RTEMS 7.0-rc1
riscv-utility.h
2
3/* Copyright (c) 2013, The Regents of the University of California (Regents).
4 * All Rights Reserved.
5 *
6 * Modifications for RTEMS
7 * COPYRIGHT (c) 2015 Hesham Almatary <hesham@alumni.york.ac.uk>
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions are met:
11 * 1. Redistributions of source code must retain the above copyright
12 * notice, this list of conditions and the following disclaimer.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 * 3. Neither the name of the Regents nor the
17 * names of its contributors may be used to endorse or promote products
18 * derived from this software without specific prior written
19 * permission.
20 *
21 * IN NO EVENT SHALL REGENTS BE LIABLE TO ANY PARTY FOR DIRECT,
22 * INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING LOST
23 * PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
24 * REGENTS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
25 *
26 * REGENTS SPECIFICALLY DISCLAIMS ANY WARRANTIES, INCLUDING, BUT NOT
27 * LIMITED TO,THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
28 * PURPOSE. THE SOFTWARE AND ACCOMPANYING DOCUMENTATION, IF ANY, PROVIDED
29 * HEREUNDER IS PROVIDED "AS IS". REGENTS HAS NO OBLIGATION TO PROVIDE
30 * MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
31 */
32
41#ifndef _RTEMS_SCORE_RISCV_UTILITY_H
42#define _RTEMS_SCORE_RISCV_UTILITY_H
43
44#define MSTATUS_UIE 0x00000001
45#define MSTATUS_SIE 0x00000002
46#define MSTATUS_HIE 0x00000004
47#define MSTATUS_MIE 0x00000008
48#define MSTATUS_UPIE 0x00000010
49#define MSTATUS_SPIE 0x00000020
50#define MSTATUS_HPIE 0x00000040
51#define MSTATUS_MPIE 0x00000080
52#define MSTATUS_SPP 0x00000100
53#define MSTATUS_HPP 0x00000600
54#define MSTATUS_MPP 0x00001800
55#define MSTATUS_FS 0x00006000
56#define MSTATUS_XS 0x00018000
57#define MSTATUS_MPRV 0x00020000
58#define MSTATUS_SUM 0x00040000
59#define MSTATUS_MXR 0x00080000
60#define MSTATUS_TVM 0x00100000
61#define MSTATUS_TW 0x00200000
62#define MSTATUS_TSR 0x00400000
63#define MSTATUS32_SD 0x80000000
64#define MSTATUS64_SD 0x8000000000000000
65
66#define SSTATUS_UIE 0x00000001
67#define SSTATUS_SIE 0x00000002
68#define SSTATUS_UPIE 0x00000010
69#define SSTATUS_SPIE 0x00000020
70#define SSTATUS_SPP 0x00000100
71#define SSTATUS_FS 0x00006000
72#define SSTATUS_XS 0x00018000
73#define SSTATUS_SUM 0x00040000
74#define SSTATUS_MXR 0x00080000
75#define SSTATUS32_SD 0x80000000
76#define SSTATUS64_SD 0x8000000000000000
77
78#define DCSR_XDEBUGVER (3U<<30)
79#define DCSR_NDRESET (1<<29)
80#define DCSR_FULLRESET (1<<28)
81#define DCSR_EBREAKM (1<<15)
82#define DCSR_EBREAKH (1<<14)
83#define DCSR_EBREAKS (1<<13)
84#define DCSR_EBREAKU (1<<12)
85#define DCSR_STOPCYCLE (1<<10)
86#define DCSR_STOPTIME (1<<9)
87#define DCSR_CAUSE (7<<6)
88#define DCSR_DEBUGINT (1<<5)
89#define DCSR_HALT (1<<3)
90#define DCSR_STEP (1<<2)
91#define DCSR_PRV (3<<0)
92
93#define DCSR_CAUSE_NONE 0
94#define DCSR_CAUSE_SWBP 1
95#define DCSR_CAUSE_HWBP 2
96#define DCSR_CAUSE_DEBUGINT 3
97#define DCSR_CAUSE_STEP 4
98#define DCSR_CAUSE_HALT 5
99
100#define MCONTROL_TYPE(xlen) (0xfULL<<((xlen)-4))
101#define MCONTROL_DMODE(xlen) (1ULL<<((xlen)-5))
102#define MCONTROL_MASKMAX(xlen) (0x3fULL<<((xlen)-11))
103
104#define MCONTROL_SELECT (1<<19)
105#define MCONTROL_TIMING (1<<18)
106#define MCONTROL_ACTION (0x3f<<12)
107#define MCONTROL_CHAIN (1<<11)
108#define MCONTROL_MATCH (0xf<<7)
109#define MCONTROL_M (1<<6)
110#define MCONTROL_H (1<<5)
111#define MCONTROL_S (1<<4)
112#define MCONTROL_U (1<<3)
113#define MCONTROL_EXECUTE (1<<2)
114#define MCONTROL_STORE (1<<1)
115#define MCONTROL_LOAD (1<<0)
116
117#define MCONTROL_TYPE_NONE 0
118#define MCONTROL_TYPE_MATCH 2
119
120#define MCONTROL_ACTION_DEBUG_EXCEPTION 0
121#define MCONTROL_ACTION_DEBUG_MODE 1
122#define MCONTROL_ACTION_TRACE_START 2
123#define MCONTROL_ACTION_TRACE_STOP 3
124#define MCONTROL_ACTION_TRACE_EMIT 4
125
126#define MCONTROL_MATCH_EQUAL 0
127#define MCONTROL_MATCH_NAPOT 1
128#define MCONTROL_MATCH_GE 2
129#define MCONTROL_MATCH_LT 3
130#define MCONTROL_MATCH_MASK_LOW 4
131#define MCONTROL_MATCH_MASK_HIGH 5
132
133#define MIP_SSIP (1 << IRQ_S_SOFT)
134#define MIP_HSIP (1 << IRQ_H_SOFT)
135#define MIP_MSIP (1 << IRQ_M_SOFT)
136#define MIP_STIP (1 << IRQ_S_TIMER)
137#define MIP_HTIP (1 << IRQ_H_TIMER)
138#define MIP_MTIP (1 << IRQ_M_TIMER)
139#define MIP_SEIP (1 << IRQ_S_EXT)
140#define MIP_HEIP (1 << IRQ_H_EXT)
141#define MIP_MEIP (1 << IRQ_M_EXT)
142
143#define SIP_SSIP MIP_SSIP
144#define SIP_STIP MIP_STIP
145
146#define PRV_U 0
147#define PRV_S 1
148#define PRV_H 2
149#define PRV_M 3
150
151#define SPTBR32_MODE 0x80000000
152#define SPTBR32_ASID 0x7FC00000
153#define SPTBR32_PPN 0x003FFFFF
154#define SPTBR64_MODE 0xF000000000000000
155#define SPTBR64_ASID 0x0FFFF00000000000
156#define SPTBR64_PPN 0x00000FFFFFFFFFFF
157
158#define SPTBR_MODE_OFF 0
159#define SPTBR_MODE_SV32 1
160#define SPTBR_MODE_SV39 8
161#define SPTBR_MODE_SV48 9
162#define SPTBR_MODE_SV57 10
163#define SPTBR_MODE_SV64 11
164
165#define PMP_R 0x01
166#define PMP_W 0x02
167#define PMP_X 0x04
168#define PMP_A 0x18
169#define PMP_L 0x80
170#define PMP_SHIFT 2
171
172#define PMP_TOR 0x08
173#define PMP_NA4 0x10
174#define PMP_NAPOT 0x18
175
176#define IRQ_S_SOFT 1
177#define IRQ_H_SOFT 2
178#define IRQ_M_SOFT 3
179#define IRQ_S_TIMER 5
180#define IRQ_H_TIMER 6
181#define IRQ_M_TIMER 7
182#define IRQ_S_EXT 9
183#define IRQ_H_EXT 10
184#define IRQ_M_EXT 11
185#define IRQ_COP 12
186#define IRQ_HOST 13
187
188#define DEFAULT_RSTVEC 0x00001000
189#define CLINT_BASE 0x02000000
190#define CLINT_SIZE 0x000c0000
191#define EXT_IO_BASE 0x40000000
192#define DRAM_BASE 0x80000000
193
194// page table entry (PTE) fields
195#define PTE_V 0x001 // Valid
196#define PTE_R 0x002 // Read
197#define PTE_W 0x004 // Write
198#define PTE_X 0x008 // Execute
199#define PTE_U 0x010 // User
200#define PTE_G 0x020 // Global
201#define PTE_A 0x040 // Accessed
202#define PTE_D 0x080 // Dirty
203#define PTE_SOFT 0x300 // Reserved for Software
204
205#define PTE_PPN_SHIFT 10
206
207#define PTE_TABLE(PTE) (((PTE) & (PTE_V | PTE_R | PTE_W | PTE_X)) == PTE_V)
208
209#ifdef __riscv
210
211#if __riscv_xlen == 64
212# define MSTATUS_SD MSTATUS64_SD
213# define SSTATUS_SD SSTATUS64_SD
214# define RISCV_PGLEVEL_BITS 9
215# define SPTBR_MODE SPTBR64_MODE
216#else
217# define MSTATUS_SD MSTATUS32_SD
218# define SSTATUS_SD SSTATUS32_SD
219# define RISCV_PGLEVEL_BITS 10
220# define SPTBR_MODE SPTBR32_MODE
221#endif
222#define RISCV_PGSHIFT 12
223#define RISCV_PGSIZE (1 << RISCV_PGSHIFT)
224
225#ifndef __ASSEMBLER__
226
232typedef enum {
233 RISCV_USER_INTERRUPT = 0,
234 RISCV_SUPERVISOR_SW_INTERRUPT = 1,
235 RISCV_MACHINE_SW_INTERRUPT = 3,
236 RISCV_USER_TIMER_INTERRUPT = 4,
237 RISCV_SUPERVISOR_TIMER_INTERRUPT = 4,
238 RISCV_MACHINE_TIMER_INTERRUPT = 7,
239 RISCV_USER_EXTERNAL_INTERRUPT = 8,
240 RISCV_SUPERVISOR_EXTERNAL_INTERRUPT = 9,
241 RISCV_MACHINE_EXTERNAL_INTERRUPT = 11
242} RISCV_Symbolic_interrupt_name;
243
244#ifdef __GNUC__
245
246#define read_csr(reg) ({ unsigned long __tmp; \
247 asm volatile (".option push\n.option arch, +zicsr\n" \
248 "csrr %0, " #reg "\n.option pop ": "=r"(__tmp)); \
249 __tmp; })
250
251#define write_csr(reg, val) ({ \
252 asm volatile (".option push\n.option arch, +zicsr\n" \
253 "csrw " #reg ", %0\n.option pop" :: "rK"(val)); })
254
255#define swap_csr(reg, val) ({ unsigned long __tmp; \
256 asm volatile (".option push\n.option arch, +zicsr\n" \
257 "csrrw %0, " #reg ", %1\n.option pop" : "=r"(__tmp) : "rK"(val)); \
258 __tmp; })
259
260#define set_csr(reg, bit) ({ unsigned long __tmp; \
261 asm volatile (".option push\n.option arch, +zicsr\nc" \
262 "srrs %0, " #reg ", %1\n.option pop" : "=r"(__tmp) : "rK"(bit)); \
263 __tmp; })
264
265#define clear_csr(reg, bit) ({ unsigned long __tmp; \
266 asm volatile (".option push\n.option arch, +zicsr\n" \
267 "csrrc %0, " #reg ", %1\n.option pop" : "=r"(__tmp) : "rK"(bit)); \
268 __tmp; })
269
270#define rdtime() read_csr(time)
271#define rdcycle() read_csr(cycle)
272#define rdinstret() read_csr(instret)
273
274#endif
275
276#endif
277
278#endif
279
280#endif
281/* Automatically generated by parse-opcodes. */
282#ifndef RISCV_ENCODING_H
283#define RISCV_ENCODING_H
284#define MATCH_BEQ 0x63
285#define MASK_BEQ 0x707f
286#define MATCH_BNE 0x1063
287#define MASK_BNE 0x707f
288#define MATCH_BLT 0x4063
289#define MASK_BLT 0x707f
290#define MATCH_BGE 0x5063
291#define MASK_BGE 0x707f
292#define MATCH_BLTU 0x6063
293#define MASK_BLTU 0x707f
294#define MATCH_BGEU 0x7063
295#define MASK_BGEU 0x707f
296#define MATCH_JALR 0x67
297#define MASK_JALR 0x707f
298#define MATCH_JAL 0x6f
299#define MASK_JAL 0x7f
300#define MATCH_LUI 0x37
301#define MASK_LUI 0x7f
302#define MATCH_AUIPC 0x17
303#define MASK_AUIPC 0x7f
304#define MATCH_ADDI 0x13
305#define MASK_ADDI 0x707f
306#define MATCH_SLLI 0x1013
307#define MASK_SLLI 0xfc00707f
308#define MATCH_SLTI 0x2013
309#define MASK_SLTI 0x707f
310#define MATCH_SLTIU 0x3013
311#define MASK_SLTIU 0x707f
312#define MATCH_XORI 0x4013
313#define MASK_XORI 0x707f
314#define MATCH_SRLI 0x5013
315#define MASK_SRLI 0xfc00707f
316#define MATCH_SRAI 0x40005013
317#define MASK_SRAI 0xfc00707f
318#define MATCH_ORI 0x6013
319#define MASK_ORI 0x707f
320#define MATCH_ANDI 0x7013
321#define MASK_ANDI 0x707f
322#define MATCH_ADD 0x33
323#define MASK_ADD 0xfe00707f
324#define MATCH_SUB 0x40000033
325#define MASK_SUB 0xfe00707f
326#define MATCH_SLL 0x1033
327#define MASK_SLL 0xfe00707f
328#define MATCH_SLT 0x2033
329#define MASK_SLT 0xfe00707f
330#define MATCH_SLTU 0x3033
331#define MASK_SLTU 0xfe00707f
332#define MATCH_XOR 0x4033
333#define MASK_XOR 0xfe00707f
334#define MATCH_SRL 0x5033
335#define MASK_SRL 0xfe00707f
336#define MATCH_SRA 0x40005033
337#define MASK_SRA 0xfe00707f
338#define MATCH_OR 0x6033
339#define MASK_OR 0xfe00707f
340#define MATCH_AND 0x7033
341#define MASK_AND 0xfe00707f
342#define MATCH_ADDIW 0x1b
343#define MASK_ADDIW 0x707f
344#define MATCH_SLLIW 0x101b
345#define MASK_SLLIW 0xfe00707f
346#define MATCH_SRLIW 0x501b
347#define MASK_SRLIW 0xfe00707f
348#define MATCH_SRAIW 0x4000501b
349#define MASK_SRAIW 0xfe00707f
350#define MATCH_ADDW 0x3b
351#define MASK_ADDW 0xfe00707f
352#define MATCH_SUBW 0x4000003b
353#define MASK_SUBW 0xfe00707f
354#define MATCH_SLLW 0x103b
355#define MASK_SLLW 0xfe00707f
356#define MATCH_SRLW 0x503b
357#define MASK_SRLW 0xfe00707f
358#define MATCH_SRAW 0x4000503b
359#define MASK_SRAW 0xfe00707f
360#define MATCH_LB 0x3
361#define MASK_LB 0x707f
362#define MATCH_LH 0x1003
363#define MASK_LH 0x707f
364#define MATCH_LW 0x2003
365#define MASK_LW 0x707f
366#define MATCH_LD 0x3003
367#define MASK_LD 0x707f
368#define MATCH_LBU 0x4003
369#define MASK_LBU 0x707f
370#define MATCH_LHU 0x5003
371#define MASK_LHU 0x707f
372#define MATCH_LWU 0x6003
373#define MASK_LWU 0x707f
374#define MATCH_SB 0x23
375#define MASK_SB 0x707f
376#define MATCH_SH 0x1023
377#define MASK_SH 0x707f
378#define MATCH_SW 0x2023
379#define MASK_SW 0x707f
380#define MATCH_SD 0x3023
381#define MASK_SD 0x707f
382#define MATCH_FENCE 0xf
383#define MASK_FENCE 0x707f
384#define MATCH_FENCE_I 0x100f
385#define MASK_FENCE_I 0x707f
386#define MATCH_MUL 0x2000033
387#define MASK_MUL 0xfe00707f
388#define MATCH_MULH 0x2001033
389#define MASK_MULH 0xfe00707f
390#define MATCH_MULHSU 0x2002033
391#define MASK_MULHSU 0xfe00707f
392#define MATCH_MULHU 0x2003033
393#define MASK_MULHU 0xfe00707f
394#define MATCH_DIV 0x2004033
395#define MASK_DIV 0xfe00707f
396#define MATCH_DIVU 0x2005033
397#define MASK_DIVU 0xfe00707f
398#define MATCH_REM 0x2006033
399#define MASK_REM 0xfe00707f
400#define MATCH_REMU 0x2007033
401#define MASK_REMU 0xfe00707f
402#define MATCH_MULW 0x200003b
403#define MASK_MULW 0xfe00707f
404#define MATCH_DIVW 0x200403b
405#define MASK_DIVW 0xfe00707f
406#define MATCH_DIVUW 0x200503b
407#define MASK_DIVUW 0xfe00707f
408#define MATCH_REMW 0x200603b
409#define MASK_REMW 0xfe00707f
410#define MATCH_REMUW 0x200703b
411#define MASK_REMUW 0xfe00707f
412#define MATCH_AMOADD_W 0x202f
413#define MASK_AMOADD_W 0xf800707f
414#define MATCH_AMOXOR_W 0x2000202f
415#define MASK_AMOXOR_W 0xf800707f
416#define MATCH_AMOOR_W 0x4000202f
417#define MASK_AMOOR_W 0xf800707f
418#define MATCH_AMOAND_W 0x6000202f
419#define MASK_AMOAND_W 0xf800707f
420#define MATCH_AMOMIN_W 0x8000202f
421#define MASK_AMOMIN_W 0xf800707f
422#define MATCH_AMOMAX_W 0xa000202f
423#define MASK_AMOMAX_W 0xf800707f
424#define MATCH_AMOMINU_W 0xc000202f
425#define MASK_AMOMINU_W 0xf800707f
426#define MATCH_AMOMAXU_W 0xe000202f
427#define MASK_AMOMAXU_W 0xf800707f
428#define MATCH_AMOSWAP_W 0x800202f
429#define MASK_AMOSWAP_W 0xf800707f
430#define MATCH_LR_W 0x1000202f
431#define MASK_LR_W 0xf9f0707f
432#define MATCH_SC_W 0x1800202f
433#define MASK_SC_W 0xf800707f
434#define MATCH_AMOADD_D 0x302f
435#define MASK_AMOADD_D 0xf800707f
436#define MATCH_AMOXOR_D 0x2000302f
437#define MASK_AMOXOR_D 0xf800707f
438#define MATCH_AMOOR_D 0x4000302f
439#define MASK_AMOOR_D 0xf800707f
440#define MATCH_AMOAND_D 0x6000302f
441#define MASK_AMOAND_D 0xf800707f
442#define MATCH_AMOMIN_D 0x8000302f
443#define MASK_AMOMIN_D 0xf800707f
444#define MATCH_AMOMAX_D 0xa000302f
445#define MASK_AMOMAX_D 0xf800707f
446#define MATCH_AMOMINU_D 0xc000302f
447#define MASK_AMOMINU_D 0xf800707f
448#define MATCH_AMOMAXU_D 0xe000302f
449#define MASK_AMOMAXU_D 0xf800707f
450#define MATCH_AMOSWAP_D 0x800302f
451#define MASK_AMOSWAP_D 0xf800707f
452#define MATCH_LR_D 0x1000302f
453#define MASK_LR_D 0xf9f0707f
454#define MATCH_SC_D 0x1800302f
455#define MASK_SC_D 0xf800707f
456#define MATCH_ECALL 0x73
457#define MASK_ECALL 0xffffffff
458#define MATCH_EBREAK 0x100073
459#define MASK_EBREAK 0xffffffff
460#define MATCH_URET 0x200073
461#define MASK_URET 0xffffffff
462#define MATCH_SRET 0x10200073
463#define MASK_SRET 0xffffffff
464#define MATCH_MRET 0x30200073
465#define MASK_MRET 0xffffffff
466#define MATCH_DRET 0x7b200073
467#define MASK_DRET 0xffffffff
468#define MATCH_SFENCE_VMA 0x12000073
469#define MASK_SFENCE_VMA 0xfe007fff
470#define MATCH_WFI 0x10500073
471#define MASK_WFI 0xffffffff
472#define MATCH_CSRRW 0x1073
473#define MASK_CSRRW 0x707f
474#define MATCH_CSRRS 0x2073
475#define MASK_CSRRS 0x707f
476#define MATCH_CSRRC 0x3073
477#define MASK_CSRRC 0x707f
478#define MATCH_CSRRWI 0x5073
479#define MASK_CSRRWI 0x707f
480#define MATCH_CSRRSI 0x6073
481#define MASK_CSRRSI 0x707f
482#define MATCH_CSRRCI 0x7073
483#define MASK_CSRRCI 0x707f
484#define MATCH_FADD_S 0x53
485#define MASK_FADD_S 0xfe00007f
486#define MATCH_FSUB_S 0x8000053
487#define MASK_FSUB_S 0xfe00007f
488#define MATCH_FMUL_S 0x10000053
489#define MASK_FMUL_S 0xfe00007f
490#define MATCH_FDIV_S 0x18000053
491#define MASK_FDIV_S 0xfe00007f
492#define MATCH_FSGNJ_S 0x20000053
493#define MASK_FSGNJ_S 0xfe00707f
494#define MATCH_FSGNJN_S 0x20001053
495#define MASK_FSGNJN_S 0xfe00707f
496#define MATCH_FSGNJX_S 0x20002053
497#define MASK_FSGNJX_S 0xfe00707f
498#define MATCH_FMIN_S 0x28000053
499#define MASK_FMIN_S 0xfe00707f
500#define MATCH_FMAX_S 0x28001053
501#define MASK_FMAX_S 0xfe00707f
502#define MATCH_FSQRT_S 0x58000053
503#define MASK_FSQRT_S 0xfff0007f
504#define MATCH_FADD_D 0x2000053
505#define MASK_FADD_D 0xfe00007f
506#define MATCH_FSUB_D 0xa000053
507#define MASK_FSUB_D 0xfe00007f
508#define MATCH_FMUL_D 0x12000053
509#define MASK_FMUL_D 0xfe00007f
510#define MATCH_FDIV_D 0x1a000053
511#define MASK_FDIV_D 0xfe00007f
512#define MATCH_FSGNJ_D 0x22000053
513#define MASK_FSGNJ_D 0xfe00707f
514#define MATCH_FSGNJN_D 0x22001053
515#define MASK_FSGNJN_D 0xfe00707f
516#define MATCH_FSGNJX_D 0x22002053
517#define MASK_FSGNJX_D 0xfe00707f
518#define MATCH_FMIN_D 0x2a000053
519#define MASK_FMIN_D 0xfe00707f
520#define MATCH_FMAX_D 0x2a001053
521#define MASK_FMAX_D 0xfe00707f
522#define MATCH_FCVT_S_D 0x40100053
523#define MASK_FCVT_S_D 0xfff0007f
524#define MATCH_FCVT_D_S 0x42000053
525#define MASK_FCVT_D_S 0xfff0007f
526#define MATCH_FSQRT_D 0x5a000053
527#define MASK_FSQRT_D 0xfff0007f
528#define MATCH_FADD_Q 0x6000053
529#define MASK_FADD_Q 0xfe00007f
530#define MATCH_FSUB_Q 0xe000053
531#define MASK_FSUB_Q 0xfe00007f
532#define MATCH_FMUL_Q 0x16000053
533#define MASK_FMUL_Q 0xfe00007f
534#define MATCH_FDIV_Q 0x1e000053
535#define MASK_FDIV_Q 0xfe00007f
536#define MATCH_FSGNJ_Q 0x26000053
537#define MASK_FSGNJ_Q 0xfe00707f
538#define MATCH_FSGNJN_Q 0x26001053
539#define MASK_FSGNJN_Q 0xfe00707f
540#define MATCH_FSGNJX_Q 0x26002053
541#define MASK_FSGNJX_Q 0xfe00707f
542#define MATCH_FMIN_Q 0x2e000053
543#define MASK_FMIN_Q 0xfe00707f
544#define MATCH_FMAX_Q 0x2e001053
545#define MASK_FMAX_Q 0xfe00707f
546#define MATCH_FCVT_S_Q 0x40300053
547#define MASK_FCVT_S_Q 0xfff0007f
548#define MATCH_FCVT_Q_S 0x46000053
549#define MASK_FCVT_Q_S 0xfff0007f
550#define MATCH_FCVT_D_Q 0x42300053
551#define MASK_FCVT_D_Q 0xfff0007f
552#define MATCH_FCVT_Q_D 0x46100053
553#define MASK_FCVT_Q_D 0xfff0007f
554#define MATCH_FSQRT_Q 0x5e000053
555#define MASK_FSQRT_Q 0xfff0007f
556#define MATCH_FLE_S 0xa0000053
557#define MASK_FLE_S 0xfe00707f
558#define MATCH_FLT_S 0xa0001053
559#define MASK_FLT_S 0xfe00707f
560#define MATCH_FEQ_S 0xa0002053
561#define MASK_FEQ_S 0xfe00707f
562#define MATCH_FLE_D 0xa2000053
563#define MASK_FLE_D 0xfe00707f
564#define MATCH_FLT_D 0xa2001053
565#define MASK_FLT_D 0xfe00707f
566#define MATCH_FEQ_D 0xa2002053
567#define MASK_FEQ_D 0xfe00707f
568#define MATCH_FLE_Q 0xa6000053
569#define MASK_FLE_Q 0xfe00707f
570#define MATCH_FLT_Q 0xa6001053
571#define MASK_FLT_Q 0xfe00707f
572#define MATCH_FEQ_Q 0xa6002053
573#define MASK_FEQ_Q 0xfe00707f
574#define MATCH_FCVT_W_S 0xc0000053
575#define MASK_FCVT_W_S 0xfff0007f
576#define MATCH_FCVT_WU_S 0xc0100053
577#define MASK_FCVT_WU_S 0xfff0007f
578#define MATCH_FCVT_L_S 0xc0200053
579#define MASK_FCVT_L_S 0xfff0007f
580#define MATCH_FCVT_LU_S 0xc0300053
581#define MASK_FCVT_LU_S 0xfff0007f
582#define MATCH_FMV_X_W 0xe0000053
583#define MASK_FMV_X_W 0xfff0707f
584#define MATCH_FCLASS_S 0xe0001053
585#define MASK_FCLASS_S 0xfff0707f
586#define MATCH_FCVT_W_D 0xc2000053
587#define MASK_FCVT_W_D 0xfff0007f
588#define MATCH_FCVT_WU_D 0xc2100053
589#define MASK_FCVT_WU_D 0xfff0007f
590#define MATCH_FCVT_L_D 0xc2200053
591#define MASK_FCVT_L_D 0xfff0007f
592#define MATCH_FCVT_LU_D 0xc2300053
593#define MASK_FCVT_LU_D 0xfff0007f
594#define MATCH_FMV_X_D 0xe2000053
595#define MASK_FMV_X_D 0xfff0707f
596#define MATCH_FCLASS_D 0xe2001053
597#define MASK_FCLASS_D 0xfff0707f
598#define MATCH_FCVT_W_Q 0xc6000053
599#define MASK_FCVT_W_Q 0xfff0007f
600#define MATCH_FCVT_WU_Q 0xc6100053
601#define MASK_FCVT_WU_Q 0xfff0007f
602#define MATCH_FCVT_L_Q 0xc6200053
603#define MASK_FCVT_L_Q 0xfff0007f
604#define MATCH_FCVT_LU_Q 0xc6300053
605#define MASK_FCVT_LU_Q 0xfff0007f
606#define MATCH_FMV_X_Q 0xe6000053
607#define MASK_FMV_X_Q 0xfff0707f
608#define MATCH_FCLASS_Q 0xe6001053
609#define MASK_FCLASS_Q 0xfff0707f
610#define MATCH_FCVT_S_W 0xd0000053
611#define MASK_FCVT_S_W 0xfff0007f
612#define MATCH_FCVT_S_WU 0xd0100053
613#define MASK_FCVT_S_WU 0xfff0007f
614#define MATCH_FCVT_S_L 0xd0200053
615#define MASK_FCVT_S_L 0xfff0007f
616#define MATCH_FCVT_S_LU 0xd0300053
617#define MASK_FCVT_S_LU 0xfff0007f
618#define MATCH_FMV_W_X 0xf0000053
619#define MASK_FMV_W_X 0xfff0707f
620#define MATCH_FCVT_D_W 0xd2000053
621#define MASK_FCVT_D_W 0xfff0007f
622#define MATCH_FCVT_D_WU 0xd2100053
623#define MASK_FCVT_D_WU 0xfff0007f
624#define MATCH_FCVT_D_L 0xd2200053
625#define MASK_FCVT_D_L 0xfff0007f
626#define MATCH_FCVT_D_LU 0xd2300053
627#define MASK_FCVT_D_LU 0xfff0007f
628#define MATCH_FMV_D_X 0xf2000053
629#define MASK_FMV_D_X 0xfff0707f
630#define MATCH_FCVT_Q_W 0xd6000053
631#define MASK_FCVT_Q_W 0xfff0007f
632#define MATCH_FCVT_Q_WU 0xd6100053
633#define MASK_FCVT_Q_WU 0xfff0007f
634#define MATCH_FCVT_Q_L 0xd6200053
635#define MASK_FCVT_Q_L 0xfff0007f
636#define MATCH_FCVT_Q_LU 0xd6300053
637#define MASK_FCVT_Q_LU 0xfff0007f
638#define MATCH_FMV_Q_X 0xf6000053
639#define MASK_FMV_Q_X 0xfff0707f
640#define MATCH_FLW 0x2007
641#define MASK_FLW 0x707f
642#define MATCH_FLD 0x3007
643#define MASK_FLD 0x707f
644#define MATCH_FLQ 0x4007
645#define MASK_FLQ 0x707f
646#define MATCH_FSW 0x2027
647#define MASK_FSW 0x707f
648#define MATCH_FSD 0x3027
649#define MASK_FSD 0x707f
650#define MATCH_FSQ 0x4027
651#define MASK_FSQ 0x707f
652#define MATCH_FMADD_S 0x43
653#define MASK_FMADD_S 0x600007f
654#define MATCH_FMSUB_S 0x47
655#define MASK_FMSUB_S 0x600007f
656#define MATCH_FNMSUB_S 0x4b
657#define MASK_FNMSUB_S 0x600007f
658#define MATCH_FNMADD_S 0x4f
659#define MASK_FNMADD_S 0x600007f
660#define MATCH_FMADD_D 0x2000043
661#define MASK_FMADD_D 0x600007f
662#define MATCH_FMSUB_D 0x2000047
663#define MASK_FMSUB_D 0x600007f
664#define MATCH_FNMSUB_D 0x200004b
665#define MASK_FNMSUB_D 0x600007f
666#define MATCH_FNMADD_D 0x200004f
667#define MASK_FNMADD_D 0x600007f
668#define MATCH_FMADD_Q 0x6000043
669#define MASK_FMADD_Q 0x600007f
670#define MATCH_FMSUB_Q 0x6000047
671#define MASK_FMSUB_Q 0x600007f
672#define MATCH_FNMSUB_Q 0x600004b
673#define MASK_FNMSUB_Q 0x600007f
674#define MATCH_FNMADD_Q 0x600004f
675#define MASK_FNMADD_Q 0x600007f
676#define MATCH_C_NOP 0x1
677#define MASK_C_NOP 0xffff
678#define MATCH_C_ADDI16SP 0x6101
679#define MASK_C_ADDI16SP 0xef83
680#define MATCH_C_JR 0x8002
681#define MASK_C_JR 0xf07f
682#define MATCH_C_JALR 0x9002
683#define MASK_C_JALR 0xf07f
684#define MATCH_C_EBREAK 0x9002
685#define MASK_C_EBREAK 0xffff
686#define MATCH_C_LD 0x6000
687#define MASK_C_LD 0xe003
688#define MATCH_C_SD 0xe000
689#define MASK_C_SD 0xe003
690#define MATCH_C_ADDIW 0x2001
691#define MASK_C_ADDIW 0xe003
692#define MATCH_C_LDSP 0x6002
693#define MASK_C_LDSP 0xe003
694#define MATCH_C_SDSP 0xe002
695#define MASK_C_SDSP 0xe003
696#define MATCH_C_ADDI4SPN 0x0
697#define MASK_C_ADDI4SPN 0xe003
698#define MATCH_C_FLD 0x2000
699#define MASK_C_FLD 0xe003
700#define MATCH_C_LW 0x4000
701#define MASK_C_LW 0xe003
702#define MATCH_C_FLW 0x6000
703#define MASK_C_FLW 0xe003
704#define MATCH_C_FSD 0xa000
705#define MASK_C_FSD 0xe003
706#define MATCH_C_SW 0xc000
707#define MASK_C_SW 0xe003
708#define MATCH_C_FSW 0xe000
709#define MASK_C_FSW 0xe003
710#define MATCH_C_ADDI 0x1
711#define MASK_C_ADDI 0xe003
712#define MATCH_C_JAL 0x2001
713#define MASK_C_JAL 0xe003
714#define MATCH_C_LI 0x4001
715#define MASK_C_LI 0xe003
716#define MATCH_C_LUI 0x6001
717#define MASK_C_LUI 0xe003
718#define MATCH_C_SRLI 0x8001
719#define MASK_C_SRLI 0xec03
720#define MATCH_C_SRAI 0x8401
721#define MASK_C_SRAI 0xec03
722#define MATCH_C_ANDI 0x8801
723#define MASK_C_ANDI 0xec03
724#define MATCH_C_SUB 0x8c01
725#define MASK_C_SUB 0xfc63
726#define MATCH_C_XOR 0x8c21
727#define MASK_C_XOR 0xfc63
728#define MATCH_C_OR 0x8c41
729#define MASK_C_OR 0xfc63
730#define MATCH_C_AND 0x8c61
731#define MASK_C_AND 0xfc63
732#define MATCH_C_SUBW 0x9c01
733#define MASK_C_SUBW 0xfc63
734#define MATCH_C_ADDW 0x9c21
735#define MASK_C_ADDW 0xfc63
736#define MATCH_C_J 0xa001
737#define MASK_C_J 0xe003
738#define MATCH_C_BEQZ 0xc001
739#define MASK_C_BEQZ 0xe003
740#define MATCH_C_BNEZ 0xe001
741#define MASK_C_BNEZ 0xe003
742#define MATCH_C_SLLI 0x2
743#define MASK_C_SLLI 0xe003
744#define MATCH_C_FLDSP 0x2002
745#define MASK_C_FLDSP 0xe003
746#define MATCH_C_LWSP 0x4002
747#define MASK_C_LWSP 0xe003
748#define MATCH_C_FLWSP 0x6002
749#define MASK_C_FLWSP 0xe003
750#define MATCH_C_MV 0x8002
751#define MASK_C_MV 0xf003
752#define MATCH_C_ADD 0x9002
753#define MASK_C_ADD 0xf003
754#define MATCH_C_FSDSP 0xa002
755#define MASK_C_FSDSP 0xe003
756#define MATCH_C_SWSP 0xc002
757#define MASK_C_SWSP 0xe003
758#define MATCH_C_FSWSP 0xe002
759#define MASK_C_FSWSP 0xe003
760#define MATCH_CUSTOM0 0xb
761#define MASK_CUSTOM0 0x707f
762#define MATCH_CUSTOM0_RS1 0x200b
763#define MASK_CUSTOM0_RS1 0x707f
764#define MATCH_CUSTOM0_RS1_RS2 0x300b
765#define MASK_CUSTOM0_RS1_RS2 0x707f
766#define MATCH_CUSTOM0_RD 0x400b
767#define MASK_CUSTOM0_RD 0x707f
768#define MATCH_CUSTOM0_RD_RS1 0x600b
769#define MASK_CUSTOM0_RD_RS1 0x707f
770#define MATCH_CUSTOM0_RD_RS1_RS2 0x700b
771#define MASK_CUSTOM0_RD_RS1_RS2 0x707f
772#define MATCH_CUSTOM1 0x2b
773#define MASK_CUSTOM1 0x707f
774#define MATCH_CUSTOM1_RS1 0x202b
775#define MASK_CUSTOM1_RS1 0x707f
776#define MATCH_CUSTOM1_RS1_RS2 0x302b
777#define MASK_CUSTOM1_RS1_RS2 0x707f
778#define MATCH_CUSTOM1_RD 0x402b
779#define MASK_CUSTOM1_RD 0x707f
780#define MATCH_CUSTOM1_RD_RS1 0x602b
781#define MASK_CUSTOM1_RD_RS1 0x707f
782#define MATCH_CUSTOM1_RD_RS1_RS2 0x702b
783#define MASK_CUSTOM1_RD_RS1_RS2 0x707f
784#define MATCH_CUSTOM2 0x5b
785#define MASK_CUSTOM2 0x707f
786#define MATCH_CUSTOM2_RS1 0x205b
787#define MASK_CUSTOM2_RS1 0x707f
788#define MATCH_CUSTOM2_RS1_RS2 0x305b
789#define MASK_CUSTOM2_RS1_RS2 0x707f
790#define MATCH_CUSTOM2_RD 0x405b
791#define MASK_CUSTOM2_RD 0x707f
792#define MATCH_CUSTOM2_RD_RS1 0x605b
793#define MASK_CUSTOM2_RD_RS1 0x707f
794#define MATCH_CUSTOM2_RD_RS1_RS2 0x705b
795#define MASK_CUSTOM2_RD_RS1_RS2 0x707f
796#define MATCH_CUSTOM3 0x7b
797#define MASK_CUSTOM3 0x707f
798#define MATCH_CUSTOM3_RS1 0x207b
799#define MASK_CUSTOM3_RS1 0x707f
800#define MATCH_CUSTOM3_RS1_RS2 0x307b
801#define MASK_CUSTOM3_RS1_RS2 0x707f
802#define MATCH_CUSTOM3_RD 0x407b
803#define MASK_CUSTOM3_RD 0x707f
804#define MATCH_CUSTOM3_RD_RS1 0x607b
805#define MASK_CUSTOM3_RD_RS1 0x707f
806#define MATCH_CUSTOM3_RD_RS1_RS2 0x707b
807#define MASK_CUSTOM3_RD_RS1_RS2 0x707f
808#define CSR_FFLAGS 0x1
809#define CSR_FRM 0x2
810#define CSR_FCSR 0x3
811#define CSR_CYCLE 0xc00
812#define CSR_TIME 0xc01
813#define CSR_INSTRET 0xc02
814#define CSR_HPMCOUNTER3 0xc03
815#define CSR_HPMCOUNTER4 0xc04
816#define CSR_HPMCOUNTER5 0xc05
817#define CSR_HPMCOUNTER6 0xc06
818#define CSR_HPMCOUNTER7 0xc07
819#define CSR_HPMCOUNTER8 0xc08
820#define CSR_HPMCOUNTER9 0xc09
821#define CSR_HPMCOUNTER10 0xc0a
822#define CSR_HPMCOUNTER11 0xc0b
823#define CSR_HPMCOUNTER12 0xc0c
824#define CSR_HPMCOUNTER13 0xc0d
825#define CSR_HPMCOUNTER14 0xc0e
826#define CSR_HPMCOUNTER15 0xc0f
827#define CSR_HPMCOUNTER16 0xc10
828#define CSR_HPMCOUNTER17 0xc11
829#define CSR_HPMCOUNTER18 0xc12
830#define CSR_HPMCOUNTER19 0xc13
831#define CSR_HPMCOUNTER20 0xc14
832#define CSR_HPMCOUNTER21 0xc15
833#define CSR_HPMCOUNTER22 0xc16
834#define CSR_HPMCOUNTER23 0xc17
835#define CSR_HPMCOUNTER24 0xc18
836#define CSR_HPMCOUNTER25 0xc19
837#define CSR_HPMCOUNTER26 0xc1a
838#define CSR_HPMCOUNTER27 0xc1b
839#define CSR_HPMCOUNTER28 0xc1c
840#define CSR_HPMCOUNTER29 0xc1d
841#define CSR_HPMCOUNTER30 0xc1e
842#define CSR_HPMCOUNTER31 0xc1f
843#define CSR_SSTATUS 0x100
844#define CSR_SIE 0x104
845#define CSR_STVEC 0x105
846#define CSR_SCOUNTEREN 0x106
847#define CSR_SSCRATCH 0x140
848#define CSR_SEPC 0x141
849#define CSR_SCAUSE 0x142
850#define CSR_SBADADDR 0x143
851#define CSR_SIP 0x144
852#define CSR_SPTBR 0x180
853#define CSR_MSTATUS 0x300
854#define CSR_MISA 0x301
855#define CSR_MEDELEG 0x302
856#define CSR_MIDELEG 0x303
857#define CSR_MIE 0x304
858#define CSR_MTVEC 0x305
859#define CSR_MCOUNTEREN 0x306
860#define CSR_MSCRATCH 0x340
861#define CSR_MEPC 0x341
862#define CSR_MCAUSE 0x342
863#define CSR_MBADADDR 0x343
864#define CSR_MIP 0x344
865#define CSR_PMPCFG0 0x3a0
866#define CSR_PMPCFG1 0x3a1
867#define CSR_PMPCFG2 0x3a2
868#define CSR_PMPCFG3 0x3a3
869#define CSR_PMPADDR0 0x3b0
870#define CSR_PMPADDR1 0x3b1
871#define CSR_PMPADDR2 0x3b2
872#define CSR_PMPADDR3 0x3b3
873#define CSR_PMPADDR4 0x3b4
874#define CSR_PMPADDR5 0x3b5
875#define CSR_PMPADDR6 0x3b6
876#define CSR_PMPADDR7 0x3b7
877#define CSR_PMPADDR8 0x3b8
878#define CSR_PMPADDR9 0x3b9
879#define CSR_PMPADDR10 0x3ba
880#define CSR_PMPADDR11 0x3bb
881#define CSR_PMPADDR12 0x3bc
882#define CSR_PMPADDR13 0x3bd
883#define CSR_PMPADDR14 0x3be
884#define CSR_PMPADDR15 0x3bf
885#define CSR_TSELECT 0x7a0
886#define CSR_TDATA1 0x7a1
887#define CSR_TDATA2 0x7a2
888#define CSR_TDATA3 0x7a3
889#define CSR_DCSR 0x7b0
890#define CSR_DPC 0x7b1
891#define CSR_DSCRATCH 0x7b2
892#define CSR_MCYCLE 0xb00
893#define CSR_MINSTRET 0xb02
894#define CSR_MHPMCOUNTER3 0xb03
895#define CSR_MHPMCOUNTER4 0xb04
896#define CSR_MHPMCOUNTER5 0xb05
897#define CSR_MHPMCOUNTER6 0xb06
898#define CSR_MHPMCOUNTER7 0xb07
899#define CSR_MHPMCOUNTER8 0xb08
900#define CSR_MHPMCOUNTER9 0xb09
901#define CSR_MHPMCOUNTER10 0xb0a
902#define CSR_MHPMCOUNTER11 0xb0b
903#define CSR_MHPMCOUNTER12 0xb0c
904#define CSR_MHPMCOUNTER13 0xb0d
905#define CSR_MHPMCOUNTER14 0xb0e
906#define CSR_MHPMCOUNTER15 0xb0f
907#define CSR_MHPMCOUNTER16 0xb10
908#define CSR_MHPMCOUNTER17 0xb11
909#define CSR_MHPMCOUNTER18 0xb12
910#define CSR_MHPMCOUNTER19 0xb13
911#define CSR_MHPMCOUNTER20 0xb14
912#define CSR_MHPMCOUNTER21 0xb15
913#define CSR_MHPMCOUNTER22 0xb16
914#define CSR_MHPMCOUNTER23 0xb17
915#define CSR_MHPMCOUNTER24 0xb18
916#define CSR_MHPMCOUNTER25 0xb19
917#define CSR_MHPMCOUNTER26 0xb1a
918#define CSR_MHPMCOUNTER27 0xb1b
919#define CSR_MHPMCOUNTER28 0xb1c
920#define CSR_MHPMCOUNTER29 0xb1d
921#define CSR_MHPMCOUNTER30 0xb1e
922#define CSR_MHPMCOUNTER31 0xb1f
923#define CSR_MHPMEVENT3 0x323
924#define CSR_MHPMEVENT4 0x324
925#define CSR_MHPMEVENT5 0x325
926#define CSR_MHPMEVENT6 0x326
927#define CSR_MHPMEVENT7 0x327
928#define CSR_MHPMEVENT8 0x328
929#define CSR_MHPMEVENT9 0x329
930#define CSR_MHPMEVENT10 0x32a
931#define CSR_MHPMEVENT11 0x32b
932#define CSR_MHPMEVENT12 0x32c
933#define CSR_MHPMEVENT13 0x32d
934#define CSR_MHPMEVENT14 0x32e
935#define CSR_MHPMEVENT15 0x32f
936#define CSR_MHPMEVENT16 0x330
937#define CSR_MHPMEVENT17 0x331
938#define CSR_MHPMEVENT18 0x332
939#define CSR_MHPMEVENT19 0x333
940#define CSR_MHPMEVENT20 0x334
941#define CSR_MHPMEVENT21 0x335
942#define CSR_MHPMEVENT22 0x336
943#define CSR_MHPMEVENT23 0x337
944#define CSR_MHPMEVENT24 0x338
945#define CSR_MHPMEVENT25 0x339
946#define CSR_MHPMEVENT26 0x33a
947#define CSR_MHPMEVENT27 0x33b
948#define CSR_MHPMEVENT28 0x33c
949#define CSR_MHPMEVENT29 0x33d
950#define CSR_MHPMEVENT30 0x33e
951#define CSR_MHPMEVENT31 0x33f
952#define CSR_MVENDORID 0xf11
953#define CSR_MARCHID 0xf12
954#define CSR_MIMPID 0xf13
955#define CSR_MHARTID 0xf14
956#define CSR_CYCLEH 0xc80
957#define CSR_TIMEH 0xc81
958#define CSR_INSTRETH 0xc82
959#define CSR_HPMCOUNTER3H 0xc83
960#define CSR_HPMCOUNTER4H 0xc84
961#define CSR_HPMCOUNTER5H 0xc85
962#define CSR_HPMCOUNTER6H 0xc86
963#define CSR_HPMCOUNTER7H 0xc87
964#define CSR_HPMCOUNTER8H 0xc88
965#define CSR_HPMCOUNTER9H 0xc89
966#define CSR_HPMCOUNTER10H 0xc8a
967#define CSR_HPMCOUNTER11H 0xc8b
968#define CSR_HPMCOUNTER12H 0xc8c
969#define CSR_HPMCOUNTER13H 0xc8d
970#define CSR_HPMCOUNTER14H 0xc8e
971#define CSR_HPMCOUNTER15H 0xc8f
972#define CSR_HPMCOUNTER16H 0xc90
973#define CSR_HPMCOUNTER17H 0xc91
974#define CSR_HPMCOUNTER18H 0xc92
975#define CSR_HPMCOUNTER19H 0xc93
976#define CSR_HPMCOUNTER20H 0xc94
977#define CSR_HPMCOUNTER21H 0xc95
978#define CSR_HPMCOUNTER22H 0xc96
979#define CSR_HPMCOUNTER23H 0xc97
980#define CSR_HPMCOUNTER24H 0xc98
981#define CSR_HPMCOUNTER25H 0xc99
982#define CSR_HPMCOUNTER26H 0xc9a
983#define CSR_HPMCOUNTER27H 0xc9b
984#define CSR_HPMCOUNTER28H 0xc9c
985#define CSR_HPMCOUNTER29H 0xc9d
986#define CSR_HPMCOUNTER30H 0xc9e
987#define CSR_HPMCOUNTER31H 0xc9f
988#define CSR_MCYCLEH 0xb80
989#define CSR_MINSTRETH 0xb82
990#define CSR_MHPMCOUNTER3H 0xb83
991#define CSR_MHPMCOUNTER4H 0xb84
992#define CSR_MHPMCOUNTER5H 0xb85
993#define CSR_MHPMCOUNTER6H 0xb86
994#define CSR_MHPMCOUNTER7H 0xb87
995#define CSR_MHPMCOUNTER8H 0xb88
996#define CSR_MHPMCOUNTER9H 0xb89
997#define CSR_MHPMCOUNTER10H 0xb8a
998#define CSR_MHPMCOUNTER11H 0xb8b
999#define CSR_MHPMCOUNTER12H 0xb8c
1000#define CSR_MHPMCOUNTER13H 0xb8d
1001#define CSR_MHPMCOUNTER14H 0xb8e
1002#define CSR_MHPMCOUNTER15H 0xb8f
1003#define CSR_MHPMCOUNTER16H 0xb90
1004#define CSR_MHPMCOUNTER17H 0xb91
1005#define CSR_MHPMCOUNTER18H 0xb92
1006#define CSR_MHPMCOUNTER19H 0xb93
1007#define CSR_MHPMCOUNTER20H 0xb94
1008#define CSR_MHPMCOUNTER21H 0xb95
1009#define CSR_MHPMCOUNTER22H 0xb96
1010#define CSR_MHPMCOUNTER23H 0xb97
1011#define CSR_MHPMCOUNTER24H 0xb98
1012#define CSR_MHPMCOUNTER25H 0xb99
1013#define CSR_MHPMCOUNTER26H 0xb9a
1014#define CSR_MHPMCOUNTER27H 0xb9b
1015#define CSR_MHPMCOUNTER28H 0xb9c
1016#define CSR_MHPMCOUNTER29H 0xb9d
1017#define CSR_MHPMCOUNTER30H 0xb9e
1018#define CSR_MHPMCOUNTER31H 0xb9f
1019#define CAUSE_MISALIGNED_FETCH 0x0
1020#define CAUSE_FETCH_ACCESS 0x1
1021#define CAUSE_ILLEGAL_INSTRUCTION 0x2
1022#define CAUSE_BREAKPOINT 0x3
1023#define CAUSE_MISALIGNED_LOAD 0x4
1024#define CAUSE_LOAD_ACCESS 0x5
1025#define CAUSE_MISALIGNED_STORE 0x6
1026#define CAUSE_STORE_ACCESS 0x7
1027#define CAUSE_USER_ECALL 0x8
1028#define CAUSE_SUPERVISOR_ECALL 0x9
1029#define CAUSE_HYPERVISOR_ECALL 0xa
1030#define CAUSE_MACHINE_ECALL 0xb
1031#define CAUSE_FETCH_PAGE_FAULT 0xc
1032#define CAUSE_LOAD_PAGE_FAULT 0xd
1033#define CAUSE_STORE_PAGE_FAULT 0xf
1034#endif
1035#ifdef DECLARE_INSN
1036DECLARE_INSN(beq, MATCH_BEQ, MASK_BEQ)
1037DECLARE_INSN(bne, MATCH_BNE, MASK_BNE)
1038DECLARE_INSN(blt, MATCH_BLT, MASK_BLT)
1039DECLARE_INSN(bge, MATCH_BGE, MASK_BGE)
1040DECLARE_INSN(bltu, MATCH_BLTU, MASK_BLTU)
1041DECLARE_INSN(bgeu, MATCH_BGEU, MASK_BGEU)
1042DECLARE_INSN(jalr, MATCH_JALR, MASK_JALR)
1043DECLARE_INSN(jal, MATCH_JAL, MASK_JAL)
1044DECLARE_INSN(lui, MATCH_LUI, MASK_LUI)
1045DECLARE_INSN(auipc, MATCH_AUIPC, MASK_AUIPC)
1046DECLARE_INSN(addi, MATCH_ADDI, MASK_ADDI)
1047DECLARE_INSN(slli, MATCH_SLLI, MASK_SLLI)
1048DECLARE_INSN(slti, MATCH_SLTI, MASK_SLTI)
1049DECLARE_INSN(sltiu, MATCH_SLTIU, MASK_SLTIU)
1050DECLARE_INSN(xori, MATCH_XORI, MASK_XORI)
1051DECLARE_INSN(srli, MATCH_SRLI, MASK_SRLI)
1052DECLARE_INSN(srai, MATCH_SRAI, MASK_SRAI)
1053DECLARE_INSN(ori, MATCH_ORI, MASK_ORI)
1054DECLARE_INSN(andi, MATCH_ANDI, MASK_ANDI)
1055DECLARE_INSN(add, MATCH_ADD, MASK_ADD)
1056DECLARE_INSN(sub, MATCH_SUB, MASK_SUB)
1057DECLARE_INSN(sll, MATCH_SLL, MASK_SLL)
1058DECLARE_INSN(slt, MATCH_SLT, MASK_SLT)
1059DECLARE_INSN(sltu, MATCH_SLTU, MASK_SLTU)
1060DECLARE_INSN(xor, MATCH_XOR, MASK_XOR)
1061DECLARE_INSN(srl, MATCH_SRL, MASK_SRL)
1062DECLARE_INSN(sra, MATCH_SRA, MASK_SRA)
1063DECLARE_INSN( or , MATCH_OR, MASK_OR)
1064DECLARE_INSN( and , MATCH_AND, MASK_AND)
1065DECLARE_INSN(addiw, MATCH_ADDIW, MASK_ADDIW)
1066DECLARE_INSN(slliw, MATCH_SLLIW, MASK_SLLIW)
1067DECLARE_INSN(srliw, MATCH_SRLIW, MASK_SRLIW)
1068DECLARE_INSN(sraiw, MATCH_SRAIW, MASK_SRAIW)
1069DECLARE_INSN(addw, MATCH_ADDW, MASK_ADDW)
1070DECLARE_INSN(subw, MATCH_SUBW, MASK_SUBW)
1071DECLARE_INSN(sllw, MATCH_SLLW, MASK_SLLW)
1072DECLARE_INSN(srlw, MATCH_SRLW, MASK_SRLW)
1073DECLARE_INSN(sraw, MATCH_SRAW, MASK_SRAW)
1074DECLARE_INSN(lb, MATCH_LB, MASK_LB)
1075DECLARE_INSN(lh, MATCH_LH, MASK_LH)
1076DECLARE_INSN(lw, MATCH_LW, MASK_LW)
1077DECLARE_INSN(ld, MATCH_LD, MASK_LD)
1078DECLARE_INSN(lbu, MATCH_LBU, MASK_LBU)
1079DECLARE_INSN(lhu, MATCH_LHU, MASK_LHU)
1080DECLARE_INSN(lwu, MATCH_LWU, MASK_LWU)
1081DECLARE_INSN(sb, MATCH_SB, MASK_SB)
1082DECLARE_INSN(sh, MATCH_SH, MASK_SH)
1083DECLARE_INSN(sw, MATCH_SW, MASK_SW)
1084DECLARE_INSN(sd, MATCH_SD, MASK_SD)
1085DECLARE_INSN(fence, MATCH_FENCE, MASK_FENCE)
1086DECLARE_INSN(fence_i, MATCH_FENCE_I, MASK_FENCE_I)
1087DECLARE_INSN(mul, MATCH_MUL, MASK_MUL)
1088DECLARE_INSN(mulh, MATCH_MULH, MASK_MULH)
1089DECLARE_INSN(mulhsu, MATCH_MULHSU, MASK_MULHSU)
1090DECLARE_INSN(mulhu, MATCH_MULHU, MASK_MULHU)
1091DECLARE_INSN(div, MATCH_DIV, MASK_DIV)
1092DECLARE_INSN(divu, MATCH_DIVU, MASK_DIVU)
1093DECLARE_INSN(rem, MATCH_REM, MASK_REM)
1094DECLARE_INSN(remu, MATCH_REMU, MASK_REMU)
1095DECLARE_INSN(mulw, MATCH_MULW, MASK_MULW)
1096DECLARE_INSN(divw, MATCH_DIVW, MASK_DIVW)
1097DECLARE_INSN(divuw, MATCH_DIVUW, MASK_DIVUW)
1098DECLARE_INSN(remw, MATCH_REMW, MASK_REMW)
1099DECLARE_INSN(remuw, MATCH_REMUW, MASK_REMUW)
1100DECLARE_INSN(amoadd_w, MATCH_AMOADD_W, MASK_AMOADD_W)
1101DECLARE_INSN(amoxor_w, MATCH_AMOXOR_W, MASK_AMOXOR_W)
1102DECLARE_INSN(amoor_w, MATCH_AMOOR_W, MASK_AMOOR_W)
1103DECLARE_INSN(amoand_w, MATCH_AMOAND_W, MASK_AMOAND_W)
1104DECLARE_INSN(amomin_w, MATCH_AMOMIN_W, MASK_AMOMIN_W)
1105DECLARE_INSN(amomax_w, MATCH_AMOMAX_W, MASK_AMOMAX_W)
1106DECLARE_INSN(amominu_w, MATCH_AMOMINU_W, MASK_AMOMINU_W)
1107DECLARE_INSN(amomaxu_w, MATCH_AMOMAXU_W, MASK_AMOMAXU_W)
1108DECLARE_INSN(amoswap_w, MATCH_AMOSWAP_W, MASK_AMOSWAP_W)
1109DECLARE_INSN(lr_w, MATCH_LR_W, MASK_LR_W)
1110DECLARE_INSN(sc_w, MATCH_SC_W, MASK_SC_W)
1111DECLARE_INSN(amoadd_d, MATCH_AMOADD_D, MASK_AMOADD_D)
1112DECLARE_INSN(amoxor_d, MATCH_AMOXOR_D, MASK_AMOXOR_D)
1113DECLARE_INSN(amoor_d, MATCH_AMOOR_D, MASK_AMOOR_D)
1114DECLARE_INSN(amoand_d, MATCH_AMOAND_D, MASK_AMOAND_D)
1115DECLARE_INSN(amomin_d, MATCH_AMOMIN_D, MASK_AMOMIN_D)
1116DECLARE_INSN(amomax_d, MATCH_AMOMAX_D, MASK_AMOMAX_D)
1117DECLARE_INSN(amominu_d, MATCH_AMOMINU_D, MASK_AMOMINU_D)
1118DECLARE_INSN(amomaxu_d, MATCH_AMOMAXU_D, MASK_AMOMAXU_D)
1119DECLARE_INSN(amoswap_d, MATCH_AMOSWAP_D, MASK_AMOSWAP_D)
1120DECLARE_INSN(lr_d, MATCH_LR_D, MASK_LR_D)
1121DECLARE_INSN(sc_d, MATCH_SC_D, MASK_SC_D)
1122DECLARE_INSN(ecall, MATCH_ECALL, MASK_ECALL)
1123DECLARE_INSN(ebreak, MATCH_EBREAK, MASK_EBREAK)
1124DECLARE_INSN(uret, MATCH_URET, MASK_URET)
1125DECLARE_INSN(sret, MATCH_SRET, MASK_SRET)
1126DECLARE_INSN(mret, MATCH_MRET, MASK_MRET)
1127DECLARE_INSN(dret, MATCH_DRET, MASK_DRET)
1128DECLARE_INSN(sfence_vma, MATCH_SFENCE_VMA, MASK_SFENCE_VMA)
1129DECLARE_INSN(wfi, MATCH_WFI, MASK_WFI)
1130DECLARE_INSN(csrrw, MATCH_CSRRW, MASK_CSRRW)
1131DECLARE_INSN(csrrs, MATCH_CSRRS, MASK_CSRRS)
1132DECLARE_INSN(csrrc, MATCH_CSRRC, MASK_CSRRC)
1133DECLARE_INSN(csrrwi, MATCH_CSRRWI, MASK_CSRRWI)
1134DECLARE_INSN(csrrsi, MATCH_CSRRSI, MASK_CSRRSI)
1135DECLARE_INSN(csrrci, MATCH_CSRRCI, MASK_CSRRCI)
1136DECLARE_INSN(fadd_s, MATCH_FADD_S, MASK_FADD_S)
1137DECLARE_INSN(fsub_s, MATCH_FSUB_S, MASK_FSUB_S)
1138DECLARE_INSN(fmul_s, MATCH_FMUL_S, MASK_FMUL_S)
1139DECLARE_INSN(fdiv_s, MATCH_FDIV_S, MASK_FDIV_S)
1140DECLARE_INSN(fsgnj_s, MATCH_FSGNJ_S, MASK_FSGNJ_S)
1141DECLARE_INSN(fsgnjn_s, MATCH_FSGNJN_S, MASK_FSGNJN_S)
1142DECLARE_INSN(fsgnjx_s, MATCH_FSGNJX_S, MASK_FSGNJX_S)
1143DECLARE_INSN(fmin_s, MATCH_FMIN_S, MASK_FMIN_S)
1144DECLARE_INSN(fmax_s, MATCH_FMAX_S, MASK_FMAX_S)
1145DECLARE_INSN(fsqrt_s, MATCH_FSQRT_S, MASK_FSQRT_S)
1146DECLARE_INSN(fadd_d, MATCH_FADD_D, MASK_FADD_D)
1147DECLARE_INSN(fsub_d, MATCH_FSUB_D, MASK_FSUB_D)
1148DECLARE_INSN(fmul_d, MATCH_FMUL_D, MASK_FMUL_D)
1149DECLARE_INSN(fdiv_d, MATCH_FDIV_D, MASK_FDIV_D)
1150DECLARE_INSN(fsgnj_d, MATCH_FSGNJ_D, MASK_FSGNJ_D)
1151DECLARE_INSN(fsgnjn_d, MATCH_FSGNJN_D, MASK_FSGNJN_D)
1152DECLARE_INSN(fsgnjx_d, MATCH_FSGNJX_D, MASK_FSGNJX_D)
1153DECLARE_INSN(fmin_d, MATCH_FMIN_D, MASK_FMIN_D)
1154DECLARE_INSN(fmax_d, MATCH_FMAX_D, MASK_FMAX_D)
1155DECLARE_INSN(fcvt_s_d, MATCH_FCVT_S_D, MASK_FCVT_S_D)
1156DECLARE_INSN(fcvt_d_s, MATCH_FCVT_D_S, MASK_FCVT_D_S)
1157DECLARE_INSN(fsqrt_d, MATCH_FSQRT_D, MASK_FSQRT_D)
1158DECLARE_INSN(fadd_q, MATCH_FADD_Q, MASK_FADD_Q)
1159DECLARE_INSN(fsub_q, MATCH_FSUB_Q, MASK_FSUB_Q)
1160DECLARE_INSN(fmul_q, MATCH_FMUL_Q, MASK_FMUL_Q)
1161DECLARE_INSN(fdiv_q, MATCH_FDIV_Q, MASK_FDIV_Q)
1162DECLARE_INSN(fsgnj_q, MATCH_FSGNJ_Q, MASK_FSGNJ_Q)
1163DECLARE_INSN(fsgnjn_q, MATCH_FSGNJN_Q, MASK_FSGNJN_Q)
1164DECLARE_INSN(fsgnjx_q, MATCH_FSGNJX_Q, MASK_FSGNJX_Q)
1165DECLARE_INSN(fmin_q, MATCH_FMIN_Q, MASK_FMIN_Q)
1166DECLARE_INSN(fmax_q, MATCH_FMAX_Q, MASK_FMAX_Q)
1167DECLARE_INSN(fcvt_s_q, MATCH_FCVT_S_Q, MASK_FCVT_S_Q)
1168DECLARE_INSN(fcvt_q_s, MATCH_FCVT_Q_S, MASK_FCVT_Q_S)
1169DECLARE_INSN(fcvt_d_q, MATCH_FCVT_D_Q, MASK_FCVT_D_Q)
1170DECLARE_INSN(fcvt_q_d, MATCH_FCVT_Q_D, MASK_FCVT_Q_D)
1171DECLARE_INSN(fsqrt_q, MATCH_FSQRT_Q, MASK_FSQRT_Q)
1172DECLARE_INSN(fle_s, MATCH_FLE_S, MASK_FLE_S)
1173DECLARE_INSN(flt_s, MATCH_FLT_S, MASK_FLT_S)
1174DECLARE_INSN(feq_s, MATCH_FEQ_S, MASK_FEQ_S)
1175DECLARE_INSN(fle_d, MATCH_FLE_D, MASK_FLE_D)
1176DECLARE_INSN(flt_d, MATCH_FLT_D, MASK_FLT_D)
1177DECLARE_INSN(feq_d, MATCH_FEQ_D, MASK_FEQ_D)
1178DECLARE_INSN(fle_q, MATCH_FLE_Q, MASK_FLE_Q)
1179DECLARE_INSN(flt_q, MATCH_FLT_Q, MASK_FLT_Q)
1180DECLARE_INSN(feq_q, MATCH_FEQ_Q, MASK_FEQ_Q)
1181DECLARE_INSN(fcvt_w_s, MATCH_FCVT_W_S, MASK_FCVT_W_S)
1182DECLARE_INSN(fcvt_wu_s, MATCH_FCVT_WU_S, MASK_FCVT_WU_S)
1183DECLARE_INSN(fcvt_l_s, MATCH_FCVT_L_S, MASK_FCVT_L_S)
1184DECLARE_INSN(fcvt_lu_s, MATCH_FCVT_LU_S, MASK_FCVT_LU_S)
1185DECLARE_INSN(fmv_x_w, MATCH_FMV_X_W, MASK_FMV_X_W)
1186DECLARE_INSN(fclass_s, MATCH_FCLASS_S, MASK_FCLASS_S)
1187DECLARE_INSN(fcvt_w_d, MATCH_FCVT_W_D, MASK_FCVT_W_D)
1188DECLARE_INSN(fcvt_wu_d, MATCH_FCVT_WU_D, MASK_FCVT_WU_D)
1189DECLARE_INSN(fcvt_l_d, MATCH_FCVT_L_D, MASK_FCVT_L_D)
1190DECLARE_INSN(fcvt_lu_d, MATCH_FCVT_LU_D, MASK_FCVT_LU_D)
1191DECLARE_INSN(fmv_x_d, MATCH_FMV_X_D, MASK_FMV_X_D)
1192DECLARE_INSN(fclass_d, MATCH_FCLASS_D, MASK_FCLASS_D)
1193DECLARE_INSN(fcvt_w_q, MATCH_FCVT_W_Q, MASK_FCVT_W_Q)
1194DECLARE_INSN(fcvt_wu_q, MATCH_FCVT_WU_Q, MASK_FCVT_WU_Q)
1195DECLARE_INSN(fcvt_l_q, MATCH_FCVT_L_Q, MASK_FCVT_L_Q)
1196DECLARE_INSN(fcvt_lu_q, MATCH_FCVT_LU_Q, MASK_FCVT_LU_Q)
1197DECLARE_INSN(fmv_x_q, MATCH_FMV_X_Q, MASK_FMV_X_Q)
1198DECLARE_INSN(fclass_q, MATCH_FCLASS_Q, MASK_FCLASS_Q)
1199DECLARE_INSN(fcvt_s_w, MATCH_FCVT_S_W, MASK_FCVT_S_W)
1200DECLARE_INSN(fcvt_s_wu, MATCH_FCVT_S_WU, MASK_FCVT_S_WU)
1201DECLARE_INSN(fcvt_s_l, MATCH_FCVT_S_L, MASK_FCVT_S_L)
1202DECLARE_INSN(fcvt_s_lu, MATCH_FCVT_S_LU, MASK_FCVT_S_LU)
1203DECLARE_INSN(fmv_w_x, MATCH_FMV_W_X, MASK_FMV_W_X)
1204DECLARE_INSN(fcvt_d_w, MATCH_FCVT_D_W, MASK_FCVT_D_W)
1205DECLARE_INSN(fcvt_d_wu, MATCH_FCVT_D_WU, MASK_FCVT_D_WU)
1206DECLARE_INSN(fcvt_d_l, MATCH_FCVT_D_L, MASK_FCVT_D_L)
1207DECLARE_INSN(fcvt_d_lu, MATCH_FCVT_D_LU, MASK_FCVT_D_LU)
1208DECLARE_INSN(fmv_d_x, MATCH_FMV_D_X, MASK_FMV_D_X)
1209DECLARE_INSN(fcvt_q_w, MATCH_FCVT_Q_W, MASK_FCVT_Q_W)
1210DECLARE_INSN(fcvt_q_wu, MATCH_FCVT_Q_WU, MASK_FCVT_Q_WU)
1211DECLARE_INSN(fcvt_q_l, MATCH_FCVT_Q_L, MASK_FCVT_Q_L)
1212DECLARE_INSN(fcvt_q_lu, MATCH_FCVT_Q_LU, MASK_FCVT_Q_LU)
1213DECLARE_INSN(fmv_q_x, MATCH_FMV_Q_X, MASK_FMV_Q_X)
1214DECLARE_INSN(flw, MATCH_FLW, MASK_FLW)
1215DECLARE_INSN(fld, MATCH_FLD, MASK_FLD)
1216DECLARE_INSN(flq, MATCH_FLQ, MASK_FLQ)
1217DECLARE_INSN(fsw, MATCH_FSW, MASK_FSW)
1218DECLARE_INSN(fsd, MATCH_FSD, MASK_FSD)
1219DECLARE_INSN(fsq, MATCH_FSQ, MASK_FSQ)
1220DECLARE_INSN(fmadd_s, MATCH_FMADD_S, MASK_FMADD_S)
1221DECLARE_INSN(fmsub_s, MATCH_FMSUB_S, MASK_FMSUB_S)
1222DECLARE_INSN(fnmsub_s, MATCH_FNMSUB_S, MASK_FNMSUB_S)
1223DECLARE_INSN(fnmadd_s, MATCH_FNMADD_S, MASK_FNMADD_S)
1224DECLARE_INSN(fmadd_d, MATCH_FMADD_D, MASK_FMADD_D)
1225DECLARE_INSN(fmsub_d, MATCH_FMSUB_D, MASK_FMSUB_D)
1226DECLARE_INSN(fnmsub_d, MATCH_FNMSUB_D, MASK_FNMSUB_D)
1227DECLARE_INSN(fnmadd_d, MATCH_FNMADD_D, MASK_FNMADD_D)
1228DECLARE_INSN(fmadd_q, MATCH_FMADD_Q, MASK_FMADD_Q)
1229DECLARE_INSN(fmsub_q, MATCH_FMSUB_Q, MASK_FMSUB_Q)
1230DECLARE_INSN(fnmsub_q, MATCH_FNMSUB_Q, MASK_FNMSUB_Q)
1231DECLARE_INSN(fnmadd_q, MATCH_FNMADD_Q, MASK_FNMADD_Q)
1232DECLARE_INSN(c_nop, MATCH_C_NOP, MASK_C_NOP)
1233DECLARE_INSN(c_addi16sp, MATCH_C_ADDI16SP, MASK_C_ADDI16SP)
1234DECLARE_INSN(c_jr, MATCH_C_JR, MASK_C_JR)
1235DECLARE_INSN(c_jalr, MATCH_C_JALR, MASK_C_JALR)
1236DECLARE_INSN(c_ebreak, MATCH_C_EBREAK, MASK_C_EBREAK)
1237DECLARE_INSN(c_ld, MATCH_C_LD, MASK_C_LD)
1238DECLARE_INSN(c_sd, MATCH_C_SD, MASK_C_SD)
1239DECLARE_INSN(c_addiw, MATCH_C_ADDIW, MASK_C_ADDIW)
1240DECLARE_INSN(c_ldsp, MATCH_C_LDSP, MASK_C_LDSP)
1241DECLARE_INSN(c_sdsp, MATCH_C_SDSP, MASK_C_SDSP)
1242DECLARE_INSN(c_addi4spn, MATCH_C_ADDI4SPN, MASK_C_ADDI4SPN)
1243DECLARE_INSN(c_fld, MATCH_C_FLD, MASK_C_FLD)
1244DECLARE_INSN(c_lw, MATCH_C_LW, MASK_C_LW)
1245DECLARE_INSN(c_flw, MATCH_C_FLW, MASK_C_FLW)
1246DECLARE_INSN(c_fsd, MATCH_C_FSD, MASK_C_FSD)
1247DECLARE_INSN(c_sw, MATCH_C_SW, MASK_C_SW)
1248DECLARE_INSN(c_fsw, MATCH_C_FSW, MASK_C_FSW)
1249DECLARE_INSN(c_addi, MATCH_C_ADDI, MASK_C_ADDI)
1250DECLARE_INSN(c_jal, MATCH_C_JAL, MASK_C_JAL)
1251DECLARE_INSN(c_li, MATCH_C_LI, MASK_C_LI)
1252DECLARE_INSN(c_lui, MATCH_C_LUI, MASK_C_LUI)
1253DECLARE_INSN(c_srli, MATCH_C_SRLI, MASK_C_SRLI)
1254DECLARE_INSN(c_srai, MATCH_C_SRAI, MASK_C_SRAI)
1255DECLARE_INSN(c_andi, MATCH_C_ANDI, MASK_C_ANDI)
1256DECLARE_INSN(c_sub, MATCH_C_SUB, MASK_C_SUB)
1257DECLARE_INSN(c_xor, MATCH_C_XOR, MASK_C_XOR)
1258DECLARE_INSN(c_or, MATCH_C_OR, MASK_C_OR)
1259DECLARE_INSN(c_and, MATCH_C_AND, MASK_C_AND)
1260DECLARE_INSN(c_subw, MATCH_C_SUBW, MASK_C_SUBW)
1261DECLARE_INSN(c_addw, MATCH_C_ADDW, MASK_C_ADDW)
1262DECLARE_INSN(c_j, MATCH_C_J, MASK_C_J)
1263DECLARE_INSN(c_beqz, MATCH_C_BEQZ, MASK_C_BEQZ)
1264DECLARE_INSN(c_bnez, MATCH_C_BNEZ, MASK_C_BNEZ)
1265DECLARE_INSN(c_slli, MATCH_C_SLLI, MASK_C_SLLI)
1266DECLARE_INSN(c_fldsp, MATCH_C_FLDSP, MASK_C_FLDSP)
1267DECLARE_INSN(c_lwsp, MATCH_C_LWSP, MASK_C_LWSP)
1268DECLARE_INSN(c_flwsp, MATCH_C_FLWSP, MASK_C_FLWSP)
1269DECLARE_INSN(c_mv, MATCH_C_MV, MASK_C_MV)
1270DECLARE_INSN(c_add, MATCH_C_ADD, MASK_C_ADD)
1271DECLARE_INSN(c_fsdsp, MATCH_C_FSDSP, MASK_C_FSDSP)
1272DECLARE_INSN(c_swsp, MATCH_C_SWSP, MASK_C_SWSP)
1273DECLARE_INSN(c_fswsp, MATCH_C_FSWSP, MASK_C_FSWSP)
1274DECLARE_INSN(custom0, MATCH_CUSTOM0, MASK_CUSTOM0)
1275DECLARE_INSN(custom0_rs1, MATCH_CUSTOM0_RS1, MASK_CUSTOM0_RS1)
1276DECLARE_INSN(custom0_rs1_rs2, MATCH_CUSTOM0_RS1_RS2, MASK_CUSTOM0_RS1_RS2)
1277DECLARE_INSN(custom0_rd, MATCH_CUSTOM0_RD, MASK_CUSTOM0_RD)
1278DECLARE_INSN(custom0_rd_rs1, MATCH_CUSTOM0_RD_RS1, MASK_CUSTOM0_RD_RS1)
1279DECLARE_INSN(custom0_rd_rs1_rs2, MATCH_CUSTOM0_RD_RS1_RS2, MASK_CUSTOM0_RD_RS1_RS2)
1280DECLARE_INSN(custom1, MATCH_CUSTOM1, MASK_CUSTOM1)
1281DECLARE_INSN(custom1_rs1, MATCH_CUSTOM1_RS1, MASK_CUSTOM1_RS1)
1282DECLARE_INSN(custom1_rs1_rs2, MATCH_CUSTOM1_RS1_RS2, MASK_CUSTOM1_RS1_RS2)
1283DECLARE_INSN(custom1_rd, MATCH_CUSTOM1_RD, MASK_CUSTOM1_RD)
1284DECLARE_INSN(custom1_rd_rs1, MATCH_CUSTOM1_RD_RS1, MASK_CUSTOM1_RD_RS1)
1285DECLARE_INSN(custom1_rd_rs1_rs2, MATCH_CUSTOM1_RD_RS1_RS2, MASK_CUSTOM1_RD_RS1_RS2)
1286DECLARE_INSN(custom2, MATCH_CUSTOM2, MASK_CUSTOM2)
1287DECLARE_INSN(custom2_rs1, MATCH_CUSTOM2_RS1, MASK_CUSTOM2_RS1)
1288DECLARE_INSN(custom2_rs1_rs2, MATCH_CUSTOM2_RS1_RS2, MASK_CUSTOM2_RS1_RS2)
1289DECLARE_INSN(custom2_rd, MATCH_CUSTOM2_RD, MASK_CUSTOM2_RD)
1290DECLARE_INSN(custom2_rd_rs1, MATCH_CUSTOM2_RD_RS1, MASK_CUSTOM2_RD_RS1)
1291DECLARE_INSN(custom2_rd_rs1_rs2, MATCH_CUSTOM2_RD_RS1_RS2, MASK_CUSTOM2_RD_RS1_RS2)
1292DECLARE_INSN(custom3, MATCH_CUSTOM3, MASK_CUSTOM3)
1293DECLARE_INSN(custom3_rs1, MATCH_CUSTOM3_RS1, MASK_CUSTOM3_RS1)
1294DECLARE_INSN(custom3_rs1_rs2, MATCH_CUSTOM3_RS1_RS2, MASK_CUSTOM3_RS1_RS2)
1295DECLARE_INSN(custom3_rd, MATCH_CUSTOM3_RD, MASK_CUSTOM3_RD)
1296DECLARE_INSN(custom3_rd_rs1, MATCH_CUSTOM3_RD_RS1, MASK_CUSTOM3_RD_RS1)
1297DECLARE_INSN(custom3_rd_rs1_rs2, MATCH_CUSTOM3_RD_RS1_RS2, MASK_CUSTOM3_RD_RS1_RS2)
1298#endif
1299#ifdef DECLARE_CSR
1300DECLARE_CSR(fflags, CSR_FFLAGS)
1301DECLARE_CSR(frm, CSR_FRM)
1302DECLARE_CSR(fcsr, CSR_FCSR)
1303DECLARE_CSR(cycle, CSR_CYCLE)
1304DECLARE_CSR(time, CSR_TIME)
1305DECLARE_CSR(instret, CSR_INSTRET)
1306DECLARE_CSR(hpmcounter3, CSR_HPMCOUNTER3)
1307DECLARE_CSR(hpmcounter4, CSR_HPMCOUNTER4)
1308DECLARE_CSR(hpmcounter5, CSR_HPMCOUNTER5)
1309DECLARE_CSR(hpmcounter6, CSR_HPMCOUNTER6)
1310DECLARE_CSR(hpmcounter7, CSR_HPMCOUNTER7)
1311DECLARE_CSR(hpmcounter8, CSR_HPMCOUNTER8)
1312DECLARE_CSR(hpmcounter9, CSR_HPMCOUNTER9)
1313DECLARE_CSR(hpmcounter10, CSR_HPMCOUNTER10)
1314DECLARE_CSR(hpmcounter11, CSR_HPMCOUNTER11)
1315DECLARE_CSR(hpmcounter12, CSR_HPMCOUNTER12)
1316DECLARE_CSR(hpmcounter13, CSR_HPMCOUNTER13)
1317DECLARE_CSR(hpmcounter14, CSR_HPMCOUNTER14)
1318DECLARE_CSR(hpmcounter15, CSR_HPMCOUNTER15)
1319DECLARE_CSR(hpmcounter16, CSR_HPMCOUNTER16)
1320DECLARE_CSR(hpmcounter17, CSR_HPMCOUNTER17)
1321DECLARE_CSR(hpmcounter18, CSR_HPMCOUNTER18)
1322DECLARE_CSR(hpmcounter19, CSR_HPMCOUNTER19)
1323DECLARE_CSR(hpmcounter20, CSR_HPMCOUNTER20)
1324DECLARE_CSR(hpmcounter21, CSR_HPMCOUNTER21)
1325DECLARE_CSR(hpmcounter22, CSR_HPMCOUNTER22)
1326DECLARE_CSR(hpmcounter23, CSR_HPMCOUNTER23)
1327DECLARE_CSR(hpmcounter24, CSR_HPMCOUNTER24)
1328DECLARE_CSR(hpmcounter25, CSR_HPMCOUNTER25)
1329DECLARE_CSR(hpmcounter26, CSR_HPMCOUNTER26)
1330DECLARE_CSR(hpmcounter27, CSR_HPMCOUNTER27)
1331DECLARE_CSR(hpmcounter28, CSR_HPMCOUNTER28)
1332DECLARE_CSR(hpmcounter29, CSR_HPMCOUNTER29)
1333DECLARE_CSR(hpmcounter30, CSR_HPMCOUNTER30)
1334DECLARE_CSR(hpmcounter31, CSR_HPMCOUNTER31)
1335DECLARE_CSR(sstatus, CSR_SSTATUS)
1336DECLARE_CSR(sie, CSR_SIE)
1337DECLARE_CSR(stvec, CSR_STVEC)
1338DECLARE_CSR(scounteren, CSR_SCOUNTEREN)
1339DECLARE_CSR(sscratch, CSR_SSCRATCH)
1340DECLARE_CSR(sepc, CSR_SEPC)
1341DECLARE_CSR(scause, CSR_SCAUSE)
1342DECLARE_CSR(sbadaddr, CSR_SBADADDR)
1343DECLARE_CSR(sip, CSR_SIP)
1344DECLARE_CSR(sptbr, CSR_SPTBR)
1345DECLARE_CSR(mstatus, CSR_MSTATUS)
1346DECLARE_CSR(misa, CSR_MISA)
1347DECLARE_CSR(medeleg, CSR_MEDELEG)
1348DECLARE_CSR(mideleg, CSR_MIDELEG)
1349DECLARE_CSR(mie, CSR_MIE)
1350DECLARE_CSR(mtvec, CSR_MTVEC)
1351DECLARE_CSR(mcounteren, CSR_MCOUNTEREN)
1352DECLARE_CSR(mscratch, CSR_MSCRATCH)
1353DECLARE_CSR(mepc, CSR_MEPC)
1354DECLARE_CSR(mcause, CSR_MCAUSE)
1355DECLARE_CSR(mbadaddr, CSR_MBADADDR)
1356DECLARE_CSR(mip, CSR_MIP)
1357DECLARE_CSR(pmpcfg0, CSR_PMPCFG0)
1358DECLARE_CSR(pmpcfg1, CSR_PMPCFG1)
1359DECLARE_CSR(pmpcfg2, CSR_PMPCFG2)
1360DECLARE_CSR(pmpcfg3, CSR_PMPCFG3)
1361DECLARE_CSR(pmpaddr0, CSR_PMPADDR0)
1362DECLARE_CSR(pmpaddr1, CSR_PMPADDR1)
1363DECLARE_CSR(pmpaddr2, CSR_PMPADDR2)
1364DECLARE_CSR(pmpaddr3, CSR_PMPADDR3)
1365DECLARE_CSR(pmpaddr4, CSR_PMPADDR4)
1366DECLARE_CSR(pmpaddr5, CSR_PMPADDR5)
1367DECLARE_CSR(pmpaddr6, CSR_PMPADDR6)
1368DECLARE_CSR(pmpaddr7, CSR_PMPADDR7)
1369DECLARE_CSR(pmpaddr8, CSR_PMPADDR8)
1370DECLARE_CSR(pmpaddr9, CSR_PMPADDR9)
1371DECLARE_CSR(pmpaddr10, CSR_PMPADDR10)
1372DECLARE_CSR(pmpaddr11, CSR_PMPADDR11)
1373DECLARE_CSR(pmpaddr12, CSR_PMPADDR12)
1374DECLARE_CSR(pmpaddr13, CSR_PMPADDR13)
1375DECLARE_CSR(pmpaddr14, CSR_PMPADDR14)
1376DECLARE_CSR(pmpaddr15, CSR_PMPADDR15)
1377DECLARE_CSR(tselect, CSR_TSELECT)
1378DECLARE_CSR(tdata1, CSR_TDATA1)
1379DECLARE_CSR(tdata2, CSR_TDATA2)
1380DECLARE_CSR(tdata3, CSR_TDATA3)
1381DECLARE_CSR(dcsr, CSR_DCSR)
1382DECLARE_CSR(dpc, CSR_DPC)
1383DECLARE_CSR(dscratch, CSR_DSCRATCH)
1384DECLARE_CSR(mcycle, CSR_MCYCLE)
1385DECLARE_CSR(minstret, CSR_MINSTRET)
1386DECLARE_CSR(mhpmcounter3, CSR_MHPMCOUNTER3)
1387DECLARE_CSR(mhpmcounter4, CSR_MHPMCOUNTER4)
1388DECLARE_CSR(mhpmcounter5, CSR_MHPMCOUNTER5)
1389DECLARE_CSR(mhpmcounter6, CSR_MHPMCOUNTER6)
1390DECLARE_CSR(mhpmcounter7, CSR_MHPMCOUNTER7)
1391DECLARE_CSR(mhpmcounter8, CSR_MHPMCOUNTER8)
1392DECLARE_CSR(mhpmcounter9, CSR_MHPMCOUNTER9)
1393DECLARE_CSR(mhpmcounter10, CSR_MHPMCOUNTER10)
1394DECLARE_CSR(mhpmcounter11, CSR_MHPMCOUNTER11)
1395DECLARE_CSR(mhpmcounter12, CSR_MHPMCOUNTER12)
1396DECLARE_CSR(mhpmcounter13, CSR_MHPMCOUNTER13)
1397DECLARE_CSR(mhpmcounter14, CSR_MHPMCOUNTER14)
1398DECLARE_CSR(mhpmcounter15, CSR_MHPMCOUNTER15)
1399DECLARE_CSR(mhpmcounter16, CSR_MHPMCOUNTER16)
1400DECLARE_CSR(mhpmcounter17, CSR_MHPMCOUNTER17)
1401DECLARE_CSR(mhpmcounter18, CSR_MHPMCOUNTER18)
1402DECLARE_CSR(mhpmcounter19, CSR_MHPMCOUNTER19)
1403DECLARE_CSR(mhpmcounter20, CSR_MHPMCOUNTER20)
1404DECLARE_CSR(mhpmcounter21, CSR_MHPMCOUNTER21)
1405DECLARE_CSR(mhpmcounter22, CSR_MHPMCOUNTER22)
1406DECLARE_CSR(mhpmcounter23, CSR_MHPMCOUNTER23)
1407DECLARE_CSR(mhpmcounter24, CSR_MHPMCOUNTER24)
1408DECLARE_CSR(mhpmcounter25, CSR_MHPMCOUNTER25)
1409DECLARE_CSR(mhpmcounter26, CSR_MHPMCOUNTER26)
1410DECLARE_CSR(mhpmcounter27, CSR_MHPMCOUNTER27)
1411DECLARE_CSR(mhpmcounter28, CSR_MHPMCOUNTER28)
1412DECLARE_CSR(mhpmcounter29, CSR_MHPMCOUNTER29)
1413DECLARE_CSR(mhpmcounter30, CSR_MHPMCOUNTER30)
1414DECLARE_CSR(mhpmcounter31, CSR_MHPMCOUNTER31)
1415DECLARE_CSR(mhpmevent3, CSR_MHPMEVENT3)
1416DECLARE_CSR(mhpmevent4, CSR_MHPMEVENT4)
1417DECLARE_CSR(mhpmevent5, CSR_MHPMEVENT5)
1418DECLARE_CSR(mhpmevent6, CSR_MHPMEVENT6)
1419DECLARE_CSR(mhpmevent7, CSR_MHPMEVENT7)
1420DECLARE_CSR(mhpmevent8, CSR_MHPMEVENT8)
1421DECLARE_CSR(mhpmevent9, CSR_MHPMEVENT9)
1422DECLARE_CSR(mhpmevent10, CSR_MHPMEVENT10)
1423DECLARE_CSR(mhpmevent11, CSR_MHPMEVENT11)
1424DECLARE_CSR(mhpmevent12, CSR_MHPMEVENT12)
1425DECLARE_CSR(mhpmevent13, CSR_MHPMEVENT13)
1426DECLARE_CSR(mhpmevent14, CSR_MHPMEVENT14)
1427DECLARE_CSR(mhpmevent15, CSR_MHPMEVENT15)
1428DECLARE_CSR(mhpmevent16, CSR_MHPMEVENT16)
1429DECLARE_CSR(mhpmevent17, CSR_MHPMEVENT17)
1430DECLARE_CSR(mhpmevent18, CSR_MHPMEVENT18)
1431DECLARE_CSR(mhpmevent19, CSR_MHPMEVENT19)
1432DECLARE_CSR(mhpmevent20, CSR_MHPMEVENT20)
1433DECLARE_CSR(mhpmevent21, CSR_MHPMEVENT21)
1434DECLARE_CSR(mhpmevent22, CSR_MHPMEVENT22)
1435DECLARE_CSR(mhpmevent23, CSR_MHPMEVENT23)
1436DECLARE_CSR(mhpmevent24, CSR_MHPMEVENT24)
1437DECLARE_CSR(mhpmevent25, CSR_MHPMEVENT25)
1438DECLARE_CSR(mhpmevent26, CSR_MHPMEVENT26)
1439DECLARE_CSR(mhpmevent27, CSR_MHPMEVENT27)
1440DECLARE_CSR(mhpmevent28, CSR_MHPMEVENT28)
1441DECLARE_CSR(mhpmevent29, CSR_MHPMEVENT29)
1442DECLARE_CSR(mhpmevent30, CSR_MHPMEVENT30)
1443DECLARE_CSR(mhpmevent31, CSR_MHPMEVENT31)
1444DECLARE_CSR(mvendorid, CSR_MVENDORID)
1445DECLARE_CSR(marchid, CSR_MARCHID)
1446DECLARE_CSR(mimpid, CSR_MIMPID)
1447DECLARE_CSR(mhartid, CSR_MHARTID)
1448DECLARE_CSR(cycleh, CSR_CYCLEH)
1449DECLARE_CSR(timeh, CSR_TIMEH)
1450DECLARE_CSR(instreth, CSR_INSTRETH)
1451DECLARE_CSR(hpmcounter3h, CSR_HPMCOUNTER3H)
1452DECLARE_CSR(hpmcounter4h, CSR_HPMCOUNTER4H)
1453DECLARE_CSR(hpmcounter5h, CSR_HPMCOUNTER5H)
1454DECLARE_CSR(hpmcounter6h, CSR_HPMCOUNTER6H)
1455DECLARE_CSR(hpmcounter7h, CSR_HPMCOUNTER7H)
1456DECLARE_CSR(hpmcounter8h, CSR_HPMCOUNTER8H)
1457DECLARE_CSR(hpmcounter9h, CSR_HPMCOUNTER9H)
1458DECLARE_CSR(hpmcounter10h, CSR_HPMCOUNTER10H)
1459DECLARE_CSR(hpmcounter11h, CSR_HPMCOUNTER11H)
1460DECLARE_CSR(hpmcounter12h, CSR_HPMCOUNTER12H)
1461DECLARE_CSR(hpmcounter13h, CSR_HPMCOUNTER13H)
1462DECLARE_CSR(hpmcounter14h, CSR_HPMCOUNTER14H)
1463DECLARE_CSR(hpmcounter15h, CSR_HPMCOUNTER15H)
1464DECLARE_CSR(hpmcounter16h, CSR_HPMCOUNTER16H)
1465DECLARE_CSR(hpmcounter17h, CSR_HPMCOUNTER17H)
1466DECLARE_CSR(hpmcounter18h, CSR_HPMCOUNTER18H)
1467DECLARE_CSR(hpmcounter19h, CSR_HPMCOUNTER19H)
1468DECLARE_CSR(hpmcounter20h, CSR_HPMCOUNTER20H)
1469DECLARE_CSR(hpmcounter21h, CSR_HPMCOUNTER21H)
1470DECLARE_CSR(hpmcounter22h, CSR_HPMCOUNTER22H)
1471DECLARE_CSR(hpmcounter23h, CSR_HPMCOUNTER23H)
1472DECLARE_CSR(hpmcounter24h, CSR_HPMCOUNTER24H)
1473DECLARE_CSR(hpmcounter25h, CSR_HPMCOUNTER25H)
1474DECLARE_CSR(hpmcounter26h, CSR_HPMCOUNTER26H)
1475DECLARE_CSR(hpmcounter27h, CSR_HPMCOUNTER27H)
1476DECLARE_CSR(hpmcounter28h, CSR_HPMCOUNTER28H)
1477DECLARE_CSR(hpmcounter29h, CSR_HPMCOUNTER29H)
1478DECLARE_CSR(hpmcounter30h, CSR_HPMCOUNTER30H)
1479DECLARE_CSR(hpmcounter31h, CSR_HPMCOUNTER31H)
1480DECLARE_CSR(mcycleh, CSR_MCYCLEH)
1481DECLARE_CSR(minstreth, CSR_MINSTRETH)
1482DECLARE_CSR(mhpmcounter3h, CSR_MHPMCOUNTER3H)
1483DECLARE_CSR(mhpmcounter4h, CSR_MHPMCOUNTER4H)
1484DECLARE_CSR(mhpmcounter5h, CSR_MHPMCOUNTER5H)
1485DECLARE_CSR(mhpmcounter6h, CSR_MHPMCOUNTER6H)
1486DECLARE_CSR(mhpmcounter7h, CSR_MHPMCOUNTER7H)
1487DECLARE_CSR(mhpmcounter8h, CSR_MHPMCOUNTER8H)
1488DECLARE_CSR(mhpmcounter9h, CSR_MHPMCOUNTER9H)
1489DECLARE_CSR(mhpmcounter10h, CSR_MHPMCOUNTER10H)
1490DECLARE_CSR(mhpmcounter11h, CSR_MHPMCOUNTER11H)
1491DECLARE_CSR(mhpmcounter12h, CSR_MHPMCOUNTER12H)
1492DECLARE_CSR(mhpmcounter13h, CSR_MHPMCOUNTER13H)
1493DECLARE_CSR(mhpmcounter14h, CSR_MHPMCOUNTER14H)
1494DECLARE_CSR(mhpmcounter15h, CSR_MHPMCOUNTER15H)
1495DECLARE_CSR(mhpmcounter16h, CSR_MHPMCOUNTER16H)
1496DECLARE_CSR(mhpmcounter17h, CSR_MHPMCOUNTER17H)
1497DECLARE_CSR(mhpmcounter18h, CSR_MHPMCOUNTER18H)
1498DECLARE_CSR(mhpmcounter19h, CSR_MHPMCOUNTER19H)
1499DECLARE_CSR(mhpmcounter20h, CSR_MHPMCOUNTER20H)
1500DECLARE_CSR(mhpmcounter21h, CSR_MHPMCOUNTER21H)
1501DECLARE_CSR(mhpmcounter22h, CSR_MHPMCOUNTER22H)
1502DECLARE_CSR(mhpmcounter23h, CSR_MHPMCOUNTER23H)
1503DECLARE_CSR(mhpmcounter24h, CSR_MHPMCOUNTER24H)
1504DECLARE_CSR(mhpmcounter25h, CSR_MHPMCOUNTER25H)
1505DECLARE_CSR(mhpmcounter26h, CSR_MHPMCOUNTER26H)
1506DECLARE_CSR(mhpmcounter27h, CSR_MHPMCOUNTER27H)
1507DECLARE_CSR(mhpmcounter28h, CSR_MHPMCOUNTER28H)
1508DECLARE_CSR(mhpmcounter29h, CSR_MHPMCOUNTER29H)
1509DECLARE_CSR(mhpmcounter30h, CSR_MHPMCOUNTER30H)
1510DECLARE_CSR(mhpmcounter31h, CSR_MHPMCOUNTER31H)
1511#endif
1512#ifdef DECLARE_CAUSE
1513DECLARE_CAUSE("misaligned fetch", CAUSE_MISALIGNED_FETCH)
1514DECLARE_CAUSE("fetch access", CAUSE_FETCH_ACCESS)
1515DECLARE_CAUSE("illegal instruction", CAUSE_ILLEGAL_INSTRUCTION)
1516DECLARE_CAUSE("breakpoint", CAUSE_BREAKPOINT)
1517DECLARE_CAUSE("misaligned load", CAUSE_MISALIGNED_LOAD)
1518DECLARE_CAUSE("load access", CAUSE_LOAD_ACCESS)
1519DECLARE_CAUSE("misaligned store", CAUSE_MISALIGNED_STORE)
1520DECLARE_CAUSE("store access", CAUSE_STORE_ACCESS)
1521DECLARE_CAUSE("user_ecall", CAUSE_USER_ECALL)
1522DECLARE_CAUSE("supervisor_ecall", CAUSE_SUPERVISOR_ECALL)
1523DECLARE_CAUSE("hypervisor_ecall", CAUSE_HYPERVISOR_ECALL)
1524DECLARE_CAUSE("machine_ecall", CAUSE_MACHINE_ECALL)
1525DECLARE_CAUSE("fetch page fault", CAUSE_FETCH_PAGE_FAULT)
1526DECLARE_CAUSE("load page fault", CAUSE_LOAD_PAGE_FAULT)
1527DECLARE_CAUSE("store page fault", CAUSE_STORE_PAGE_FAULT)
1528#endif
