21. Services Provided by C Library (libc)#
21.1. Introduction#
This section lists the routines that provided by the Newlib C Library.
21.2. Standard Utility Functions (stdlib.h)#
abort- Abnormal termination of a programabs- Integer absolute value (magnitude)assert- Macro for Debugging Diagnosticsatexit- Request execution of functions at program exitat_quick_exit- Request execution of functions at quick program exitatof- String to double or floatatoi- String to integerbsearch- Binary searchcalloc- Allocate space for arraysdiv- Divide two integersecvtbuf- Double or float to string of digitsecvt- Double or float to string of digits (malloc result)__env_lock- Lock environment list for getenv and setenvgvcvt- Format double or float as stringexit- End program executiongetenv- Look up environment variablelabs- Long integer absolute value (magnitude)ldiv- Divide two long integersmalloc- Allocate memoryrealloc- Reallocate memoryfree- Free previously allocated memorymallinfo- Get information about allocated memory__malloc_lock- Lock memory pool for malloc and freembstowcs- Minimal multibyte string to wide string convertermblen- Minimal multibyte lengthmbtowc- Minimal multibyte to wide character converterqsort- Sort an arrayquick_exit- Quick program termination without full cleanuprand- Pseudo-random numbersstrtod- String to double or floatstrtol- String to longstrtoul- String to unsigned longsystem- Execute command stringwcstombs- Minimal wide string to multibyte string converterwctomb- Minimal wide character to multibyte converter
21.3. Character Type Macros and Functions (ctype.h)#
isalnum- Alphanumeric character predicateisalpha- Alphabetic character predicateisascii- ASCII character predicateiscntrl- Control character predicateisdigit- Decimal digit predicateislower- Lower-case character predicateisprint- Printable character predicates (isprint, isgraph)ispunct- Punctuation character predicateisspace- Whitespace character predicateisupper- Uppercase character predicateisxdigit- Hexadecimal digit predicatetoascii- Force integers to ASCII rangetolower- Translate characters to lower casetoupper- Translate characters to upper case
21.4. Input and Output (stdio.h)#
clearerr- Clear file or stream error indicatorfclose- Close a filefeof- Test for end of fileferror- Test whether read/write error has occurredfflush- Flush buffered file outputfgetc- Get a character from a file or streamfgetpos- Record position in a stream or filefgets- Get character string from a file or streamfiprintf- Write formatted output to file (integer only)fopen- Open a filefdopen- Turn an open file into a streamfputc- Write a character on a stream or filefputs- Write a character string in a file or streamfread- Read array elements from a filefreopen- Open a file using an existing file descriptorfseek- Set file positionfsetpos- Restore position of a stream or fileftell- Return position in a stream or filefwrite- Write array elements from memory to a file or streamgetc- Get a character from a file or stream (macro)getchar- Get a character from standard input (macro)gets- Get character string from standard input (obsolete)iprintf- Write formatted output (integer only)mktemp- Generate unused file nameperror- Print an error message on standard errorputc- Write a character on a stream or file (macro)putchar- Write a character on standard output (macro)puts- Write a character string on standard outputremove- Delete a file’s namerename- Rename a filerewind- Reinitialize a file or streamsetbuf- Specify full buffering for a file or streamsetvbuf- Specify buffering for a file or streamsiprintf- Write formatted output (integer only)printf- Write formatted outputscanf- Scan and format inputtmpfile- Create a temporary filetmpnam- Generate name for a temporary filevprintf- Format variable argument list
21.5. Strings and Memory (string.h)#
bcmp- Compare two memory areasbcopy- Copy memory regionsbzero- Initialize memory to zeroindex- Search for character in stringmemchr- Find character in memorymemcmp- Compare two memory areasmemcpy- Copy memory regionsmemmove- Move possibly overlapping memorymemset- Set an area of memoryrindex- Reverse search for character in stringstrcasecmp- Compare strings ignoring casestrcat- Concatenate stringsstrchr- Search for character in stringstrcmp- Character string comparestrcoll- Locale specific character string comparestrcpy- Copy stringstrcspn- Count chars not in stringstrerror- Convert error number to stringstrlen- Character string lengthstrlwr- Convert string to lower casestrncasecmp- Compare strings ignoring casestrncat- Concatenate stringsstrncmp- Character string comparestrncpy- Counted copy stringstrpbrk- Find chars in stringstrrchr- Reverse search for character in stringstrspn- Find initial matchstrstr- Find string segmentstrtok- Get next token from a stringstrupr- Convert string to upper casestrxfrm- Transform string
21.6. Signal Handling (signal.h)#
raise- Send a signalsignal- Specify handler subroutine for a signal
21.7. Time Functions (time.h)#
asctime- Format time as stringclock- Cumulative processor timectime- Convert time to local and format as stringdifftime- Subtract two timesgmtime- Convert time to UTC (GMT) traditional representationlocaltime- Convert time to local representationmktime- Convert time to arithmetic representationstrftime- Flexible calendar time formattertime- Get current calendar time (as single number)
21.8. Locale (locale.h)#
setlocale- Select or query locale
21.9. Reentrant Versions of Functions#
Equivalent for errno variable: -
errno_r- XXXLocale functions:
localeconv_r- XXXsetlocale_r- XXX
Equivalents for stdio variables:
stdin_r- XXXstdout_r- XXXstderr_r- XXX
Stdio functions:
fdopen_r- XXXperror_r- XXXtempnam_r- XXXfopen_r- XXXputchar_r- XXXtmpnam_r- XXXgetchar_r- XXXputs_r- XXXtmpfile_r- XXXgets_r- XXXremove_r- XXXvfprintf_r- XXXiprintf_r- XXXrename_r- XXXvsnprintf_r- XXXmkstemp_r- XXXsnprintf_r- XXXvsprintf_r- XXXmktemp_t- XXXsprintf_r- XXX
Signal functions:
init_signal_r- XXXsignal_r- XXXkill_r- XXX_sigtramp_r- XXXraise_r- XXX
Stdlib functions:
calloc_r- XXXmblen_r- XXXsrand_r- XXXdtoa_r- XXXmbstowcs_r- XXXstrtod_r- XXXfree_r- XXXmbtowc_r- XXXstrtol_r- XXXgetenv_r- XXXmemalign_r- XXXstrtoul_r- XXXmallinfo_r- XXXmstats_r- XXXsystem_r- XXXmalloc_r- XXXrand_r- XXXwcstombs_r- XXXmalloc_r- XXXrealloc_r- XXXwctomb_r- XXXmalloc_stats_r- XXXsetenv_r- XXX
String functions:
strtok_r- XXX
System functions:
close_r- XXXlink_r- XXXunlink_r- XXXexecve_r- XXXlseek_r- XXXwait_r- XXXfcntl_r- XXXopen_r- XXXwrite_r- XXXfork_r- XXXread_r- XXXfstat_r- XXXsbrk_r- XXXgettimeofday_r- XXXstat_r- XXXgetpid_r- XXXtimes_r- XXX
Time function:
asctime_r- XXX
21.10. Miscellaneous Macros and Functions#
unctrl- Return printable representation of a character
21.11. Variable Argument Lists#
Stdarg (stdarg.h):
va_start- XXXva_arg- XXXva_end- XXX
Vararg (varargs.h):
va_alist- XXXva_start-trad- XXXva_arg-trad- XXXva_end-trad- XXX
21.12. Reentrant System Calls#
open_r- XXXclose_r- XXXlseek_r- XXXread_r- XXXwrite_r- XXXfork_r- XXXwait_r- XXXstat_r- XXXfstat_r- XXXlink_r- XXXunlink_r- XXXsbrk_r- XXX
