14. Message Manager¶
14.1. Introduction¶
The message manager provides communication and synchronization capabilities using RTEMS message queues. The directives provided by the message manager are:
- rtems_message_queue_create - Create a queue
- rtems_message_queue_ident - Get ID of a queue
- rtems_message_queue_delete - Delete a queue
- rtems_message_queue_send - Put message at rear of a queue
- rtems_message_queue_urgent - Put message at front of a queue
- rtems_message_queue_broadcast - Broadcast N messages to a queue
- rtems_message_queue_receive - Receive message from a queue
- rtems_message_queue_get_number_pending - Get number of messages pending on a queue
- rtems_message_queue_flush - Flush all messages on a queue
14.2. Background¶
14.2.1. Messages¶
A message is a variable length buffer where information can be stored to support communication. The length of the message and the information stored in that message are user-defined and can be actual data, pointer(s), or empty.
14.2.2. Message Queues¶
A message queue permits the passing of messages among tasks and ISRs. Message
queues can contain a variable number of messages. Normally messages are sent
to and received from the queue in FIFO order using the
rtems_message_queue_send directive. However, the
rtems_message_queue_urgent directive can be used to place messages at the
head of a queue in LIFO order.
Synchronization can be accomplished when a task can wait for a message to arrive at a queue. Also, a task may poll a queue for the arrival of a message.
The maximum length message which can be sent is set on a per message queue basis. The message content must be copied in general to/from an internal buffer of the message queue or directly to a peer in certain cases. This copy operation is performed with interrupts disabled. So it is advisable to keep the messages as short as possible.
14.2.3. Building a Message Queue Attribute Set¶
In general, an attribute set is built by a bitwise OR of the desired attribute components. The set of valid message queue attributes is provided in the following table:
RTEMS_FIFO |
tasks wait by FIFO (default) |
RTEMS_PRIORITY |
tasks wait by priority |
RTEMS_LOCAL |
local message queue (default) |
RTEMS_GLOBAL |
global message queue |
An attribute listed as a default is not required to appear in the attribute
list, although it is a good programming practice to specify default attributes.
If all defaults are desired, the attribute RTEMS_DEFAULT_ATTRIBUTES should
be specified on this call.
This example demonstrates the attribute_set parameter needed to create a local
message queue with the task priority waiting queue discipline. The
attribute_set parameter to the rtems_message_queue_create directive could
be either RTEMS_PRIORITY or RTEMS_LOCAL | RTEMS_PRIORITY. The
attribute_set parameter can be set to RTEMS_PRIORITY because
RTEMS_LOCAL is the default for all created message queues. If a similar
message queue were to be known globally, then the attribute_set parameter would
be RTEMS_GLOBAL | RTEMS_PRIORITY.
14.2.4. Building a MESSAGE_QUEUE_RECEIVE Option Set¶
In general, an option is built by a bitwise OR of the desired option
components. The set of valid options for the rtems_message_queue_receive
directive are listed in the following table:
RTEMS_WAIT |
task will wait for a message (default) |
RTEMS_NO_WAIT |
task should not wait |
An option listed as a default is not required to appear in the option OR list,
although it is a good programming practice to specify default options. If all
defaults are desired, the option RTEMS_DEFAULT_OPTIONS should be specified
on this call.
This example demonstrates the option parameter needed to poll for a message to
arrive. The option parameter passed to the rtems_message_queue_receive
directive should be RTEMS_NO_WAIT.
14.3. Operations¶
14.3.1. Creating a Message Queue¶
The rtems_message_queue_create directive creates a message queue with the
user-defined name. The user specifies the maximum message size and maximum
number of messages which can be placed in the message queue at one time. The
user may select FIFO or task priority as the method for placing waiting tasks
in the task wait queue. RTEMS allocates a Queue Control Block (QCB) from the
QCB free list to maintain the newly created queue as well as memory for the
message buffer pool associated with this message queue. RTEMS also generates a
message queue ID which is returned to the calling task.
For GLOBAL message queues, the maximum message size is effectively limited to the longest message which the MPCI is capable of transmitting.
14.3.2. Obtaining Message Queue IDs¶
When a message queue is created, RTEMS generates a unique message queue ID.
The message queue ID may be obtained by either of two methods. First, as the
result of an invocation of the rtems_message_queue_create directive, the
queue ID is stored in a user provided location. Second, the queue ID may be
obtained later using the rtems_message_queue_ident directive. The queue ID
is used by other message manager directives to access this message queue.
14.3.3. Receiving a Message¶
The rtems_message_queue_receive directive attempts to retrieve a message
from the specified message queue. If at least one message is in the queue,
then the message is removed from the queue, copied to the caller’s message
buffer, and returned immediately along with the length of the message. When
messages are unavailable, one of the following situations applies:
- By default, the calling task will wait forever for the message to arrive.
- Specifying the
RTEMS_NO_WAIToption forces an immediate return with an error status code. - Specifying a timeout limits the period the task will wait before returning with an error status.
If the task waits for a message, then it is placed in the message queue’s task wait queue in either FIFO or task priority order. All tasks waiting on a message queue are returned an error code when the message queue is deleted.
14.3.4. Sending a Message¶
Messages can be sent to a queue with the rtems_message_queue_send and
rtems_message_queue_urgent directives. These directives work identically
when tasks are waiting to receive a message. A task is removed from the task
waiting queue, unblocked, and the message is copied to a waiting task’s message
buffer.
When no tasks are waiting at the queue, rtems_message_queue_send places the
message at the rear of the message queue, while rtems_message_queue_urgent
places the message at the front of the queue. The message is copied to a
message buffer from this message queue’s buffer pool and then placed in the
message queue. Neither directive can successfully send a message to a message
queue which has a full queue of pending messages.
14.3.5. Broadcasting a Message¶
The rtems_message_queue_broadcast directive sends the same message to every
task waiting on the specified message queue as an atomic operation. The
message is copied to each waiting task’s message buffer and each task is
unblocked. The number of tasks which were unblocked is returned to the caller.
14.3.6. Deleting a Message Queue¶
The rtems_message_queue_delete directive removes a message queue from the
system and frees its control block as well as the memory associated with this
message queue’s message buffer pool. A message queue can be deleted by any
local task that knows the message queue’s ID. As a result of this directive,
all tasks blocked waiting to receive a message from the message queue will be
readied and returned a status code which indicates that the message queue was
deleted. Any subsequent references to the message queue’s name and ID are
invalid. Any messages waiting at the message queue are also deleted and
deallocated.
14.4. Directives¶
This section details the message manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
14.4.1. MESSAGE_QUEUE_CREATE - Create a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_create( rtems_name name, uint32_t count, size_t max_message_size, rtems_attribute attribute_set, rtems_id *id );
- DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFULqueue created successfully RTEMS_INVALID_NAMEinvalid queue name RTEMS_INVALID_ADDRESSidis NULLRTEMS_INVALID_NUMBERinvalid message count RTEMS_INVALID_SIZEinvalid message size RTEMS_TOO_MANYtoo many queues created RTEMS_UNSATISFIEDunable to allocate message buffers RTEMS_MP_NOT_CONFIGUREDmultiprocessing not configured RTEMS_TOO_MANYtoo many global objects - DESCRIPTION:
This directive creates a message queue which resides on the local node with the user-defined name specified in name. For control and maintenance of the queue, RTEMS allocates and initializes a QCB. Memory is allocated from the RTEMS Workspace for the specified count of messages, each of max_message_size bytes in length. The RTEMS-assigned queue id, returned in id, is used to access the message queue.
Specifying
RTEMS_PRIORITYin attribute_set causes tasks waiting for a message to be serviced according to task priority. WhenRTEMS_FIFOis specified, waiting tasks are serviced in First In-First Out order.- NOTES:
This directive will not cause the calling task to be preempted.
The following message queue attribute constants are defined by RTEMS:
RTEMS_FIFOtasks wait by FIFO (default) RTEMS_PRIORITYtasks wait by priority RTEMS_LOCALlocal message queue (default) RTEMS_GLOBALglobal message queue Message queues should not be made global unless remote tasks must interact with the created message queue. This is to avoid the system overhead incurred by the creation of a global message queue. When a global message queue is created, the message queue’s name and id must be transmitted to every node in the system for insertion in the local copy of the global object table.
The total number of global objects, including message queues, is limited by the
maximum_global_objectsfield in the configuration table.
14.4.2. MESSAGE_QUEUE_IDENT - Get ID of a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_ident( rtems_name name, uint32_t node, rtems_id *id );
RTEMS_SUCCESSFULqueue identified successfully RTEMS_INVALID_ADDRESSidis NULLRTEMS_INVALID_NAMEqueue name not found RTEMS_INVALID_NODEinvalid node id - DESCRIPTION:
- This directive obtains the queue id associated with the queue name specified in name. If the queue name is not unique, then the queue id will match one of the queues with that name. However, this queue id is not guaranteed to correspond to the desired queue. The queue id is used with other message related directives to access the message queue.
- NOTES:
This directive will not cause the running task to be preempted.
If node is
RTEMS_SEARCH_ALL_NODES, all nodes are searched with the local node being searched first. All other nodes are searched with the lowest numbered node searched first.If node is a valid node number which does not represent the local node, then only the message queues exported by the designated node are searched.
This directive does not generate activity on remote nodes. It accesses only the local copy of the global object table.
14.4.3. MESSAGE_QUEUE_DELETE - Delete a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_delete( rtems_id id );
RTEMS_SUCCESSFULqueue deleted successfully RTEMS_INVALID_IDinvalid queue id RTEMS_ILLEGAL_ON_REMOTE_OBJECTcannot delete remote queue - DESCRIPTION:
- This directive deletes the message queue specified by
id. As a result of this directive, all tasks blocked waiting to receive a message from this queue will be readied and returned a status code which indicates that the message queue was deleted. If no tasks are waiting, but the queue contains messages, then RTEMS returns these message buffers back to the system message buffer pool. The QCB for this queue as well as the memory for the message buffers is reclaimed by RTEMS. - NOTES:
The calling task will be preempted if its preemption mode is enabled and one or more local tasks with a higher priority than the calling task are waiting on the deleted queue. The calling task will NOT be preempted if the tasks that are waiting are remote tasks.
The calling task does not have to be the task that created the queue, although the task and queue must reside on the same node.
When the queue is deleted, any messages in the queue are returned to the free message buffer pool. Any information stored in those messages is lost.
When a global message queue is deleted, the message queue id must be transmitted to every node in the system for deletion from the local copy of the global object table.
Proxies, used to represent remote tasks, are reclaimed when the message queue is deleted.
14.4.4. MESSAGE_QUEUE_SEND - Put message at rear of a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_send( rtems_id id, const void *buffer, size_t size );
RTEMS_SUCCESSFULmessage sent successfully RTEMS_INVALID_IDinvalid queue id RTEMS_INVALID_SIZEinvalid message size RTEMS_INVALID_ADDRESSbufferis NULLRTEMS_UNSATISFIEDout of message buffers RTEMS_TOO_MANYqueue’s limit has been reached - DESCRIPTION:
- This directive sends the message buffer of size bytes in length to the queue specified by id. If a task is waiting at the queue, then the message is copied to the waiting task’s buffer and the task is unblocked. If no tasks are waiting at the queue, then the message is copied to a message buffer which is obtained from this message queue’s message buffer pool. The message buffer is then placed at the rear of the queue.
- NOTES:
The calling task will be preempted if it has preemption enabled and a higher priority task is unblocked as the result of this directive.
Sending a message to a global message queue which does not reside on the local node will generate a request to the remote node to post the message on the specified message queue.
If the task to be unblocked resides on a different node from the message queue, then the message is forwarded to the appropriate node, the waiting task is unblocked, and the proxy used to represent the task is reclaimed.
14.4.5. MESSAGE_QUEUE_URGENT - Put message at front of a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_urgent( rtems_id id, const void *buffer, size_t size );
- This directive sends the message buffer of size bytes in length to the queue specified by id. If a task is waiting on the queue, then the message is copied to the task’s buffer and the task is unblocked. If no tasks are waiting on the queue, then the message is copied to a message buffer which is obtained from this message queue’s message buffer pool. The message buffer is then placed at the front of the queue.
- NOTES:
Sending a message to a global message queue which does not reside on the local node will generate a request telling the remote node to post the message on the specified message queue.
14.4.6. MESSAGE_QUEUE_BROADCAST - Broadcast N messages to a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_broadcast( rtems_id id, const void *buffer, size_t size, uint32_t *count );
RTEMS_SUCCESSFULmessage broadcasted successfully RTEMS_INVALID_IDinvalid queue id RTEMS_INVALID_ADDRESSbufferis NULLRTEMS_INVALID_ADDRESScountis NULLRTEMS_INVALID_SIZEinvalid message size - DESCRIPTION:
- This directive causes all tasks that are waiting at the queue specified by id to be unblocked and sent the message contained in buffer. Before a task is unblocked, the message buffer of size byes in length is copied to that task’s message buffer. The number of tasks that were unblocked is returned in count.
- NOTES:
The execution time of this directive is directly related to the number of tasks waiting on the message queue, although it is more efficient than the equivalent number of invocations of
rtems_message_queue_send.Broadcasting a message to a global message queue which does not reside on the local node will generate a request telling the remote node to broadcast the message to the specified message queue.
When a task is unblocked which resides on a different node from the message queue, a copy of the message is forwarded to the appropriate node, the waiting task is unblocked, and the proxy used to represent the task is reclaimed.
14.4.7. MESSAGE_QUEUE_RECEIVE - Receive message from a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_receive( rtems_id id, void *buffer, size_t *size, rtems_option option_set, rtems_interval timeout );
RTEMS_SUCCESSFULmessage received successfully RTEMS_INVALID_IDinvalid queue id RTEMS_INVALID_ADDRESSbufferis NULLRTEMS_INVALID_ADDRESSsizeis NULLRTEMS_UNSATISFIEDqueue is empty RTEMS_TIMEOUTtimed out waiting for message RTEMS_OBJECT_WAS_DELETEDqueue deleted while waiting - DESCRIPTION:
This directive receives a message from the message queue specified in id. The
RTEMS_WAITandRTEMS_NO_WAIToptions of the options parameter allow the calling task to specify whether to wait for a message to become available or return immediately. For either option, if there is at least one message in the queue, then it is copied to buffer, size is set to return the length of the message in bytes, and this directive returns immediately with a successful return code. The buffer has to be big enough to receive a message of the maximum length with respect to this message queue.If the calling task chooses to return immediately and the queue is empty, then a status code indicating this condition is returned. If the calling task chooses to wait at the message queue and the queue is empty, then the calling task is placed on the message wait queue and blocked. If the queue was created with the
RTEMS_PRIORITYoption specified, then the calling task is inserted into the wait queue according to its priority. But, if the queue was created with theRTEMS_FIFOoption specified, then the calling task is placed at the rear of the wait queue.A task choosing to wait at the queue can optionally specify a timeout value in the timeout parameter. The timeout parameter specifies the maximum interval to wait before the calling task desires to be unblocked. If it is set to
RTEMS_NO_TIMEOUT, then the calling task will wait forever.- NOTES:
The following message receive option constants are defined by RTEMS:
RTEMS_WAITtask will wait for a message (default) RTEMS_NO_WAITtask should not wait Receiving a message from a global message queue which does not reside on the local node will generate a request to the remote node to obtain a message from the specified message queue. If no message is available and
RTEMS_WAITwas specified, then the task must be blocked until a message is posted. A proxy is allocated on the remote node to represent the task until the message is posted.A clock tick is required to support the timeout functionality of this directive.
14.4.8. MESSAGE_QUEUE_GET_NUMBER_PENDING - Get number of messages pending on a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_get_number_pending( rtems_id id, uint32_t *count );
RTEMS_SUCCESSFULnumber of messages pending returned successfully RTEMS_INVALID_ADDRESScountis NULLRTEMS_INVALID_IDinvalid queue id - DESCRIPTION:
- This directive returns the number of messages pending on this message queue in count. If no messages are present on the queue, count is set to zero.
- NOTES:
- Getting the number of pending messages on a global message queue which does not reside on the local node will generate a request to the remote node to actually obtain the pending message count for the specified message queue.
14.4.9. MESSAGE_QUEUE_FLUSH - Flush all messages on a queue¶
- CALLING SEQUENCE:
rtems_status_code rtems_message_queue_flush( rtems_id id, uint32_t *count );
RTEMS_SUCCESSFULmessage queue flushed successfully RTEMS_INVALID_ADDRESScountis NULLRTEMS_INVALID_IDinvalid queue id - DESCRIPTION:
- This directive removes all pending messages from the specified queue id. The number of messages removed is returned in count. If no messages are present on the queue, count is set to zero.
- NOTES:
- Flushing all messages on a global message queue which does not reside on the local node will generate a request to the remote node to actually flush the specified message queue.
