RTEMS 7.0-rc1
Data Structures | Macros | Typedefs | Enumerations | Enumerator | Variables
Enc
struct  _enc_config
 Define user configuration structure for ENC module. More...
struct  _enc_self_test_config
 Define configuration structure for self test module. More...
#define FSL_ENC_DRIVER_VERSION   (MAKE_VERSION(2, 1, 0))
typedef enum _enc_home_trigger_mode enc_home_trigger_mode_t
 Define HOME signal's trigger mode.
typedef enum _enc_index_trigger_mode enc_index_trigger_mode_t
 Define INDEX signal's trigger mode.
typedef enum _enc_decoder_work_mode enc_decoder_work_mode_t
 Define type for decoder work mode.
typedef enum _enc_position_match_mode enc_position_match_mode_t
 Define type for the condition of POSMATCH pulses.
typedef enum _enc_revolution_count_condition enc_revolution_count_condition_t
 Define type for determining how the revolution counter (REV) is incremented/decremented.
typedef enum _enc_self_test_direction enc_self_test_direction_t
 Define type for direction of self test generated signal.
typedef struct _enc_config enc_config_t
typedef struct _enc_self_test_config enc_self_test_config_t
enum  _enc_interrupt_enable {
  kENC_HOMETransitionInterruptEnable = (1U << 0U) , kENC_INDEXPulseInterruptEnable = (1U << 1U) , kENC_WatchdogTimeoutInterruptEnable = (1U << 2U) , kENC_PositionCompareInerruptEnable = (1U << 3U) ,
  kENC_SimultBothPhaseChangeInterruptEnable , kENC_PositionRollOverInterruptEnable = (1U << 5U) , kENC_PositionRollUnderInterruptEnable = (1U << 6U)
 Interrupt enable/disable mask. More...
enum  _enc_status_flags {
  kENC_HOMETransitionFlag = (1U << 0U) , kENC_INDEXPulseFlag = (1U << 1U) , kENC_WatchdogTimeoutFlag = (1U << 2U) , kENC_PositionCompareFlag = (1U << 3U) ,
  kENC_SimultBothPhaseChangeFlag = (1U << 4U) , kENC_PositionRollOverFlag = (1U << 5U) , kENC_PositionRollUnderFlag = (1U << 6U) , kENC_LastCountDirectionFlag = (1U << 7U)
 Status flag mask. More...
enum  _enc_signal_status_flags {
  kENC_RawHOMEStatusFlag = ENC_IMR_HOME_MASK , kENC_RawINDEXStatusFlag = ENC_IMR_INDEX_MASK , kENC_RawPHBStatusFlag = ENC_IMR_PHB_MASK , kENC_RawPHAEXStatusFlag = ENC_IMR_PHA_MASK ,
  kENC_FilteredHOMEStatusFlag = ENC_IMR_FHOM_MASK , kENC_FilteredINDEXStatusFlag = ENC_IMR_FIND_MASK , kENC_FilteredPHBStatusFlag = ENC_IMR_FPHB_MASK , kENC_FilteredPHAStatusFlag = ENC_IMR_FPHA_MASK
 Signal status flag mask. More...
enum  _enc_home_trigger_mode { kENC_HOMETriggerDisabled = 0U , kENC_HOMETriggerOnRisingEdge , kENC_HOMETriggerOnFallingEdge }
 Define HOME signal's trigger mode. More...
enum  _enc_index_trigger_mode { kENC_INDEXTriggerDisabled = 0U , kENC_INDEXTriggerOnRisingEdge , kENC_INDEXTriggerOnFallingEdge }
 Define INDEX signal's trigger mode. More...
enum  _enc_decoder_work_mode { kENC_DecoderWorkAsNormalMode = 0U , kENC_DecoderWorkAsSignalPhaseCountMode }
 Define type for decoder work mode. More...
enum  _enc_position_match_mode { kENC_POSMATCHOnPositionCounterEqualToComapreValue = 0U , kENC_POSMATCHOnReadingAnyPositionCounter }
 Define type for the condition of POSMATCH pulses. More...
enum  _enc_revolution_count_condition { kENC_RevolutionCountOnINDEXPulse = 0U , kENC_RevolutionCountOnRollOverModulus }
 Define type for determining how the revolution counter (REV) is incremented/decremented. More...
enum  _enc_self_test_direction { kENC_SelfTestDirectionPositive = 0U , kENC_SelfTestDirectionNegative }
 Define type for direction of self test generated signal. More...
bool _enc_config::enableReverseDirection
enc_decoder_work_mode_t _enc_config::decoderWorkMode
enc_home_trigger_mode_t _enc_config::HOMETriggerMode
enc_index_trigger_mode_t _enc_config::INDEXTriggerMode
bool _enc_config::enableTRIGGERClearPositionCounter
bool _enc_config::enableTRIGGERClearHoldPositionCounter
bool _enc_config::enableWatchdog
uint16_t _enc_config::watchdogTimeoutValue
uint16_t _enc_config::filterCount
uint16_t _enc_config::filterSamplePeriod
enc_position_match_mode_t _enc_config::positionMatchMode
uint32_t _enc_config::positionCompareValue
enc_revolution_count_condition_t _enc_config::revolutionCountCondition
bool _enc_config::enableModuloCountMode
uint32_t _enc_config::positionModulusValue
uint32_t _enc_config::positionInitialValue
enc_self_test_direction_t _enc_self_test_config::signalDirection
uint16_t _enc_self_test_config::signalCount
uint16_t _enc_self_test_config::signalPeriod
Initialization and De-initialization
void ENC_Init (ENC_Type *base, const enc_config_t *config)
 Initialization for the ENC module.
void ENC_Deinit (ENC_Type *base)
 De-initialization for the ENC module.
void ENC_GetDefaultConfig (enc_config_t *config)
 Get an available pre-defined settings for ENC's configuration.
void ENC_DoSoftwareLoadInitialPositionValue (ENC_Type *base)
 Load the initial position value to position counter.
void ENC_SetSelfTestConfig (ENC_Type *base, const enc_self_test_config_t *config)
 Enable and configure the self test function.
void ENC_EnableWatchdog (ENC_Type *base, bool enable)
 Enable watchdog for ENC module.
void ENC_SetInitialPositionValue (ENC_Type *base, uint32_t value)
 Set initial position value for ENC module.
Status
uint32_t ENC_GetStatusFlags (ENC_Type *base)
 Get the status flags.
void ENC_ClearStatusFlags (ENC_Type *base, uint32_t mask)
 Clear the status flags.
Interrupts
void ENC_EnableInterrupts (ENC_Type *base, uint32_t mask)
 Enable the interrupts.
void ENC_DisableInterrupts (ENC_Type *base, uint32_t mask)
 Disable the interrupts.
uint32_t ENC_GetEnabledInterrupts (ENC_Type *base)
 Get the enabled interrupts' flags.
Value Operation
uint32_t ENC_GetPositionValue (ENC_Type *base)
 Get the current position counter's value.
uint32_t ENC_GetHoldPositionValue (ENC_Type *base)
 Get the hold position counter's value.
Typedef Documentation
◆ enc_decoder_work_mode_t
The normal work mode uses the standard quadrature decoder with PHASEA and PHASEB. When in signal phase count mode, a positive transition of the PHASEA input generates a count signal while the PHASEB input and the reverse direction control the counter direction. If the reverse direction is not enabled, PHASEB = 0 means counting up and PHASEB = 1 means counting down. Otherwise, the direction is reversed.
◆ enc_home_trigger_mode_t
The ENC would count the trigger from HOME signal line.
◆ enc_index_trigger_mode_t
The ENC would count the trigger from INDEX signal line.
◆ enc_self_test_config_t
The self test module provides a quadrature test signal to the inputs of the quadrature decoder module. This is a factory test feature. It is also useful to customers' software development and testing.
◆ _enc_decoder_work_mode
Use standard quadrature decoder with PHASEA and PHASEB.
PHASEA input generates a count signal while PHASEB input control the direction.
◆ _enc_home_trigger_mode
HOME signal's trigger is disabled.
Use positive going edge-to-trigger initialization of position counters.
Use negative going edge-to-trigger initialization of position counters.
◆ _enc_index_trigger_mode
INDEX signal's trigger is disabled.
◆ _enc_interrupt_enable
HOME interrupt enable.
INDEX pulse interrupt enable.
Watchdog timeout interrupt enable.
Position compare interrupt enable.
Simultaneous PHASEA and PHASEB change interrupt enable.
Roll-over interrupt enable.
Roll-under interrupt enable.
◆ _enc_position_match_mode
POSMATCH pulses when a match occurs between the position counters (POS) and the compare value (COMP).
POSMATCH pulses when any position counter register is read.
◆ _enc_revolution_count_condition
Use INDEX pulse to increment/decrement revolution counter.
Use modulus counting roll-over/under to increment/decrement revolution counter.
◆ _enc_self_test_direction
Self test generates the signal in positive direction.
Self test generates the signal in negative direction.
◆ _enc_signal_status_flags
These flags indicate the counter's signal.
Raw HOME input.
Raw INDEX input.
Raw PHASEB input.
Raw PHASEA input.
The filtered version of HOME input.
The filtered version of INDEX input.
The filtered version of PHASEB input.
The filtered version of PHASEA input.
◆ _enc_status_flags
Status flag mask.
These flags indicate the counter's events.
HOME signal transition interrupt request.
kENC_INDEXPulseFlag
INDEX Pulse Interrupt Request.
Watchdog timeout interrupt request.
Position compare interrupt request.
Simultaneous PHASEA and PHASEB change interrupt request.
Roll-over interrupt request.
Roll-under interrupt request.
Last count was in the up direction, or the down direction.
◆ ENC_ClearStatusFlags()
void ENC_ClearStatusFlags ( ENC_Type base,
uint32_t  mask
Parameters
baseENC peripheral base address.
maskMask value of status flags to be cleared. For available mask, see to "_enc_status_flags".
brief Clear the status flags.
param base ENC peripheral base address. param mask Mask value of status flags to be cleared. For available mask, see to "_enc_status_flags".
◆ ENC_Deinit()
void ENC_Deinit ( ENC_Type base)
This function is to make the de-initialization for the ENC module. It could be called when ENC is no longer used with the operations like:
  • Disable the clock for ENC module.
Parameters
brief De-initialization for the ENC module.
◆ ENC_DisableInterrupts()
void ENC_DisableInterrupts ( ENC_Type base,
uint32_t  mask
Parameters
maskMask value of interrupts to be disabled. For available mask, see to "_enc_interrupt_enable".
brief Disable the interrupts.
param base ENC peripheral base address. param mask Mask value of interrupts to be disabled. For available mask, see to "_enc_interrupt_enable".
◆ ENC_DoSoftwareLoadInitialPositionValue()
void ENC_DoSoftwareLoadInitialPositionValue ( ENC_Type base)
This function is to transfer the initial position value (UINIT and LINIT) contents to position counter (UPOS and LPOS), so that to provide the consistent operation the position counter registers.
Parameters
brief Load the initial position value to position counter.
◆ ENC_EnableInterrupts()
void ENC_EnableInterrupts ( ENC_Type base,
uint32_t  mask
Parameters
maskMask value of interrupts to be enabled. For available mask, see to "_enc_interrupt_enable".
brief Enable the interrupts.
param base ENC peripheral base address. param mask Mask value of interrupts to be enabled. For available mask, see to "_enc_interrupt_enable".
◆ ENC_EnableWatchdog()
void ENC_EnableWatchdog ( ENC_Type base,
bool  enable
Parameters
enableEnables or disables the watchdog
brief Enable watchdog for ENC module.
param base ENC peripheral base address param enable Enables or disables the watchdog
◆ ENC_GetDefaultConfig()
void ENC_GetDefaultConfig ( enc_config_t config)
This function initializes the ENC configuration structure with an available settings, the default value are:
config->enableReverseDirection = false;
config->decoderWorkMode = kENC_DecoderWorkAsNormalMode;
config->HOMETriggerMode = kENC_HOMETriggerDisabled;
config->INDEXTriggerMode = kENC_INDEXTriggerDisabled;
config->enableTRIGGERClearPositionCounter = false;
config->enableTRIGGERClearHoldPositionCounter = false;
config->enableWatchdog = false;
config->watchdogTimeoutValue = 0U;
config->filterCount = 0U;
config->filterSamplePeriod = 0U;
config->positionCompareValue = 0xFFFFFFFFU;
config->revolutionCountCondition = kENC_RevolutionCountOnINDEXPulse;
config->enableModuloCountMode = false;
config->positionModulusValue = 0U;
config->positionInitialValue = 0U;
config->prescalerValue = kENC_ClockDiv1;
config->enablePeriodMeasurementFunction = true;
@ kENC_INDEXTriggerDisabled
Definition: fsl_enc.h:95
@ kENC_HOMETriggerDisabled
Definition: fsl_enc.h:83
@ kENC_DecoderWorkAsNormalMode
Definition: fsl_enc.h:110
@ kENC_POSMATCHOnPositionCounterEqualToComapreValue
Definition: fsl_enc.h:120
@ kENC_RevolutionCountOnINDEXPulse
Definition: fsl_enc.h:130
Parameters
configPointer to a variable of configuration structure. See to "enc_config_t".
brief Get an available pre-defined settings for ENC's configuration.
This function initializes the ENC configuration structure with an available settings, the default value are: code config->enableReverseDirection = false; config->decoderWorkMode = kENC_DecoderWorkAsNormalMode; config->HOMETriggerMode = kENC_HOMETriggerDisabled; config->INDEXTriggerMode = kENC_INDEXTriggerDisabled; config->enableTRIGGERClearPositionCounter = false; config->enableTRIGGERClearHoldPositionCounter = false; config->enableWatchdog = false; config->watchdogTimeoutValue = 0U; config->filterCount = 0U; config->filterSamplePeriod = 0U; config->positionMatchMode = kENC_POSMATCHOnPositionCounterEqualToComapreValue; config->positionCompareValue = 0xFFFFFFFFU; config->revolutionCountCondition = kENC_RevolutionCountOnINDEXPulse; config->enableModuloCountMode = false; config->positionModulusValue = 0U; config->positionInitialValue = 0U; config->prescalerValue = kENC_ClockDiv1; config->enablePeriodMeasurementFunction = true; endcode param config Pointer to a variable of configuration structure. See to "enc_config_t".
◆ ENC_GetEnabledInterrupts()
uint32_t ENC_GetEnabledInterrupts ( ENC_Type base)
Parameters
Returns
Mask value of enabled interrupts.
brief Get the enabled interrupts' flags.
return Mask value of enabled interrupts.
◆ ENC_GetHoldPositionValue()
uint32_t ENC_GetHoldPositionValue ( ENC_Type base)
When any of the counter registers is read, the contents of each counter register is written to the corresponding hold register. Taking a snapshot of the counters' values provides a consistent view of a system position and a velocity to be attained.
Parameters
Returns
Hold position counter's value.
brief Get the hold position counter's value.
return Hold position counter's value.
◆ ENC_GetPositionValue()
uint32_t ENC_GetPositionValue ( ENC_Type base)
Parameters
Returns
Current position counter's value.
brief Get the current position counter's value.
return Current position counter's value.
◆ ENC_GetStatusFlags()
uint32_t ENC_GetStatusFlags ( ENC_Type base)
Parameters
Returns
Mask value of status flags. For available mask, see to "_enc_status_flags".
brief Get the status flags.
return Mask value of status flags. For available mask, see to "_enc_status_flags".
◆ ENC_Init()
void ENC_Init ( ENC_Type base,
const enc_config_t config
This function is to make the initialization for the ENC module. It should be called firstly before any operation to the ENC with the operations like:
  • Enable the clock for ENC module.
  • Configure the ENC's working attributes.
Parameters
configPointer to configuration structure. See to "enc_config_t".
brief Initialization for the ENC module.
param base ENC peripheral base address. param config Pointer to configuration structure. See to "enc_config_t".
◆ ENC_SetInitialPositionValue()
void ENC_SetInitialPositionValue ( ENC_Type base,
uint32_t  value
Parameters
valuePositive initial value
brief Set initial position value for ENC module.
param base ENC peripheral base address param value Positive initial value
◆ ENC_SetSelfTestConfig()
void ENC_SetSelfTestConfig ( ENC_Type base,
const enc_self_test_config_t config
This function is to enable and configuration the self test function. It controls and sets the frequency of a quadrature signal generator. It provides a quadrature test signal to the inputs of the quadrature decoder module. It is a factory test feature; however, it may be useful to customers' software development and testing.
Parameters
configPointer to configuration structure. See to "enc_self_test_config_t". Pass "NULL" to disable.
brief Enable and configure the self test function.
param base ENC peripheral base address. param config Pointer to configuration structure. See to "enc_self_test_config_t". Pass "NULL" to disable.
Variable Documentation
◆ decoderWorkMode
Enable signal phase count mode.
◆ enableModuloCountMode
Enable Modulo Counting.
◆ enableReverseDirection
Enable reverse direction counting.
◆ enableTRIGGERClearHoldPositionCounter
Enable update of hold registers on rising edge of TRIGGER, or not.
◆ enableTRIGGERClearPositionCounter
Clear POSD, REV, UPOS and LPOS on rising edge of TRIGGER, or not.
◆ enableWatchdog
Enable the watchdog to detect if the target is moving or not.
◆ filterCount
Input Filter Sample Count. This value should be chosen to reduce the probability of noisy samples causing an incorrect transition to be recognized. The value represent the number of consecutive samples that must agree prior to the input filter accepting an input transition. A value of 0x0 represents 3 samples. A value of 0x7 represents 10 samples. The Available range is 0 - 7.
◆ filterSamplePeriod
Input Filter Sample Period. This value should be set such that the sampling period is larger than the period of the expected noise. This value represents the sampling period (in IPBus clock cycles) of the decoder input signals. The available range is 0 - 255.
◆ HOMETriggerMode
Enable HOME to initialize position counters.
◆ INDEXTriggerMode
Enable INDEX to initialize position counters.
◆ positionCompareValue
Position compare value. The available value is a 32-bit number.
◆ positionInitialValue
Position initial value. The available value is a 32-bit number.
◆ positionMatchMode
The condition of POSMATCH pulses.
◆ positionModulusValue
Position modulus value. This value would be available only when "enableModuloCountMode" = true. The available value is a 32-bit number.
◆ revolutionCountCondition
Revolution Counter Modulus Enable.
◆ signalCount
Hold the number of quadrature advances to generate. The available range is 0 - 255.
◆ signalDirection
Direction of self test generated signal.
◆ signalPeriod
Hold the period of quadrature phase in IPBus clock cycles. The available range is 0 - 31.
◆ watchdogTimeoutValue
Watchdog timeout count value. It stores the timeout count for the quadrature decoder module watchdog timer. This field is only available when "enableWatchdog" = true. The available value is a 16-bit unsigned number.
