RTEMS 7.0-rc1
ctucanfd_txb_info Struct Reference
This represents one HW transmission buffer. More...
#include <ctucanfd_internal.h>
struct rtems_can_queue_slotslot
 This holds the pointer to the slot the buffer acquired.
struct rtems_can_queue_edgeedge
 This holds the pointer to the edge from which the slot was acquired.
Field Documentation
◆ edge
struct rtems_can_queue_edge* ctucanfd_txb_info::edge
This information is useful for future filtering of echo frames back to sending instances.
◆ slot
struct rtems_can_queue_slot* ctucanfd_txb_info::slot
The stack does not free the slot immediately after it is assigned to the buffer, but waits for succesful transmission (or error/abort). Hence the buffer has to keep the information about the slot it acquired to provide correct error reporting or to schedule it for later processing.
