RTEMS 7.0-rc1
Data Structures | Enumerator | Variables
Elcdif
struct  _elcdif_pixel_format_reg
 The register value when using different pixel format. More...
struct  _elcdif_rgb_mode_config
 eLCDIF configure structure for RGB mode (DOTCLK mode). More...
struct  _elcdif_as_buffer_config
 eLCDIF alpha surface buffer configuration. More...
struct  _elcdif_as_blend_config
 eLCDIF alpha surface blending configuration. More...
uint32_t _elcdif_pixel_format_reg::regCtrl
uint32_t _elcdif_pixel_format_reg::regCtrl1
uint16_t _elcdif_rgb_mode_config::panelWidth
uint16_t _elcdif_rgb_mode_config::panelHeight
uint8_t _elcdif_rgb_mode_config::hsw
uint8_t _elcdif_rgb_mode_config::hfp
uint8_t _elcdif_rgb_mode_config::hbp
uint8_t _elcdif_rgb_mode_config::vsw
uint8_t _elcdif_rgb_mode_config::vfp
uint8_t _elcdif_rgb_mode_config::vbp
uint32_t _elcdif_rgb_mode_config::polarityFlags
uint32_t _elcdif_rgb_mode_config::bufferAddr
elcdif_pixel_format_t _elcdif_rgb_mode_config::pixelFormat
elcdif_lcd_data_bus_t _elcdif_rgb_mode_config::dataBus
uint32_t _elcdif_as_buffer_config::bufferAddr
elcdif_as_pixel_format_t _elcdif_as_buffer_config::pixelFormat
uint8_t _elcdif_as_blend_config::alpha
bool _elcdif_as_blend_config::invertAlpha
elcdif_alpha_mode_t _elcdif_as_blend_config::alphaMode
elcdif_rop_mode_t _elcdif_as_blend_config::ropMode
Driver version
enum  _elcdif_polarity_flags {
  kELCDIF_VsyncActiveLow = 0U , kELCDIF_HsyncActiveLow = 0U , kELCDIF_DataEnableActiveLow = 0U , kELCDIF_DriveDataOnFallingClkEdge = 0U ,
  kELCDIF_VsyncActiveHigh = LCDIF_VDCTRL0_VSYNC_POL_MASK , kELCDIF_HsyncActiveHigh = LCDIF_VDCTRL0_HSYNC_POL_MASK , kELCDIF_DataEnableActiveHigh = LCDIF_VDCTRL0_ENABLE_POL_MASK , kELCDIF_DriveDataOnRisingClkEdge = LCDIF_VDCTRL0_DOTCLK_POL_MASK
 eLCDIF signal polarity flags More...
enum  _elcdif_interrupt_enable {
  kELCDIF_BusMasterErrorInterruptEnable = LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK , kELCDIF_TxFifoOverflowInterruptEnable = LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK , kELCDIF_TxFifoUnderflowInterruptEnable = LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK , kELCDIF_CurFrameDoneInterruptEnable ,
  kELCDIF_VsyncEdgeInterruptEnable
 The eLCDIF interrupts to enable. More...
enum  _elcdif_interrupt_flags {
  kELCDIF_BusMasterError = LCDIF_CTRL1_BM_ERROR_IRQ_MASK , kELCDIF_TxFifoOverflow = LCDIF_CTRL1_OVERFLOW_IRQ_MASK , kELCDIF_TxFifoUnderflow = LCDIF_CTRL1_UNDERFLOW_IRQ_MASK , kELCDIF_CurFrameDone ,
  kELCDIF_VsyncEdge = LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK
 The eLCDIF interrupt status flags. More...
enum  _elcdif_status_flags { kELCDIF_LFifoFull = LCDIF_STAT_LFIFO_FULL_MASK , kELCDIF_LFifoEmpty = LCDIF_STAT_LFIFO_EMPTY_MASK , kELCDIF_TxFifoFull = LCDIF_STAT_TXFIFO_FULL_MASK , kELCDIF_TxFifoEmpty = LCDIF_STAT_TXFIFO_EMPTY_MASK }
 eLCDIF status flags More...
enum  _elcdif_pixel_format {
  kELCDIF_PixelFormatRAW8 = 0 , kELCDIF_PixelFormatRGB565 = 1 , kELCDIF_PixelFormatRGB666 = 2 , kELCDIF_PixelFormatXRGB8888 = 3 ,
  kELCDIF_PixelFormatRGB888 = 4
 The pixel format. More...
enum  _elcdif_lcd_data_bus { kELCDIF_DataBus8Bit = LCDIF_CTRL_LCD_DATABUS_WIDTH(1) , kELCDIF_DataBus16Bit = LCDIF_CTRL_LCD_DATABUS_WIDTH(0) , kELCDIF_DataBus18Bit = LCDIF_CTRL_LCD_DATABUS_WIDTH(2) , kELCDIF_DataBus24Bit = LCDIF_CTRL_LCD_DATABUS_WIDTH(3) }
 The LCD data bus type.
More...
enum  _elcdif_as_pixel_format {
  kELCDIF_AsPixelFormatARGB8888 = 0x0 , kELCDIF_AsPixelFormatRGB888 = 0x4 , kELCDIF_AsPixelFormatARGB1555 = 0x8 , kELCDIF_AsPixelFormatARGB4444 = 0x9 ,
  kELCDIF_AsPixelFormatRGB555 = 0xC , kELCDIF_AsPixelFormatRGB444 = 0xD , kELCDIF_AsPixelFormatRGB565 = 0xE
 eLCDIF alpha surface pixel format. More...
enum  _elcdif_alpha_mode { kELCDIF_AlphaEmbedded , kELCDIF_AlphaOverride , kELCDIF_AlphaMultiply , kELCDIF_AlphaRop }
 eLCDIF alpha mode during blending. More...
enum  _elcdif_rop_mode {
  kELCDIF_RopMaskAs = 0x0 , kELCDIF_RopMaskNotAs = 0x1 , kELCDIF_RopMaskAsNot = 0x2 , kELCDIF_RopMergeAs = 0x3 ,
  kELCDIF_RopMergeNotAs = 0x4 , kELCDIF_RopMergeAsNot = 0x5 , kELCDIF_RopNotCopyAs = 0x6 , kELCDIF_RopNot = 0x7 ,
  kELCDIF_RopNotMaskAs = 0x8 , kELCDIF_RopNotMergeAs = 0x9 , kELCDIF_RopXorAs = 0xA , kELCDIF_RopNotXorAs = 0xB
 eLCDIF ROP mode during blending. More...
enum  _elcdif_lut { kELCDIF_Lut0 = 0 , kELCDIF_Lut1 }
 eLCDIF LUT More...
typedef enum _elcdif_pixel_format elcdif_pixel_format_t
 The pixel format.
typedef enum _elcdif_lcd_data_bus elcdif_lcd_data_bus_t
typedef struct _elcdif_pixel_format_reg elcdif_pixel_format_reg_t
typedef struct _elcdif_rgb_mode_config elcdif_rgb_mode_config_t
typedef enum _elcdif_as_pixel_format elcdif_as_pixel_format_t
typedef struct _elcdif_as_buffer_config elcdif_as_buffer_config_t
typedef enum _elcdif_alpha_mode elcdif_alpha_mode_t
typedef enum _elcdif_rop_mode elcdif_rop_mode_t
typedef struct _elcdif_as_blend_config elcdif_as_blend_config_t
typedef enum _elcdif_lut elcdif_lut_t
 eLCDIF LUT
#define FSL_ELCDIF_DRIVER_VERSION   (MAKE_VERSION(2, 0, 5))
 eLCDIF driver version
#define ELCDIF_CTRL1_IRQ_MASK
#define ELCDIF_CTRL1_IRQ_EN_MASK
#define ELCDIF_AS_CTRL_IRQ_MASK   0U
#define ELCDIF_AS_CTRL_IRQ_EN_MASK   0U
#define FSL_FEATURE_LCDIF_HAS_PXP_HANDSHAKE   0
#define ELCDIF_ADDR_CPU_2_IP(addr)   (addr)
#define ELCDIF_LUT_ENTRY_NUM   256U
eLCDIF initialization and de-initialization
void ELCDIF_RgbModeInit (LCDIF_Type *base, const elcdif_rgb_mode_config_t *config)
 Initializes the eLCDIF to work in RGB mode (DOTCLK mode).
void ELCDIF_RgbModeGetDefaultConfig (elcdif_rgb_mode_config_t *config)
 Gets the eLCDIF default configuration structure for RGB (DOTCLK) mode.
void ELCDIF_Deinit (LCDIF_Type *base)
 Deinitializes the eLCDIF peripheral.
Module operation
void ELCDIF_RgbModeSetPixelFormat (LCDIF_Type *base, elcdif_pixel_format_t pixelFormat)
 Set the pixel format in RGB (DOTCLK) mode.
void ELCDIF_RgbModeStop (LCDIF_Type *base)
 Stop display in RGB (DOTCLK) mode and wait until finished.
void ELCDIF_Reset (LCDIF_Type *base)
 Reset the eLCDIF peripheral.
Alpha surface
void ELCDIF_SetAlphaSurfaceBufferConfig (LCDIF_Type *base, const elcdif_as_buffer_config_t *config)
 Set the configuration for alpha surface buffer.
void ELCDIF_SetAlphaSurfaceBlendConfig (LCDIF_Type *base, const elcdif_as_blend_config_t *config)
 Set the alpha surface blending configuration.
◆ ELCDIF_CTRL1_IRQ_EN_MASK
Value:
(LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK | LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK | \
LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK)
◆ ELCDIF_CTRL1_IRQ_MASK
Value:
(LCDIF_CTRL1_BM_ERROR_IRQ_MASK | LCDIF_CTRL1_OVERFLOW_IRQ_MASK | LCDIF_CTRL1_UNDERFLOW_IRQ_MASK | \
LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK | LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK)
Typedef Documentation
◆ elcdif_lut_t
eLCDIF LUT
The Lookup Table (LUT) is used to expand the 8 bits pixel to 24 bits pixel before output to external displayer.
There are two 256x24 bits LUT memory in LCDIF, the LSB of frame buffer address determins which memory to use.
◆ elcdif_pixel_format_reg_t
These register bits control the pixel format:
  • CTRL[DATA_FORMAT_24_BIT]
  • CTRL[DATA_FORMAT_18_BIT]
  • CTRL[DATA_FORMAT_16_BIT]
  • CTRL[WORD_LENGTH]
  • CTRL1[BYTE_PACKING_FORMAT]
◆ elcdif_pixel_format_t
The pixel format.
This enumerator should be defined together with the array s_pixelFormatReg. To support new pixel format, enhance this enumerator and s_pixelFormatReg.
◆ elcdif_rop_mode_t
Explanation:
  • AS: Alpha surface
  • PS: Process surface
  • nAS: Alpha surface NOT value
  • nPS: Process surface NOT value
◆ _elcdif_alpha_mode
The alpha surface pixel alpha value will be used for blend.
The user defined alpha value will be used for blend directly.
The alpha surface pixel alpha value scaled the user defined alpha value will be used for blend, for example, pixel alpha set set to 200, user defined alpha set to 100, then the reault alpha is 200 * 100 / 255.
kELCDIF_AlphaRop
Raster operation.
◆ _elcdif_as_pixel_format
32-bit pixels with alpha.
32-bit pixels without alpha (unpacked 24-bit format)
16-bit pixels with alpha.
16-bit pixels without alpha.
◆ _elcdif_interrupt_enable
Bus master error interrupt.
TXFIFO overflow interrupt.
TXFIFO underflow interrupt.
Interrupt when hardware enters vertical blanking state.
Interrupt when hardware encounters VSYNC edge.
◆ _elcdif_interrupt_flags
kELCDIF_VsyncEdge
◆ _elcdif_lcd_data_bus
kELCDIF_DataBus8Bit
8-bit data bus.
16-bit data bus, support RGB565.
18-bit data bus, support RGB666.
24-bit data bus, support RGB888.
◆ _elcdif_lut
eLCDIF LUT
kELCDIF_Lut0
LUT 0.
kELCDIF_Lut1
LUT 1.
◆ _elcdif_pixel_format
The pixel format.
RAW 8 bit, four data use 32 bits.
RGB565, two pixel use 32 bits.
RGB666 unpacked, one pixel uses 32 bits, high byte unused, upper 2 bits of other bytes unused.
XRGB8888 unpacked, one pixel uses 32 bits, high byte unused.
RGB888 packed, one pixel uses 24 bits.
◆ _elcdif_polarity_flags
VSYNC active low.
HSYNC active low.
Data enable line active low.
Drive data on falling clock edge, capture data on rising clock edge.
VSYNC active high.
HSYNC active high.
Data enable line active high.
◆ _elcdif_rop_mode
Explanation:
  • AS: Alpha surface
kELCDIF_RopMaskAs
AS AND PS.
nAS AND PS.
AS AND nPS.
kELCDIF_RopMergeAs
AS OR PS.
nAS OR PS.
AS OR nPS.
nAS.
kELCDIF_RopNot
nPS.
AS NAND PS.
AS NOR PS.
kELCDIF_RopXorAs
AS XOR PS.
kELCDIF_RopNotXorAs
AS XNOR PS.
◆ _elcdif_status_flags
eLCDIF status flags
kELCDIF_LFifoFull
LFIFO full.
kELCDIF_LFifoEmpty
LFIFO empty.
kELCDIF_TxFifoFull
TXFIFO full.
kELCDIF_TxFifoEmpty
TXFIFO empty.
◆ ELCDIF_Deinit()
void ELCDIF_Deinit ( LCDIF_Type base)
Parameters
baseeLCDIF peripheral base address.
brief Deinitializes the eLCDIF peripheral.
param base eLCDIF peripheral base address.
◆ ELCDIF_Reset()
void ELCDIF_Reset ( LCDIF_Type base)
Parameters
brief Reset the eLCDIF peripheral.
◆ ELCDIF_RgbModeGetDefaultConfig()
void ELCDIF_RgbModeGetDefaultConfig ( elcdif_rgb_mode_config_t config)
This function sets the configuration structure to default values. The default configuration is set to the following values.
config->panelWidth = 480U;
config->panelHeight = 272U;
config->hsw = 41;
config->hfp = 4;
config->hbp = 8;
config->vsw = 10;
config->vfp = 4;
config->vbp = 2;
config->polarityFlags = kELCDIF_VsyncActiveLow |
config->bufferAddr = 0U;
config->pixelFormat = kELCDIF_PixelFormatRGB888;
config->dataBus = kELCDIF_DataBus24Bit;
@ kELCDIF_PixelFormatRGB888
Definition: fsl_elcdif.h:161
@ kELCDIF_DataBus24Bit
Definition: fsl_elcdif.h:170
@ kELCDIF_HsyncActiveLow
Definition: fsl_elcdif.h:83
@ kELCDIF_DriveDataOnFallingClkEdge
Definition: fsl_elcdif.h:85
@ kELCDIF_VsyncActiveLow
Definition: fsl_elcdif.h:82
@ kELCDIF_DataEnableActiveLow
Definition: fsl_elcdif.h:84
Parameters
configPointer to the eLCDIF configuration structure.
brief Gets the eLCDIF default configuration structure for RGB (DOTCLK) mode.
This function sets the configuration structure to default values. The default configuration is set to the following values. code config->panelWidth = 480U; config->panelHeight = 272U; config->hsw = 41; config->hfp = 4; config->hbp = 8; config->vsw = 10; config->vfp = 4; config->vbp = 2; config->polarityFlags = kELCDIF_VsyncActiveLow | kELCDIF_HsyncActiveLow | kELCDIF_DataEnableActiveLow | kELCDIF_DriveDataOnFallingClkEdge; config->bufferAddr = 0U; config->pixelFormat = kELCDIF_PixelFormatRGB888; config->dataBus = kELCDIF_DataBus24Bit; code
param config Pointer to the eLCDIF configuration structure.
◆ ELCDIF_RgbModeInit()
void ELCDIF_RgbModeInit ( LCDIF_Type base,
const elcdif_rgb_mode_config_t config
This function ungates the eLCDIF clock and configures the eLCDIF peripheral according to the configuration structure.
Parameters
configPointer to the configuration structure.
brief Initializes the eLCDIF to work in RGB mode (DOTCLK mode).
param base eLCDIF peripheral base address. param config Pointer to the configuration structure.
◆ ELCDIF_RgbModeSetPixelFormat()
void ELCDIF_RgbModeSetPixelFormat ( LCDIF_Type base,
Parameters
pixelFormatThe pixel format.
brief Set the pixel format in RGB (DOTCLK) mode.
param base eLCDIF peripheral base address. param pixelFormat The pixel format.
◆ ELCDIF_RgbModeStop()
void ELCDIF_RgbModeStop ( LCDIF_Type base)
Parameters
brief Stop display in RGB (DOTCLK) mode and wait until finished.
◆ ELCDIF_SetAlphaSurfaceBlendConfig()
void ELCDIF_SetAlphaSurfaceBlendConfig ( LCDIF_Type base,
const elcdif_as_blend_config_t config
Parameters
brief Set the alpha surface blending configuration.
◆ ELCDIF_SetAlphaSurfaceBufferConfig()
void ELCDIF_SetAlphaSurfaceBufferConfig ( LCDIF_Type base,
const elcdif_as_buffer_config_t config
Parameters
brief Set the configuration for alpha surface buffer.
Variable Documentation
◆ alpha
User defined alpha value, only used when alphaMode is kELCDIF_AlphaOverride or kELCDIF_AlphaRop.
◆ alphaMode
Alpha mode.
◆ bufferAddr [1/2]
Frame buffer address.
◆ bufferAddr [2/2]
Buffer address.
◆ dataBus
LCD data bus.
◆ hbp
Horizontal back porch.
◆ hfp
Horizontal front porch.
◆ hsw
HSYNC pulse width.
◆ invertAlpha
Set true to invert the alpha.
◆ panelHeight
Display panel height, how many lines per panel.
◆ panelWidth
Display panel width, pixels per line.
◆ pixelFormat [1/2]
Pixel format.
◆ pixelFormat [2/2]
Pixel format.
◆ polarityFlags
OR'ed value of _elcdif_polarity_flags, used to contol the signal polarity.
◆ regCtrl
Value of register CTRL.
◆ regCtrl1
Value of register CTRL1.
◆ ropMode
ROP mode, only valid when alphaMode is kELCDIF_AlphaRop.
◆ vbp
Vertical back porch.
◆ vfp
Vrtical front porch.
◆ vsw
VSYNC pulse width.
