39. Example Application
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
*  This file contains an example of a simple RTEMS
*  application.  It instantiates the RTEMS Configuration
*  Information using confdef.h and contains two tasks:
*  a user initialization task and a simple task.
rtems_task user_application(rtems_task_argument argument);
rtems_task init_task(
    rtems_task_argument ignored
    rtems_id          tid;
    rtems_status_code status;
    rtems_name        name;
    name = rtems_build_name( 'A', 'P', 'P', '1' )
    status = rtems_task_create(
        name, 1, RTEMS_MINIMUM_STACK_SIZE,
        RTEMS_NO_PREEMPT, RTEMS_FLOATING_POINT, &tid
    if ( status != RTEMS_SUCCESSFUL ) {
        printf( "rtems_task_create failed with status of %d.\n", status );
        exit( 1 );
    status = rtems_task_start( tid, user_application, 0 );
        printf( "rtems_task_start failed with status of %d.\n", status );
        exit( 1 );
    status = rtems_task_delete( SELF );    /* should not return */
    printf( "rtems_task_delete returned with status of %d.\n", status );
    exit( 1 );
    /* application specific initialization goes here */
    while ( 1 )  {              /* infinite loop */
        /*  APPLICATION CODE GOES HERE
         *  This code will typically include at least one
         *  directive which causes the calling task to
         *  give up the processor.
/* The Console Driver supplies Standard I/O. */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
/* The Clock Driver supplies the clock tick. */
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_INIT_TASK_NAME rtems_build_name( 'E', 'X', 'A', 'M' )
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#include <rtems/confdefs.h>
