RTEMS 7.0-rc1
rtems_can_queue_param Struct Reference
This structure represents parameters of FIFO queue. It is used to setup new queues via RTEMS_CAN_CREATE_QUEUE ioctl call. More...
#include <can.h>
uint8_t direction
 This member specifies queue's direction. Use RTEMS_CAN_QUEUE_RX or RTEMS_CAN_QUEUE_TX.
uint8_t priority
 This member specifies queue's priority. Maximum priority value is available from RTEMS_CAN_QUEUE_PRIO_NR define. Higher number means higher priority.
uint8_t dlen_max
 This member specifies queue's maximum data length. Passing 0 applies default value: CAN_FRAME_STANDARD_DLEN for standard frames only and CAN_FRAME_FD_DLEN for CAN FD capable chips.
uint8_t buffer_size
 This member specifies queue's buffer size. Passing 0 applies default RTEMS_CAN_FIFO_SIZE value.
struct rtems_can_filter filter
 This member holds a queue's filter. Refer to rtems_can_filter for more information.
