RTEMS 7.0-rc1
Driver for RTD316 ISA SCC Board. More...
#include <bsp.h>#include <termios.h>#include <stdio.h>#include <stdlib.h>#include <rtems/termiostypes.h>#include <libchip/serial.h>#include <libchip/z85c30.h>#include <rtems/bspIo.h>#include <bsp/rtd316.h>#include <rtems/score/i386.h>#include "../../shared/dev/serial/legacy-console.h"Macros | |
| #define | RTD_CLOCK_RATE (460800 * 32) |
| uint8_t | rtd316_com_get_register (uintptr_t addr, uint8_t reg) |
| RTD316 Obtain Register Helper. | |
| void | rtd316_com_set_register (uintptr_t addr, uint8_t reg, uint8_t val) |
| RTD316 Set Register Helper. | |
| rtems_device_driver | rtd316_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| RTD316 Initialization Entry Point. | |
The RTD316 has a single Z85C30.
| uint8_t rtd316_com_get_register | ( | uintptr_t | addr, |
| uint8_t | reg | ||
This method is used to read registers on the RTD316.
| [in] | addr | is the base address |
| [in] | reg | is the register number |
| void rtd316_com_set_register | ( | uintptr_t | addr, |
| uint8_t | reg, | ||
| uint8_t | val | ||
This method is used to set registers on the RTD316.
| rtems_device_driver rtd316_initialize | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void * | arg | ||
This method initializes the RTD316 device driver.
| [in] | major | is the device driver major number |
| [in] | minor | is the device driver minor number |
| [in] | arg | is the parameters to this call |
