RTEMS 7.0-rc1
Modules | Files | Macros
This group contains the architecture-independent support modules shared across all BSPs. More...
 BSP-Specific Fatal Codes
 This group contains fatal codes for RTEMS_FATAL_SOURCE_BSP.
 Bootcard
 Standard system startup.
 Console Driver Support
 This group contains the console driver support modules.
 Default BSP Initial Extension
 This group contains the default BSP initial extension.
 GRLIB
 Driver support for GRLIB IP Library.
 Linker Symbols and Sections
 This group provides support for BSP-specific linker symbols and sections.
 MicroMonitor
 shared_umon MicroMonitor (uMon) Bootloader Support
 RTC
 Set the RTC.
 Task Stack Allocator
 Task stack initialization, allocation and free functions.
 U_BOOT Support
 U_BOOT Support Package.
file  irq-default.h
file  utility.h
 This header file provides utility macros for BSPs.
file  xil-compat-common.h
 This header file provides a minimal shim for Xilinx drivers.
file  arm-generic-timer.h
 Header defining architecture-specific clock functions.
file  xilinx_versal.h
 Xilinx Versal Peripheral memory map.
file  xilinx_zynqmp.h
 Xilinx Zynq Ultrascale+ MPSoC Peripheral memory map.
file  bspfatal-default.c
 This source file contains the implementation of bsp_fatal_extension().
file  bspsmp-arm-psci.c
 PSCI-based BSP CPU start.
#define BSP_INTERRUPT_VECTOR_COUNT   1
 This constant defines the default interrupt vector count.
◆ BSP_INTERRUPT_VECTOR_COUNT
By default, no interrupt vectors are supported and all related directives return RTEMS_INVALID_ID.
