
22921
22922 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX60. */
22923 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX60_s ALT_SYSMGR_PINMUX_GPLMUX60_t;
22924 #endif /* __ASSEMBLY__ */
22925
22926 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX60 register from the beginning of the component. */
22927 #define ALT_SYSMGR_PINMUX_GPLMUX60_OFST 0x2c4
22928
22929 /*
22930  * Register : GPIO/LoanIO 61 Output/Output Enable Mux Selection Register - GPLMUX61
22931  *
22932  * Selection between GPIO and LoanIO output and output enable for GPIO61 and
22933  * LoanIO61. These signals drive the Pin Mux. The Pin Mux must be configured to use
22934  * GPIO/LoanIO in addition to these settings
22935  *
22936  * Only reset by a cold reset (ignores warm reset).
22937  *
22938  * NOTE: These registers should not be modified after IO configuration.There is no
22939  * support for dynamically changing the Pin Mux selections.
22940  *
22941  * Register Layout
22942  *
22943  * Bits | Access | Reset | Description
22944  * :-------|:-------|:------|:----------------------------------------
22945  * [0] | RW | 0x0 | GPIO/Loan IO61Input Mux Selection Field
22946  * [31:1] | ??? | 0x0 | *UNDEFINED*
22947  *
22948  */
22949 /*
22950  * Field : GPIO/Loan IO61Input Mux Selection Field - sel
22951  *
22952  * Select source for GPIO/LoanIO 61.
22953  *
22954  * 0 : LoanIO 61 controls GPIO/LOANIO[61] output and output enable signals.
22955  *
22956  * 1 : GPIO 61 controls GPIO/LOANI[61] output and output enable signals.
22957  *
22958  * Field Access Macros:
22959  *
22960  */
22961 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX61_SEL register field. */
22962 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_LSB 0
22963 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX61_SEL register field. */
22964 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_MSB 0
22965 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX61_SEL register field. */
22966 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_WIDTH 1
22967 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX61_SEL register field value. */
22968 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_SET_MSK 0x00000001
22969 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX61_SEL register field value. */
22970 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_CLR_MSK 0xfffffffe
22971 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX61_SEL register field. */
22972 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_RESET 0x0
22973 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX61_SEL field value from a register. */
22974 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_GET(value) (((value) & 0x00000001) >> 0)
22975 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX61_SEL register field value suitable for setting the register. */
22976 #define ALT_SYSMGR_PINMUX_GPLMUX61_SEL_SET(value) (((value) << 0) & 0x00000001)
22977
22978 #ifndef __ASSEMBLY__
22979 /*
22980  * WARNING: The C register and register group struct declarations are provided for
22981  * convenience and illustrative purposes. They should, however, be used with
22982  * caution as the C language standard provides no guarantees about the alignment or
22983  * atomicity of device memory accesses. The recommended practice for writing
22984  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
22985  * alt_write_word() functions.
22986  *
22987  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX61.
22988  */
22990 {
22991  uint32_t sel : 1; /* GPIO/Loan IO61Input Mux Selection Field */
22992  uint32_t : 31; /* *UNDEFINED* */
22993 };
22994
22995 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX61. */
22996 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX61_s ALT_SYSMGR_PINMUX_GPLMUX61_t;
22997 #endif /* __ASSEMBLY__ */
22998
22999 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX61 register from the beginning of the component. */
23000 #define ALT_SYSMGR_PINMUX_GPLMUX61_OFST 0x2c8
23001
23002 /*
23003  * Register : GPIO/LoanIO 62 Output/Output Enable Mux Selection Register - GPLMUX62
23004  *
23005  * Selection between GPIO and LoanIO output and output enable for GPIO62 and
23006  * LoanIO62. These signals drive the Pin Mux. The Pin Mux must be configured to use
23007  * GPIO/LoanIO in addition to these settings
23008  *
23009  * Only reset by a cold reset (ignores warm reset).
23010  *
23011  * NOTE: These registers should not be modified after IO configuration.There is no
23012  * support for dynamically changing the Pin Mux selections.
23013  *
23014  * Register Layout
23015  *
23016  * Bits | Access | Reset | Description
23017  * :-------|:-------|:------|:----------------------------------------
23018  * [0] | RW | 0x0 | GPIO/Loan IO62Input Mux Selection Field
23019  * [31:1] | ??? | 0x0 | *UNDEFINED*
23020  *
23021  */
23022 /*
23023  * Field : GPIO/Loan IO62Input Mux Selection Field - sel
23024  *
23025  * Select source for GPIO/LoanIO 62.
23026  *
23027  * 0 : LoanIO 62 controls GPIO/LOANIO[62] output and output enable signals.
23028  *
23029  * 1 : GPIO 62 controls GPIO/LOANI[62] output and output enable signals.
23030  *
23031  * Field Access Macros:
23032  *
23033  */
23034 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX62_SEL register field. */
23035 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_LSB 0
23036 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX62_SEL register field. */
23037 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_MSB 0
23038 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX62_SEL register field. */
23039 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_WIDTH 1
23040 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX62_SEL register field value. */
23041 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_SET_MSK 0x00000001
23042 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX62_SEL register field value. */
23043 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_CLR_MSK 0xfffffffe
23044 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX62_SEL register field. */
23045 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_RESET 0x0
23046 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX62_SEL field value from a register. */
23047 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_GET(value) (((value) & 0x00000001) >> 0)
23048 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX62_SEL register field value suitable for setting the register. */
23049 #define ALT_SYSMGR_PINMUX_GPLMUX62_SEL_SET(value) (((value) << 0) & 0x00000001)
23050
23051 #ifndef __ASSEMBLY__
23052 /*
23053  * WARNING: The C register and register group struct declarations are provided for
23054  * convenience and illustrative purposes. They should, however, be used with
23055  * caution as the C language standard provides no guarantees about the alignment or
23056  * atomicity of device memory accesses. The recommended practice for writing
23057  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23058  * alt_write_word() functions.
23059  *
23060  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX62.
23061  */
23063 {
23064  uint32_t sel : 1; /* GPIO/Loan IO62Input Mux Selection Field */
23065  uint32_t : 31; /* *UNDEFINED* */
23066 };
23067
23068 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX62. */
23069 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX62_s ALT_SYSMGR_PINMUX_GPLMUX62_t;
23070 #endif /* __ASSEMBLY__ */
23071
23072 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX62 register from the beginning of the component. */
23073 #define ALT_SYSMGR_PINMUX_GPLMUX62_OFST 0x2cc
23074
23075 /*
23076  * Register : GPIO/LoanIO 63 Output/Output Enable Mux Selection Register - GPLMUX63
23077  *
23078  * Selection between GPIO and LoanIO output and output enable for GPIO63 and
23079  * LoanIO63. These signals drive the Pin Mux. The Pin Mux must be configured to use
23080  * GPIO/LoanIO in addition to these settings
23081  *
23082  * Only reset by a cold reset (ignores warm reset).
23083  *
23084  * NOTE: These registers should not be modified after IO configuration.There is no
23085  * support for dynamically changing the Pin Mux selections.
23086  *
23087  * Register Layout
23088  *
23089  * Bits | Access | Reset | Description
23090  * :-------|:-------|:------|:----------------------------------------
23091  * [0] | RW | 0x0 | GPIO/Loan IO63Input Mux Selection Field
23092  * [31:1] | ??? | 0x0 | *UNDEFINED*
23093  *
23094  */
23095 /*
23096  * Field : GPIO/Loan IO63Input Mux Selection Field - sel
23097  *
23098  * Select source for GPIO/LoanIO 63.
23099  *
23100  * 0 : LoanIO 63 controls GPIO/LOANIO[63] output and output enable signals.
23101  *
23102  * 1 : GPIO 63 controls GPIO/LOANI[63] output and output enable signals.
23103  *
23104  * Field Access Macros:
23105  *
23106  */
23107 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX63_SEL register field. */
23108 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_LSB 0
23109 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX63_SEL register field. */
23110 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_MSB 0
23111 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX63_SEL register field. */
23112 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_WIDTH 1
23113 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX63_SEL register field value. */
23114 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_SET_MSK 0x00000001
23115 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX63_SEL register field value. */
23116 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_CLR_MSK 0xfffffffe
23117 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX63_SEL register field. */
23118 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_RESET 0x0
23119 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX63_SEL field value from a register. */
23120 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_GET(value) (((value) & 0x00000001) >> 0)
23121 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX63_SEL register field value suitable for setting the register. */
23122 #define ALT_SYSMGR_PINMUX_GPLMUX63_SEL_SET(value) (((value) << 0) & 0x00000001)
23123
23124 #ifndef __ASSEMBLY__
23125 /*
23126  * WARNING: The C register and register group struct declarations are provided for
23127  * convenience and illustrative purposes. They should, however, be used with
23128  * caution as the C language standard provides no guarantees about the alignment or
23129  * atomicity of device memory accesses. The recommended practice for writing
23130  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23131  * alt_write_word() functions.
23132  *
23133  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX63.
23134  */
23136 {
23137  uint32_t sel : 1; /* GPIO/Loan IO63Input Mux Selection Field */
23138  uint32_t : 31; /* *UNDEFINED* */
23139 };
23140
23141 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX63. */
23142 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX63_s ALT_SYSMGR_PINMUX_GPLMUX63_t;
23143 #endif /* __ASSEMBLY__ */
23144
23145 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX63 register from the beginning of the component. */
23146 #define ALT_SYSMGR_PINMUX_GPLMUX63_OFST 0x2d0
23147
23148 /*
23149  * Register : GPIO/LoanIO 64 Output/Output Enable Mux Selection Register - GPLMUX64
23150  *
23151  * Selection between GPIO and LoanIO output and output enable for GPIO64 and
23152  * LoanIO64. These signals drive the Pin Mux. The Pin Mux must be configured to use
23153  * GPIO/LoanIO in addition to these settings
23154  *
23155  * Only reset by a cold reset (ignores warm reset).
23156  *
23157  * NOTE: These registers should not be modified after IO configuration.There is no
23158  * support for dynamically changing the Pin Mux selections.
23159  *
23160  * Register Layout
23161  *
23162  * Bits | Access | Reset | Description
23163  * :-------|:-------|:------|:----------------------------------------
23164  * [0] | RW | 0x0 | GPIO/Loan IO64Input Mux Selection Field
23165  * [31:1] | ??? | 0x0 | *UNDEFINED*
23166  *
23167  */
23168 /*
23169  * Field : GPIO/Loan IO64Input Mux Selection Field - sel
23170  *
23171  * Select source for GPIO/LoanIO 64.
23172  *
23173  * 0 : LoanIO 64 controls GPIO/LOANIO[64] output and output enable signals.
23174  *
23175  * 1 : GPIO 64 controls GPIO/LOANI[64] output and output enable signals.
23176  *
23177  * Field Access Macros:
23178  *
23179  */
23180 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX64_SEL register field. */
23181 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_LSB 0
23182 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX64_SEL register field. */
23183 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_MSB 0
23184 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX64_SEL register field. */
23185 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_WIDTH 1
23186 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX64_SEL register field value. */
23187 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_SET_MSK 0x00000001
23188 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX64_SEL register field value. */
23189 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_CLR_MSK 0xfffffffe
23190 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX64_SEL register field. */
23191 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_RESET 0x0
23192 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX64_SEL field value from a register. */
23193 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_GET(value) (((value) & 0x00000001) >> 0)
23194 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX64_SEL register field value suitable for setting the register. */
23195 #define ALT_SYSMGR_PINMUX_GPLMUX64_SEL_SET(value) (((value) << 0) & 0x00000001)
23196
23197 #ifndef __ASSEMBLY__
23198 /*
23199  * WARNING: The C register and register group struct declarations are provided for
23200  * convenience and illustrative purposes. They should, however, be used with
23201  * caution as the C language standard provides no guarantees about the alignment or
23202  * atomicity of device memory accesses. The recommended practice for writing
23203  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23204  * alt_write_word() functions.
23205  *
23206  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX64.
23207  */
23209 {
23210  uint32_t sel : 1; /* GPIO/Loan IO64Input Mux Selection Field */
23211  uint32_t : 31; /* *UNDEFINED* */
23212 };
23213
23214 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX64. */
23215 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX64_s ALT_SYSMGR_PINMUX_GPLMUX64_t;
23216 #endif /* __ASSEMBLY__ */
23217
23218 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX64 register from the beginning of the component. */
23219 #define ALT_SYSMGR_PINMUX_GPLMUX64_OFST 0x2d4
23220
23221 /*
23222  * Register : GPIO/LoanIO 65 Output/Output Enable Mux Selection Register - GPLMUX65
23223  *
23224  * Selection between GPIO and LoanIO output and output enable for GPIO65 and
23225  * LoanIO65. These signals drive the Pin Mux. The Pin Mux must be configured to use
23226  * GPIO/LoanIO in addition to these settings
23227  *
23228  * Only reset by a cold reset (ignores warm reset).
23229  *
23230  * NOTE: These registers should not be modified after IO configuration.There is no
23231  * support for dynamically changing the Pin Mux selections.
23232  *
23233  * Register Layout
23234  *
23235  * Bits | Access | Reset | Description
23236  * :-------|:-------|:------|:----------------------------------------
23237  * [0] | RW | 0x0 | GPIO/Loan IO65Input Mux Selection Field
23238  * [31:1] | ??? | 0x0 | *UNDEFINED*
23239  *
23240  */
23241 /*
23242  * Field : GPIO/Loan IO65Input Mux Selection Field - sel
23243  *
23244  * Select source for GPIO/LoanIO 65.
23245  *
23246  * 0 : LoanIO 65 controls GPIO/LOANIO[65] output and output enable signals.
23247  *
23248  * 1 : GPIO 65 controls GPIO/LOANI[65] output and output enable signals.
23249  *
23250  * Field Access Macros:
23251  *
23252  */
23253 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX65_SEL register field. */
23254 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_LSB 0
23255 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX65_SEL register field. */
23256 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_MSB 0
23257 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX65_SEL register field. */
23258 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_WIDTH 1
23259 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX65_SEL register field value. */
23260 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_SET_MSK 0x00000001
23261 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX65_SEL register field value. */
23262 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_CLR_MSK 0xfffffffe
23263 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX65_SEL register field. */
23264 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_RESET 0x0
23265 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX65_SEL field value from a register. */
23266 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_GET(value) (((value) & 0x00000001) >> 0)
23267 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX65_SEL register field value suitable for setting the register. */
23268 #define ALT_SYSMGR_PINMUX_GPLMUX65_SEL_SET(value) (((value) << 0) & 0x00000001)
23269
23270 #ifndef __ASSEMBLY__
23271 /*
23272  * WARNING: The C register and register group struct declarations are provided for
23273  * convenience and illustrative purposes. They should, however, be used with
23274  * caution as the C language standard provides no guarantees about the alignment or
23275  * atomicity of device memory accesses. The recommended practice for writing
23276  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23277  * alt_write_word() functions.
23278  *
23279  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX65.
23280  */
23282 {
23283  uint32_t sel : 1; /* GPIO/Loan IO65Input Mux Selection Field */
23284  uint32_t : 31; /* *UNDEFINED* */
23285 };
23286
23287 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX65. */
23288 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX65_s ALT_SYSMGR_PINMUX_GPLMUX65_t;
23289 #endif /* __ASSEMBLY__ */
23290
23291 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX65 register from the beginning of the component. */
23292 #define ALT_SYSMGR_PINMUX_GPLMUX65_OFST 0x2d8
23293
23294 /*
23295  * Register : GPIO/LoanIO 66 Output/Output Enable Mux Selection Register - GPLMUX66
23296  *
23297  * Selection between GPIO and LoanIO output and output enable for GPIO66 and
23298  * LoanIO66. These signals drive the Pin Mux. The Pin Mux must be configured to use
23299  * GPIO/LoanIO in addition to these settings
23300  *
23301  * Only reset by a cold reset (ignores warm reset).
23302  *
23303  * NOTE: These registers should not be modified after IO configuration.There is no
23304  * support for dynamically changing the Pin Mux selections.
23305  *
23306  * Register Layout
23307  *
23308  * Bits | Access | Reset | Description
23309  * :-------|:-------|:------|:----------------------------------------
23310  * [0] | RW | 0x0 | GPIO/Loan IO66Input Mux Selection Field
23311  * [31:1] | ??? | 0x0 | *UNDEFINED*
23312  *
23313  */
23314 /*
23315  * Field : GPIO/Loan IO66Input Mux Selection Field - sel
23316  *
23317  * Select source for GPIO/LoanIO 66.
23318  *
23319  * 0 : LoanIO 66 controls GPIO/LOANIO[66] output and output enable signals.
23320  *
23321  * 1 : GPIO 66 controls GPIO/LOANI[66] output and output enable signals.
23322  *
23323  * Field Access Macros:
23324  *
23325  */
23326 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX66_SEL register field. */
23327 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_LSB 0
23328 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX66_SEL register field. */
23329 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_MSB 0
23330 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX66_SEL register field. */
23331 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_WIDTH 1
23332 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX66_SEL register field value. */
23333 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_SET_MSK 0x00000001
23334 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX66_SEL register field value. */
23335 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_CLR_MSK 0xfffffffe
23336 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX66_SEL register field. */
23337 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_RESET 0x0
23338 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX66_SEL field value from a register. */
23339 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_GET(value) (((value) & 0x00000001) >> 0)
23340 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX66_SEL register field value suitable for setting the register. */
23341 #define ALT_SYSMGR_PINMUX_GPLMUX66_SEL_SET(value) (((value) << 0) & 0x00000001)
23342
23343 #ifndef __ASSEMBLY__
23344 /*
23345  * WARNING: The C register and register group struct declarations are provided for
23346  * convenience and illustrative purposes. They should, however, be used with
23347  * caution as the C language standard provides no guarantees about the alignment or
23348  * atomicity of device memory accesses. The recommended practice for writing
23349  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23350  * alt_write_word() functions.
23351  *
23352  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX66.
23353  */
23355 {
23356  uint32_t sel : 1; /* GPIO/Loan IO66Input Mux Selection Field */
23357  uint32_t : 31; /* *UNDEFINED* */
23358 };
23359
23360 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX66. */
23361 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX66_s ALT_SYSMGR_PINMUX_GPLMUX66_t;
23362 #endif /* __ASSEMBLY__ */
23363
23364 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX66 register from the beginning of the component. */
23365 #define ALT_SYSMGR_PINMUX_GPLMUX66_OFST 0x2dc
23366
23367 /*
23368  * Register : GPIO/LoanIO 67 Output/Output Enable Mux Selection Register - GPLMUX67
23369  *
23370  * Selection between GPIO and LoanIO output and output enable for GPIO67 and
23371  * LoanIO67. These signals drive the Pin Mux. The Pin Mux must be configured to use
23372  * GPIO/LoanIO in addition to these settings
23373  *
23374  * Only reset by a cold reset (ignores warm reset).
23375  *
23376  * NOTE: These registers should not be modified after IO configuration.There is no
23377  * support for dynamically changing the Pin Mux selections.
23378  *
23379  * Register Layout
23380  *
23381  * Bits | Access | Reset | Description
23382  * :-------|:-------|:------|:----------------------------------------
23383  * [0] | RW | 0x0 | GPIO/Loan IO67Input Mux Selection Field
23384  * [31:1] | ??? | 0x0 | *UNDEFINED*
23385  *
23386  */
23387 /*
23388  * Field : GPIO/Loan IO67Input Mux Selection Field - sel
23389  *
23390  * Select source for GPIO/LoanIO 67.
23391  *
23392  * 0 : LoanIO 67 controls GPIO/LOANIO[67] output and output enable signals.
23393  *
23394  * 1 : GPIO 67 controls GPIO/LOANI[67] output and output enable signals.
23395  *
23396  * Field Access Macros:
23397  *
23398  */
23399 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX67_SEL register field. */
23400 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_LSB 0
23401 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX67_SEL register field. */
23402 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_MSB 0
23403 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX67_SEL register field. */
23404 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_WIDTH 1
23405 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX67_SEL register field value. */
23406 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_SET_MSK 0x00000001
23407 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX67_SEL register field value. */
23408 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_CLR_MSK 0xfffffffe
23409 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX67_SEL register field. */
23410 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_RESET 0x0
23411 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX67_SEL field value from a register. */
23412 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_GET(value) (((value) & 0x00000001) >> 0)
23413 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX67_SEL register field value suitable for setting the register. */
23414 #define ALT_SYSMGR_PINMUX_GPLMUX67_SEL_SET(value) (((value) << 0) & 0x00000001)
23415
23416 #ifndef __ASSEMBLY__
23417 /*
23418  * WARNING: The C register and register group struct declarations are provided for
23419  * convenience and illustrative purposes. They should, however, be used with
23420  * caution as the C language standard provides no guarantees about the alignment or
23421  * atomicity of device memory accesses. The recommended practice for writing
23422  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23423  * alt_write_word() functions.
23424  *
23425  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX67.
23426  */
23428 {
23429  uint32_t sel : 1; /* GPIO/Loan IO67Input Mux Selection Field */
23430  uint32_t : 31; /* *UNDEFINED* */
23431 };
23432
23433 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX67. */
23434 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX67_s ALT_SYSMGR_PINMUX_GPLMUX67_t;
23435 #endif /* __ASSEMBLY__ */
23436
23437 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX67 register from the beginning of the component. */
23438 #define ALT_SYSMGR_PINMUX_GPLMUX67_OFST 0x2e0
23439
23440 /*
23441  * Register : GPIO/LoanIO 68 Output/Output Enable Mux Selection Register - GPLMUX68
23442  *
23443  * Selection between GPIO and LoanIO output and output enable for GPIO68 and
23444  * LoanIO68. These signals drive the Pin Mux. The Pin Mux must be configured to use
23445  * GPIO/LoanIO in addition to these settings
23446  *
23447  * Only reset by a cold reset (ignores warm reset).
23448  *
23449  * NOTE: These registers should not be modified after IO configuration.There is no
23450  * support for dynamically changing the Pin Mux selections.
23451  *
23452  * Register Layout
23453  *
23454  * Bits | Access | Reset | Description
23455  * :-------|:-------|:------|:----------------------------------------
23456  * [0] | RW | 0x0 | GPIO/Loan IO68Input Mux Selection Field
23457  * [31:1] | ??? | 0x0 | *UNDEFINED*
23458  *
23459  */
23460 /*
23461  * Field : GPIO/Loan IO68Input Mux Selection Field - sel
23462  *
23463  * Select source for GPIO/LoanIO 68.
23464  *
23465  * 0 : LoanIO 68 controls GPIO/LOANIO[68] output and output enable signals.
23466  *
23467  * 1 : GPIO 68 controls GPIO/LOANI[68] output and output enable signals.
23468  *
23469  * Field Access Macros:
23470  *
23471  */
23472 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX68_SEL register field. */
23473 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_LSB 0
23474 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX68_SEL register field. */
23475 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_MSB 0
23476 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX68_SEL register field. */
23477 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_WIDTH 1
23478 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX68_SEL register field value. */
23479 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_SET_MSK 0x00000001
23480 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX68_SEL register field value. */
23481 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_CLR_MSK 0xfffffffe
23482 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX68_SEL register field. */
23483 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_RESET 0x0
23484 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX68_SEL field value from a register. */
23485 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_GET(value) (((value) & 0x00000001) >> 0)
23486 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX68_SEL register field value suitable for setting the register. */
23487 #define ALT_SYSMGR_PINMUX_GPLMUX68_SEL_SET(value) (((value) << 0) & 0x00000001)
23488
23489 #ifndef __ASSEMBLY__
23490 /*
23491  * WARNING: The C register and register group struct declarations are provided for
23492  * convenience and illustrative purposes. They should, however, be used with
23493  * caution as the C language standard provides no guarantees about the alignment or
23494  * atomicity of device memory accesses. The recommended practice for writing
23495  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23496  * alt_write_word() functions.
23497  *
23498  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX68.
23499  */
23501 {
23502  uint32_t sel : 1; /* GPIO/Loan IO68Input Mux Selection Field */
23503  uint32_t : 31; /* *UNDEFINED* */
23504 };
23505
23506 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX68. */
23507 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX68_s ALT_SYSMGR_PINMUX_GPLMUX68_t;
23508 #endif /* __ASSEMBLY__ */
23509
23510 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX68 register from the beginning of the component. */
23511 #define ALT_SYSMGR_PINMUX_GPLMUX68_OFST 0x2e4
23512
23513 /*
23514  * Register : GPIO/LoanIO 69 Output/Output Enable Mux Selection Register - GPLMUX69
23515  *
23516  * Selection between GPIO and LoanIO output and output enable for GPIO69 and
23517  * LoanIO69. These signals drive the Pin Mux. The Pin Mux must be configured to use
23518  * GPIO/LoanIO in addition to these settings
23519  *
23520  * Only reset by a cold reset (ignores warm reset).
23521  *
23522  * NOTE: These registers should not be modified after IO configuration.There is no
23523  * support for dynamically changing the Pin Mux selections.
23524  *
23525  * Register Layout
23526  *
23527  * Bits | Access | Reset | Description
23528  * :-------|:-------|:------|:----------------------------------------
23529  * [0] | RW | 0x0 | GPIO/Loan IO69Input Mux Selection Field
23530  * [31:1] | ??? | 0x0 | *UNDEFINED*
23531  *
23532  */
23533 /*
23534  * Field : GPIO/Loan IO69Input Mux Selection Field - sel
23535  *
23536  * Select source for GPIO/LoanIO 69.
23537  *
23538  * 0 : LoanIO 69 controls GPIO/LOANIO[69] output and output enable signals.
23539  *
23540  * 1 : GPIO 69 controls GPIO/LOANI[69] output and output enable signals.
23541  *
23542  * Field Access Macros:
23543  *
23544  */
23545 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX69_SEL register field. */
23546 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_LSB 0
23547 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX69_SEL register field. */
23548 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_MSB 0
23549 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX69_SEL register field. */
23550 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_WIDTH 1
23551 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX69_SEL register field value. */
23552 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_SET_MSK 0x00000001
23553 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX69_SEL register field value. */
23554 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_CLR_MSK 0xfffffffe
23555 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX69_SEL register field. */
23556 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_RESET 0x0
23557 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX69_SEL field value from a register. */
23558 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_GET(value) (((value) & 0x00000001) >> 0)
23559 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX69_SEL register field value suitable for setting the register. */
23560 #define ALT_SYSMGR_PINMUX_GPLMUX69_SEL_SET(value) (((value) << 0) & 0x00000001)
23561
23562 #ifndef __ASSEMBLY__
23563 /*
23564  * WARNING: The C register and register group struct declarations are provided for
23565  * convenience and illustrative purposes. They should, however, be used with
23566  * caution as the C language standard provides no guarantees about the alignment or
23567  * atomicity of device memory accesses. The recommended practice for writing
23568  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23569  * alt_write_word() functions.
23570  *
23571  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX69.
23572  */
23574 {
23575  uint32_t sel : 1; /* GPIO/Loan IO69Input Mux Selection Field */
23576  uint32_t : 31; /* *UNDEFINED* */
23577 };
23578
23579 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX69. */
23580 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX69_s ALT_SYSMGR_PINMUX_GPLMUX69_t;
23581 #endif /* __ASSEMBLY__ */
23582
23583 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX69 register from the beginning of the component. */
23584 #define ALT_SYSMGR_PINMUX_GPLMUX69_OFST 0x2e8
23585
23586 /*
23587  * Register : GPIO/LoanIO 70 Output/Output Enable Mux Selection Register - GPLMUX70
23588  *
23589  * Selection between GPIO and LoanIO output and output enable for GPIO70 and
23590  * LoanIO70. These signals drive the Pin Mux. The Pin Mux must be configured to use
23591  * GPIO/LoanIO in addition to these settings
23592  *
23593  * Only reset by a cold reset (ignores warm reset).
23594  *
23595  * NOTE: These registers should not be modified after IO configuration.There is no
23596  * support for dynamically changing the Pin Mux selections.
23597  *
23598  * Register Layout
23599  *
23600  * Bits | Access | Reset | Description
23601  * :-------|:-------|:------|:----------------------------------------
23602  * [0] | RW | 0x0 | GPIO/Loan IO70Input Mux Selection Field
23603  * [31:1] | ??? | 0x0 | *UNDEFINED*
23604  *
23605  */
23606 /*
23607  * Field : GPIO/Loan IO70Input Mux Selection Field - sel
23608  *
23609  * Select source for GPIO/LoanIO 70.
23610  *
23611  * 0 : LoanIO 70 controls GPIO/LOANIO[70] output and output enable signals.
23612  *
23613  * 1 : GPIO 70 controls GPIO/LOANI[70] output and output enable signals.
23614  *
23615  * Field Access Macros:
23616  *
23617  */
23618 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GPLMUX70_SEL register field. */
23619 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_LSB 0
23620 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GPLMUX70_SEL register field. */
23621 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_MSB 0
23622 /* The width in bits of the ALT_SYSMGR_PINMUX_GPLMUX70_SEL register field. */
23623 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_WIDTH 1
23624 /* The mask used to set the ALT_SYSMGR_PINMUX_GPLMUX70_SEL register field value. */
23625 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_SET_MSK 0x00000001
23626 /* The mask used to clear the ALT_SYSMGR_PINMUX_GPLMUX70_SEL register field value. */
23627 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_CLR_MSK 0xfffffffe
23628 /* The reset value of the ALT_SYSMGR_PINMUX_GPLMUX70_SEL register field. */
23629 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_RESET 0x0
23630 /* Extracts the ALT_SYSMGR_PINMUX_GPLMUX70_SEL field value from a register. */
23631 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_GET(value) (((value) & 0x00000001) >> 0)
23632 /* Produces a ALT_SYSMGR_PINMUX_GPLMUX70_SEL register field value suitable for setting the register. */
23633 #define ALT_SYSMGR_PINMUX_GPLMUX70_SEL_SET(value) (((value) << 0) & 0x00000001)
23634
23635 #ifndef __ASSEMBLY__
23636 /*
23637  * WARNING: The C register and register group struct declarations are provided for
23638  * convenience and illustrative purposes. They should, however, be used with
23639  * caution as the C language standard provides no guarantees about the alignment or
23640  * atomicity of device memory accesses. The recommended practice for writing
23641  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23642  * alt_write_word() functions.
23643  *
23644  * The struct declaration for register ALT_SYSMGR_PINMUX_GPLMUX70.
23645  */
23647 {
23648  uint32_t sel : 1; /* GPIO/Loan IO70Input Mux Selection Field */
23649  uint32_t : 31; /* *UNDEFINED* */
23650 };
23651
23652 /* The typedef declaration for register ALT_SYSMGR_PINMUX_GPLMUX70. */
23653 typedef volatile struct ALT_SYSMGR_PINMUX_GPLMUX70_s ALT_SYSMGR_PINMUX_GPLMUX70_t;
23654 #endif /* __ASSEMBLY__ */
23655
23656 /* The byte offset of the ALT_SYSMGR_PINMUX_GPLMUX70 register from the beginning of the component. */
23657 #define ALT_SYSMGR_PINMUX_GPLMUX70_OFST 0x2ec
23658
23659 /*
23660  * Register : Select source for NAND signals (HPS Pins or FPGA Interface) - NANDUSEFPGA
23661  *
23662  * Selection between HPS Pins and FPGA Interface for NAND signals.
23663  *
23664  * Only reset by a cold reset (ignores warm reset).
23665  *
23666  * NOTE: These registers should not be modified after IO configuration.There is no
23667  * support for dynamically changing the Pin Mux selections.
23668  *
23669  * Register Layout
23670  *
23671  * Bits | Access | Reset | Description
23672  * :-------|:-------|:------|:---------------------------
23673  * [0] | RW | 0x0 | Selection for NAND signals
23674  * [31:1] | ??? | 0x0 | *UNDEFINED*
23675  *
23676  */
23677 /*
23678  * Field : Selection for NAND signals - sel
23679  *
23680  * Select connection for NAND.
23681  *
23682  * 0 : NAND uses HPS Pins.
23683  *
23684  * 1 : NAND uses the FPGA Inteface.
23685  *
23686  * Field Access Macros:
23687  *
23688  */
23689 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL register field. */
23690 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_LSB 0
23691 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL register field. */
23692 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_MSB 0
23693 /* The width in bits of the ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL register field. */
23694 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_WIDTH 1
23695 /* The mask used to set the ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL register field value. */
23696 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_SET_MSK 0x00000001
23697 /* The mask used to clear the ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL register field value. */
23698 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_CLR_MSK 0xfffffffe
23699 /* The reset value of the ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL register field. */
23700 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_RESET 0x0
23701 /* Extracts the ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL field value from a register. */
23702 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
23703 /* Produces a ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL register field value suitable for setting the register. */
23704 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
23705
23706 #ifndef __ASSEMBLY__
23707 /*
23708  * WARNING: The C register and register group struct declarations are provided for
23709  * convenience and illustrative purposes. They should, however, be used with
23710  * caution as the C language standard provides no guarantees about the alignment or
23711  * atomicity of device memory accesses. The recommended practice for writing
23712  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23713  * alt_write_word() functions.
23714  *
23715  * The struct declaration for register ALT_SYSMGR_PINMUX_NANDUSEFPGA.
23716  */
23718 {
23719  uint32_t sel : 1; /* Selection for NAND signals */
23720  uint32_t : 31; /* *UNDEFINED* */
23721 };
23722
23723 /* The typedef declaration for register ALT_SYSMGR_PINMUX_NANDUSEFPGA. */
23724 typedef volatile struct ALT_SYSMGR_PINMUX_NANDUSEFPGA_s ALT_SYSMGR_PINMUX_NANDUSEFPGA_t;
23725 #endif /* __ASSEMBLY__ */
23726
23727 /* The byte offset of the ALT_SYSMGR_PINMUX_NANDUSEFPGA register from the beginning of the component. */
23728 #define ALT_SYSMGR_PINMUX_NANDUSEFPGA_OFST 0x2f0
23729
23730 /*
23731  * Register : Select source for RGMII1 signals (HPS Pins or FPGA Interface) - RGMII1USEFPGA
23732  *
23733  * Selection between HPS Pins and FPGA Interface for RGMII1 signals.
23734  *
23735  * Only reset by a cold reset (ignores warm reset).
23736  *
23737  * NOTE: These registers should not be modified after IO configuration.There is no
23738  * support for dynamically changing the Pin Mux selections.
23739  *
23740  * Register Layout
23741  *
23742  * Bits | Access | Reset | Description
23743  * :-------|:-------|:------|:-----------------------------
23744  * [0] | RW | 0x0 | Selection for RGMII1 signals
23745  * [31:1] | ??? | 0x0 | *UNDEFINED*
23746  *
23747  */
23748 /*
23749  * Field : Selection for RGMII1 signals - sel
23750  *
23751  * Select connection for RGMII1.
23752  *
23753  * 0 : RGMII1 uses HPS Pins.
23754  *
23755  * 1 : RGMII1 uses the FPGA Inteface.
23756  *
23757  * Field Access Macros:
23758  *
23759  */
23760 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL register field. */
23761 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_LSB 0
23762 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL register field. */
23763 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_MSB 0
23764 /* The width in bits of the ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL register field. */
23765 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_WIDTH 1
23766 /* The mask used to set the ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL register field value. */
23767 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_SET_MSK 0x00000001
23768 /* The mask used to clear the ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL register field value. */
23769 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_CLR_MSK 0xfffffffe
23770 /* The reset value of the ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL register field. */
23771 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_RESET 0x0
23772 /* Extracts the ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL field value from a register. */
23773 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
23774 /* Produces a ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL register field value suitable for setting the register. */
23775 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
23776
23777 #ifndef __ASSEMBLY__
23778 /*
23779  * WARNING: The C register and register group struct declarations are provided for
23780  * convenience and illustrative purposes. They should, however, be used with
23781  * caution as the C language standard provides no guarantees about the alignment or
23782  * atomicity of device memory accesses. The recommended practice for writing
23783  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23784  * alt_write_word() functions.
23785  *
23786  * The struct declaration for register ALT_SYSMGR_PINMUX_RGMII1USEFPGA.
23787  */
23789 {
23790  uint32_t sel : 1; /* Selection for RGMII1 signals */
23791  uint32_t : 31; /* *UNDEFINED* */
23792 };
23793
23794 /* The typedef declaration for register ALT_SYSMGR_PINMUX_RGMII1USEFPGA. */
23795 typedef volatile struct ALT_SYSMGR_PINMUX_RGMII1USEFPGA_s ALT_SYSMGR_PINMUX_RGMII1USEFPGA_t;
23796 #endif /* __ASSEMBLY__ */
23797
23798 /* The byte offset of the ALT_SYSMGR_PINMUX_RGMII1USEFPGA register from the beginning of the component. */
23799 #define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_OFST 0x2f8
23800
23801 /*
23802  * Register : Select source for I2C0 signals (HPS Pins or FPGA Interface) - I2C0USEFPGA
23803  *
23804  * Selection between HPS Pins and FPGA Interface for I2C0 signals.
23805  *
23806  * Only reset by a cold reset (ignores warm reset).
23807  *
23808  * NOTE: These registers should not be modified after IO configuration.There is no
23809  * support for dynamically changing the Pin Mux selections.
23810  *
23811  * Register Layout
23812  *
23813  * Bits | Access | Reset | Description
23814  * :-------|:-------|:------|:---------------------------
23815  * [0] | RW | 0x0 | Selection for I2C0 signals
23816  * [31:1] | ??? | 0x0 | *UNDEFINED*
23817  *
23818  */
23819 /*
23820  * Field : Selection for I2C0 signals - sel
23821  *
23822  * Select connection for I2C0.
23823  *
23824  * 0 : I2C0 uses HPS Pins.
23825  *
23826  * 1 : I2C0 uses the FPGA Inteface.
23827  *
23828  * Field Access Macros:
23829  *
23830  */
23831 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL register field. */
23832 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_LSB 0
23833 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL register field. */
23834 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_MSB 0
23835 /* The width in bits of the ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL register field. */
23836 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_WIDTH 1
23837 /* The mask used to set the ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL register field value. */
23838 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_SET_MSK 0x00000001
23839 /* The mask used to clear the ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL register field value. */
23840 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_CLR_MSK 0xfffffffe
23841 /* The reset value of the ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL register field. */
23842 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_RESET 0x0
23843 /* Extracts the ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL field value from a register. */
23844 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
23845 /* Produces a ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL register field value suitable for setting the register. */
23846 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
23847
23848 #ifndef __ASSEMBLY__
23849 /*
23850  * WARNING: The C register and register group struct declarations are provided for
23851  * convenience and illustrative purposes. They should, however, be used with
23852  * caution as the C language standard provides no guarantees about the alignment or
23853  * atomicity of device memory accesses. The recommended practice for writing
23854  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23855  * alt_write_word() functions.
23856  *
23857  * The struct declaration for register ALT_SYSMGR_PINMUX_I2C0USEFPGA.
23858  */
23860 {
23861  uint32_t sel : 1; /* Selection for I2C0 signals */
23862  uint32_t : 31; /* *UNDEFINED* */
23863 };
23864
23865 /* The typedef declaration for register ALT_SYSMGR_PINMUX_I2C0USEFPGA. */
23866 typedef volatile struct ALT_SYSMGR_PINMUX_I2C0USEFPGA_s ALT_SYSMGR_PINMUX_I2C0USEFPGA_t;
23867 #endif /* __ASSEMBLY__ */
23868
23869 /* The byte offset of the ALT_SYSMGR_PINMUX_I2C0USEFPGA register from the beginning of the component. */
23870 #define ALT_SYSMGR_PINMUX_I2C0USEFPGA_OFST 0x304
23871
23872 /*
23873  * Register : Select source for RGMII0 signals (HPS Pins or FPGA Interface) - RGMII0USEFPGA
23874  *
23875  * Selection between HPS Pins and FPGA Interface for RGMII0 signals.
23876  *
23877  * Only reset by a cold reset (ignores warm reset).
23878  *
23879  * NOTE: These registers should not be modified after IO configuration.There is no
23880  * support for dynamically changing the Pin Mux selections.
23881  *
23882  * Register Layout
23883  *
23884  * Bits | Access | Reset | Description
23885  * :-------|:-------|:------|:-----------------------------
23886  * [0] | RW | 0x0 | Selection for RGMII0 signals
23887  * [31:1] | ??? | 0x0 | *UNDEFINED*
23888  *
23889  */
23890 /*
23891  * Field : Selection for RGMII0 signals - sel
23892  *
23893  * Select connection for RGMII0.
23894  *
23895  * 0 : RGMII0 uses HPS Pins.
23896  *
23897  * 1 : RGMII0 uses the FPGA Inteface.
23898  *
23899  * Field Access Macros:
23900  *
23901  */
23902 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL register field. */
23903 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_LSB 0
23904 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL register field. */
23905 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_MSB 0
23906 /* The width in bits of the ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL register field. */
23907 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_WIDTH 1
23908 /* The mask used to set the ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL register field value. */
23909 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_SET_MSK 0x00000001
23910 /* The mask used to clear the ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL register field value. */
23911 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_CLR_MSK 0xfffffffe
23912 /* The reset value of the ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL register field. */
23913 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_RESET 0x0
23914 /* Extracts the ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL field value from a register. */
23915 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
23916 /* Produces a ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL register field value suitable for setting the register. */
23917 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
23918
23919 #ifndef __ASSEMBLY__
23920 /*
23921  * WARNING: The C register and register group struct declarations are provided for
23922  * convenience and illustrative purposes. They should, however, be used with
23923  * caution as the C language standard provides no guarantees about the alignment or
23924  * atomicity of device memory accesses. The recommended practice for writing
23925  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23926  * alt_write_word() functions.
23927  *
23928  * The struct declaration for register ALT_SYSMGR_PINMUX_RGMII0USEFPGA.
23929  */
23931 {
23932  uint32_t sel : 1; /* Selection for RGMII0 signals */
23933  uint32_t : 31; /* *UNDEFINED* */
23934 };
23935
23936 /* The typedef declaration for register ALT_SYSMGR_PINMUX_RGMII0USEFPGA. */
23937 typedef volatile struct ALT_SYSMGR_PINMUX_RGMII0USEFPGA_s ALT_SYSMGR_PINMUX_RGMII0USEFPGA_t;
23938 #endif /* __ASSEMBLY__ */
23939
23940 /* The byte offset of the ALT_SYSMGR_PINMUX_RGMII0USEFPGA register from the beginning of the component. */
23941 #define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_OFST 0x314
23942
23943 /*
23944  * Register : Select source for I2C3 signals (HPS Pins or FPGA Interface) - I2C3USEFPGA
23945  *
23946  * Selection between HPS Pins and FPGA Interface for I2C3 signals.
23947  *
23948  * Only reset by a cold reset (ignores warm reset).
23949  *
23950  * NOTE: These registers should not be modified after IO configuration.There is no
23951  * support for dynamically changing the Pin Mux selections.
23952  *
23953  * Register Layout
23954  *
23955  * Bits | Access | Reset | Description
23956  * :-------|:-------|:------|:---------------------------
23957  * [0] | RW | 0x0 | Selection for I2C3 signals
23958  * [31:1] | ??? | 0x0 | *UNDEFINED*
23959  *
23960  */
23961 /*
23962  * Field : Selection for I2C3 signals - sel
23963  *
23964  * Select connection for I2C3.
23965  *
23966  * 0 : I2C3 uses HPS Pins.
23967  *
23968  * 1 : I2C3 uses the FPGA Inteface.
23969  *
23970  * Field Access Macros:
23971  *
23972  */
23973 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL register field. */
23974 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_LSB 0
23975 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL register field. */
23976 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_MSB 0
23977 /* The width in bits of the ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL register field. */
23978 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_WIDTH 1
23979 /* The mask used to set the ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL register field value. */
23980 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_SET_MSK 0x00000001
23981 /* The mask used to clear the ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL register field value. */
23982 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_CLR_MSK 0xfffffffe
23983 /* The reset value of the ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL register field. */
23984 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_RESET 0x0
23985 /* Extracts the ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL field value from a register. */
23986 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
23987 /* Produces a ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL register field value suitable for setting the register. */
23988 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
23989
23990 #ifndef __ASSEMBLY__
23991 /*
23992  * WARNING: The C register and register group struct declarations are provided for
23993  * convenience and illustrative purposes. They should, however, be used with
23994  * caution as the C language standard provides no guarantees about the alignment or
23995  * atomicity of device memory accesses. The recommended practice for writing
23996  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
23997  * alt_write_word() functions.
23998  *
23999  * The struct declaration for register ALT_SYSMGR_PINMUX_I2C3USEFPGA.
24000  */
24002 {
24003  uint32_t sel : 1; /* Selection for I2C3 signals */
24004  uint32_t : 31; /* *UNDEFINED* */
24005 };
24006
24007 /* The typedef declaration for register ALT_SYSMGR_PINMUX_I2C3USEFPGA. */
24008 typedef volatile struct ALT_SYSMGR_PINMUX_I2C3USEFPGA_s ALT_SYSMGR_PINMUX_I2C3USEFPGA_t;
24009 #endif /* __ASSEMBLY__ */
24010
24011 /* The byte offset of the ALT_SYSMGR_PINMUX_I2C3USEFPGA register from the beginning of the component. */
24012 #define ALT_SYSMGR_PINMUX_I2C3USEFPGA_OFST 0x324
24013
24014 /*
24015  * Register : Select source for I2C2 signals (HPS Pins or FPGA Interface) - I2C2USEFPGA
24016  *
24017  * Selection between HPS Pins and FPGA Interface for I2C2 signals.
24018  *
24019  * Only reset by a cold reset (ignores warm reset).
24020  *
24021  * NOTE: These registers should not be modified after IO configuration.There is no
24022  * support for dynamically changing the Pin Mux selections.
24023  *
24024  * Register Layout
24025  *
24026  * Bits | Access | Reset | Description
24027  * :-------|:-------|:------|:---------------------------
24028  * [0] | RW | 0x0 | Selection for I2C2 signals
24029  * [31:1] | ??? | 0x0 | *UNDEFINED*
24030  *
24031  */
24032 /*
24033  * Field : Selection for I2C2 signals - sel
24034  *
24035  * Select connection for I2C2.
24036  *
24037  * 0 : I2C2 uses HPS Pins.
24038  *
24039  * 1 : I2C2 uses the FPGA Inteface.
24040  *
24041  * Field Access Macros:
24042  *
24043  */
24044 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL register field. */
24045 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_LSB 0
24046 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL register field. */
24047 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_MSB 0
24048 /* The width in bits of the ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL register field. */
24049 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_WIDTH 1
24050 /* The mask used to set the ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL register field value. */
24051 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_SET_MSK 0x00000001
24052 /* The mask used to clear the ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL register field value. */
24053 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_CLR_MSK 0xfffffffe
24054 /* The reset value of the ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL register field. */
24055 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_RESET 0x0
24056 /* Extracts the ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL field value from a register. */
24057 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
24058 /* Produces a ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL register field value suitable for setting the register. */
24059 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
24060
24061 #ifndef __ASSEMBLY__
24062 /*
24063  * WARNING: The C register and register group struct declarations are provided for
24064  * convenience and illustrative purposes. They should, however, be used with
24065  * caution as the C language standard provides no guarantees about the alignment or
24066  * atomicity of device memory accesses. The recommended practice for writing
24067  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
24068  * alt_write_word() functions.
24069  *
24070  * The struct declaration for register ALT_SYSMGR_PINMUX_I2C2USEFPGA.
24071  */
24073 {
24074  uint32_t sel : 1; /* Selection for I2C2 signals */
24075  uint32_t : 31; /* *UNDEFINED* */
24076 };
24077
24078 /* The typedef declaration for register ALT_SYSMGR_PINMUX_I2C2USEFPGA. */
24079 typedef volatile struct ALT_SYSMGR_PINMUX_I2C2USEFPGA_s ALT_SYSMGR_PINMUX_I2C2USEFPGA_t;
24080 #endif /* __ASSEMBLY__ */
24081
24082 /* The byte offset of the ALT_SYSMGR_PINMUX_I2C2USEFPGA register from the beginning of the component. */
24083 #define ALT_SYSMGR_PINMUX_I2C2USEFPGA_OFST 0x328
24084
24085 /*
24086  * Register : Select source for I2C1 signals (HPS Pins or FPGA Interface) - I2C1USEFPGA
24087  *
24088  * Selection between HPS Pins and FPGA Interface for I2C1 signals.
24089  *
24090  * Only reset by a cold reset (ignores warm reset).
24091  *
24092  * NOTE: These registers should not be modified after IO configuration.There is no
24093  * support for dynamically changing the Pin Mux selections.
24094  *
24095  * Register Layout
24096  *
24097  * Bits | Access | Reset | Description
24098  * :-------|:-------|:------|:---------------------------
24099  * [0] | RW | 0x0 | Selection for I2C1 signals
24100  * [31:1] | ??? | 0x0 | *UNDEFINED*
24101  *
24102  */
24103 /*
24104  * Field : Selection for I2C1 signals - sel
24105  *
24106  * Select connection for I2C1.
24107  *
24108  * 0 : I2C1 uses HPS Pins.
24109  *
24110  * 1 : I2C1 uses the FPGA Inteface.
24111  *
24112  * Field Access Macros:
24113  *
24114  */
24115 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL register field. */
24116 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_LSB 0
24117 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL register field. */
24118 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_MSB 0
24119 /* The width in bits of the ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL register field. */
24120 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_WIDTH 1
24121 /* The mask used to set the ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL register field value. */
24122 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_SET_MSK 0x00000001
24123 /* The mask used to clear the ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL register field value. */
24124 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_CLR_MSK 0xfffffffe
24125 /* The reset value of the ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL register field. */
24126 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_RESET 0x0
24127 /* Extracts the ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL field value from a register. */
24128 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
24129 /* Produces a ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL register field value suitable for setting the register. */
24130 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
24131
24132 #ifndef __ASSEMBLY__
24133 /*
24134  * WARNING: The C register and register group struct declarations are provided for
24135  * convenience and illustrative purposes. They should, however, be used with
24136  * caution as the C language standard provides no guarantees about the alignment or
24137  * atomicity of device memory accesses. The recommended practice for writing
24138  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
24139  * alt_write_word() functions.
24140  *
24141  * The struct declaration for register ALT_SYSMGR_PINMUX_I2C1USEFPGA.
24142  */
24144 {
24145  uint32_t sel : 1; /* Selection for I2C1 signals */
24146  uint32_t : 31; /* *UNDEFINED* */
24147 };
24148
24149 /* The typedef declaration for register ALT_SYSMGR_PINMUX_I2C1USEFPGA. */
24150 typedef volatile struct ALT_SYSMGR_PINMUX_I2C1USEFPGA_s ALT_SYSMGR_PINMUX_I2C1USEFPGA_t;
24151 #endif /* __ASSEMBLY__ */
24152
24153 /* The byte offset of the ALT_SYSMGR_PINMUX_I2C1USEFPGA register from the beginning of the component. */
24154 #define ALT_SYSMGR_PINMUX_I2C1USEFPGA_OFST 0x32c
24155
24156 /*
24157  * Register : Select source for SPIM1 signals (HPS Pins or FPGA Interface) - SPIM1USEFPGA
24158  *
24159  * Selection between HPS Pins and FPGA Interface for SPIM1 signals.
24160  *
24161  * Only reset by a cold reset (ignores warm reset).
24162  *
24163  * NOTE: These registers should not be modified after IO configuration.There is no
24164  * support for dynamically changing the Pin Mux selections.
24165  *
24166  * Register Layout
24167  *
24168  * Bits | Access | Reset | Description
24169  * :-------|:-------|:------|:----------------------------
24170  * [0] | RW | 0x0 | Selection for SPIM1 signals
24171  * [31:1] | ??? | 0x0 | *UNDEFINED*
24172  *
24173  */
24174 /*
24175  * Field : Selection for SPIM1 signals - sel
24176  *
24177  * Select connection for SPIM1.
24178  *
24179  * 0 : SPIM1 uses HPS Pins.
24180  *
24181  * 1 : SPIM1 uses the FPGA Inteface.
24182  *
24183  * Field Access Macros:
24184  *
24185  */
24186 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL register field. */
24187 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_LSB 0
24188 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL register field. */
24189 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_MSB 0
24190 /* The width in bits of the ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL register field. */
24191 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_WIDTH 1
24192 /* The mask used to set the ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL register field value. */
24193 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_SET_MSK 0x00000001
24194 /* The mask used to clear the ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL register field value. */
24195 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_CLR_MSK 0xfffffffe
24196 /* The reset value of the ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL register field. */
24197 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_RESET 0x0
24198 /* Extracts the ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL field value from a register. */
24199 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
24200 /* Produces a ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL register field value suitable for setting the register. */
24201 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
24202
24203 #ifndef __ASSEMBLY__
24204 /*
24205  * WARNING: The C register and register group struct declarations are provided for
24206  * convenience and illustrative purposes. They should, however, be used with
24207  * caution as the C language standard provides no guarantees about the alignment or
24208  * atomicity of device memory accesses. The recommended practice for writing
24209  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
24210  * alt_write_word() functions.
24211  *
24212  * The struct declaration for register ALT_SYSMGR_PINMUX_SPIM1USEFPGA.
24213  */
24215 {
24216  uint32_t sel : 1; /* Selection for SPIM1 signals */
24217  uint32_t : 31; /* *UNDEFINED* */
24218 };
24219
24220 /* The typedef declaration for register ALT_SYSMGR_PINMUX_SPIM1USEFPGA. */
24221 typedef volatile struct ALT_SYSMGR_PINMUX_SPIM1USEFPGA_s ALT_SYSMGR_PINMUX_SPIM1USEFPGA_t;
24222 #endif /* __ASSEMBLY__ */
24223
24224 /* The byte offset of the ALT_SYSMGR_PINMUX_SPIM1USEFPGA register from the beginning of the component. */
24225 #define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_OFST 0x330
24226
24227 /*
24228  * Register : Select source for SPIM0 signals (HPS Pins or FPGA Interface) - SPIM0USEFPGA
24229  *
24230  * Selection between HPS Pins and FPGA Interface for SPIM0 signals.
24231  *
24232  * Only reset by a cold reset (ignores warm reset).
24233  *
24234  * NOTE: These registers should not be modified after IO configuration.There is no
24235  * support for dynamically changing the Pin Mux selections.
24236  *
24237  * Register Layout
24238  *
24239  * Bits | Access | Reset | Description
24240  * :-------|:-------|:------|:----------------------------
24241  * [0] | RW | 0x0 | Selection for SPIM0 signals
24242  * [31:1] | ??? | 0x0 | *UNDEFINED*
24243  *
24244  */
24245 /*
24246  * Field : Selection for SPIM0 signals - sel
24247  *
24248  * Select connection for SPIM0.
24249  *
24250  * 0 : SPIM0 uses HPS Pins.
24251  *
24252  * 1 : SPIM0 uses the FPGA Inteface.
24253  *
24254  * Field Access Macros:
24255  *
24256  */
24257 /* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL register field. */
24258 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_LSB 0
24259 /* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL register field. */
24260 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_MSB 0
24261 /* The width in bits of the ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL register field. */
24262 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_WIDTH 1
24263 /* The mask used to set the ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL register field value. */
24264 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_SET_MSK 0x00000001
24265 /* The mask used to clear the ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL register field value. */
24266 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_CLR_MSK 0xfffffffe
24267 /* The reset value of the ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL register field. */
24268 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_RESET 0x0
24269 /* Extracts the ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL field value from a register. */
24270 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_GET(value) (((value) & 0x00000001) >> 0)
24271 /* Produces a ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL register field value suitable for setting the register. */
24272 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_SEL_SET(value) (((value) << 0) & 0x00000001)
24273
24274 #ifndef __ASSEMBLY__
24275 /*
24276  * WARNING: The C register and register group struct declarations are provided for
24277  * convenience and illustrative purposes. They should, however, be used with
24278  * caution as the C language standard provides no guarantees about the alignment or
24279  * atomicity of device memory accesses. The recommended practice for writing
24280  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
24281  * alt_write_word() functions.
24282  *
24283  * The struct declaration for register ALT_SYSMGR_PINMUX_SPIM0USEFPGA.
24284  */
24286 {
24287  uint32_t sel : 1; /* Selection for SPIM0 signals */
24288  uint32_t : 31; /* *UNDEFINED* */
24289 };
24290
24291 /* The typedef declaration for register ALT_SYSMGR_PINMUX_SPIM0USEFPGA. */
24292 typedef volatile struct ALT_SYSMGR_PINMUX_SPIM0USEFPGA_s ALT_SYSMGR_PINMUX_SPIM0USEFPGA_t;
24293 #endif /* __ASSEMBLY__ */
24294
24295 /* The byte offset of the ALT_SYSMGR_PINMUX_SPIM0USEFPGA register from the beginning of the component. */
24296 #define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_OFST 0x338
24297
24298 #ifndef __ASSEMBLY__
24299 /*
24300  * WARNING: The C register and register group struct declarations are provided for
24301  * convenience and illustrative purposes. They should, however, be used with
24302  * caution as the C language standard provides no guarantees about the alignment or
24303  * atomicity of device memory accesses. The recommended practice for writing
24304  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
24305  * alt_write_word() functions.
24306  *
24307  * The struct declaration for register group ALT_SYSMGR_PINMUX.
24308  */
24310 {
24311  volatile ALT_SYSMGR_PINMUX_EMACIO0_t EMACIO0; /* ALT_SYSMGR_PINMUX_EMACIO0 */
24312  volatile ALT_SYSMGR_PINMUX_EMACIO1_t EMACIO1; /* ALT_SYSMGR_PINMUX_EMACIO1 */
24313  volatile ALT_SYSMGR_PINMUX_EMACIO2_t EMACIO2; /* ALT_SYSMGR_PINMUX_EMACIO2 */
24314  volatile ALT_SYSMGR_PINMUX_EMACIO3_t EMACIO3; /* ALT_SYSMGR_PINMUX_EMACIO3 */
24315  volatile ALT_SYSMGR_PINMUX_EMACIO4_t EMACIO4; /* ALT_SYSMGR_PINMUX_EMACIO4 */
24316  volatile ALT_SYSMGR_PINMUX_EMACIO5_t EMACIO5; /* ALT_SYSMGR_PINMUX_EMACIO5 */
24317  volatile ALT_SYSMGR_PINMUX_EMACIO6_t EMACIO6; /* ALT_SYSMGR_PINMUX_EMACIO6 */
24318  volatile ALT_SYSMGR_PINMUX_EMACIO7_t EMACIO7; /* ALT_SYSMGR_PINMUX_EMACIO7 */
24319  volatile ALT_SYSMGR_PINMUX_EMACIO8_t EMACIO8; /* ALT_SYSMGR_PINMUX_EMACIO8 */
24320  volatile ALT_SYSMGR_PINMUX_EMACIO9_t EMACIO9; /* ALT_SYSMGR_PINMUX_EMACIO9 */
24321  volatile ALT_SYSMGR_PINMUX_EMACIO10_t EMACIO10; /* ALT_SYSMGR_PINMUX_EMACIO10 */
24322  volatile ALT_SYSMGR_PINMUX_EMACIO11_t EMACIO11; /* ALT_SYSMGR_PINMUX_EMACIO11 */
24323  volatile ALT_SYSMGR_PINMUX_EMACIO12_t EMACIO12; /* ALT_SYSMGR_PINMUX_EMACIO12 */
24324  volatile ALT_SYSMGR_PINMUX_EMACIO13_t EMACIO13; /* ALT_SYSMGR_PINMUX_EMACIO13 */
24325  volatile ALT_SYSMGR_PINMUX_EMACIO14_t EMACIO14; /* ALT_SYSMGR_PINMUX_EMACIO14 */
24326  volatile ALT_SYSMGR_PINMUX_EMACIO15_t EMACIO15; /* ALT_SYSMGR_PINMUX_EMACIO15 */
24327  volatile ALT_SYSMGR_PINMUX_EMACIO16_t EMACIO16; /* ALT_SYSMGR_PINMUX_EMACIO16 */
24328  volatile ALT_SYSMGR_PINMUX_EMACIO17_t EMACIO17; /* ALT_SYSMGR_PINMUX_EMACIO17 */
24329  volatile ALT_SYSMGR_PINMUX_EMACIO18_t EMACIO18; /* ALT_SYSMGR_PINMUX_EMACIO18 */
24330  volatile ALT_SYSMGR_PINMUX_EMACIO19_t EMACIO19; /* ALT_SYSMGR_PINMUX_EMACIO19 */
24331  volatile ALT_SYSMGR_PINMUX_FLSHIO0_t FLASHIO0; /* ALT_SYSMGR_PINMUX_FLSHIO0 */
24332  volatile ALT_SYSMGR_PINMUX_FLSHIO1_t FLASHIO1; /* ALT_SYSMGR_PINMUX_FLSHIO1 */
24333  volatile ALT_SYSMGR_PINMUX_FLSHIO2_t FLASHIO2; /* ALT_SYSMGR_PINMUX_FLSHIO2 */
24334  volatile ALT_SYSMGR_PINMUX_FLSHIO3_t FLASHIO3; /* ALT_SYSMGR_PINMUX_FLSHIO3 */
24335  volatile ALT_SYSMGR_PINMUX_FLSHIO4_t FLASHIO4; /* ALT_SYSMGR_PINMUX_FLSHIO4 */
24336  volatile ALT_SYSMGR_PINMUX_FLSHIO5_t FLASHIO5; /* ALT_SYSMGR_PINMUX_FLSHIO5 */
24337  volatile ALT_SYSMGR_PINMUX_FLSHIO6_t FLASHIO6; /* ALT_SYSMGR_PINMUX_FLSHIO6 */
24338  volatile ALT_SYSMGR_PINMUX_FLSHIO7_t FLASHIO7; /* ALT_SYSMGR_PINMUX_FLSHIO7 */
24339  volatile ALT_SYSMGR_PINMUX_FLSHIO8_t FLASHIO8; /* ALT_SYSMGR_PINMUX_FLSHIO8 */
24340  volatile ALT_SYSMGR_PINMUX_FLSHIO9_t FLASHIO9; /* ALT_SYSMGR_PINMUX_FLSHIO9 */
24341  volatile ALT_SYSMGR_PINMUX_FLSHIO10_t FLASHIO10; /* ALT_SYSMGR_PINMUX_FLSHIO10 */
24342  volatile ALT_SYSMGR_PINMUX_FLSHIO11_t FLASHIO11; /* ALT_SYSMGR_PINMUX_FLSHIO11 */
24343  volatile ALT_SYSMGR_PINMUX_GENERALIO0_t GENERALIO0; /* ALT_SYSMGR_PINMUX_GENERALIO0 */
24344  volatile ALT_SYSMGR_PINMUX_GENERALIO1_t GENERALIO1; /* ALT_SYSMGR_PINMUX_GENERALIO1 */
24345  volatile ALT_SYSMGR_PINMUX_GENERALIO2_t GENERALIO2; /* ALT_SYSMGR_PINMUX_GENERALIO2 */
24346  volatile ALT_SYSMGR_PINMUX_GENERALIO3_t GENERALIO3; /* ALT_SYSMGR_PINMUX_GENERALIO3 */
24347  volatile ALT_SYSMGR_PINMUX_GENERALIO4_t GENERALIO4; /* ALT_SYSMGR_PINMUX_GENERALIO4 */
24348  volatile ALT_SYSMGR_PINMUX_GENERALIO5_t GENERALIO5; /* ALT_SYSMGR_PINMUX_GENERALIO5 */
24349  volatile ALT_SYSMGR_PINMUX_GENERALIO6_t GENERALIO6; /* ALT_SYSMGR_PINMUX_GENERALIO6 */
24350  volatile ALT_SYSMGR_PINMUX_GENERALIO7_t GENERALIO7; /* ALT_SYSMGR_PINMUX_GENERALIO7 */
24351  volatile ALT_SYSMGR_PINMUX_GENERALIO8_t GENERALIO8; /* ALT_SYSMGR_PINMUX_GENERALIO8 */
24352  volatile ALT_SYSMGR_PINMUX_GENERALIO9_t GENERALIO9; /* ALT_SYSMGR_PINMUX_GENERALIO9 */
24353  volatile ALT_SYSMGR_PINMUX_GENERALIO10_t GENERALIO10; /* ALT_SYSMGR_PINMUX_GENERALIO10 */
24354  volatile ALT_SYSMGR_PINMUX_GENERALIO11_t GENERALIO11; /* ALT_SYSMGR_PINMUX_GENERALIO11 */
24355  volatile ALT_SYSMGR_PINMUX_GENERALIO12_t GENERALIO12; /* ALT_SYSMGR_PINMUX_GENERALIO12 */
24356  volatile ALT_SYSMGR_PINMUX_GENERALIO13_t GENERALIO13; /* ALT_SYSMGR_PINMUX_GENERALIO13 */
24357  volatile ALT_SYSMGR_PINMUX_GENERALIO14_t GENERALIO14; /* ALT_SYSMGR_PINMUX_GENERALIO14 */
24358  volatile ALT_SYSMGR_PINMUX_GENERALIO15_t GENERALIO15; /* ALT_SYSMGR_PINMUX_GENERALIO15 */
24359  volatile ALT_SYSMGR_PINMUX_GENERALIO16_t GENERALIO16; /* ALT_SYSMGR_PINMUX_GENERALIO16 */
24360  volatile ALT_SYSMGR_PINMUX_GENERALIO17_t GENERALIO17; /* ALT_SYSMGR_PINMUX_GENERALIO17 */
24361  volatile ALT_SYSMGR_PINMUX_GENERALIO18_t GENERALIO18; /* ALT_SYSMGR_PINMUX_GENERALIO18 */
24362  volatile ALT_SYSMGR_PINMUX_GENERALIO19_t GENERALIO19; /* ALT_SYSMGR_PINMUX_GENERALIO19 */
24363  volatile ALT_SYSMGR_PINMUX_GENERALIO20_t GENERALIO20; /* ALT_SYSMGR_PINMUX_GENERALIO20 */
24364  volatile ALT_SYSMGR_PINMUX_GENERALIO21_t GENERALIO21; /* ALT_SYSMGR_PINMUX_GENERALIO21 */
24365  volatile ALT_SYSMGR_PINMUX_GENERALIO22_t GENERALIO22; /* ALT_SYSMGR_PINMUX_GENERALIO22 */
24366  volatile ALT_SYSMGR_PINMUX_GENERALIO23_t GENERALIO23; /* ALT_SYSMGR_PINMUX_GENERALIO23 */
24367  volatile ALT_SYSMGR_PINMUX_GENERALIO24_t GENERALIO24; /* ALT_SYSMGR_PINMUX_GENERALIO24 */
24368  volatile ALT_SYSMGR_PINMUX_GENERALIO25_t GENERALIO25; /* ALT_SYSMGR_PINMUX_GENERALIO25 */
24369  volatile ALT_SYSMGR_PINMUX_GENERALIO26_t GENERALIO26; /* ALT_SYSMGR_PINMUX_GENERALIO26 */
24370  volatile ALT_SYSMGR_PINMUX_GENERALIO27_t GENERALIO27; /* ALT_SYSMGR_PINMUX_GENERALIO27 */
24371  volatile ALT_SYSMGR_PINMUX_GENERALIO28_t GENERALIO28; /* ALT_SYSMGR_PINMUX_GENERALIO28 */
24372  volatile ALT_SYSMGR_PINMUX_GENERALIO29_t GENERALIO29; /* ALT_SYSMGR_PINMUX_GENERALIO29 */
24373  volatile ALT_SYSMGR_PINMUX_GENERALIO30_t GENERALIO30; /* ALT_SYSMGR_PINMUX_GENERALIO30 */
24374  volatile ALT_SYSMGR_PINMUX_GENERALIO31_t GENERALIO31; /* ALT_SYSMGR_PINMUX_GENERALIO31 */
24375  volatile ALT_SYSMGR_PINMUX_MIXED1IO0_t MIXED1IO0; /* ALT_SYSMGR_PINMUX_MIXED1IO0 */
24376  volatile ALT_SYSMGR_PINMUX_MIXED1IO1_t MIXED1IO1; /* ALT_SYSMGR_PINMUX_MIXED1IO1 */
24377  volatile ALT_SYSMGR_PINMUX_MIXED1IO2_t MIXED1IO2; /* ALT_SYSMGR_PINMUX_MIXED1IO2 */
24378  volatile ALT_SYSMGR_PINMUX_MIXED1IO3_t MIXED1IO3; /* ALT_SYSMGR_PINMUX_MIXED1IO3 */
24379  volatile ALT_SYSMGR_PINMUX_MIXED1IO4_t MIXED1IO4; /* ALT_SYSMGR_PINMUX_MIXED1IO4 */
24380  volatile ALT_SYSMGR_PINMUX_MIXED1IO5_t MIXED1IO5; /* ALT_SYSMGR_PINMUX_MIXED1IO5 */
24381  volatile ALT_SYSMGR_PINMUX_MIXED1IO6_t MIXED1IO6; /* ALT_SYSMGR_PINMUX_MIXED1IO6 */
24382  volatile ALT_SYSMGR_PINMUX_MIXED1IO7_t MIXED1IO7; /* ALT_SYSMGR_PINMUX_MIXED1IO7 */
24383  volatile ALT_SYSMGR_PINMUX_MIXED1IO8_t MIXED1IO8; /* ALT_SYSMGR_PINMUX_MIXED1IO8 */
24384  volatile ALT_SYSMGR_PINMUX_MIXED1IO9_t MIXED1IO9; /* ALT_SYSMGR_PINMUX_MIXED1IO9 */
24385  volatile ALT_SYSMGR_PINMUX_MIXED1IO10_t MIXED1IO10; /* ALT_SYSMGR_PINMUX_MIXED1IO10 */
24386  volatile ALT_SYSMGR_PINMUX_MIXED1IO11_t MIXED1IO11; /* ALT_SYSMGR_PINMUX_MIXED1IO11 */
24387  volatile ALT_SYSMGR_PINMUX_MIXED1IO12_t MIXED1IO12; /* ALT_SYSMGR_PINMUX_MIXED1IO12 */
24388  volatile ALT_SYSMGR_PINMUX_MIXED1IO13_t MIXED1IO13; /* ALT_SYSMGR_PINMUX_MIXED1IO13 */
24389  volatile ALT_SYSMGR_PINMUX_MIXED1IO14_t MIXED1IO14; /* ALT_SYSMGR_PINMUX_MIXED1IO14 */
24390  volatile ALT_SYSMGR_PINMUX_MIXED1IO15_t MIXED1IO15; /* ALT_SYSMGR_PINMUX_MIXED1IO15 */
24391  volatile ALT_SYSMGR_PINMUX_MIXED1IO16_t MIXED1IO16; /* ALT_SYSMGR_PINMUX_MIXED1IO16 */
24392  volatile ALT_SYSMGR_PINMUX_MIXED1IO17_t MIXED1IO17; /* ALT_SYSMGR_PINMUX_MIXED1IO17 */
24393  volatile ALT_SYSMGR_PINMUX_MIXED1IO18_t MIXED1IO18; /* ALT_SYSMGR_PINMUX_MIXED1IO18 */
24394  volatile ALT_SYSMGR_PINMUX_MIXED1IO19_t MIXED1IO19; /* ALT_SYSMGR_PINMUX_MIXED1IO19 */
24395  volatile ALT_SYSMGR_PINMUX_MIXED1IO20_t MIXED1IO20; /* ALT_SYSMGR_PINMUX_MIXED1IO20 */
24396  volatile ALT_SYSMGR_PINMUX_MIXED1IO21_t MIXED1IO21; /* ALT_SYSMGR_PINMUX_MIXED1IO21 */
24397  volatile ALT_SYSMGR_PINMUX_MIXED2IO0_t MIXED2IO0; /* ALT_SYSMGR_PINMUX_MIXED2IO0 */
24398  volatile ALT_SYSMGR_PINMUX_MIXED2IO1_t MIXED2IO1; /* ALT_SYSMGR_PINMUX_MIXED2IO1 */
24399  volatile ALT_SYSMGR_PINMUX_MIXED2IO2_t MIXED2IO2; /* ALT_SYSMGR_PINMUX_MIXED2IO2 */
24400  volatile ALT_SYSMGR_PINMUX_MIXED2IO3_t MIXED2IO3; /* ALT_SYSMGR_PINMUX_MIXED2IO3 */
24401  volatile ALT_SYSMGR_PINMUX_MIXED2IO4_t MIXED2IO4; /* ALT_SYSMGR_PINMUX_MIXED2IO4 */
24402  volatile ALT_SYSMGR_PINMUX_MIXED2IO5_t MIXED2IO5; /* ALT_SYSMGR_PINMUX_MIXED2IO5 */
24403  volatile ALT_SYSMGR_PINMUX_MIXED2IO6_t MIXED2IO6; /* ALT_SYSMGR_PINMUX_MIXED2IO6 */
24404  volatile ALT_SYSMGR_PINMUX_MIXED2IO7_t MIXED2IO7; /* ALT_SYSMGR_PINMUX_MIXED2IO7 */
24405  volatile ALT_SYSMGR_PINMUX_GPLINMUX48_t GPLINMUX48; /* ALT_SYSMGR_PINMUX_GPLINMUX48 */
24406  volatile ALT_SYSMGR_PINMUX_GPLINMUX49_t GPLINMUX49; /* ALT_SYSMGR_PINMUX_GPLINMUX49 */
24407  volatile ALT_SYSMGR_PINMUX_GPLINMUX50_t GPLINMUX50; /* ALT_SYSMGR_PINMUX_GPLINMUX50 */
24408  volatile ALT_SYSMGR_PINMUX_GPLINMUX51_t GPLINMUX51; /* ALT_SYSMGR_PINMUX_GPLINMUX51 */
24409  volatile ALT_SYSMGR_PINMUX_GPLINMUX52_t GPLINMUX52; /* ALT_SYSMGR_PINMUX_GPLINMUX52 */
24410  volatile ALT_SYSMGR_PINMUX_GPLINMUX53_t GPLINMUX53; /* ALT_SYSMGR_PINMUX_GPLINMUX53 */
24411  volatile ALT_SYSMGR_PINMUX_GPLINMUX54_t GPLINMUX54; /* ALT_SYSMGR_PINMUX_GPLINMUX54 */
24412  volatile ALT_SYSMGR_PINMUX_GPLINMUX55_t GPLINMUX55; /* ALT_SYSMGR_PINMUX_GPLINMUX55 */
24413  volatile ALT_SYSMGR_PINMUX_GPLINMUX56_t GPLINMUX56; /* ALT_SYSMGR_PINMUX_GPLINMUX56 */
24414  volatile ALT_SYSMGR_PINMUX_GPLINMUX57_t GPLINMUX57; /* ALT_SYSMGR_PINMUX_GPLINMUX57 */
24415  volatile ALT_SYSMGR_PINMUX_GPLINMUX58_t GPLINMUX58; /* ALT_SYSMGR_PINMUX_GPLINMUX58 */
24416  volatile ALT_SYSMGR_PINMUX_GPLINMUX59_t GPLINMUX59; /* ALT_SYSMGR_PINMUX_GPLINMUX59 */
24417  volatile ALT_SYSMGR_PINMUX_GPLINMUX60_t GPLINMUX60; /* ALT_SYSMGR_PINMUX_GPLINMUX60 */
24418  volatile ALT_SYSMGR_PINMUX_GPLINMUX61_t GPLINMUX61; /* ALT_SYSMGR_PINMUX_GPLINMUX61 */
24419  volatile ALT_SYSMGR_PINMUX_GPLINMUX62_t GPLINMUX62; /* ALT_SYSMGR_PINMUX_GPLINMUX62 */
24420  volatile ALT_SYSMGR_PINMUX_GPLINMUX63_t GPLINMUX63; /* ALT_SYSMGR_PINMUX_GPLINMUX63 */
24421  volatile ALT_SYSMGR_PINMUX_GPLINMUX64_t GPLINMUX64; /* ALT_SYSMGR_PINMUX_GPLINMUX64 */
24422  volatile ALT_SYSMGR_PINMUX_GPLINMUX65_t GPLINMUX65; /* ALT_SYSMGR_PINMUX_GPLINMUX65 */
24423  volatile ALT_SYSMGR_PINMUX_GPLINMUX66_t GPLINMUX66; /* ALT_SYSMGR_PINMUX_GPLINMUX66 */
24424  volatile ALT_SYSMGR_PINMUX_GPLINMUX67_t GPLINMUX67; /* ALT_SYSMGR_PINMUX_GPLINMUX67 */
24425  volatile ALT_SYSMGR_PINMUX_GPLINMUX68_t GPLINMUX68; /* ALT_SYSMGR_PINMUX_GPLINMUX68 */
24426  volatile ALT_SYSMGR_PINMUX_GPLINMUX69_t GPLINMUX69; /* ALT_SYSMGR_PINMUX_GPLINMUX69 */
24427  volatile ALT_SYSMGR_PINMUX_GPLINMUX70_t GPLINMUX70; /* ALT_SYSMGR_PINMUX_GPLINMUX70 */
24428  volatile ALT_SYSMGR_PINMUX_GPLMUX0_t GPLMUX0; /* ALT_SYSMGR_PINMUX_GPLMUX0 */
24429  volatile ALT_SYSMGR_PINMUX_GPLMUX1_t GPLMUX1; /* ALT_SYSMGR_PINMUX_GPLMUX1 */
24430  volatile ALT_SYSMGR_PINMUX_GPLMUX2_t GPLMUX2; /* ALT_SYSMGR_PINMUX_GPLMUX2 */
24431  volatile ALT_SYSMGR_PINMUX_GPLMUX3_t GPLMUX3; /* ALT_SYSMGR_PINMUX_GPLMUX3 */
24432  volatile ALT_SYSMGR_PINMUX_GPLMUX4_t GPLMUX4; /* ALT_SYSMGR_PINMUX_GPLMUX4 */
24433  volatile ALT_SYSMGR_PINMUX_GPLMUX5_t GPLMUX5; /* ALT_SYSMGR_PINMUX_GPLMUX5 */
24434  volatile ALT_SYSMGR_PINMUX_GPLMUX6_t GPLMUX6; /* ALT_SYSMGR_PINMUX_GPLMUX6 */
24435  volatile ALT_SYSMGR_PINMUX_GPLMUX7_t GPLMUX7; /* ALT_SYSMGR_PINMUX_GPLMUX7 */
24436  volatile ALT_SYSMGR_PINMUX_GPLMUX8_t GPLMUX8; /* ALT_SYSMGR_PINMUX_GPLMUX8 */
24437  volatile ALT_SYSMGR_PINMUX_GPLMUX9_t GPLMUX9; /* ALT_SYSMGR_PINMUX_GPLMUX9 */
24438  volatile ALT_SYSMGR_PINMUX_GPLMUX10_t GPLMUX10; /* ALT_SYSMGR_PINMUX_GPLMUX10 */
24439  volatile ALT_SYSMGR_PINMUX_GPLMUX11_t GPLMUX11; /* ALT_SYSMGR_PINMUX_GPLMUX11 */
24440  volatile ALT_SYSMGR_PINMUX_GPLMUX12_t GPLMUX12; /* ALT_SYSMGR_PINMUX_GPLMUX12 */
24441  volatile ALT_SYSMGR_PINMUX_GPLMUX13_t GPLMUX13; /* ALT_SYSMGR_PINMUX_GPLMUX13 */
24442  volatile ALT_SYSMGR_PINMUX_GPLMUX14_t GPLMUX14; /* ALT_SYSMGR_PINMUX_GPLMUX14 */
24443  volatile ALT_SYSMGR_PINMUX_GPLMUX15_t GPLMUX15; /* ALT_SYSMGR_PINMUX_GPLMUX15 */
24444  volatile ALT_SYSMGR_PINMUX_GPLMUX16_t GPLMUX16; /* ALT_SYSMGR_PINMUX_GPLMUX16 */
24445  volatile ALT_SYSMGR_PINMUX_GPLMUX17_t GPLMUX17; /* ALT_SYSMGR_PINMUX_GPLMUX17 */
24446  volatile ALT_SYSMGR_PINMUX_GPLMUX18_t GPLMUX18; /* ALT_SYSMGR_PINMUX_GPLMUX18 */
24447  volatile ALT_SYSMGR_PINMUX_GPLMUX19_t GPLMUX19; /* ALT_SYSMGR_PINMUX_GPLMUX19 */
24448  volatile ALT_SYSMGR_PINMUX_GPLMUX20_t GPLMUX20; /* ALT_SYSMGR_PINMUX_GPLMUX20 */
24449  volatile ALT_SYSMGR_PINMUX_GPLMUX21_t GPLMUX21; /* ALT_SYSMGR_PINMUX_GPLMUX21 */
24450  volatile ALT_SYSMGR_PINMUX_GPLMUX22_t GPLMUX22; /* ALT_SYSMGR_PINMUX_GPLMUX22 */
24451  volatile ALT_SYSMGR_PINMUX_GPLMUX23_t GPLMUX23; /* ALT_SYSMGR_PINMUX_GPLMUX23 */
24452  volatile ALT_SYSMGR_PINMUX_GPLMUX24_t GPLMUX24; /* ALT_SYSMGR_PINMUX_GPLMUX24 */
24453  volatile ALT_SYSMGR_PINMUX_GPLMUX25_t GPLMUX25; /* ALT_SYSMGR_PINMUX_GPLMUX25 */
24454  volatile ALT_SYSMGR_PINMUX_GPLMUX26_t GPLMUX26; /* ALT_SYSMGR_PINMUX_GPLMUX26 */
24455  volatile ALT_SYSMGR_PINMUX_GPLMUX27_t GPLMUX27; /* ALT_SYSMGR_PINMUX_GPLMUX27 */
24456  volatile ALT_SYSMGR_PINMUX_GPLMUX28_t GPLMUX28; /* ALT_SYSMGR_PINMUX_GPLMUX28 */
24457  volatile ALT_SYSMGR_PINMUX_GPLMUX29_t GPLMUX29; /* ALT_SYSMGR_PINMUX_GPLMUX29 */
24458  volatile ALT_SYSMGR_PINMUX_GPLMUX30_t GPLMUX30; /* ALT_SYSMGR_PINMUX_GPLMUX30 */
24459  volatile ALT_SYSMGR_PINMUX_GPLMUX31_t GPLMUX31; /* ALT_SYSMGR_PINMUX_GPLMUX31 */
24460  volatile ALT_SYSMGR_PINMUX_GPLMUX32_t GPLMUX32; /* ALT_SYSMGR_PINMUX_GPLMUX32 */
24461  volatile ALT_SYSMGR_PINMUX_GPLMUX33_t GPLMUX33; /* ALT_SYSMGR_PINMUX_GPLMUX33 */
24462  volatile ALT_SYSMGR_PINMUX_GPLMUX34_t GPLMUX34; /* ALT_SYSMGR_PINMUX_GPLMUX34 */
24463  volatile ALT_SYSMGR_PINMUX_GPLMUX35_t GPLMUX35; /* ALT_SYSMGR_PINMUX_GPLMUX35 */
24464  volatile ALT_SYSMGR_PINMUX_GPLMUX36_t GPLMUX36; /* ALT_SYSMGR_PINMUX_GPLMUX36 */
24465  volatile ALT_SYSMGR_PINMUX_GPLMUX37_t GPLMUX37; /* ALT_SYSMGR_PINMUX_GPLMUX37 */
24466  volatile ALT_SYSMGR_PINMUX_GPLMUX38_t GPLMUX38; /* ALT_SYSMGR_PINMUX_GPLMUX38 */
24467  volatile ALT_SYSMGR_PINMUX_GPLMUX39_t GPLMUX39; /* ALT_SYSMGR_PINMUX_GPLMUX39 */
24468  volatile ALT_SYSMGR_PINMUX_GPLMUX40_t GPLMUX40; /* ALT_SYSMGR_PINMUX_GPLMUX40 */
24469  volatile ALT_SYSMGR_PINMUX_GPLMUX41_t GPLMUX41; /* ALT_SYSMGR_PINMUX_GPLMUX41 */
24470  volatile ALT_SYSMGR_PINMUX_GPLMUX42_t GPLMUX42; /* ALT_SYSMGR_PINMUX_GPLMUX42 */
24471  volatile ALT_SYSMGR_PINMUX_GPLMUX43_t GPLMUX43; /* ALT_SYSMGR_PINMUX_GPLMUX43 */
24472  volatile ALT_SYSMGR_PINMUX_GPLMUX44_t GPLMUX44; /* ALT_SYSMGR_PINMUX_GPLMUX44 */
24473  volatile ALT_SYSMGR_PINMUX_GPLMUX45_t GPLMUX45; /* ALT_SYSMGR_PINMUX_GPLMUX45 */
24474  volatile ALT_SYSMGR_PINMUX_GPLMUX46_t GPLMUX46; /* ALT_SYSMGR_PINMUX_GPLMUX46 */
24475  volatile ALT_SYSMGR_PINMUX_GPLMUX47_t GPLMUX47; /* ALT_SYSMGR_PINMUX_GPLMUX47 */
24476  volatile ALT_SYSMGR_PINMUX_GPLMUX48_t GPLMUX48; /* ALT_SYSMGR_PINMUX_GPLMUX48 */
24477  volatile ALT_SYSMGR_PINMUX_GPLMUX49_t GPLMUX49; /* ALT_SYSMGR_PINMUX_GPLMUX49 */
24478  volatile ALT_SYSMGR_PINMUX_GPLMUX50_t GPLMUX50; /* ALT_SYSMGR_PINMUX_GPLMUX50 */
24479  volatile ALT_SYSMGR_PINMUX_GPLMUX51_t GPLMUX51; /* ALT_SYSMGR_PINMUX_GPLMUX51 */
24480  volatile ALT_SYSMGR_PINMUX_GPLMUX52_t GPLMUX52; /* ALT_SYSMGR_PINMUX_GPLMUX52 */
24481  volatile ALT_SYSMGR_PINMUX_GPLMUX53_t GPLMUX53; /* ALT_SYSMGR_PINMUX_GPLMUX53 */
24482  volatile ALT_SYSMGR_PINMUX_GPLMUX54_t GPLMUX54; /* ALT_SYSMGR_PINMUX_GPLMUX54 */
24483  volatile ALT_SYSMGR_PINMUX_GPLMUX55_t GPLMUX55; /* ALT_SYSMGR_PINMUX_GPLMUX55 */
24484  volatile ALT_SYSMGR_PINMUX_GPLMUX56_t GPLMUX56; /* ALT_SYSMGR_PINMUX_GPLMUX56 */
24485  volatile ALT_SYSMGR_PINMUX_GPLMUX57_t GPLMUX57; /* ALT_SYSMGR_PINMUX_GPLMUX57 */
24486  volatile ALT_SYSMGR_PINMUX_GPLMUX58_t GPLMUX58; /* ALT_SYSMGR_PINMUX_GPLMUX58 */
24487  volatile ALT_SYSMGR_PINMUX_GPLMUX59_t GPLMUX59; /* ALT_SYSMGR_PINMUX_GPLMUX59 */
24488  volatile ALT_SYSMGR_PINMUX_GPLMUX60_t GPLMUX60; /* ALT_SYSMGR_PINMUX_GPLMUX60 */
24489  volatile ALT_SYSMGR_PINMUX_GPLMUX61_t GPLMUX61; /* ALT_SYSMGR_PINMUX_GPLMUX61 */
24490  volatile ALT_SYSMGR_PINMUX_GPLMUX62_t GPLMUX62; /* ALT_SYSMGR_PINMUX_GPLMUX62 */
24491  volatile ALT_SYSMGR_PINMUX_GPLMUX63_t GPLMUX63; /* ALT_SYSMGR_PINMUX_GPLMUX63 */
24492  volatile ALT_SYSMGR_PINMUX_GPLMUX64_t GPLMUX64; /* ALT_SYSMGR_PINMUX_GPLMUX64 */
24493  volatile ALT_SYSMGR_PINMUX_GPLMUX65_t GPLMUX65; /* ALT_SYSMGR_PINMUX_GPLMUX65 */
24494  volatile ALT_SYSMGR_PINMUX_GPLMUX66_t GPLMUX66; /* ALT_SYSMGR_PINMUX_GPLMUX66 */
24495  volatile ALT_SYSMGR_PINMUX_GPLMUX67_t GPLMUX67; /* ALT_SYSMGR_PINMUX_GPLMUX67 */
24496  volatile ALT_SYSMGR_PINMUX_GPLMUX68_t GPLMUX68; /* ALT_SYSMGR_PINMUX_GPLMUX68 */
24497  volatile ALT_SYSMGR_PINMUX_GPLMUX69_t GPLMUX69; /* ALT_SYSMGR_PINMUX_GPLMUX69 */
24498  volatile ALT_SYSMGR_PINMUX_GPLMUX70_t GPLMUX70; /* ALT_SYSMGR_PINMUX_GPLMUX70 */
24499  volatile ALT_SYSMGR_PINMUX_NANDUSEFPGA_t NANDUSEFPGA; /* ALT_SYSMGR_PINMUX_NANDUSEFPGA */
24500  volatile uint32_t _pad_0x2f4_0x2f7; /* *UNDEFINED* */
24501  volatile ALT_SYSMGR_PINMUX_RGMII1USEFPGA_t RGMII1USEFPGA; /* ALT_SYSMGR_PINMUX_RGMII1USEFPGA */
24502  volatile uint32_t _pad_0x2fc_0x303[2]; /* *UNDEFINED* */
24503  volatile ALT_SYSMGR_PINMUX_I2C0USEFPGA_t I2C0USEFPGA; /* ALT_SYSMGR_PINMUX_I2C0USEFPGA */
24504  volatile uint32_t _pad_0x308_0x313[3]; /* *UNDEFINED* */
24505  volatile ALT_SYSMGR_PINMUX_RGMII0USEFPGA_t RGMII0USEFPGA; /* ALT_SYSMGR_PINMUX_RGMII0USEFPGA */
24506  volatile uint32_t _pad_0x318_0x323[3]; /* *UNDEFINED* */
24507  volatile ALT_SYSMGR_PINMUX_I2C3USEFPGA_t I2C3USEFPGA; /* ALT_SYSMGR_PINMUX_I2C3USEFPGA */
24508  volatile ALT_SYSMGR_PINMUX_I2C2USEFPGA_t I2C2USEFPGA; /* ALT_SYSMGR_PINMUX_I2C2USEFPGA */
24509  volatile ALT_SYSMGR_PINMUX_I2C1USEFPGA_t I2C1USEFPGA; /* ALT_SYSMGR_PINMUX_I2C1USEFPGA */
24510  volatile ALT_SYSMGR_PINMUX_SPIM1USEFPGA_t SPIM1USEFPGA; /* ALT_SYSMGR_PINMUX_SPIM1USEFPGA */
24511  volatile uint32_t _pad_0x334_0x337; /* *UNDEFINED* */
24512  volatile ALT_SYSMGR_PINMUX_SPIM0USEFPGA_t SPIM0USEFPGA; /* ALT_SYSMGR_PINMUX_SPIM0USEFPGA */
24513  volatile uint32_t _pad_0x33c_0x400[49]; /* *UNDEFINED* */
24514 };
24515
24516 /* The typedef declaration for register group ALT_SYSMGR_PINMUX. */
24517 typedef volatile struct ALT_SYSMGR_PINMUX_s ALT_SYSMGR_PINMUX_t;
24518 /* The struct declaration for the raw register contents of register group ALT_SYSMGR_PINMUX. */
24520 {
24521  volatile uint32_t EMACIO0; /* ALT_SYSMGR_PINMUX_EMACIO0 */
24522  volatile uint32_t EMACIO1; /* ALT_SYSMGR_PINMUX_EMACIO1 */
24523  volatile uint32_t EMACIO2; /* ALT_SYSMGR_PINMUX_EMACIO2 */
24524  volatile uint32_t EMACIO3; /* ALT_SYSMGR_PINMUX_EMACIO3 */
24525  volatile uint32_t EMACIO4; /* ALT_SYSMGR_PINMUX_EMACIO4 */
24526  volatile uint32_t EMACIO5; /* ALT_SYSMGR_PINMUX_EMACIO5 */
24527  volatile uint32_t EMACIO6; /* ALT_SYSMGR_PINMUX_EMACIO6 */
24528  volatile uint32_t EMACIO7; /* ALT_SYSMGR_PINMUX_EMACIO7 */
24529  volatile uint32_t EMACIO8; /* ALT_SYSMGR_PINMUX_EMACIO8 */
24530  volatile uint32_t EMACIO9; /* ALT_SYSMGR_PINMUX_EMACIO9 */
24531  volatile uint32_t EMACIO10; /* ALT_SYSMGR_PINMUX_EMACIO10 */
24532  volatile uint32_t EMACIO11; /* ALT_SYSMGR_PINMUX_EMACIO11 */
24533  volatile uint32_t EMACIO12; /* ALT_SYSMGR_PINMUX_EMACIO12 */
24534  volatile uint32_t EMACIO13; /* ALT_SYSMGR_PINMUX_EMACIO13 */
24535  volatile uint32_t EMACIO14; /* ALT_SYSMGR_PINMUX_EMACIO14 */
24536  volatile uint32_t EMACIO15; /* ALT_SYSMGR_PINMUX_EMACIO15 */
24537  volatile uint32_t EMACIO16; /* ALT_SYSMGR_PINMUX_EMACIO16 */
24538  volatile uint32_t EMACIO17; /* ALT_SYSMGR_PINMUX_EMACIO17 */
24539  volatile uint32_t EMACIO18; /* ALT_SYSMGR_PINMUX_EMACIO18 */
24540  volatile uint32_t EMACIO19; /* ALT_SYSMGR_PINMUX_EMACIO19 */
24541  volatile uint32_t FLASHIO0; /* ALT_SYSMGR_PINMUX_FLSHIO0 */
24542  volatile uint32_t FLASHIO1; /* ALT_SYSMGR_PINMUX_FLSHIO1 */
24543  volatile uint32_t FLASHIO2; /* ALT_SYSMGR_PINMUX_FLSHIO2 */
24544  volatile uint32_t FLASHIO3; /* ALT_SYSMGR_PINMUX_FLSHIO3 */
24545  volatile uint32_t FLASHIO4; /* ALT_SYSMGR_PINMUX_FLSHIO4 */
24546  volatile uint32_t FLASHIO5; /* ALT_SYSMGR_PINMUX_FLSHIO5 */
24547  volatile uint32_t FLASHIO6; /* ALT_SYSMGR_PINMUX_FLSHIO6 */
24548  volatile uint32_t FLASHIO7; /* ALT_SYSMGR_PINMUX_FLSHIO7 */
24549  volatile uint32_t FLASHIO8; /* ALT_SYSMGR_PINMUX_FLSHIO8 */
24550  volatile uint32_t FLASHIO9; /* ALT_SYSMGR_PINMUX_FLSHIO9 */
24551  volatile uint32_t FLASHIO10; /* ALT_SYSMGR_PINMUX_FLSHIO10 */
24552  volatile uint32_t FLASHIO11; /* ALT_SYSMGR_PINMUX_FLSHIO11 */
24553  volatile uint32_t GENERALIO0; /* ALT_SYSMGR_PINMUX_GENERALIO0 */
24554  volatile uint32_t GENERALIO1; /* ALT_SYSMGR_PINMUX_GENERALIO1 */
24555  volatile uint32_t GENERALIO2; /* ALT_SYSMGR_PINMUX_GENERALIO2 */
24556  volatile uint32_t GENERALIO3; /* ALT_SYSMGR_PINMUX_GENERALIO3 */
24557  volatile uint32_t GENERALIO4; /* ALT_SYSMGR_PINMUX_GENERALIO4 */
24558  volatile uint32_t GENERALIO5; /* ALT_SYSMGR_PINMUX_GENERALIO5 */
24559  volatile uint32_t GENERALIO6; /* ALT_SYSMGR_PINMUX_GENERALIO6 */
24560  volatile uint32_t GENERALIO7; /* ALT_SYSMGR_PINMUX_GENERALIO7 */
24561  volatile uint32_t GENERALIO8; /* ALT_SYSMGR_PINMUX_GENERALIO8 */
24562  volatile uint32_t GENERALIO9; /* ALT_SYSMGR_PINMUX_GENERALIO9 */
24563  volatile uint32_t GENERALIO10; /* ALT_SYSMGR_PINMUX_GENERALIO10 */
24564  volatile uint32_t GENERALIO11; /* ALT_SYSMGR_PINMUX_GENERALIO11 */
24565  volatile uint32_t GENERALIO12; /* ALT_SYSMGR_PINMUX_GENERALIO12 */
24566  volatile uint32_t GENERALIO13; /* ALT_SYSMGR_PINMUX_GENERALIO13 */
24567  volatile uint32_t GENERALIO14; /* ALT_SYSMGR_PINMUX_GENERALIO14 */
24568  volatile uint32_t GENERALIO15; /* ALT_SYSMGR_PINMUX_GENERALIO15 */
24569  volatile uint32_t GENERALIO16; /* ALT_SYSMGR_PINMUX_GENERALIO16 */
24570  volatile uint32_t GENERALIO17; /* ALT_SYSMGR_PINMUX_GENERALIO17 */
24571  volatile uint32_t GENERALIO18; /* ALT_SYSMGR_PINMUX_GENERALIO18 */
24572  volatile uint32_t GENERALIO19; /* ALT_SYSMGR_PINMUX_GENERALIO19 */
24573  volatile uint32_t GENERALIO20; /* ALT_SYSMGR_PINMUX_GENERALIO20 */
24574  volatile uint32_t GENERALIO21; /* ALT_SYSMGR_PINMUX_GENERALIO21 */
24575  volatile uint32_t GENERALIO22; /* ALT_SYSMGR_PINMUX_GENERALIO22 */
24576  volatile uint32_t GENERALIO23; /* ALT_SYSMGR_PINMUX_GENERALIO23 */
24577  volatile uint32_t GENERALIO24; /* ALT_SYSMGR_PINMUX_GENERALIO24 */
24578  volatile uint32_t GENERALIO25; /* ALT_SYSMGR_PINMUX_GENERALIO25 */
24579  volatile uint32_t GENERALIO26; /* ALT_SYSMGR_PINMUX_GENERALIO26 */
24580  volatile uint32_t GENERALIO27; /* ALT_SYSMGR_PINMUX_GENERALIO27 */
24581  volatile uint32_t GENERALIO28; /* ALT_SYSMGR_PINMUX_GENERALIO28 */
24582  volatile uint32_t GENERALIO29; /* ALT_SYSMGR_PINMUX_GENERALIO29 */
24583  volatile uint32_t GENERALIO30; /* ALT_SYSMGR_PINMUX_GENERALIO30 */
24584  volatile uint32_t GENERALIO31; /* ALT_SYSMGR_PINMUX_GENERALIO31 */
24585  volatile uint32_t MIXED1IO0; /* ALT_SYSMGR_PINMUX_MIXED1IO0 */
24586  volatile uint32_t MIXED1IO1; /* ALT_SYSMGR_PINMUX_MIXED1IO1 */
24587  volatile uint32_t MIXED1IO2; /* ALT_SYSMGR_PINMUX_MIXED1IO2 */
24588  volatile uint32_t MIXED1IO3; /* ALT_SYSMGR_PINMUX_MIXED1IO3 */
24589  volatile uint32_t MIXED1IO4; /* ALT_SYSMGR_PINMUX_MIXED1IO4 */
24590  volatile uint32_t MIXED1IO5; /* ALT_SYSMGR_PINMUX_MIXED1IO5 */
24591  volatile uint32_t MIXED1IO6; /* ALT_SYSMGR_PINMUX_MIXED1IO6 */
24592  volatile uint32_t MIXED1IO7; /* ALT_SYSMGR_PINMUX_MIXED1IO7 */
24593  volatile uint32_t MIXED1IO8; /* ALT_SYSMGR_PINMUX_MIXED1IO8 */
24594  volatile uint32_t MIXED1IO9; /* ALT_SYSMGR_PINMUX_MIXED1IO9 */
24595  volatile uint32_t MIXED1IO10; /* ALT_SYSMGR_PINMUX_MIXED1IO10 */
24596  volatile uint32_t MIXED1IO11; /* ALT_SYSMGR_PINMUX_MIXED1IO11 */
24597  volatile uint32_t MIXED1IO12; /* ALT_SYSMGR_PINMUX_MIXED1IO12 */
24598  volatile uint32_t MIXED1IO13; /* ALT_SYSMGR_PINMUX_MIXED1IO13 */
24599  volatile uint32_t MIXED1IO14; /* ALT_SYSMGR_PINMUX_MIXED1IO14 */
24600  volatile uint32_t MIXED1IO15; /* ALT_SYSMGR_PINMUX_MIXED1IO15 */
24601  volatile uint32_t MIXED1IO16; /* ALT_SYSMGR_PINMUX_MIXED1IO16 */
24602  volatile uint32_t MIXED1IO17; /* ALT_SYSMGR_PINMUX_MIXED1IO17 */
24603  volatile uint32_t MIXED1IO18; /* ALT_SYSMGR_PINMUX_MIXED1IO18 */
24604  volatile uint32_t MIXED1IO19; /* ALT_SYSMGR_PINMUX_MIXED1IO19 */
24605  volatile uint32_t MIXED1IO20; /* ALT_SYSMGR_PINMUX_MIXED1IO20 */
24606  volatile uint32_t MIXED1IO21; /* ALT_SYSMGR_PINMUX_MIXED1IO21 */
24607  volatile uint32_t MIXED2IO0; /* ALT_SYSMGR_PINMUX_MIXED2IO0 */
24608  volatile uint32_t MIXED2IO1; /* ALT_SYSMGR_PINMUX_MIXED2IO1 */
24609  volatile uint32_t MIXED2IO2; /* ALT_SYSMGR_PINMUX_MIXED2IO2 */
24610  volatile uint32_t MIXED2IO3; /* ALT_SYSMGR_PINMUX_MIXED2IO3 */
24611  volatile uint32_t MIXED2IO4; /* ALT_SYSMGR_PINMUX_MIXED2IO4 */
24612  volatile uint32_t MIXED2IO5; /* ALT_SYSMGR_PINMUX_MIXED2IO5 */
24613  volatile uint32_t MIXED2IO6; /* ALT_SYSMGR_PINMUX_MIXED2IO6 */
24614  volatile uint32_t MIXED2IO7; /* ALT_SYSMGR_PINMUX_MIXED2IO7 */
24615  volatile uint32_t GPLINMUX48; /* ALT_SYSMGR_PINMUX_GPLINMUX48 */
24616  volatile uint32_t GPLINMUX49; /* ALT_SYSMGR_PINMUX_GPLINMUX49 */
24617  volatile uint32_t GPLINMUX50; /* ALT_SYSMGR_PINMUX_GPLINMUX50 */
24618  volatile uint32_t GPLINMUX51; /* ALT_SYSMGR_PINMUX_GPLINMUX51 */
24619  volatile uint32_t GPLINMUX52; /* ALT_SYSMGR_PINMUX_GPLINMUX52 */
24620  volatile uint32_t GPLINMUX53; /* ALT_SYSMGR_PINMUX_GPLINMUX53 */
24621  volatile uint32_t GPLINMUX54; /* ALT_SYSMGR_PINMUX_GPLINMUX54 */
24622  volatile uint32_t GPLINMUX55; /* ALT_SYSMGR_PINMUX_GPLINMUX55 */
24623  volatile uint32_t GPLINMUX56; /* ALT_SYSMGR_PINMUX_GPLINMUX56 */
24624  volatile uint32_t GPLINMUX57; /* ALT_SYSMGR_PINMUX_GPLINMUX57 */
24625  volatile uint32_t GPLINMUX58; /* ALT_SYSMGR_PINMUX_GPLINMUX58 */
24626  volatile uint32_t GPLINMUX59; /* ALT_SYSMGR_PINMUX_GPLINMUX59 */
24627  volatile uint32_t GPLINMUX60; /* ALT_SYSMGR_PINMUX_GPLINMUX60 */
24628  volatile uint32_t GPLINMUX61; /* ALT_SYSMGR_PINMUX_GPLINMUX61 */
24629  volatile uint32_t GPLINMUX62; /* ALT_SYSMGR_PINMUX_GPLINMUX62 */
24630  volatile uint32_t GPLINMUX63; /* ALT_SYSMGR_PINMUX_GPLINMUX63 */
24631  volatile uint32_t GPLINMUX64; /* ALT_SYSMGR_PINMUX_GPLINMUX64 */
24632  volatile uint32_t GPLINMUX65; /* ALT_SYSMGR_PINMUX_GPLINMUX65 */
24633  volatile uint32_t GPLINMUX66; /* ALT_SYSMGR_PINMUX_GPLINMUX66 */
24634  volatile uint32_t GPLINMUX67; /* ALT_SYSMGR_PINMUX_GPLINMUX67 */
24635  volatile uint32_t GPLINMUX68; /* ALT_SYSMGR_PINMUX_GPLINMUX68 */
24636  volatile uint32_t GPLINMUX69; /* ALT_SYSMGR_PINMUX_GPLINMUX69 */
24637  volatile uint32_t GPLINMUX70; /* ALT_SYSMGR_PINMUX_GPLINMUX70 */
24638  volatile uint32_t GPLMUX0; /* ALT_SYSMGR_PINMUX_GPLMUX0 */
24639  volatile uint32_t GPLMUX1; /* ALT_SYSMGR_PINMUX_GPLMUX1 */
24640  volatile uint32_t GPLMUX2; /* ALT_SYSMGR_PINMUX_GPLMUX2 */
24641  volatile uint32_t GPLMUX3; /* ALT_SYSMGR_PINMUX_GPLMUX3 */
24642  volatile uint32_t GPLMUX4; /* ALT_SYSMGR_PINMUX_GPLMUX4 */
24643  volatile uint32_t GPLMUX5; /* ALT_SYSMGR_PINMUX_GPLMUX5 */
24644  volatile uint32_t GPLMUX6; /* ALT_SYSMGR_PINMUX_GPLMUX6 */
24645  volatile uint32_t GPLMUX7; /* ALT_SYSMGR_PINMUX_GPLMUX7 */
24646  volatile uint32_t GPLMUX8; /* ALT_SYSMGR_PINMUX_GPLMUX8 */
24647  volatile uint32_t GPLMUX9; /* ALT_SYSMGR_PINMUX_GPLMUX9 */
24648  volatile uint32_t GPLMUX10; /* ALT_SYSMGR_PINMUX_GPLMUX10 */
24649  volatile uint32_t GPLMUX11; /* ALT_SYSMGR_PINMUX_GPLMUX11 */
24650  volatile uint32_t GPLMUX12; /* ALT_SYSMGR_PINMUX_GPLMUX12 */
24651  volatile uint32_t GPLMUX13; /* ALT_SYSMGR_PINMUX_GPLMUX13 */
24652  volatile uint32_t GPLMUX14; /* ALT_SYSMGR_PINMUX_GPLMUX14 */
24653  volatile uint32_t GPLMUX15; /* ALT_SYSMGR_PINMUX_GPLMUX15 */
24654  volatile uint32_t GPLMUX16; /* ALT_SYSMGR_PINMUX_GPLMUX16 */
24655  volatile uint32_t GPLMUX17; /* ALT_SYSMGR_PINMUX_GPLMUX17 */
24656  volatile uint32_t GPLMUX18; /* ALT_SYSMGR_PINMUX_GPLMUX18 */
24657  volatile uint32_t GPLMUX19; /* ALT_SYSMGR_PINMUX_GPLMUX19 */
24658  volatile uint32_t GPLMUX20; /* ALT_SYSMGR_PINMUX_GPLMUX20 */
24659  volatile uint32_t GPLMUX21; /* ALT_SYSMGR_PINMUX_GPLMUX21 */
24660  volatile uint32_t GPLMUX22; /* ALT_SYSMGR_PINMUX_GPLMUX22 */
24661  volatile uint32_t GPLMUX23; /* ALT_SYSMGR_PINMUX_GPLMUX23 */
24662  volatile uint32_t GPLMUX24; /* ALT_SYSMGR_PINMUX_GPLMUX24 */
24663  volatile uint32_t GPLMUX25; /* ALT_SYSMGR_PINMUX_GPLMUX25 */
24664  volatile uint32_t GPLMUX26; /* ALT_SYSMGR_PINMUX_GPLMUX26 */
24665  volatile uint32_t GPLMUX27; /* ALT_SYSMGR_PINMUX_GPLMUX27 */
24666  volatile uint32_t GPLMUX28; /* ALT_SYSMGR_PINMUX_GPLMUX28 */
24667  volatile uint32_t GPLMUX29; /* ALT_SYSMGR_PINMUX_GPLMUX29 */
24668  volatile uint32_t GPLMUX30; /* ALT_SYSMGR_PINMUX_GPLMUX30 */
24669  volatile uint32_t GPLMUX31; /* ALT_SYSMGR_PINMUX_GPLMUX31 */
24670  volatile uint32_t GPLMUX32; /* ALT_SYSMGR_PINMUX_GPLMUX32 */
24671  volatile uint32_t GPLMUX33; /* ALT_SYSMGR_PINMUX_GPLMUX33 */
24672  volatile uint32_t GPLMUX34; /* ALT_SYSMGR_PINMUX_GPLMUX34 */
24673  volatile uint32_t GPLMUX35; /* ALT_SYSMGR_PINMUX_GPLMUX35 */
24674  volatile uint32_t GPLMUX36; /* ALT_SYSMGR_PINMUX_GPLMUX36 */
24675  volatile uint32_t GPLMUX37; /* ALT_SYSMGR_PINMUX_GPLMUX37 */
24676  volatile uint32_t GPLMUX38; /* ALT_SYSMGR_PINMUX_GPLMUX38 */
24677  volatile uint32_t GPLMUX39; /* ALT_SYSMGR_PINMUX_GPLMUX39 */
24678  volatile uint32_t GPLMUX40; /* ALT_SYSMGR_PINMUX_GPLMUX40 */
24679  volatile uint32_t GPLMUX41; /* ALT_SYSMGR_PINMUX_GPLMUX41 */
24680  volatile uint32_t GPLMUX42; /* ALT_SYSMGR_PINMUX_GPLMUX42 */
24681  volatile uint32_t GPLMUX43; /* ALT_SYSMGR_PINMUX_GPLMUX43 */
24682  volatile uint32_t GPLMUX44; /* ALT_SYSMGR_PINMUX_GPLMUX44 */
24683  volatile uint32_t GPLMUX45; /* ALT_SYSMGR_PINMUX_GPLMUX45 */
24684  volatile uint32_t GPLMUX46; /* ALT_SYSMGR_PINMUX_GPLMUX46 */
24685  volatile uint32_t GPLMUX47; /* ALT_SYSMGR_PINMUX_GPLMUX47 */
24686  volatile uint32_t GPLMUX48; /* ALT_SYSMGR_PINMUX_GPLMUX48 */
24687  volatile uint32_t GPLMUX49; /* ALT_SYSMGR_PINMUX_GPLMUX49 */
24688  volatile uint32_t GPLMUX50; /* ALT_SYSMGR_PINMUX_GPLMUX50 */
24689  volatile uint32_t GPLMUX51; /* ALT_SYSMGR_PINMUX_GPLMUX51 */
24690  volatile uint32_t GPLMUX52; /* ALT_SYSMGR_PINMUX_GPLMUX52 */
24691  volatile uint32_t GPLMUX53; /* ALT_SYSMGR_PINMUX_GPLMUX53 */
24692  volatile uint32_t GPLMUX54; /* ALT_SYSMGR_PINMUX_GPLMUX54 */
24693  volatile uint32_t GPLMUX55; /* ALT_SYSMGR_PINMUX_GPLMUX55 */
24694  volatile uint32_t GPLMUX56; /* ALT_SYSMGR_PINMUX_GPLMUX56 */
24695  volatile uint32_t GPLMUX57; /* ALT_SYSMGR_PINMUX_GPLMUX57 */
24696  volatile uint32_t GPLMUX58; /* ALT_SYSMGR_PINMUX_GPLMUX58 */
24697  volatile uint32_t GPLMUX59; /* ALT_SYSMGR_PINMUX_GPLMUX59 */
24698  volatile uint32_t GPLMUX60; /* ALT_SYSMGR_PINMUX_GPLMUX60 */
24699  volatile uint32_t GPLMUX61; /* ALT_SYSMGR_PINMUX_GPLMUX61 */
24700  volatile uint32_t GPLMUX62; /* ALT_SYSMGR_PINMUX_GPLMUX62 */
24701  volatile uint32_t GPLMUX63; /* ALT_SYSMGR_PINMUX_GPLMUX63 */
24702  volatile uint32_t GPLMUX64; /* ALT_SYSMGR_PINMUX_GPLMUX64 */
24703  volatile uint32_t GPLMUX65; /* ALT_SYSMGR_PINMUX_GPLMUX65 */
24704  volatile uint32_t GPLMUX66; /* ALT_SYSMGR_PINMUX_GPLMUX66 */
24705  volatile uint32_t GPLMUX67; /* ALT_SYSMGR_PINMUX_GPLMUX67 */
24706  volatile uint32_t GPLMUX68; /* ALT_SYSMGR_PINMUX_GPLMUX68 */
24707  volatile uint32_t GPLMUX69; /* ALT_SYSMGR_PINMUX_GPLMUX69 */
24708  volatile uint32_t GPLMUX70; /* ALT_SYSMGR_PINMUX_GPLMUX70 */
24709  volatile uint32_t NANDUSEFPGA; /* ALT_SYSMGR_PINMUX_NANDUSEFPGA */
24710  volatile uint32_t _pad_0x2f4_0x2f7; /* *UNDEFINED* */
24711  volatile uint32_t RGMII1USEFPGA; /* ALT_SYSMGR_PINMUX_RGMII1USEFPGA */
24712  volatile uint32_t _pad_0x2fc_0x303[2]; /* *UNDEFINED* */
24713  volatile uint32_t I2C0USEFPGA; /* ALT_SYSMGR_PINMUX_I2C0USEFPGA */
24714  volatile uint32_t _pad_0x308_0x313[3]; /* *UNDEFINED* */
24715  volatile uint32_t RGMII0USEFPGA; /* ALT_SYSMGR_PINMUX_RGMII0USEFPGA */
24716  volatile uint32_t _pad_0x318_0x323[3]; /* *UNDEFINED* */
24717  volatile uint32_t I2C3USEFPGA; /* ALT_SYSMGR_PINMUX_I2C3USEFPGA */
24718  volatile uint32_t I2C2USEFPGA; /* ALT_SYSMGR_PINMUX_I2C2USEFPGA */
24719  volatile uint32_t I2C1USEFPGA; /* ALT_SYSMGR_PINMUX_I2C1USEFPGA */
24720  volatile uint32_t SPIM1USEFPGA; /* ALT_SYSMGR_PINMUX_SPIM1USEFPGA */
24721  volatile uint32_t _pad_0x334_0x337; /* *UNDEFINED* */
24722  volatile uint32_t SPIM0USEFPGA; /* ALT_SYSMGR_PINMUX_SPIM0USEFPGA */
24723  volatile uint32_t _pad_0x33c_0x400[49]; /* *UNDEFINED* */
24724 };
24725
24726 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR_PINMUX. */
24727 typedef volatile struct ALT_SYSMGR_PINMUX_raw_s ALT_SYSMGR_PINMUX_raw_t;
24728 #endif /* __ASSEMBLY__ */
24729
24730
24731 #ifndef __ASSEMBLY__
24732 /*
24733  * WARNING: The C register and register group struct declarations are provided for
24734  * convenience and illustrative purposes. They should, however, be used with
24735  * caution as the C language standard provides no guarantees about the alignment or
24736  * atomicity of device memory accesses. The recommended practice for writing
24737  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
24738  * alt_write_word() functions.
24739  *
24740  * The struct declaration for register group ALT_SYSMGR.
24741  */
24743 {
24744  volatile ALT_SYSMGR_SILICONID1_t siliconid1; /* ALT_SYSMGR_SILICONID1 */
24745  volatile ALT_SYSMGR_SILICONID2_t siliconid2; /* ALT_SYSMGR_SILICONID2 */
24746  volatile uint32_t _pad_0x8_0xf[2]; /* *UNDEFINED* */
24747  volatile ALT_SYSMGR_WDDBG_t wddbg; /* ALT_SYSMGR_WDDBG */
24748  volatile ALT_SYSMGR_BOOT_t bootinfo; /* ALT_SYSMGR_BOOT */
24749  volatile ALT_SYSMGR_HPSINFO_t hpsinfo; /* ALT_SYSMGR_HPSINFO */
24750  volatile ALT_SYSMGR_PARITYINJ_t parityinj; /* ALT_SYSMGR_PARITYINJ */
24751  volatile ALT_SYSMGR_FPGAINTF_t fpgaintfgrp; /* ALT_SYSMGR_FPGAINTF */
24752  volatile ALT_SYSMGR_SCANMGR_t scanmgrgrp; /* ALT_SYSMGR_SCANMGR */
24753  volatile uint32_t _pad_0x34_0x3f[3]; /* *UNDEFINED* */
24754  volatile ALT_SYSMGR_FRZCTL_t frzctrl; /* ALT_SYSMGR_FRZCTL */
24755  volatile ALT_SYSMGR_EMAC_t emacgrp; /* ALT_SYSMGR_EMAC */
24756  volatile ALT_SYSMGR_DMA_t dmagrp; /* ALT_SYSMGR_DMA */
24757  volatile uint32_t _pad_0x78_0x7f[2]; /* *UNDEFINED* */
24758  volatile ALT_SYSMGR_ISW_t iswgrp; /* ALT_SYSMGR_ISW */
24759  volatile uint32_t _pad_0xa0_0xbf[8]; /* *UNDEFINED* */
24760  volatile ALT_SYSMGR_ROMCODE_t romcodegrp; /* ALT_SYSMGR_ROMCODE */
24761  volatile ALT_SYSMGR_ROMHW_t romhwgrp; /* ALT_SYSMGR_ROMHW */
24762  volatile uint32_t _pad_0x104_0x107; /* *UNDEFINED* */
24763  volatile ALT_SYSMGR_SDMMC_t sdmmcgrp; /* ALT_SYSMGR_SDMMC */
24764  volatile ALT_SYSMGR_NAND_t nandgrp; /* ALT_SYSMGR_NAND */
24765  volatile ALT_SYSMGR_USB_t usbgrp; /* ALT_SYSMGR_USB */
24766  volatile uint32_t _pad_0x11c_0x13f[9]; /* *UNDEFINED* */
24767  volatile ALT_SYSMGR_ECC_t eccgrp; /* ALT_SYSMGR_ECC */
24768  volatile uint32_t _pad_0x180_0x3ff[160]; /* *UNDEFINED* */
24769  volatile ALT_SYSMGR_PINMUX_t pinmuxgrp; /* ALT_SYSMGR_PINMUX */
24770  volatile uint32_t _pad_0x800_0x4000[3584]; /* *UNDEFINED* */
24771 };
24772
24773 /* The typedef declaration for register group ALT_SYSMGR. */
24774 typedef volatile struct ALT_SYSMGR_s ALT_SYSMGR_t;
24775 /* The struct declaration for the raw register contents of register group ALT_SYSMGR. */
24777 {
24778  volatile uint32_t siliconid1; /* ALT_SYSMGR_SILICONID1 */
24779  volatile uint32_t siliconid2; /* ALT_SYSMGR_SILICONID2 */
24780  volatile uint32_t _pad_0x8_0xf[2]; /* *UNDEFINED* */
24781  volatile uint32_t wddbg; /* ALT_SYSMGR_WDDBG */
24782  volatile uint32_t bootinfo; /* ALT_SYSMGR_BOOT */
24783  volatile uint32_t hpsinfo; /* ALT_SYSMGR_HPSINFO */
24784  volatile uint32_t parityinj; /* ALT_SYSMGR_PARITYINJ */
24785  volatile ALT_SYSMGR_FPGAINTF_raw_t fpgaintfgrp; /* ALT_SYSMGR_FPGAINTF */
24786  volatile ALT_SYSMGR_SCANMGR_raw_t scanmgrgrp; /* ALT_SYSMGR_SCANMGR */
24787  volatile uint32_t _pad_0x34_0x3f[3]; /* *UNDEFINED* */
24788  volatile ALT_SYSMGR_FRZCTL_raw_t frzctrl; /* ALT_SYSMGR_FRZCTL */
24789  volatile ALT_SYSMGR_EMAC_raw_t emacgrp; /* ALT_SYSMGR_EMAC */
24790  volatile ALT_SYSMGR_DMA_raw_t dmagrp; /* ALT_SYSMGR_DMA */
24791  volatile uint32_t _pad_0x78_0x7f[2]; /* *UNDEFINED* */
24792  volatile ALT_SYSMGR_ISW_raw_t iswgrp; /* ALT_SYSMGR_ISW */
24793  volatile uint32_t _pad_0xa0_0xbf[8]; /* *UNDEFINED* */
24794  volatile ALT_SYSMGR_ROMCODE_raw_t romcodegrp; /* ALT_SYSMGR_ROMCODE */
24795  volatile ALT_SYSMGR_ROMHW_raw_t romhwgrp; /* ALT_SYSMGR_ROMHW */
24796  volatile uint32_t _pad_0x104_0x107; /* *UNDEFINED* */
24797  volatile ALT_SYSMGR_SDMMC_raw_t sdmmcgrp; /* ALT_SYSMGR_SDMMC */
24798  volatile ALT_SYSMGR_NAND_raw_t nandgrp; /* ALT_SYSMGR_NAND */
24799  volatile ALT_SYSMGR_USB_raw_t usbgrp; /* ALT_SYSMGR_USB */
24800  volatile uint32_t _pad_0x11c_0x13f[9]; /* *UNDEFINED* */
24801  volatile ALT_SYSMGR_ECC_raw_t eccgrp; /* ALT_SYSMGR_ECC */
24802  volatile uint32_t _pad_0x180_0x3ff[160]; /* *UNDEFINED* */
24803  volatile ALT_SYSMGR_PINMUX_raw_t pinmuxgrp; /* ALT_SYSMGR_PINMUX */
24804  volatile uint32_t _pad_0x800_0x4000[3584]; /* *UNDEFINED* */
24805 };
24806
24807 /* The typedef declaration for the raw register contents of register group ALT_SYSMGR. */
24808 typedef volatile struct ALT_SYSMGR_raw_s ALT_SYSMGR_raw_t;
24809 #endif /* __ASSEMBLY__ */
24810
24811
24812 #ifdef __cplusplus
24813 }
24814 #endif /* __cplusplus */
24815 #endif /* __ALTERA_ALT_SYSMGR_H__ */
24816
Definition: alt_sysmgr.h:22405
Definition: alt_sysmgr.h:15607
Definition: alt_sysmgr.h:2851
Definition: alt_sysmgr.h:14182
Definition: alt_sysmgr.h:19777
Definition: alt_sysmgr.h:21018
Definition: alt_sysmgr.h:16507
Definition: alt_sysmgr.h:22770
Definition: alt_sysmgr.h:18247
Definition: alt_sysmgr.h:15832
Definition: alt_sysmgr.h:13057
Definition: alt_sysmgr.h:21091
Definition: alt_sysmgr.h:5459
Definition: alt_sysmgr.h:22843
Definition: alt_sysmgr.h:10057
Definition: alt_sysmgr.h:4890
Definition: alt_sysmgr.h:15457
Definition: alt_sysmgr.h:14032
Definition: alt_sysmgr.h:20872
Definition: alt_sysmgr.h:4391
Definition: alt_sysmgr.h:5473
Definition: alt_sysmgr.h:11632
Definition: alt_sysmgr.h:6954
Definition: alt_sysmgr.h:12157
Definition: alt_sysmgr.h:22624
Definition: alt_sysmgr.h:18391
Definition: alt_sysmgr.h:15682
Definition: alt_sysmgr.h:14257
Definition: alt_sysmgr.h:20945
Definition: alt_sysmgr.h:22697
Definition: alt_sysmgr.h:18175
Definition: alt_sysmgr.h:6081
Definition: alt_sysmgr.h:15907
Definition: alt_sysmgr.h:21310
Definition: alt_sysmgr.h:5913
Definition: alt_sysmgr.h:6633
Definition: alt_sysmgr.h:17959
Definition: alt_sysmgr.h:14107
Definition: alt_sysmgr.h:2056
Definition: alt_sysmgr.h:19266
Definition: alt_sysmgr.h:21383
Definition: alt_sysmgr.h:18319
Definition: alt_sysmgr.h:15757
Definition: alt_sysmgr.h:14332
Definition: alt_sysmgr.h:10582
Definition: alt_sysmgr.h:6642
Definition: alt_sysmgr.h:19339
Definition: alt_sysmgr.h:21164
Definition: alt_sysmgr.h:9393
Definition: alt_sysmgr.h:18974
Definition: alt_sysmgr.h:18103
Definition: alt_sysmgr.h:15982
Definition: alt_sysmgr.h:14482
Definition: alt_sysmgr.h:21237
Definition: alt_sysmgr.h:5653
Definition: alt_sysmgr.h:17887
Definition: alt_sysmgr.h:5175
Definition: alt_sysmgr.h:10507
Definition: alt_sysmgr.h:4491
Definition: alt_sysmgr.h:22186
Definition: alt_sysmgr.h:10432
Definition: alt_sysmgr.h:13657
Definition: alt_sysmgr.h:17311
Definition: alt_sysmgr.h:4746
Definition: alt_sysmgr.h:24072
Definition: alt_sysmgr.h:11857
Definition: alt_sysmgr.h:22259
Definition: alt_sysmgr.h:24309
Definition: alt_sysmgr.h:2080
Definition: alt_sysmgr.h:1375
Definition: alt_sysmgr.h:17815
Definition: alt_sysmgr.h:12007
Definition: alt_sysmgr.h:10207
Definition: alt_sysmgr.h:13132
Definition: alt_sysmgr.h:20726
Definition: alt_sysmgr.h:11782
Definition: alt_sysmgr.h:19120
Definition: alt_sysmgr.h:10132
Definition: alt_sysmgr.h:15532
Definition: alt_sysmgr.h:5420
Definition: alt_sysmgr.h:20799
Definition: alt_sysmgr.h:4078
Definition: alt_sysmgr.h:11557
Definition: alt_sysmgr.h:19193
Definition: alt_sysmgr.h:15157
Definition: alt_sysmgr.h:17743
Definition: alt_sysmgr.h:10357
Definition: alt_sysmgr.h:12982
Definition: alt_sysmgr.h:11182
Definition: alt_sysmgr.h:6608
Definition: alt_sysmgr.h:11932
Definition: alt_sysmgr.h:24001
Definition: alt_sysmgr.h:10282
Definition: alt_sysmgr.h:1952
Definition: alt_sysmgr.h:15382
Definition: alt_sysmgr.h:6108
Definition: alt_sysmgr.h:1253
Definition: alt_sysmgr.h:13207
Definition: alt_sysmgr.h:9205
Definition: alt_sysmgr.h:3121
Definition: alt_sysmgr.h:24214
Definition: alt_sysmgr.h:11707
Definition: alt_sysmgr.h:19047
Definition: alt_sysmgr.h:14707
Definition: alt_sysmgr.h:23646
Definition: alt_sysmgr.h:9907
Definition: alt_sysmgr.h:24776
Definition: alt_sysmgr.h:13432
Definition: alt_sysmgr.h:10732
Definition: alt_sysmgr.h:12832
Definition: alt_sysmgr.h:20288
Definition: alt_sysmgr.h:5250
Definition: alt_sysmgr.h:11482
Definition: alt_sysmgr.h:18828
Definition: alt_sysmgr.h:23859
Definition: alt_sysmgr.h:4051
Definition: alt_sysmgr.h:14632
Definition: alt_sysmgr.h:4593
Definition: alt_sysmgr.h:8616
Definition: alt_sysmgr.h:9832
Definition: alt_sysmgr.h:16057
Definition: alt_sysmgr.h:20361
Definition: alt_sysmgr.h:7296
Definition: alt_sysmgr.h:8436
Definition: alt_sysmgr.h:18901
Definition: alt_sysmgr.h:4601
Definition: alt_sysmgr.h:16207
Definition: alt_sysmgr.h:13282
Definition: alt_sysmgr.h:20142
Definition: alt_sysmgr.h:14782
Definition: alt_sysmgr.h:9982
Definition: alt_sysmgr.h:13507
Definition: alt_sysmgr.h:10657
Definition: alt_sysmgr.h:20215
Definition: alt_sysmgr.h:11407
Definition: alt_sysmgr.h:18755
Definition: alt_sysmgr.h:15007
Definition: alt_sysmgr.h:4570
Definition: alt_sysmgr.h:23208
Definition: alt_sysmgr.h:24742
Definition: alt_sysmgr.h:8796
Definition: alt_sysmgr.h:11032
Definition: alt_sysmgr.h:20580
Definition: alt_sysmgr.h:780
Definition: alt_sysmgr.h:23788
Definition: alt_sysmgr.h:18536
Definition: alt_sysmgr.h:14932
Definition: alt_sysmgr.h:23281
Definition: alt_sysmgr.h:13357
Definition: alt_sysmgr.h:10807
Definition: alt_sysmgr.h:3410
Definition: alt_sysmgr.h:20653
Definition: alt_sysmgr.h:18609
Definition: alt_sysmgr.h:23062
Definition: alt_sysmgr.h:5317
Definition: alt_sysmgr.h:3159
Definition: alt_sysmgr.h:383
Definition: alt_sysmgr.h:13582
Definition: alt_sysmgr.h:12682
Definition: alt_sysmgr.h:5433
Definition: alt_sysmgr.h:20434
Definition: alt_sysmgr.h:6269
Definition: alt_sysmgr.h:11332
Definition: alt_sysmgr.h:4500
Definition: alt_sysmgr.h:15082
Definition: alt_sysmgr.h:23135
Definition: alt_sysmgr.h:10957
Definition: alt_sysmgr.h:215
Definition: alt_sysmgr.h:12457
Definition: alt_sysmgr.h:20507
Definition: alt_sysmgr.h:21748
Definition: alt_sysmgr.h:15307
Definition: alt_sysmgr.h:23500
Definition: alt_sysmgr.h:17527
Definition: alt_sysmgr.h:9738
Definition: alt_sysmgr.h:8252
Definition: alt_sysmgr.h:6985
Definition: alt_sysmgr.h:12232
Definition: alt_sysmgr.h:13807
Definition: alt_sysmgr.h:21821
Definition: alt_sysmgr.h:15232
Definition: alt_sysmgr.h:23573
Definition: alt_sysmgr.h:11107
Definition: alt_sysmgr.h:12607
Definition: alt_sysmgr.h:21602
Definition: alt_sysmgr.h:14857
Definition: alt_sysmgr.h:23354
Definition: alt_sysmgr.h:17671
Definition: alt_sysmgr.h:10882
Definition: alt_sysmgr.h:4468
Definition: alt_sysmgr.h:21675
Definition: alt_sysmgr.h:18682
Definition: alt_sysmgr.h:23427
Definition: alt_sysmgr.h:17455
Definition: alt_sysmgr.h:7952
Definition: alt_sysmgr.h:11257
Definition: alt_sysmgr.h:12757
Definition: alt_sysmgr.h:6993
Definition: alt_sysmgr.h:9686
Definition: alt_sysmgr.h:24519
Definition: alt_sysmgr.h:5014
Definition: alt_sysmgr.h:22040
Definition: alt_sysmgr.h:16807
Definition: alt_sysmgr.h:4952
Definition: alt_sysmgr.h:17239
Definition: alt_sysmgr.h:12532
Definition: alt_sysmgr.h:19996
Definition: alt_sysmgr.h:22113
Definition: alt_sysmgr.h:12082
Definition: alt_sysmgr.h:17599
Definition: alt_sysmgr.h:1780
Definition: alt_sysmgr.h:4811
Definition: alt_sysmgr.h:12907
Definition: alt_sysmgr.h:9718
Definition: alt_sysmgr.h:20069
Definition: alt_sysmgr.h:21894
Definition: alt_sysmgr.h:16357
Definition: alt_sysmgr.h:18463
Definition: alt_sysmgr.h:17383
Definition: alt_sysmgr.h:21967
Definition: alt_sysmgr.h:16282
Definition: alt_sysmgr.h:17167
Definition: alt_sysmgr.h:7117
Definition: alt_sysmgr.h:7476
Definition: alt_sysmgr.h:16132
Definition: alt_sysmgr.h:3146
Definition: alt_sysmgr.h:16951
Definition: alt_sysmgr.h:24285
Definition: alt_sysmgr.h:22916
Definition: alt_sysmgr.h:14407
Definition: alt_sysmgr.h:19558
Definition: alt_sysmgr.h:4088
Definition: alt_sysmgr.h:16432
Definition: alt_sysmgr.h:24143
Definition: alt_sysmgr.h:6117
Definition: alt_sysmgr.h:22989
Definition: alt_sysmgr.h:18031
Definition: alt_sysmgr.h:5395
Definition: alt_sysmgr.h:14557
Definition: alt_sysmgr.h:19631
Definition: alt_sysmgr.h:16657
Definition: alt_sysmgr.h:17095
Definition: alt_sysmgr.h:7656
Definition: alt_sysmgr.h:2088
Definition: alt_sysmgr.h:5109
Definition: alt_sysmgr.h:12382
Definition: alt_sysmgr.h:16879
Definition: alt_sysmgr.h:19412
Definition: alt_sysmgr.h:5628
Definition: alt_sysmgr.h:16582
Definition: alt_sysmgr.h:2381
Definition: alt_sysmgr.h:13882
Definition: alt_sysmgr.h:19485
Definition: alt_sysmgr.h:21456
Definition: alt_sysmgr.h:2955
Definition: alt_sysmgr.h:22478
Definition: alt_sysmgr.h:23717
Definition: alt_sysmgr.h:19850
Definition: alt_sysmgr.h:23930
Definition: alt_sysmgr.h:21529
Definition: alt_sysmgr.h:16732
Definition: alt_sysmgr.h:22551
Definition: alt_sysmgr.h:17023
Definition: alt_sysmgr.h:12307
Definition: alt_sysmgr.h:13732
Definition: alt_sysmgr.h:19923
Definition: alt_sysmgr.h:649
Definition: alt_sysmgr.h:22332
Definition: alt_sysmgr.h:13957
Definition: alt_sysmgr.h:19704
Definition: alt_sysmgr.h:5661
