10. Timer Manager¶
10.1. Introduction¶
The timer manager provides support for timer facilities. The directives provided by the timer manager are:
- rtems_timer_create - Create a timer
- rtems_timer_ident - Get ID of a timer
- rtems_timer_cancel - Cancel a timer
- rtems_timer_delete - Delete a timer
- rtems_timer_fire_after - Fire timer after interval
- rtems_timer_fire_when - Fire timer when specified
- rtems_timer_initiate_server - Initiate server for task-based timers
- rtems_timer_server_fire_after - Fire task-based timer after interval
- rtems_timer_server_fire_when - Fire task-based timer when specified
- rtems_timer_reset - Reset an interval timer
10.2. Background¶
10.2.1. Required Support¶
A clock tick is required to support the functionality provided by this manager.
10.2.2. Timers¶
A timer is an RTEMS object which allows the application to schedule operations to occur at specific times in the future. User supplied timer service routines are invoked by either a clock tick directive or a special Timer Server task when the timer fires. Timer service routines may perform any operations or directives which normally would be performed by the application code which invoked a clock tick directive.
The timer can be used to implement watchdog routines which only fire to denote that an application error has occurred. The timer is reset at specific points in the application to ensure that the watchdog does not fire. Thus, if the application does not reset the watchdog timer, then the timer service routine will fire to indicate that the application has failed to reach a reset point. This use of a timer is sometimes referred to as a “keep alive” or a “deadman” timer.
10.2.3. Timer Server¶
The Timer Server task is responsible for executing the timer service routines associated with all task-based timers. This task executes at a priority specified by rtems_timer_initiate_server() and it may have a priority of zero (the highest priority). In uniprocessor configurations, it is created non-preemptible.
By providing a mechanism where timer service routines execute in task rather than interrupt space, the application is allowed a bit more flexibility in what operations a timer service routine can perform. For example, the Timer Server can be configured to have a floating point context in which case it would be safe to perform floating point operations from a task-based timer. Most of the time, executing floating point instructions from an interrupt service routine is not considered safe. The timer service routines invoked by the Timer Server may block, however, since this blocks the Timer Server itself, other timer service routines that are already pending do not run until the blocked timer service routine finished its work.
The Timer Server is designed to remain blocked until a task-based timer fires. This reduces the execution overhead of the Timer Server.
10.2.4. Timer Service Routines¶
The timer service routine should adhere to C calling conventions and have a prototype similar to the following:
rtems_timer_service_routine user_routine(
rtems_id timer_id,
void *user_data
Where the timer_id parameter is the RTEMS object ID of the timer which is being fired and user_data is a pointer to user-defined information which may be utilized by the timer service routine. The argument user_data may be NULL.
10.3. Operations¶
10.3.1. Creating a Timer¶
The rtems_timer_create directive creates a timer by allocating a Timer
Control Block (TMCB), assigning the timer a user-specified name, and assigning
it a timer ID. Newly created timers do not have a timer service routine
associated with them and are not active.
10.3.2. Obtaining Timer IDs¶
When a timer is created, RTEMS generates a unique timer ID and assigns it to
the created timer until it is deleted. The timer ID may be obtained by either
of two methods. First, as the result of an invocation of the
rtems_timer_create directive, the timer ID is stored in a user provided
location. Second, the timer ID may be obtained later using the
rtems_timer_ident directive. The timer ID is used by other directives to
manipulate this timer.
10.3.3. Initiating an Interval Timer¶
The rtems_timer_fire_after and rtems_timer_server_fire_after directives
initiate a timer to fire a user provided timer service routine after the
specified number of clock ticks have elapsed. When the interval has elapsed,
the timer service routine will be invoked from a clock tick
directive if it was initiated by the rtems_timer_fire_after directive and
from the Timer Server task if initiated by the
rtems_timer_server_fire_after directive.
10.3.4. Initiating a Time of Day Timer¶
The rtems_timer_fire_when and rtems_timer_server_fire_when directive
initiate a timer to fire a user provided timer service routine when the
specified time of day has been reached. When the interval has elapsed, the
timer service routine will be invoked from a clock tick directive
by the rtems_timer_fire_when directive and from the Timer Server task if
initiated by the rtems_timer_server_fire_when directive.
10.3.5. Canceling a Timer¶
The rtems_timer_cancel directive is used to halt the specified timer. Once
canceled, the timer service routine will not fire unless the timer is
reinitiated. The timer can be reinitiated using the rtems_timer_reset,
rtems_timer_fire_after, and rtems_timer_fire_when directives.
10.3.6. Resetting a Timer¶
The rtems_timer_reset directive is used to restore an interval timer
initiated by a previous invocation of rtems_timer_fire_after or
rtems_timer_server_fire_after to its original interval length. If the
timer has not been used or the last usage of this timer was by the
rtems_timer_fire_when or rtems_timer_server_fire_when directive, then
an error is returned. The timer service routine is not changed or fired by
this directive.
10.3.7. Initiating the Timer Server¶
The rtems_timer_initiate_server directive is used to allocate and start the
execution of the Timer Server task. The application can specify both the stack
size and attributes of the Timer Server. The Timer Server executes at a
priority higher than any application task and thus the user can expect to be
preempted as the result of executing the rtems_timer_initiate_server
directive.
10.3.8. Deleting a Timer¶
The rtems_timer_delete directive is used to delete a timer. If the timer
is running and has not expired, the timer is automatically canceled. The
timer’s control block is returned to the TMCB free list when it is deleted. A
timer can be deleted by a task other than the task which created the timer.
Any subsequent references to the timer’s name and ID are invalid.
10.4. Directives¶
This section details the timer manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
10.4.1. TIMER_CREATE - Create a timer¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_create( rtems_name name, rtems_id *id );
- DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFULtimer created successfully RTEMS_INVALID_ADDRESSidis NULLRTEMS_INVALID_NAMEinvalid timer name RTEMS_TOO_MANYtoo many timers created - DESCRIPTION:
- This directive creates a timer. The assigned timer id is returned in id. This id is used to access the timer with other timer manager directives. For control and maintenance of the timer, RTEMS allocates a TMCB from the local TMCB free pool and initializes it.
- NOTES:
This directive will obtain the allocator mutex and may cause the calling task to be preempted.
In SMP configurations, the processor of the currently executing thread determines the processor used for the created timer. During the life-time of the timer this processor is used to manage the timer internally.
10.4.2. TIMER_IDENT - Get ID of a timer¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_ident( rtems_name name, rtems_id *id );
RTEMS_SUCCESSFULtimer identified successfully RTEMS_INVALID_ADDRESSidis NULLRTEMS_INVALID_NAMEtimer name not found - DESCRIPTION:
- This directive obtains the timer id associated with the timer name to be acquired. If the timer name is not unique, then the timer id will match one of the timers with that name. However, this timer id is not guaranteed to correspond to the desired timer. The timer id is used to access this timer in other timer related directives.
- NOTES:
- This directive will not cause the running task to be preempted.
10.4.3. TIMER_CANCEL - Cancel a timer¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_cancel( rtems_id id );
RTEMS_SUCCESSFULtimer canceled successfully RTEMS_INVALID_IDinvalid timer id - DESCRIPTION:
- This directive cancels the timer id. This timer will be reinitiated by the
next invocation of
rtems_timer_reset,rtems_timer_fire_after, orrtems_timer_fire_whenwith this id. - NOTES:
10.4.4. TIMER_DELETE - Delete a timer¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_delete( rtems_id id );
RTEMS_SUCCESSFULtimer deleted successfully RTEMS_INVALID_IDinvalid timer id - DESCRIPTION:
- This directive deletes the timer specified by id. If the timer is running, it is automatically canceled. The TMCB for the deleted timer is reclaimed by RTEMS.
- NOTES:
A timer can be deleted by a task other than the task which created the timer.
10.4.5. TIMER_FIRE_AFTER - Fire timer after interval¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_fire_after( rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data );
RTEMS_SUCCESSFULtimer initiated successfully RTEMS_INVALID_ADDRESSroutineis NULLRTEMS_INVALID_IDinvalid timer id RTEMS_INVALID_NUMBERinvalid interval - DESCRIPTION:
- This directive initiates the timer specified by id. If the timer is running, it is automatically canceled before being initiated. The timer is scheduled to fire after an interval ticks clock ticks has passed. When the timer fires, the timer service routine routine will be invoked with the argument user_data.
- NOTES:
10.4.6. TIMER_FIRE_WHEN - Fire timer when specified¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_fire_when( rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data );
RTEMS_SUCCESSFULtimer initiated successfully RTEMS_INVALID_ADDRESSroutineis NULLRTEMS_INVALID_ADDRESSwall_timeis NULLRTEMS_INVALID_IDinvalid timer id RTEMS_NOT_DEFINEDsystem date and time is not set RTEMS_INVALID_CLOCKinvalid time of day - DESCRIPTION:
- This directive initiates the timer specified by id. If the timer is running, it is automatically canceled before being initiated. The timer is scheduled to fire at the time of day specified by wall_time. When the timer fires, the timer service routine routine will be invoked with the argument user_data.
- NOTES:
10.4.7. TIMER_INITIATE_SERVER - Initiate server for task-based timers¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_initiate_server( uint32_t priority, uint32_t stack_size, rtems_attribute attribute_set );
RTEMS_SUCCESSFULTimer Server initiated successfully RTEMS_TOO_MANYtoo many tasks created - DESCRIPTION:
- This directive initiates the Timer Server task. This task is responsible
for executing all timers initiated via the
rtems_timer_server_fire_afterorrtems_timer_server_fire_whendirectives. - NOTES:
This directive could cause the calling task to be preempted.
The Timer Server task is created using the
rtems_task_createservice and must be accounted for when configuring the system.Even through this directive invokes the
rtems_task_createandrtems_task_startdirectives, it should only fail due to resource allocation problems.
10.4.8. TIMER_SERVER_FIRE_AFTER - Fire task-based timer after interval¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_server_fire_after( rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data );
RTEMS_SUCCESSFULtimer initiated successfully RTEMS_INVALID_ADDRESSroutineis NULLRTEMS_INVALID_IDinvalid timer id RTEMS_INVALID_NUMBERinvalid interval RTEMS_INCORRECT_STATETimer Server not initiated - DESCRIPTION:
This directive initiates the timer specified by id and specifies that when it fires it will be executed by the Timer Server.
- NOTES:
10.4.9. TIMER_SERVER_FIRE_WHEN - Fire task-based timer when specified¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_server_fire_when( rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data );
RTEMS_SUCCESSFULtimer initiated successfully RTEMS_INVALID_ADDRESSroutineis NULLRTEMS_INVALID_ADDRESSwall_timeis NULLRTEMS_INVALID_IDinvalid timer id RTEMS_NOT_DEFINEDsystem date and time is not set RTEMS_INVALID_CLOCKinvalid time of day RTEMS_INCORRECT_STATETimer Server not initiated - DESCRIPTION:
- NOTES:
10.4.10. TIMER_RESET - Reset an interval timer¶
- CALLING SEQUENCE:
rtems_status_code rtems_timer_reset( rtems_id id );
RTEMS_SUCCESSFULtimer reset successfully RTEMS_INVALID_IDinvalid timer id RTEMS_NOT_DEFINEDattempted to reset a when or newly created timer - DESCRIPTION:
- This directive resets the timer associated with id. This timer must have
been previously initiated with either the
rtems_timer_fire_afterorrtems_timer_server_fire_afterdirective. If active the timer is canceled, after which the timer is reinitiated using the same interval and timer service routine which the originalrtems_timer_fire_afterorrtems_timer_server_fire_afterdirective used. - NOTES:
If the timer has not been used or the last usage of this timer was by a
rtems_timer_fire_whenorrtems_timer_server_fire_whendirective, then theRTEMS_NOT_DEFINEDerror is returned.Restarting a cancelled after timer results in the timer being reinitiated with its previous timer service routine and interval.
