RTEMS 7.0-rc1
STM32U5xx_System_Private_Defines
#define HSE_VALUE   16000000U
#define MSI_VALUE   4000000U
#define HSI_VALUE   16000000U
#define VECT_TAB_OFFSET   0x00000000UL
◆ HSE_VALUE
Value of the External oscillator in Hz
◆ HSI_VALUE
Value of the Internal oscillator in Hz
◆ MSI_VALUE
◆ VECT_TAB_OFFSET
< Uncomment the following line if you need to relocate your vector Table in Internal SRAM. Vector Table base offset field. This value must be a multiple of 0x200.
