RTEMS 7.0-rc1
Data Structures | Enumerator | Variables
Gpt
struct  _gpt_init_config
 Structure to configure the running mode. More...
gpt_clock_source_t _gpt_init_config::clockSource
uint32_t _gpt_init_config::divider
bool _gpt_init_config::enableFreeRun
bool _gpt_init_config::enableRunInWait
bool _gpt_init_config::enableRunInStop
bool _gpt_init_config::enableRunInDoze
bool _gpt_init_config::enableRunInDbg
bool _gpt_init_config::enableMode
Driver version
enum  _gpt_clock_source {
  kGPT_ClockSource_Off = 0U , kGPT_ClockSource_Periph = 1U , kGPT_ClockSource_HighFreq = 2U , kGPT_ClockSource_Ext = 3U ,
  kGPT_ClockSource_LowFreq = 4U , kGPT_ClockSource_Osc = 5U
 List of clock sources. More...
enum  _gpt_input_capture_channel { kGPT_InputCapture_Channel1 = 0U , kGPT_InputCapture_Channel2 = 1U }
 List of input capture channel number. More...
enum  _gpt_input_operation_mode { kGPT_InputOperation_Disabled = 0U , kGPT_InputOperation_RiseEdge = 1U , kGPT_InputOperation_FallEdge = 2U , kGPT_InputOperation_BothEdge = 3U }
 List of input capture operation mode. More...
enum  _gpt_output_compare_channel { kGPT_OutputCompare_Channel1 = 0U , kGPT_OutputCompare_Channel2 = 1U , kGPT_OutputCompare_Channel3 = 2U }
 List of output compare channel number. More...
enum  _gpt_output_operation_mode {
  kGPT_OutputOperation_Disconnected = 0U , kGPT_OutputOperation_Toggle = 1U , kGPT_OutputOperation_Clear = 2U , kGPT_OutputOperation_Set = 3U ,
  kGPT_OutputOperation_Activelow = 4U
 List of output compare operation mode. More...
enum  _gpt_interrupt_enable {
  kGPT_OutputCompare1InterruptEnable = GPT_IR_OF1IE_MASK , kGPT_OutputCompare2InterruptEnable = GPT_IR_OF2IE_MASK , kGPT_OutputCompare3InterruptEnable = GPT_IR_OF3IE_MASK , kGPT_InputCapture1InterruptEnable = GPT_IR_IF1IE_MASK ,
  kGPT_InputCapture2InterruptEnable = GPT_IR_IF2IE_MASK , kGPT_RollOverFlagInterruptEnable = GPT_IR_ROVIE_MASK
 List of GPT interrupts. More...
enum  _gpt_status_flag {
  kGPT_OutputCompare1Flag = GPT_SR_OF1_MASK , kGPT_OutputCompare2Flag = GPT_SR_OF2_MASK , kGPT_OutputCompare3Flag = GPT_SR_OF3_MASK , kGPT_InputCapture1Flag = GPT_SR_IF1_MASK ,
  kGPT_InputCapture2Flag = GPT_SR_IF2_MASK , kGPT_RollOverFlag = GPT_SR_ROV_MASK
 Status flag. More...
typedef enum _gpt_clock_source gpt_clock_source_t
typedef enum _gpt_input_capture_channel gpt_input_capture_channel_t
typedef enum _gpt_input_operation_mode gpt_input_operation_mode_t
typedef enum _gpt_output_compare_channel gpt_output_compare_channel_t
typedef enum _gpt_output_operation_mode gpt_output_operation_mode_t
typedef enum _gpt_interrupt_enable gpt_interrupt_enable_t
typedef enum _gpt_status_flag gpt_status_flag_t
 Status flag.
typedef struct _gpt_init_config gpt_config_t
#define FSL_GPT_DRIVER_VERSION   (MAKE_VERSION(2, 0, 4))
Initialization and deinitialization
void GPT_Init (GPT_Type *base, const gpt_config_t *initConfig)
 Initialize GPT to reset state and initialize running mode.
void GPT_Deinit (GPT_Type *base)
 Disables the module and gates the GPT clock.
void GPT_GetDefaultConfig (gpt_config_t *config)
 Fills in the GPT configuration structure with default settings.
Typedef Documentation
◆ gpt_clock_source_t
Note
Actual number of clock sources is SoC dependent
◆ _gpt_clock_source
Note
GPT Clock Source Off.
GPT Clock Source from Peripheral Clock.
GPT Clock Source from High Frequency Reference Clock.
GPT Clock Source from external pin.
GPT Clock Source from Low Frequency Reference Clock.
GPT Clock Source from Crystal oscillator.
◆ _gpt_input_capture_channel
GPT Input Capture Channel1.
GPT Input Capture Channel2.
◆ _gpt_input_operation_mode
Don't capture.
Capture on rising edge of input pin.
Capture on falling edge of input pin.
Capture on both edges of input pin.
◆ _gpt_interrupt_enable
Output Compare Channel1 interrupt enable
Output Compare Channel2 interrupt enable
Output Compare Channel3 interrupt enable
Input Capture Channel1 interrupt enable
Counter rolled over interrupt enable
◆ _gpt_output_compare_channel
Output Compare Channel1.
Output Compare Channel2.
Output Compare Channel3.
◆ _gpt_output_operation_mode
Don't change output pin.
Toggle output pin.
Set output pin low.
Set output pin high.
Generate a active low pulse on output pin.
◆ _gpt_status_flag
Status flag.
Output compare channel 1 event.
Output compare channel 2 event.
Output compare channel 3 event.
Input Capture channel 1 event.
Input Capture channel 2 event.
kGPT_RollOverFlag
Counter reaches maximum value and rolled over to 0 event.
◆ GPT_Deinit()
void GPT_Deinit ( GPT_Type base)
Parameters
baseGPT peripheral base address.
brief Disables the module and gates the GPT clock.
param base GPT peripheral base address.
◆ GPT_GetDefaultConfig()
void GPT_GetDefaultConfig ( gpt_config_t config)
The default values are:
config->clockSource = kGPT_ClockSource_Periph;
config->divider = 1U;
config->enableRunInStop = true;
config->enableRunInWait = true;
config->enableRunInDoze = false;
config->enableRunInDbg = false;
config->enableFreeRun = false;
config->enableMode = true;
@ kGPT_ClockSource_Periph
Definition: fsl_gpt.h:35
Parameters
configPointer to the user configuration structure.
brief Fills in the GPT configuration structure with default settings.
The default values are: code config->clockSource = kGPT_ClockSource_Periph; config->divider = 1U; config->enableRunInStop = true; config->enableRunInWait = true; config->enableRunInDoze = false; config->enableRunInDbg = false; config->enableFreeRun = false; config->enableMode = true; endcode param config Pointer to the user configuration structure.
◆ GPT_Init()
void GPT_Init ( GPT_Type base,
const gpt_config_t initConfig
Parameters
initConfigGPT mode setting configuration.
brief Initialize GPT to reset state and initialize running mode.
param base GPT peripheral base address. param initConfig GPT mode setting configuration.
Variable Documentation
◆ clockSource
clock source for GPT module.
◆ divider
clock divider (prescaler+1) from clock source to counter.
◆ enableFreeRun
true: FreeRun mode, false: Restart mode.
◆ enableMode
true: counter reset to 0 when enabled; false: counter retain its value when enabled.
◆ enableRunInDbg
GPT enabled in debug mode.
◆ enableRunInDoze
GPT enabled in doze mode.
◆ enableRunInStop
GPT enabled in stop mode.
◆ enableRunInWait
GPT enabled in wait mode.
