RTEMS 7.0-rc1
Interrupt support. More...
#include <bsp/fatal.h>#include <bsp/irq-generic.h>#include <amba.h>#include <rtems/score/percpu.h>#include <rtems/score/riscv-utility.h>#include <rtems/score/smpimpl.h>Functions | |
| void | _RISCV_Interrupt_dispatch (uintptr_t mcause, Per_CPU_Control *cpu_self) |
| void | bsp_interrupt_facility_initialize (void) |
| BSP specific initialization. | |
| rtems_status_code | bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes) |
| Gets the attributes of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending) |
| Checks if the interrupt is pending. | |
| rtems_status_code | bsp_interrupt_raise (rtems_vector_number vector) |
| Causes the interrupt vector. | |
| rtems_status_code | bsp_interrupt_clear (rtems_vector_number vector) |
| Clears the interrupt vector. | |
| rtems_status_code | bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled) |
| Checks if the interrupt is enabled. | |
| rtems_status_code | bsp_interrupt_vector_enable (rtems_vector_number vector) |
| Enables the interrupt vector. | |
| rtems_status_code | bsp_interrupt_vector_disable (rtems_vector_number vector) |
| Disables the interrupt vector. | |
| rtems_status_code | bsp_interrupt_set_priority (rtems_vector_number vector, uint32_t priority) |
| Sets the priority of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_get_priority (rtems_vector_number vector, uint32_t *priority) |
| Gets the priority of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_get_affinity (rtems_vector_number vector, Processor_mask *affinity) |
| Gets the processor affinity set of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_set_affinity (rtems_vector_number vector, const Processor_mask *affinity) |
| Sets the processor affinity set of the interrupt vector. | |
Interrupt support.
