NULL, \
void _Scheduler_EDF_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Cancels a job and removes the thread from the queue context.
Definition: scheduleredfreleasejob.c:106
void _Scheduler_EDF_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Releases a EDF job.
Definition: scheduleredfreleasejob.c:69
Priority_Control _Scheduler_EDF_Map_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Gets the mapped priority map of the priority control.
Definition: scheduleredfreleasejob.c:45
Priority_Control _Scheduler_EDF_Unmap_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Gets the unmapped priority map of the priority control.
Definition: scheduleredfreleasejob.c:55
void _Scheduler_EDF_SMP_Yield(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Performs the yield of a thread.
Definition: scheduleredfsmp.c:806
void _Scheduler_EDF_SMP_Start_idle(const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu)
Starts an idle thread.
Definition: scheduleredfsmp.c:841
void _Scheduler_EDF_SMP_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes the node with the given priority.
Definition: scheduleredfsmp.c:121
void _Scheduler_EDF_SMP_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Updates the priority of the node.
Definition: scheduleredfsmp.c:647
void _Scheduler_EDF_SMP_Unpin(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu)
Unpin thread operation.
Definition: scheduleredfsmp.c:883
void _Scheduler_EDF_SMP_Clean_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Cleans the sticky property from the node.
Definition: scheduleredfsmp.c:733
void _Scheduler_EDF_SMP_Unblock(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Unblocks the thread.
Definition: scheduleredfsmp.c:609
void _Scheduler_EDF_SMP_Initialize(const Scheduler_Control *scheduler)
Initializes the context of the scheduler control.
Definition: scheduleredfsmp.c:111
void _Scheduler_EDF_SMP_Block(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Blocks the thread.
Definition: scheduleredfsmp.c:541
Thread_Control * _Scheduler_EDF_SMP_Remove_processor(const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
Removes an idle thread from the given cpu.
Definition: scheduleredfsmp.c:788
void _Scheduler_EDF_SMP_Pin(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu)
Pin thread operation.
Definition: scheduleredfsmp.c:859
bool _Scheduler_EDF_SMP_Ask_for_help(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Asks for help operation.
Definition: scheduleredfsmp.c:668
void _Scheduler_EDF_SMP_Reconsider_help_request(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Reconsiders help operation.
Definition: scheduleredfsmp.c:679
void _Scheduler_EDF_SMP_Add_processor(const Scheduler_Control *scheduler, Thread_Control *idle)
Adds processor.
Definition: scheduleredfsmp.c:772
void _Scheduler_EDF_SMP_Make_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Makes the node sticky.
Definition: scheduleredfsmp.c:718
void _Scheduler_EDF_SMP_Withdraw_node(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
Withdraws node operation.
Definition: scheduleredfsmp.c:695
Status_Control _Scheduler_EDF_SMP_Set_affinity(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node, const Processor_mask *affinity)
Checks if the processor set of the scheduler is the subset of the affinity set.
Definition: scheduleredfsmp.c:906
void _Scheduler_default_Node_destroy(const Scheduler_Control *scheduler, Scheduler_Node *node)
Does nothing.
Definition: schedulerdefaultnodedestroy.c:45
