RTEMS 7.0-rc1
CMSIS STM32U5xx Device Peripheral Access Layer Header File. More...
#include "stm32u5g9xx.h"Go to the source code of this file.
| #define | STM32U5 |
| STM32 Family. | |
| #define | STM32U5G9xx |
| #define | __STM32U5_CMSIS_VERSION_MAIN (0x01) |
| Comment the line below if you will not use the peripherals drivers. In this case, these drivers will not be included and the application code will be based on direct access to peripherals registers. | |
| #define | __STM32U5_CMSIS_VERSION_SUB1 (0x04) |
| #define | __STM32U5_CMSIS_VERSION_SUB2 (0x00) |
| #define | __STM32U5_CMSIS_VERSION_RC (0x00) |
| #define | __STM32U5_CMSIS_VERSION |
| #define | IS_FUNCTIONAL_STATE(STATE) (((STATE) == DISABLE) || ((STATE) == ENABLE)) |
| #define | SET_BIT(REG, BIT) ((REG) |= (BIT)) |
| #define | CLEAR_BIT(REG, BIT) ((REG) &= ~(BIT)) |
| #define | READ_BIT(REG, BIT) ((REG) & (BIT)) |
| #define | CLEAR_REG(REG) ((REG) = (0x0)) |
| #define | WRITE_REG(REG, VAL) ((REG) = (VAL)) |
| #define | READ_REG(REG) ((REG)) |
| #define | MODIFY_REG(REG, CLEARMASK, SETMASK) WRITE_REG((REG), (((READ_REG(REG)) & (~(CLEARMASK))) | (SETMASK))) |
| #define | ATOMIC_SET_BIT(REG, BIT) |
| #define | ATOMIC_CLEAR_BIT(REG, BIT) |
| #define | ATOMIC_MODIFY_REG(REG, CLEARMSK, SETMASK) |
| #define | ATOMIC_SETH_BIT(REG, BIT) |
| #define | ATOMIC_CLEARH_BIT(REG, BIT) |
| #define | ATOMIC_MODIFYH_REG(REG, CLEARMSK, SETMASK) |
| #define | POSITION_VAL(VAL) (__CLZ(__RBIT(VAL))) |
Typedefs | |
| typedef enum FlagStatus | ITStatus |
Enumerations | |
| enum | FlagStatus { RESET = 0 , SET = !RESET } |
| enum | FunctionalState { DISABLE = 0 , ENABLE = !DISABLE } |
| enum | ErrorStatus { SUCCESS = 0 , ERROR = !SUCCESS } |
Copyright (c) 2021 STMicroelectronics. All rights reserved.
