RTEMS 7.0-rc1
Data Structures | Enumerator | Variables
Edma
struct  _edma_config
 eDMA global configuration structure. More...
struct  _edma_transfer_config
 eDMA transfer configuration More...
struct  _edma_channel_Preemption_config
 eDMA channel priority configuration More...
struct  _edma_minor_offset_config
 eDMA minor offset configuration More...
struct  _edma_tcd
 eDMA TCD. More...
struct  _edma_handle
 eDMA transfer handle structure More...
bool _edma_config::enableContinuousLinkMode
bool _edma_config::enableHaltOnError
bool _edma_config::enableRoundRobinArbitration
bool _edma_config::enableDebugMode
uint32_t _edma_transfer_config::srcAddr
uint32_t _edma_transfer_config::destAddr
edma_transfer_size_t _edma_transfer_config::srcTransferSize
edma_transfer_size_t _edma_transfer_config::destTransferSize
int16_t _edma_transfer_config::srcOffset
int16_t _edma_transfer_config::destOffset
uint32_t _edma_transfer_config::minorLoopBytes
uint32_t _edma_transfer_config::majorLoopCounts
bool _edma_channel_Preemption_config::enableChannelPreemption
bool _edma_channel_Preemption_config::enablePreemptAbility
uint8_t _edma_channel_Preemption_config::channelPriority
bool _edma_minor_offset_config::enableSrcMinorOffset
bool _edma_minor_offset_config::enableDestMinorOffset
uint32_t _edma_minor_offset_config::minorOffset
__IO uint32_t _edma_tcd::SADDR
__IO uint16_t _edma_tcd::SOFF
__IO uint16_t _edma_tcd::ATTR
__IO uint32_t _edma_tcd::NBYTES
__IO uint32_t _edma_tcd::SLAST
__IO uint32_t _edma_tcd::DADDR
__IO uint16_t _edma_tcd::DOFF
__IO uint16_t _edma_tcd::CITER
__IO uint32_t _edma_tcd::DLAST_SGA
__IO uint16_t _edma_tcd::CSR
__IO uint16_t _edma_tcd::BITER
edma_callback _edma_handle::callback
void * _edma_handle::userData
DMA_Type_edma_handle::base
edma_tcd_t_edma_handle::tcdPool
uint8_t _edma_handle::channel
volatile int8_t _edma_handle::header
volatile int8_t _edma_handle::tail
volatile int8_t _edma_handle::tcdUsed
volatile int8_t _edma_handle::tcdSize
uint8_t _edma_handle::flags
Driver version
enum  _edma_transfer_size {
  kEDMA_TransferSize1Bytes = 0x0U , kEDMA_TransferSize2Bytes = 0x1U , kEDMA_TransferSize4Bytes = 0x2U , kEDMA_TransferSize8Bytes = 0x3U ,
  kEDMA_TransferSize16Bytes = 0x4U , kEDMA_TransferSize32Bytes = 0x5U
enum  _edma_modulo {
  kEDMA_ModuloDisable = 0x0U , kEDMA_Modulo2bytes , kEDMA_Modulo4bytes , kEDMA_Modulo8bytes ,
  kEDMA_Modulo16bytes , kEDMA_Modulo32bytes , kEDMA_Modulo64bytes , kEDMA_Modulo128bytes ,
  kEDMA_Modulo256bytes , kEDMA_Modulo512bytes , kEDMA_Modulo1Kbytes , kEDMA_Modulo2Kbytes ,
  kEDMA_Modulo4Kbytes , kEDMA_Modulo8Kbytes , kEDMA_Modulo16Kbytes , kEDMA_Modulo32Kbytes ,
  kEDMA_Modulo64Kbytes , kEDMA_Modulo128Kbytes , kEDMA_Modulo256Kbytes , kEDMA_Modulo512Kbytes ,
  kEDMA_Modulo1Mbytes , kEDMA_Modulo2Mbytes , kEDMA_Modulo4Mbytes , kEDMA_Modulo8Mbytes ,
  kEDMA_Modulo16Mbytes , kEDMA_Modulo32Mbytes , kEDMA_Modulo64Mbytes , kEDMA_Modulo128Mbytes ,
  kEDMA_Modulo256Mbytes , kEDMA_Modulo512Mbytes , kEDMA_Modulo1Gbytes , kEDMA_Modulo2Gbytes
 eDMA modulo configuration More...
enum  _edma_bandwidth { kEDMA_BandwidthStallNone = 0x0U , kEDMA_BandwidthStall4Cycle = 0x2U , kEDMA_BandwidthStall8Cycle = 0x3U }
 Bandwidth control. More...
enum  _edma_channel_link_type { kEDMA_LinkNone = 0x0U , kEDMA_MinorLink , kEDMA_MajorLink }
 Channel link type. More...
enum  { kEDMA_DoneFlag = 0x1U , kEDMA_ErrorFlag = 0x2U , kEDMA_InterruptFlag = 0x4U }
 _edma_channel_status_flags eDMA channel status flags. More...
enum  {
  kEDMA_DestinationBusErrorFlag = DMA_ES_DBE_MASK , kEDMA_SourceBusErrorFlag = DMA_ES_SBE_MASK , kEDMA_ScatterGatherErrorFlag = DMA_ES_SGE_MASK , kEDMA_NbytesErrorFlag = DMA_ES_NCE_MASK ,
  kEDMA_DestinationOffsetErrorFlag = DMA_ES_DOE_MASK , kEDMA_DestinationAddressErrorFlag = DMA_ES_DAE_MASK , kEDMA_SourceOffsetErrorFlag = DMA_ES_SOE_MASK , kEDMA_SourceAddressErrorFlag = DMA_ES_SAE_MASK ,
  kEDMA_ErrorChannelFlag = DMA_ES_ERRCHN_MASK , kEDMA_ChannelPriorityErrorFlag = DMA_ES_CPE_MASK , kEDMA_TransferCanceledFlag = DMA_ES_ECX_MASK , kEDMA_ValidFlag = (int)DMA_ES_VLD_MASK
 _edma_error_status_flags eDMA channel error status flags. More...
enum  _edma_interrupt_enable { kEDMA_ErrorInterruptEnable = 0x1U , kEDMA_MajorInterruptEnable = DMA_CSR_INTMAJOR_MASK , kEDMA_HalfInterruptEnable = DMA_CSR_INTHALF_MASK }
 eDMA interrupt source More...
enum  _edma_transfer_type { kEDMA_MemoryToMemory = 0x0U , kEDMA_PeripheralToMemory , kEDMA_MemoryToPeripheral , kEDMA_PeripheralToPeripheral }
 eDMA transfer type More...
enum  { kStatus_EDMA_QueueFull = MAKE_STATUS(kStatusGroup_EDMA, 0) , kStatus_EDMA_Busy = MAKE_STATUS(kStatusGroup_EDMA, 1) }
 _edma_transfer_status eDMA transfer status More...
typedef enum _edma_transfer_size edma_transfer_size_t
typedef enum _edma_modulo edma_modulo_t
typedef enum _edma_bandwidth edma_bandwidth_t
 Bandwidth control.
typedef enum _edma_channel_link_type edma_channel_link_type_t
 Channel link type.
typedef enum _edma_interrupt_enable edma_interrupt_enable_t
typedef enum _edma_transfer_type edma_transfer_type_t
 eDMA transfer type
typedef struct _edma_config edma_config_t
typedef struct _edma_transfer_config edma_transfer_config_t
typedef struct _edma_channel_Preemption_config edma_channel_Preemption_config_t
typedef struct _edma_minor_offset_config edma_minor_offset_config_t
typedef struct _edma_tcd edma_tcd_t
 eDMA TCD.
typedef void(* edma_callback) (struct _edma_handle *handle, void *userData, bool transferDone, uint32_t tcds)
 Define callback function for eDMA.
typedef struct _edma_handle edma_handle_t
#define FSL_EDMA_DRIVER_VERSION   (MAKE_VERSION(2, 4, 3))
 eDMA driver version
#define DMA_DCHPRI_INDEX(channel)   (((channel) & ~0x03U) | (3U - ((channel)&0x03U)))
 Compute the offset unit from DCHPRI3.
eDMA initialization and de-initialization
void EDMA_Init (DMA_Type *base, const edma_config_t *config)
 Initializes the eDMA peripheral.
void EDMA_Deinit (DMA_Type *base)
 Deinitializes the eDMA peripheral.
void EDMA_InstallTCD (DMA_Type *base, uint32_t channel, edma_tcd_t *tcd)
 Push content of TCD structure into hardware TCD register.
void EDMA_GetDefaultConfig (edma_config_t *config)
 Gets the eDMA default configuration structure.
eDMA Channel Operation
void EDMA_ResetChannel (DMA_Type *base, uint32_t channel)
 Sets all TCD registers to default values.
void EDMA_SetTransferConfig (DMA_Type *base, uint32_t channel, const edma_transfer_config_t *config, edma_tcd_t *nextTcd)
 Configures the eDMA transfer attribute.
void EDMA_SetMinorOffsetConfig (DMA_Type *base, uint32_t channel, const edma_minor_offset_config_t *config)
 Configures the eDMA minor offset feature.
void EDMA_SetChannelPreemptionConfig (DMA_Type *base, uint32_t channel, const edma_channel_Preemption_config_t *config)
 Configures the eDMA channel preemption feature.
void EDMA_SetChannelLink (DMA_Type *base, uint32_t channel, edma_channel_link_type_t linkType, uint32_t linkedChannel)
 Sets the channel link for the eDMA transfer.
void EDMA_SetBandWidth (DMA_Type *base, uint32_t channel, edma_bandwidth_t bandWidth)
 Sets the bandwidth for the eDMA transfer.
void EDMA_SetModulo (DMA_Type *base, uint32_t channel, edma_modulo_t srcModulo, edma_modulo_t destModulo)
 Sets the source modulo and the destination modulo for the eDMA transfer.
void EDMA_EnableChannelInterrupts (DMA_Type *base, uint32_t channel, uint32_t mask)
 Enables the interrupt source for the eDMA transfer.
void EDMA_DisableChannelInterrupts (DMA_Type *base, uint32_t channel, uint32_t mask)
 Disables the interrupt source for the eDMA transfer.
void EDMA_SetMajorOffsetConfig (DMA_Type *base, uint32_t channel, int32_t sourceOffset, int32_t destOffset)
 Configures the eDMA channel TCD major offset feature.
eDMA TCD Operation
void EDMA_TcdReset (edma_tcd_t *tcd)
 Sets all fields to default values for the TCD structure.
void EDMA_TcdSetTransferConfig (edma_tcd_t *tcd, const edma_transfer_config_t *config, edma_tcd_t *nextTcd)
 Configures the eDMA TCD transfer attribute.
void EDMA_TcdSetMinorOffsetConfig (edma_tcd_t *tcd, const edma_minor_offset_config_t *config)
 Configures the eDMA TCD minor offset feature.
void EDMA_TcdSetChannelLink (edma_tcd_t *tcd, edma_channel_link_type_t linkType, uint32_t linkedChannel)
 Sets the channel link for the eDMA TCD.
void EDMA_TcdSetModulo (edma_tcd_t *tcd, edma_modulo_t srcModulo, edma_modulo_t destModulo)
 Sets the source modulo and the destination modulo for the eDMA TCD.
void EDMA_TcdEnableInterrupts (edma_tcd_t *tcd, uint32_t mask)
 Enables the interrupt source for the eDMA TCD.
void EDMA_TcdDisableInterrupts (edma_tcd_t *tcd, uint32_t mask)
 Disables the interrupt source for the eDMA TCD.
void EDMA_TcdSetMajorOffsetConfig (edma_tcd_t *tcd, int32_t sourceOffset, int32_t destOffset)
 Configures the eDMA TCD major offset feature.
eDMA Channel Status Operation
uint32_t EDMA_GetRemainingMajorLoopCount (DMA_Type *base, uint32_t channel)
 Gets the remaining major loop count from the eDMA current channel TCD.
uint32_t EDMA_GetChannelStatusFlags (DMA_Type *base, uint32_t channel)
 Gets the eDMA channel status flags.
void EDMA_ClearChannelStatusFlags (DMA_Type *base, uint32_t channel, uint32_t mask)
 Clears the eDMA channel status flags.
eDMA Transactional Operation
void EDMA_CreateHandle (edma_handle_t *handle, DMA_Type *base, uint32_t channel)
 Creates the eDMA handle.
void EDMA_InstallTCDMemory (edma_handle_t *handle, edma_tcd_t *tcdPool, uint32_t tcdSize)
 Installs the TCDs memory pool into the eDMA handle.
void EDMA_SetCallback (edma_handle_t *handle, edma_callback callback, void *userData)
 Installs a callback function for the eDMA transfer.
void EDMA_PrepareTransferConfig (edma_transfer_config_t *config, void *srcAddr, uint32_t srcWidth, int16_t srcOffset, void *destAddr, uint32_t destWidth, int16_t destOffset, uint32_t bytesEachRequest, uint32_t transferBytes)
 Prepares the eDMA transfer structure configurations.
void EDMA_PrepareTransfer (edma_transfer_config_t *config, void *srcAddr, uint32_t srcWidth, void *destAddr, uint32_t destWidth, uint32_t bytesEachRequest, uint32_t transferBytes, edma_transfer_type_t transferType)
 Prepares the eDMA transfer structure.
status_t EDMA_SubmitTransfer (edma_handle_t *handle, const edma_transfer_config_t *config)
 Submits the eDMA transfer request.
void EDMA_StartTransfer (edma_handle_t *handle)
 eDMA starts transfer.
void EDMA_StopTransfer (edma_handle_t *handle)
 eDMA stops transfer.
void EDMA_AbortTransfer (edma_handle_t *handle)
 eDMA aborts transfer.
void EDMA_HandleIRQ (edma_handle_t *handle)
 eDMA IRQ handler for the current major loop transfer completion.
◆ FSL_EDMA_DRIVER_VERSION
eDMA driver version
Version 2.4.3.
Typedef Documentation
◆ edma_callback
This callback function is called in the EDMA interrupt handle. In normal mode, run into callback function means the transfer users need is done. In scatter gather mode, run into callback function means a transfer control block (tcd) is finished. Not all transfer finished, users can get the finished tcd numbers using interface EDMA_GetUnusedTCDNumber.
Parameters
handleEDMA handle pointer, users shall not touch the values inside.
userDataThe callback user parameter pointer. Users can use this parameter to involve things users need to change in EDMA callback function.
transferDoneIf the current loaded transfer done. In normal mode it means if all transfer done. In scatter gather mode, this parameter shows is the current transfer block in EDMA register is done. As the load of core is different, it will be different if the new tcd loaded into EDMA registers while this callback called. If true, it always means new tcd still not loaded into registers, while false means new tcd already loaded into registers.
tcdsHow many tcds are done from the last callback. This parameter only used in scatter gather mode. It tells user how many tcds are finished between the last callback and this.
◆ edma_tcd_t
eDMA TCD.
This structure is same as TCD register which is described in reference manual, and is used to configure the scatter/gather feature as a next hardware TCD.
◆ edma_transfer_config_t
This structure configures the source/destination transfer attribute.
◆ anonymous enum
anonymous enum
kEDMA_DoneFlag
DONE flag, set while transfer finished, CITER value exhausted
kEDMA_ErrorFlag
eDMA error flag, an error occurred in a transfer
kEDMA_InterruptFlag
eDMA interrupt flag, set while an interrupt occurred of this channel
◆ anonymous enum
anonymous enum
Bus error on destination address
Bus error on the source address
Error on the Scatter/Gather address, not 32byte aligned.
NBYTES/CITER configuration error
Destination offset not aligned with destination size
Destination address not aligned with destination size
Source offset not aligned with source size
Source address not aligned with source size
Error channel number of the cancelled channel number
Channel priority is not unique.
Transfer cancelled
kEDMA_ValidFlag
No error occurred, this bit is 0. Otherwise, it is 1.
◆ anonymous enum
anonymous enum
TCD queue is full.
kStatus_EDMA_Busy
Channel is busy and can't handle the transfer request.
◆ _edma_bandwidth
Bandwidth control.
No eDMA engine stalls.
eDMA engine stalls for 4 cycles after each read/write.
eDMA engine stalls for 8 cycles after each read/write.
◆ _edma_channel_link_type
Channel link type.
kEDMA_LinkNone
No channel link
kEDMA_MinorLink
Channel link after each minor loop
kEDMA_MajorLink
Channel link while major loop count exhausted
◆ _edma_interrupt_enable
Enable interrupt while channel error occurs.
Enable interrupt while major count exhausted.
Enable interrupt while major count to half value.
◆ _edma_modulo
kEDMA_ModuloDisable
Disable modulo
kEDMA_Modulo2bytes
Circular buffer size is 2 bytes.
kEDMA_Modulo4bytes
Circular buffer size is 4 bytes.
kEDMA_Modulo8bytes
Circular buffer size is 8 bytes.
kEDMA_Modulo16bytes
Circular buffer size is 16 bytes.
kEDMA_Modulo32bytes
Circular buffer size is 32 bytes.
kEDMA_Modulo64bytes
Circular buffer size is 64 bytes.
Circular buffer size is 128 bytes.
Circular buffer size is 256 bytes.
Circular buffer size is 512 bytes.
kEDMA_Modulo1Kbytes
Circular buffer size is 1 K bytes.
kEDMA_Modulo2Kbytes
Circular buffer size is 2 K bytes.
kEDMA_Modulo4Kbytes
Circular buffer size is 4 K bytes.
kEDMA_Modulo8Kbytes
Circular buffer size is 8 K bytes.
Circular buffer size is 16 K bytes.
Circular buffer size is 32 K bytes.
Circular buffer size is 64 K bytes.
Circular buffer size is 128 K bytes.
Circular buffer size is 256 K bytes.
Circular buffer size is 512 K bytes.
kEDMA_Modulo1Mbytes
Circular buffer size is 1 M bytes.
kEDMA_Modulo2Mbytes
Circular buffer size is 2 M bytes.
kEDMA_Modulo4Mbytes
Circular buffer size is 4 M bytes.
kEDMA_Modulo8Mbytes
Circular buffer size is 8 M bytes.
Circular buffer size is 16 M bytes.
Circular buffer size is 32 M bytes.
Circular buffer size is 64 M bytes.
Circular buffer size is 128 M bytes.
Circular buffer size is 256 M bytes.
Circular buffer size is 512 M bytes.
kEDMA_Modulo1Gbytes
Circular buffer size is 1 G bytes.
kEDMA_Modulo2Gbytes
Circular buffer size is 2 G bytes.
◆ _edma_transfer_size
Source/Destination data transfer size is 1 byte every time
Source/Destination data transfer size is 2 bytes every time
Source/Destination data transfer size is 4 bytes every time
Source/Destination data transfer size is 8 bytes every time
Source/Destination data transfer size is 16 bytes every time
Source/Destination data transfer size is 32 bytes every time
◆ _edma_transfer_type
eDMA transfer type
Transfer from memory to memory
Transfer from peripheral to memory
Transfer from memory to peripheral
Transfer from Peripheral to peripheral
◆ EDMA_AbortTransfer()
void EDMA_AbortTransfer ( edma_handle_t handle)
This function disables the channel request and clear transfer status bits. Users can submit another transfer after calling this API.
Parameters
handleDMA handle pointer.
brief eDMA aborts transfer.
param handle DMA handle pointer.
◆ EDMA_ClearChannelStatusFlags()
void EDMA_ClearChannelStatusFlags ( DMA_Type base,
uint32_t  channel,
uint32_t  mask
Parameters
baseeDMA peripheral base address.
channeleDMA channel number.
maskThe mask of channel status to be cleared. Users need to use the defined _edma_channel_status_flags type.
brief Clears the eDMA channel status flags.
param base eDMA peripheral base address. param channel eDMA channel number. param mask The mask of channel status to be cleared. Users need to use the defined _edma_channel_status_flags type.
◆ EDMA_CreateHandle()
void EDMA_CreateHandle ( edma_handle_t handle,
DMA_Type base,
uint32_t  channel
This function is called if using the transactional API for eDMA. This function initializes the internal state of the eDMA handle.
Parameters
handleeDMA handle pointer. The eDMA handle stores callback function and parameters.
brief Creates the eDMA handle.
param handle eDMA handle pointer. The eDMA handle stores callback function and parameters. param base eDMA peripheral base address. param channel eDMA channel number.
◆ EDMA_Deinit()
void EDMA_Deinit ( DMA_Type base)
This function gates the eDMA clock.
Parameters
brief Deinitializes the eDMA peripheral.
◆ EDMA_DisableChannelInterrupts()
void EDMA_DisableChannelInterrupts ( DMA_Type base,
uint32_t  channel,
uint32_t  mask
Parameters
maskThe mask of the interrupt source to be set. Use the defined edma_interrupt_enable_t type.
brief Disables the interrupt source for the eDMA transfer.
param base eDMA peripheral base address. param channel eDMA channel number. param mask The mask of the interrupt source to be set. Use the defined edma_interrupt_enable_t type.
◆ EDMA_EnableChannelInterrupts()
void EDMA_EnableChannelInterrupts ( DMA_Type base,
uint32_t  channel,
uint32_t  mask
Parameters
maskThe mask of interrupt source to be set. Users need to use the defined edma_interrupt_enable_t type.
brief Enables the interrupt source for the eDMA transfer.
param base eDMA peripheral base address. param channel eDMA channel number. param mask The mask of interrupt source to be set. Users need to use the defined edma_interrupt_enable_t type.
◆ EDMA_GetChannelStatusFlags()
uint32_t EDMA_GetChannelStatusFlags ( DMA_Type base,
uint32_t  channel
Parameters
Returns
The mask of channel status flags. Users need to use the _edma_channel_status_flags type to decode the return variables.
brief Gets the eDMA channel status flags.
param base eDMA peripheral base address. param channel eDMA channel number. return The mask of channel status flags. Users need to use the _edma_channel_status_flags type to decode the return variables.
◆ EDMA_GetDefaultConfig()
void EDMA_GetDefaultConfig ( edma_config_t config)
This function sets the configuration structure to default values. The default configuration is set to the following values.
config.enableContinuousLinkMode = false;
config.enableHaltOnError = true;
config.enableRoundRobinArbitration = false;
config.enableDebugMode = false;
Parameters
configA pointer to the eDMA configuration structure.
brief Gets the eDMA default configuration structure.
This function sets the configuration structure to default values. The default configuration is set to the following values. code config.enableContinuousLinkMode = false; config.enableHaltOnError = true; config.enableRoundRobinArbitration = false; config.enableDebugMode = false; endcode
param config A pointer to the eDMA configuration structure.
◆ EDMA_GetRemainingMajorLoopCount()
uint32_t EDMA_GetRemainingMajorLoopCount ( DMA_Type base,
uint32_t  channel
This function checks the TCD (Task Control Descriptor) status for a specified eDMA channel and returns the number of major loop count that has not finished.
Parameters
Returns
Major loop count which has not been transferred yet for the current TCD.
Note
1. This function can only be used to get unfinished major loop count of transfer without the next TCD, or it might be inaccuracy.
  1. The unfinished/remaining transfer bytes cannot be obtained directly from registers while the channel is running. Because to calculate the remaining bytes, the initial NBYTES configured in DMA_TCDn_NBYTES_MLNO register is needed while the eDMA IP does not support getting it while a channel is active. In another word, the NBYTES value reading is always the actual (decrementing) NBYTES value the dma_engine is working with while a channel is running. Consequently, to get the remaining transfer bytes, a software-saved initial value of NBYTES (for example copied before enabling the channel) is needed. The formula to calculate it is shown below: RemainingBytes = RemainingMajorLoopCount * NBYTES(initially configured)
brief Gets the remaining major loop count from the eDMA current channel TCD.
param base eDMA peripheral base address. param channel eDMA channel number. return Major loop count which has not been transferred yet for the current TCD. note 1. This function can only be used to get unfinished major loop count of transfer without the next TCD, or it might be inaccuracy.
◆ EDMA_HandleIRQ()
void EDMA_HandleIRQ ( edma_handle_t handle)
This function clears the channel major interrupt flag and calls the callback function if it is not NULL.
Note: For the case using TCD queue, when the major iteration count is exhausted, additional operations are performed. These include the final address adjustments and reloading of the BITER field into the CITER. Assertion of an optional interrupt request also occurs at this time, as does a possible fetch of a new TCD from memory using the scatter/gather address pointer included in the descriptor (if scatter/gather is enabled).
For instance, when the time interrupt of TCD[0] happens, the TCD[1] has already been loaded into the eDMA engine. As sga and sga_index are calculated based on the DLAST_SGA bitfield lies in the TCD_CSR register, the sga_index in this case should be 2 (DLAST_SGA of TCD[1] stores the address of TCD[2]). Thus, the "tcdUsed" updated should be (tcdUsed - 2U) which indicates the number of TCDs can be loaded in the memory pool (because TCD[0] and TCD[1] have been loaded into the eDMA engine at this point already.).
For the last two continuous ISRs in a scatter/gather process, they both load the last TCD (The last ISR does not load a new TCD) from the memory pool to the eDMA engine when major loop completes. Therefore, ensure that the header and tcdUsed updated are identical for them. tcdUsed are both 0 in this case as no TCD to be loaded.
See the "eDMA basic data flow" in the eDMA Functional description section of the Reference Manual for further details.
Parameters
brief eDMA IRQ handler for the current major loop transfer completion.
◆ EDMA_Init()
void EDMA_Init ( DMA_Type base,
const edma_config_t config
This function ungates the eDMA clock and configures the eDMA peripheral according to the configuration structure.
Parameters
configA pointer to the configuration structure, see "edma_config_t".
Note
This function enables the minor loop map feature.
brief Initializes the eDMA peripheral.
param base eDMA peripheral base address. param config A pointer to the configuration structure, see "edma_config_t". note This function enables the minor loop map feature.
◆ EDMA_InstallTCD()
void EDMA_InstallTCD ( DMA_Type base,
uint32_t  channel,
edma_tcd_t tcd
Parameters
baseEDMA peripheral base address.
channelEDMA channel number.
tcdPoint to TCD structure.
brief Push content of TCD structure into hardware TCD register.
param base EDMA peripheral base address. param channel EDMA channel number. param tcd Point to TCD structure.
◆ EDMA_InstallTCDMemory()
void EDMA_InstallTCDMemory ( edma_handle_t handle,
edma_tcd_t tcdPool,
uint32_t  tcdSize
This function is called after the EDMA_CreateHandle to use scatter/gather feature. This function shall only be used while users need to use scatter gather mode. Scatter gather mode enables EDMA to load a new transfer control block (tcd) in hardware, and automatically reconfigure that DMA channel for a new transfer. Users need to prepare tcd memory and also configure tcds using interface EDMA_SubmitTransfer.
Parameters
tcdPoolA memory pool to store TCDs. It must be 32 bytes aligned.
tcdSizeThe number of TCD slots.
brief Installs the TCDs memory pool into the eDMA handle.
param handle eDMA handle pointer. param tcdPool A memory pool to store TCDs. It must be 32 bytes aligned. param tcdSize The number of TCD slots.
◆ EDMA_PrepareTransfer()
void EDMA_PrepareTransfer ( edma_transfer_config_t config,
void *  srcAddr,
uint32_t  srcWidth,
void *  destAddr,
uint32_t  destWidth,
This function prepares the transfer configuration structure according to the user input.
Parameters
configThe user configuration structure of type edma_transfer_t.
srcAddreDMA transfer source address.
srcWidtheDMA transfer source address width(bytes).
destAddreDMA transfer destination address.
destWidtheDMA transfer destination address width(bytes).
bytesEachRequesteDMA transfer bytes per channel request.
transferByteseDMA transfer bytes to be transferred.
transferTypeeDMA transfer type.
Note
The data address and the data width must be consistent. For example, if the SRC is 4 bytes, the source address must be 4 bytes aligned, or it results in source address error (SAE).
brief Prepares the eDMA transfer structure.
param config The user configuration structure of type edma_transfer_t. param srcAddr eDMA transfer source address. param srcWidth eDMA transfer source address width(bytes). param destAddr eDMA transfer destination address. param destWidth eDMA transfer destination address width(bytes). param bytesEachRequest eDMA transfer bytes per channel request. param transferBytes eDMA transfer bytes to be transferred. param transferType eDMA transfer type. note The data address and the data width must be consistent. For example, if the SRC is 4 bytes, the source address must be 4 bytes aligned, or it results in source address error (SAE).
◆ EDMA_PrepareTransferConfig()
void EDMA_PrepareTransferConfig ( edma_transfer_config_t config,
void *  srcAddr,
uint32_t  srcWidth,
int16_t  srcOffset,
void *  destAddr,
uint32_t  destWidth,
int16_t  destOffset,
Parameters
srcOffsetsource address offset.
destOffsetdestination address offset.
Note
brief Prepares the eDMA transfer structure configurations.
param config The user configuration structure of type edma_transfer_t. param srcAddr eDMA transfer source address. param srcWidth eDMA transfer source address width(bytes). param srcOffset source address offset. param destAddr eDMA transfer destination address. param destWidth eDMA transfer destination address width(bytes). param destOffset destination address offset. param bytesEachRequest eDMA transfer bytes per channel request. param transferBytes eDMA transfer bytes to be transferred. note The data address and the data width must be consistent. For example, if the SRC is 4 bytes, the source address must be 4 bytes aligned, or it results in source address error (SAE).
◆ EDMA_ResetChannel()
void EDMA_ResetChannel ( DMA_Type base,
uint32_t  channel
This function sets TCD registers for this channel to default values.
Parameters
Note
This function must not be called while the channel transfer is ongoing or it causes unpredictable results.
This function enables the auto stop request feature.
brief Sets all TCD registers to default values.
param base eDMA peripheral base address. param channel eDMA channel number. note This function must not be called while the channel transfer is ongoing or it causes unpredictable results. note This function enables the auto stop request feature.
◆ EDMA_SetBandWidth()
void EDMA_SetBandWidth ( DMA_Type base,
uint32_t  channel,
Because the eDMA processes the minor loop, it continuously generates read/write sequences until the minor count is exhausted. The bandwidth forces the eDMA to stall after the completion of each read/write access to control the bus request bandwidth seen by the crossbar switch.
Parameters
bandWidthA bandwidth setting, which can be one of the following:
  • kEDMABandwidthStallNone
  • kEDMABandwidthStall4Cycle
  • kEDMABandwidthStall8Cycle
brief Sets the bandwidth for the eDMA transfer.
param base eDMA peripheral base address. param channel eDMA channel number. param bandWidth A bandwidth setting, which can be one of the following: arg kEDMABandwidthStallNone arg kEDMABandwidthStall4Cycle arg kEDMABandwidthStall8Cycle
◆ EDMA_SetCallback()
void EDMA_SetCallback ( edma_handle_t handle,
void *  userData
This callback is called in the eDMA IRQ handler. Use the callback to do something after the current major loop transfer completes. This function will be called every time one tcd finished transfer.
Parameters
callbackeDMA callback function pointer.
userDataA parameter for the callback function.
brief Installs a callback function for the eDMA transfer.
param handle eDMA handle pointer. param callback eDMA callback function pointer. param userData A parameter for the callback function.
◆ EDMA_SetChannelLink()
void EDMA_SetChannelLink ( DMA_Type base,
uint32_t  channel,
This function configures either the minor link or the major link mode. The minor link means that the channel link is triggered every time CITER decreases by 1. The major link means that the channel link is triggered when the CITER is exhausted.
Parameters
linkTypeA channel link type, which can be one of the following:
  • kEDMA_LinkNone
  • kEDMA_MinorLink
  • kEDMA_MajorLink
linkedChannelThe linked channel number.
Note
Users should ensure that DONE flag is cleared before calling this interface, or the configuration is invalid.
brief Sets the channel link for the eDMA transfer.
param base eDMA peripheral base address. param channel eDMA channel number. param linkType A channel link type, which can be one of the following: arg kEDMA_LinkNone arg kEDMA_MinorLink arg kEDMA_MajorLink param linkedChannel The linked channel number. note Users should ensure that DONE flag is cleared before calling this interface, or the configuration is invalid.
◆ EDMA_SetChannelPreemptionConfig()
void EDMA_SetChannelPreemptionConfig ( DMA_Type base,
uint32_t  channel,
const edma_channel_Preemption_config_t config
This function configures the channel preemption attribute and the priority of the channel.
Parameters
configA pointer to the channel preemption configuration structure.
brief Configures the eDMA channel preemption feature.
param base eDMA peripheral base address. param channel eDMA channel number param config A pointer to the channel preemption configuration structure.
◆ EDMA_SetMajorOffsetConfig()
void EDMA_SetMajorOffsetConfig ( DMA_Type base,
uint32_t  channel,
int32_t  destOffset
Adjustment value added to the source address at the completion of the major iteration count
Parameters
channeledma channel number.
sourceOffsetsource address offset will be applied to source address after major loop done.
destOffsetdestination address offset will be applied to source address after major loop done.
brief Configures the eDMA channel TCD major offset feature.
param base eDMA peripheral base address. param channel edma channel number. param sourceOffset source address offset. param destOffset destination address offset.
◆ EDMA_SetMinorOffsetConfig()
void EDMA_SetMinorOffsetConfig ( DMA_Type base,
uint32_t  channel,
const edma_minor_offset_config_t config
The minor offset means that the signed-extended value is added to the source address or destination address after each minor loop.
Parameters
configA pointer to the minor offset configuration structure.
brief Configures the eDMA minor offset feature.
param base eDMA peripheral base address. param channel eDMA channel number. param config A pointer to the minor offset configuration structure.
◆ EDMA_SetModulo()
void EDMA_SetModulo ( DMA_Type base,
uint32_t  channel,
This function defines a specific address range specified to be the value after (SADDR + SOFF)/(DADDR + DOFF) calculation is performed or the original register value. It provides the ability to implement a circular data queue easily.
Parameters
srcModuloA source modulo value.
destModuloA destination modulo value.
brief Sets the source modulo and the destination modulo for the eDMA transfer.
param base eDMA peripheral base address. param channel eDMA channel number. param srcModulo A source modulo value. param destModulo A destination modulo value.
◆ EDMA_SetTransferConfig()
void EDMA_SetTransferConfig ( DMA_Type base,
uint32_t  channel,
const edma_transfer_config_t config,
edma_tcd_t nextTcd
This function configures the transfer attribute, including source address, destination address, transfer size, address offset, and so on. It also configures the scatter gather feature if the user supplies the TCD address. Example:
edma_transfer_t config;
config.srcAddr = ..;
config.destAddr = ..;
EDMA_SetTransferConfig(DMA0, channel, &config, &stcd);
#define DMA0
Definition: MIMXRT1052.h:17840
eDMA TCD.
Definition: fsl_edma.h:205
Parameters
configPointer to eDMA transfer configuration structure.
nextTcdPoint to TCD structure. It can be NULL if users do not want to enable scatter/gather feature.
Note
If nextTcd is not NULL, it means scatter gather feature is enabled and DREQ bit is cleared in the previous transfer configuration, which is set in the eDMA_ResetChannel.
brief Configures the eDMA transfer attribute.
This function configures the transfer attribute, including source address, destination address, transfer size, address offset, and so on. It also configures the scatter gather feature if the user supplies the TCD address. Example: code edma_transfer_t config; edma_tcd_t tcd; config.srcAddr = ..; config.destAddr = ..; ... EDMA_SetTransferConfig(DMA0, channel, &config, &stcd); endcode
param base eDMA peripheral base address. param channel eDMA channel number. param config Pointer to eDMA transfer configuration structure. param nextTcd Point to TCD structure. It can be NULL if users do not want to enable scatter/gather feature. note If nextTcd is not NULL, it means scatter gather feature is enabled and DREQ bit is cleared in the previous transfer configuration, which is set in the eDMA_ResetChannel.
◆ EDMA_StartTransfer()
void EDMA_StartTransfer ( edma_handle_t handle)
This function enables the channel request. Users can call this function after submitting the transfer request or before submitting the transfer request.
Parameters
brief eDMA starts transfer.
◆ EDMA_StopTransfer()
void EDMA_StopTransfer ( edma_handle_t handle)
This function disables the channel request to pause the transfer. Users can call EDMA_StartTransfer() again to resume the transfer.
Parameters
brief eDMA stops transfer.
◆ EDMA_SubmitTransfer()
status_t EDMA_SubmitTransfer ( edma_handle_t handle,
This function submits the eDMA transfer request according to the transfer configuration structure. In scatter gather mode, call this function will add a configured tcd to the circular list of tcd pool. The tcd pools is setup by call function EDMA_InstallTCDMemory before.
Parameters
Return values
kStatus_EDMA_SuccessIt means submit transfer request succeed.
kStatus_EDMA_QueueFullIt means TCD queue is full. Submit transfer request is not allowed.
kStatus_EDMA_BusyIt means the given channel is busy, need to submit request later.
brief Submits the eDMA transfer request.
param handle eDMA handle pointer. param config Pointer to eDMA transfer configuration structure. retval kStatus_EDMA_Success It means submit transfer request succeed. retval kStatus_EDMA_QueueFull It means TCD queue is full. Submit transfer request is not allowed. retval kStatus_EDMA_Busy It means the given channel is busy, need to submit request later.
◆ EDMA_TcdDisableInterrupts()
void EDMA_TcdDisableInterrupts ( edma_tcd_t tcd,
uint32_t  mask
Parameters
tcdPoint to the TCD structure.
brief Disables the interrupt source for the eDMA TCD.
param tcd Point to the TCD structure. param mask The mask of interrupt source to be set. Users need to use the defined edma_interrupt_enable_t type.
◆ EDMA_TcdEnableInterrupts()
void EDMA_TcdEnableInterrupts ( edma_tcd_t tcd,
uint32_t  mask
Parameters
brief Enables the interrupt source for the eDMA TCD.
◆ EDMA_TcdReset()
void EDMA_TcdReset ( edma_tcd_t tcd)
This function sets all fields for this TCD structure to default value.
Parameters
tcdPointer to the TCD structure.
Note
brief Sets all fields to default values for the TCD structure.
param tcd Pointer to the TCD structure. note This function enables the auto stop request feature.
◆ EDMA_TcdSetChannelLink()
void EDMA_TcdSetChannelLink ( edma_tcd_t tcd,
This function configures either a minor link or a major link. The minor link means the channel link is triggered every time CITER decreases by 1. The major link means that the channel link is triggered when the CITER is exhausted.
Note
Parameters
linkTypeChannel link type, it can be one of:
  • kEDMA_LinkNone
  • kEDMA_MinorLink
  • kEDMA_MajorLink
brief Sets the channel link for the eDMA TCD.
note Users should ensure that DONE flag is cleared before calling this interface, or the configuration is invalid. param tcd Point to the TCD structure. param linkType Channel link type, it can be one of: arg kEDMA_LinkNone arg kEDMA_MinorLink arg kEDMA_MajorLink param linkedChannel The linked channel number.
◆ EDMA_TcdSetMajorOffsetConfig()
void EDMA_TcdSetMajorOffsetConfig ( edma_tcd_t tcd,
int32_t  destOffset
Parameters
tcdA point to the TCD structure.
sourceOffsetsource address offset wiil be applied to source address after major loop done.
brief Configures the eDMA TCD major offset feature.
param tcd A point to the TCD structure. param sourceOffset source address offset. param destOffset destination address offset.
◆ EDMA_TcdSetMinorOffsetConfig()
void EDMA_TcdSetMinorOffsetConfig ( edma_tcd_t tcd,
A minor offset is a signed-extended value added to the source address or a destination address after each minor loop.
Parameters
brief Configures the eDMA TCD minor offset feature.
param tcd A point to the TCD structure. param config A pointer to the minor offset configuration structure.
◆ EDMA_TcdSetModulo()
void EDMA_TcdSetModulo ( edma_tcd_t tcd,
Parameters
tcdA pointer to the TCD structure.
brief Sets the source modulo and the destination modulo for the eDMA TCD.
param tcd A pointer to the TCD structure. param srcModulo A source modulo value. param destModulo A destination modulo value.
◆ EDMA_TcdSetTransferConfig()
void EDMA_TcdSetTransferConfig ( edma_tcd_t tcd,
edma_tcd_t nextTcd
The TCD is a transfer control descriptor. The content of the TCD is the same as the hardware TCD registers. The TCD is used in the scatter-gather mode. This function configures the TCD transfer attribute, including source address, destination address, transfer size, address offset, and so on. It also configures the scatter gather feature if the user supplies the next TCD address. Example:
edma_transfer_t config = {
edma_tcd_t tcd __aligned(32);
edma_tcd_t nextTcd __aligned(32);
EDMA_TcdSetTransferConfig(&tcd, &config, &nextTcd);
void EDMA_TcdSetTransferConfig(edma_tcd_t *tcd, const edma_transfer_config_t *config, edma_tcd_t *nextTcd)
Definition: fsl_edma.c:492
Parameters
nextTcdPointer to the next TCD structure. It can be NULL if users do not want to enable scatter/gather feature.
Note
TCD address should be 32 bytes aligned or it causes an eDMA error.
If the nextTcd is not NULL, the scatter gather feature is enabled and DREQ bit is cleared in the previous transfer configuration, which is set in the EDMA_TcdReset.
brief Configures the eDMA TCD transfer attribute.
The TCD is a transfer control descriptor. The content of the TCD is the same as the hardware TCD registers. The TCD is used in the scatter-gather mode. This function configures the TCD transfer attribute, including source address, destination address, transfer size, address offset, and so on. It also configures the scatter gather feature if the user supplies the next TCD address. Example: code edma_transfer_t config = { ... } edma_tcd_t tcd __aligned(32); edma_tcd_t nextTcd __aligned(32); EDMA_TcdSetTransferConfig(&tcd, &config, &nextTcd); endcode
param tcd Pointer to the TCD structure. param config Pointer to eDMA transfer configuration structure. param nextTcd Pointer to the next TCD structure. It can be NULL if users do not want to enable scatter/gather feature. note TCD address should be 32 bytes aligned or it causes an eDMA error. note If the nextTcd is not NULL, the scatter gather feature is enabled and DREQ bit is cleared in the previous transfer configuration, which is set in the EDMA_TcdReset.
Variable Documentation
◆ ATTR
ATTR register, source/destination transfer size and modulo
◆ base
DMA_Type* _edma_handle::base
◆ BITER
BITER register, begin minor loop count.
◆ callback
Callback function for major count exhausted.
◆ channel
◆ channelPriority
Channel priority
◆ CITER
CITER register, current minor loop numbers, for unfinished minor loop.
◆ CSR
CSR register, for TCD control status
◆ DADDR
DADDR register, used for destination address
◆ destAddr
Destination data address.
◆ destOffset
Sign-extended offset applied to the current destination address to form the next-state value as each destination write is completed.
◆ destTransferSize
Destination data transfer size.
◆ DLAST_SGA
DLASTSGA register, next tcd address used in scatter-gather mode
◆ DOFF
DOFF register, used for destination offset
◆ enableChannelPreemption
If true: a channel can be suspended by other channel with higher priority
◆ enableContinuousLinkMode
Enable (true) continuous link mode. Upon minor loop completion, the channel activates again if that channel has a minor loop channel link enabled and the link channel is itself.
◆ enableDebugMode
Enable(true) eDMA debug mode. When in debug mode, the eDMA stalls the start of a new channel. Executing channels are allowed to complete.
◆ enableDestMinorOffset
Enable(true) or Disable(false) destination minor loop offset.
◆ enableHaltOnError
Enable (true) transfer halt on error. Any error causes the HALT bit to set. Subsequently, all service requests are ignored until the HALT bit is cleared.
◆ enablePreemptAbility
If true: a channel can suspend other channel with low priority
◆ enableRoundRobinArbitration
Enable (true) round robin channel arbitration method or fixed priority arbitration is used for channel selection
◆ enableSrcMinorOffset
Enable(true) or Disable(false) source minor loop offset.
◆ flags
The status of the current channel.
◆ header
The first TCD index. Should point to the next TCD to be loaded into the eDMA engine.
◆ majorLoopCounts
Major loop iteration count.
◆ minorLoopBytes
Bytes to transfer in a minor loop
◆ minorOffset
Offset for a minor loop mapping.
◆ NBYTES
Nbytes register, minor loop length in bytes
◆ SADDR
SADDR register, used to save source address
◆ SLAST
SLAST register
◆ SOFF
SOFF register, save offset bytes every transfer
◆ srcAddr
Source data address.
◆ srcOffset
Sign-extended offset applied to the current source address to form the next-state value as each source read is completed.
◆ srcTransferSize
Source data transfer size.
◆ tail
The last TCD index. Should point to the next TCD to be stored into the memory pool.
◆ tcdPool
edma_tcd_t* _edma_handle::tcdPool
Pointer to memory stored TCDs.
◆ tcdSize
The total number of TCD slots in the queue.
◆ tcdUsed
The number of used TCD slots. Should reflect the number of TCDs can be used/loaded in the memory.
◆ userData
void* _edma_handle::userData
Callback function parameter.
