12. Condition Variable Manager#
12.1. Introduction#
The condition variable manager …
The directives provided by the condition variable manager are:
  • [pthread_condattr_init] - Initialize a Condition Variable Attribute Set
  • [pthread_condattr_destroy] - Destroy a Condition Variable Attribute Set
  • [pthread_condattr_setpshared] - Set Process Shared Attribute
  • [pthread_condattr_getpshared] - Get Process Shared Attribute
  • [pthread_cond_init] - Initialize a Condition Variable
  • [pthread_cond_destroy] - Destroy a Condition Variable
  • [pthread_cond_signal] - Signal a Condition Variable
  • [pthread_cond_broadcast] - Broadcast a Condition Variable
  • [pthread_cond_wait] - Wait on a Condition Variable
  • [pthread_cond_timedwait] - With with Timeout a Condition Variable
  • [pthread_cond_clockwait] - Wait on a Condition Variable with Timeout against the chosen clock
12.2. Background#
There is currently no text in this section.
12.3. Operations#
12.4. Directives#
This section details the condition variable manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
12.4.1. pthread_condattr_init - Initialize a Condition Variable Attribute Set#
CALLING SEQUENCE:
#include <pthread.h>
int pthread_condattr_init(
    pthread_condattr_t *attr
STATUS CODES:
    • ENOMEM
    • Insufficient memory is available to initialize the condition variable attributes object.
DESCRIPTION:
NOTES:
12.4.2. pthread_condattr_destroy - Destroy a Condition Variable Attribute Set#
CALLING SEQUENCE:
int pthread_condattr_destroy(
STATUS CODES:
EINVAL
The attribute object specified is invalid.
DESCRIPTION:
NOTES:
12.4.3. pthread_condattr_setpshared - Set Process Shared Attribute#
CALLING SEQUENCE:
int pthread_condattr_setpshared(
    pthread_condattr_t *attr,
    int                 pshared
STATUS CODES:
EINVAL
Invalid argument passed.
DESCRIPTION:
NOTES:
12.4.4. pthread_condattr_getpshared - Get Process Shared Attribute#
CALLING SEQUENCE:
int pthread_condattr_getpshared(
    const pthread_condattr_t *attr,
    int                      *pshared
STATUS CODES:
EINVAL
DESCRIPTION:
NOTES:
12.4.5. pthread_cond_init - Initialize a Condition Variable#
CALLING SEQUENCE:
int pthread_cond_init(
    pthread_cond_t           *cond,
STATUS CODES:
EAGAIN
The system lacked a resource other than memory necessary to create the initialize the condition variable object.
ENOMEM
Insufficient memory is available to initialize the condition variable object.
EBUSY
The specified condition variable has already been initialized.
EINVAL
The specified attribute value is invalid.
DESCRIPTION:
NOTES:
12.4.6. pthread_cond_destroy - Destroy a Condition Variable#
CALLING SEQUENCE:
int pthread_cond_destroy(
STATUS CODES:
EINVAL
The specified condition variable is invalid.
EBUSY
The specified condition variable is currently in use.
DESCRIPTION:
NOTES:
12.4.7. pthread_cond_signal - Signal a Condition Variable#
CALLING SEQUENCE:
int pthread_cond_signal(
STATUS CODES:
EINVAL
The specified condition variable is not valid.
DESCRIPTION:
NOTES:
This routine should not be invoked from a handler from an asynchronous signal handler or an interrupt service routine.
12.4.8. pthread_cond_broadcast - Broadcast a Condition Variable#
CALLING SEQUENCE:
int pthread_cond_broadcast(
STATUS CODES:
EINVAL
DESCRIPTION:
NOTES:
12.4.9. pthread_cond_wait - Wait on a Condition Variable#
CALLING SEQUENCE:
int pthread_cond_wait(
    pthread_mutex_t *mutex
STATUS CODES:
EINVAL
The specified condition variable or mutex is not initialized OR different mutexes were specified for concurrent pthread_cond_wait(), pthread_cond_timedwait(), and pthread_cond_clockwait() operations on the same condition variable OR the mutex was not owned by the current thread at the time of the call.
DESCRIPTION:
NOTES:
12.4.10. pthread_cond_timedwait - Wait with Timeout a Condition Variable#
CALLING SEQUENCE:
int pthread_cond_timedwait(
    pthread_mutex_t       *mutex,
    const struct timespec *abstime
STATUS CODES:
EINVAL
The nanoseconds field of timeout is invalid.
EINVAL
ETIMEDOUT
The specified time has elapsed without the condition variable being satisfied.
DESCRIPTION:
NOTES:
12.4.11. pthread_cond_clockwait - Wait on a Condition Variable with Timeout against the chosen clock#
CALLING SEQUENCE:
int pthread_cond_clockwait(
    clockid_t              clockid,
STATUS CODES:
EINVAL
EINVAL
EINVAL
The clock specified by clockid is not supported.
ETIMEDOUT
DESCRIPTION:
The pthread_cond_clockwait() function blocks the calling thread until the condition variable is signaled or until the absolute timeout specified by abstime is reached. The timeout is measured against the clock specified by clockid.
The only supported clocks are CLOCK_MONOTONIC and CLOCK_REALTIME.
NOTES:
