Time Test 27 routines.
More...
#define | MUST_WAIT_FOR_INTERRUPT 0 |
#define | TM27_USE_VECTOR_HANDLER |
| #define | Install_tm27_vector(handler) |
#define | Cause_tm27_intr() asm volatile ("trap #3"); |
#define | Clear_tm27_intr() /* empty */ |
#define | Lower_tm27_intr() /* empty */ |
◆ Install_tm27_vector
| #define Install_tm27_vector |
handler | ) |
Value:
35, \
"Install tm27 interrupt", \
(void *)handler, \
NULL \
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler routine, void *arg)
Installs the interrupt handler routine and argument at the interrupt vector.
Definition: irq-handler-install.c:85
#define RTEMS_INTERRUPT_UNIQUE
This interrupt handler install option ensures that the interrupt handler is unique.
Definition: intr.h:972
