RTEMS 7.0-rc1
Files | Macros | Typedefs | Functions | Variables
ERC32 Board Support Package. More...
file  btimer.c
 This file contains the Benchmark Timer support for the ERC32 BSP.
file  bsp.h
 Global BSP definitions.
file  irqimpl.h
 This header file provides interfaces used by the interrupt support implementation.
file  bspdelay.c
 This file contains the implementation of the delay mechanisms for ERC32.
file  bspidle.c
 This file contains the idle thread with power-down function.
file  bspsmp.c
 This file contains the Symmetric Multiprocessing (SMP) support for ERC32.
file  bspstart.c
 This file contains the shared BSP startup code for ERC32.
file  erc32mec.c
 This file contains the ERC32 Memory Error Controller (MEC) support.
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "sonic1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_erc32_sonic_driver_attach
typedef void(* bsp_shared_isr) (void *arg)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
int rtems_erc32_sonic_driver_attach (struct rtems_bsdnet_ifconfig *config)
void SPARC_Clear_and_unmask_interrupt (rtems_vector_number vector)
void BSP_fatal_exit (uint32_t error)
void rtems_bsp_delay (int usecs)
void console_outbyte_polled (int port, unsigned char ch)
int console_inbyte_nonblocking (int port)
int RAM_START
int RAM_END
int RAM_SIZE
int PROM_START
int PROM_END
int PROM_SIZE
int CLOCK_SPEED
int end
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
◆ console_inbyte_nonblocking()
int console_inbyte_nonblocking ( int  port)
This method polls the specified port for an input character. console port.
Parameters
[in]portis the input port
Returns
This method returns the character read of -1 if there is no data.
