RTEMS 7.0-rc1
Macros | Functions
Serial Mouse Driver
#define SERIAL_MOUSE_DEVICE_PS2   "/dev/psaux"
 Standard device file path for a PS2 mouse device.
#define SERIAL_MOUSE_DRIVER_TABLE_ENTRY
rtems_device_driver serial_mouse_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 The initialization of the serial mouse driver.
rtems_device_driver serial_mouse_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Open device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Close device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Read device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Write device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 IO Control device driver entry point for the serial mouse driver.
bool bsp_get_serial_mouse_device (const char **name, const char **type)
 Obtain serial mouse configuration information.
◆ SERIAL_MOUSE_DRIVER_TABLE_ENTRY
Value:
rtems_device_driver serial_mouse_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: serial_mouse.c:160
rtems_device_driver serial_mouse_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: serial_mouse.c:189
rtems_device_driver serial_mouse_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: serial_mouse.c:203
rtems_device_driver serial_mouse_read(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: serial_mouse.c:175
rtems_device_driver serial_mouse_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: serial_mouse.c:80
rtems_device_driver serial_mouse_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: serial_mouse.c:104
This macro defines the serial mouse device driver entry points.
◆ bsp_get_serial_mouse_device()
bool bsp_get_serial_mouse_device ( const char **  name,
const char **  type
This method is implemented by the BSP or application and tells the driver what device to open() and what type of mouse is connected.
Parameters
[in]namewill point to a string with the device name of the serial port with the mouse connected.
[in]typewill point to a string with the type of mouse connected.
Return values
Thismethod returns true on success and false on error.
◆ serial_mouse_close()
rtems_device_driver serial_mouse_close ( rtems_device_major_number  major,
void *  arg
This method implements the Close device driver entry point for the serial mouse driver.
Parameters
[in]majoris the mouse device major number
[in]minoris the mouse device minor number
[in]argpoints to device driver arguments
◆ serial_mouse_control()
rtems_device_driver serial_mouse_control ( rtems_device_major_number  major,
void *  arg
This method implements the IO Control device driver entry point for the serial mouse driver.
Parameters
◆ serial_mouse_initialize()
rtems_device_driver serial_mouse_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the serial mouse driver.
Parameters
◆ serial_mouse_open()
rtems_device_driver serial_mouse_open ( rtems_device_major_number  major,
void *  arg
This method implements the Open device driver entry point for the serial mouse driver.
Parameters
◆ serial_mouse_read()
rtems_device_driver serial_mouse_read ( rtems_device_major_number  major,
void *  arg
This method implements the Read device driver entry point for the serial mouse driver.
Parameters
◆ serial_mouse_write()
rtems_device_driver serial_mouse_write ( rtems_device_major_number  major,
void *  arg
This method implements the Write device driver entry point for the serial mouse driver.
Parameters
